Staro 15.08.2018., 03:31   #481
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Autor Dottore Pregled postova
Ima li kakve promjene B350 vs B450 ploče? Naravno, mATX formata
Isto kao x370 vs x470, u principu isti čipset samo rebrandiran + storeMI softver
The wave of B450 motherboards launched with 2nd-gen Ryzen chips largely offer the same capabilities and specifications as B350, but with two minor additions. Support for AMD’s micro-tiering StoreMI technology lets you combine multiple storage sources into a larger virtual drive and can be used to speed up hard drives with the help of an SSD... We explain StoreMI in more depth in the X470 motherboard section. B450 boards like the Asus ROG Strix B450-F Gaming ($130 on Newegg) also idle more efficiently than their B350 siblings.
If neither of those extra features sound appealing, opting for a B350 motherboard rather than a B450 board could save you some cash and get you largely the same functionality.
Naravno što se tiče ostalog (opremljenosti, featurea) svaka ploča je priča za sebe
Staro 15.08.2018., 10:37   #482
Autor Colossus Pregled postova
Ti Šojiću da šutiš, nisi se javio za reč, da ne popaseš jednu disciplinsku komisiju, i ti bre ko dvoglavi arapin, dve švalerke, dva stana, dva auta, dva kompjutera, i to još Asus ploća, nek se nadje
Duneš mi pod prozor Pantiću. Mesto da se tu kuburiš, ima da dođeš u PCE owner temu pa da te se prijavi u baza na prvi post.
Sent from Usreo Mobara
Staro 15.08.2018., 13:05   #483
Manuel Calavera
Postovi: 14,584
E da nadodam još B450 ne podržava bristol ridge APU-e kao B350 (zadnja generacija bulldozer arhitekture, kao prvi APU-i i entry level opcija na AM4), no to vjerujem nikome nije problem. Eventualno će AMD kad dođe zen3 morati slati ryzene (ako budu htjeli imati takav program) ljudima koji kupe 4xx čipset i zen3 za update biosa, umjesto dosadašnjih bristol ridge jeftinjakera
Staro 15.08.2018., 21:53   #484
Colossus
Colossus's Avatar
Postovi: 379
https://www.youtube.com/watch?v=ocBRnSfNDGA
Colossus je offline   Reply With Quote
Staro 18.08.2018., 14:42   #485
lobo64
lobo64's Avatar
Postovi: 1,345
Dali je netko od poštovanog članstva stavio bios 7A37v1G za MSI B350M Mortar?
Ako jest, možda da podijeli iskustva, kako pozitivna, tako i negativna.
Konkretno me zanima dali je omogućen OC IGPa, te kompatibilnost sa memom (na v1F dobiti hynix da radi na deklariranom taktu i latencijama - suicide stunt).
Isto tako njesra sa mem voltažama- koliko god zadam u biosu (išao do 1,41V) na kraju nikad više od 1,36V, kako po monitoring programima tako i u očitanju iz biosa.
Zadnje izmijenjeno od: lobo64. 18.08.2018. u 14:50. Razlog: dodavanje
lobo64 je online   Reply With Quote
Staro 20.08.2018., 12:34   #486
caruga
Lokacija: TU
Postovi: 27
Pozz
Jedno brzo pitanje...
Na napajanju imam samo 4 i 6 pin, a maticna za procesor ima 8 pinova.
Koje je bolje i sigurnije da stavim?
Ryzen 3 220g
Asrock b450pro4
Poslano sa mog SM-J530F koristeći Tapatalk
caruga je offline   Reply With Quote
Staro 20.08.2018., 12:44   #487
4 pina.
Staro 20.08.2018., 13:26   #488
caruga
Lokacija: TU
Postovi: 27
Hvala!
Staro 20.08.2018., 15:10   #489
trpi
Autor lobo64 Pregled postova
imam doticnu plocu i deklarirani CL15 moje hynix memorije prihvaca samo sa GEAR DOWN MODE-om disabled, iz nekog razloga sa tim upaljenim samo cl16 ili cl14, kroz vise biosa.
Staro 20.08.2018., 16:15   #490
lobo64
lobo64's Avatar
Postovi: 1,345
Hvala na odgovoru. Moj Aegis je doduše 3000 16-18-18-38 no svejedno. Probat ću isključit ovo što si naveo, makar u biosu ima hrpa opcija koje uopće nisu objašnjene. A kopanje i isprobavanje ali baš svake opcije, iideeš...
Jel ima kakav forum koji se bavi baš MSI Ryzen pločama pa da probam tamo bacit oko?
