#4921 |
Uptime 99.99%
Postovi: 2,569
Broj za support im je iskljucen, a na 0800 1000 je poruka da je to globalni problem na razini Hrvatske.
#4922 |
Lokacija: Worldwide
Postovi: 2,553
Proradilo. |
#4923 |
The Zappa
Postovi: 595
Četiri godine ovako: Code:
============================================================================ VDSL Training Status: Showtime Mode: VDSL2 Annex B VDSL Profile: Profile 8b Traffic Type: PTM Mode Link Uptime: 0 day: 11 hours: 53 minutes ============================================================================ VDSL Port Details Upstream Downstream Line Rate: 2.046 Mbps 20.479 Mbps Actual Net Data Rate: 2.047 Mbps 20.480 Mbps Trellis Coding: ON ON SNR Margin: 7.8 dB 6.7 dB Actual Delay: 0 ms 0 ms Transmit Power: 12.7 dBm 18.6 dBm Receive Power: 0.8 dBm 0.2 dBm Actual INP: 12.0 symbols 27.0 symbols Total Attenuation: 12.1 dB 18.4 dB Attainable Net Data Rate: 2.263 Mbps 21.997 Mbps ============================================================================ VDSL Band Status U0 U1 U2 U3 D1 D2 D3 Line Attenuation(dB): 19.5 N/A N/A N/A 33.9 102.3 N/A Signal Attenuation(dB): 19.5 N/A N/A N/A 31.5 N/A N/A SNR Margin(dB): 7.8 N/A N/A N/A 6.7 N/A N/A Transmit Power(dBm): 12.7 N/A N/A N/A 18.6 N/A N/A ============================================================================ Code:
============================================================================ VDSL Training Status: Showtime Mode: VDSL2 Annex B VDSL Profile: Profile 17a Traffic Type: PTM Mode Link Uptime: 0 day: 0 hour: 8 minutes ============================================================================ VDSL Port Details Upstream Downstream Line Rate: 2.799 Mbps 23.999 Mbps Actual Net Data Rate: 2.800 Mbps 24.000 Mbps Trellis Coding: ON ON SNR Margin: 31.0 dB 27.3 dB Actual Delay: 0 ms 0 ms Transmit Power: 1.9 dBm 10.0 dBm Receive Power: -15.2 dBm -9.9 dBm Actual INP: 54.0 symbols 51.0 symbols Total Attenuation: 18.0 dB 19.9 dB Attainable Net Data Rate: 48.789 Mbps 81.531 Mbps ============================================================================ VDSL Band Status U0 U1 U2 U3 D1 D2 D3 Line Attenuation(dB): 6.5 21.3 31.9 N/A 13.1 27.2 40.6 Signal Attenuation(dB): 6.5 20.8 33.0 N/A 9.0 26.9 40.6 SNR Margin(dB): 31.0 31.0 31.0 N/A 27.3 27.4 27.0 Transmit Power(dBm):-10.1 - 0.5 - 0.4 N/A - 1.5 7.9 5.2 ============================================================================ ![]() |
#4924 |
Lokacija: vž
Postovi: 1,331
Vjerojatno vijeće mudraca mora vijećati i složiti brži paket od 50/10. Ili im nije napeto, jer ruku na srce, 1/10 korisnika probija tu granicu (random broj izvučen iz glave ![]() |
#4925 |
The Zappa
Postovi: 595
Baš! Fleksibilni su ko dotrajale michelin gume. ![]() |
#4926 |
Lokacija: vž
Postovi: 1,331
A gle, kak bude vise ljudi na FTTx, tak ce dizati brzine. Optika je bila prvo 80/40 pa eto ga na 200/100. Tak da sumjam da nece staviti od 10-100 paket na vdsl pa kolko vuče vuče ![]() |
#4927 |
The Zappa
Postovi: 595
Jest, u pravu si. Ovo je komotno 'optička brzina' i rado bih im dao 200 i kusur kuna da me formalno stave na optiku, ali ne... VDSL i to je to. ![]() |
#4928 | |
Postovi: 772
#4929 | |
The Zappa
Postovi: 595
E, da, "mora se". ![]() ![]() Pitao sam ih, kažu ne može. OK , tako je. Glupo je, ali nije moj problem. Mislio sam da postoji čisto matematički razlog, a ne "takvi su nam paketi". Citiraj:
![]() Koliki je Attainable Net Data Rate na optici (ako toga uopće ima na optici), a koliko puštaju? Zadnje izmijenjeno od: karabaja. 21.05.2018. u 20:49. |
#4930 |
Lokacija: vž
Postovi: 1,331
na čistoj optici ide kolko svjetla uspiju nagurati nutra i koju tehnologiju koriste. Mislim da je 1G neki min, a 10G ili 100G uz opremu nije greda. |
#4931 |
Datum registracije: Apr 2015
Postovi: 1,703
problem nije u tome koliko može kroz optičku nit nego je problem u krajnjoj opremi odnosno skupoći 1G routera,odnosno modema,tek su se nedavno pojavili i trenutno su preskupi za široku upotrebu sa stajališta operatera(čitaj t-com/vip u nas),kako na optici tako i na kablu,ovo što reklamira t-com je trenutno pilot projekt i dok bude dostupan svim sadašnjim korisnicima optike mogu proteći godine,osim ako vip ne iznenadi sa docsis 3.1 pa ubrza stvari i kod t-coma ,o 10G i više ćemo vjerojatno razgovarati polovinom sljedečeg desetljeća ![]()
#4932 |
Lokacija: Lava Reef
Postovi: 1,137
Se moze preko routera nekak blokirati tel i mob brojevi koje necu da me gnjave ili moram iskonovce zvat ili to ni ne nude ?
