Staro 27.11.2018., 20:54   #4891
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Staro 28.11.2018., 09:33   #4892
Postovi: 8,284
Chiplet Based Designs are Gaining Momentum
While AMD recently gained notoriety for using a "chiplet" based design in their EPYC CPUs, Semiconductor Engineering says that numerous other companies are working on chiplet-based products. The report claims that Marvell is actually the first, and only, company to deploy the chiplet concept commercially so far, but a senior director at the company said "Next year you’ll be hearing a lot more about chiplets." Multiple industry leaders claim that the chiplet approach is becoming more viable as Moore's Law "comes to a grinding halt." Nevertheless, there are still some major hurdles to overcome with multi-chip designs, like added testing complexities, packaging concerns, and managing IPs from different vendors, among many others. But Semi Engineering's experts seem to think chiplets are the next logical step in silicon chip design, and their opinions are worth a read.
Izvor: [H]ard|OCP i Semiconductor Engineering
Staro 30.11.2018., 16:36   #4893
ShebY
ShebY's Avatar
Lokacija: Velika / Osijek
Postovi: 1,442
Jedan dugometražni Škot
Staro 30.11.2018., 21:09   #4894
Gigi1
Postovi: 2,138
Jos jedna njegova spekulacija na mjestu, bas dobar watch dok doma nema zene
Nadam se da ce tako i biti, jedino kod chipleta me zanima kako ce rijesitiproblem hoppanja, pretpostavljam mirror cachem.
Inace navi 10 negdje izmedju rtx2070 i rtx2080 za vj. cca 2500-3500kn
Staro 30.11.2018., 21:11   #4895
Postovi: 8,284
Dresdenski šrot (s tim da se ovaj put ništa ne baca) vs. Intelovih all-core 5.0GHz+
vs.
Staro 01.12.2018., 22:54   #4896
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
AMD Ryzen 3000 cpus X570 chipset and pcie Gen4 support
Staro 04.12.2018., 23:15   #4897
Litra
Litra's Avatar
Lokacija: Zagreb, Dubrava
Postovi: 502
Evo video od škota s vrlo zanimljivim informacijama
https://www.youtube.com/watch?v=PCdsTBsH-rI
Litra je offline   Reply With Quote
Staro 04.12.2018., 23:34   #4898
ShebY
ShebY's Avatar
Postovi: 1,442
Molim bogove hardwarea da je ovo istina, kako dobro to sve zvuči.
Staro 04.12.2018., 23:55   #4899
Facelessone
Facelessone's Avatar
Postovi: 4,204
Sve zvuči odlično, mislim da bi krajem godine moglo taman biti vrijeme za promjenu platforme
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 05.12.2018., 00:31   #4900
Gigi1
Postovi: 2,138
fresh news, adored tv yt account has been hacked!
Staro 05.12.2018., 05:11   #4901
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,291
Ovi škotovi leakovi zvuče nevjerojatno, em ludilo sa Ryzenima za koje jednostavno odbijam vjerovat da će ići sa 16/32, em sa Navi koji će napast nVidiaine pandane u vj najprodavanijem segmentu sa osjetno nižim cijenama i potrošnjom. Ja bi prije rekao da će Ryzen 9 biti 12/24 ili 10/20 (pogotovo mi nema smisla toliko jezgri za mainsteram tržište ako postižu clockove od 5ghz), ovi ostali se neće mjenjat tj mjenjat će samo clock i IPC, latencije, RAM kompatibilnost... Volio bi da sam u krivu. Za GPU ne znam više što misliti, toliko puta su obećavali sve i svašta pa je bila kifla..
Jako bi volio da se varam, ako bude imalo blizu ovoga i za CPU i GPU mislim da ću pocrvenit svoju konfiguraciju
Slobodno me dodajte na PSN
Staro 05.12.2018., 09:07   #4902
Postovi: 8,284
Ryzen 5 8C/16T + iGPU, a kamoli da ostatak ponude ispadne (a moglo bi) po škoCkim nagađanjima i pretpostavkama.
