Datum registracije: Sep 2018
Postovi: 12
Speedport Plus (T-Com)
Evo nekoliko slika ovoga routera, radi se o Sercomm routeru, korisničko ime je admin a lozinka je serijski broj routera sa naljepnice. Administrativno sučelje je djelomično zaključano tako da nisu dostupne sve opcije. Na matičnoj ploči postoji priključak za serijski port 3.3V, međutim kada se pristupi konzoli traži login i ne prihvaća admin niti ništa uobićajeno. Parametri za pristup konzoli su 115200/8/none/1 Ima li tko ideju/informaciju kako pristupiti root accessu na uređaju? Boot log: Code:
PRELOADER.00000000.LPLR.19767609. II: SNAF version check OK! II: version check OK! TLB initial done: .ro section works! .text and .ro sections work! II: SWR setup... II: DRAM init... Start to set DDR parameters ENABLE: Triple SYNC TRIG: DRAM initialization procedure, wait done bit...Done! PLL: MEMPLL31 = 0x10407f PLL: MEMPLL63 = 0xc00001ef PLL: MEMPLL95 = 0x26622760 PLL: MEMPLL127 = 0x270f0000 PLL: MEMPLL159 = 0xfff PLL: MEMPLL191 = 0x0 PLL: MEMPLL223 = 0x0 System FREQ. info:OCP0: 0x3e8 MHz, OCP1: 0x1f4 MHz, DRAM: 0x20d MHz, LX: 0xc8 MHz Slow bits configuration: 0xb8000380: 0x80000070 0xb8000390: 0x80000070 0xb8000388: 0x22200 0xb8000398: 0x200 0xb80003a0: 0xf000f SCATS settings: 0xb80040f8: 0xc5 ZQ: Clock GROUP ZQ: ODT/OCD= 30/30 ZQ: zq_zctrl_prog=0x80803be zq_zctrl_status=0x20a133 ZQ: Address GROUP ZQ: ODT/OCD= 30/48 ZQ: zq_zctrl_prog=0x180803b4 zq_zctrl_status=0x20a100 ZQ: DQ GROUP ZQ: ODT/OCD= 30/3c ZQ: zq_zctrl_prog=0x280803b8 zq_zctrl_status=0x20a111 ZQ: DQS GROUP ZQ: ODT/OCD= 30/3c ZQ: zq_zctrl_prog=0x380803b8 zq_zctrl_status=0x20a111 ZQ: ZQ Calibration PASS! MRS: mr[0] = 100c72 MRS: mr[1] = 110006 MRS: mr[2] = 120000 MRS: mr[3] = 130000 AK: Start DDR_Calibration... AK: Reduce DDR calibration AK: Bit:0 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:1 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:2 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:3 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:4 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:5 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:6 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:7 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:8 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:9 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1d AK: Bit:a max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1d AK: Bit:b max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1d AK: Bit:c max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:d max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1d AK: Bit:e max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1d AK: Bit:f max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:10 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:11 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:12 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:13 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:14 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:15 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:16 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:17 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:18 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:19 max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:1a max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:1b max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:1c max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:1d max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:1e max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f AK: Bit:1f max_r_s:0 max_r_l:1f max_w_s:0 max_w_l:1f ENABLE: DQ output enable delay SYNC AK: Finish DDR Calibration DCR: 0x21220000 DTR: tRFC[DRAM_capacity_index]=80 DTR: DRAM_capacity_index=3 DTR: dram_freq_mhz=20d DTR: tRFC=10680 DTR: DTR0=77544e26, DTR1=606051c, DTR2=4617000 DISABLE: Read after Write ENABLE: Parallel Bank & Read Buffer Patch II: Change Stack from 0x9f000edc to 0x83bfffe0 II: U-boot Magic Number is 0x27051956 II: Inflating U-Boot (0x83c00040 -> 0x83c00000)... OK II: Starting U-boot... U-Boot 2011.12. (Aug 03 2017 - 16:58:23) Board: VD2, CPU:1000MHz, LX:200MHz, DDR2:525MHz DRAM: 128 MB SPI-NAND Flash: C212/Mode0 1x128MB uboot: create bbt uboot: bb 226 537 uboot: create skip table last skip_block 1022 Loading 16384B env. variables from offset 0x200000 Net: Ext. phy is not found. RTL SwCore Warning: eth device name has a space! SC_DEBUG: Nand Partition Table Magic Found at 100000. reading at Bi 0x8 WW: ecc check failed (ret 0xecdead01) 0 c0 2 12 35 88 Prod Buil, No Chance to get into CLI! Load Standalone Code from flash to buffer address in DRAM... Standalone:SC_DEBUG: Nand Partition Table Magic Found at 100000. SC_DEBUG: Nand Partition Table Magic Found at 100000. Standalone:SC_DEBUG: Nand Partition Table Magic Found at 100000. Standalone:SC_DEBUG: Nand Partition Table Magic Found at 100000. *************************************************** Sercomm Boot Version 2.3.0.0, at Dec 26 2017, 15:45:13 *************************************************** Entering Firmware : Everything is OK. Dual Image Selection Flag Value 0x1 ubi part kfs2 Creating 1 MTD partitions on "nand0": 0x0000034e0000-0x000006500000 : "mtd=8" UBI: attaching mtd4 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 126976 bytes UBI: smallest flash I/O unit: 2048 UBI: VID header offset: 2048 (aligned 2048) UBI: data offset: 4096 UBI: attached mtd4 to ubi0 UBI: MTD device name: "mtd=8" UBI: MTD device size: 48 MiB UBI: number of good PEBs: 384 UBI: number of bad PEBs: 1 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 2 UBI: available PEBs: 215 UBI: total number of reserved PEBs: 169 UBI: number of PEBs reserved for bad PEB handling: 3 UBI: max/mean erase counter: 1/0 kernel_size 0x338800, roofs_size 0xe78000 ubi readvol 0x80000000 ubi_vol_kernel Read 0 bytes from volume ubi_vol_kernel to 80000000 No size specified -> Using max size (3377152) Verifing Kernel Image Check Sum:PASS! ubi readvol 0x80000000 ubi_vol_rootfs Read 0 bytes from volume ubi_vol_rootfs to 80000000 No size specified -> Using max size (15237120) Verifing Rootfs Image Check Sum:PASS! ubi readvol 0x83000000 ubi_vol_kernel Read 0 bytes from volume ubi_vol_kernel to 83000000 No size specified -> Using max size (3377152) ## Booting kernel from Legacy Image at 83000000 ... Image Name: Linux Kernel Image Created: 2018-03-26 9:27:48 UTC Image Type: MIPS Linux Kernel Image (lzma compressed) Data Size: 3375640 Bytes = 3.2 MB Load Address: 80000000 Entry Point: 80000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK Starting kernel ... Linux version 3.18.20-svn3477 (root@ubuntu) (gcc version 4.8.5 20150209 (prerelease) (Realtek MSDK-4.8.5p1 Build 2220) ) #30 SMP Mon Mar 26 17:15:06 CST 2018 [SDK 2.4.1] Total DRAM Size=128M OCP0 DRAM Size=128M MIPS: machine is RTL8685SB [L2_DEBUG:(bsp_setup_syncctl,235)]mips_cm_base= bfbf8000 [L2_DEBUG:(bsp_setup_syncctl,236)]read_gcr_control() = 0x1 => [L2_DEBUG:(bsp_setup_syncctl,239)]0x10001 [L2_DEBUG:(bsp_scache_config,157)]L2_CONFIG= 0x11 [L2_DEBUG:(bsp_scache_config,168)] - L2_DataStall= 0x1 [L2_DEBUG:(bsp_scache_config,169)] - L2_TagStall = 0x0 [L2_DEBUG:(bsp_scache_config,170)] - L2_WsStall = 0x1 [L2_DEBUG:(bsp_scache_config,171)] - L2_Bypass: Disable [L2_DEBUG:(bsp_setup_scache,214)]SCache LineSize= 32 (B) bootconsole [early0] enabled CPU0 revision is: 0001a120 (MIPS interAptiv (multi)) Determined physical RAM map: memory: 08000000 @ 00000000 (usable) User-defined physical RAM map: memory: 07800000 @ 00000000 (usable) Zone ranges: Normal [mem 0x00000000-0x077fffff] Movable zone start for each node Early memory node ranges node 0: [mem 0x00000000-0x077fffff] Initmem setup node 0 [mem 0x00000000-0x077fffff] VPE topology {2,2} total 4 Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes. Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes MIPS secondary cache 256kB, 8-way, linesize 32 bytes. PERCPU: Embedded 9 pages/cpu @827b9000 s7552 r8192 d21120 u36864 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 30480 Kernel command line: console=ttyS0,115200 mtdparts=spinand:1024k(boot),512k(part_map),512k(dual_flag),512k(u-boot-env),512k(checksum1),512k(checksum2),1280k(protect),49280k(kfs1),49280k(kfs2),5120k(xml_config),5120k(app_data),1024k(factory) ubi.mtd=8 root=ubi0:ubi_vol_rootfs ro rootfstype=squashfs mem=120M log_buf_len individual max cpu contribution: 4096 bytes log_buf_len total cpu_extra contributions: 12288 bytes log_buf_len min size: 4096 bytes log_buf_len: 16384 bytes early log buf free: 1120(27%) PID hash table entries: 512 (order: -1, 2048 bytes) Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Writing ErrCtl register=00000000 Readback ErrCtl register=00000000 Memory: 81924K/122880K available (7487K kernel code, 1497K rwdata, 1480K rodata, 212K init, 28919K bss, 40956K reserved) Hierarchical RCU implementation. NR_IRQS:128 Calibrating delay loop... 666.41 BogoMIPS (lpj=3332096) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) Performance counters: mips/interAptiv PMU enabled, 2 32-bit counters available to each CPU, irq -1 (share with timer interrupt) Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes. Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes MIPS secondary cache 256kB, 8-way, linesize 32 bytes. CPU1 revision is: 0001a120 (MIPS interAptiv (multi)) Synchronize counters for CPU 1: done. Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes. Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes MIPS secondary cache 256kB, 8-way, linesize 32 bytes. CPU2 revision is: 0001a120 (MIPS interAptiv (multi)) Synchronize counters for CPU 2: done. Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes. Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes MIPS secondary cache 256kB, 8-way, linesize 32 bytes. CPU3 revision is: 0001a120 (MIPS interAptiv (multi)) Synchronize counters for CPU 3: done. Brought up 4 CPUs NET: Registered protocol family 16 cpuidle: using governor ladder cpuidle: using governor menu pm-cps: CPC does not support clock gating SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb NET: Registered protocol family 8 NET: Registered protocol family 20 Switched to clocksource MIPS NET: Registered protocol family 2 TCP established hash table entries: 1024 (order: 0, 4096 bytes) TCP bind hash table entries: 1024 (order: 1, 8192 bytes) TCP: Hash tables configured (established 1024 bind 1024) TCP: reno registered UDP hash table entries: 256 (order: 1, 8192 bytes) UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) NET: Registered protocol family 1 Realtek GPIO Driver for Flash Reload Default futex hash table entries: 1024 (order: 4, 65536 bytes) squashfs: version 4.0 (2009/01/31) Phillip Lougher ntfs: driver 2.1.31 [Flags: R/W]. fuse init (API version 7.23) JFS: nTxBlock = 640, nTxLock = 5120 msgmni has been set to 160 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled serial8250: ttyS0 at MMIO 0x18002000 (irq = 58, base_baud = 12327200) is a 16550A console [ttyS0] enabled console [ttyS0] enabled bootconsole [early0] disabled bootconsole [early0] disabled console [ttyS0] disabled console [ttyS0] enabled SOC_ID 0x6518 unknown bond id aipc: register chrdev(254,0) aipc: create device successed aipc: start aipc irq init aipc: Request IRQ for IPC OK aipc: create dsp console device successed aipc: init done /proc/usb_mount_failed_dev created. Realtek Luna SPI NAND Flash Driver Rev:00:00:00 (ChaoYuan_Yang) nand: device found, Manufacturer ID: 0xc2, Chip ID: 0x12 nand: Macronix nand: 128MiB, SLC, page size: 2048, OOB size: 64 Scanning device for bad blocks Bad eraseblock 226 at 0x000001c40000 Bad eraseblock 537 at 