#61 |
Lokacija: st
Postovi: 596
MinigRig*H110-D3A*5*rx570nitro8GB OC. Zadnje izmijenjeno od: gloginjaR. 03.03.2018. u 11:19. |
#62 |
Postovi: 1,629
I never make the same mistake twice I make it five or six times just to be sure... |
#63 | |
Postovi: 18,847
Ma slikaj se, ograđuju se maksimalno... Citiraj:
#64 |
Lokacija: st
Postovi: 596
A posla sam upit, pa ako prodje ;/ Samo bojim se da je ovo mala lovica za zezat se s menom! ![]() Da imam 5 keka, onda bi bez problema vratili!!! Uz proviziju!! Ovo sam dobio kao generički odgovor, pa sa i dalje postavio pitanje! Ipak oni drže moje privatne kljucčeve! Ako nece da vrate nek mi daju ključeve i opciju da ih sam vratim! Auto odgovor: Bittrex's cross chain recovery policy is that we will only attempt to recover deposits that exceed $5000 at the time of deposit, within 7 days of the deposit and will charge a 0.1 BTC for this recovery. Recovering coins crosschain is an inherently dangerous and time consuming process. Not all deposits can be recovered and the time frame of recovery is at our discretion. This policy DOES NOT apply to deposits with incorrect or missing memos on currencies such as CryptoNote, NXT, BitShares, Ripple, STEEM, or any others that rely on a message/memo/tag for crediting deposits. Nor does it apply to ETH tokens sent to other addresses on the ETH network. These will be recovered in a time frame of our discretion. This policy DOES apply to any deposits sent to an address of another coin on another network. This includes but is not limited to: Sending, for example, BTC to a BCC addressSending an OMNI/XCP asset to ANY address other than the one assignedSending ETH to an ETC address Note: We WILL NOT recover coins or tokens we do not support. Nor will we recover funds that were distributed as part of an ICO. Koji je to monopol i ucijena!! Neke mjenjačnice imaju opciju (besplatnu) za vratit srestva! Ovo je čista ucijena.
MinigRig*H110-D3A*5*rx570nitro8GB OC. Zadnje izmijenjeno od: gloginjaR. 03.03.2018. u 21:39. |
#65 |
Datum registracije: Aug 2014
Postovi: 2,929
Jbg. Pomiri se sa tim gubitkom i više pazi slijedeći puta . Nažalost sam si kriv i u njihovoj si milosti 🤐 |
#66 |
Postovi: 1,629
Eto, sad barem znaš da nije nemoguće. Ovo je tvoja greška, malo je skuplja... ali jebiga, na takvima se najbolje uči.
#67 |
Lokacija: st
Postovi: 596
Ma da. Otpila me glatko! :\ Dorian veli da su takva pravila i da se za sad nemjenjaju, Ništa, čeka cu da tih 0.48eth naraste na 5keka $ pa cu onda povuć ![]() ... kako god, nije pošteno, čemu im onda služi održavanje walleta? Na mjenjačnici kada je odredjeni novčic nedostupan par sati!!! Bice tada kupe ove zaglavljene transakcije i djele medusobno ![]() Tek vako kad zapadneš u "probleme" sa transakciom, onda vidiš sve mogućnosti dotične valute (ili coina). I monopola i ovlasti koje pojedine mjenjačnice imaju!! Uzimaju nam provizije i kojekakve uvijete traže kod registracije! Ok, sve to se podrazumijeva, ali daj neka i oni "daju nešto zauzvrat. tipkano sa mog T98 4G八核(C6R3)
MinigRig*H110-D3A*5*rx570nitro8GB OC. |
#68 |
Postovi: 2,929
U 7 dana neće narasti toliko ETH nikako 😅 pomiri se sa time . Bit će ti lakse |
#69 |
Datum registracije: Dec 2017
Postovi: 16
Danas izašao update firmwarea za Ledger nano s, verzija 1.4.1. Ja sam uspješno odradio a onima koji će tek raditi par savjeta: -deinstalirajte sve wallete sa ledgera - pratite upustva koja su postavili na svojim stranicama jer ima par neočekivanih caka -budite jako strpljivi jer sve traje dosta duže nego inače, vjerojatno su serveri preopterećeni |
#70 |
Postovi: 18,847
Baš sam ujutro dobio mail i nikako napraviti update. Ledger Manager se vuče za poluditi, jako sporo prepoznaje Nano S, deinstalacija aplikacija ide jako sporo ili nikako. Bojim se da update negdje ne pukne pa da se moram zezati oko RMA.
