Lokacija: RH
Postovi: 1,736
Asus RT-AC1200G+ random reboot
eth0
Aug 1 02:00:19 pppd[472]: PAP authentication succeeded
Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A3:B7:70 authorized
Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep
Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep
Aug 1 02:00:20 pppd[472]: local IP address 93.142.236.121
Aug 1 02:00:20 pppd[472]: remote IP address 172.29.252.90
Aug 1 02:00:20 rc_service: ip-up 500:notify_rc start_firewall
Aug 1 02:00:20 kernel: SCSI subsystem initialized
Aug 1 02:00:21 rc_service: ip-up 500:notify_rc stop_upnp
Aug 1 02:00:21 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:00:22 WAN Connection: WAN was restored.
Aug 1 02:00:27 miniupnpd[465]: shutting down MiniUPnPd
Aug 1 02:00:27 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:00:32 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:32 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:32 miniupnpd[748]: version 1.9 started
Aug 1 02:00:32 miniupnpd[748]: HTTP listening on port 45952
Aug 1 02:00:32 miniupnpd[748]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:33 rc_service: ip-up 500:notify_rc start_upnp
Aug 1 02:00:33 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:00:33 miniupnpd[748]: shutting down MiniUPnPd
Aug 1 02:00:35 miniupnpd[754]: version 1.9 started
Aug 1 02:00:35 miniupnpd[754]: HTTP listening on port 55762
Aug 1 02:00:35 miniupnpd[754]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:37 ntp: start NTP update
Aug 1 02:00:37 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Nov 29 05:02:11 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Nov 29 05:02:12 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Nov 29 05:02:12 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Nov 29 05:02:12 rc_service: ntp 752:notify_rc restart_upnp
Nov 29 05:02:12 miniupnpd[754]: shutting down MiniUPnPd
Nov 29 05:02:13 rc_service: ntp 752:notify_rc restart_diskmon
Nov 29 05:02:14 disk_monitor: Finish
Nov 29 05:02:15 miniupnpd[784]: version 1.9 started
Nov 29 05:02:15 miniupnpd[784]: HTTP listening on port 44342
Nov 29 05:02:15 miniupnpd[784]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 29 05:02:17 disk monitor: be idle
Nov 29 05:02:17 rc_service: zcip 785:notify_rc start_firewall
Nov 29 05:02:17 zcip client: configured 169.254.163.221
Nov 29 05:02:18 miniupnpd[784]: shutting down MiniUPnPd
Nov 29 05:02:18 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Nov 29 05:02:20 miniupnpd[825]: version 1.9 started
Nov 29 05:02:20 miniupnpd[825]: HTTP listening on port 49515
Nov 29 05:02:20 miniupnpd[825]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 29 09:36:17 miniupnpd[825]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Nov 29 09:36:24 miniupnpd[825]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Nov 29 09:36:38 miniupnpd[825]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Nov 29 17:18:01 rc_service: httpds 417:notify_rc start_webs_update
Nov 29 23:04:49 disk_monitor: Got SIGALRM...
Nov 30 05:00:15 kernel: Emergency Sync complete
Aug 1 02:00:09 syslogd started: BusyBox v1.17.4
Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST)
Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017
Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f
Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug 1 02:00:09 kernel: Machine: Northstar Prototype
Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000
Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug 1 02:00:09 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Aug 1 02:00:09 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem
Aug 1 02:00:10 kernel: Virtual kernel memory layout:
Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB)
Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB)
Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB)
Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB)
Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB)
Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB)
Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512
Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB
Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled
Aug 1 02:00:10 kernel: bio: create slab at 0
Aug 1 02:00:10 kernel: PCI: no core
Aug 1 02:00:10 kernel: PCI: Fixing up bus 0
Aug 1 02:00:10 kernel: PCI: Fixing up bus 1
Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!!
Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2
Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 1 02:00:10 kernel: pflash: found no supported devices
Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30
Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash":
Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot"
Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug 1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs"
Aug 1 02:00:10 kernel: 0x000000d30000-0x000000ff0000 : "jffs2"
Aug 1 02:00:10 kernel: 0x000000ff0000-0x000001000000 : "nvram"
Aug 1 02:00:10 kernel: === PPTP init ===
Aug 1 02:00:11 kernel: Registering the dns_resolver key type
Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel.
Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint
Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0
Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1
Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8
Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20
Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled
Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393)
Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0
Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1
Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2adde000, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2abb13b0, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored.
Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257)
Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________
Aug 1 02:00:11 kernel: <4>Emergency Sync complete
Aug 1 02:00:11 kernel: <4>gro disabled
Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt
Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state
Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode
Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating
Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state
Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state
Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state
Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state
Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp
Aug 1 02:00:11 kernel: <0>Restarting system.
Aug 1 02:00:11 kernel: ____________________________________________________________________________
Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules!
Aug 1 02:00:11 WAN Connection: Fail to connect with some issues.
Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL
Aug 1 02:00:17 syslog: Generating SSL certificate...
Aug 1 02:00:17 jffs2: valid logs(1)
Aug 1 02:00:17 hour monitor: daemon is starting
Aug 1 02:00:17 hour monitor: daemon terminates
Aug 1 02:00:17 disk monitor: be idle
Aug 1 02:00:17 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1]
Aug 1 02:00:17 kernel: Attempt to kill tasklet from interrupt
Aug 1 02:00:18 miniupnpd[464]: version 1.9 started
Aug 1 02:00:18 miniupnpd[464]: HTTP listening on port 59631
Aug 1 02:00:18 miniupnpd[464]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized
Aug 1 02:00:19 kernel: SCSI subsystem initialized
Aug 1 02:00:20 pppd[472]: local IP address 93.139.156.15
Aug 1 02:00:20 pppd[472]: remote IP address 172.29.252.89
Aug 1 02:00:20 rc_service: ip-up 513:notify_rc start_firewall
Aug 1 02:00:20 rc_service: ip-up 513:notify_rc stop_upnp
Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:00:21 WAN Connection: WAN was restored.
Aug 1 02:00:27 miniupnpd[464]: shutting down MiniUPnPd
Aug 1 02:00:30 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:30 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:31 miniupnpd[746]: version 1.9 started
Aug 1 02:00:31 miniupnpd[746]: HTTP listening on port 46370
Aug 1 02:00:31 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:32 rc_service: ip-up 513:notify_rc start_upnp
Aug 1 02:00:32 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:00:32 miniupnpd[746]: shutting down MiniUPnPd
Aug 1 02:00:34 miniupnpd[751]: version 1.9 started
Aug 1 02:00:34 miniupnpd[751]: HTTP listening on port 54040
Aug 1 02:00:34 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:35 ntp: start NTP update
Nov 30 05:01:45 rc_service: ntp 749:notify_rc restart_upnp
Nov 30 05:01:45 miniupnpd[751]: shutting down MiniUPnPd
Nov 30 05:01:46 rc_service: ntp 749:notify_rc restart_diskmon
Nov 30 05:01:47 miniupnpd[766]: version 1.9 started
Nov 30 05:01:47 miniupnpd[766]: HTTP listening on port 36896
Nov 30 05:01:47 miniupnpd[766]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 30 05:01:47 disk_monitor: Finish
Nov 30 05:01:47 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Nov 30 05:01:47 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Nov 30 05:01:47 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Nov 30 05:01:48 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Nov 30 05:01:50 disk monitor: be idle
Nov 30 05:01:50 rc_service: zcip 778:notify_rc start_firewall
Nov 30 05:01:50 zcip client: configured 169.254.163.221
Nov 30 05:01:52 miniupnpd[766]: shutting down MiniUPnPd
Nov 30 05:01:52 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Nov 30 05:01:54 miniupnpd[821]: version 1.9 started
Nov 30 05:01:54 miniupnpd[821]: HTTP listening on port 41162
Nov 30 05:01:54 miniupnpd[821]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 30 23:04:17 disk_monitor: Got SIGALRM...
Dec 1 00:26:07 rc_service: httpds 417:notify_rc start_webs_update
Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae0e004, fsr=0x1c06, pc=0x80171f68 lr=0x800cc4c4 ignored.
Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1]
Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt
Aug 1 02:00:18 miniupnpd[459]: version 1.9 started
Aug 1 02:00:18 miniupnpd[459]: HTTP listening on port 59994
Aug 1 02:00:18 miniupnpd[459]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:19 pppd[473]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[473]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:00:19 pppd[473]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 pppd[473]: PAP authentication succeeded
Aug 1 02:00:19 pppd[473]: peer from calling number 00:90:1A:A3:B7:7C authorized
Aug 1 02:00:20 syslog: module leds-usb not found in modules.dep
Aug 1 02:00:20 pppd[473]: local IP address 93.139.153.7
Aug 1 02:00:20 pppd[473]: remote IP address 172.29.252.89
Aug 1 02:00:20 rc_service: ip-up 503:notify_rc start_firewall
Aug 1 02:00:21 rc_service: ip-up 503:notify_rc stop_upnp
Aug 1 02:00:28 miniupnpd[459]: shutting down MiniUPnPd
Aug 1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:00:33 miniupnpd[750]: version 1.9 started
Aug 1 02:00:33 miniupnpd[750]: HTTP listening on port 54542
Aug 1 02:00:33 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:33 rc_service: ip-up 503:notify_rc start_upnp
Aug 1 02:00:33 miniupnpd[750]: shutting down MiniUPnPd
Aug 1 02:00:35 miniupnpd[755]: version 1.9 started
Aug 1 02:00:35 miniupnpd[755]: HTTP listening on port 38653
Aug 1 02:00:35 miniupnpd[755]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:36 ntp: start NTP update
Aug 1 02:00:36 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Aug 1 02:00:36 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 1 05:01:41 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 1 05:01:42 rc_service: ntp 753:notify_rc restart_upnp
Dec 1 05:01:42 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 1 05:01:42 miniupnpd[755]: shutting down MiniUPnPd
Dec 1 05:01:42 miniupnpd[779]: version 1.9 started
Dec 1 05:01:42 miniupnpd[779]: HTTP listening on port 43370
Dec 1 05:01:42 miniupnpd[779]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 1 05:01:43 rc_service: ntp 753:notify_rc restart_diskmon
Dec 1 05:01:43 disk_monitor: Finish
Dec 1 05:01:45 disk monitor: be idle
Dec 1 05:01:47 rc_service: zcip 803:notify_rc start_firewall
Dec 1 05:01:47 zcip client: configured 169.254.163.221
Dec 1 05:01:48 miniupnpd[779]: shutting down MiniUPnPd
Dec 1 05:01:48 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 1 05:01:49 miniupnpd[830]: version 1.9 started
Dec 1 05:01:49 miniupnpd[830]: HTTP listening on port 35003
Dec 1 05:01:49 miniupnpd[830]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 1 13:31:57 rc_service: httpds 417:notify_rc start_webs_update
Dec 1 13:46:24 rc_service: httpds 417:notify_rc start_webs_update
Dec 1 15:51:15 rc_service: httpds 417:notify_rc start_webs_update
Dec 1 23:04:19 disk_monitor: Got SIGALRM...
