Staro 07.02.2018., 00:26   #91
O9g1
Bee-do Bee-do Bee-do, TUP
O9g1's Avatar
Datum registracije: Aug 2009
Postovi: 323
Delete, dupli post!
CPU: Intel i5 2500k (BX80623I52500K) cooled by Scythe Ninja3 (SCNJ-3000)
MBO: Asus P8Z68-V PRO/GEN3
RAM: 2x4GB Kingston 1600MHz, DDR3, XMP (KHX1600C9D3K2/8G)
GPU: GIGABYTE Radeon R9 290 4GB Windforce 3x (GV-R929OC-4GD)
SSD: Samsung 840 EVO 120GB (MZ-7TE120BW) - System
HDD1: WD Caviar Black 500GB (WD5001AALS) - Storage
HDD2: WD 250GB (WD2500JS-22MHB0 ) - Backup
ODD: Samsung 22/8/8/48/32x (SH-S222AB)
PSU: XFX XXX Edition P1-650X-CAG9 650W
CASE: Fractal Design Arc midi
FAN CONTROL: Scythe KAZE MASTER 5.25″ Bay Fan Controller (KM01-BK)
FAN: 2x Fractal Design Dynamic GP-14, 140 mm intake+2X Scythe S-flex 120mm (SFF21E) exhaust
OS: W10 x64
LCD:MASTER: LG 29UM57-P Ultra širok đubar, jooooj što ga volem... , SLAVE: Dell 17"
KEYBOARD: Logitech UltraX keyboard (Y-BL49)
MOUSE: Logitech G400
SOUND: Creative Sound Blaster X-Fi XtremeMusic
HEADSET: Steelseries Siberia v2
RALLYING GEAR: Logitech G25+homemade cokpit+handbrake (modani Genius MaxFighter F-16U)
IF IN DOUBT, FLAT OUT!!!
Don't touch it! It is mine! It's all miiiiineeee!!!
Lenovo Essential B580
CPU: Intel Celeron Dual Core B820 1.70GHz (2MB cache)
LCD: 15.6" HD LED 1366 x 768
GPU: Intel HD Graphics 3000
RAM: 4GB DDR3 1600MHz
HDD: 320GB SATA
ODD: DVDRW DL
PSU: Up to 4hours (Li-Ion 6 cell)
ETHERNET: Yes (Gb LAN)
COMM: Yes (802.11b/g/n)
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
FINGERPRINT READER: Yes
CAMERA: Yes
OS: Windows 7 Profesional
Lenovo ThinkPad E560
CPU: Intel Core i7-6500U 2.5 GHz
LCD: 15.6 inch 16:9, 1920x1080, IPS-Panel, LED-Backlight, glossy: no
Extern LCD:Lenovo X24a, 24 inch 16:10, 1920x1200, IPS-Panel, LED-Backlight
GPU: AMD Radeon R7 M370 2 GB GDDR5
RAM: 16GB, 2 x 8 GB DDR3L-1600
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
ETHERNET: Gigabit Ethernet
COMM: 802.11ac, Bluetooth, Intel Dual Band Wireless-AC 8260 - M.2 Card
CONNECTIONS: 3 x USB 3.0, HDMI, VGA, OneLink connector, LAN, Headphone/microphone combo jack
CARD READER: 4 in 1 ( SD Card, MultiMediaCard, SDHC Card, SDXC Card )
CAMERA: Yes
OS: Windows 10 64x
Poštena, dobra i odgovorna trgovina +još jedna...
Straight roads are for fast cars, turns are for fast drivers!
O9g1 je offline   Reply With Quote
Staro 07.02.2018., 08:32   #92
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
pirl.minerpool.net
Staro 07.02.2018., 11:05   #93
lit
Lokacija: hr
Postovi: 976
Izgleda da je ovo stvarno bilo preusmjeravanje adrese na neku drugu preko Claymorea, ovo je stvarno a ne sprdati kao što neki rade na ovom forumu.
https://cryptovest.com/news/major-bo...e-mining-rigs/
https://www.reddit.com/r/EtherMining...aymore_hacked/
lit je offline   Reply With Quote
Staro 07.02.2018., 11:20   #94
Postovi: 8,276
Nažalost, itekak je stvarno (1 - 2 - 3) i dio puno veće priče.
