Staro 22.12.2005., 22:59   #1
Razer
Razer's Avatar
Postovi: 11,642
Iskustva sa Gigabyte 6800 Silentpipe?
Namjeravam kupiti Gigabyte 6800 Silentpipe za 1350kn u linksu. Pa me zanima jel je netko ima i koja su vam iskustva. I jel se da otključati na 16/6? Ako imate koji drugi prijedlog za grafičku do 1500 recite...Ostatak konfe: 2500 Barton@2500, A7N8X Deluxe, 2*512 Kingmax HC500
Unaprijed hvala!
Staro 23.12.2005., 00:42   #2
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,507
Naravno, postoji mogućnost.
No za 1000-1100KN dobiješ 6800LE 16,6 na forumu...
Staro 23.12.2005., 01:14   #3
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Za Gigabyte 6800 Silentpipe u linksu pise "Naručeno, artikl u dolasku", kad sam ja uzimao grafulju isto je pisalo za Leadtek 6800nu i XFX 6800 Extreme Gamer zvao sam i rekli su da ih vise nece dobit jer se ne proizvode... Pa prvo nazovi links jel imaju tu grafu, ak ne, kak kaze Eddie, kupi neku otkljucanu 6800LE s foruma...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 23.12.2005., 01:40   #4
Razer
Razer's Avatar
Postovi: 11,642
6800
A posto su otkljucane 6800le na forumu...gdje da pitam tko ih ima za prodati...a sto mislite o x800gt kao alternativi? cujem dosta o toj grafičkoj-kažu da se bolesno clocka ali ima samo 8 cjevovoda...hm..
Staro 23.12.2005., 14:15   #5
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,507
Slušaj, imaš podforum tržnica, pogledaj tamo šta se nudi, ako nema ništa pokreni temu, pričekaj kojih 10 dana i već će biti neka dobra grafička. Probaj uhvatiti LE@16,6.
npr...
http://forum.pcekspert.com/showthrea...threadid=30174
Staro 23.12.2005., 17:48   #6
Razer
Razer's Avatar
Postovi: 11,642
Hvala!
