#661 |
Freelancer
Lokacija: Bilje (Osijek)
Postovi: 5,260
Zaj....s ili stvarno neko kupuje 2 kom 2080Ti po sadasnjim cijenama na rate ? IMO ako neko sad kupuje 2*2080Ti po sadasnjim cijenama 10500-11000kn/kom i placa na 12-24 rate ili nedaj boze vise onda to njemu definitinvo ne treba ili je lud do daske ![]()
#662 |
dobro pitam samo, tko pita ne skita. zanimalo me kakav si igrac |
#663 |
Freelancer
Postovi: 5,260
#664 |
Postovi: 14,578
E sad možeš igrati assasins creed na 1080p high settings da ti ne spada ispod 60 fps ![]() https://wccftech.com/assassins-creed...ance-explored/ EDIT Bome ako pričamo o novim gpu, ne vidim kako je 1080Ti isplativija, rtx 2080 košta samo 9-10% više (6300 vs 6900kn ako pričamo o najjeftinijima), a i bolja je (mrvu jača i efikasnija). Bude to još palo, tek su došle Zadnje izmijenjeno od: Manuel Calavera. 11.10.2018. u 22:33. |
#665 |
Freelancer
Postovi: 5,260
Stos je sto ekipa usporedjuje polovne 1080Ti cijene sa novim RTX 2080 (posto polovnih ba si nema) pa se u tom slucaju vise "isplati" 1080Ti. Premda nijedna se ne ISPLATI za to za sta vecina gleda da kupi ![]()
#666 |
Freelancer
Postovi: 5,260
Uhh, jedva cekam Octane 2019.1, Dio koda prebacuju na Vulkan i ubrzanja su fantasticna naspram samo CUDA renderinga. "A few hours ago Arturo Blas Jiménez finished the very first experimental build of Octane 2019.1. This build uses a Vulkan backend on RTX hardware, compiled with the RNDR SDK we showed in March for the 2019 roadmap. While this build is actually a mix of Vulkan and CUDA10 (we’re a ways off from going 100% VK/Metal), it’s already showing waaay faster performance on RT Cores (in the first scene we tested below) than anything we tried before. On our current CUDA backend, a 1080 is about 130 OB (top image), and a 2080 is about 207 OB (bottom left). The bottom right image is the same 2080 with the new Vulkan backend+RTX turned on: GTX 1080 (CUDA) - 34 seconds RTX 2080 (CUDA) - 22 seconds RTX 2080 (Vulkan+RTX on) - 11 seconds Ray tracing hardware is the future. (Update - just tested on 2080 Ti, and it’s same scaling as above, and 30% faster than 2080 on both cuda and VK+RTX) https://www.facebook.com/groups/Octa...0240151486395/ Znaci sa upaljenim RTX jezgrama na CUDA+Vulkan dobiej se ubrzanje 2x (22sec vs 11 sec) u ovom primjeru/renderu.
#667 | |
dr. sc. tech. dipl. ing.
Lokacija: Rijeka-Opatija
Postovi: 3,164
Je da su skupe k'o vrag, ali ovo je impresivan rezultat. Jedino mi je žao što AMD nekako nema ništa značajno na tom polju tj. što OpenCL nije zaživio kao CUDA. Ali tko zna što nas čeka sa Vulkanom i AMD-om.
Pouzdan i pošten trgovac! (ima još puno novijih primjera, nisam ni pratio jel me još tko stavljao u temu.. slobodno pretražite novije postove na temi) StarCitizen refferal code: |
#668 |
Freelancer
Postovi: 5,260
E tako, sad jos da natjeram jednu 1080Ti da radi preko 16x-->1x extendera umjesto ove 1080 i to je to
![]() https://prnt.sc/l57uxy
#670 |
Freelancer
Postovi: 5,260
Najvise igram igre, ono Tetris, Civilization, Settlers, WOW i slicne zahtjevne strategije.... J/K ![]() BTW tri su monitor ali jedna je spojen na onboard grafu dodatno preko D-SUBa pa se pojavi kao 5ta grafa i jos jednom isti monitor ali Analog konektor. Ova Asus Workstation ploca uopce nedaje signal na dedicated graficke dok je u BIOSu pa moramm imat spojeno i to cudo da bi mogo uci u BIOS ili instalirat windowse.....