Staro 07.02.2018., 14:20   #95
lit
Lokacija: hr
Postovi: 976
decred.luxor pool mi svako malo (par puta u sat vremena) javlja rejected shares jel to normalno?
Staro 23.02.2018., 19:20   #96
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,226
Dakle koji pool koristite za XVG? Ovaj NLpool mi je užasno mutan i stalno gubi konekciju.
Staro 23.02.2018., 19:38   #97
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Negdi sam pročitao da unošenjem mport 0 može zaštitit od ovih napada???
samo nisam skužia di se to unosi?
Može li se jednostavno nekom šifrom zaključat cijeli folder od Claymore?
MinigRig*H110-D3A*5*rx570nitro8GB OC.
Zadnje izmijenjeno od: gloginjaR. 23.02.2018. u 20:06.
gloginjaR je offline   Reply With Quote
Staro 23.02.2018., 20:57   #98
dadoremix
dadoremix's Avatar
Postovi: 4,715
ko si je forvardal 3333 porta ili neki po želji
da kontrolira rig preko neta..
e tu ti mogu doč .. makar i slozis read only..
ako to ne koristis.. nemas beda
ja sam tako imao.. da ga pogledam jel ziv ili nije.. a ne da svako malo ga prcam sa remote desktop
Staro 23.02.2018., 21:18   #99
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Di se to štela! U configure.tex? Ili negdi drugo,
tipkano sa mog T98 4G八核(C6R3)
Staro 23.02.2018., 22:17   #100
dadoremix
dadoremix's Avatar
Postovi: 4,715
u configu ili u samom startu .. đe želiš
a imas i redme.. jel ga tko pročitao ?
Staro 24.02.2018., 01:19   #101
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,226
Sad mi ovaj nlpool pak uopće ne prikazuje statse, sve 0, mrtvo. A rig radi pun gas.
Staro 24.02.2018., 05:34   #102
golfw12
golfw12's Avatar
Postovi: 424
Ovaj nlpool se raspao skroz. Prvo je radio dobro, pa je bio down vjerojatno zbog preopterecenja. Odusto od njega totalno prije dva dana. Ako nadjes neku dobru zamjenu za nlpool javi
CPU: AMD Ryzen 5 PRO 4650G@3.7GHz@ CM Hyper 212X
MBO: Gigabyte B450 AORUS PRO
RAM: 2 x 8 GB DDR4 3200Mhz CL16 Kingston HyperX Predator RGB
GPU: Radeon Onboard Graphics
SSD: Samsung 1Tb, NVMe
HDD: Seagate 1TB, Sata III
PSU: Corsair RM650X 650W
CASE: Phanteks ECLIPSE P400
MONITOR: AOC 24G2U @ 144HZ
MOUSE: Logitech MX518 Batman Edition
KEYBOARD: Logitech K200
PERIPHERY: RAZER Goliathus Control Alpha
OS: Windows 10 Home x64
PRINTER: HP LaserJet Pro M12w
CONNECT: T-Com VDSL 30/6 Mb Flat
CPU: Intel® Core™ i5-8250U@1.6GHz
RAM: 2 x 8 GB DDR4 2400Mhz
GPU: Intel® UHD Graphics 620
HDD: 256 GB M.2 SSD
PSU: HP 90W
LCD: 1.920 x 1.080 FHD-Display SVA
golfw12 je offline   Reply With Quote
Staro 24.02.2018., 07:51   #103
luzer80
Datum registracije: Jun 2017
Postovi: 54
ja sam se prebacio na http://antminepool.com
luzer80 je offline   Reply With Quote
Staro 24.02.2018., 10:37   #104
problem_child
Lokacija: online
Postovi: 137
Autor luzer80 Pregled postova
daje li koliko kaže whattomine?