Why would you invite a mushroom to a Christmas party? He's a fun guy to be with. Why do mummies like Christmas so much? Because of all the wrapping. Why does Santa have three gardens? So he can "ho ho ho". |
#4933 |
Kostolomac
Postovi: 1,510
![]() Spojili me danas, zadovoljan sam. Nisam imao problema sa port forwardanjem na Innboxu V51. Jedino se osjeti manja kvaliteta IskonTV-a u odnosu na Bnet, ali je zato više programa uz 20kn manju cijenu. EDIT: čini mi se da mi je veći ping u CSGO nego što je bio na Bnetu, ali barem je skroz stabilan. Zadnje izmijenjeno od: d0X. 23.05.2018. u 11:43. |
#4934 |
Datum registracije: Jan 2010
Postovi: 2,137
Koji paket? Koliko novaca? Jeli razlika u slici samo na SD ili i na HD kanalima? Hvala |
#4935 |
Lokacija: vž
Postovi: 1,331
vjerojatno smart full paket |
#4936 | |
Postovi: 291
#4938 |
Postovi: 291
Inače, kakva je slika na Iskonu, SD i HD kanali? Ako netko nešto može reći o ovome... |
#4939 |
Postovi: 772
Koliko sam ja vidio, bnet preko coaxa ima bolju sliku od bilo kojeg naseg iptv providera, jednostavno pustaju veci bitrate i slika bolje izgleda |
#4940 | |
Postovi: 753
HD je zadovoljavajući na Iskonu, imam samo HBO. Njega baš ne mogu usporediti pošto sam na MaxTV-u imao Arenu HD koju nisam gledao (ja i sport ko krava i balet ![]() Uglavnom, žena ne primijeti razliku, ja kažem da je nešto lošija kvaliteta. (koju kompenziram puuuno manjim računom ![]() |
#4941 |
Datum registracije: Sep 2010
Postovi: 39
Ovako, trenutno sam jos na bnetu ali s iskonom se natezem evo ima vec tri mjeseca kako sam potpisao zahtjev s njma za prelazak. Pisao sam im i u reklamacije al evo traje i to. Optiku su mi postavili u stan prije malo vise od tjedan dana. Tek u petak sam prvi put vidio da je tel. broj u stanju prijenosa. Da li ja jos uvijek mogu ostati na bnetu nakon tog silnog natezanja bez obzira sto sam dobio poruku da tehnicar dolazi iduci tjedan da me spoji? Da mi ne izmisle jos da sam ja njima duzan neku lovu a navlace me ko budalu... |
#4942 | |
Datum registracije: Feb 2015
Lokacija: Sisak
Postovi: 827
Evo ako je nekome promaklo da ne bi bilo joj meni ne radi. ![]() Citiraj:
#4943 |
Postovi: 753
Hmmmm, danas skužim da je WLAN na routeru upaljen (bio je zgašen) i ne mogu se ulogirati u router sa defaultnim user-om i pass-om. Resetirao router i nulla bodova. Izgleda da su ga oni resetirali na nullu ne znam ni ja kad, ali mi je veći problem što ne mogu u router ući :/ Može netko provjeriti jel kod vas sve OK? |
#4944 |
The Zappa
Postovi: 595
User je i dalje 'Administrator', ali je šifra sad, nakon upgradea, ono što piše na routeru u polju 'wireless key'. |
#4945 |
Lokacija: Lava Reef
Postovi: 1,137
oni koji dobiju Enkom ruter, lozinka vam ja kao i user name: Administrator
Why would you invite a mushroom to a Christmas party? He's a fun guy to be with. Why do mummies like Christmas so much? Because of all the wrapping. Why does Santa have three gardens? So he can "ho ho ho". Zadnje izmijenjeno od: HumWeed. 04.06.2018. u 15:56. |
#4946 |
Postovi: 1,542
Jel ima netko Iskonovu uslugu na optici net i TV? Koji se uređaji dobe? |
#4947 |
Lokacija: Lava Reef
Postovi: 1,137
joj mi netko moze objasnit zasto ovaj glupi enkom nemoze da mu radi wifi sve je podeseno // dobra lozinka, AES // wpa2-psk al nemogu niti jedan mobitel spojit stalno sere autentication problem
#4948 |
Postovi: 1,542
stavi AES+TKIP |
#4949 |
Lokacija: Lava Reef
Postovi: 1,137
nece ni sa AES-TKIP evo mojih postavki ako nesto znaci ![]()
#4950 |
Postovi: 1,542
Stavi fiksni kanal i AES+TKIP pa napravi reset |
