Staro 09.11.2018., 21:18   #2971
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,580
Dobio T450s i moram priznat da mi je bolje sjeo nego T530. Kompaktniji je, tipkovnica i trackpad su mi puno bolji. Baš mala zvjerka. Za sada imam samo pohvale
Staro 09.11.2018., 22:05   #2972
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Napiši specke pa ćemo te uputiti u nadogradnje
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 09.11.2018., 22:22   #2973
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,063
... jer ako nešto ne promijeniš, ne smiješ u ovoj temi napisati više od jednog posta mjesečno
PS. Za novi stroj
Zadnje izmijenjeno od: bertone. 10.11.2018. u 02:15.
Staro 10.11.2018., 10:21   #2974
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,580
T450s: i7-5600U, 8gb, 256gb ssd, full hd 14"
T530: neki i5, 8gb, 256gb ssd, 1600x900 15,6"
Za nošenje nebo i zemlja razlika. 450s ima neš malo preko 1,5 kg, a 530 je ipak cigla
Staro 10.11.2018., 10:25   #2975
Dottore
Dottore's Avatar
Postovi: 7,703
T530 je cigla ali i mrcina kad može ugraditi i7 QM nego T450s. Robustan i lakše nadograđuje
Отправлено через SM-N950FD
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 10.11.2018., 18:33   #2976
ThePornstar
Postovi: 4,403
Autor bertone Pregled postova
Taaaaako je! Go hard or go home
Autor Juice Pregled postova
Od kud da počnem?
Zezam se. Već sad su fine konfe, ali imaš mjesta za neke finese
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 10.11.2018., 20:05   #2977
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,580
Autor Dottore Pregled postova
Za službenog je daleko nespretniji kad ti je svaki dan na ramenu i u pokretu.
Kao kućni je mrcina slažem se,
Staro 18.11.2018., 16:37   #2978
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,799
Programer
Staro 18.11.2018., 17:38   #2979
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,293
Pravo fino je izemulirao win
Ibm-ov case budi nostalgiju.
Staro 18.11.2018., 17:58   #2980
thubanx6
thubanx6's Avatar
Datum registracije: Aug 2011
Postovi: 533
jel imao netko prilike isprobat t480S ?
Izgleda kao dosta dobar paket snage s obzirom na masu. Samo me brine da li je filing tipkanja znatno degradiran radi malo smanjenog hoda u odnosu na npr X230 i P50 koje imam.
S obzirom na snagu novih quadcore ULV-ova čini mi se da bi mi takav stroj mogao odradit znatnu količinu posla.
thubanx6 je offline   Reply With Quote
Staro 18.11.2018., 18:22   #2981
bertone
bertone's Avatar
Postovi: 2,063
NetVista Ryzen edition
... ima ovdje malo više pikčr istog kompa:
https://imgur.com/a/7vmtx9k#qJGF0gT
https://imgur.com/gallery/t6HiO
Zadnje izmijenjeno od: bertone. 18.11.2018. u 18:36.
Staro 18.11.2018., 21:23   #2982
orson
Postovi: 129
Autor thubanx6 Pregled postova
Ako ti nije hitno, ja bih kroz tjedan-dva trebao dobiti T480s 20L7001HSC, a trenutno radim na X230 pa ću moći usporediti. Inače, smanjeni hod ne mora nužno značiti loš osjećaj tipkanja, type cover za Microsoftov Surface 5/6 tablet ima dosta mali hod tipki, ali je meni osjećaj tipkanja odličan.
orson je offline   Reply With Quote
Staro 18.11.2018., 23:04   #2983
thubanx6
thubanx6's Avatar
Postovi: 533
Autor orson Pregled postova
Ma kakvi hitno. Ionako bi čekao jeftine refurbove po njuškalu
Ali mi se čini dosta dobro pogođen stroj generalno. Javi sve moguće dojmove čim ti dođe.
Također, ako ti naleti mushy mekana tipkovnica postoji šansa da je možeš zamijenit za bolju.
Neki dolaze s liteon, neki s chicony tipkovnicama. Kažu da je liteon bolji.
Na P seriji su konzistentni,sve tipkovnice su jednake i jednako vrhunske. Pa nema tih problema.
EDIT:
Btw kupio si novi ili već ima izložbeni primjerak/refurb izvora?
Staro 19.11.2018., 09:22   #2984
..::Matej::..
