Staro 02.04.2018., 19:01   #4411
Postovi: 8,229
Autor fAg Pregled postova
Šta im predstavlja oznaka X? Prema tablici rayzen 7 2700 ide do 4.1GHz? Jel se svi daju ručno overklokirat ili samo neki?
Svi se daju ručno clockati, samo X modeli imaju drukčije/bolje podešenu XFR mogućnost.
This is a fully automated solution that attempts to allow higher upper limit on the maximum frequency based on the cooling technique used (e.g. air, water, LN2). Whenever the chip senses that it's suitable enough for a given frequency, it will attempt to increase that limit further. XFR is partially enabled on all models, providing an extra +50 MHz frequency boost whenever possible. For 'X' models, full XFR is enabled providing twice the headroom of up to +100 MHz.
Staro 02.04.2018., 21:46   #4412
Gigi1
Postovi: 2,138
1.5 V za 4.35+GHz za zen+
Staro 02.04.2018., 22:14   #4413
Oklen ti taj info?
Sent from Mobara
Staro 02.04.2018., 22:27   #4414
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Da nisu neke okasnile prvoaprilske fore
Eno i po wccfu bilo trolerskih vijesti vezane uz nvidia i amd gpu
Staro 02.04.2018., 22:54   #4415
Gigi1
Postovi: 2,138
xfr1 je rokao 1950X na 2 jezgre sa 1.5~1.55V za 4.1~4.2, znaci da je ovo cak i poboljsanje.
Nerealno je ocekivati ista bolje od malo ispeglanog 14nm lp procesa(12nm), prakticki je ist k ko i 14nm, jbg lp je lp i nije zamisljen/napravljen da dobro skalira sa visokom voltazom.
Svih 8 jezgri na ~4.4 GHz zaboraviti kod vecine proceva, osim ak nekoga zdrma lutrija
good morning
Yesterday after the tests I discovered why the pc crashed
The corsair h90 pump was at minimum speed
This morning I'm re-testing now I can stay stable at 4250mhz to the core
with 1.38v
An excellent result for my expectations
With a custom heatsink, I think 4300-4350mhz (all core) is possible (silicon lottery)
In default (4350-4375mhz) voltages are over 1.5v, I do not like to use too much voltage
Also consider that the gigabyte bios for this cpu does not exist
With new bios, with 3600mhz ram support and over , we will have incredible boost.
My ram is 3200 c14 but can also go to 3600 c14.14.14 without problems
To be correct ,I'm not under NDA, I have not signed anything, so I can do what I want
voglio
Info je od Ashrafa Easse, a on ga je uzeo sa overcl uk
Zadnje izmijenjeno od: Gigi1. 02.04.2018. u 23:04.
Staro 03.04.2018., 07:20   #4416
Good times are coming ako to sad radi sa nekim paušalnim BIOSom na toj Gnjidabajtici, ima da ubija na C6H
Sent from Mobara
Staro 03.04.2018., 08:12   #4417
Gigi1
Postovi: 2,138
ma naravno, recimo 4.25GHz na 1.35V za neki every day use na 8 jezgri je super, ionak ce single core boost s vremenom sve više gubiti na znacaju
Zadnje izmijenjeno od: Gigi1. 03.04.2018. u 09:32.
Staro 03.04.2018., 09:22   #4418
To je još Intel "boljiji za igrice", no nama FHD 60FPSašima je to sasvim nebitno. Ovo drugo što "radim" na kompu je itekako Ryzen puno bolji izbor.
Realno, ne treba mi ni Ryzen refresh ali obzirom na situaciju (OKP, segfault) što da ne
Sent from Mobara
Staro 03.04.2018., 09:52   #4419
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,265
Pa kad će više relevantni benčevi tj rivjui?
Nadam se da će do 12.-og biti rivjua (bar tj dana prije prodaje)...
Sviđa mi se u kom smjeru ovo sa Ryzenima ide
...ali ko zna, da potrpim još godinu dana i ubodem zen2 i bok...ovaj ivy me još uvijek služi pristojno za 1080p igranje i nešto malo handbrake-a.
