Postovi: 36
Nemam neko cool ime za build, al je W/C :)
Mislim da svi ovdje znaju engleski jako dobro, tako da nema potrebe da prevodim svoj post sa overclock.net-a (nadam se). ![]() Uglavnom poceo sam dizajnirati comp u 11/2017, za Bozicne praznike sam ga funckionalno slozio, i napokon od proslog tjedna je sve kozmeticki bilo poslozeno. Potrajalo je, jer je prvo moje iskustvo sa W/C uopce, nisam htio AIO solucije, nego odmah custom loop. Nakon skoro 20 let slaganja compova, moram priznat da mi je opet bilo uzbudljivo, a ne samo nesto sto moram. ![]() Pozdrav! ---------------------------------------------------------------------------- So finally got around to completely finish my first watercooled build. It was a lengthy and painstaking process (had to disassemble everything twice to fix tiny leaks). The only thing I regret is that I scratched some things up (fittings, res), but Sharpie covers the mistakes well! Also it was a very tough fit for the 1080ti, unfortunately didn't think about the spacing and by the time I was building everything the time to be able to exchange the card was passed. But with some roughage I was able to do it! Heatkiller Tube is all scratched up on that side, but you can't see them from the card anyway, so in the end not too big of a problem. Water out temps are 27-28C and CPU cores are usually between 28C and 29C idle (24C room temperature). Also did the mod where the front of the case is 4mm pushed outwards (didn't change the temps at idle at all, didn't test on full load yet). Overall I love the build, it's pretty much impossible to hear anything, the most silent PC I have ever (or not) heard!!! P.S. Yes I know that a piece of carbon foil is messed up on the bottom, but you can't see it when the case is closed, and I wasn't going to re-do all of it! The parts used: Maximus X Hero i7-8700k (stock speeds currently) Gigabyte AORUS 1080Ti Samsung 960 Pro 500Gb (boot) 2 x Samsung 850 Evo 2TB (storage, RAID1) Seasonic PRIME Ultra 850W Watercooling: All Bitspower fittings (incl temp probe) HEATKILLER® Tube 150 HEATKILLER® IV PRO (with backplate) EKWB D5 PWM EKWB CE280 Radiator PrimoChill PrimoFlex Advanced LRT tubing Noiseblocker NB-eLoop® fans Whole album in high res: https://imgur.com/a/BVnJc |
Postovi: 17,107
Ok je za prvi puta. Ali samo napomena. Ravne cijevi + kutnici daju dodatnu dimenziju samom dizajnu, nego ovako savinute cijevi. Za drugi puta ![]() |
Postovi: 8,226
Fora je, jedino meni ova kućišta što imaju pokriveno većina komponenti nisu nešto. Tu što ti se nesviđa bubneš dolje i bok. To ti je odma 70% posla više. |
Postovi: 36
Hvala momci! Acryl nije dolazio u obzir za prvi susret sa W/C-om, tu bas trebas znati kaj radis, pogotovo zglobovi sa heatgunom itd. I naravno slazem se da puno lepse zgleda i sve. To mozda jednog dana kada cu imat volje i vremena. @nick praskaton ovo je idle, cek da izmjerim load na brzaka u idlu ne znam ni da comp radi Cooling Fans CPU 1571 RPM Chassis #1 674 RPM Chassis #2 573 RPM Chassis #3 599 RPM GPU 0 RPM (0%) Zadnje izmijenjeno od: brab. 08.02.2018. u 23:49. |
Postovi: 36
Evo i rezultata Prime95 (Small FFTs) testa: Cooling Fans CPU 3117 RPM Chassis #1 1041 RPM Chassis #2 861 RPM Chassis #3 903 RPM GPU 0 RPM (0%) CPU 59 °C (138 °F) CPU Package 70 °C (158 °F) CPU IA Cores 70 °C (158 °F) CPU GT Cores 41 °C (106 °F) CPU #1 / Core #1 70 °C (158 °F) CPU #1 / Core #2 66 °C (151 °F) CPU #1 / Core #3 70 °C (158 °F) CPU #1 / Core #4 68 °C (154 °F) CPU #1 / Core #5 66 °C (151 °F) CPU #1 / Core #6 67 °C (153 °F) Pumpa si ni ne cuje ni na maxu, samo ventovi. |
ZeNgE_Tiho_Cro
Lokacija: Virovitica
Postovi: 466