Staro 20.08.2018., 19:40   #491
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,595
Autor caruga Pregled postova
Pozz
Ryzen 3 220g
Asrock b450pro4
6 pin nije za cpu
Pikaj 4 pin
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 22.08.2018., 19:43   #492
caruga
Lokacija: TU
Postovi: 27
Imam problem sa ram-om...
asrock b450pro4
ryzen 3 2200g
2x4gb patriot viper pc4-22400 2800mhz
u bios sam normalno postavio xmp profil i radilo je ok na 2800mhz, radilo je i na 3000.
dan kasnije sam pokusao vratit nazad na 2800 jer mi se pc zaledio(samo je stao radit )
ali bez uspijeha.
xmp profil mi daje mogučnost promijene ali je stalno stajao na 3000mhz.
U među vremenu sam ubacio novi bios i napravio cleer cmos i sada je zaglavio na 2133.
Šta god da stavim ram konstantno stoji na 2133mhz
Šta bi moglo biti problem?
Staro 23.08.2018., 13:44   #493
shar
Overclocker
shar's Avatar
Datum registracije: Nov 2016
Postovi: 523
Gdje gledaš frekvenciju rama? Jer pojedini software zna pogrešno očitavat brzinu, npr. task manager na win 10 u većini slučajeva pokazuje 2133mhz.
Ako je stvarno 2133, možeš probat ručno postavit ram, a ne preko xmp-a, eventualno povećat ram napon na možda 1.45v. Također možeš probat vratit staru verziju biosa na kojoj je bolje radilo. Izabrao si prilično loš ram za ryzena, pogotovo za apu koji još više ovisi o performansama memorije.
shar je offline   Reply With Quote
Staro 23.08.2018., 13:46   #494
Do Patriota je. To je najgori RAM kaj se može kupiti od ovog kaj se kod nas nudi (G.Skill, Corsair, Kingston, Crucial...).
Uz dizanje napona na RAMu, trebalo bi dignuti i SoC napon na 1.025-1.075V. Ako još ima kakav Phase VRAM control u BIOSu postaviti na max vrijednost i to bi možda i ferceralo.
Staro 24.08.2018., 16:12   #495
caruga
Lokacija: TU
Postovi: 27
Uspio sam ga odglavit sa ryzen master.
Sad radi na 2800mhz 1.2v
Neznam dali je to što mi nekad zamrzne pc vezano za HW ili SW (win10)
Sva tri puta kada je zamrzio bio sam na netu (opera)
Što se tice ram-a kad sam kupovao ovdije sam na forumu dobio savijet za patriot.
Ikao prije nego sam kupio konponente, citao sam dosta na netu i vidim da dosta ljudi imaju problema sa ram-om razlicitih proizvođača.
Staro 24.08.2018., 16:20   #496
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Yep, ja sam taj. Dobra cijena za dual-channel 2800MHz na 1.2V se činilo kao pun pogodak za APU. Mislih da 2xxx serija neće biti tolko osjetljiva budući da ja imam skoro pa isti kit na 8600K i radi na 3066MHz/15-16-16-35 na 1.3V bez problema. Ali... istina da uspoređujem IMC unaprijeđen kroz 5-6 platformi vs. jednu i pol
Staro 24.08.2018., 16:35   #497
caruga
Lokacija: TU
Postovi: 27
Je ti si taj ali nije bilo rijec o tom nego 2400mhz patriot.
Staro 25.08.2018., 21:01   #498
Strider
Nuclear Experiment
Strider's Avatar
Datum registracije: Aug 2009
Postovi: 647
Kolege molio bih pomoc.
Nakon 10 godina se vracam na AMD i po prvi put overklokam(i7 3770,i7 4790). Nabavio sam ryzen 2600, Corsair Vengeance 3000MHz CL15 i Asus ROG STRIX B450-I. Stavljen je zadnji bios(0901). Sustav se normalno dize kada stavim 3000mhz memorije, ali je problem kod OC proca. Slicno kao kolega Warlock25 ne mogu dici iznad 3.9ghz(isti ducan khm khm...). Stavio ja auto ili 1.38 rusi se. Iznad nisam isprobavao. Po uzoru na kolegu sam stavio 3.9ghz na 1.27v i opet ga rusi. Na auto ili 1.3v ga drzi u cinebenchu. Vec nekoliko sati pokusavam dobit neki sweet spot ali tesko. Na sto bi treba stavit Global c-state control? Evo validacija ako treba (vcore je na auto bio). Puno hvala na pomoci
For everything you gain,
You lose something else
Strider je offline   Reply With Quote
Staro 25.08.2018., 21:06   #499
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
LLC ?
