Povratak   PC Ekspert Forum > Računala > Kriptovalute
Staro 03.03.2018., 10:20   #61
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Autor RimtuTiTuki Pregled postova
Ima. Kontaktiraj njihov support. Ako imaju ključeve za classic adresu, imaju i za ETH
Zapravo, ja sam sa nano S, spojia se na myetherwalet! i onda poslao ETH na ETC (bitrex adresa)
U bit trebao bi kontaktiratr Nano s podršku? dalli sam u pravu?
MinigRig*H110-D3A*5*rx570nitro8GB OC.
Zadnje izmijenjeno od: gloginjaR. 03.03.2018. u 11:19.
gloginjaR je offline   Reply With Quote
Staro 03.03.2018., 18:47   #62
RimtuTiTuki
RimtuTiTuki's Avatar
Postovi: 1,645
Autor gloginjaR Pregled postova
Ne, kontaktiraj Bitrex.
Staro 03.03.2018., 19:38   #63
domy_os
domy_os's Avatar
Postovi: 18,866
Ma slikaj se, ograđuju se maksimalno...
Please deposit ETH and ETC to the correct address. Bittrex will not cross-chain credit your account. Please view this article for more information.
https://support.bittrex.com/hc/en-us/articles/223411407
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 03.03.2018., 21:34   #64
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
A posla sam upit, pa ako prodje ;/
Samo bojim se da je ovo mala lovica za zezat se s menom! ))
Da imam 5 keka, onda bi bez problema vratili!!! Uz proviziju!!
Ovo sam dobio kao generički odgovor, pa sa i dalje postavio pitanje! Ipak oni drže moje privatne kljucčeve! Ako nece da vrate nek mi daju ključeve i opciju da ih sam vratim!
Auto odgovor:
Bittrex's cross chain recovery policy is that we will only attempt to recover deposits that exceed $5000 at the time of deposit, within 7 days of the deposit and will charge a 0.1 BTC for this recovery. Recovering coins crosschain is an inherently dangerous and time consuming process. Not all deposits can be recovered and the time frame of recovery is at our discretion.
This policy DOES NOT apply to deposits with incorrect or missing memos on currencies such as CryptoNote, NXT, BitShares, Ripple, STEEM, or any others that rely on a message/memo/tag for crediting deposits. Nor does it apply to ETH tokens sent to other addresses on the ETH network. These will be recovered in a time frame of our discretion.
This policy DOES apply to any deposits sent to an address of another coin on another network. This includes but is not limited to:
Sending, for example, BTC to a BCC addressSending an OMNI/XCP asset to ANY address other than the one assignedSending ETH to an ETC address
Note: We WILL NOT recover coins or tokens we do not support. Nor will we recover funds that were distributed as part of an ICO.
Koji je to monopol i ucijena!! Neke mjenjačnice imaju opciju (besplatnu) za vratit srestva! Ovo je čista ucijena.
Zadnje izmijenjeno od: gloginjaR. 03.03.2018. u 21:39.
Staro 03.03.2018., 21:48   #65
buljaka
Datum registracije: Aug 2014
Postovi: 2,931
Jbg. Pomiri se sa tim gubitkom i više pazi slijedeći puta . Nažalost sam si kriv i u njihovoj si milosti 🤐
Staro 04.03.2018., 14:21   #66
RimtuTiTuki
Postovi: 1,645
Eto, sad barem znaš da nije nemoguće.
Ovo je tvoja greška, malo je skuplja... ali jebiga, na takvima se najbolje uči.
Staro 04.03.2018., 21:27   #67
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Ma da. Otpila me glatko! :\
Dorian veli da su takva pravila i da se za sad nemjenjaju,
Ništa, čeka cu da tih 0.48eth naraste na 5keka $ pa cu onda povuć
... kako god, nije pošteno, čemu im onda služi održavanje walleta? Na mjenjačnici kada je odredjeni novčic nedostupan par sati!!! Bice tada kupe ove zaglavljene transakcije i djele medusobno ))).