#71 |
Postovi: 119
Hvala za info. Pretpostavljam da ne moram žuriti s instalacijom novog firmware-a ako ne mislim koristiti Ledger. Ali pitanje... Ako deinstaliram sve wallete s Ledgera, kako će on znati nakon ponovne instalacije koji je moj wallet? Poslano sa mog Redmi 3 koristeći Tapatalk |
#72 |
Postovi: 16
Znat će on, bez brige (da ne pišemo ponovo jer je već par puta objasnjeno), možeš wallete bez straha deinstalirati i instalirati one koji ti trenutno trebaju. |
#73 | |
Postovi: 18,847
Sve se veže uz tvoj seed, možeš brisati i stavljati koliko hoćeš walleta, stanje coina se ne mijenja. Zato, čuvaj seed kao oči u glavi i nemaš brige. Evo i punog change loga: Citiraj:
#74 |
Postovi: 119
Objavili su upute točno korak po korak pa ako netko još nije ažurirano, sad može pratiti ove upute: https://support.ledgerwallet.com/hc/...e-firmware-1-4 Poslano sa mog Redmi 3 koristeći Tapatalk |
#75 |
Lokacija: st
Postovi: 596
Pogledao sam upute , probao sam nadogradit, ali mi nece izbrisat eth i litecoin aplikaciju! Pa cu probat sutra prekosutra kad malo padne promet!? mislim da su ga maksimalno zakomplicirali ![]() tipkano sa mog T98 4G八核(C6R3)
#76 |
Postovi: 18,847
Nije ni meni htio, ali je uspio nakon nekoliko pokušaja. Ovo čak i nije toliko komplicirano koliko je bilo za stari firmware kada si morao ponovno unositi seed.
#79 |
Lokacija: st
Postovi: 596
Hoću sa NANO s, da pošaljem na bitrex eth, ali mi javlja neku grešku??? o čemu se radi? https://s17.postimg.org/nkyv3tatb/bit.jpg nekužim kako u Nano S da povećam plin??? https://s17.postimg.org/ididd045b/nano.jpg
MinigRig*H110-D3A*5*rx570nitro8GB OC. Zadnje izmijenjeno od: gloginjaR. 07.03.2018. u 12:25. |
#81 |
Datum registracije: Oct 2013
Postovi: 132
Meni se još otprije 2 dana nije prebacio ETH sa miningpoolhuba na Bittrex iako je transakcija uredno provedena. Ima netko neku ideju? (kontaktirao sam support) EDIT: Našao ovo kad sam htio kopirat adresu: "Please use a small amount for your first deposit to verify everything is working as expected before sending larger amounts. Your deposit address must hold more than 0.1 ETH before we will credit your account. If you deposit less than 0.1 ETH you will need to deposit more until your balance on the block chain holds greater than 0.1 ETH" Ahhhh... |
#82 | |
Lokacija: st
Postovi: 596
![]() neznam da probam sa myetherwaleta? edit; neide ni sa myetherwalet??? https://s17.postimg.org/o71m5aun3/myet.jpg :
MinigRig*H110-D3A*5*rx570nitro8GB OC. Zadnje izmijenjeno od: gloginjaR. 07.03.2018. u 13:49. |
#84 |
Postovi: 18,847
#85 | |
Lokacija: st
Postovi: 596
ima li neki kallkulator da izračunam? kolika je cijena??? edit; posla sam sa myetherwalet, stavia sam 41 gwei i prošlo je! a hebo ga patak! satra me je! ![]() Hvala Buljo! ![]()
MinigRig*H110-D3A*5*rx570nitro8GB OC. Zadnje izmijenjeno od: gloginjaR. 07.03.2018. u 14:16. |
#86 |
Lokacija: hr
Postovi: 976
Znači sa novom nadogradnjom Ledger Nano S dobije se podrška za do 18 aplikacija (coina), umjesto dosadašnjih 4 ? jel može netko potvrditi tko je nadogradio? |
#87 |
Postovi: 18,847
Kod mene je zasad instalirano 7 aplikacija. Ako hoćeš, mogu vidjeti koliko stvarno ide.
#88 |
Lokacija: hr
Postovi: 976
Ne treba hvala, dovoljno je i 7. Onda valjda ide do te brojke. |
#90 |
Postovi: 18,847
Pa ne treba ti browser support za Ledger Wallet.
