Zaključane teme
Staro 11.05.2018., 13:29   #601
gunther
Postovi: 1,358
Blizimo se 100%, a bloka nema...
nece pa nece...
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2
gunther je offline
Staro 11.05.2018., 13:46   #602
O9g1
Bee-do Bee-do Bee-do, TUP
O9g1's Avatar
Datum registracije: Aug 2009
Postovi: 323
Ovog je valjda urekla baba Manda urokača
CPU: Intel i5 2500k (BX80623I52500K) cooled by Scythe Ninja3 (SCNJ-3000)
MBO: Asus P8Z68-V PRO/GEN3
RAM: 2x4GB Kingston 1600MHz, DDR3, XMP (KHX1600C9D3K2/8G)
GPU: GIGABYTE Radeon R9 290 4GB Windforce 3x (GV-R929OC-4GD)
SSD: Samsung 840 EVO 120GB (MZ-7TE120BW) - System
HDD1: WD Caviar Black 500GB (WD5001AALS) - Storage
HDD2: WD 250GB (WD2500JS-22MHB0 ) - Backup
ODD: Samsung 22/8/8/48/32x (SH-S222AB)
PSU: XFX XXX Edition P1-650X-CAG9 650W
CASE: Fractal Design Arc midi
FAN CONTROL: Scythe KAZE MASTER 5.25″ Bay Fan Controller (KM01-BK)
FAN: 2x Fractal Design Dynamic GP-14, 140 mm intake+2X Scythe S-flex 120mm (SFF21E) exhaust
OS: W10 x64
LCD:MASTER: LG 29UM57-P Ultra širok đubar, jooooj što ga volem... , SLAVE: Dell 17"
KEYBOARD: Logitech UltraX keyboard (Y-BL49)
MOUSE: Logitech G400
SOUND: Creative Sound Blaster X-Fi XtremeMusic
HEADSET: Steelseries Siberia v2
RALLYING GEAR: Logitech G25+homemade cokpit+handbrake (modani Genius MaxFighter F-16U)
IF IN DOUBT, FLAT OUT!!!
Don't touch it! It is mine! It's all miiiiineeee!!!
Lenovo Essential B580
CPU: Intel Celeron Dual Core B820 1.70GHz (2MB cache)
LCD: 15.6" HD LED 1366 x 768
GPU: Intel HD Graphics 3000
RAM: 4GB DDR3 1600MHz
HDD: 320GB SATA
ODD: DVDRW DL
PSU: Up to 4hours (Li-Ion 6 cell)
ETHERNET: Yes (Gb LAN)
COMM: Yes (802.11b/g/n)
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
FINGERPRINT READER: Yes
CAMERA: Yes
OS: Windows 7 Profesional
Lenovo ThinkPad E560
CPU: Intel Core i7-6500U 2.5 GHz
LCD: 15.6 inch 16:9, 1920x1080, IPS-Panel, LED-Backlight, glossy: no
Extern LCD:Lenovo X24a, 24 inch 16:10, 1920x1200, IPS-Panel, LED-Backlight
GPU: AMD Radeon R7 M370 2 GB GDDR5
RAM: 16GB, 2 x 8 GB DDR3L-1600
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
ETHERNET: Gigabit Ethernet
COMM: 802.11ac, Bluetooth, Intel Dual Band Wireless-AC 8260 - M.2 Card
CONNECTIONS: 3 x USB 3.0, HDMI, VGA, OneLink connector, LAN, Headphone/microphone combo jack
CARD READER: 4 in 1 ( SD Card, MultiMediaCard, SDHC Card, SDXC Card )
CAMERA: Yes
OS: Windows 10 64x
Poštena, dobra i odgovorna trgovina +još jedna...
Straight roads are for fast cars, turns are for fast drivers!