Staro 05.12.2018., 09:44   #4903
Gigi1
Postovi: 2,138
Ovo je brutalno dobro, 16c/32t sam ocekivao, ono oko cega sam skeptican su frekvencije za boost od 5+GHz, nadam se da ce biti tako ali dok ne vidim-ne vjerujem.
Ako stvarno bude tako to ce biti brisanje poda s intelom.
Ostaju jos dve nepoznanice, kako ce I/O die utjecat na latencije, odnosno kako su rijesili taj problem kad se spominjao ipc gain od 10/15%...
G serije mi izgledaju bas primamljivo, vjerojatno nece biti limitirane bandwithom kao dosadasnje G serije zbog pcie 4.0 i viseg stock takta za mem.controler.
Staro 05.12.2018., 10:34   #4904
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 716
I meni ovo izgleda malo predobro, ali ako se već predviđa 64/128 Threadripper onda je HEDT opet dovoljno distanciran od mainstreama pa ni 16/32 R9 više ne zvuči toliko nemoguće.
Ne sjećam se sad točno svega od kraja 2016. ... koliko je drug Škot bio točan u svim leakovima do sada (prva generacija i refresh) ?
Staro 05.12.2018., 10:41   #4905
Litra
Litra's Avatar
Postovi: 502
Ja već razmišljam ukoliko je ovo istina da piknem Ryzen 7 3700X i Radeon 3080.AMD-u je pun pogodak što su odlučili da će podržavat starije chipsete
Staro 05.12.2018., 10:47   #4906
Gigi1
Postovi: 2,138
Autor Litra Pregled postova
Kyle Bennett...
There is a whole lot of reality in that video. A lot. There is a little wrong, but not a lot.
Staro 05.12.2018., 11:01   #4907
Postovi: 8,284
Bilo bi jebeno da ne naprave ništa osim migracije na 7nm i potencijalnog podizanja radnih taktova na tih famoznih 5.0GHz. U slučaju da ispadne dijelić ovoga kaj Škot priča - dobar dan.
Staro 05.12.2018., 13:01   #4908
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,291
Autor Max Rockatansky Pregled postova
Koliko mi je poznato, dosta je bio točan o refreshu i chipletima, a za prvu generaciju nisam siguran ali mislim da mu je i tu kristalna kulga dobro pokazala...
Staro 05.12.2018., 13:07   #4909
Fap fap fap sad oću neću moraću core bump napraviti
GG AMD. Ako bude stvarno takav leap forward u taktu i IPCu, odma ide R9 onda pa da se stvarno razlika osjeti
Sent from Usreo Mobara
Staro 05.12.2018., 13:18   #4910
Postovi: 8,284
Bome i ove RX 3000 grafičke ne zvuče loše. Lako za procesore, ali ako GPU dio ispadne točan, bog-bogova, da se pomaknu s mrtve točke.
Staro 05.12.2018., 16:10   #4911
BusMaster
BusMaster's Avatar
Postovi: 343
AMD Ryzen 3000 Specs & Prices Leaked, Upto 16 Cores & 5.1GHz on AM4
https://wccftech.com/amd-ryzen-3000-...5-1ghz-on-am4/
https://www.guru3d.com/news-story/po...d-5-1-ghz.html
Hmm, evo i ovi navode taj video od Škota, možda je ovo namjerni leak pred CES -2019. Uglavnom dosada se pokazao prilično informiran, a i TSMC ima puno bolji process node od GF, nije to sve nerealno. Treba se još malo strpit do 09.01. ...
Staro 05.12.2018., 16:48   #4912
Mislite da će AMD pokazati sve karte 09.01? Ako je release May 2019, onda bi mogli nešto reći o tome. Nekako nisam optimist ali slatke brige budu između R5 ili R7 ili R9
Staro 05.12.2018., 17:06   #4913
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,748
Ma ako se ovaj core-bump pokaze tocan, jedan 3600x bi mi lega ko budali samar
8c16t + visoki taktovi + TDP od 90w = ... 3700x ne treba ni spominjati, 12c24t na 5Ghz
Staro 05.12.2018., 19:41   #4914
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Najveći fanovi se nisu usudili niti zamisliti ovakvu najavu, a adored hladno pol satni video
Kakva lista želja
..i to i na cpu i na apu i na gpu frontu
Još sam zbunjen
MojSkuter
Staro 05.12.2018., 19:54   #4915
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 716
Autor Eladio Pregled postova
Kakva lista želja
Još sam zbunjen
Prijelaz na 7nm, 4.5Ghz i 12/24 uz isti socket u mainstreamu bi već bio solidan upgrade i s pravom se može nazvati novom generacijom.
