Staro 05.10.2018., 07:44   #301
Postovi: 8,223
Autor dakky Pregled postova
A kad trebam bar jos 2-3 plugina pored adblockera... mozda neki zeza, ali kako to otkriti... a i nije za ovu temu... da li bi vise coreova rijesilo problem jeste....
Privremeno isključi dodatke koje koristiš za Firefox, a možeš probati i s prijenosnom verzijom i isključivanjem/uključivanjem hardverske akceleracije.
Također provjeri da se kojim slučajem u pozadini ne vrte kojekakve (1 - 2) gadosti. Lako onda kasnije kreneš u nadogradnju, odnosno kupnju novog hardvera.
Staro 05.10.2018., 15:36   #302
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,262
A probaj i waterfox, a tu je uvijek i refresh FF-a, ali si napravi backup prije u slučaju da ne pomogne.
BTW, probaj malo i Operu, a posebno EDGE ako koristiš W10, mogao bi se ugodno iznenadit
Slobodno me dodajte na PSN
Staro 06.10.2018., 18:55   #303
Postovi: 8,223
AMD Announces Threadripper 2970WX, 2920X Availability, New Dynamic Local Mode Feature
AMD has provided an update to their continued rollout of 2nd generation Threadripper CPUs, including the 12 and 24-core variants. Both of these new Threadripper SKUs will be available starting on October 29th, for a price of $649 for the 12-core 2920X and $1299 for the 24-core 2970WX. The more surprising announcement comes in the form of a new software feature for the Threadripper WX-series processors called "Dynamic Local Mode" which aims to address some of the performance issues caused by the non-traditional memory structure of these processors, where not all CPU cores have direct access to a memory controller.
Dynamic Local Mode will run as a Windows 10 service and measure how much CPU time each thread is utilizing. This service will then begin to reallocate these demanding threads to the CPU cores which have direct memory access until it runs out of available cores. In that case, the service will start to assign threads to the remaining cores. This dynamic operation ensures for applications that aren't consuming all 48/64 threads on the WX-series processors, that direct memory access will be available when needed. In particular, this should provide an advantage to gaming, which typically takes up less than eight cores, but is dependant on fast memory access.
Users will be able to enable and disable this feature on the fly through the Ryzen Master, and it will not require a reboot unlike the existing Dynamic/Local mode toggle for the Threadripper X-seres processors.
Izvor: PC Perspective
Staro 29.10.2018., 11:18   #304
Immortalis
Slobodan leni seronja
Immortalis's Avatar
Postovi: 852
Imam ova dva kita memorije, znaci 32 gb. Stavio sam ih da rade u quad i radi bez problema.
E sad, kad bi htio dodati jos 32 gb, jel mora biti ista ili slicna memorija, sto se tice brzine, voltaze, xmp profile i tako to?
Opcenito, na sta trebam pripaziti kod kupnje dodatne memorije?
Nisam nikad imao maticnu sa 8 utora pa mi je ovo sve novo.
Hvala
Staro 29.10.2018., 11:44   #305
Postovi: 8,223
Najbolje bi bilo da kupiš identične module, tj. još jedno duplo pakiranje, jer s tim je vjerojatnost za potencijalne probleme svedena na minimum.
Zadnje izmijenjeno od: The Exiled. 29.10.2018. u 14:18.
Staro 30.11.2018., 21:26   #306
Immortalis
Immortalis's Avatar
Postovi: 852
Trebam preporuku hlađenja.
Imao sam enermax liqtech tr4 360 ali mi je krepao. Koliko citam, ova nova generacija, enermax liqtech II tr4 je puno bolja i kvalitetnija i cak bolje hladi.
U uziu ce biti dostupni tek za neka 2 tjedna. Nije mi hitno posto mi je i maticna na popravku.
Ali zanima me imali sto bolje? Ne mogu naci nikakve testove usporedbe tr4 hladnjaka.
kraken x72?
Staro 01.12.2018., 17:19   #307
shar
Overclocker
shar's Avatar
Datum registracije: Nov 2016
Postovi: 523
Ne, nikakvi krakeni pored liq-a.
shar je offline   Reply With Quote
Staro 03.01.2019., 15:17   #308
Postovi: 8,223
2990WX Threadripper Performance Regression FIXED on Windows
Nekolicina entuzijasta je riješila problem na relaciji Windows OS (kernel) i Threadripper/EPYC.
Staro 05.01.2019., 19:12   #309
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Tek sad pogledao video. Masu toga nisam razumio, ali što reći nego svaka čast!
Najjači dio mi je kad kaže kako "ne pozna baš previše windowse"
Staro 07.01.2019., 12:38   #310
lutherus
lutherus's Avatar
Datum registracije: Sep 2011
Lokacija: Dubai UAE
Postovi: 714
Di u Europi mogu nabaviti epyc cpu? Ne threadripper to imam već epyc.