Dec 2 00:19:22 rc_service: httpds 417:notify_rc start_webs_update
Aug 1 02:00:10 syslogd started: BusyBox v1.17.4
Aug 1 02:00:10 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST)
Aug 1 02:00:10 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017
Aug 1 02:00:10 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f
Aug 1 02:00:10 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug 1 02:00:10 kernel: Machine: Northstar Prototype
Aug 1 02:00:10 kernel: Ignoring unrecognised tag 0x00000000
Aug 1 02:00:10 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug 1 02:00:11 kernel: PCI: Fixing up bus 0
Aug 1 02:00:11 kernel: VFS: Disk quotas dquot_6.5.2
Aug 1 02:00:11 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 1 02:00:11 kernel: pflash: found no supported devices
Aug 1 02:00:11 kernel: bcmsflash: squash filesystem found at block 30
Aug 1 02:00:11 kernel: Creating 5 MTD partitions on "bcmsflash":
Aug 1 02:00:11 kernel: 0x000000000000-0x000000040000 : "boot"
Aug 1 02:00:11 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug 1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs"
Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2"
Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram"
Aug 1 02:00:11 kernel: === PPTP init ===
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2adf7004, fsr=0x1c06, pc=0x8016ff34 lr=0x616e6669 ignored.
Aug 1 02:00:12 stop_nat_rules: apply the redirect_rules!
Aug 1 02:00:12 WAN Connection: Fail to connect with some issues.
Aug 1 02:00:17 RT-AC1200G+: start httpd - SSL
Aug 1 02:00:18 hour monitor: daemon is starting
Aug 1 02:00:18 hour monitor: daemon terminates
Aug 1 02:00:18 miniupnpd[463]: version 1.9 started
Aug 1 02:00:18 miniupnpd[463]: HTTP listening on port 48188
Aug 1 02:00:18 miniupnpd[463]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:19 pppd[472]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:00:19 pppd[472]: local IP address 93.138.35.49
Aug 1 02:00:19 pppd[472]: remote IP address 172.29.252.64
Aug 1 02:00:20 rc_service: ip-up 502:notify_rc start_firewall
Aug 1 02:00:20 rc_service: ip-up 502:notify_rc stop_upnp
Aug 1 02:00:28 miniupnpd[463]: shutting down MiniUPnPd
Aug 1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:32 miniupnpd[746]: version 1.9 started
Aug 1 02:00:32 miniupnpd[746]: HTTP listening on port 38934
Aug 1 02:00:32 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:32 rc_service: ip-up 502:notify_rc start_upnp
Aug 1 02:00:35 miniupnpd[752]: version 1.9 started
Aug 1 02:00:35 miniupnpd[752]: HTTP listening on port 34247
Aug 1 02:00:35 miniupnpd[752]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 2 05:01:51 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 2 05:01:52 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 2 05:01:52 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 2 05:01:52 rc_service: ntp 749:notify_rc restart_upnp
Dec 2 05:01:52 miniupnpd[752]: shutting down MiniUPnPd
Dec 2 05:01:53 rc_service: ntp 749:notify_rc restart_diskmon
Dec 2 05:01:53 disk_monitor: Finish
Dec 2 05:01:54 miniupnpd[772]: version 1.9 started
Dec 2 05:01:54 miniupnpd[772]: HTTP listening on port 39930
Dec 2 05:01:54 miniupnpd[772]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 2 05:01:55 disk monitor: be idle
Dec 2 05:01:55 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 2 05:01:56 rc_service: zcip 783:notify_rc start_firewall
Dec 2 05:01:56 zcip client: configured 169.254.163.221
Dec 2 05:01:57 miniupnpd[772]: shutting down MiniUPnPd
Dec 2 05:01:57 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 2 05:01:59 miniupnpd[829]: version 1.9 started
Dec 2 05:01:59 miniupnpd[829]: HTTP listening on port 60719
Dec 2 05:01:59 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 2 23:04:36 disk_monitor: Got SIGALRM...
Dec 2 23:24:42 rc_service: httpds 417:notify_rc start_webs_update
Dec 3 05:00:08 kernel: Emergency Sync complete
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2addf004, fsr=0x1c06, pc=0x2abe2c58 lr=0x17bd8 ignored.
Aug 1 02:00:18 syslog: Generating SSL certificate...
Aug 1 02:00:18 miniupnpd[456]: version 1.9 started
Aug 1 02:00:18 miniupnpd[456]: HTTP listening on port 58051
Aug 1 02:00:18 miniupnpd[456]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:18 pppd[468]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[468]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:00:19 pppd[468]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 pppd[468]: PAP authentication succeeded
Aug 1 02:00:19 pppd[468]: peer from calling number 84:B5:9C:A4:4D:B7 authorized
Aug 1 02:00:19 pppd[468]: local IP address 78.1.145.97
Aug 1 02:00:19 pppd[468]: remote IP address 172.29.252.59
Aug 1 02:00:20 rc_service: ip-up 500:notify_rc stop_upnp
Aug 1 02:00:28 miniupnpd[456]: shutting down MiniUPnPd
Aug 1 02:00:31 miniupnpd[746]: HTTP listening on port 34838
Aug 1 02:00:32 rc_service: ip-up 500:notify_rc start_upnp
Aug 1 02:00:36 miniupnpd[751]: version 1.9 started
Aug 1 02:00:36 miniupnpd[751]: HTTP listening on port 43021
Aug 1 02:00:36 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:38 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 3 05:01:41 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 3 05:01:41 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 3 05:01:41 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 3 05:01:41 rc_service: ntp 749:notify_rc restart_upnp
Dec 3 05:01:41 miniupnpd[751]: shutting down MiniUPnPd
Dec 3 05:01:42 rc_service: ntp 749:notify_rc restart_diskmon
Dec 3 05:01:43 disk_monitor: Finish
Dec 3 05:01:43 miniupnpd[777]: version 1.9 started
Dec 3 05:01:43 miniupnpd[777]: HTTP listening on port 58098
Dec 3 05:01:43 miniupnpd[777]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 3 05:01:46 disk monitor: be idle
Dec 3 05:01:46 rc_service: zcip 779:notify_rc start_firewall
Dec 3 05:01:46 zcip client: configured 169.254.163.221
Dec 3 05:01:48 miniupnpd[777]: shutting down MiniUPnPd
Dec 3 05:01:48 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 3 05:01:51 miniupnpd[821]: version 1.9 started
Dec 3 05:01:51 miniupnpd[821]: HTTP listening on port 38041
Dec 3 05:01:51 miniupnpd[821]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 3 14:38:57 rc_service: httpds 417:notify_rc start_webs_update
Dec 3 16:27:13 rc_service: httpds 417:notify_rc start_webs_update
Dec 3 23:04:15 disk_monitor: Got SIGALRM...
Dec 4 05:00:31 kernel: Emergency Sync complete
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ace0004, fsr=0x1c06, pc=0x2aefa014 lr=0xed80 ignored.
Aug 1 02:00:18 miniupnpd[458]: version 1.9 started
Aug 1 02:00:18 miniupnpd[458]: HTTP listening on port 57289
Aug 1 02:00:18 miniupnpd[458]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:18 pppd[473]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[473]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:19 pppd[473]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:00:19 pppd[473]: local IP address 93.138.65.23
Aug 1 02:00:19 pppd[473]: remote IP address 172.29.252.64
Aug 1 02:00:28 miniupnpd[458]: shutting down MiniUPnPd
Aug 1 02:00:32 miniupnpd[749]: version 1.9 started
Aug 1 02:00:32 miniupnpd[749]: HTTP listening on port 56477
Aug 1 02:00:32 miniupnpd[749]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:32 miniupnpd[749]: shutting down MiniUPnPd
Aug 1 02:00:34 miniupnpd[753]: version 1.9 started
Aug 1 02:00:34 miniupnpd[753]: HTTP listening on port 45468
Aug 1 02:00:34 miniupnpd[753]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 4 05:02:10 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 4 05:02:10 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 4 05:02:10 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 4 05:02:10 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 4 05:02:10 rc_service: ntp 751:notify_rc restart_upnp
Dec 4 05:02:10 miniupnpd[753]: shutting down MiniUPnPd
Dec 4 05:02:11 miniupnpd[777]: version 1.9 started
Dec 4 05:02:11 miniupnpd[777]: HTTP listening on port 34593
Dec 4 05:02:11 miniupnpd[777]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 4 05:02:11 rc_service: ntp 751:notify_rc restart_diskmon
Dec 4 05:02:12 disk_monitor: Finish
Dec 4 05:02:14 disk monitor: be idle
Dec 4 05:02:15 rc_service: zcip 794:notify_rc start_firewall
Dec 4 05:02:15 zcip client: configured 169.254.163.221
Dec 4 05:02:15 miniupnpd[777]: shutting down MiniUPnPd
Dec 4 05:02:15 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 4 05:02:16 miniupnpd[830]: version 1.9 started
Dec 4 05:02:16 miniupnpd[830]: HTTP listening on port 58999
Dec 4 05:02:16 miniupnpd[830]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 4 23:04:47 disk_monitor: Got SIGALRM...