..::Matej::..'s Avatar
Postovi: 391
Ima netko mozda iskustva s t480s (20L7001HSC)? Trenutno imam p51 (20HH0014SC+24gb+2tb hdd+512gb ssd), ali zbog čestih putovanja avionom u potrazi sam za manjim i lakšim laptopom. Izbor sam sveo na t480s, t480 (20L50057SC ), X1 (20KH006JSC) i mozda cak i t580 (20L90026SC). Nekako mi t480s po specifikacijama najviše odgovara, ali čitam po netu da se ljudi bune na pregrijavanje i da touch pad zeza.
Laptop u 50% vremena koristim za web u ostalo 50% vremena za Lightroom, Photoshop, AutoCAD...
..::Matej::.. je offline   Reply With Quote
Staro 19.11.2018., 12:05   #2985
thubanx6
thubanx6's Avatar
Postovi: 533
Autor ..::Matej::.. Pregled postova
Poviše sam pitao istu stvar... na redditu sam otvorio temu vezanu za feel rada na t480s vs P serija kao P50 koji mi je sad glavni stroj.
https://www.reddit.com/r/thinkpad/co...51_willing_to/
Zaključak je... iako bi trebalo testirat za bit pametan. 480s je jako dobar ultrabook ali nije mobile workstation i ja osobno za dobar dio posla vjerojatno nebi bio zadovoljan s korisničkim iskustvom. On peak snage ima dosta ali vrlo je upitno kako se nosi sa konzistentnim opterečenjem kao video editiranje, autocad itd...
Druga stvar je, tipkovnica vjerojatno ima malo lošiji filing radi kračeg hoda, manji je, ima samo 2 usb-A porta. Meni bi sve skupa to bila dovoljna degradacija iskustva da ga nebi mogao koristit kao "A" mašinu. Ali kao ultrabook je vjerojatno fenomenalan.
Ako ga probaš pored P51 javi dojmove obavezno.
Ako budeš prodavao taj P51 također se javi
Staro 19.11.2018., 12:32   #2986
orson
Postovi: 129
Imat ću ja uskoro pa napišem. Osim za touchpad, njega ne koristim.
Što se tiče modela, i ja sam razmatrao sve koje si naveo i T480s mi ispada najbolja kombinacija onoga što tražim: 14" što je meni optimalno za laptop, dobar balans debljine, mase, količine portova i kvalitete izrade, memorija proširiva do 24 GB, WQHD ekran, LTE modem. U kombinaciji s Lenovovim 24" P24h WQHD monitorom koji ima USB-C neće mi trebati dock jer se sve (osim mreže) spaja na monitor, a preko monitora se može i puniti pa ne treba biti spojen na punjač (ovo trebam isprobati u praksi). Što se tiče pregrijavanja, čitam da pomaže undervoltanje za 100 mV uz koje je rad i dalje stabilan, a temperature su niže.
Ostale sam isključio radi sljedećeg:
T480: slabija kvaliteta plastike, masa
X1C6: za mrežni priključak treba dongle, nemoguće proširiti memoriju (16 GB max, zalemljena na ploču), problemi s kvalitetom izrade (čitao na netu, može biti, a i ne mora), više throttla od T480s koji ima bolje hlađenje zato što je deblji i hlađenje je dimenzionirano za diskretnu grafiku (2 heatpipea), skuplji
T580: tipkovnica ima numerički dio pa trackpoint i tipke nisu u sredini (to me izluđuje!), masa
@thubanx6 Firma plaća pa će biti ganc novi.
Zadnje izmijenjeno od: orson. 19.11.2018. u 12:38.
Staro 19.11.2018., 12:57   #2987
thubanx6
thubanx6's Avatar
Postovi: 533
Da, super, napiši dojmove.
To za USB-c me isto dosta zanima jer bi trebalo radit. Sad imam 2715H koji bi odnio u firmu a doma bi uzeo USB-c monitor koji je ujedno USB hub i onda bi mogao ultrabook spojit preko monitora na periferiju i preko istog kabela bi mogao spojit mobile workstation samo bi njemu trebao uštekati i punjač.
U principu smanjiš clutter na stolu i imaš isti dock za dvije dosta različite mašine.
Da, trackpoint je nevjerojatan ali ima caku što traži da ga se uvježbaš koristit. Ali jednom kad sam se naučio prestao sam dirati touchpad za iša osim multi finger gesti. Nevjerojatno je praktičan i dobar alat.
Po meni su za T480S nad klasičnim t480 ključne slijedeče stvari.
1. Unatoč razlici u masi od skoro 400 grama, razlike u termalima i performansama baš i nema. Da, grafička je malo oslabljena ali ne pada mi na pamet igrati se na tom stroju pa...
2. t480s ima PCI slot za nvme disk sa 4 linije a t480 sa dvije linije radi adaptera.