Sve preko toga je ... (nema odgovarajuće ikone ).
Staro 05.12.2018., 20:15   #4916
Postovi: 8,284
TSMC's 7nm production likely to be underutilized in 2019 as smartphone chip demand weakens
Due to a cutback in orders placed by Apple, HiSilicon and Qualcomm, concerns regarding TSMC's ability to be the sole 7nm chip fabrication tech for the industry can likely be laid to rest. That the smartphone market is reaching saturation is a well-known quantity - it's becoming harder and harder to cram new technologies that justify the yearly smartphone upgrade that most companies vie for - and one of the reasons for the launch of various brand-specific smartphone subscription services. The difference isn't scandalous - TSMC will still be making use of 80-90% of its total 7nm process capacity during the first half of 2019.
Izvor: DigiTimes i TechPowerUp
U prijevodu, AMD bi (uz nVidiju i ostatak društva) fino mogel popuniti rupu u 7nm narudžbama, a ako se realizira sve ili barem većina ovog kaj Škot priča - Lisi Su ne gine neki spomenik.
Staro 06.12.2018., 00:01   #4917
Manuel Calavera
Postovi: 14,584
Nvidiju skine 100% (pascal je snagu pogodio u bobu skoro godinu dana prije izlaska, a za RTX je imao excluzivni leak sa burner e-maila, pa je morao procjeniti dali je istina ili ne tj. dali objaviti pa se osramoiti ili proslaviti).
Za chiplete u zen2 tj. Rome epyc je imao isto izvor (kao i tip iz semi accurate).
Sa AMD gpu i nije baš toliko precizan bio, polaris nije dugo uspio pročitat (tko bi pomislio da će biti samo mainstream) pa se dugo "kalibrirao", no blizu izlaska je naravno sve znao točno. Vegu je rano pročitao da će doći kasno, te da će biti razočarenje za gaming (nakon famozne prezentacije u 1. mjesecu), no to je bilo lako skužiti za vegu, znao sam to i sam mjesecima prije izlaska.
Za ovaj video je rekao "grain of salt". Osobno ne vjerujem da će postojati Navi snage RX 580 da se hrani iz pci-e slota, no way jose.
Ovo ostalo manje više stoji prema dosadašnjim procjenama (da najjači Navi bude u rangu ~ gtx 1080/rtx 2070, on kaže malo jače no vidjet ćemo).
Što se tiče ryzena rekao je da će 16c32t morati ići na nove čipsete vjerojatno, jer probija trenutne specifikacije, no na postojeće će ići 12c24t... Vjerujem da je moguć 16c32t, no ne vjerujem u te visoke clockove s druge strane (išta preko 4.5ghz na bilo kojem modelu)
Što se tiče APU-a tu ne kužim baš situaciju, jer đaba xy CU Navija ako ne rješe problem memory bandwidtha, pod die jednostavno mora ići hbm2 memorija ako integruša misli biti iole značajnije jača. Ne može se to sa sistemskim ramom nahranit
Zadnje izmijenjeno od: Manuel Calavera. 06.12.2018. u 00:12.
Staro 06.12.2018., 00:56   #4918
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
.vise manje sam i ja ovako suzdrzan kao i ti.
Slazem se da sistemska memorija koci apu, to se vec osjeti sada na R5 2400g. Bez ddr5 ili neke hbm kombinacije realno prostora za veci napredak ne vidim. Ipak oni ni ne pucaju na na to, skok kakav takav + i dobra priprema za AM5
Testovi će pokazat vjerojatno da je neki postotak pomaka, za nezahtjevne super, a za ozbiljniji gaming ce i dalje mnogi ici na dedicated grafu..da stave hbm2 nebi im ni trebao dedicated mali polaris ..imaju vremena za te vece skokove tu su ionako bez konkurencije.