Dec 4 23:48:21 miniupnpd[830]: send(res_buf): Connection reset by peer
Dec 4 23:56:56 rc_service: httpds 417:notify_rc start_webs_update
Dec 4 23:57:13 rc_service: httpds 417:notify_rc start_webs_update
Dec 5 00:24:08 miniupnpd[830]: upnp_event_recv: recv(): Connection reset by peer
Dec 5 00:38:33 miniupnpd[830]: upnp_event_recv: recv(): Connection reset by peer
Dec 5 00:51:09 miniupnpd[830]: upnp_event_recv: recv(): Connection reset by peer
Dec 5 05:00:09 kernel: Emergency Sync complete
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2adef004, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac983b0, fsr=0x1c06, pc=0x7f190b38 lr=0x80208820 ignored.
Aug 1 02:00:18 miniupnpd[459]: HTTP listening on port 34377
Aug 1 02:00:19 pppd[472]: local IP address 93.138.33.193
Aug 1 02:00:20 rc_service: ip-up 505:notify_rc start_firewall
Aug 1 02:00:20 rc_service: ip-up 505:notify_rc stop_upnp
Aug 1 02:00:27 miniupnpd[459]: shutting down MiniUPnPd
Aug 1 02:00:31 miniupnpd[747]: version 1.9 started
Aug 1 02:00:31 miniupnpd[747]: HTTP listening on port 33348
Aug 1 02:00:31 miniupnpd[747]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:31 rc_service: ip-up 505:notify_rc start_upnp
Aug 1 02:00:31 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:00:31 miniupnpd[747]: shutting down MiniUPnPd
Aug 1 02:00:34 miniupnpd[753]: HTTP listening on port 46842
Dec 5 05:01:47 rc_service: ntp 750:notify_rc restart_upnp
Dec 5 05:01:47 miniupnpd[753]: shutting down MiniUPnPd
Dec 5 05:01:47 rc_service: ntp 750:notify_rc restart_diskmon
Dec 5 05:01:48 miniupnpd[767]: version 1.9 started
Dec 5 05:01:48 miniupnpd[767]: HTTP listening on port 34835
Dec 5 05:01:48 miniupnpd[767]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 5 05:01:48 disk_monitor: Finish
Dec 5 05:01:49 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 5 05:01:49 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 5 05:01:49 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 5 05:01:50 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 5 05:01:50 syslog: Generating SSL certificate...
Dec 5 05:01:51 disk monitor: be idle
Dec 5 05:01:51 syslog: Generating SSL certificate...
Dec 5 05:01:54 rc_service: zcip 817:notify_rc start_firewall
Dec 5 05:01:54 zcip client: configured 169.254.163.221
Dec 5 05:01:55 miniupnpd[767]: shutting down MiniUPnPd
Dec 5 05:01:55 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 5 05:01:57 miniupnpd[845]: version 1.9 started
Dec 5 05:01:57 miniupnpd[845]: HTTP listening on port 35000
Dec 5 05:01:57 miniupnpd[845]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 5 17:13:06 rc_service: httpds 417:notify_rc start_webs_update
Dec 5 17:19:06 rc_service: httpds 417:notify_rc restart_firewall;restart_qos
Dec 5 17:19:07 miniupnpd[845]: shutting down MiniUPnPd
Dec 5 17:19:07 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 5 17:19:08 miniupnpd[11742]: version 1.9 started
Dec 5 17:19:08 miniupnpd[11742]: HTTP listening on port 59119
Dec 5 17:19:08 miniupnpd[11742]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 5 17:19:09 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 5 17:19:09 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 5 17:19:09 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 5 17:19:09 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 5 17:19:09 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec 5 17:19:13 rc_service: httpds 417:notify_rc restart_firewall;restart_qos
Dec 5 17:19:14 miniupnpd[11742]: shutting down MiniUPnPd
Dec 5 17:19:14 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 5 17:19:17 miniupnpd[11825]: version 1.9 started
Dec 5 17:19:17 miniupnpd[11825]: HTTP listening on port 36609
Dec 5 17:19:17 miniupnpd[11825]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 5 17:19:17 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 5 17:19:17 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 5 17:19:17 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 5 17:19:17 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 5 17:19:18 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec 5 17:27:34 rc_service: httpds 417:notify_rc restart_firewall;restart_qos
Dec 5 17:27:35 miniupnpd[11825]: shutting down MiniUPnPd
Dec 5 17:27:35 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 5 17:27:37 miniupnpd[12024]: version 1.9 started
Dec 5 17:27:37 miniupnpd[12024]: HTTP listening on port 50107
Dec 5 17:27:37 miniupnpd[12024]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 5 17:27:38 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 5 17:27:38 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 5 17:27:38 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 5 17:27:38 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 5 17:27:38 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec 5 17:38:51 rc_service: httpds 417:notify_rc start_webs_update
Dec 5 23:04:12 disk_monitor: Got SIGALRM...
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae3c000, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ad133b0, fsr=0x1c06, pc=0x7f190b38 lr=0x80208820 ignored.
Aug 1 02:00:18 miniupnpd[464]: HTTP listening on port 40151
Aug 1 02:00:41 rc_service: zcip 659:notify_rc start_firewall
Aug 1 02:00:41 zcip client: configured 169.254.163.221
Aug 1 02:00:42 miniupnpd[464]: shutting down MiniUPnPd
Aug 1 02:00:42 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)!
Aug 1 02:00:43 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:43 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:44 miniupnpd[715]: version 1.9 started
Aug 1 02:00:44 miniupnpd[715]: HTTP listening on port 51086
Aug 1 02:00:44 miniupnpd[715]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:47 stop_nat_rules: apply the redirect_rules!
Aug 1 02:00:49 pppd[472]: No response to PAP authenticate-requests
Aug 1 02:00:49 pppd[472]: Connection terminated.
Aug 1 02:00:59 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:59 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:00 pppd[472]: PAP authentication succeeded
Aug 1 02:01:00 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:01:00 pppd[472]: local IP address 93.138.14.31
Aug 1 02:01:00 pppd[472]: remote IP address 172.29.252.64
Aug 1 02:01:01 rc_service: ip-up 742:notify_rc start_firewall
Aug 1 02:01:02 miniupnpd[715]: shutting down MiniUPnPd
Aug 1 02:01:02 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:01:02 rc_service: ip-up 742:notify_rc stop_upnp
Aug 1 02:01:02 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:01:03 WAN Connection: WAN was restored.
Aug 1 02:01:03 miniupnpd[806]: version 1.9 started
Aug 1 02:01:03 miniupnpd[806]: HTTP listening on port 56297
Aug 1 02:01:03 miniupnpd[806]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:03 rc_service: ip-up 742:notify_rc start_upnp
Aug 1 02:01:03 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:01:03 miniupnpd[806]: shutting down MiniUPnPd
Aug 1 02:01:05 miniupnpd[810]: version 1.9 started
Aug 1 02:01:05 miniupnpd[810]: HTTP listening on port 48458
Aug 1 02:01:05 miniupnpd[810]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:06 ntp: start NTP update
Dec 6 05:02:21 rc_service: ntp 808:notify_rc restart_upnp
Dec 6 05:02:21 miniupnpd[810]: shutting down MiniUPnPd
Dec 6 05:02:22 miniupnpd[818]: version 1.9 started
Dec 6 05:02:22 miniupnpd[818]: HTTP listening on port 39117
Dec 6 05:02:22 miniupnpd[818]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 6 05:02:22 rc_service: ntp 808:notify_rc restart_diskmon
Dec 6 05:02:22 disk_monitor: Finish
Dec 6 05:02:23 disk monitor: be idle
Dec 6 05:02:23 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 6 05:02:23 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 6 05:02:23 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 6 05:02:23 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 6 05:02:23 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec 6 23:05:05 disk_monitor: Got SIGALRM...
Dec 7 05:00:09 kernel: Emergency Sync complete
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae82000, fsr=0x1c06, pc=0x80171f68 lr=0x800cc4c4 ignored.
