Staro 22.04.2018., 02:40   #91
Postovi: 8,421
Mislim da GloFo laprda bez veze. Fakat mi nije jasno kako će AMD-u na proizvodnim procesima čijima su tvorcima na prvom mjestu mobitelaši i low power node, a za high performance "šta bude bude" - rasti clock do 5ghz, a intelu koji je utukao milijarde isključivo u high perfomance proizvodne procese - padati clockovi sa 5ghz na niže. Nešto mi tu sve opako smrdi. Il je intel opako zasrao ili ovi drugi (glofo i tsmc) nemaju pojma što ih još čeka...
Siva eminencija iza svega kaj GlobalFoundries radi je IBM, a mislim da se možemo složiti da je Veliki Plavi ipak malo drukčiji igrač - čak i kad je u pitanju Intel.
GlobalFoundries acquired IBM’s microelectronics business unit along with fabs, personnel and customers. Under the terms of the deal, IBM paid GF around $1.5 billion in cash to take the business, and gave GF access to its leading edge manufacturing patents, but in exchange GF was obliged to serve IBM’s clients and to produce IBM CPUs made using custom fabrication processes for the following 10 years (until 2024). General specifications of GF’s first variant of the 7LP process technology uses deep ultraviolet (DUV) argon fluoride (ArF) excimer lasers with 193 nm wavelength. These processes are relatively well known, but we also know that the company plans to offer three generations of the technology, two of which will use EUV lithography. Something less known is that there will be five different versions of GF’s 7 nm node aimed at different applications.
Sve ovo ne mora nužno značiti da ćemo ubrzo imati 5.0GHz Ryzen modele, ali po svemu sudeći IBM i GlobalFoundries spremaju nešto za svoj 7nm proizvodni proces.
The 7nm platform of GlobalFoundries is called 7LP for a reason — the company is targeting primarily high-performance applications, not just SoCs for smartphones, which contrasts to TSMC’s approach to 7nm. GlobalFoundries intends to produce a variety of chips using the tech, including CPUs for high-performance computing, GPUs, mobile SoCs, chips for aerospace and defense, as well as automotive applications. GlobalFoundries has been processing test wafers using 7nm process technology for clients for several quarters now. The company’s customers are already working on chips that will be made using 7nm DUV process technology, and the company intends to start risk production of such ICs early in 2018. Keep in mind that large customers of GlobalFoundries (such as AMD) do not need the final version of the PDK to start development of their CPUs or GPUs for a given node.
Izvor i štivo za kasno nedjeljno poslijepodne:
Zadnje izmijenjeno od: The Exiled. 22.04.2018. u 03:52.
Staro 22.04.2018., 03:03   #92
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,899
Gledam tu malo neke grfove R7 2700.
https://wccftech.com/review/amd-ryze...therboards/10/
Pa taj 65w proc sada ozbiljno dise za vratom i7 8700K, razlike su zanemarive.
Jeftiniji je R7 tu negdje oko 200/250kn i kada izadju B450 ploce koje ce definitivno biti jeftinije od sadasnjih Z370 za Intela koje jedine dozvoljavaju OC to je vec fina usteda za perfomanse unutar 5-10% razlike.
Ne mogu vjerovati koji glupani su ovi iz Intela, Q370, H370, B360 te H310 i ni jedna ne podrzava ni neku minimalnu mogucnost OC-a !?
Z370 + i7 8700K
B450 + R7 2700
Za sada je razlika samo u cijeni procesora i bice zanimljivo vidit oce ovi bedaki iz Intela skuzit da jedne te iste perfomanse mogu kostati do 500kn manje ak si na Amd-u
trebaš seedbox?