Note to the AMD haters: nobody cares
lutherus je offline   Reply With Quote
Staro 07.01.2019., 12:42   #311
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,275
Autor lutherus Pregled postova
U Njemackoj ih ima u puno shopova:
evo ovaj je oko 4500 EUR za 7601
https://www.proshop.de/CPU/AMD-EPYC-...aign=pricesite
Staro 07.01.2019., 13:50   #312
lutherus
lutherus's Avatar
Lokacija: Dubai UAE
Postovi: 714
Autor Lewis Pregled postova
Thank you
Staro 15.02.2019., 07:54   #313
Manuel Calavera
Postovi: 14,584
Neki frend od frenda uzeo konfu od 60 000kn (koja ga je s popustom i/ili odbijanjem PDV-a izašla 6000 eura odnosno 45 000)
Znači 32/64 threadripper, 128gb ram, rtx 2080Ti, neki napucani 32" 4K monitor
Tip je iz Osijeka, Lewis jesi to ti?
Uzeo je neki hyper x ram (kaže mi ovaj da nije samsung b-die ram) stock 3600mhz, naravno da sam mu rekao da mu 8 keksiju ne može sigurno raditi na toj brzini (pogotovo non b-die), te da sa 3000mhz može biti sretan i na 3000mhz na kraju i radi (zasad, nisu tweakali). Dobro njima za worsktation workload ionako nije bitna brzina rama, to se samo malo vidi u high end gamingu. Nemam nikakve specse nego samo jednu sliku. Znači radi se o gigabyte x399 ploči, pokušavam skužiti koja je, ali jednostavno ne postoji na gigabyte stranici
Znači izgleda isto kao ova po vrm-ovima, ali ova plastika lijevo pored vrm-a nije crna nego srebrna i ne piše aorus nego gigabyte
EDIT
Našao sam - https://www.gigabyte.com/Motherboard...E-EX-rev-10#kf
Iz nekog razloga mi samo aorus mbo izbacivalo pod x399
Staro 15.02.2019., 07:59   #314
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Grehota uzimat 2990WX a ne uzet MSI MEG maticnu. Temperature VRM-a su jedina stvar o kojoj brinut treba a MEG-ica je tu daleko bolja od ove koju je uzeo.
Staro 15.02.2019., 08:00   #315
Manuel Calavera
Postovi: 14,584
Ma nije se ovaj mnogo informirao čini mi se... Dat tolike novce na ho-ruk
Staro 15.02.2019., 09:43   #316
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,275
Pa dobro kako si onda mislio da sam to ja :? Nisam ja.
Ja sam pocetkom prosle godine htio uzeti jedna WS ili RS sa Threadripperom ali na kraju je opet pao intel sa WS plocom (7 slotova) jer AMD TR4 socket i dalje nema nijednu Workstaiton plocu sa 7 full size PCI-E slotova . To mi je toliko nejanso da nemogu opisati, Hvale se sa 64 PCI-E lanea na procesorima a nemaju plocu koja to moze full iskorisititi u korist grafike . Tako da se ja i dalje drzim mojeg starog WSa iz 2016te sa 80 laneova (kombinirano na dva E5 Xeona)
Sto se tice navedene konfe da mi je CPU render prioritet isao bi i ja na w2990 ali posto mi je danas 99% GPU render jedna 2080Ti je malo i CPU s toliko threadova mi ne pomaze.
Staro 15.02.2019., 11:35   #317
Immortalis
Immortalis's Avatar
Postovi: 852
Lewis, kako slozis vise od 4 grafe u kuciste? Koristis vodeno pa ih rezes da budu one-slot gpu ili pci-e extendere?
Mozes poslat kakvu sliku? Moze i na pm. Hvala
Staro 15.02.2019., 11:38   #318
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,275
Trenutno korisitm Thermaltake PCI-E 16x extendere a grafe "objesim" u kucsite okomito da ih razmaknem jednu od druge .
Imam ovakve slicne od 30c, i 60cm extendere
https://www.thermaltake.com/Chassis/...ble/design.htm
Staro 15.02.2019., 11:46   #319
Immortalis
Immortalis's Avatar
Postovi: 852
Znaci, ko kobasice u pušnici
Nisu ni skupi. Budem si kupio to.
Hvala
Staro 15.02.2019., 11:53   #320
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,275
Autor Immortalis Pregled postova
Hvala
Sad jesu skupi ili nisu to je relativno i zavisi kolko dugacak kabel trebas.
ovi od 30cm su nekih 600 kn a ovi od 60cm su oko 750-800kn za komad kabela
konkrento imam ove shileded verzije
https://www.thermaltake.com/Chassis/...0mm/design.htm
od 1m su preko 1000kn .
Staro 15.02.2019., 13:21   #321
Immortalis
Immortalis's Avatar
Postovi: 852
Dobro, ne planiram ju okacit kod susjeda
mislim da ce mi za pocetak 30cm biti dovoljno.