Tek vako kad zapadneš u "probleme" sa transakciom, onda vidiš sve mogućnosti dotične valute (ili coina). I monopola i ovlasti koje pojedine mjenjačnice imaju!! Uzimaju nam provizije i kojekakve uvijete traže kod registracije! Ok, sve to se podrazumijeva, ali daj neka i oni "daju nešto zauzvrat.
tipkano sa mog T98 4G八核(C6R3)
Staro 04.03.2018., 21:40   #68
buljaka
Postovi: 2,931
U 7 dana neće narasti toliko ETH nikako 😅 pomiri se sa time . Bit će ti lakse
Staro 06.03.2018., 16:02   #69
ddark
Datum registracije: Dec 2017
Postovi: 16
Danas izašao update firmwarea za Ledger nano s, verzija 1.4.1. Ja sam uspješno odradio a onima koji će tek raditi par savjeta:
-deinstalirajte sve wallete sa ledgera
- pratite upustva koja su postavili na svojim stranicama jer ima par neočekivanih caka
-budite jako strpljivi jer sve traje dosta duže nego inače, vjerojatno su serveri preopterećeni
ddark je offline   Reply With Quote
Staro 06.03.2018., 17:39   #70
domy_os
domy_os's Avatar
Postovi: 18,866
Baš sam ujutro dobio mail i nikako napraviti update. Ledger Manager se vuče za poluditi, jako sporo prepoznaje Nano S, deinstalacija aplikacija ide jako sporo ili nikako. Bojim se da update negdje ne pukne pa da se moram zezati oko RMA.
Staro 06.03.2018., 17:51   #71
k31k0
Postovi: 119
Hvala za info. Pretpostavljam da ne moram žuriti s instalacijom novog firmware-a ako ne mislim koristiti Ledger. Ali pitanje... Ako deinstaliram sve wallete s Ledgera, kako će on znati nakon ponovne instalacije koji je moj wallet?
Poslano sa mog Redmi 3 koristeći Tapatalk
k31k0 je offline   Reply With Quote
Staro 06.03.2018., 17:58   #72
ddark
Postovi: 16
Znat će on, bez brige (da ne pišemo ponovo jer je već par puta objasnjeno), možeš wallete bez straha deinstalirati i instalirati one koji ti trenutno trebaju.
Staro 06.03.2018., 18:23   #73
domy_os
domy_os's Avatar
Postovi: 18,866
Sve se veže uz tvoj seed, možeš brisati i stavljati koliko hoćeš walleta, stanje coina se ne mijenja. Zato, čuvaj seed kao oči u glavi i nemaš brige. Evo i punog change loga:
New UX features
  • The number of apps which can be loaded onto the Nano S at the same time has been raised up to 18 (depending of the kind of apps).
  • The screen lock management has been slightly modified. A long press (3 seconds) on both buttons of your Nano S when it is in use (whether in the dashboard or while using apps) will enable you to lock the screen.
  • To ensure that the user has backed up correctly the 24 words, all of them must now be confirmed during the onboarding.
  • Several other optimizations have been implemented in order to improve the user experience. For instance, the device is now faster and using some cache optimizations.
Upgraded security
BOLOS (Ledger OS) has evolved. You’ll find below some of the latest modifications:
  • The apps are now split in 3 segments (code, data, installation parameters). Two different hashes are computed (code + data and code + data + installParams). This allows the user to verify the data loaded even for apps which have secret data.
  • U2F tunnel is now supported for APDUs in the dashboard and also in the SDK. It’ll make it possible to support all communication protocols with a single interface and avoid using the “Browser Support” options. U2F tunnel is very convenient to interface with a web application (such as MyCrypto/MyEtherWallet).
  • The SDK now offers another primitive for comparing memory pointers securely (memcmp).
Extended cryptographic support
  • SEC curves (SECP384R1, SECP521R1),
  • Brainpool Curves (P256R1, P320T1, P320R1, P384T1, P384R1, P512T1, P512R1)
  • ANSSI Curve (FRP256V1),
  • Edwards Curves (Ed448), and
  • Goldilocks’s curve (Curve448)
The firmware 1.4 includes a few other security improvements. For instance, the policy to load 3rd party apps slightly evolved. The custom Certification Authority (CA) management is now only available under recovery mode. It is intended to make malware applications less attractive to promote for inexperienced users.
Staro 06.03.2018., 21:14   #74
k31k0
Postovi: 119
Objavili su upute točno korak po korak pa ako netko još nije ažurirano, sad može pratiti ove upute: https://support.ledgerwallet.com/hc/...e-firmware-1-4
Staro 06.03.2018., 21:29   #75
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Pogledao sam upute , probao sam nadogradit, ali mi nece izbrisat eth i litecoin aplikaciju!
