Staro 12.03.2018., 08:18   #1291
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,595
Za početak probaj spustiti clock memorije
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 12.03.2018., 08:19   #1292
Facelessone
Facelessone's Avatar
Postovi: 4,204
Smanji clock memorije i vrti 2 dana stock pa vidi ako se ponavlja. Ako ne, memorija ti je previše clockana. Pogotovo ako imaš hynix memoriju na karticama. Za nju teško da budeš dobio i preko 600mhz.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 12.03.2018., 08:51   #1293
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,595
On ima +900 na memoriji, a meni niti jedan samsung neide iznad +750-775 stabilno
A nedajbože da je hynix
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 12.03.2018., 08:56   #1294
Facelessone
Postovi: 4,204
Vjerojatno i jesu Samsung samo im je malo previše. Meni su dvije na 900 stabilne a druge dvije na 860
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 12.03.2018., 09:53   #1295
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Autor maXonja Pregled postova
Meni je isla na +1000 i radila x dana tak
Al je onda claymore nekaj zeznuo pa sam spustio na 850 iako bi to islo jos gore, ovak znam da x mjeseci nema brige.
žmnpp
Staro 12.03.2018., 10:26   #1296
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,595
Dobro, možda je problem što ja odjednom dižem svih 5 kartica
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 12.03.2018., 10:41   #1297
neverin
Datum registracije: Dec 2017
Postovi: 219
Kod dizanja clocka memorije, mora li se uvijek dizati polako po +50 ili može odmah na +1000 ako se zna da može i da je stabilno?
neverin je offline   Reply With Quote
Staro 12.03.2018., 10:46   #1298
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,595
Pa ako znaš da radi rokaj na +1000 odmah
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 12.03.2018., 11:13   #1299
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Ja 6
žmnpp
Staro 12.03.2018., 11:15   #1300
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,595
Damn, jači si
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 12.03.2018., 14:59   #1301
Nbdy32
Datum registracije: Aug 2016
Lokacija: Bestovje,Sv.Nedelja
Postovi: 2,821
Probam onda smanjiti clock memirije, inace samsung memorija je
Staro 12.03.2018., 17:48   #1302
goran047
goran047's Avatar
Datum registracije: Nov 2016
Postovi: 142
upravo mi se updejtaju windowsi na oba riga nakon skoro godinu dana unatoc iskljucenoj opciji updatea, u isto vrijeme restart i vec pola sata stoji na 1%
ocito fall creators update, to samo meni il
goran047 je offline   Reply With Quote
Staro 12.03.2018., 19:00   #1303
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Taj update smo odavno obavili mi windowsaši
Staro 13.03.2018., 09:04   #1304
Nbdy32
Postovi: 2,821
Radila cijeli dan na 900,sada stavio na 700,na 750 mi je gpu3# imao incorrect,s time da sam promijenio nicehash i sada miniram claymoreom u jaxx
1. Oće to biti u redu ?
2. Kada se vidi da je nešto naminirao,iliti koliko mu treba za cca 0.1 ether,vidim da ima samo jednu decimalu
naravno moram napomenuti da je sa 25 (čistih),pao na 23.800
edit:
i sve mi je to na 665W,jeli to ok,ili previše (tako pokazuje mjerač)
Staro 14.03.2018., 14:02   #1305
smurf
Lokacija: Cakovec
Postovi: 32
Jel možda netko zna zašto mi na dvije XFX 580 napon skoči sa 875mV na preko 1000mV nakon nekog vremena iako je u OverDriveNtool-u namješten na 875?
U rigu su 4 kartice, dvije Asus(rade na 875mV) i dvije XFX koje sad rade probleme, do neki dan je sve radilo bez frke tjednima, Win update disabled.
Jedino što je novo je claymore 11.4 i njegovo namještanje DCRI-a...
Razlika u potrošnji je 90W(530W vs 620W)...
smurf je offline   Reply With Quote
Staro 14.03.2018., 15:52   #1306
lit
Lokacija: hr
Postovi: 976
Neće mi raditi ove dvije grafičke, iako ih kao prepoznaje ali s greškom, one se ne pokazuju u minerima kad rudarim:
Probao sam reinstalirati drivere, mjenjao risere ali nije uspjelo. Ako spojim samo njih dvije bez svih ostalih onda rade.
Kako da mi prorade?
lit je offline   Reply With Quote
Staro 14.03.2018., 16:03   #1307
Facelessone
Postovi: 4,204
max pcie link speed u biosu probaj promjeniti (gen2 ili gen1)
enable above 4g decoding
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 14.03.2018., 19:44   #1308
lit
Lokacija: hr
Postovi: 976
Imam asrock h81 btc pro 2.0, pa tamo nema 4g već je on automatski složen na ploči, a gen2 i gen1 samo izmjenjivao pa neće isto.
Maknuo sam i bateriju resetirao cmos, miksao sve kablove između svega i uvijek 2 neće raditi, a kad ih probam po jednu onda rade.
Ne znam više što da isprobavam...
Staro 14.03.2018., 20:33   #1309
Kamby
Kamby's Avatar
Datum registracije: Oct 2013
Postovi: 132
Koja napajanja imas?
Kamby je offline   Reply With Quote
Staro 14.03.2018., 20:49   #1310
lit
Lokacija: hr
Postovi: 976
Jedno, Corsair HX 850 što bi trebalo biti dosta jer ove kartice ne troše kao AMD-ove. Kad mi radi 1070x1, 1060x2 = 3 komada troše 300W iz zida.