Aug 1 02:00:18 miniupnpd[464]: HTTP listening on port 48188
Aug 1 02:00:19 pppd[472]: local IP address 93.139.184.227
Aug 1 02:00:19 pppd[472]: remote IP address 172.29.252.89
Aug 1 02:00:19 rc_service: ip-up 502:notify_rc start_firewall
Aug 1 02:00:31 miniupnpd[746]: HTTP listening on port 47285
Aug 1 02:00:31 rc_service: ip-up 502:notify_rc start_upnp
Aug 1 02:00:31 miniupnpd[746]: shutting down MiniUPnPd
Aug 1 02:00:33 miniupnpd[751]: version 1.9 started
Aug 1 02:00:33 miniupnpd[751]: HTTP listening on port 41997
Aug 1 02:00:33 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:35 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Aug 1 02:00:36 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 7 05:01:38 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 7 05:01:38 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec 7 05:01:38 rc_service: ntp 749:notify_rc restart_upnp
Dec 7 05:01:38 miniupnpd[751]: shutting down MiniUPnPd
Dec 7 05:01:39 rc_service: ntp 749:notify_rc restart_diskmon
Dec 7 05:01:39 miniupnpd[781]: version 1.9 started
Dec 7 05:01:39 miniupnpd[781]: HTTP listening on port 53280
Dec 7 05:01:39 miniupnpd[781]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 7 05:01:40 disk_monitor: Finish
Dec 7 05:01:42 disk monitor: be idle
Dec 7 05:01:43 rc_service: zcip 790:notify_rc start_firewall
Dec 7 05:01:43 zcip client: configured 169.254.163.221
Dec 7 05:01:45 miniupnpd[781]: shutting down MiniUPnPd
Dec 7 05:01:45 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 7 05:01:48 miniupnpd[831]: version 1.9 started
Dec 7 05:01:48 miniupnpd[831]: HTTP listening on port 37489
Dec 7 05:01:48 miniupnpd[831]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 7 11:46:32 kernel: wl1: PHYTX error
Dec 7 11:46:33 kernel: wl1: PHYTX error
Dec 7 17:38:38 rc_service: httpds 417:notify_rc start_webs_update
Dec 7 17:38:56 rc_service: httpds 417:notify_rc restart_firewall;restart_qos
Dec 7 17:38:57 miniupnpd[831]: shutting down MiniUPnPd
Dec 7 17:38:57 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 7 17:38:58 miniupnpd[11999]: version 1.9 started
Dec 7 17:38:58 miniupnpd[11999]: HTTP listening on port 54246
Dec 7 17:38:58 miniupnpd[11999]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 7 17:38:59 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 7 17:38:59 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 7 17:38:59 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 7 17:38:59 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 7 23:04:25 disk_monitor: Got SIGALRM...
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae13000, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac803b0, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored.
Aug 1 02:00:18 miniupnpd[458]: HTTP listening on port 38078
Aug 1 02:00:18 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:00:18 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 pppd[472]: local IP address 93.139.145.162
Aug 1 02:00:19 rc_service: ip-up 500:notify_rc start_firewall
Aug 1 02:00:27 miniupnpd[458]: shutting down MiniUPnPd
Aug 1 02:00:32 miniupnpd[755]: version 1.9 started
Aug 1 02:00:32 miniupnpd[755]: HTTP listening on port 41125
Aug 1 02:00:32 miniupnpd[755]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:32 miniupnpd[755]: shutting down MiniUPnPd
Aug 1 02:00:34 miniupnpd[759]: version 1.9 started
Aug 1 02:00:34 miniupnpd[759]: HTTP listening on port 34872
Aug 1 02:00:34 miniupnpd[759]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:36 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 8 05:01:57 rc_service: ntp 757:notify_rc restart_upnp
Dec 8 05:01:57 miniupnpd[759]: shutting down MiniUPnPd
Dec 8 05:01:57 miniupnpd[789]: version 1.9 started
Dec 8 05:01:57 miniupnpd[789]: HTTP listening on port 39839
Dec 8 05:01:57 miniupnpd[789]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 8 05:01:58 rc_service: ntp 757:notify_rc restart_diskmon
Dec 8 05:01:58 disk_monitor: Finish
Dec 8 05:01:58 disk monitor: be idle
Dec 8 05:02:02 rc_service: zcip 801:notify_rc start_firewall
Dec 8 05:02:02 zcip client: configured 169.254.163.221
Dec 8 05:02:02 miniupnpd[789]: shutting down MiniUPnPd
Dec 8 05:02:02 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 8 05:02:03 miniupnpd[829]: version 1.9 started
Dec 8 05:02:03 miniupnpd[829]: HTTP listening on port 54681
Dec 8 05:02:03 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae70004, fsr=0x1c06, pc=0x2ac34c58 lr=0x17bd8 ignored.
Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1403)
Aug 1 02:00:11 kernel: <0>Kernel panic - not syncing: Out of memory: system-wide panic_on_oom is enabled
Aug 1 02:00:11 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<802fec2c>] (panic+0x7c/0x1a4)
Aug 1 02:00:11 kernel: <4>[<802fec2c>] (panic+0x7c/0x1a4) from [<80091038>] (out_of_memory+0x2c8/0x328)
Aug 1 02:00:11 kernel: <4>[<80091038>] (out_of_memory+0x2c8/0x328) from [<800942c0>] (__alloc_pages_nodemask+0x66c/0x694)
Aug 1 02:00:11 kernel: <4>[<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) from [<80096000>] (__do_page_cache_readahead+0x140/0x2d0)
Aug 1 02:00:11 kernel: <4>[<80096000>] (__do_page_cache_readahead+0x140/0x2d0) from [<80096440>] (ra_submit+0x28/0x30)
Aug 1 02:00:11 kernel: <4>[<80096440>] (ra_submit+0x28/0x30) from [<8008e5d0>] (filemap_fault+0x42c/0x454)
Aug 1 02:00:11 kernel: <4>[<8008e5d0>] (filemap_fault+0x42c/0x454) from [<800a315c>] (__do_fault.clone.60+0x54/0x4c8)
Aug 1 02:00:11 kernel: <4>[<800a315c>] (__do_fault.clone.60+0x54/0x4c8) from [<800a67c4>] (handle_mm_fault+0x114/0x934)
Aug 1 02:00:11 kernel: <4>[<800a67c4>] (handle_mm_fault+0x114/0x934) from [<8003fd90>] (do_page_fault+0x178/0x1ec)
Aug 1 02:00:11 kernel: <4>[<8003fd90>] (do_page_fault+0x178/0x1ec) from [<80038298>] (do_PrefetchAbort+0x30/0x9c)
Aug 1 02:00:11 kernel: <4>[<80038298>] (do_PrefetchAbort+0x30/0x9c) from [<803bf2e0>] (ret_from_exception+0x0/0x10)
Aug 1 02:00:11 kernel: <4>Exception stack(0x849fffb0 to 0x849ffff8)
Aug 1 02:00:11 kernel: <4>ffa0: 00000001 7ea52ca0 7ea52c20 00000000
Aug 1 02:00:11 kernel: <4>ffc0: 7ea52da8 7ea52c20 0000000a 0000008e 00000007 7ea52c20 00027078 00000001
Aug 1 02:00:11 kernel: <4>ffe0: 000258c4 7ea52768 0000b318 2ab764cc 60000010 ffffffff
Aug 1 02:00:11 kernel: <0>Rebooting in 3 seconds..
Aug 1 02:00:18 miniupnpd[465]: version 1.9 started
Aug 1 02:00:18 miniupnpd[465]: HTTP listening on port 35710
Aug 1 02:00:18 miniupnpd[465]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:21 pppd[472]: PAP authentication failed
Aug 1 02:00:28 pppd[472]: Connection terminated.
Aug 1 02:00:28 pppd[472]: Modem hangup
Aug 1 02:00:38 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:38 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:41 rc_service: zcip 674:notify_rc start_firewall
Aug 1 02:00:41 pppd[472]: PAP authentication failed
Aug 1 02:00:42 miniupnpd[465]: shutting down MiniUPnPd
Aug 1 02:00:44 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:44 miniupnpd[731]: version 1.9 started
Aug 1 02:00:44 miniupnpd[731]: HTTP listening on port 46554
Aug 1 02:00:44 miniupnpd[731]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:46 stop_nat_rules: apply the redirect_rules!
Aug 1 02:00:48 pppd[472]: Connection terminated.
Aug 1 02:00:48 pppd[472]: Modem hangup
Aug 1 02:00:59 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:01:01 pppd[472]: PAP authentication failed
Aug 1 02:01:01 pppd[472]: Connection terminated.
Aug 1 02:01:12 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:12 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:14 pppd[472]: PAP authentication failed
Aug 1 02:01:14 pppd[472]: Connection terminated.
Aug 1 02:01:25 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:25 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:27 pppd[472]: PAP authentication failed
Aug 1 02:01:27 pppd[472]: Connection terminated.
Aug 1 02:01:38 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:38 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:38 pppd[472]: PAP authentication succeeded
Aug 1 02:01:38 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:01:39 pppd[472]: local IP address 93.138.5.224
Aug 1 02:01:39 pppd[472]: remote IP address 172.29.252.64
Aug 1 02:01:39 rc_service: ip-up 805:notify_rc start_firewall
Aug 1 02:01:40 miniupnpd[731]: shutting down MiniUPnPd
Aug 1 02:01:40 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:01:40 rc_service: ip-up 805:notify_rc stop_upnp
Aug 1 02:01:40 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:01:40 WAN Connection: WAN was restored.
Aug 1 02:01:41 miniupnpd[865]: version 1.9 started
Aug 1 02:01:41 miniupnpd[865]: HTTP listening on port 54744
Aug 1 02:01:41 miniupnpd[865]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:41 rc_service: ip-up 805:notify_rc start_upnp
Aug 1 02:01:41 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:01:41 miniupnpd[865]: shutting down MiniUPnPd
Aug 1 02:01:42 miniupnpd[868]: version 1.9 started
Aug 1 02:01:42 miniupnpd[868]: HTTP listening on port 37727
Aug 1 02:01:42 miniupnpd[868]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:43 ntp: start NTP update
Dec 8 22:53:22 rc_service: ntp 867:notify_rc restart_upnp
Dec 8 22:53:22 miniupnpd[868]: shutting down MiniUPnPd
Dec 8 22:53:23 miniupnpd[878]: version 1.9 started
Dec 8 22:53:23 miniupnpd[878]: HTTP listening on port 48606
Dec 8 22:53:23 miniupnpd[878]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 8 22:53:23 rc_service: ntp 867:notify_rc restart_diskmon
Dec 8 22:53:23 disk_monitor: Finish
Dec 8 22:53:24 disk monitor: be idle
Dec 8 22:53:24 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 8 22:53:24 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 8 22:53:24 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 8 22:53:24 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 8 22:54:06 rc_service: httpd 418:notify_rc start_webs_update
Dec 8 23:00:25 disk_monitor: Got SIGALRM...