3. Kvaliteta izrade je na višoj razini.
Mane u odnosu na klasični t480 su klasična baterija, za ovo me nije briga jer se ovu unutra lako zamijeni kad se istroši.
Samo jedan slot za ram. Međutim sad kad dođu 32GB moduli mislim da postoji dobra šansa da će to raditi i sa 40GB.
X1 carbon je divan ali zalemljen ram ograničen na 16GB mi je debeli dealbreaker.
Jedino što je u biti stvar je, gledam u kolikom razmjeru t480s može biti zamjena za mobile workstation.
Kao, kad bi prodao P50, nebi bilo problem komplementirati T480S stolnom mašinom koju sad više nemam. Ali ideja P50ke mi je bila, sav posao u jednoj mašini koju mogu ponijet sa sobom i to funkcionira iznimno dobro.
Teško mi je procijenit sveukupni user experience za powerusera na t480s. Trebat ću probat nekad.
EDIT:
Meni na P50 tipkovnica isto nije u centru radi numpada ali stvarno mi nikad nije bilo jasno u čemu je problem. Nisam ni primjetio dok mi netko nije rekao.
Baš mi nikako ne utječe na ugodu rada.
Staro 19.11.2018., 19:46   #2988
DR bodul
Datum registracije: Jan 2018
Lokacija: Krk
Postovi: 271
Pošto mi uskoro dolazi X240 imam par pitanja vezana za taj uređaj.
Može li se X240 nadoraditi sa dvije baterije kao što ima T440s te o čemu to ovisi?
Kako da izvučem Win licencu jer bi zamjenio HDD sa SSDom a mislim da se 10ka ne isporučuje sa onom naljepnicom sa kodom?
Konkreno se radi o ovom uređaju.
DR bodul je offline   Reply With Quote
Staro 19.11.2018., 19:53   #2989
ThePornstar
Postovi: 4,403
Prema machine numberu (20AM-S1S500), u tu konfu je već ugrađena interna baterija, ako u međuvremenu nije nešto prčkano.
Što se Win keya tiče, što misliš instalirati gore? Kako izvući key: ovdje
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 19.11.2018., 21:35   #2990
DR bodul
Lokacija: Krk
Postovi: 271
Hvala
Za sada mislim ostati na Win10, jedino bi radi startanja HDD zamjenio SSDom.
Staro 20.11.2018., 00:16   #2991
orson
Postovi: 129
Imati mašinu koja bi bila dobra za sve je utopija (kao i bicikl, za idealni setup trebaju ti barem 2, ako ne i 3 ). Doma imam X1C1 u najjačoj konfiguraciji koji je uz FHD mod bez obzira na starost još uvijek odličan stroj, ali sam za casual surf, multimediju i putovanja jučer naručio MS Surface Pro 6 tablet: upola je lakši, nečujan jer je i5 verzija pasivno hlađena pa nema ventilator, ima izvrstan 3:2 ekran i bateriju koja traje. Iako je po speckama tablet procesorski duplo jači, ne mislim da će laptop skupljati prašinu, jednostavno postoje situacije kad ga je ugodnije koristiti i vice versa.
Za tipkovnicu si sretan što ti ne smeta, meni je to koma (i nisam jedini) te nikada ne bih uzeo takav laptop. Zato je Lenovo i napravio X1 Extreme model koji, iako je 15", nema numerički dio tipkovnice.
Staro 20.11.2018., 00:29   #2992
thubanx6
thubanx6's Avatar
Postovi: 533
Potpuno se slažem. Poweruseru koji živi od računala najčešće trebaju dvije ili čak tri mašine za pokrit sve baze kako spada.
Međutim P50 mi je do sada debelo najbolji sveukupan paket. Ne postoji to što na njemu ne mogu odradit brzo i produktivno (a mogu ga nosit sa sobom). S jako visokom razinom korisničkog iskustva.
Ako zaronimo dublje, nekih 75% zadataka mi odrađuje apsolutno savršeno. U ovih 25% spadaju stvari koje traže "desktop grade" grafičke performanse.
a) Dakle gaming na visokim postavkama...
b) Fali mi činjenica što u njega ne mogu staviti pet 3.5 inčnih diskova.
c) Značilo bi mi da je nešto lakši.
Za sada sam ga nadopunio polovnim X230 tako da imam nešto lagano kad sam na bicikli i da imam backup stroj.
Idealno bi bilo da imam i stolni pc i njega i jedan T480S. Ali to je pre skupo a upitno je koliko bi koristio sve tri mašine. P50 sam debelo platio ali me ne boli jer mi radi 24 sata dnevno i manje više mi ne izlazi iz ruku.