MojSkuter
Staro 25.08.2018., 21:08   #500
Strider
Nuclear Experiment
Strider's Avatar
Postovi: 647
LLC je na 1
Staro 25.08.2018., 21:10   #501
LLC na 3.
VRAM LLC na Extreme
SoC voltage na 1.025-1.075V
RAM voltage na 1.4V
Core boost off
Bilo CPU boost ili Core Performance level na off
Množitelj na 40.5, BCLK sync (nikako async) na 100.2 i CPU voltage na 1.25V i trebalo bi raditi na 4050 bez beda.
Staro 25.08.2018., 21:11   #502
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
LLC digni na neku gornju srednju vrijednost, trebalo bi biti dosta za 4ghz
Ps .evo brko asusicar ti je sve rekao
MojSkuter
Staro 25.08.2018., 21:12   #503
Autor Eladio Pregled postova
Opet si koristan ko semafor u GTA V
Staro 25.08.2018., 21:14   #504
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
A nemam asus da znam sta je 1 a sta je 3, meni je medium ili high dovoljno, turbo i extreme ne koristim :P
MojSkuter
Staro 25.08.2018., 21:21   #505
Sve 5 poanta priče je što Asus ploče sa novim BIOSima i prilikom prvog boota sa Zen+ (R2X00) procesorom, odmah dižu sve te auto boost pizdarije od kojih koristi ima samo ekipa koja ima X procesore i oni koji ne misle koristiti fixed OC kao mi ostali.
Imao sam i ja istraživanja nakon što mi je jedna jedina postavka ubila RAM performance. Imao sam 3200 C14 i zategnute subtiminge, a u benču dobivao reze manje nego ekipa sa 2400 C17 jebote pa isto, tražiš, pitaš, skužiš da je to sve do automatike u BIOSu.
Nekako ne vjerujem da ti Zen+ ne mogu preko 3.9GHz sa 1.39V. Nemoguće
Staro 25.08.2018., 21:28   #506
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
Ja ugasio core boost, llc stavio negdje na sredinu, soc 1.05 , ram na xmp, multi za 4050 i kreno se igrat s cpu V, spustao s 1.3 do 1.2 dok nije prime smrznuo, malo fine tuning i skuzio da drzi na 1,21V..podigao za kraj dva koraka i tu negdje na 1.22V držim.. mozda moze bolje al ne dira me, lijen sam za to
Ostalo mi je sve auto. Gigabajt je stroj kume moj
Ps.. imao sam nekw glupe probleme, da bih skuzio da sam atx konektor na mbo slabašno piknuo, ali to nemoj nikom rec
MojSkuter
Zadnje izmijenjeno od: Eladio. 25.08.2018. u 21:33.
Staro 25.08.2018., 21:37   #507
Strider
Nuclear Experiment
Strider's Avatar
Postovi: 647
Idemo redom: 1 slika nadam se da je sve kako treba. 100.2 mi ne zeli prihvatit pa...
2. slika Ovaj SoC voltage na 1.025-1.075V to ide pod CPU SOC voltage zar ne?
3 slika VRAM LLC na Extreme imam jedino kod ovog CPU power duty control. Ostalo je postavljeno llc 3, ram 1.4 vcore na 1.25 Vec mi dosta svega pa sorry ljudi ako zamaram haha
Staro 25.08.2018., 21:41   #508
Slika 1 - Performance enhancer na disable/off
Slika 2 - da, to je taj napon SoC CPU Voltage. Za početak 1.05V.
Slika 3 - huh, mršavo. VDDSOC isto podebljaj.
F10 i javi što se dogodilo
Staro 25.08.2018., 22:10   #509
Strider
Nuclear Experiment
Strider's Avatar
Postovi: 647
Opet nista...Performance enhancer nemam disable/off, probao sam auto i default nema razlike
soc je stavljen na 1.05, probao i na 1.075. VDDSOC je stavljen na 3. crash, core proban na 3.9 crash. Fkt polako ludim, budem se jos ujutro pozabavio kombinacijama. Barem da mi 3.9 normalno radi.
Staro 25.08.2018., 22:20   #510
Ajde prvo RAM spusti na 2133 čisto da vidimo da te RAM ne seksa. Sve ostalo ostavi da vidiš jel oće na 4GHz raditi CPU.
Također, u kojim slotovima ti je RAM? Nekima je i to zadavalo probleme.
