Staro 19.04.2018., 23:14   #31
Postovi: 8,255
Autor Eladio Pregled postova
Tko je kriv za veće taktove memorije, novi cpu ili chipset?
Na temelju (malo) poboljšanog proizvodnog procesa su (između ostalog) uspjeli izvući niže latencije i bolju podršku za bržu memoriju. Obzirom da CPU SoC sadrži IMC, čipset (više) nema veze s memorijskom podrškom.
Staro 19.04.2018., 23:35   #32
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Rafinirani 14nm proizvodni proces, kojeg zovu 12nm
Staro 20.04.2018., 00:28   #33
Gigi1
Postovi: 2,138
Autor Gigi1 Pregled postova
max oc ocekivano los, ali krivulja napon/freq/potrošnja do 4GHz je brutalno dobra, cca 1.2V za 4GHz
ako 7nm proces za romu nastavi ovim koracima, nece biti lijepo intelu na serverskom tržištu
ovo je ono na sto sam ostao paf...70W niza potrošnja na 4GHz(1.162V) naspram zen1(1.425V)
Our review begins by discussing the most immediate improvement in the new Ryzen CPUs, which is the lowest stable voltage at a given frequency. The frequency curve for Ryzen is somewhat exponential, in that a 4.2GHz clock might take 1.38V to 1.4V to sustain, but a 4.3GHz clock takes beyond acceptable safe voltages in our testing.
To this end, we found that, at a given frequency of 4.0GHz, our R7 2700X held stable at 1.175V input at LLC level 4, which equated to 1.162V VCore at SVI2 TFN. The result was stability in Blender and Prime95 with torturous FFTs, while measuring at about 129W power consumption in Blender. For this same test, our 1700 at 4.0GHz required a 1.425V input at LLC level 5, yielding a 1.425VCore, a 201W power draw – so 70W higher – and pushed thermals to 79 degrees Tdie. That’s up from 57.8 degrees Tdie at the same ambient.
Prime95 produced similar results, but you can find those in the article below.
Lower voltage for a given frequency also means lower power consumption for the same frequency. To some extent, this is binning – but most of that large delta is from improvement of the product’s clock efficiency at the “old” high clocks of 4.0GHz
Staro 20.04.2018., 00:50   #34
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 712
Nisam prije vidio ništa od ovog youtubera pa je malo upitno, ali zanimljivo da je uzeo 6 kom. 2700X i svi idu na 4.2GHz stabilno, ispada bolje nego primjerci poslani na testove prije NDA.
https://www.youtube.com/watch?v=zqMRY49qheM
Staro 20.04.2018., 01:36   #35
Manuel Calavera
Postovi: 14,584
Staro 20.04.2018., 02:09   #36
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
..znao sam , zato sam i nedavno uzeo bez puno razmišljanja x370 ..sve je bilo poznato
MojSkuter
Zadnje izmijenjeno od: Eladio. 20.04.2018. u 03:23.
Staro 20.04.2018., 06:56   #37
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Jednom rijecju, impresivno... 4Ghz na svih 8 jezgri @1.2v i to bench stabilno je j3ben rezultat za AMD , samo LLC4 mi je malo too much . U biti, treba viditi koliko ploca overvolta pri loadu, nadam se da LLC ne overvolta kao kod C6H ili sam ja nesto propustija? Osobno nebi isa na nista vise od LLC3 za 24/7 tj. ovisno o voltazi, ali da je 4Ghz moguce i @1.25v sa LLC3, to je vise nego dobro.
Staro 20.04.2018., 07:03   #38
fAg
Datum registracije: Dec 2017
Lokacija: u hr
Postovi: 125
Autor Sn4k3 Pregled postova
Šta je LLC ako može? Ukratko
fAg je offline   Reply With Quote
Staro 20.04.2018., 07:17   #39
LoadLine Calibration. Uloga mu je da spriječi pad napona na komponenti (jezgra CPU) prilikom velikog opterećenja.
Npr. moj Ryzen u BIOSu ima zadano 1.300V. Bez LLCa kad bi upalio Prime95 (ili slično), napon moze pasti na 1.25V. Kad se LLC level postavi (2 i 3 su najpopularniji) onda taj napon prilikom opterećenja ostane isti ili minorno manji npr. 1.293V.
