#91 |
Postovi: 2,138
ima li tko ovdje da je probao XMR stak i claymore cryptonote gpu miner na istom gpu i da li je bilo razlika u h/s? moze i neki treci popout sgminera ako je probavan...ugl citam po netu neki govore claymore neki govore xmr stak...
#93 |
Postovi: 344
Zanimljiva novost za Vega minere: Navodno su izašli novi driveri: 18-3-4 march 23 koji rade kako treba, iliti daju normalan hash rate kao sa beta blockchain driverima :-) info: https://forums.overclockers.co.uk/th...-3-0.18815432/ https://bitcointalk.org/index.php?topic=2256917.1900 |
#94 |
Lokacija: hr
Postovi: 976
Ako je isto kao blockchain driveri onda ne vidim zašto bi ljudi prelazili na nove: don't fix what is not broken. Kad su već radili nove driver onda su automatski trebali biti 10% bolji, i nakon ovih testiranja u public dodati još 10%. Ovako ne vidim svrhu nikakvu. Sa btctalk foruma: Just tested the new drivers vs the old blockchain drivers. Hash rate is slightly down on each of my Vega's by at least 40-50 h/s (with 8x Vega 64's) Also even though I applied the powertables, when opening OverdriveN most of the powertable settings get greyed out (I tweak some of the settings with my own profile within OverdriveN) when you apply settings. And powerdraw is slightly up, might be because of the powertables/OverdriveN not working properly. So. . . Switched back using the old blockchain drivers and all working fine (better hash, power and overdriveN working properly) Needless to say I'll be staying put for now with the blockchain drivers until things get updated. One thing to note you don't have to reset the drivers after rebooting with the new drivers which is the only plus I can see for now. Zadnje izmijenjeno od: lit. 28.03.2018. u 06:23. |
#95 | |
Postovi: 344
Poslano sa mog SM-N910C koristeći Tapatalk |
#98 |
Datum registracije: Oct 2017
Lokacija: nigdje
Postovi: 475
al su zakomplicirali s ovim forkovima. SAd odjednom umjesto jednog imamo tri criptonight algoritma i svaki drugacije daje . cast-xmr cak ni ne podrzava light i heavy nego samo v7. Ktome ovi heavy nisu isti za sumo i heaven npr. pa ovaj criptonightlite ne radi sa sttelite.Znaci ima ih bar 5 varijacija koje su razlicite Hevy daje puno manji HR al i trosi manje light daje duplo od v7 v7 daje mrvicu vise od bivseg criptonight-a 3*vega56: Criptonight stari 5500-5600HR 520W v7 - 5800 530W light - 11000 530W heavy - 4150 493W Zadnje izmijenjeno od: livada2. 12.04.2018. u 01:15. |
#99 | |
Postovi: 344
Inače, xmr-stak ima config za razne coine u zadnjim verzijama. Poslano sa mog SM-N910C koristeći Tapatalk |
#100 |
Lokacija: hr
Postovi: 976
@livada2 jel možeš poslati config file od overdriventool-a za svoje vege 56 ovdje https://files.fm/ hvala |
#101 | |
Lokacija: nigdje
Postovi: 475
gpu 900mv mem900mv gpu1407mhz mem 1090-1100mhz kako koja spomenute su psotavke na prvoj stranici vec, |
#102 | |
Lokacija: nigdje
Postovi: 475
jos nisam nasao nijedna u kojem su svi . Najviise me zivcira sto ima podvarijanti pa jedan heavi ne radi sa svim coinovima nego bas moras izabrat coin a ne algoritam sto znaci da svaki coin moras nesto cackat . Lako je onom ko je baziran na jednom coinu, al ja svako malo idem kopat neke nepoznate coinove da se nadju ![]() onda se neki forka pa moram 5 varijanti staka isporbat dok ne nadjem s kojim radi ![]() onda nadjem nek is manjim fee i ima u popisu i heavi i lite al npr ne radi s TRTL mada pise da podrzava lite ![]() ![]() * aeon7 (use this for Aeon's new PoW) * cryptonight (try this if your coin is not listed) * cryptonight_lite * edollar * electroneum * graft * intense * karbo * monero7 (use this for Monero's new PoW) * sumokoin Zadnje izmijenjeno od: livada2. 14.04.2018. u 10:11. |
#103 |
Lokacija: nigdje
Postovi: 475
Isprobao sam SRBMINER i pokazao se jako dobar za novi Cripronight. Podrzava sve verzije-normal -lite-litev7-heavy-ultraheavy Dev fee je samo 0,8% a HR daje cak nesto veci od cast-xmr a dosta veci od staka i sgminera npr na staku sam imao na sumu 4100 i nisam mogao natjerat nikako na vise a sad imam 4440 . litev7 na cast daje oko 10800 ovdje preko 12000 tako je sa svim podvarijantama. naravno da onda i vise struje povuce... evo par rezultata za 3*vega56 lite 540W ![]() lite v7 555W ![]() heavy 500W ![]() ultraheavy 520W ![]() Zadnje izmijenjeno od: livada2. 17.04.2018. u 01:31. |
#104 |
Lokacija: hr
Postovi: 976
Monero je light v7 ? |
#105 |
Lokacija: nigdje
Postovi: 475