problem_child je offline   Reply With Quote
Staro 24.02.2018., 12:21   #105
Geaprvi
Datum registracije: Feb 2018
Lokacija: BiH
Postovi: 1
pozdrav ekipi novi sam na forumu. imam manju farmu i rovim ether i dcr farmering storj. bavim se nekih godinu i pol dana sa majningom. prisutan sam uveliko bio zadnjih godinu dana kada je i krenula ludnica majninga. zadovoljan sam ali ima puno neprdvijenog posla. sa dva riga redovno lutam po poolovima i trazim sta se rovi vec godinu dana. neke pustim mjesec neke dan, poolovi nestaju, zcl mi se pravo isplatio gotov za komplet farmu pred novu godinu, btx isto, btcz, etn, pac (POS), LCP (POS), STORJ (Farmering), zen... tona uglavnom odustanem u nekom trenutku kad vise nesto od segmenata ne funkcionira ili nije isplativ u smislu da pokrije troska energije. to radim sa dva riga, jedan RX 570 SN+ 6xGPU i nVidia 1060 6xGPU (meni najbolja karta za eksperimente ove vrste, sve podnosi). Coine za majning biram preko btt ili coinmarketcap a od whattomine ide eth+dcr. Naisao sam na KMC prije tacno 3 mjeseca. preko stranice https://bitcointalk.org/index.php?topic=2335467.0 na prvoj stranici su svi linkovi a ima i neki web kmcoin.cf ali cini mi se sa manje aktivnosti. btt radi i dev je prisutan i rjesava probleme. meni je dva puta oslobodio transakcije. rovim na http://pool.kmcoin.info/# na portu:5555 i ostavio sam jedan RX rig rovi vec dva mjeseca, narovio sam dobro ali je poceo diff skakat iako je to i sad ekstra jedva 10 miliona. simple wallet i simple node radi perfektno a i GUI wallet. nesto je ubrzao zadnjih 15 dana pravo dobro radi transakcije. poceo sam ga prodavat na https://stocks.exchange/trade/KMC/BTC a nasao sam jos jedan pool http://kmcoin.hashpool.eu/# i izgeda po block exploreru da ih je 5. block im je strava: http://explorer.kmcoin.info/en/. za ovo sto sam do sada rovio mogu reci jedino btcz da mi je bio top a KMC stvarno dere. moze i preko minergate conzole na add pool doda se pool i adresa i to je to biraj jezgru i broj i rovi. 0% premine i izrovljeno 5% jedva 2,6 miliona, produkcija je 52 ukupno i 24 KMC nagrada za svaki blok. Znao sam skidat od 10 blokova 8 je bilo mojih i sad gledam na stocks.exchange npr, RIG mi je prosli mjesec izrovio (RX) 18000 cca. KMC. na stocku je to danas 0,01113 BTC. kako god sracunam najisplativiji mi poslije ETH a karte na 48 stepeni i trosi mi rig 25€ struje. prodo sam nesto vidim skace diff ne pada mi sad napamet da prodajem jer sam se isto zezno sa eterom, rovio sam ga po 12 na dan i rjesavo cccc. sto se mene tice KMC ubija, a evo info svima pogledajte stranice ljudi su sve pokrili, transaprentno do kraja.
Geaprvi je offline   Reply With Quote
Staro 24.02.2018., 13:02   #106
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Neznam što je! Ali juče sam bio napunio 0.05 na etermine.org i to sam prebacio i krenuo sa novom turom, SAD vidim da mi je jutros kada je bilo malo više od 0.01eth, opet prebacio i krenuo od nule???
Inače je minimum 0.05eth. Na etermine
Org.
Zna ko što se dešava?
Poslano sa mog A0001 koristeći Tapatalk
Staro 24.02.2018., 13:28   #107
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,226
Možeš podijeliti .bat molim te?
Staro 24.02.2018., 18:13   #108
luzer80
Postovi: 54
ja minam na SMOS i imam ovo:
-wd 1 -r 1 -epool stratum+tcp://eu1.ethermine.org:4444 -ewal ETH_ADRESA.IME_RIGA -esm 0 -epsw x -allpools 1 -mport -3333 -asm 1 -dpool stratum+tcp://s.antminepool.com:9008 -dwal XVG_ADRESA -dpsw c=XVG -dcoin blake2s -allpools 1 -dcri 40
Staro 25.02.2018., 08:52   #109
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Može li se kopat samo ETC ? sa gpu rx570
I ako ko ima volje da podijeli bat.fajl?