0x000004320000 12 cmdlinepart partitions found on MTD device spinand RTK: using dynamic nand partition Creating 12 MTD partitions on "spinand": 0x000000000000-0x000000100000 : "boot" 0x000000100000-0x000000180000 : "part_map" 0x000000180000-0x000000200000 : "dual_flag" 0x000000200000-0x000000280000 : "u-boot-env" 0x000000280000-0x000000300000 : "checksum1" 0x000000300000-0x000000380000 : "checksum2" 0x000000380000-0x0000004c0000 : "protect" 0x0000004c0000-0x0000034e0000 : "kfs1" 0x0000034e0000-0x000006500000 : "kfs2" 0x000006500000-0x000006a00000 : "xml_config" 0x000006a00000-0x000006f00000 : "app_data" 0x000006f00000-0x000007000000 : "factory" Realtek SPI Nand Flash Driver is successfully installing. IMQ: No specify the numqueues. Use the cores number 4 as numqueuues IMQ driver loaded successfully. (numdevs = 2, numqueues = 4, imq_dev_accurate_stats = 1) Hooking IMQ after NAT on PREROUTING. Hooking IMQ before NAT on POSTROUTING. tun: Universal TUN/TAP device driver, 1.6 tun: (C) 1999-2004 Max Krasnyansky |
Datum registracije: Jul 2013
Lokacija: Tenja(Osijek)
Postovi: 1,120
Imas mozda firmware image da probamo iskopati password? Te,ima li mozda originalni model naveden? Sent from my Redmi Note 5 Pro using Tapatalk |
Postovi: 12
Nemam ništa samo zaključani router i enkriptiran config file kojeg isto tako nemogu dekriptirat pomoću algoritma za speedport https://github.com/Stricted/SPHDecode |
RESPECT MY AUTHORITAH
Postovi: 7,473
Nakon logina ne radi ovo? http://192.168.1.1/html/engineer/ro_dsl.htm
Postovi: 12
Ne, "The connection was reset" ne otvara niti engineer stranice, izgleda da su uklonjene ili nepostoje, niti radi onaj exploit sa dyndns-om kao na w724v |
Lokacija: hr
Postovi: 755
Probaj login sa tech / !M1PhoIAD2 taj user je isto radio za shell login na starom speedportu. |
Postovi: 12
probao sam tech ali mi nakon sto unesem username kaze Invalid user acc |
Postovi: 12
je u tom je obliku, probao sam vec ali daje opet enkriptirani output probao sam i pomocu tvog alata generirat kljuc i IV pa ih unest u skriptu sa githuba, isto nista, probao sam i mac adresu 2.4ghz + serial, 5ghz mac + serial, uvijek ostane enkriptirano EDIT: nije 10 znamenkasti serial nego 12 znamenkasti ! J825BHxxxxxx EDIT2: ovdje na grčkom telekomu postoji manual i firmware za taj router http://help.cosmote.gr/system/templa...Manual_eng.pdf http://help.cosmote.gr/system/templa...lus_323520.img firmware bi trebao biti jedan od ova dva: 09022001.00.009 , Boot code version 2.20.0 DSL modem code version v135k35b-v901 10-13-17 09022001.00.017 , Boot code version 2.20.0 DSL modem code version v135k35B-v901 03-21-18b u mojemu je ovaj drugi po redu EDIT3: firmware na gornjem linku je 09022001.00.019 Zadnje izmijenjeno od: Nikky. 12.09.2018. u 19:39. |
Postovi: 12
ovim alatom radi dekripcja iako mislim da nije točna ali po veličini dekriptiranog filea bi trebalo bit točno ali ne radi dekompresija moguće da je enkriptiran dva puta ili da key i IV se postižu na drugačiji način https://github.com/Psychotropos/sercomm_fwutils Edit: nije niti tip1 niti tip2, strukturiran je kao tip1 s tim da posljednjih 16byte-a su isto nekakav hash koj se vjerovatno koristi prilikom izračunavalja ključa, ili je možda IV ili je moguće da je skroz druga enkripcija Zadnje izmijenjeno od: mrmess. 11.09.2018. u 10:55. |
Lokacija: hr
Postovi: 755
Postovi: 12
Lokacija: hr
Postovi: 755
Vjerovatno je ista veličina exe ali evo link drugi: http://rgho.st/7WCtkVkjJ Ako ne radi onda su drugačije napravili metodu enkripcije. |
Postovi: 12
ista stvar, ne dekriptira.. promijenili su ili način na koj se izračunava ključ i IV, ili su promijenili enkripciju, ili treba sa streamom napravit prvo neku operaciju prije dekripcije |
Postovi: 371
i ja sam dobio ovaj ruter sa 09022001.00.017 firmwareom, ali kako sam se žalio da se vuče valjda su ga updateali na 09022001.00.021 i modem code version: v135k35B-v901 07-27-18..