Slobodno me dodajte na PSN
Staro 03.04.2018., 10:03   #4420
NDA lift je 19.04. Tada i reviewi i prodaja kreće. Čekaju se ploče u biti.
Sent from Mobara
Staro 03.04.2018., 12:09   #4421
Postovi: 8,229
Jesi se možda već unaprijed raspital o proceduri slanja? U rijetkim slučajevima su korisnicima unaprijed slali nove procesore.
Većina ipak čeka kakvih 5+ radnih dana (ovisi o regiji) da im stigne novi, dok se stari kotrlja prema AMD-u.
Staro 03.04.2018., 13:08   #4422
Nisam još o tome razmišljal... ima vremena
Sent from Mobara
Staro 03.04.2018., 13:30   #4423
Postovi: 8,229
RMA još uvijek prolazi bez pardona uz računicu da si koji dan bez procesora, ako se ne smiluju pa ga pošalju unaprijed.
Jedino da ti po defaultu ne ponude "novi" R5 1600 umjesto novijeg R5 2600.
Staro 03.04.2018., 13:33   #4424
Manuel Calavera
Postovi: 14,584
Kao što sam ranije rekao - ne vidim kako nebi opet dobio R5 1600, pa nije da ih nemaju
Staro 03.04.2018., 13:45   #4425
Zato ćemo ga poslat tamo neđe na jesen a i malo ćemo popratit što za povrat dobiva ekipa sa drugih foruma koje pratim te koji imaju iste ideje
Sent from Mobara
Staro 03.04.2018., 13:49   #4426
fAg
Datum registracije: Dec 2017
Lokacija: u hr
Postovi: 125
Sent from Mobara
Pa neće im ni do jeseni nestat,imaju oni sigurno puno procesora na zalihi.
Kaj nebi trebala ova druga generacija ryzena pobijedit napokon intela i trenutnu generaciju 8000?(da,i u gamingu)
fAg je offline   Reply With Quote
Staro 03.04.2018., 13:50   #4427
Nadajte se vi pogane duše da će mi vratiti R5 1600...
Sent from Mobara
Staro 03.04.2018., 13:59   #4428
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Ne i u gamingu. Za Zen2 bi to trebalo biti realno, za ovaj refresh još ne. Mada tu pričamo o gamingu s grafičkama poput 1080 Ti na 1080p...
Staro 03.04.2018., 14:24   #4429
Manuel Calavera
Postovi: 14,584
zen2 vs ice lake, sučeljavanje clockova i ipc-a, broja jezgri/threadova po kategoriji bi mogao biti show. Intel je i dalje blagi faforit za prvo, al ono gusto
Staro 03.04.2018., 16:18   #4430
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Potpis, na kraju krajeva profitirat cemo samo mi - kupci...
Staro 05.04.2018., 21:22   #4431
Ryzen 7 2700
Batch UA 1805SUS
Znači da su ti procesori naštancani još u siječnju tj. krajem siječnja. 3 mjeseca je kaj, čekanje da zakuha ko mošt ?
Neki lik LOLN1 sa overclockers uk foruma laprda da ga ima i vrti testove. Niš konkretno nije baš pokazao. Pravi se tulav i žica btc donacije. Sigurno je točno da ga posjeduje, ali velim, pravi se blesav malo.
Edit:
Evo LINK pa popratite ako vam se da.
Lik ima kombinaciju: Gigabyte AX370 Gaming 5 + Ryzen 7 2700 + B-Die RAM 3200 14-14-14-34.
Zadnje izmijenjeno od: Brko. 05.04.2018. u 21:50.
Staro 06.04.2018., 19:18   #4432
Poslao sam Fernandu Alonsu mail da prevede ovo
R7 2700X review
Hype train slowing down... ili još bolje... hype train is derailed. Ni 10% OC potencijal nije narastao. Pih...
Ipak ništa od R7 2700. Idemo na R5 2600 kao free upgrade i bok zdravo do 7nm. Nema mi smisla davati 100 EUR-a za 2 jezgre extra koje mi ne trebaju i 200 MHz više, čak i da liječi moj OCD
Zadnje izmijenjeno od: Brko. 06.04.2018. u 19:26.