Staro 14.03.2018., 21:37   #1311
Kamby
Kamby's Avatar
Postovi: 132
Probaj dodavati jednu po jednu grafu.
Staro 15.03.2018., 00:09   #1312
Sniper
Community Manager
Sniper's Avatar
Postovi: 313
Kada napravis double click na kartice, dali dobijes Code 12?
Sniper je offline   Reply With Quote
Staro 15.03.2018., 07:57   #1313
Nbdy32
Postovi: 2,821
Meni se isto dogodilo da nije našao 2 kartice,ali u device manageru na update driver (bez lana),mi je instalirao drivere koji su bili na kompu,i proradile obje ...
Probaj te kartice zamijeniti u portovima sa onima koje rade ...
Probaj zamijeniti risere sa onima koji rade (obje strane)...
Probaj zamijeniti usb kablove ...
Staro 15.03.2018., 08:54   #1314
lit
Lokacija: hr
Postovi: 976
Da, vidim tamo Code 12. što sada?
Gen-ove sam mijenjao ali ništa nisam dobio s njima.
Staro 15.03.2018., 12:31   #1315
Churta_Sia
Datum registracije: Feb 2018
Postovi: 54
Evo i mene sa sličnim problemom... nisam uz komp pa ne mogu provjeriti za Code 12,
Uzeo sam 1 na 4 PCIe spliter u nadi da će stvar proraditi na mojoj staroj Asus P5B Deluxe ploči.
Spojio sam nadobudno prvo sve kartice (3xGTX1050TI) na spliter i utaknuo u glavni x16 PCIe slot.
Komp se digao čačkao po drajverima cijelu vječnost, poinstalirao sve vezano uz audio ali je zapeo na grafičkim karticama.
U biti device manager ih vidi kao GTX1050TI, ali sa žutim uskličnikom i komentarom da nešto ne štima sa driverima.
Nakon toga sam isprobao sve kombinacije:
- 1 GPU + spliter u sva tri PCIe slota na kompu – problem isti
- 1 GPU u glavni PCIe slot samo preko risera + 1 GPU u spliter u preostala 2 PCIe slota – ova prva je OK, druga isti problem sa driverom bez obzira u kojem slotu bila
Inače kad preko risera upiknem kartice svaku u svoj PCIe sve radi OK… znači MBO bez beda majna sa 3 GPU.
Sad ne znam dal da nešto čačkam po BIOSu ili da idem ubiti sve drivere pa probati sve iz početka.
Jel imao netko iskustva sa sličnim problemom?
Churta_Sia je offline   Reply With Quote
Staro 15.03.2018., 21:42   #1316
Churta_Sia
Postovi: 54
Provjerio... kod mene javlja Code 43
Sent from my SM-G930F using Tapatalk
Staro 16.03.2018., 07:56   #1317
Nbdy32
Postovi: 2,821
DDU, maknite prvo sve drivere koji su gore ...
Stavite jednu karticu u "main" pcie slot,zatim dodavajte risere,adaptere i ....
Isključite audio u biosu,uključite 4G,pcie na gen2 (negdje gen1) ...
Staro 16.03.2018., 10:48   #1318
renaTq
renaTq's Avatar
Datum registracije: May 2017
Postovi: 387
Fast help ! SMOS se ne zeli connectat na ethermine pool... Kako to rijesiti ? Samo dwarfpool mi radi
Remote management is enabled on port 3333
You did not specify -dcri values directly, so they will be detected automatically
Automatic detection of best -dcri values started, please wait...
ETH: Share rejected!
GPU0 t=26C fan=52%, GPU1 t=26C fan=52%, GPU2 t=19C fan=52%
ETH: Job timeout, disconnect, retry in 20 sec...
ETH: Stratum - connecting to 'eu1.ethermine.org' <94.23.36.128> port 4444 (unsecure)
ETH: Stratum - Connected (eu1.ethermine.org:4444) (unsecure)
GPU0 t=24C fan=52%, GPU1 t=24C fan=52%, GPU2 t=17C fan=52%
GPU0 t=23C fan=52%, GPU1 t=22C fan=52%, GPU2 t=16C fan=52%
ETH: Stratum - connecting to 'eu1.ethermine.org' <188.165.220.188> port 4444 (unsecure)
EDIT : Uspio. Nisam maknuo / izmedu adrese i imena
#propo
Zadnje izmijenjeno od: renaTq. 16.03.2018. u 11:38.
renaTq je offline   Reply With Quote
Staro 16.03.2018., 22:38   #1319
Sniper
Community Manager
Sniper's Avatar
Postovi: 313
I ja sam imao slican problem nako sto mi se updejtalo na winverziju 1709.
Problem ces 100% rijesiti tako da odes u regedit.
Start > Run i kucaj "regedit"
Odi ovdje:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\PnP\Pci\
I napravi NOVI KEY > DWORD 32
Ime: HackFlags
Value HEX 600
Resetiraj računalo.
Nakon toga odi u Device Manager i samo disable HD audio za bilo koju graficku, ako ti nisu vec proradile.
Ako trebas pomoc javi se u privatno, vjeruj problem je "piece of cake"
Staro 18.03.2018., 17:56   #1320
Churta_Sia
Postovi: 54
Kod mene jednostavno ništa ne pomaže.
U BIOSu podesio sve što se podesit da, g4 ne postoji, DDUom maknuo drivere, reinstalirao najstarije, pa jedno 5 ili 6 drugih varijanti... očito ova matična i taj PCIe splitter ne idu jedno s drugim...
Izgubio volju za čačkanjem, očito je da ću morati odriješiti kesu i uložiti u MBO, proc i ram
