Staro 05.03.2018., 21:19   #1
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,688
Logitech MK330 combo užasno laga
Kao što naslov kaže (combo = k330 + m215).
Windows 10 64bit. Probao instalirati i origigi software i drivere, ne pomaže.
Jel polako Unifying receiver odlazi ili bi moglo biti nešto drugo?
Hvala,
pozz
Staro 05.03.2018., 21:29   #2
Facelessone
Facelessone's Avatar
Postovi: 4,203
Wireless router ili mining rig u blizini?
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 05.03.2018., 21:31   #3
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,688
Router bio godinama, od neki dan iskljucen i sad je samo wifi usb adapter (tl-wn822n)
Staro 05.03.2018., 21:34   #4
Facelessone
Postovi: 4,203
Možeš probati live linux? Ako znaš nekoga tko ima unifying reciever lagano provjeriš ak je do njega.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 05.03.2018., 21:41   #5
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,688
Sutra isprobam linux...
Staro 06.03.2018., 12:31   #6
Keano16
Postovi: 786
Autor Problem Pregled postova
Hvala,
pozz
Imao isti problem na jednoj lokaciji (prodajnom mjestu), 4 seta.
Maknuo ih u drugi objekt gdje radi dobro.
Nesto je bilo sporno u materijalu koji je okruzivao received (ili drvo ili metali, ili nesto trece...).
Probaj ubaciti u neki laptop ako ti je pri ruci
Keano16 je offline   Reply With Quote
Staro 06.03.2018., 12:36   #7
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,688
Kod mene sve godinama radilo ok. Ništa očito nisam u sobi promjenio da bi izazivalo smetnje. Sad sam se sjetio da imam doma na jednom laptopu receiver. Zamjenim pa da vidim...
