#4231 |
Postovi: 542
Ne znam zašto sam ja zabrijao da cijela 2xxx serija ima integriranu ![]() Zadnje izmijenjeno od: coconut. 02.05.2018. u 06:31. |
#4232 |
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,572
1x AOC LCD 23,8", IPS WLED, HDMI, 4ms 1x Intel Core i5 8600k 3,6GHz,9MB, 6C,LGA 1151 1x Cooler LC POWER LC-CC-120 Cosmo Cool, socket 775/1150/1151/1155/1156/1366/2011/2011-3/FM1/FM2/AM2//AM2+/AM3/AM3+ 1x GIGABYTE Main Board Desktop INTEL Z370 (Socket LGA1151, 4xDDR4, HDMI,DVI-D, 1xPCIEX16/2xPCIEX1, USB3.1/USB2.0, 6xSATA III/M.2socket3/RAID, LAN) mATX retail 1x Patriot Elite DDR4, 2666Mhz, 16GB, CL16 1x Crucial SSD 250GB MX500 SATA 1x Seagate Barracuda Guardian 2TB S-ATA3, 7200rpm, 64MB cache (ST2000DM006) 1x Napajanje Seasonic SS-620GM2 EVO, 620W 1x Zalman Z3+, 4x120mm, USB3.0 black Ukupno: 7.362kn (-2%=7.214kn) Besplatno slaganje i dostava |
#4233 |
Lokacija: Vinkovci
Postovi: 478
Sastavljam komp, malo posao, malo klinci cs:go, fornite ili kako već, cca 6tkn, valjda je dovoljno. Treba i monitor, neki 24", ništa skupo jer nema prostora. Ssd obavezno + neki 1-2 tb. Grafička u rangu 1050 / ti ram 8 gb Intel i3 ili ryzen 3 - nisam dovoljno pametan, ne pratim to više. Može na pm, plaćanje virman R1 |
#4235 |
Postovi: 16,708
1 x Intel Core i5-8400 2.8GHz 1 x ASUS Prime H310-Plus Intel H310 ATX matična ploča 1 x G. Skill Aegis 8GB DDR4 3000Mhz 1 x ZOTAC GeForce GTX 1060 3GB AMP! Edition 1 x Kingston Technology A400 SSD 120GB 120GB 2.5" Serijski ATA III 1 x WD Blue 1TB SATA 1 x Fortron napajanje Hyper M 500W, polu modularno 1 x Sharkoon VG5-V Midi Tower ATX kućište, bez napajanja, crno UKUPNO: 6030kn Zadnje izmijenjeno od: coconut. 15.06.2018. u 15:35. |
#4236 | |
Postovi: 16,708
1 x ASUS B350M-K 1 x G. Skill Aegis 8GB DDR4 3000Mhz 1 x Kingston Technology A400 SSD 120GB 120GB 2.5" Serijski ATA III 1 x WD Blue 1TB SATA 1 x MSI GeForce GTX 1050 Ti 4GT OC 1 x Fortron HD420 W napajanje ATX, 85%,active,bulk 1 x Sharkoon VG5-V Midi Tower ATX kućište, bez napajanja, crno 1 x Acer ET241Ybi LED Monitor IPS ZeroFrame UKUPNO: 5800kn |
#4238 |
Postovi: 16,708
Može i i3. Složi čovjeku. |
#4239 | |
Postovi: 1,572
1 x Intel CPU Desktop Core i3-8100 (3.6GHz, 6MB, LGA1151) box 1 x MSI Main Board Desktop B360 (S1151, DDR4, USB3.1, USB2.0, SATA III,M.2, DVI-D, VGA - Requires Processor Graphics, 8-Channel(7.1) HD Audio with Audio Boost, Realtek 8111H Gigabit LAN) mATX Retail 1 x Patriot Signature DDR4, 2400Mhz, 8GB, CL15 1 x Grafička kartica Asus GTX 1050 Ti 4GB/128bit, GDDR5 1 x CRUCIAL MX500 250GB SSD, 2.5” 7mm (with 9.5mm adapter), SATA 6 Gbit/s, Read/Write: 560 MB/s / 510 MB/s, Random Read/Write IOPS 95K/90K 1 x Seagate HDD, 2TB, 7200rpm, SATA-6, 64M 1 x Napajanje Thermaltake Smart RGB 500W 1 x MS WINSTON midi tower gaming kućište Ukupno: 6.207,00 kn (-2%=6.082kn) Besplatno slaganje i dostava |
#4241 |
MiningMod
Postovi: 8,715
#4242 |
cyborg
Datum registracije: Dec 2016
Lokacija: hills of SB
Postovi: 236
Mislim da je ipak mislio na ovu https://www.gigabyte.com/Motherboard...-DS2-rev-10#kf Samo mu se 0 izgubila. ![]() |
#4244 |
Postovi: 735
Društvo, znam da se pitanja ponavljaju, ali prošlo je već skoro 15 dana od zadnjeg posta i neke stvari više ne mogu naći sve u jednoj ili dvije trgovini da skratim vrijeme šetanja po gradu. U Zagrebu sam, preporuka koja trgovina, treba mi samo kištra i sve što ide u nju i apsolutno ništa od periferije. Cifra do 6000kn plus minus 500kn. Običan HDD ne trebam jer imam od starog kompa, treba mi samo SSD od nekih oko 240GB za OS i pokretanje zahtijevnije igre, i sad dalje ugrubo trebam najmanje 8GB RAM-a, jaka grafička bla bla. Nekad sam i ja preporučiao konfiguracije, no više od tri godine ne pratim komponente tako da više nisam u toku. Namjena isključivo za gaming. |