Aug 1 02:00:10 kernel: * Invalid signature of oopsbuf: 37-F3-57-77-B5-75-56-55 (len 4283905917)
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae31004, fsr=0x1c06, pc=0x2abffbe8 lr=0x2ac00c7c ignored.
Aug 1 02:00:18 miniupnpd[461]: version 1.9 started
Aug 1 02:00:18 miniupnpd[461]: HTTP listening on port 48173
Aug 1 02:00:18 miniupnpd[461]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:20 syslog: module ledtrig-usbdev not found in modules.dep
Aug 1 02:00:42 rc_service: zcip 654:notify_rc start_firewall
Aug 1 02:00:42 zcip client: configured 169.254.163.221
Aug 1 02:00:42 miniupnpd[461]: shutting down MiniUPnPd
Aug 1 02:00:44 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:44 miniupnpd[710]: version 1.9 started
Aug 1 02:00:44 miniupnpd[710]: HTTP listening on port 52585
Aug 1 02:00:44 miniupnpd[710]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:54 pppd[472]: Timeout waiting for PADO packets
Aug 1 02:02:09 pppd[472]: Timeout waiting for PADO packets
Aug 1 02:02:09 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:02:09 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:02:39 pppd[472]: PAP authentication succeeded
Aug 1 02:02:39 pppd[472]: peer from calling number 00:90:1A:A3:B7:70 authorized
Aug 1 02:02:40 pppd[472]: local IP address 93.142.212.104
Aug 1 02:02:40 pppd[472]: remote IP address 172.29.252.90
Aug 1 02:02:40 rc_service: ip-up 733:notify_rc start_firewall
Aug 1 02:02:41 miniupnpd[710]: shutting down MiniUPnPd
Aug 1 02:02:41 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:02:41 rc_service: ip-up 733:notify_rc stop_upnp
Aug 1 02:02:41 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:02:42 miniupnpd[792]: version 1.9 started
Aug 1 02:02:42 miniupnpd[792]: HTTP listening on port 44126
Aug 1 02:02:42 miniupnpd[792]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:02:42 rc_service: ip-up 733:notify_rc start_upnp
Aug 1 02:02:42 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:02:42 miniupnpd[792]: shutting down MiniUPnPd
Aug 1 02:02:43 miniupnpd[794]: version 1.9 started
Aug 1 02:02:43 miniupnpd[794]: HTTP listening on port 40806
Aug 1 02:02:43 miniupnpd[794]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:02:44 WAN Connection: WAN was restored.
Aug 1 02:02:44 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Aug 1 02:02:44 ntp: start NTP update
Aug 1 02:02:44 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Aug 1 02:02:44 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Aug 1 02:02:44 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 9 09:37:03 rc_service: ntp 795:notify_rc restart_upnp
Dec 9 09:37:03 miniupnpd[794]: shutting down MiniUPnPd
Dec 9 09:37:04 miniupnpd[824]: version 1.9 started
Dec 9 09:37:04 miniupnpd[824]: HTTP listening on port 48536
Dec 9 09:37:04 miniupnpd[824]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 9 09:37:04 rc_service: ntp 795:notify_rc restart_diskmon
Dec 9 09:37:04 disk_monitor: Finish
Dec 9 09:37:05 disk monitor: be idle
Dec 9 09:47:53 pppd[472]: Serial link appears to be disconnected.
Dec 9 09:47:54 WAN Connection: Fail to connect with some issues.
Dec 9 09:47:54 stop_nat_rules: apply the redirect_rules!
Dec 9 09:47:59 pppd[472]: Connection terminated.
Dec 9 09:47:59 pppd[472]: Modem hangup
Dec 9 09:48:09 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Dec 9 09:48:09 pppd[472]: Connect: ppp0 <--> eth0
Dec 9 09:48:13 pppd[472]: PAP authentication failed
Dec 9 09:48:13 pppd[472]: Connection terminated.
Dec 9 09:48:23 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Dec 9 09:48:23 pppd[472]: Connect: ppp0 <--> eth0
Dec 9 09:48:26 pppd[472]: PAP authentication failed
Dec 9 09:48:26 pppd[472]: Connection terminated.
Dec 9 09:48:36 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Dec 9 09:48:36 pppd[472]: Connect: ppp0 <--> eth0
Dec 9 09:48:39 pppd[472]: PAP authentication failed
Dec 9 09:48:39 pppd[472]: Connection terminated.
Dec 9 09:48:49 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Dec 9 09:48:49 pppd[472]: Connect: ppp0 <--> eth0
Dec 9 09:49:17 rc_service: httpds 417:notify_rc start_webs_update
Dec 9 09:49:19 pppd[472]: No response to PAP authenticate-requests
Dec 9 09:49:20 pppd[472]: Connection terminated.
Dec 9 09:49:30 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Dec 9 09:49:30 pppd[472]: Connect: ppp0 <--> eth0
Dec 9 09:49:54 rc_service: httpds 417:notify_rc start_webs_update
Dec 9 09:50:00 pppd[472]: PAP authentication succeeded
Dec 9 09:50:00 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized
Dec 9 09:50:01 pppd[472]: local IP address 93.139.178.251
Dec 9 09:50:01 pppd[472]: remote IP address 172.29.252.89
Dec 9 09:50:01 rc_service: ip-up 1308:notify_rc start_firewall
Dec 9 09:50:02 miniupnpd[824]: shutting down MiniUPnPd
Dec 9 09:50:02 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 9 09:50:02 rc_service: httpds 417:notify_rc reboot
Dec 9 09:50:02 rc_service: waitting "start_firewall" via ip-up ...
Dec 9 09:50:02 rc_service: ip-up 1308:notify_rc stop_upnp
Dec 9 09:50:03 miniupnpd[1352]: version 1.9 started
Dec 9 09:50:03 miniupnpd[1352]: HTTP listening on port 58937
Dec 9 09:50:03 miniupnpd[1352]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 9 09:50:04 pppd[472]: Connection terminated.
Dec 9 09:50:05 kernel: Attempt to kill tasklet from interrupt
Dec 9 09:50:05 stop_nat_rules: apply the redirect_rules!
Dec 9 09:50:06 iTunes: daemon is stoped
Dec 9 09:50:06 FTP Server: daemon is stoped
Dec 9 09:50:06 Samba Server: smb daemon is stoped
Dec 9 09:50:06 kernel: gro disabled
Aug 1 02:00:09 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem
Aug 1 02:00:09 kernel: Virtual kernel memory layout:
Aug 1 02:00:09 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Aug 1 02:00:09 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Aug 1 02:00:09 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Aug 1 02:00:09 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB)
Aug 1 02:00:09 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB)
Aug 1 02:00:09 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB)
Aug 1 02:00:09 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB)
Aug 1 02:00:09 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB)
Aug 1 02:00:09 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB)
Aug 1 02:00:10 kernel: Registering the dns_resolver key type
Aug 1 02:00:10 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2adf4004, fsr=0x1c06, pc=0x800ce0e0 lr=0x800c1154 ignored.
Aug 1 02:00:18 miniupnpd[457]: version 1.9 started
Aug 1 02:00:18 miniupnpd[457]: HTTP listening on port 36504
Aug 1 02:00:18 miniupnpd[457]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:18 pppd[466]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[466]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:00:19 pppd[466]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 pppd[466]: PAP authentication succeeded
Aug 1 02:00:19 pppd[466]: peer from calling number 84:B5:9C:A4:4D:B7 authorized
Aug 1 02:00:19 pppd[466]: local IP address 93.141.119.37
Aug 1 02:00:19 pppd[466]: remote IP address 172.29.252.59
Aug 1 02:00:20 rc_service: ip-up 509:notify_rc start_firewall
Aug 1 02:00:20 rc_service: ip-up 509:notify_rc stop_upnp
Aug 1 02:00:26 miniupnpd[457]: shutting down MiniUPnPd
Aug 1 02:00:26 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:00:28 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:29 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:29 miniupnpd[750]: version 1.9 started
Aug 1 02:00:29 miniupnpd[750]: HTTP listening on port 56881
Aug 1 02:00:29 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:29 rc_service: ip-up 509:notify_rc start_upnp
Aug 1 02:00:29 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:00:29 miniupnpd[750]: shutting down MiniUPnPd
Aug 1 02:00:31 miniupnpd[753]: version 1.9 started
Aug 1 02:00:31 miniupnpd[753]: HTTP listening on port 38145
Aug 1 02:00:31 miniupnpd[753]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:32 ntp: start NTP update
Dec 9 09:51:26 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 9 09:51:26 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 9 09:51:26 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 9 09:51:26 rc_service: ntp 752:notify_rc restart_upnp
Dec 9 09:51:26 miniupnpd[753]: shutting down MiniUPnPd
Dec 9 09:51:27 miniupnpd[775]: version 1.9 started
Dec 9 09:51:27 miniupnpd[775]: HTTP listening on port 55434
Dec 9 09:51:27 miniupnpd[775]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 9 09:51:27 rc_service: ntp 752:notify_rc restart_diskmon
Dec 9 09:51:27 disk_monitor: Finish
Dec 9 09:51:28 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 9 09:51:29 disk monitor: be idle
Dec 9 09:51:34 rc_service: zcip 801:notify_rc start_firewall
Dec 9 09:51:34 zcip client: configured 169.254.163.221
Dec 9 09:51:34 miniupnpd[775]: shutting down MiniUPnPd
Dec 9 09:51:34 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 9 09:51:35 miniupnpd[829]: version 1.9 started
Dec 9 09:51:35 miniupnpd[829]: HTTP listening on port 52933
Dec 9 09:51:35 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 9 10:00:30 disk_monitor: Got SIGALRM...