Pa cu probat sutra prekosutra kad malo padne promet!?
mislim da su ga maksimalno zakomplicirali )
Staro 06.03.2018., 22:00   #76
domy_os
domy_os's Avatar
Postovi: 18,866
Nije ni meni htio, ali je uspio nakon nekoliko pokušaja. Ovo čak i nije toliko komplicirano koliko je bilo za stari firmware kada si morao ponovno unositi seed.
Staro 07.03.2018., 10:24   #77
rodriguez
rodriguez's Avatar
Postovi: 2,062
Probajte i sa drugim usbom na laptopu, ja sam se jebo sa jednim te istim, i onda kad sam promjenio na drugi usb, krenulo je installing firmware.
Staro 07.03.2018., 11:01   #78
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Meni jutros sve iz prve odradio.
Poslano sa mog A0001 koristeći Tapatalk
Staro 07.03.2018., 12:06   #79
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Hoću sa NANO s, da pošaljem na bitrex eth,
ali mi javlja neku grešku???
o čemu se radi?
https://s17.postimg.org/nkyv3tatb/bit.jpg
nekužim kako u Nano S da povećam plin???
https://s17.postimg.org/ididd045b/nano.jpg
Zadnje izmijenjeno od: gloginjaR. 07.03.2018. u 12:25.
Staro 07.03.2018., 13:19   #80
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,599
Pa ručno upiši Gas limit kada klikneš Advanced mode
Default je 21000 mislim, probaj sa većom cifrom tipa 42000
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 07.03.2018., 13:21   #81
Kamby
Kamby's Avatar
Datum registracije: Oct 2013
Postovi: 133
Meni se još otprije 2 dana nije prebacio ETH sa miningpoolhuba na Bittrex iako je transakcija uredno provedena. Ima netko neku ideju? (kontaktirao sam support)
EDIT:
Našao ovo kad sam htio kopirat adresu:
"Please use a small amount for your first deposit to verify everything is working as expected before sending larger amounts. Your deposit address must hold more than 0.1 ETH before we will credit your account. If you deposit less than 0.1 ETH you will need to deposit more until your balance on the block chain holds greater than 0.1 ETH"
Ahhhh...
Kamby je offline   Reply With Quote
Staro 07.03.2018., 13:32   #82
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Autor maXonja Pregled postova
poduplo sam na 4 ali opet neide???
neznam da probam sa myetherwaleta?
edit;
neide ni sa myetherwalet???
https://s17.postimg.org/o71m5aun3/myet.jpg
Zadnje izmijenjeno od: gloginjaR. 07.03.2018. u 13:49.
Staro 07.03.2018., 13:34   #83
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Da pogodim stavis max etera i onda povecas gas price? I nije ti jasno zasto nema love?
Ajde promjeni raspored klikanja
žmnpp
Staro 07.03.2018., 13:35   #84
domy_os
domy_os's Avatar
Postovi: 18,866
Također, dva walleta sam updateao za manje od 5 min.
Staro 07.03.2018., 13:59   #85
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Autor buljo Pregled postova
Moguće! ali stavi na 4. ili na 6. isto mi javlja??
ima li neki kallkulator da izračunam? kolika je cijena???
edit; posla sam sa myetherwalet, stavia sam 41 gwei i prošlo je!
a hebo ga patak! satra me je! (
Hvala Buljo!
Zadnje izmijenjeno od: gloginjaR. 07.03.2018. u 14:16.
Staro 09.03.2018., 13:59   #86
lit
Lokacija: hr
Postovi: 976
Znači sa novom nadogradnjom Ledger Nano S dobije se podrška za do 18 aplikacija (coina), umjesto dosadašnjih 4 ? jel može netko potvrditi tko je nadogradio?
lit je offline   Reply With Quote
Staro 09.03.2018., 15:24   #87
domy_os
domy_os's Avatar
Postovi: 18,866
Kod mene je zasad instalirano 7 aplikacija. Ako hoćeš, mogu vidjeti koliko stvarno ide.
Staro 09.03.2018., 17:41   #88
lit
Lokacija: hr
Postovi: 976
Ne treba hvala, dovoljno je i 7. Onda valjda ide do te brojke.
Staro 09.03.2018., 17:53   #89
dukee
dukee's Avatar
Lokacija: vz
Postovi: 461
U ovoj verziji Zcash aplikacija na Ledgeru nema browser support opciju.
Kako da sada preselim Zcash na Ledger?
dukee je offline   Reply With Quote
Staro 09.03.2018., 17:58   #90
domy_os
domy_os's Avatar
Postovi: 18,866
Pa ne treba ti browser support za Ledger Wallet.
