Staro 19.02.2018., 21:35   #421
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ima tko Sapphire RX 560 4GB sa Hynix-om da je uspio preko 13 MHs?
Staro 19.02.2018., 22:07   #422
Herr Flick
Herr Flick's Avatar
Lokacija: ČK
Postovi: 133
Ja nemam od Sapphirea ali imam 5 kom MSI RX560 4GB ITX AERO sa Hynix memorijom (H5GQ8H24MJR) i idu 13.5-14.1 MHs + 550-560 MHs blake2s (XVG).
1 kom je na 13.5, 3 kom na 13.8 i 1 kom na 14.1, a sve iste memorije.
Sve na kraju ovisi o sreći.
Herr Flick je offline   Reply With Quote
Staro 19.02.2018., 23:27   #423
Facelessone
Facelessone's Avatar
Postovi: 4,203
Kod mene je jedna Sapphire, ~13MHs iznad baš nije stabilan hashrate ali ak se sjecam dobro nije bilo mem errora u Windowsima, samo skakanje hashratea.
Gdje lupaš XVG jer ovaj nlpool svako malo ode u k?
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 19.02.2018., 23:53   #424
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,001
Jel se isplati XVG il je dolar na mjesec?
Staro 20.02.2018., 00:06   #425
Facelessone
Postovi: 4,203
Ovisi koliko ga tjeraš u dualu, ide ~1.1GHs po jednoj RX570 da ne padne ETH. Oko ~150W više ukupno, ~$70 - struja.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 20.02.2018., 08:19   #426
MfMax
Datum registracije: Oct 2017
Postovi: 15
Napiši koji je bios, odnosno koji tip hynixa?
Autor FRipper Pregled postova
MfMax je offline   Reply With Quote
Staro 20.02.2018., 08:28   #427
luzer80
Datum registracije: Jun 2017
Postovi: 54
Ja sam upogonio ETH + XVG na 2xRX580 + 2xRX570. ETH brzina mi se povećala za 1,5 MH/s a B2S-Total Speed: 4813.303 Mh/s
luzer80 je offline   Reply With Quote
Staro 20.02.2018., 08:38   #428
marac
marac's Avatar
Postovi: 2,030
GPU Mining Bios Collection i ostalo
Sent from my X using Tapatalk
Meni su 570/580 cca. 30mhs za eth i 1400 za xvg.
Zadnje izmijenjeno od: FRipper. 25.02.2018. u 11:37.
Staro 20.02.2018., 10:11   #429
Street_Racer
Ulični trkač
Street_Racer's Avatar
Postovi: 316
Može li mi netko objasniti zašto windowsi 10 + zadnji ati driveri ne prihvaćaju napone fleshane direktno u biosu grafičke kartice? Znači ja stavim 850mV za memoriju, hwinfo pokazuje defaultnih 950mV. Tek kad napone promjenim preko overdriventool-a onda prihvati.
I live my life a 1/4 mile at a time! Nothing else matters...
For those 10 seconds or less...I'm free!
Poštene trgovine: #1 #2 #3 #4
Street_Racer je offline   Reply With Quote
Staro 20.02.2018., 10:25   #430
Facelessone
Postovi: 4,203
Probaj staviti dinamičke napone koje GPU sam rikta prema ASIC quality. Stavi 65286 pa vidi koji napon ti onda daje. Kad ideš po kućicama prema dolje vrijednost ti mora biti ista ili veća u sljedećoj.
Edit: nvm, ja pričam za core a sad vidim da se o memoriji radi
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 20.02.2018., 22:06   #431
Herr Flick
Herr Flick's Avatar
Lokacija: ČK
Postovi: 133
Prvo sam probao zPool i UniMining ali mi se nisu baš pokazali dobri.
Zatim sam prešao na Nlpool i dan i pol je bilo super, ali sad vidim da je i on za k.
Ima tko kakvu preporuku za bolji pool?
Staro 21.02.2018., 08:13   #432
lit
Lokacija: hr
Postovi: 976
Blake xvg poolovi su svi sh*t, niti jedan ne izdrži 8h a još manje da izdrži 24h. Ako je netko probao na drugom algu neka javi.
lit je offline   Reply With Quote
Staro 22.02.2018., 19:17   #433
skrgahr
Datum registracije: Dec 2017
Postovi: 88
Autor Herr Flick Pregled postova
nlpool je radio jedan dan dobro, a nakon toga su sav history na walletu obrisali i nije bilo payouta. taj pool je zesce sranje.
presao sam na antminepool i za sad je ok
skrgahr je offline   Reply With Quote
Staro 23.02.2018., 08:36   #434
lit
Lokacija: hr
Postovi: 976
Kod dual biosa na karticama, kada flasham na koju stranu treba biti bios? na onoj strani kako je došla kartica?
Staro 23.02.2018., 09:44   #435
smurf
Lokacija: Cakovec
Postovi: 32
Autor lit Pregled postova
Prekidač mora biti bliže HDMI portu, znači suprotno kako je došla kartica. Barem na mojoj XFX RX580 je tako bilo.
smurf je offline   Reply With Quote
Staro 23.02.2018., 10:10   #436
BBminer
Lokacija: Sisačko-moslavačka županija
Postovi: 183
Autor smurf Pregled postova
Istina. Kod mene je XFX i Sapphire ista stvar. 470/480/570/580.