Dec 9 23:02:13 disk_monitor: Got SIGALRM...
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae35004, fsr=0x1c06, pc=0x2abb0be8 lr=0x2abb1c7c ignored.
Aug 1 02:00:18 miniupnpd[465]: HTTP listening on port 52007
Aug 1 02:00:18 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:19 pppd[472]: local IP address 93.138.84.144
Aug 1 02:00:29 miniupnpd[465]: shutting down MiniUPnPd
Aug 1 02:00:29 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:00:32 miniupnpd[750]: version 1.9 started
Aug 1 02:00:32 miniupnpd[750]: HTTP listening on port 42798
Aug 1 02:00:32 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:35 miniupnpd[755]: HTTP listening on port 48602
Dec 10 05:01:57 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 10 05:01:57 rc_service: ntp 753:notify_rc restart_upnp
Dec 10 05:01:57 miniupnpd[755]: shutting down MiniUPnPd
Dec 10 05:01:57 miniupnpd[772]: version 1.9 started
Dec 10 05:01:57 miniupnpd[772]: HTTP listening on port 55124
Dec 10 05:01:57 miniupnpd[772]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 10 05:01:57 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 10 05:01:58 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 10 05:01:58 rc_service: ntp 753:notify_rc restart_diskmon
Dec 10 05:01:58 disk_monitor: Finish
Dec 10 05:01:58 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 10 05:02:00 disk monitor: be idle
Dec 10 05:02:01 rc_service: zcip 788:notify_rc start_firewall
Dec 10 05:02:01 zcip client: configured 169.254.163.221
Dec 10 05:02:03 miniupnpd[772]: shutting down MiniUPnPd
Dec 10 05:02:03 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 10 05:02:04 miniupnpd[825]: version 1.9 started
Dec 10 05:02:04 miniupnpd[825]: HTTP listening on port 48968
Dec 10 05:02:04 miniupnpd[825]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:11 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Aug 1 02:00:11 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug 1 02:00:11 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem
Aug 1 02:00:11 kernel: Virtual kernel memory layout:
Aug 1 02:00:11 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Aug 1 02:00:11 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Aug 1 02:00:11 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Aug 1 02:00:11 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB)
Aug 1 02:00:11 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB)
Aug 1 02:00:11 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB)
Aug 1 02:00:11 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB)
Aug 1 02:00:11 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB)
Aug 1 02:00:11 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB)
Aug 1 02:00:11 kernel: Mount-cache hash table entries: 512
Aug 1 02:00:11 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB
Aug 1 02:00:11 kernel: ACP (Accelerator Coherence Port) enabled
Aug 1 02:00:11 kernel: bio: create slab at 0
Aug 1 02:00:12 kernel: PCI: no core
Aug 1 02:00:12 kernel: PCI: Fixing up bus 0
Aug 1 02:00:12 kernel: PCI: Fixing up bus 1
Aug 1 02:00:12 kernel: PCI: scanning bus 0 !!!
Aug 1 02:00:12 kernel: VFS: Disk quotas dquot_6.5.2
Aug 1 02:00:12 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 1 02:00:12 kernel: pflash: found no supported devices
Aug 1 02:00:12 kernel: bcmsflash: squash filesystem found at block 30
Aug 1 02:00:12 kernel: Creating 5 MTD partitions on "bcmsflash":
Aug 1 02:00:12 kernel: 0x000000000000-0x000000040000 : "boot"
Aug 1 02:00:12 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug 1 02:00:12 kernel: 0x0000001ef614-0x000000d30000 : "rootfs"
Aug 1 02:00:12 kernel: 0x000000d30000-0x000000ff0000 : "jffs2"
Aug 1 02:00:12 kernel: 0x000000ff0000-0x000001000000 : "nvram"
Aug 1 02:00:12 kernel: === PPTP init ===
Aug 1 02:00:12 kernel: Registering the dns_resolver key type
Aug 1 02:00:12 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Aug 1 02:00:12 kernel: ctf: module license 'Proprietary' taints kernel.
Aug 1 02:00:12 kernel: Disabling lock debugging due to kernel taint
Aug 1 02:00:12 kernel: et_module_init: passivemode set to 0x0
Aug 1 02:00:12 kernel: et_module_init: txworkq set to 0x1
Aug 1 02:00:12 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug 1 02:00:12 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8
Aug 1 02:00:12 kernel: et_module_init: et_rxlazy_framecnt set to 0x20
Aug 1 02:00:12 kernel: bcm_robo_enable_switch: EEE is disabled
Aug 1 02:00:12 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393)
Aug 1 02:00:12 kernel: wl_module_init: passivemode set to 0x0
Aug 1 02:00:12 kernel: wl_module_init: txworkq set to 0x1
Aug 1 02:00:12 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
Aug 1 02:00:12 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 02:00:12 kernel: External imprecise Data abort at addr=0x2ae99000, fsr=0x1c06, pc=0x800c2aec lr=0x800ce1c8 ignored.
Aug 1 02:00:12 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 02:00:12 kernel: [dump prev ops] from 87000000, local len(8179)
Aug 1 02:00:12 kernel: _ Reboot message ... _______________________________________________________
Aug 1 02:00:12 kernel: <0>Kernel panic - not syncing: Out of memory: system-wide panic_on_oom is enabled
Aug 1 02:00:12 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<802fec2c>] (panic+0x7c/0x1a4)
Aug 1 02:00:12 kernel: <4>[<802fec2c>] (panic+0x7c/0x1a4) from [<80091038>] (out_of_memory+0x2c8/0x328)
Aug 1 02:00:12 kernel: <4>[<80091038>] (out_of_memory+0x2c8/0x328) from [<800942c0>] (__alloc_pages_nodemask+0x66c/0x694)
Aug 1 02:00:12 kernel: <4>[<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) from [<80096000>] (__do_page_cache_readahead+0x140/0x2d0)
Aug 1 02:00:12 kernel: <4>[<80096000>] (__do_page_cache_readahead+0x140/0x2d0) from [<80096440>] (ra_submit+0x28/0x30)
Aug 1 02:00:12 kernel: <4>[<80096440>] (ra_submit+0x28/0x30) from [<8008e5d0>] (filemap_fault+0x42c/0x454)
Aug 1 02:00:12 kernel: <4>[<8008e5d0>] (filemap_fault+0x42c/0x454) from [<800a315c>] (__do_fault.clone.60+0x54/0x4c8)
Aug 1 02:00:12 kernel: <4>[<800a315c>] (__do_fault.clone.60+0x54/0x4c8) from [<800a67c4>] (handle_mm_fault+0x114/0x934)
Aug 1 02:00:12 kernel: <4>[<800a67c4>] (handle_mm_fault+0x114/0x934) from [<8003fd90>] (do_page_fault+0x178/0x1ec)
Aug 1 02:00:13 kernel: <4>[<8003fd90>] (do_page_fault+0x178/0x1ec) from [<80038298>] (do_PrefetchAbort+0x30/0x9c)
Aug 1 02:00:13 kernel: <4>[<80038298>] (do_PrefetchAbort+0x30/0x9c) from [<803bf2e0>] (ret_from_exception+0x0/0x10)
Aug 1 02:00:13 kernel: <4>Exception stack(0x8534ffb0 to 0x8534fff8)
Aug 1 02:00:13 kernel: <4>ffa0: 0000000e 00000008 7eae7c48 00000000
Aug 1 02:00:13 kernel: <4>ffc0: 7eae7c48 00000001 7eae7e94 000000b3 0000d1f0 0000ec14 7eae7e08 00000000
Aug 1 02:00:13 kernel: <4>ffe0: 2aef35b4 7eae7948 2ae9b254 0003be5c 00000010 ffffffff
Aug 1 02:00:13 kernel: <0>Rebooting in 3 seconds..osl_ctfpool_add: skb alloc of len 2272 failed
Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed
Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed
Aug 1 02:00:13 kernel: <4>__alloc_pages_slowpath: 54706 callbacks suppressed
Aug 1 02:00:13 kernel: <4>watchdog: page allocation failure. order:0, mode:0x4020
Aug 1 02:00:13 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694)
Aug 1 02:00:13 kernel: <4>[<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0)
Aug 1 02:00:13 kernel: <4>[<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8)
Aug 1 02:00:13 kernel: <4>[<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104)
Aug 1 02:00:13 kernel: <4>[<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac)
Aug 1 02:00:13 kernel: <4>[<801fc860>] (osl_alloc_skb+0x50/0xac) from [<803c2cc0>] (osl_pktget+0x6c/0x170)
Aug 1 02:00:13 kernel: <4>[<803c2cc0>] (osl_pktget+0x6c/0x170) from [<803c1a34>] (_dma_rxfill+0x3c8/0x51c)
Aug 1 02:00:13 kernel: <4>[<803c1a34>] (_dma_rxfill+0x3c8/0x51c) from [<7f289fc0>] (wlc_bmac_recv+0x368/0x380 [wl])
Aug 1 02:00:13 kernel: <4>unwind: Index not found 7f289fc0
Aug 1 02:00:13 kernel: <4>Mem-info:
Aug 1 02:00:13 kernel: <4>DMA per-cpu:
Aug 1 02:00:13 kernel: <4>CPU 0: hi: 42, btch: 7 usd: 6
Aug 1 02:00:13 kernel: <4>active_anon:941 inactive_anon:953 isolated_anon:0
Aug 1 02:00:13 kernel: <4> active_file:0 inactive_file:0 isolated_file:32
Aug 1 02:00:13 kernel: <4> unevictable:0 dirty:0 writeback:0 unstable:0
Aug 1 02:00:13 kernel: <4> free:383 slab_reclaimable:82 slab_unreclaimable:25949
Aug 1 02:00:13 kernel: <4> mapped:16 shmem:172 pagetables:151 bounce:0
Aug 1 02:00:13 kernel: <4>DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:3764kB inactive_anon:3812kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):128kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:64kB shmem:688kB slab_reclaimable:328kB slab_unreclaimable:103796kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Aug 1 02:00:13 kernel: <4>lowmem_reserve[]: 0 0 0
Aug 1 02:00:13 kernel: <4>DMA: 111*4kB 52*8kB 28*16kB 1*32kB 1*64kB 1*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 1532kB
Aug 1 02:00:13 kernel: <4>185 total pagecache pages
Aug 1 02:00:13 kernel: <4>0 pages in swap cache
Aug 1 02:00:13 kernel: <4>Swap cache stats: add 0, delete 0, find 0/0
Aug 1 02:00:13 kernel: <4>Free swap = 0kB
Aug 1 02:00:13 kernel: <4>Total swap = 0kB