silver_tip je online   Reply With Quote
Staro 22.04.2018., 03:24   #93
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Brži je u gamingu i veći brand, pa si mogu dozvoliti "price premium". Intel je čak sad i darežljiv sa ovim hexama s obzirom koliko su gulili sa quadovima
Kažem, što se tiče B450 zasad uopće ne postoje, ne treba se s njima uopće zamarati, moglo bi ispasti čekanje godota, može se komotno ići na B350, sva tehnologija je u procesoru (ram, boostanje), jedino ovaj StoreMI možda ovisi o X470 čipsetu, no nitko još ne zna imali vajde od toga uopće u praksi
Staro 22.04.2018., 08:26   #94
Z370 + i7 8700K
B450 + R7 2700
Ma nisu u Intelu glupi. Vidiš da ekipa kupuje skenjane procesore deliddanjem kojima ne radi dual channel, da kupuje i7 quad core kojima ne radi HT, dok je moj potpuno zdravi R5 1600 na jedvite jade otišao za 900 kn (plus šiping) (najjeftiniji novi je cca 1300).
Ne sekiram se ja za Intel uz takve mušterije da im idući procesori budu nešto a la NetBurst nakon P3, i dalje bi se kupovali ko vruće kifle.
Što se tvoje matematike tiče, B350 za manje od soma (Gigabyte ili Asus, nd mogu vjerovat šta pišem, počo sam Gigabyte gurat ljudima, a @Overclock_freak me nije potkupio niti mi cugu platio ) i taj R7 2700 koji na 4GHz ide ko od šale sa 1.3V, ti ćeš sa time imati jako fini upgrade u odnosu na ovo kaj sad imaš. Jedino je DDR4 i 32/64 GB guzoder po pitanju cijena (16GB ti je malo, ako se sjećam rasprave prije godinu dana ).
Sent from Mobara
Zadnje izmijenjeno od: Brko. 22.04.2018. u 08:32.
Staro 22.04.2018., 09:49   #95
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Baš zato. Jednostavno nemaju lufta za nešto bolje.
Jedino kad bi se cherry pickalo primjerke za 2800X do ljeta da dobiju još 100mhz, ali kažem nema smisla i vjerojatno nije isinito.
Mozda omoguce sve PCIE stazice na 2800X, kad ga se stavi na Z490 chipset. Da bude negdje izmedju Threadrippera i R7.
Staro 22.04.2018., 10:39   #96
Gigi1
Postovi: 2,138
Autor Gigi1 Pregled postova
cekam rivju na level1tech za storeMI, cini se kao ok komad softwarea
storeMI super stvarcica, kada bi sada kupovao bez razmišljanja bi uzeo x470
the irony to get the best experiance with optane u have to use amd platform
Staro 22.04.2018., 12:20   #97
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,899
Ma i nije toliko malo koliko je stvar navike da poduplam kod promjene platforme ali bice para, lugar se smilovao konacno i radi se punom parom
No prema vise testova sto sam bacio gledalicu i7 8700K je ok dok je na stock-u, bilo kakav pa i blazi OC ili forsiranje svih jezgri na 4.7GHz je ziva grijalica i treba dobar
cooler ili vodeno. R7 2700 na stock-u nije nis bitno slabiji a jeftiniji je no za razliku od R7 2700X cini se da non X R7 2700 ima osjetno manje temperature.
Skoro sam ja kupio taj tvoj proc jer sam slucajno naletio 0 min kako si opalio oglas no ovaj refresh Ryzena mi je definitivno napravio
guzvu jer nisam ocekivao da ce toliko biti blizu i7 8700K a cijena ovakog tek sada izaslog R7 je 500/600kn svega vise one cijene sto je imao R5 1600 kada je izletio vanka i ova sad cijena za R7 mora dolje bar 200kn kroz 1-2mj.
trebaš seedbox?
Staro 22.04.2018., 12:27   #98
trpi
sad kad intel izbaci 8 core coffe lake pa ce biti kuku lele gle perfomansi amd rekt
Staro 22.04.2018., 12:35   #99
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Introducing Enmotus FuzeDrive™ for Ryzen™, exclusively for AMD on Consumer Desktop PCs
To achieve these goals, AMD partnered with Enmotus, a company that develops high-end server-class storage solutions designed to optimize both performance and capacity in the data center. We worked together to tailor Enmotus’ FuzeDrive software for use with AMD Ryzen desktop processors in the consumer desktop PC space, for systems using the AMD B350 and X370 chipsets (Socket AM4* Ryzen™ 7, 5, and 3*) and the X399 chipset (socket sTR4 Ryzen™ Threadripper). That software is available for purchase today from Enmotus today for $19.99.