Hvala
Staro 25.02.2018., 21:16   #110
webstar_007
Datum registracije: Sep 2017
Postovi: 62
Autor gloginjaR Pregled postova
Hvala
može se kopat, Claymore 11, https://etc.ethermine.org/
.bat ti ovako treba bit
EthDcrMiner64.exe -epool eu1-etc.ethermine.org:4444 -ewal tvoja_adresa_za_etc.Ime -epsw x
webstar_007 je offline   Reply With Quote
Staro 28.02.2018., 12:56   #111
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Evo proba cu na nanopolu!?
Vlada je to to. stavia sam adresu sa nano s novčanika.
Staro 01.03.2018., 16:01   #112
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Opet šaltanje na drugi novac! sad mislim preć na Monero! Navodno je za 15tak dana vilica
I dobija se 10 MoneroV na jedan monero!?
https://coingape.com/monero-hard-for...v-coming-soon/
pa bi proba malo kopat monero
#CUT#
EDIT!!!!
Evo da nadodam ovi informaciju, da se radi o istoj shemi kao i za litecoin cash!
https://cryptobriefing.com/monerov-f...onero-privacy/
Pa budi te oprezni!
LP.
Zadnje izmijenjeno od: gloginjaR. 01.03.2018. u 19:24.
Staro 01.03.2018., 19:51   #113
lit
Lokacija: hr
Postovi: 976
Pa to ne možeš više pratiti koliko je to forkova i svih drugih informacija, just too much...
Zadnje izmijenjeno od: lit. 01.03.2018. u 20:15.
Staro 01.03.2018., 19:56   #114
damba_
Datum registracije: Feb 2017
Postovi: 119
Jel majna tko Musicoin i ako ima preporuka za pool za Musicoin?
Isto je najavljen fork krajem 3. mjeseca pa bi mogla cijena skočiti.
damba_ je offline   Reply With Quote
Staro 02.03.2018., 10:05   #115
BBminer
Datum registracije: Dec 2017
Lokacija: Sisačko-moslavačka županija
Postovi: 183
Evo jedno možda i blesavo pitanje. Imam myetherwallet za cuvanje ETH i isplate sa ethermine. Jedan rig bi prebacio na ETC. Vidim da ethermine app za android ima za prebacivat na istoj adresi iz eth u etc wallet. Da li to znaci da na istu adresu walleta mogu namjestiti isplate za etc i eth sa poola(nekako mi to nema smisla)? Ili novi wallet za etc?
Zadnje izmijenjeno od: BBminer. 02.03.2018. u 10:16.
BBminer je offline   Reply With Quote
Staro 02.03.2018., 13:27   #116
Kamby
Kamby's Avatar
Datum registracije: Oct 2013
Postovi: 132
Kamby je offline   Reply With Quote
Staro 02.03.2018., 21:03   #117
...Tihomir...
...Tihomir...'s Avatar
Postovi: 343
Autor damba_ Pregled postova
Evo pa si izaberi: https://minerpool.net/pools/musicoin/
Ja sam se igrao sa Music-om tamo negdje u 09 mjesecu sa jednom karticom, koristio sam dva poola koja su mi bila ok s popisa, ali previše je to vremena da ti ih sada preporučujem...
...Tihomir... je offline   Reply With Quote
Staro 02.03.2018., 21:14   #118
skrgahr
Postovi: 88
ako se netko pitao koliko claymore ubire od feea - >
https://ethermine.org/miners/3509F7b...3bfA2Cd505ae31
https://ethermine.org/miners/6F31A79...a88BB577A67eaC
12 ETH dnevno na ove dvije adrese, i to samo na ethermine.
lik si slozio penziju, i to kakvu
skrgahr je offline   Reply With Quote
Staro 02.03.2018., 22:24   #119
dadoremix
dadoremix's Avatar
Postovi: 4,715
je to ti je posel
programa sklepat
a ne rudarit
a ima i na zeco, i druge valute
bravo za njega
Staro 03.03.2018., 08:00   #120
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Poz.
Daj ako imaš volje da mi pojasniš
Poslao sam sa myetherwaleta ETH. Na adresu ETC(na bittrex)!!
SAD više nevidim ni ETH na myeterwaletu
Niti imam etc, a transakcija je uredno potvrdila blok potvrde?
Mogu li kako vratit ETH na novčanik?
https://etherscan.io/tx/0xd31d64ba09...51334fca0b4546