Aug 1 02:00:13 kernel: <4>32768 pages of RAM
Aug 1 02:00:13 kernel: <4>571 free pages
Aug 1 02:00:13 kernel: <4>1352 reserved pages
Aug 1 02:00:13 kernel: <4>8182 slab pages
Aug 1 02:00:13 kernel: <4>266 pages shared
Aug 1 02:00:13 kernel: <4>0 pages swap cached
Aug 1 02:00:13 kernel: <4>SLUB: Unable to allocate memory on node -1 (gfp=0x20)
Aug 1 02:00:13 kernel: <4> cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0
Aug 1 02:00:13 kernel: <4> node 0: slabs: 3297, objs: 20972, free: 0
Aug 1 02:00:13 kernel: <4>[<803b28d0>] (__alloc_skb+0x54/0x104) from [<802179c0>] (pskb_copy+0x20/0x184)
Aug 1 02:00:13 kernel: <4>[<802179c0>] (pskb_copy+0x20/0x184) from [<801fcbc4>] (osl_pktdup+0x68/0x134)
Aug 1 02:00:13 kernel: <4>[<801fcbc4>] (osl_pktdup+0x68/0x134) from [<7f28edf4>] (wlc_recvdata_sendup+0x714/0x768 [wl])
Aug 1 02:00:13 kernel: <4>unwind: Index not found 7f28edf4
Aug 1 02:00:13 kernel: ____________________________________________________________________________
Aug 1 02:00:18 disk monitor: be idle
Aug 1 02:00:18 jffs2: valid logs(1)
Aug 1 02:00:18 miniupnpd[463]: HTTP listening on port 33441
Aug 1 02:00:21 kernel: SCSI subsystem initialized
Aug 1 02:00:22 pppd[472]: PAP authentication failed
Aug 1 02:00:39 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:00:39 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:42 pppd[472]: PAP authentication failed
Aug 1 02:00:42 pppd[472]: Connection terminated.
Aug 1 02:00:43 rc_service: zcip 684:notify_rc start_firewall
Aug 1 02:00:43 zcip client: configured 169.254.163.221
Aug 1 02:00:44 miniupnpd[463]: shutting down MiniUPnPd
Aug 1 02:00:44 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)!
Aug 1 02:00:45 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:45 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:45 miniupnpd[740]: version 1.9 started
Aug 1 02:00:45 miniupnpd[740]: HTTP listening on port 47434
Aug 1 02:00:45 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:52 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:00:52 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:55 pppd[472]: PAP authentication failed
Aug 1 02:00:55 pppd[472]: Connection terminated.
Aug 1 02:01:05 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:01:05 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:08 pppd[472]: PAP authentication failed
Aug 1 02:01:08 pppd[472]: Connection terminated.
Aug 1 02:01:18 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:01:18 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:21 pppd[472]: PAP authentication failed
Aug 1 02:01:21 pppd[472]: Connection terminated.
Aug 1 02:01:31 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:01:31 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:34 pppd[472]: PAP authentication failed
Aug 1 02:01:34 pppd[472]: Connection terminated.
Aug 1 02:01:44 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:01:44 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:44 pppd[472]: PAP authentication succeeded
Aug 1 02:01:44 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized
Aug 1 02:01:45 pppd[472]: local IP address 93.139.148.103
Aug 1 02:01:45 pppd[472]: remote IP address 172.29.252.89
Aug 1 02:01:45 rc_service: ip-up 819:notify_rc start_firewall
Aug 1 02:01:46 miniupnpd[740]: shutting down MiniUPnPd
Aug 1 02:01:46 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:01:46 rc_service: ip-up 819:notify_rc stop_upnp
Aug 1 02:01:46 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:01:47 miniupnpd[878]: version 1.9 started
Aug 1 02:01:47 miniupnpd[878]: HTTP listening on port 41732
Aug 1 02:01:47 miniupnpd[878]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:47 rc_service: ip-up 819:notify_rc start_upnp
Aug 1 02:01:47 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:01:47 miniupnpd[878]: shutting down MiniUPnPd
Aug 1 02:01:49 WAN Connection: WAN was restored.
Aug 1 02:01:49 miniupnpd[883]: version 1.9 started
Aug 1 02:01:49 miniupnpd[883]: HTTP listening on port 39510
Aug 1 02:01:49 miniupnpd[883]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:50 ntp: start NTP update
Dec 10 10:09:54 rc_service: ntp 880:notify_rc restart_upnp
Dec 10 10:09:54 miniupnpd[883]: shutting down MiniUPnPd
Dec 10 10:09:54 miniupnpd[892]: version 1.9 started
Dec 10 10:09:54 miniupnpd[892]: HTTP listening on port 34451
Dec 10 10:09:54 miniupnpd[892]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 10 10:09:55 rc_service: ntp 880:notify_rc restart_diskmon
Dec 10 10:09:55 disk_monitor: Finish
Dec 10 10:09:56 disk monitor: be idle
Dec 10 10:09:56 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 10 10:09:56 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 10 10:09:56 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 10 10:09:56 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 10 23:11:45 disk_monitor: Got SIGALRM...
Dec 11 00:00:45 disk_monitor: Got SIGALRM...
Dec 11 00:24:48 miniupnpd[892]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Dec 11 00:24:54 miniupnpd[892]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Aug 1 02:00:09 syslogd started: BusyBox v1.17.4
Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST)
Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017
Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f
Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug 1 02:00:09 kernel: Machine: Northstar Prototype
Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000
Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem
Aug 1 02:00:10 kernel: Virtual kernel memory layout:
Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB)
Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB)
Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB)
Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB)
Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB)
Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB)
Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512
Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB
Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled
Aug 1 02:00:10 kernel: bio: create slab at 0
Aug 1 02:00:10 kernel: PCI: no core
Aug 1 02:00:10 kernel: PCI: Fixing up bus 0
Aug 1 02:00:10 kernel: PCI: Fixing up bus 1
Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!!
Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2
Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 1 02:00:11 kernel: Registering the dns_resolver key type
Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel.
Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint
Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0
Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1
Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8
Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20
Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled
Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393)
Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0
Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1
Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae48004, fsr=0x1c06, pc=0x2abeac58 lr=0x17bd8 ignored.
Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257)
Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________
Aug 1 02:00:11 kernel: <4>Emergency Sync complete
Aug 1 02:00:11 kernel: <4>gro disabled
Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt
Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state
Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode
Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating
Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state
Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state
Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state
Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state
Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state
Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules!
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp
Aug 1 02:00:11 kernel: <0>Restarting system.
Aug 1 02:00:11 kernel: ____________________________________________________________________________
Aug 1 02:00:11 WAN Connection: Fail to connect with some issues.
Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL
Aug 1 02:00:17 disk monitor: be idle
Aug 1 02:00:17 jffs2: valid logs(1)
Aug 1 02:00:17 hour monitor: daemon is starting
Aug 1 02:00:17 hour monitor: daemon terminates
Aug 1 02:00:17 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1]
Aug 1 02:00:17 kernel: Attempt to kill tasklet from interrupt
Aug 1 02:00:18 miniupnpd[457]: HTTP listening on port 57753
Aug 1 02:00:18 pppd[460]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:18 pppd[460]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:18 pppd[460]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 pppd[460]: PAP authentication succeeded
Aug 1 02:00:19 pppd[460]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep
Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep
Aug 1 02:00:19 pppd[460]: local IP address 93.138.42.188
Aug 1 02:00:19 pppd[460]: remote IP address 172.29.252.64
Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:00:20 kernel: SCSI subsystem initialized
Aug 1 02:00:21 WAN Connection: WAN was restored.