Veći LLC leveli čak mogu i dodati napona na tih 1.3V. Oni su pozeljni kod LN2 (tekući dušik) sesija i ganjanja svjetskih rekorda u suicide runovima.
Sent from Mobara
Staro 20.04.2018., 09:33   #40
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,625
Ipak ću čekati na zamjenu mog R5 1600 sa Zen 2 CPU-om, iako su ovo odlični procesori.
virty je online   Reply With Quote
Staro 20.04.2018., 12:55   #41
Manuel Calavera
Postovi: 14,584
Naravno. Ja ću mijenjati sa zadnjim zenom na AM4 socketu. I to vjerojatno ne odmah dok su friški
Nego Tech Yes City kaže da je refresh isprobao na dosta ploča i kaže da dobije iste ram brzine na B350/X370 i X470, logično jer je IMC na cpu, ali uglavnom niti sama ploča nije limitirajući faktor. O B450 se ne zna ništa tj. nema naznaka da uopće postoje, čini se da B350 ostaje za mainstream, barem neko vrijeme
Staro 20.04.2018., 13:08   #42
fAg
Lokacija: u hr
Postovi: 125
A ryzen 1. i 2. generacija ima znači 4 razine LLC-a? Pa koliko doda onda 4. razina LLC-a? Pa to se da iskontrirat opet,šta amd preporuča da se stavi?
Jel se OC na amd-u vrši preko biosa ili se može i preko windowsa(programski)?
Staro 20.04.2018., 13:16   #43
Manuel Calavera
Postovi: 14,584
Nema ti ryzen odnosno AMD nikakve veze sa brojem LLC stadija na ploči, to je isključivo do mbo proizvođača. Moja ako se dobro sjećam ima 5 stadija, ovisi od ploče do ploče kako se koja ponaša i kakav učinak ima, ako se dobro sjećam asus u tutorialu peporuča prva 2 stadija za vulgaris korisnike. A Z370 extreme 4 npr. od asorocka nije imala bog zna kakav učinak ni sa max LLC, barem ne do kasnijih biosa za koje je pisalo da su popravili llc
Staro 20.04.2018., 13:16   #44
Postovi: 8,255
Autor fAg Pregled postova
LLC implementacija ovisi isključivo o proizvođačima matičnih ploča i pripadajućim UEFI/BIOS revizijama. Kaj se clockanja tiče, provjeri kaj sve se nudi i može.
Staro 20.04.2018., 13:24   #45
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,268
Hmmm...Tech Yes City je u svom videu napomenuo kako ryzen 2 na X370 nije uspio navuć isti takt memorije kao na x470, što mi nekako ne drži vodu. Da budem precizniji kao fol na x470 je uspio dić memoriju na veći takt.
Slobodno me dodajte na PSN
Staro 20.04.2018., 13:28   #46
Manuel Calavera
Postovi: 14,584
Autor Disco Pregled postova
Mislim da je prvo rekao da sa refreshom ima isti takt memorije na svim mbo (b350, x370, x470), a da sa 1 gen ryzenom na istim nije mogao dobiti isti clock memorije (1800x - 3200mhz, 2700x - 3466mhz), samo ovaj drugi info možda nije artikulirao kako treba, ali se podrazumjeva sa obzirom na prvi info. Dakle u slučaju ploča keč je koji cpu koristiš
Iskreno čak mi je čudno da sa tim high end pločama na 1st gen sad ne mogu dobiti preko 3200mhz, kad mogu ja sa no name, non samsung b-die ramom na non high end ploči...
Staro 20.04.2018., 13:40   #47
syss
syss's Avatar
Postovi: 10,805
isuse bože pričate o vdroopu koji utječe na idle state kao i na load state i naravno da utječe na stabilnost kompa.
upalit to i bok.
Staro 20.04.2018., 13:49   #48
fAg
Lokacija: u hr
Postovi: 125
Jel intel coffee lake i dalje ima niže latencije od rayzena 2? I memorija ddr4 na intelu i dalje radi bolje,na većim taktovima?
Staro 20.04.2018., 13:53   #49
Postovi: 8,255
Autor syss Pregled postova
upalit to i bok.