BBminer je offline   Reply With Quote
Staro 25.02.2018., 20:01   #437
BaneBG
Datum registracije: Feb 2018
Postovi: 15
oćeš reči da je Sapphire RX 560 4GB lošiji od gigabyte rx560 4gb Hynix
BaneBG je offline   Reply With Quote
Staro 25.02.2018., 21:04   #438
BBminer
Postovi: 183
Autor BaneBG Pregled postova
Kod 560-ki ti dosta veliku ulogu imaju i stream processori tj. shaderi.
Većina proizvođača je izdala seriju 560D koja ti je zapravo rx 460 samo drugi naziv
E sad, pošto sam i ja piknuo naravno u tu "stariju" verziju proučavao sam i imao sreće da su fizički na kartici samo su bili zaključani.
Kada ih otključaš možeš uređivati strapove (inače vidiš samo do 1:1500 i ne možeš puno izvući iz nje).
Ovako, ja trenutno imam 14Mh/s na cca 40-45w iz zida. Asus RX 560 EVO 4gb
Koliko sam vidio, najviše sreće sa 560kom imaju modeli od Gigabyte-a i to rev.1 (ako ih je uopće moguće naći) i oni mogu nategnuti do 16Mh/s (info sa stranog foruma).
Staro 26.02.2018., 14:57   #439
mesiah
Datum registracije: Jan 2018
Lokacija: Makedonija
Postovi: 32
Kako si proracunao XVG hashrate? Imam Sapphire RX 470 8GB i na ETH imam 29MH/s, pa bih hteo videti ako majnam dual ETH+XVG dali bi se to isplatilo. Za whattomine koji hashrate da stavim za XVG u kalkulatoru za dual mining. Po nekim mojim racunicama, ako za 84MH/s za ETH u whattomine daje 4000MH/s za XVG, onda za 29MH/s trebalo bi da bude 1380 MH/s za XVG ?!!
Autor marac Pregled postova
Zadnje izmijenjeno od: mesiah. 26.02.2018. u 15:14.
mesiah je offline   Reply With Quote
Staro 27.02.2018., 13:24   #440
BaneBG
Postovi: 15
Autor BBminer Pregled postova
To nisam znao.
Da moguće je ali memorija baca stotine grešaka po sekundi, najstabilnije je za sad 15.1Mh/s sa greškom tu i tamo
Staro 28.02.2018., 22:12   #441
skrgahr
Postovi: 88
Pozdrav!
Nabavio sam dvije XFX RX570 4GB sa Elpida memorijom. Iz kutije u mining modu rade 26.3 MH/s. BIOS nije flashan.
Molim da netko postavi BIOS ako ima, te da napiše clockove
SMOS ,clockovi su 1020/1850 na 950 mV.
Staro 01.03.2018., 07:22   #442
BBminer
Postovi: 183
Autor skrgahr Pregled postova
Pozdrav!
Vidi samo koja je verzija. Kod mene je xxx Black Edition RS i trenutno je na 30,5Mhs
Staro 01.03.2018., 07:29   #443
tabana
Datum registracije: May 2017
Postovi: 60
Na koju foru?
Moje sve RX-ice su na 28-30 MH/s, a samo ta XFX RS sa elpidom na 27 s tim da je najtoplija i najglasnija...
Bios mod - 1:1500 kopiran na više
Clock - 1100/1900/950 - 70% fan - 65C
Koje su tvoje postavke?
tabana je offline   Reply With Quote
Staro 01.03.2018., 08:30   #444
BBminer
Postovi: 183
Autor tabana Pregled postova
Na koju foru?
Driver AMD 18.2.2
Bios one click mod
1150/850 i 2050/850
temp je oko 65C na 50-ak % (nisam trenutno kraj riga pa ne znam točno)
Piči tako već skoro mjesec dana
Staro 01.03.2018., 08:37   #445
skrgahr
Postovi: 88
nije Black Edition, da ti pravo kažem, ni ne znam koji točno edition. kako da prepoznam?
Staro 01.03.2018., 08:45   #446
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Black i XXX Ed. je isto, samo black ima veće clockove...
Probaj ovaj bios na toj XFX elpidi
https://mega.nz/#!dx1R2Z6L!yGMiUz5V-...hUCrZhlqcLBU8E
Staro 01.03.2018., 09:06   #447
skrgahr
Postovi: 88
Hvala! Probam kasnije. Koji clock da stavim za pocetak?
Edititon je XXX - XFX-RX-570P4DFD6
Staro 01.03.2018., 09:29   #448
skrgahr
Postovi: 88
Taj BIOS, 1100/1950 na 925 mV = 28.4 MH/s.
EDIT: na 1100/2000/925 ide 29.2 MH/s.
Zadnje izmijenjeno od: skrgahr. 01.03.2018. u 10:12.
Staro 01.03.2018., 10:19   #449
bez_komentara
Datum registracije: Jul 2017
Postovi: 238
bez_komentara je offline   Reply With Quote
Staro 01.03.2018., 11:10   #450
skrgahr
Postovi: 88
Autor bez_komentara Pregled postova
na koliko undervolta? potrošnja?