O9g1 je offline
Staro 11.05.2018., 13:55   #603
aerial
Datum registracije: Oct 2017
Postovi: 163
i moj mašklin je od sada u hrvatskom rudniku
aerial je offline
Staro 11.05.2018., 14:13   #604
Nbdy32
Datum registracije: Aug 2016
Lokacija: Bestovje,Sv.Nedelja
Postovi: 2,821
eto 101,valjda bu sad,jbga naviko nas od jučer na par komada i sad nikako ;-)
Nbdy32 je offline
Staro 11.05.2018., 21:02   #605
aurellie
aurellie's Avatar
Datum registracije: Nov 2002
Lokacija: i
Postovi: 504
kad ceeee moneroooooooooo
The machine spirit is with me!
aurellie je offline
Staro 11.05.2018., 21:04   #606
aurellie
aurellie's Avatar
Lokacija: i
Postovi: 504
aha, vidim pool je online, cak i majna netko. Je li sve postavljeno, mozemo li se spajat? I nije li fee od 1% malo velik za novi pool?
aurellie je offline
Staro 11.05.2018., 21:20   #607
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
I sa ETH smo krenuli od 1 Pa ćemo polako spuštati, sada je 0.8 pool + 0.2 za dev-a...
Možete se spajati pa da vidimo kako on radi, budem i ja pripomogao
FRipper je offline
Staro 11.05.2018., 21:43   #608
aurellie
aurellie's Avatar
Lokacija: i
Postovi: 504
Ne mogu se spojit. Pingam server i sve ok ali miner (cast xmr) mi izbacuje socket error.
pool xmr.gigantpool.com:5555
Moram li imat neki od nabrojanih minera na siteu ili mogu sa castom?
aurellie je offline
Staro 11.05.2018., 21:50   #609
gunther
Postovi: 1,358
Joj, sto bi bilo super da nam sada padne kakav blokić
gunther je offline
Staro 11.05.2018., 22:26   #610
aurellie
aurellie's Avatar
Lokacija: i
Postovi: 504
Kad probam sa XMR-STAK sve radi ok. Ali kad koristim CAST XMR pisse ERROR: SOCKET CLOSED. Zasto? Je li problem do mene ili do servera?
Kako imam dobar razlog da koristim cast umjesto stak, necu se pokusavat spajat dok ne nadjem rjesenje
aurellie je offline
Staro 11.05.2018., 22:43   #611
kratos
Datum registracije: Apr 2018
Postovi: 131
Autor aurellie Pregled postova
Bilo bi poželjno neki od onih nabrojanih, jako je bitno naglasiti monero7 opciju..
Svi mineri imaju config fajl pa možete koristit pool da vam configurora config fajl.. Ono što vam pool izlista ubacite u config fajl a u bat fajl samo stavite nazive exe fajla...
Ili možete skinuti određeni program i aktivirajte exe fajl i on će vas pitati parametre pa će sam napraviti config fajl..
kratos je offline
Staro 11.05.2018., 22:46   #612
kratos
Postovi: 131
Kopiraj ovdje u txt formatu svoj bat fajl da čekiram ak želiš..Imaš vega kartice i zato ga koristiš, kužim..
kratos je offline
Staro 11.05.2018., 22:46   #613
aurellie
aurellie's Avatar
Lokacija: i
Postovi: 504
Definitivno je CN7...probao sam na nekoliko drugih poolova, a redovito majnam na supportxmr, i samo ovdje ne radi. Zanimljivo, sa STAK radi, sa CAST ne.
Nisam danas htio vise imat downtime, sutra cu opet probat.
aurellie je offline
Staro 11.05.2018., 22:49   #614
aurellie
aurellie's Avatar
Lokacija: i
Postovi: 504
cast_xmr-vega --algo=1 -S xmr.gigantpool.com:5555 -u xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.home --opencl 0 -G 0, -p home:xxxxxxxxxxxx@gmail.com --fastjobswitch 1 --nonicehash 1 -R*
evo ovo mi je konfig sa gaming kompa, jedna grafa. Ista stvar, STAK radi, CAST ne, a radi na drugim poolovima.
Da, vege su u pitanju
aurellie je offline
Staro 11.05.2018., 22:54   #615
kratos
Postovi: 131
home:xxxxxxxxxxxx@gmail.com izbaciti
--fastjobswich ti ne treba to pool radi, izbaciti
--nonicehash 1 -R* isto
probaj bez toga..
Nemaš config fajla samo bat fajl?
