14.01.2018., 12:34 | #361 |
Lokacija: Yautja Prime
Postovi: 1,128
Ahh čekam i ja verifikaciju. Već dva puta odbili prvo oversaturated, a drugdje prošlo bez problema. Sad pak ne paše dokument jer se kao ne vidi pečat od banke. Lel Isto sam u dilemi uzeti USD ili EUR. Još ću na kraju obje (netko je tu spomenuo da se može). xd |
14.01.2018., 12:50 | #363 |
Lokacija: vž
Postovi: 1,302
veci limiti i nemas lifetime ogranicenja. Ko neverificirani, imas neke smijesne ***LIFETIME*** limite, 250 balance, 100 atm i onda kartica u blok dok ne posaljes papire... c/p: Your Advanced Cash account is not verified yet. Because of this, there are certain limits concerning your plastic card transactions: - total cumulative lifetime card funding/transaction limit: $250 Card funding - max one-time funding: $250 - max daily funding: $250 - funding transactions: 1 Purchases - transactions per day: no limit - max daily spending: $250 - max total transactions: $250 - total card transactions: no limit ATM withdrawals - total withdrawal amount: $100 - max ATM transactions per day: 5 - max one-time withdrawal: $100 - total withdrawals per day: $100 When you successfully complete your account verification, we will set our standard limits to your card: $3,000 daily withdrawals, $10,000 total daily transactions, $3,000 total daily funding. Verification is a fast and easy procedure that unlocks all the Advanced Cash features and advantages for you. |
14.01.2018., 13:12 | #364 | |
Lokacija: hr
Postovi: 976
Pošalji im na support i reci isto da te to nitko drugi nije tražio od svih burzi nego samo oni i napomeni da ima kao i drugih kartica. Što nas više ima treba im dat pritisak da brže prođe. Inače, Wirex stiže za 3 tjedna. |
14.01.2018., 13:15 | #365 |
bu
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,535
Ne kužim o kakvim vi bankama pričate? Za verifikaciju na adv vam treba osobna i račun od telefona/struje/interneta i to je to. Ja sam slao od optime račun Čak mi je kolegi prošla verifikacija sa prednjom stranom osobne za ID i stražnjom stranom osobne za adress, nije imao nikakav račun na svoje ime pa onda nije mogao to poslati @ lit - kako to misliš da wirex stiže za 3 tjedna? Otkud ti informacija?
14.01.2018., 13:31 | #366 | |
Lokacija: hr
Postovi: 976
Wirex support mi je rekao, lijepo sam pitao rekli su da moraju potpisati ugovor s novom kartičarskom kućom a već je sve u tijeku i da će biti gotovo za 3 tjedna. A ima i drugih Bitwala koliko vidim nudi 60 altcoina, što je super. Ako je netko na Bitwali neka javi kakvi su. |
14.01.2018., 14:03 | #367 |
Lokacija: RH
Postovi: 1,609
pitanje oko trosenja preko kartica..je li tko trosio vece iznose? recimo 20-30k kn godisnje? je li bilo kakvih problema? jer par servisa sam pitao i rekli su da oni ne salju poreznoj izvode osim ako porezna trazi, ne znam na koji nacin bi se porezna mogla sjetiti traziti za pojedinca osim ako ne traze grupno...ja sam do sad trosio male iznose samo tj ukupno manje 10k kn pa sad je li ima tko iskustva sa vecim ciframa? |
14.01.2018., 14:15 | #369 |
Datum registracije: Aug 2014
Postovi: 2,883
Zadnje izmijenjeno od: buljaka. 14.01.2018. u 14:25. |
14.01.2018., 14:23 | #370 |
Lokacija: Sveti Ivan Zelina
Postovi: 54
Ja sam za sada sa virtualnom karticom u USD uspješno kupio neku sitnicu na AliExpress-u te platio 120 kuna račun u PROTIS-u. Čekam da mi stigne plastična kartica u EUR. Verifikacija je prošla sa osobnom iskaznicom. Zadnje izmijenjeno od: msantic. 14.01.2018. u 14:29. |
14.01.2018., 15:03 | #371 |
Postovi: 18,504
Kod mene će onda biti veselo jer nemam nijedan račun na svoje ime kao ni izvode iz banke. Morat ću sa e-Građani skinuti potvrdu o prebivalištu, valjda će to uvažiti.
14.01.2018., 17:35 | #372 |
Lokacija: RH
Postovi: 1,609
nece, probao sam...najlakse mi prolazio izvod od ziro racuna (taj jedini imam), racuni od interneta 50:50, a potvrda o prebivalistu niti jednom |
14.01.2018., 19:43 | #374 |
Datum registracije: Sep 2017
Postovi: 64
Imam pitanje u vezi Revolut kartice, nisam siguran jesam li to negdje na ovom forumu čitao ili negdje drugdje ne mogu naći. Ima li netko da ima tu karticu i da je probao tipa poslati devize na Revolut karticu. Zamišljam si tipa prebaciti na neku burzu tipa GDAX, prodam tamo, šibnem nazad na Coinbase eure i onda SEPA transakciju koja je free btw na Revolut i trošim onda pare s Revoluta? Da li bi to funkcioniralo tako? Čak i njihova premium opcija za 7 GBP nije uopće puno. |
14.01.2018., 22:25 | #375 |
Lokacija: vž
Postovi: 1,302
15.01.2018., 15:53 | #376 |
Datum registracije: Dec 2015
Postovi: 263
friski info adv radi i na bankomatu samo su digli frei |
15.01.2018., 16:04 | #377 |
Postovi: 2,883
15.01.2018., 16:17 | #380 |
Postovi: 263
15.01.2018., 16:30 | #381 |
Lokacija: zadar
Postovi: 192
Ček, znači povećali su fee na adv??? taman mi jutros prošla verifikacija i naručio je..... Kaže:
Znači ako dižem sa bankomata skida 1.99€ + 2.95% ? I plaćanje na POS ista priča? |
15.01.2018., 17:01 | #384 |
Postovi: 263
15.01.2018., 18:27 | #386 |
Postovi: 2,883
https://www.advcash.com/en/solutions/card/ Kako onda tu kaže 2.99 za druge valute ili 1.99 za euro plus 3 %? |
15.01.2018., 18:58 | #387 | |
Lokacija: Lika
Postovi: 861
Nisu izmjenili tu , u obavijestima imas da je sad fee 6€+3% Sent from my iPhone 7+ using Tapatalk |
15.01.2018., 19:34 | #388 | |
Postovi: 54
Čini se da obavijest nema veze sa podizanjem gotovine na bankomatu... Citiraj:
15.01.2018., 20:53 | #389 |
Datum registracije: Nov 2016
Postovi: 135
Ja od uquid-a dobio nakon par mjeseci novu karticu par dana prije nove godine, ovog puta mastercard iz bugarske. jedva prebacio tih 150eur koji su mi ostali na uquidu i potrosio vec skoro sve. imam jos 10-ak eur. I eto danas mi dodje mail iz bugarskog Paynetics-a da do 26.01.2018. moram potrosit sve sto imam jer raskidaju ugovor sa nekakvim Cocsi Ltd koji trguje sa uquidom. tako da svi koji su bili ili milse u uquid bjezite glavom bez obzira jer cudim se da vec nisu propali. vise ne mislim narucivat nikakvu karticu jer vidim da su poceli svi polako nesto kemijat |
15.01.2018., 21:57 | #390 | |
Lokacija: hr
Postovi: 976
Samo što umjesto toga? |