#4248 |
Postovi: 1,572
1x AMD Ryzen 5 1600, 6C/12T 3,4GHz, 19MB, AM4 1x Matična ploča GIGABYTE GA-AX370M-Gaming 3 2x Patriot Elite DDR4, 2666Mhz, 8GB, CL16 1x Gigabyte GF GTX1060 WF2 OC, 3GB GDDR5 1x Kingston A400 240GB SSD, SATA 1x Fortron napajanje Hexa 85+ 550W, 80+ Bronze, ATX 1x MS FALCON PRO midi tower gaming kućište plavi LED ventilatori Ukupno: 6.611kn (-2%=6.478kn) Besplatno slaganje i dostava |
#4251 |
Postovi: 1,572
1x Intel CPU Desktop Core i5-8400 (2.8GHz, 9MB, LGA1151) box 1x CPU Hladnjak LC-CC-95, Intel/AMD, 90mm 4-pin 1x Gigabyte GA-B360M-DS3H, 1151 CL 1x Patriot Elite DDR4, 2666Mhz, 8GB, CL16 1x Gigabyte GF GTX1060 WF2 OC, 3GB GDDR5 1x Western Digital HDD, 1TB, 7200rpm, Caviar Blue 1x Fortron napajanje Hexa 85+ 550W, 80+ Bronze, ATX 1x MS FALCON PRO midi tower gaming kućište plavi LED ventilatori Ukupno: 6.107kn (-2%=5.984kn) Besplatno slaganje i dostava |
#4253 |
Datum registracije: Mar 2011
Postovi: 2,707
Nije skroz prema željama, ali imaš 6GB verziju. Istina da je single-fan, ali mislim da je jedan kolega s foruma rekao da buka nije problem na tom modelu. Patriot Elite DDR4, 2666Mhz, 8GB, CL16 Toshiba P300 1TB 3.5" MSI Main Board Desktop B350 (SAM4, 2xDDR4, PCI-Ex16, 2xPCI-Ex1, USB3.1, USB2.0, 4xSATA III, M.2, Raid) B350M_PRO-VD_PLUS Inno3D GeForce GTX1060 6GB Compact, INO-N1060-6DDN-N5GM Procesor AMD Ryzen 5 2600 Kućište Thermaltake Versa N23 2x MS PC COOL 12cm hladnjak za kućište -> za front panel Corsair PSU Builder Series CX450, 450 Watt Power Supply, EU Version Sveukupno: 6.055,95kn |
#4255 |
to bucno i tiho je toliko subjektivno da se ne vrijedi uopce koristiti tom terminologijom u kontekstu racunalnih komponenti, eventualno navesti neki reference point ili do koliko RPM se ventilatori vrte pa nek pojedinac odluci... osobno mi je necujno jedino pasivno racunalo bez hard diskova evetnualno sa ventilatorima do 500rpm, jasno cujem sve preko 700rpm i smeta mi vec, glasno mi je sve preko 1200rpm, stare r9 280x koje znaju ici 2000+rpm (kao vjerojatno single fan gtx1060, obzirom su dual fanke palit i asus sto sam imao trebale oko 1800rpm za 77-80c) ne bih prihvatio u racunalo nikako dok se poznanik sa stock amd coolerom i hddima u racunalu izrazava "ne cujem" Zadnje izmijenjeno od: trpi. 30.06.2018. u 21:54. |
#4257 | |
Postovi: 735
Kućište stvarno izgleda super u odnosu na to koliko košta, čak sam se i iznenadio zar je moguće kupiti za te pare takvo kućište. |
#4259 |
Postovi: 735
Pa prije 5 godina takva kucista nisi mogao nabaviti ispod 500kn nikak ! To se jako dobro sjecam jer dulje vrijeme pokusavam zamjeniti staro bijelo kuciste DTK, pa nikak da ga zamjenim jer nisam mogao za vrijeme studiranja naci 500kn. A sad ovakvih kucista imas za 200-300kn kojih cak ni studentu nije problem pljunuti. |
#4260 |
Postovi: 1,513
Što kažete na sljedeću konfiguraciju za FHD gaming? Neću skoro prelaziti na veću rezoluciju. Intel i 3 8100 Asrock B360m Corsair 2x8gb ddr 4 2666 MHz SSD 240 gb Kingston HDD WD Blue 1 tb Corsair VS550, 550 W Cijena u HG spotu sa kućištem nekim bzveze 4400kn, i uzeo bi polovnu RX 580 8 gb za cca 1800 kn. |