Ak imaš config faj pobrini se da ispred svakog reda bude # tada ga ne čita..
kratos je offline
Staro 11.05.2018., 22:56   #616
kratos
Postovi: 131
Fali ti opcija
monero7 ili pow7...
kratos je offline
Staro 11.05.2018., 23:00   #617
kratos
Postovi: 131
cast_xmr-vega --algo=pow7 -S xmr.gigantpool.com:5555 -u xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.home --opencl 0 -G
Nisam siguran što ti je ona NUla sa zarezom, ali ovo bi trebalo šljakati..
kratos je offline
Staro 11.05.2018., 23:01   #618
aurellie
aurellie's Avatar
Lokacija: i
Postovi: 504
Poceo micat sve jedno po jedno i evo ga proradilo! Treba maknut worker name nakon adrese, tj iz xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.home izbacio sam ovo .home
Puno hvala na help, idem prebacit rigove
aurellie je offline
Staro 11.05.2018., 23:02   #619
kratos
Postovi: 131
G 0 ti ne treba isto pošto imaš samo jednu grafu..
kratos je offline
Staro 11.05.2018., 23:03   #620
kratos
Postovi: 131
Eto, baš mi drago da sam bar indirektno pomogao..
kratos je offline
Staro 11.05.2018., 23:10   #621
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
Daj ti pomogni nać blok, želim sretan leć
žmnpp
buljo je offline
Staro 11.05.2018., 23:14   #622
kratos
Postovi: 131
Wow..već piše 3 tjedna za blok...Dajte ljudi još 10khs da ga srušimo za dan-dva..Puno je lakše kopati neg eth i isplativije zbog struje.. idem i ja nekaj crkavice prikopčati..hahahahahahahahahahaha
kratos je offline
Staro 11.05.2018., 23:19   #623
aurellie
aurellie's Avatar
Lokacija: i
Postovi: 504
Evo uspio sam prebacit 3 riga ali 4 nece spojit ni teamviewer ni chrome remote...samo crni ekran prikazuje. Cini se da nadogradnja na windows 1803 nije bila bas pametna ideja (( Pa cu se sutra prebacit kad odem na selo. Zivili i hvala svima na pomoci, znaci ako naletite na koga sa slicnim problemom nek makne ime workera iza adrese
aurellie je offline
Staro 11.05.2018., 23:39   #624
kratos
Postovi: 131
Vnc server zakon ak nemaš walleta na njemu spojiš na cloud i imaš besplatno 5 rigova, prolazi kor routere firewall i ostalli shit..
Spojio i ja svoju crkavicu, nekak mi fali monera ovih dana...hahahahahahahaha
kratos je offline
Staro 11.05.2018., 23:47   #625
kratos
Postovi: 131
LJudovi, treba nam 1 mhs (malo manje al volim zaokružiti) da skidamo 1 blok po danu.. Upravo računao..
kratos je offline
Staro 12.05.2018., 00:00   #626
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Probao bi i ja monero ( ovaj eth već grije previše!)
Zadnji put sam monero na nanopoolu rudario, sa Srbminerom!
Pa SAD baš nisam siguran kako podesiti za ovaj novi moneroV
Koristi li ko srbminer?
Poslano sa mog A0001 koristeći Tapatalk
MinigRig*H110-D3A*5*rx570nitro8GB OC.
gloginjaR je offline
Staro 12.05.2018., 00:05   #627
kratos
Postovi: 131
Autor gloginjaR Pregled postova
samo dođi pomoći ćemo ti..prvo skini neki od programa tamo koji je najbolji za tebe, nvidia, amd ili oboje..
kratos je offline
Staro 12.05.2018., 00:12   #628
kratos
Postovi: 131
U pools txt ubaci ovo:
{"pool_use_tls" : false, "keepalive" : false, "pool" : "xmr.gigantpool.com:3333", "wallet" : "YOURWALLET.IMERIGA", "password" : "x"},
drugi red izbriši i bude šljakalo..
Ak imaš slab hardware uzmi port 3333 ak imaš jači hardwer uzmi port 5555
Btw, zgodan programčić, nisam ga do sada gledao..
Zadnje izmijenjeno od: kratos. 12.05.2018. u 00:17.
kratos je offline
Staro 12.05.2018., 00:22   #629
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Autor kratos Pregled postova
Sutra probama pa javim rezultat hvala.
Imam5x rx570nitro 8gb. Koji port stavit?
Staro 12.05.2018., 00:30   #630
kratos
Postovi: 131
3333 onda..
kratos je offline
Zaključane teme