Ovi jesu skupi sto si stavio, ja sam gledao ovako nesto https://www.instar-informatika.hr/ri...t/?utm_source=
Vidjet cu jos
Staro 15.02.2019., 13:27   #322
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,275
Taj iz instara je 20cm a to se brzo potrosi tako da s tim neces moci "objesit" grafu okomito jer cak i ovi od 30cm su kratki za tako nesto posto nisu bas savitljivi
Ovi noviji sto sam linkao su nesto fleksibilniji jer je kable razrezan na nekoliko djelova pa shieldan zasebno svaki dio. Linus ih je testirao na 3+ metra .
Staro 15.02.2019., 16:07   #323
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
Postoje li gubici u odnosu na pcie utor?
Po tvom misljenju.
Amd_Shill je offline   Reply With Quote
Staro 15.02.2019., 16:35   #324
Manuel Calavera
Postovi: 14,584
Ma znam da nisi ti (1 gpu), zajebavam
Koliko mi je ovaj znao reći ovaj se bavi autocadom, Catia itd. IMO djeluje mi ovo overkill za tako što, no možda radi više stvari odjednom. Navodno su mu 16 core i "neka radeon instinct" preslabi, a kaže uzet će i Radeon VII za neki workload
Došla mu dvojica, kažu žele probat Metro Exodus na rtx 2080Ti sa ray tracingom
Edit
Sad mi ovaj šalje da je još jednu rtx 2080Ti naručio
Kraken x62 TR4
samsung 1tb 970
NZXT H700i smart
WD 6tb gold
cm v1200w
PD3200U benq itd.
Zadnje izmijenjeno od: Manuel Calavera. 15.02.2019. u 16:52.
Staro 15.02.2019., 17:19   #325
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,275
Autor Amd_Shill Pregled postova
Po tvom misljenju.
Probao sam testove vrtiti za GPU render (Octane Bench) dok sam testirao prvi extender na TitanX i nije bilo razlike u rezultatu u odnosu na grafu u portu na ploci, cak sam 2 puta (od 3 testa) dobio veci score nego kad je na maticnoj ali to su bile marginalne razlike tipa 144 vs 145 bodova tako da je zanemarivo.
Sa onim USB 1x extenderima pad performansi grafe mi je bio drastican cak do 25-27% losiji rezultati (ti se najcesce koriste za mining i tamo nema neke vaznosti sto su 1x)
Onda sam korisito one BTC PRO sa onima Dual S-ATA 1x extenderom i na njima sam imao gubitke 15-17% tako da ovi sad su idelani/nema gubitaka ali i papreno skupi (ocito s razlogom jer shielding je odlican dok nema gubitaka).
Volio bi probati na TR4 socketu ali kao sto rekoh nisam nasao plocu koja ima vise od 5 PCI-E full size slotova .
Staro 15.02.2019., 18:17   #326
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Kraken x62 TR4
Uf, tezak fail sa izborom coolera, TR4 zracni cooleri bolje hlade od Krakena posto mu je IHS coverage los. Al skup je, bar nesto...
Staro 15.02.2019., 18:23   #327
Manuel Calavera
Postovi: 14,584
Znam, prvo što sam pitao ovoga jel mu barem vodeno prekrije cijeli cpu... Barem je tr4...
Više i ta vodena, koji je kurac ljudima, imaju google...
Staro 15.02.2019., 22:49   #328
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Ma nije problem vodeno, Enermax-ov Liqtech TR4 vrhunski hladi i 2990WX, al Kraken nikako...
Staro 16.02.2019., 09:04   #329
Immortalis
Immortalis's Avatar
Postovi: 852
Bas sam jucer testirao te x1 risere. 2x 1070.
Na vray GPU, x1 mi je sporiji za nekih 8%, a ne racunajuci prvi render, iduca 4 rendera su mi 6,6% sporiji na x1.
Probao sam 5 testova u maticnoj, pa 5 testova na riserima. Probat cu danas i neke teze scene i vece rezolucije pa cu vidjeti, ali koliko sam citao po vray forumima, neki njihov tech lik je isto tako dobio 8% sporije, sto nije lose uopce.
Staro 16.02.2019., 17:47   #330
Immortalis
Immortalis's Avatar
Postovi: 852
Jebem se cijeli dan s ovim. Imam 5 PCI-e utora, i u 3 utora su mi graficke, na 2 sam stavio risere. I nece ih prepoznat svih 5 pa da sam ne znam tko...
Onda sam ga mislio zajebat i stavio sam 2 grafe na jedan PCI-e sa ovim ali cim ih je 5 ukopcano, jednostavno nece bootat.
Kad su mi ove dvije na riserima (svaka grafa u jednom slotu), samo jednu prepozna, drugu ne zeli...
Jos sam u biosu podijelio brzine, npr x16 na x4/x4/x4/x4.
I nece bootat...