*Note: Enmotus FuzeDrive™ does not support the AMD A320 chipset
MojSkuter
Staro 22.04.2018., 13:07   #100
Autor trpi Pregled postova
Kad ga sjebem deliddanjem, budem ga tebi onda prodo u 50% cijene
Sent from Mobara
Staro 22.04.2018., 13:15   #101
Overclock_freak
Datum registracije: Dec 2012
Lokacija: Rijeka-Zagreb
Postovi: 1,207
Danas se vraćam sa puta pa ćemo benchati
Brko : haha a da nemogu ni ja vjerovati što čitam
Staro 22.04.2018., 14:00   #102
Postovi: 8,421
Da, ali Intel bude izbacil svoj octa-core mainstream procesor nekih godinu i pol nakon AMD-a i nema dvojbe da budu performanse na strani Intel modela.
Samo kaj bude taj procesor koštal kakvih 3.000 do 3.500 kn i uz to traži novu Z390 ploču koja bi u svojoj najjeftinijoj varijanti mogla koštati 1.500+ kn.
Staro 22.04.2018., 14:10   #103
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Rekao bih više 4.000kn... da si potpuno ne kanibaliziraju i7 7820X.
Staro 22.04.2018., 14:29   #104
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Treba pričekati TR+ , jer ako špekuliramo, aktualni TR kojeg čine zlatni primjerci lovi i do 4.3 kao ovi novi, a na staroj je tehnologiji koja kao jedva lovi 4GHz.
Tako da možda ima lufta taman ako bude nužno, da uistinu iscjede još 200MHz ibera za zlatne primjerke
MojSkuter
Staro 22.04.2018., 15:20   #105
Gigi1
Postovi: 2,138
@eladio u drugoj temi pretpostavljeno da je rijec o fuzedriveu
http://forum.pcekspert.com/showpost....postcount=4516
Staro 22.04.2018., 16:17   #106
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,499
X470 vs. X370 razlike y/n
https://www.youtube.com/watch?v=jIkQCszgW5Q
Delidded 2600
https://www.youtube.com/watch?v=VEUG9d4Mjug
ima i zlata radi boljeg kontakta vs šintelova smola iz ušiju
btw kako se teorija razvija u komentarima "nije ovo 12 nm" hhhhh
Zadnje izmijenjeno od: Tajl3r. 22.04.2018. u 16:28.
Staro 22.04.2018., 23:08   #107
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
..evo jedan od "najkraćih" video klipića vezano za ryzen2: https://www.youtube.com/watch?v=BT60W_EDel0
MojSkuter
Staro 23.04.2018., 01:11   #108
Manuel Calavera
Postovi: 14,584
Čekaj, koliko sam skužio čitava ta StoreMI priča se svodi na to da se uz X470 i X399 dobije u bundleu nekakav besplatni softver tj. licencu? Drugim riječima X470 je doslovce samo rebrand tj. neki novi modeli ploča koji su se komotno mogli zvati i x370
Staro 23.04.2018., 02:53   #109
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
MojSkuter
Staro 23.04.2018., 13:43   #110
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,332
HU review 2600 non X:
https://youtu.be/8sqs5aRBzCk
Izgleda da u silikonsku lutriju ulazi i kvaliteta IMC-a
2600 se da dobro OC-at, ali IMC je izgleda slabije kvalitete, e sada je samo pitanje koliko često će to biti.
Nekako X model izgleda ipak primamljivije.
Ionako po viđenom ga ubodeš i prst u uvo, XFR2 se brine za ostalo
Slobodno me dodajte na PSN
Zadnje izmijenjeno od: Disco. 23.04.2018. u 13:56.