Destiny isn't already Forged!!! |
#16 |
Datum registracije: Jun 2010
Lokacija: hr
Postovi: 887
I da li na kraju Speedport plus nudi kakve benefite u odnosu na ranije verzije? |
#17 |
Postovi: 12
Kao trebao bi modem podržavati veće adsl brzine ali to mora tcom uvest s njihove strane, ima Gbit-ni switch, uređaj kao hardware izgleda solidan ali su nedostupne sve opcije pa bas i nije moguće podesiti ga. Firewall je zaključan, internet konekcija, pristup korisnicima, pristup udaljenoj administraciji.. Moguće je podesit wifi, dhcp i port forwarding, skrivena je i opcija za postavit ga u bridge mode ali se moze iskemijat nekako.. Primjetio sam da računala u lanu su ponekad nedostupna dok ako im se pristupa preko eksterne ip adrese i port forwardinga (nat loopback) su dostupna. Kao da firewall onemogućuje neke portove između računala u lanu. Npr ssh sa jednog računala na drugo u lanu "invalid handshake", dok pristup kroz browser na apache radi, eksternim ip-op ssh radi EDIT: ima i 5ghz wifi, 300mbps Zadnje izmijenjeno od: Nikky. 12.09.2018. u 19:34. |
#18 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,465
#19 |
Postovi: 12
i to sto kazes.. u svakom slucaju zte mi je bio drazi jedino sto nije podrzavao nat loopback |
#20 |
Postovi: 371
#21 |
Postovi: 12
izgleda da pocinje politika zakljucavanja postavka kao sto je bilo sa zakljucavanjem mobitela na mrezu EDIT: ima li tko iskustva sa tr69, jel postoji kakav interface/klijent ili samo server pa se router spaja na njega jel moguce pristupit routeru tim protokolom ikako? EDIT2: skužio sam da router ima otvoren ssh na portu 22, kada mu se unese neki bezveze username zatvori konekciju, kada mu se unese admin, tech, root prihvati i pita password, ako se unese bezveze pasword pita ponovno, ako unesem admin/serial, root/root tech/!M1PhoIAD2 zatvori konekciju i izbaci invalid user account. Izgleda da su važeći admin / serial tech / !M1PhoIAD2 root / root ali nešto prekine konekciju kada se autenticira. Negdje kao da sam pročitao da je potrebno onemogućiti firewall najprije. probao sam pristupiti i preko wifia i preko lana! EDIT3: .Delboy ti si napisao u drugom postu da si uspio ući u root shell na w724v preko tr69, kako da to napravim? Zadnje izmijenjeno od: Nikky. 12.09.2018. u 19:36. |
#24 |
Postovi: 12
moguce je jedino u obliku zvjezdica.. dok se ne objavi algoritam dekriptiranja konfiguracije |
#27 |
Lokacija: slavonac
Postovi: 495
he,he |
#29 |
Postovi: 371
#30 |
Lokacija: hr
Postovi: 887
Stavio ga u bridge i sasvim korektno radi.Ne znam da li je netko spomenuo kako radi u 2.4 modu na dva kanala. |