U jednom momentu ću uzeti t480s pa ću viditi za koliko mi zadataka može zamijeniti p50 pa prema tome viditi treba li mi još nešto.
Svakome svoje, meni je kod P1 jedan od glavnih dealbreakera to što nema numpad
Zadnje izmijenjeno od: thubanx6. 20.11.2018. u 00:34.
Staro 20.11.2018., 00:35   #2993
ThePornstar
Postovi: 4,403
Zato je Lenovo i napravio X1 Extreme model koji...
... košta 28 'iljada kuna kod nas
Link
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 20.11.2018., 01:03   #2994
thubanx6
thubanx6's Avatar
Postovi: 533
Link
Doć će ti refurbovi kad tad
Staro 20.11.2018., 01:31   #2995
ThePornstar
Postovi: 4,403
Uz to što mi je skroz nezanimljiv - za te pare odem u Meriku, uzmem T480s, eksternu grafulju, provedem se i platim sva davanja pri povratku
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 20.11.2018., 09:20   #2996
medo
#erase startup-config
medo's Avatar
Postovi: 3,732
Igrao sam se s T480s i novim Carbonima. Uzeli smo ih nekoliko u firmi.
Brzi su ti 8xxx quadovi. Sa hyperthreadingom su brzi u 7zipu od mojeg T460p koji ima i5-6440HQ procesor (cca 21000 naspram 18000). Frekvencija ne pada ispod nekih 3GHz pod realnim opterećenjem. Ventilator se češće pali nego na starijim vezijama pogotovo na Carbonu. I ne zuje, lijepo šušte.
Novi dockovi su... blah. Preskupi i imaš osjećaj kao da će se sve slomiti pod pritiskom.
Staro 20.11.2018., 10:43   #2997
thubanx6
thubanx6's Avatar
Postovi: 533
Tako se i meni čini. Kao p52 stvarno ima snage da bude prijenosno stolno računalo. To te košta mase ali znaš zašto ga nosiš. A X1 extreme je kompromitiran na više načina, ne možeš stavit 2.5 disk uz SSD. Ne možeš dobit toliko ni CPU ni GPU performansi a da se hlađenje u stanju nosit s konstantnim opterečenjem. Nemaš numpad, nemaš CAT5 konektor, imaš samo dva USB-a porta.
A on je još uvjek 1.8 kila bez punjača. Nije to baš toliko lagano. Opet imaš šta nosit.
Nekako su mi ti kompromisi not worth it u odnosu na P52. Ali morao bi probat da budem pametan.
Autor medo Pregled postova
Da, zato sam ja i gledao, P50 mi je stvarno zakon ali realno postoji dobra mogučnost da bi mi T480S za dobar dio posla pružio dovoljno visoke performanse da ne osjetim neznam kakvu razliku. A pričamo o 1.3 kila...
Nego, kakva je tipkovnica u odnosu na T460P? Smanjili su hod na 1.6mm pa me to brine.
EDIT:
_ebeš dockove. Usb-c monitor, periferiju u njega i vozi
Staro 20.11.2018., 11:20   #2998
orson
Postovi: 129
Link
Hahahaha, ovlaš sam neki dan gledao po cjenicima i nisam ga našao, znao sam da će nabiti cijenu u nebo, ali baš toliko! OK, mašina je top spec, ali svejedno. U Hrvatskoj jednostavno ne možeš kupiti T ili X thinkpad po normalnoj cijeni i zato ga kupuju gotovo isključivo firme. I u Americi su skupi, pogotovo kada tek izađu, ali onda dođe black friday i kupiš zvijer za manje od soma dolara. Ja niti jedan svoj privatni nisam kupio kod nas.
Staro 20.11.2018., 12:45   #2999
thubanx6
thubanx6's Avatar
Postovi: 533
Kažem, samo refurbished. Lijepo 3 generacije star model za 20% originalne cijene. Još ga nađeš tako da je nekome stajao u docku i odmarao i miran si.
Neznam kome zdravog razuma bi palo na pamet kupovat ovo novo za takvu cijenu. Firme su druga stvar.
Staro 20.11.2018., 13:09   #3000
chillout23
Your God is in your mind.
chillout23's Avatar
Datum registracije: Jun 2017
Lokacija: Planet Earth
Postovi: 642
Di gledaš te (p)reparirane ?
Čisto da imam info, ako nekome bude trebalo nekaj...
Mjesto rođenja: Zemlja, Rasa: čovjek, Politika: sloboda, Religija: ljubav
chillout23 je offline   Reply With Quote