Staro 23.04.2018., 18:01   #111
Manuel Calavera
Postovi: 14,584
Pametnije su (za sebe) odigrali ove godine sa X modelima. Prošle su sa non X modelima potpuno kanibalizirali sve iznad, kud su bili jeftiniji, tu su i dolazili sa coolerima, dok X bez coolera, a sam XFR ispao ćorak (boostanje 2 threada), overclockiranje isto. Ovaj put X modeli ne samo da dolaze sa coolerima, nego su i bolji cooleri nego na non X, a XFR2 je ovaj put nešto. Čak su mnogi revieweri dobili iste ili gore gaming rezultate sa manualnim overclockom od stocka u nekim igrama sa X modelima (jer je XFR2 više boosta 4 jezgre, nego što se može dobiti sa manualnim OC na svim jezgrama)
Svejedno što se tiče overclock potencijala opet su po svoj prilici isti (HU 2600 primjerak čak i bolji od 2600X), tako da je IMO ipak bolje ići na non X i za razliku u cijeni uzeti aftermarket cooler (ako se već nema), iako i stealth i dalje odradi posao, samo ne možeš puno overclockat."Turbo noobs" ako ništa ovaj put imaju nekakvo opravdanje za X modele
Zadnje izmijenjeno od: Manuel Calavera. 23.04.2018. u 18:06.
Staro 23.04.2018., 19:20   #112
redhill
Datum registracije: Jul 2017
Postovi: 66
Ljudi moji, jel moguce da u HR ni u jednoj trgovini nema 2600X ni X470 ploce zajedno? Neke trgovine imaju samo 2600X procesore, a neke samo X470 ploce, ali jos nisam nasao ni jednu trgovinu koja ima oboje u ponudi, pa koji k?
Sta je to s nasim trgovinama?
redhill je offline   Reply With Quote
Staro 23.04.2018., 21:04   #113
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
XFR nije auto OC opcija.
Vidim da tu mnogi griješe
Amd_Shill je offline   Reply With Quote
Staro 23.04.2018., 21:25   #114
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Autor redhill Pregled postova
UZI sve ima i kad nema, samo trebaš pitat
MojSkuter
Staro 23.04.2018., 21:37   #115
redhill
Postovi: 66
Autor Eladio Pregled postova
Ima 2600 i 2700, ali nema X verzije koje ja ocu Napisao sam im email, da sto prije nabave X verzije i imaju novog kupca ili bilo koja druga trgovina koja nabavi ili X470 ili 2600X s obzirom da skoro ni jedna trgovina nema X470 ili nemaju 2600X, stvarno smijesno
Staro 23.04.2018., 21:38   #116
Manuel Calavera
Postovi: 14,584
AKo ti je hitno ne moraš uopće preplaćivati x470 prema trenutnim cijenama, uzmi koju god AM4 ti paše
Staro 23.04.2018., 21:44   #117
Postovi: 8,421
R7 2700X + ASUS Prime X470-Pro - rezerviraj još dok se rezervirati da.
Staro 23.04.2018., 21:44   #118
redhill
Postovi: 66
Skroz novi komp kupujem, pa bi zato uzeo sve novo odnosno X470 i 2600X, iako mi svi govore da idem na intel posto vecinom samo igram igre, ali mislim da su Ryzen procesori opcenito bolji, nije sve u gamingu
Staro 23.04.2018., 22:00   #119
Manuel Calavera
Postovi: 14,584
Pa i X370 bi dobio novu
Kao što se par postova gore rasplelo nema hardverskih razlika u samom čipsetu, svodi se samo na razliku u imenu (naravno svaki pojedini model ploče je drugačiji u opremljenosti), te besplatnom FuzeDrive softveru (tzv. StoreMI)
Staro 23.04.2018., 23:59   #120
Gigi1
Postovi: 2,138
prime x470 ima dobru cijenu taman koliko kosta storeMI, nije preplacivanje ako ce koristi storeMI + vjerojatno ce dobiti koju kunu vise ako ce je ici prodavati za koju godinu
strix f 470 jos manja razlika u cijeni naspram 370tke