Ali tu su ovi drugi "pomaci" na cpu frontu..
Nor. moja ploča ima naponsku regulaciju takvu kao da je rađena za taj navodni R9 ..imam i onaj spomenuti drugi "4pin" koji trenutno nisam ni spojio i odlično hladjenje oko socketa (ipak ju necu prodati još lol)
..cijeli cpu line up mi ajmo reći generalno ima logike.
CPU taktovi su mozda napuhani.. ali to mi tesko mozemo nagađati.
Navi , tu pojma nemam sta misliti. Opet zanimljivo imenovanje modela hehe.
Ali čudno su izbacili rx 590 ako je ovo istina..
Uglavnom, ova efikasnost izgleda brutalno. Pa cak i da mali navi probije "75"w . Nije nemoguće, ipak je 7nm, i gddr6
Sad kad krene rasprodaja Polarisa hjoj
Sve ostalo isto nije nemoguće ..
Adoredtv
..ima inace dobre procjene sve u svemu. Cak i za dionice LoL. Sve tri put provjerava, sumnja u sve, i u vlastite izvore, ima taj nepotkupljiv stav i kritican je prema svima i sebi.
Zato se nadam da ce u većini biti blizu ili skroz u pravu
Ali lopata soli i svejedno čekam prve testove
MojSkuter
Zadnje izmijenjeno od: Eladio. 06.12.2018. u 01:16.
Staro 06.12.2018., 01:35   #4919
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 716
Hvala na iscrpnom odgovoru.
Ne kužim ovaj dio za chipset ... zašto baš razlika između 12 i 16 ?
Da, taktovi zvuče nevjerojatno ali još više Threadripper modeli, ispada da bi pokopali 29xx modele unutar godinu dana jer više nema odgađanja kao sa 1950X (pola Epyca) pa tek u refreshu svih 32-core u 2990WX, nego odmah puštaju sve sa lanca odnosno idu na max., 64/128. Nelogično mi samo izgleda da 3920X bude 32/64 a ne 24/48 ili da 64/128 idu cijepat na 2 odnosno 3 modela - bundle sa vodenim od 500$ !?.
Nije da se bunim, posebno kad pogledam i cijene, ali kako je Eladio napisao - ovo stvarno izgleda kao popis želja. Do prije par godina 128 threadova je bila mala render-farma
Staro 06.12.2018., 07:28   #4920
Gigi1
Postovi: 2,138
Ne vidim razlog zasto mali navi ne bi mogao imati rx580 perf na pcie only poweru.
Sami polarisi su voljeli undervolt, vege jos i vise jer su u startu bili napucani kako bi konkurirali nvda.
Undervoltanjem gcn4/5 se ne gubi toliko perf koliko se smanji potrosnja, isto tako gcn arch obozava mem.propusnost, tako da ce navi profitirati sa gddr6 u pogledu vecih perf. i nize potrosnje,na to se doda cip manje povrsine+veca eff nove arch...sasvim moguce da ce postojati 75W navi sa perf polaris10/20 4gb
Edit.
ovo je sa sapp rx580 nitro+, sapp kod nitrica stavlja visi tdp od vecine ostali(150)
Ako gddr6 donosi 30/35% nizu potrosnju naspram gddr5 onda umjesto cca 30W, mem ce trositi 20W. Znaci ostaje jos 50/55W za cip. Tsmc kaze 7nm 40% power reduction, znaci jos cca 50W dolje, sto znaci da amd sa navi arch mora izvuc jos cca 15/20% u ipc/taktovima naspram polarisa i to bez da se racuna gddr6 boost koji se dobije. Kad se to stavi rekao bih negdje izmedju 10/15% da amd mora izvuci.
Nije nemoguce.
Pisem s moba pa sam mozda i fulao negdje u racunu
Zadnje izmijenjeno od: Gigi1. 06.12.2018. u 08:36.