Meni je nakon godine prozujala d-5 revo pumpa, sva sreca da je bila 2 god gara. Poslao video na support i dobio drugu za 2 dana. Inace da, nije nist bucna, a meni je jos pod kontrolama od aquasuite boarda 1500-2000rpm. |
#10 | |
Lokacija: Cro
Postovi: 1,034
Postovi: 8,226
Ja sam imao D5 vario, i baš je brutalna pumpa. Na minimumu nečujna, iako postoje vibracije, a na max baš protjera i pravi mjehuriće koliko brzo tera. Ja sam slagao, i ako hoćeš i motat cijevi, bez koljena, znači da je sve izvedeno, treba ti više vremena nego za posložit blokove i sve unutra. S tim, da ak nemaš sreće, budeš u prosjeku morao motat dvaput cijevi. Jednu testnu i drugu finalnu za svaku sekciju. Baš je pain in the ass. To su neka moja iskustva. |
#12 | ||
Postovi: 36
Isto EKWB? Prime95, v29.4 build 7 A za ostalo kak pise gore :"i7-8700k (stock speeds currently)" Citiraj:
I da na Prime-u je pocela mjehurice rokat, reko pa izbacio sam skoro sav zrak iz sistema, od kud sad ovo! HAHAHA ![]() Ako si imao D5, kaj sad koristis? |
#13 | |
Lokacija: Cro
Postovi: 1,034
Ako ti napon nije fiksan, koliko shvaćam da nije. Onda ti regulator u ovisnosti o namještenim postavkama i VID tablicama koje su različite za svaki procesor daje različite napone,+LLC utječe na rezultate temperatura. Tako da ti temperatura nije usporediva. Imam slični kompjuter kao ti, i i7 8700k. Trenutno hlađen s NHD14 i razmišljao sam o custom loopu (baš taj hladnjak i pumpa, ek blok) jer su mi temperature visoke (nije delidan procesor). Pa me zato zanima dal bi profitirao s custom loopom. Ono što mogu reć, je da je meni na auto naponu napon debelo previsok nego što mom procesoru treba da bude stabilan. I to na svim frekvencijama, i underclock i oc. Detaljno sam istražavao 3 frekvencije 4.0 s max llc dovoljan je 1,0V 4,8 dovoljan je 1,2V 5,0 dovoljan je 1,3V i temperature su mi previsoke u prime AVX (bez ofseta). Uglavnom čestitke na loopu. |
Postovi: 8,226
Nema veze tko je vendor, sve su to iste pumpe, s iste trake. Ma ja sam imao svašta; neku random za akvarije -> Eheim 1046 -> Eheim 1046 -> D5 Vario -> DDC Trenutno nekoristim ništa, na zračnom sam iako bi od dijelova koji mi stoje po kutijama mogao složit 2 loopa Kad jednom probaš, nema nazad. |
#16 |
CNE @ Verne global DC
Datum registracije: Feb 2015
Lokacija: Reykjavik, Iceland
Postovi: 493
Odlican odabir Flex tubing + Heatkiller blokovi. ![]() Konacno imamo malo odstupanja od sabloniziranih hardtubing buildova .Heatkiller je po meni ispred EKWB-a, samo sto na zalost nemaju bas opsirnu ponudu, pogotovo sto se monoblokova tice. A sto se D5 tice, da drnda -> drnda i buci, ali je najtisa kad se usporedi s ostatkom Eheim/Laing pumpi, ne znam gdi ljudi slusaju pumpu u radu, 1m od ceste po kojoj voze kamioni pa je 'necujna' ? |
#17 | |||
Postovi: 36
Covjek se uljeni kad ostari. ![]() Mozda se jednog dana pozabavim time. Meni je bilo najbitnije (osim da bude neki fun project) da bude sto tisi moguce, sto definitivno stoji, i zbog toga sam presretan! ![]() Ja sam originalno sve zivo htio uzet od EKWB-a, i poslao sam im e-mail sa cijelom narudzbom (bilo tipa €450) tada i kukci mi nisu htjeli dati niti 1% popusta. I onda sam si rekao ko vas i poceo malo vise istrazivati i na overclock.net-u su mi dali preporuke za sve. Na kraju sve kaj sam uzeo je bilo cca cca €700-800, al je Heatkiller definitivno klase i klase iznad, a i kak je bio Black Friday dobio i EKWB stvari sa 15% popusta. ![]() Oooooo da, vise nikad se ne bi vratio na zrak! Citiraj:
Do sad nisam procitao da je nekome zujala, a nastavila raditi. Citiraj:
![]() Znam da mi neces vjerovati, ali kunem ti se, sjedim u sobi koja nema vanjske zidove, i na idleu ne cujes apsolutno nista, osim mozda mrvicu mrvicu prednje ventove. |