Staro 06.04.2018., 21:32   #4433
trpi
ali koliko bi sretnije koracao zivotom da te 8 jezgri i 4ghz ceka doma, i ne bi morao pisati neistine o posjedovanju 4000mhz u potpisu...
Staro 06.04.2018., 21:46   #4434
Que cosa? Ti imaš puno većih problema nego ja. Sredi ih, pa ćemo pričati.
Sent from Mobara
Staro 06.04.2018., 21:53   #4435
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
Ne vidim zašto bi 4ghz bilo nedostizno.
Najveće njubare se dovuku do 3,9.
Amd_Shill je offline   Reply With Quote
Staro 06.04.2018., 23:56   #4436
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
Sent from Mobara
svi mi imamo problema, i viska vremena za gluposti, i para isto tako čim nas svrbi već kombiniramo, to danas zovu entuzijasti
..ajde ne mogu svi imati stable 4GHz, to je činjenica, ali ..
MojSkuter
Staro 07.04.2018., 09:11   #4437
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Da nastavim misao
...sve ovisi sto nekome predstavlja to stabilno. Za mene to znaci da se pc ne rusi nikad (bar ne zbog cpu-a) u okruzenju u kojem radi veliku vecinu vremena, bilo to enkodiranje videa, rendanje, ili igranje... Za mene je to definicija stabilnog. A to sto bi netko dosa kod mene pa izvrtio neki burn test, cinebench ili neki treci program/igru koju ja ne koristim pa se pc srusi - to me ne zanima. Jednom kad i ako krenem koristiti takve programe kao dnevnu rutinu, tad cu se pobrinuti da pc radi stabilno (dodatnom voltazom ili smanjivanjem clocka)... Sto ne znaci da opet ne postoji nesto sto ga ne moze srusiti, you get the point. Znam da ce netko reci da "moje stabilno" nije apsolutno stabilno, ali to me ne opterecuje previse jer smatram da se svak treba ravnati po osobnom nacinu koristenja... Just my 50 cents.
Staro 07.04.2018., 09:20   #4438
trpi
svi mi imamo 4ghz ali rijetko tko stabilno... kao da imas jak auto koji se gasi preko 5k rpm ("ali ja ga nikad ne stiskam toliko") djaba ti to
Staro 07.04.2018., 09:33   #4439
@Sn4k3
Moj R5 1600 je gaming stabilan na 4GHz @ 1.4V LLC3 (ne pričam o 100-satnom renderiranju ili 3-dnevnom stress testu jer to nisam vozio). Pičio sam Titanfall 2 i Witchera 3 sa tim postavkama, ali.. previše se grije, Venomous ga ne može držati ispod 70°C.
Za 70 MHz manje, razlika je 15°C i treba mu 1.35V (cca 50 mV manje) LLC3. 3.93 GHz je gaming profil koji koristim, sad će godinu dana. Nikad problema nisam imao.
Zato bi bilo fino kad bi R5 2600 radio na 4000-4050 @ 1.3V max recimo i još fino RAM da vozi na 3600 C14 (koliko vidim LOLN1 je uspio B-Die natjerat da mu tako rade).
Nagodinu Zen2 na 7nm bude sigurno i glat išao na 4.5-4.7 GHz. Priča se o 5GHz ali otom potom.
Što se Zen+ refresha tiče, treba isto uzeti u obzir da su trenutni rezuotati takvi (možda) jer X370 ploča (Gigabyte Gaming 5) i dalje nema full official BIOS za Pinnacle Ridge. Ima AGESA kod koji prepoznaje procesor, ali i dalje nije to to (barem po riječima Elmora koji upravo za Crosshair VI Hero kuha takav BIOS da X370 ploča ima full support za PR CPU).
Sent from Mobara
Zadnje izmijenjeno od: Brko. 07.04.2018. u 09:40.
Staro 07.04.2018., 10:16   #4440
Gigi1
Postovi: 2,138
Sent from Mobara
ako i dalje bude na glofo lp, vjerojatno nista od tih 4.7+ ghz osima ak osjetno promjene arch u što cisto sumnjam
Sent from Mobara
neznam bas hoce li novi bios utjecat na max oc, zapravo jako malo vjerojatno.