#672 |
Postovi: 14,578
NVIDIA GeForce RTX 2070 3DMark Timespy Performance Benchmark Leaks Out – Slightly Faster Than GeForce GTX 1080 Leak od ovog azijata je bio i za jednu od ove dvije postojeće, tada se mislilo da je fake, no ispalo je legit ako se ne varam |
#676 |
aka Mithrandir
Postovi: 449
#677 | |
Postovi: 8,176
#678 | |
Postovi: 3,164
... NDA... not ![]() Ajd', ova clockana 2070 je solidna... samo je pitanje ima li RTX smisla kod nje (barem ovaj dio koji se odnosi na RT, DLSS ima smisla možda čak i više nego kod 2080 serije)
#679 |
ODUZIMAM VAM RIJEČ
Postovi: 13,266
Pa rtx nema smisla ni na 2080ti Uz te grafe idu barem 2k monitori, ili 4k za entuzijaste, dok natjeras igre na toj rezi da rade na 144fps, rtx mora ic papa Ionako je ta tehnologija samo marketing trenutno, svrsavanje na odsjaj explozije u oku dok igras battlefield, neprocjenjivo ![]()
#680 | |
Postovi: 3,164
Nisam bas preveliki fan nVidia-e, ali moram ipak rec da bi ipak ostavio ovakve izjave o beskorisnosti RTX-a kod bilo kojeg modela. RT implementacija kod svih prikazanih igara je u visoko eksperimentalnoj fazi, performanse se vjerojatno jos mogu popravit. Što se tiče 2k ili 4k reze, tu stvar što se tiče RT-a može dosta popravit DLSS. Ali ono, 144FPS je malo optimistično za 4k, msm da nitko normalan nije očekivao takve performanse na 4k ![]() ![]()
#681 |
ODUZIMAM VAM RIJEČ
Postovi: 13,266
ma naravno da nije ni blizu 144fps, oni su sretni da bar 60FPS sa uključenim rtx postignu u 4k ali dam se kladit da će većina korisnika te kartice maknut RTX i uživat u framerateu, 2k, 4k, štogod
#682 | |
Datum registracije: Jul 2018
Lokacija: Otok
Postovi: 20
to Citiraj:
Meni je iskreno najviše žao što su ovako rascjepkali čip i dodali rt jezgre. Da su stavili sirove cuda jezgre, performanse bi bile sigurno još 10ak% bolje u tradicionalnom rasteru < ono kako se igre vrte još uvijek. Barem dok devovi ne izbace dovoljan broj rt naslova i ispeglaju to kako spada. |
#684 |
ODUZIMAM VAM RIJEČ
Postovi: 13,266
#685 |
Postovi: 14,578
Mora se nekad krenuti sa nekom novom tehnologijom, a za njih je sad idealan trenutak. Preporuka pogledati predzadnji adoredtv video o raytracingu. Većim djelom se radi o povijesnom pregledu razvoja grafike u igrama, a malo spominje i rendering, ovaj octane što lewis koristi. Jasno je da se sa ovom generacijom neće baš raytrejsat u igrama, možda budu 3 igre dok je aktualna, ali što future starts slow... |
#686 | |
Datum registracije: Jul 2004
Lokacija: Zagreb/Šibenik
Postovi: 826
![]() Mene zanima nesto ovakvo, ASUS Strix ili onaj MSI Gaming Trio X model, ali nekako u nasih dobavljaca kazu da ih nema bas.
Bila je toliko lijepa da sam poželio da nikad ne otvori usta. A onda mi je nekako objasnila da je nijema. Oženio sam ju Las Vegasu, tjedan dana kasnije. I sad napokon živim sa ženom koju razumijem. Moj PC - https://www.twitch.tv/flegmoar |
#687 | |
Postovi: 3,164
Slažem se s ovim. Tako su i počeli sa GeForce čipovima, još u doba GeForce SDR/DDR (ustvari sam onda nekako pravo i počeo pratit razvoj grafičkih kartica). Dodali su hardverski T'n'L engine kad ga praktički nijedna igra nije podržavala. No nakon dvije generacije to je feature koje im je omogućio da pregaze konkurenciju, jedino ih je ATi uspio koliko toliko pratit sa prvim Radeonom. S3 je propao zbog zbuganih drivera Savage2000 serije, iako je sam chip na papiru djelovao solidno, 3Dfx je otisao kvragu jer nisu imali T'n'L itd.
#688 | |
..starija garda
Postovi: 3,278
čak imaju i tehnike tipa kako na pametne ili manje pametne, čiste ili prljave, itd itd. načine doći do kritične mase da poguraju to "zaljepljivanje" ...ili nametanjem na ovaj ili onaj nacin, ako je prihvaceno, kako da to monopoliziraju i iskoriste do ibera protiv konkurencije.. to je tako u svim biznisima , a u tehnici poznato vecini nama ponajvise od VHSa pa nadalje ![]() PS 3dfx je imao ekskluzivu preko STBa koja ih je najviše koštala.. savage je bio na papiru najjači, ali da driveri i im nikad nisu bili najjaca strana..
#689 |
Datum registracije: Feb 2004
Postovi: 1,303
#690 | |
Postovi: 3,164
A da, ATi/AMD isto svasta od novih tehnologija izbaci pa obično im se ne uspije "uhvatit"...vjerojatno zato sto ne koriste mafijaske tehnike, nego obicno open access/open source... jedino sto mi je drago sto se FreeSync uspio uhvatit... za par dana ce i do mog stola doc ![]() Ne znam koliko je poznato, ali pionir teselacije je bio ustvari AMD... to su imali jos na Radeonu 8500 ![]()