normal v7 - Cryptonight - Cryptonight V7 - Cryptonight Lite - Cryptonight Lite V7 - Cryptonight Heavy - Cryptonight UltraHeavy Cryptonight: Electroneum, Karbowanec, Bytecoin, Dero Cryptonight v7: Monero, Graft, Stellite ... Cryptonight Lite: Aeon Cryptonight Heavy: Sumokoin Cryptonight UltraHeavy: IPBC |
#106 |
Lokacija: nigdje
Postovi: 475
TEST SRB MINERA sa VEGA 56 karticama
INFO - TEST VEGA 56 PowerColor 3*Vega56 flashed to 64 Crimson-ReLive-Beta-Blockchain driver SRBminer 1.4.9 GPU - 1442/1437/1407mhz 905-907mv MEM - 1095/1100mhz 900mv Cryptonight V7(monero) "intensity" : 120 HR=6000 - 560W ![]() Cryptonight lite(aeon) "intensity" : 235 HR=12900 - 570W ![]() Cryptonight liteV7(trtl) "intensity" : 235 HR=12900 - 570W ![]() Cryptonight ultraheavy-lightv3(ipbc) "intensity" : 239 HR=11100 - 550W ![]() Cryptonight heavy(sumo) "intensity" : 56 HR=4550 - 530W ![]() Cryptonight artocache(arto) "intensity" : 118 HR=5400 - 550W ![]() |
#107 |
Lokacija: hr
Postovi: 976
Odlično, nego daj reci jel si koristio onaj overdriver ili wattman ili neka druga kombinacija. Jel rade stabilno? |
#108 | |
Lokacija: nigdje
Postovi: 475
Na ovim postavkama sve radi stabilno vec danima. Ovo gore su maksimalne postavke za moje kartice i tu bi se jos mrvica potrosnja dala smanjit jer ovo je makismala na HR. npr heavy kad se stavi na 4400hr trosi ispod 500w a ovako na 4550Hr trosi 530W. Pa zato i ventilatori vrte cirka 300okretaja brze za istu temperaturu. |
#109 |
Lokacija: nigdje
Postovi: 475
skinuo sam overdrive i evo SS iz njega i iz GPU z pa mozda nekom pomogne ![]() GPUz SS - GPU Z odma ugasi HBM memoriju i HR sa 1500 padne na 1300 i ond amoram uplait xmr-stak da mi opet upali hbm nemam pojma zasto ![]() ![]() ![]() |
#110 |
Lokacija: nigdje
Postovi: 475
Moze preporuka za MBO a da provjereno radi barem 6 VEGA bez puno postelavanja. Po netu se spominje GA-H110-D3A(6card) i asus PRIME Z270-P (8 card) al treba nesto postelavat po biosu. PA ako netko koristi 6 ili vise vega rado cu poslusat savjet. Sad mi 3 vege trosi 500-550w iz zida (znaci 6 bi trosilo oko 1000W a po netu svi spominju za 6 vega 2*1000 sto mi se previse cini Dal bi mi 2*650 gold / 750W bronce ili silver bilo dosta? hvala |
#111 |
Lokacija: hr
Postovi: 976
Na d3a matičnoj radi 6 komada, provjereno. |
#112 |
Lokacija: nigdje
Postovi: 475
#113 |
Lokacija: nigdje
Postovi: 475
Sta je moguce da saphire nitro vega 56 daje slabije rezultate nego obicna power color vega 56? Mislio sam da je nitro najbolja izvedba kartice. Ok hladna je i ne zuji al rezultati su joj koma u odnosu na uvu powercolor. powercolor ima samsung memoriju i na hevy daje preko 1500hr na v7 2000hr. na postavkama. gpu 1442mhz 905mv i mem 1100 900mv. ova nitro ima hynix memoriju i daje na hevi 1430hr na v7 1850hr. na postavkama gpu 1427mhz 920mv i mem 1020 910mv al i tu puca. ova nitro se neda dic ni blizu 1100mhz memorije : ![]() trosi vise struje a daje slabije rezultate. Jedini dobitak je sto je stvarno tiha i hladna mad da i powercolor stavim da kopa tak malo i ona bi bila tiha ... ako netko ima nitro+ vegu 56 modanu na 64 da posalje ss overdrivetoolsa. thx |
#114 |
Datum registracije: Dec 2017
Lokacija: os
Postovi: 5
Pozz ko zeli majnat xmv (monerov) ima server u HR xmv.cyberideas.hk pa nek navali dok je jos diff mali. |
#115 |
Lokacija: st
Postovi: 596
Negde sam danas nešto pročita da ce kina zabraniti ove valute (coine) koje su anonimne (Dash, monero, sve skupa 4) nešto u vezi zakona o pranju novca!!! Neznam koliko ce to uticat na cijenu! Eto samo da spomenem. tipkano sa mog T98 4G八核(C6R3)
MinigRig*H110-D3A*5*rx570nitro8GB OC. |
#116 |
Lokacija: nigdje
Postovi: 475
Jel netko uspio automatizirat vege da rade na HEAVY algu? imam automatizaciju da se resetiraj ukartice al na hevy algu to ne pomaze i ne radi _HBC memoriaj dok ne promjenim intenzititet na vise pa na manje a to neznam izvest u skripti koju koristim. znaci trbao bi upalit miner na 60 intenzititet pa ugasit pa opet upalit na 56 i onda tek proradi hnc memorija . |
#118 |
Bot Maker
Postovi: 2,741
meni hashrate na novom mineru na koji smo morali preci jucer sad radi slabo, 1500. Koristim XMR-stack, jel ima kakvog rjesenja, prije je radilo od 1950 do 2000...
#119 | |
Lokacija: nigdje
Postovi: 475
v8 daje manji rezultat na vegama otprilike 5% i trosi puno vise struje cirka 30/35W vise po kartici. 6 vega nitro na v7 davalo cirka 11660HR i trosilo 970W iz zida a na v8 daje 11100HR i trosi 1170W iz zida
SAMOANA: Nije u šoldima sve Nadmudrivanje sa budalom je kao hrvanje sa svinjom u blatu ..... nakon nekog vremena skužiš da svinja uživa |