Uključen je LLC po defaultu, samo ga ne treba ostaviti na Auto, jer neke ploče jednostavno imaju preagresivne postavke, pa je kasnije plač.
Da, Intel trenutno još uvijek ima bolju podršku za memoriju, ali polako i to sjeda na svoje mjesto s AMD strane.
Staro 20.04.2018., 14:52   #50
Manuel Calavera
Postovi: 14,584
Staro 20.04.2018., 15:46   #51
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Autor virty Pregled postova
Naravno. Ja ću mijenjati sa zadnjim zenom na AM4 socketu. I to vjerojatno ne odmah dok su friški...
Tako i ja planiram... Realno ne vidim potrebu mijenjati svoj 1600x jer bez muke radi na psiholoskoj granici od 4Ghz pa i vise po potrebi . Cekam zen2 i neki bijesni 8-core Ryzen 7 3700X koji ce radit na 4.2Ghz, boost na 4.8Ghz, sa xfr3 na 5Ghz, sve to sa 1.25v bez LLC-a, jos da kosta oko 2500kn
Staro 20.04.2018., 15:54   #52
trpi
pa da, nisu mi jasni ovi sto se upustaju u trosak 100eur za 10% perfomansi, i to samo u bechmarcima jer ionako ne zakucavaju procesor nikada do 100%. ali hajde podrzavaju i guraju amd dalje sto je lijepo
Staro 20.04.2018., 16:00   #53
fAg
Lokacija: u hr
Postovi: 125
Pa baš uspoređujem intel(coffee lake) i amd konfiguracije(ryzen 1 i 2) i cijena je praktički ista.Više naginjem amd-u jer nisu obuhvaćeni meltdown i spectre i zato jer nemaju integriranu grafiku šta mi je nepotrebno i plus inteli nisu zalemljeni.Više pluseva ima amd.
Staro 20.04.2018., 16:18   #54
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,459
Does Ryzen 2 perform better on X470 than X370?
https://www.youtube.com/watch?v=YSMXbbw2B8Y
Staro 20.04.2018., 17:35   #55
Overclock_freak
Datum registracije: Dec 2012
Lokacija: Rijeka-Zagreb
Postovi: 1,207
Pucajte što želite od testova itd
Evo upravo upogonjeno
https://valid.x86.fr/qx4760
Staro 20.04.2018., 17:38   #56
Autor trpi Pregled postova
100 kuna prijatelju, 100 kuna.
Sent from Mobara
Staro 20.04.2018., 17:41   #57
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Sent from Mobara
Imaš li još jedan po toj cijeni, dam i 150kn?
MojSkuter
Staro 20.04.2018., 18:14   #58
Gigi1
Postovi: 2,138
Autor Overclock_freak Pregled postova
4GHz all core, min. stabilna voltaza za npr.neki test poput blendera, occt-a ili slicno, GN rivju kaze da je 1.162V potrebno za takvo što, pa ako mozes potvrditi bilo bi super.
i sibni potrošnju iz hwinfo64 da vidimo koliko se razlikuje od njihove potrošnje koja je mjerena instrumentom(trebala bi biti oko 130W cpu only)
Staro 20.04.2018., 18:47   #59
Slažem se sa tripišom te ni meni nisu jasni koji bi sada izgorili 100+ eura u zamjeni Ryzena 1000 i Ryzena 2000. Još ajde de prilikom prelaska sa recimo 1600 na 2700X, ali sa 6 na 6, stvarno da, totalno nejasno za tih 100 eura. Ali da, lijepo je što pomažu AMD-u tako.
Drugi tjedan se javim. Odvrtio puno benčeva sa ovom svojom postojećom konfiguracijom, pa onda isti scenarij sa novim procom. Let's say idući tjedan, sredina pa prema kraju.
Do tada, @Overclock_freak neka ubija malo svoga da vidimo kako flagship ploča i flagship procesor rade skupa (još da ima B-Die RAM, nebi mu bilo kraja)
Staro 20.04.2018., 19:37   #60
Overclock_freak
Postovi: 1,207
Odvrtim danas ako stignem “ gigi”
pokusat cu i tvoje, masu imamo toga sad na poslu pa ne stizem nista doma
ako ti se da igrat dodi po proc i igraj se