Aug 1 02:00:28 miniupnpd[457]: shutting down MiniUPnPd
Aug 1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:00:31 miniupnpd[750]: version 1.9 started
Aug 1 02:00:31 miniupnpd[750]: HTTP listening on port 46651
Aug 1 02:00:31 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:32 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:00:32 miniupnpd[750]: shutting down MiniUPnPd
Aug 1 02:00:35 miniupnpd[759]: version 1.9 started
Aug 1 02:00:35 miniupnpd[759]: HTTP listening on port 60062
Aug 1 02:00:35 miniupnpd[759]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:36 ntp: start NTP update
Dec 11 05:02:06 rc_service: ntp 757:notify_rc restart_upnp
Dec 11 05:02:06 miniupnpd[759]: shutting down MiniUPnPd
Dec 11 05:02:07 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 11 05:02:07 miniupnpd[774]: version 1.9 started
Dec 11 05:02:07 miniupnpd[774]: HTTP listening on port 35670
Dec 11 05:02:07 miniupnpd[774]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 11 05:02:07 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 11 05:02:07 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 11 05:02:07 rc_service: ntp 757:notify_rc restart_diskmon
Dec 11 05:02:07 disk_monitor: Finish
Dec 11 05:02:08 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 11 05:02:09 disk monitor: be idle
Dec 11 05:02:13 rc_service: zcip 801:notify_rc start_firewall
Dec 11 05:02:13 zcip client: configured 169.254.163.221
Dec 11 05:02:13 miniupnpd[774]: shutting down MiniUPnPd
Dec 11 05:02:13 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 11 05:02:14 miniupnpd[829]: version 1.9 started
Dec 11 05:02:14 miniupnpd[829]: HTTP listening on port 54166
Dec 11 05:02:14 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 11 14:31:10 rc_service: httpds 417:notify_rc start_webs_update
Dec 11 23:04:34 disk_monitor: Got SIGALRM...
Dec 12 05:00:03 kernel: Emergency Sync complete
Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug 1 02:00:11 kernel: pflash: found no supported devices
Aug 1 02:00:11 kernel: bcmsflash: squash filesystem found at block 30
Aug 1 02:00:11 kernel: Creating 5 MTD partitions on "bcmsflash":
Aug 1 02:00:11 kernel: 0x000000000000-0x000000040000 : "boot"
Aug 1 02:00:11 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug 1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs"
Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2"
Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram"
Aug 1 02:00:11 kernel: === PPTP init ===
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2acef004, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac963b0, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored.
Aug 1 02:00:12 WAN Connection: Fail to connect with some issues.
Aug 1 02:00:17 RT-AC1200G+: start httpd - SSL
Aug 1 02:00:17 syslog: Generating SSL certificate...
Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1]
Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt
Aug 1 02:00:18 miniupnpd[465]: HTTP listening on port 34836
Aug 1 02:00:18 pppd[470]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[470]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:19 pppd[470]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 pppd[470]: PAP authentication succeeded
Aug 1 02:00:19 pppd[470]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:00:19 pppd[470]: local IP address 93.138.92.101
Aug 1 02:00:19 pppd[470]: remote IP address 172.29.252.64
Aug 1 02:00:19 rc_service: ip-up 498:notify_rc start_firewall
Aug 1 02:00:20 rc_service: ip-up 498:notify_rc stop_upnp
Aug 1 02:00:28 miniupnpd[465]: shutting down MiniUPnPd
Aug 1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:31 miniupnpd[746]: version 1.9 started
Aug 1 02:00:31 miniupnpd[746]: HTTP listening on port 41075
Aug 1 02:00:31 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:32 rc_service: ip-up 498:notify_rc start_upnp
Aug 1 02:00:32 miniupnpd[746]: shutting down MiniUPnPd
Aug 1 02:00:34 miniupnpd[750]: version 1.9 started
Aug 1 02:00:34 miniupnpd[750]: HTTP listening on port 35645
Aug 1 02:00:34 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 12 05:01:43 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 12 05:01:44 rc_service: ntp 749:notify_rc restart_upnp
Dec 12 05:01:44 miniupnpd[750]: shutting down MiniUPnPd
Dec 12 05:01:44 miniupnpd[770]: version 1.9 started
Dec 12 05:01:44 miniupnpd[770]: HTTP listening on port 37305
Dec 12 05:01:44 miniupnpd[770]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 12 05:01:45 rc_service: ntp 749:notify_rc restart_diskmon
Dec 12 05:01:45 disk_monitor: Finish
Dec 12 05:01:47 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 12 05:01:47 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 12 05:01:47 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 12 05:01:47 disk monitor: be idle
Dec 12 05:01:48 rc_service: zcip 793:notify_rc start_firewall
Dec 12 05:01:48 zcip client: configured 169.254.163.221
Dec 12 05:01:49 miniupnpd[770]: shutting down MiniUPnPd
Dec 12 05:01:49 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 12 05:01:50 miniupnpd[829]: version 1.9 started
Dec 12 05:01:50 miniupnpd[829]: HTTP listening on port 36053
Dec 12 05:01:50 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 12 23:04:13 disk_monitor: Got SIGALRM...
Dec 12 23:34:16 rc_service: httpds 417:notify_rc start_webs_update
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae3f004, fsr=0x1c06, pc=0x2ab76a00 lr=0x2ab76e5c ignored.
Aug 1 02:00:18 miniupnpd[464]: version 1.9 started
Aug 1 02:00:18 miniupnpd[464]: HTTP listening on port 34013
Aug 1 02:00:18 miniupnpd[464]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:19 pppd[470]: local IP address 93.138.17.169
Aug 1 02:00:20 rc_service: ip-up 502:notify_rc start_firewall
Aug 1 02:00:20 rc_service: ip-up 502:notify_rc stop_upnp
Aug 1 02:00:22 WAN Connection: WAN was restored.
Aug 1 02:00:28 miniupnpd[464]: shutting down MiniUPnPd
Aug 1 02:00:32 miniupnpd[746]: version 1.9 started
Aug 1 02:00:32 miniupnpd[746]: HTTP listening on port 49039
Aug 1 02:00:32 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:32 rc_service: ip-up 502:notify_rc start_upnp
Aug 1 02:00:33 miniupnpd[746]: shutting down MiniUPnPd
Aug 1 02:00:35 miniupnpd[751]: version 1.9 started
Aug 1 02:00:35 miniupnpd[751]: HTTP listening on port 37247
Aug 1 02:00:35 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 13 05:01:51 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 13 05:01:51 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 13 05:01:51 rc_service: ntp 749:notify_rc restart_upnp
Dec 13 05:01:51 miniupnpd[751]: shutting down MiniUPnPd
Dec 13 05:01:52 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 13 05:01:52 rc_service: ntp 749:notify_rc restart_diskmon
Dec 13 05:01:53 disk_monitor: Finish
Dec 13 05:01:53 miniupnpd[771]: version 1.9 started
Dec 13 05:01:53 miniupnpd[771]: HTTP listening on port 41168
Dec 13 05:01:53 miniupnpd[771]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 13 05:01:53 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 13 05:01:55 disk monitor: be idle
Dec 13 05:01:56 rc_service: zcip 778:notify_rc start_firewall
Dec 13 05:01:56 zcip client: configured 169.254.163.221
Dec 13 05:01:57 miniupnpd[771]: shutting down MiniUPnPd
Dec 13 05:01:57 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 13 05:02:00 miniupnpd[816]: version 1.9 started
Dec 13 05:02:00 miniupnpd[816]: HTTP listening on port 60177
Dec 13 05:02:00 miniupnpd[816]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 13 17:41:12 rc_service: httpds 417:notify_rc start_webs_update
Aug 1 02:00:10 kernel: pflash: found no supported devices
Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30
Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash":
Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot"
Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ade2004, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2acc23b0, fsr=0x1c06, pc=0x7f190b38 lr=0x80208820 ignored.
Aug 1 02:00:11 kernel: <4>Exception stack(0x8534bfb0 to 0x8534bff8)
Aug 1 02:00:11 kernel: <4>bfa0: 0000000e 00000008 7ec48c48 00000000
Aug 1 02:00:11 kernel: <4>bfc0: 7ec48c48 00000001 7ec48e94 000000b3 0000d1f0 0000ec14 7ec48e08 00000000
Aug 1 02:00:11 kernel: <4>bfe0: 2aea65b4 7ec48948 2ae4e254 0003be5c 00000010 ffffffff
Aug 1 02:00:18 syslog: Generating SSL certificate...
Aug 1 02:00:18 miniupnpd[465]: HTTP listening on port 56032
Aug 1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:27 pppd[472]: Connection terminated.
Aug 1 02:00:27 pppd[472]: Modem hangup
Aug 1 02:00:40 pppd[472]: PAP authentication failed
Aug 1 02:00:40 pppd[472]: Connection terminated.
Aug 1 02:00:41 rc_service: zcip 684:notify_rc start_firewall
Aug 1 02:00:43 miniupnpd[740]: version 1.9 started
Aug 1 02:00:43 miniupnpd[740]: HTTP listening on port 48089
Aug 1 02:00:43 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:50 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:50 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:53 pppd[472]: PAP authentication failed
Aug 1 02:00:53 pppd[472]: Connection terminated.
Aug 1 02:01:03 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:03 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:06 pppd[472]: PAP authentication failed
Aug 1 02:01:06 pppd[472]: Connection terminated.
Aug 1 02:01:16 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:01:16 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:19 pppd[472]: PAP authentication failed
Aug 1 02:01:19 pppd[472]: Connection terminated.
Aug 1 02:01:29 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:01:29 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:32 pppd[472]: PAP authentication failed
Aug 1 02:01:32 pppd[472]: Connection terminated.
Aug 1 02:01:42 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:01:42 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:43 pppd[472]: PAP authentication succeeded
Aug 1 02:01:43 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized
Aug 1 02:01:43 pppd[472]: local IP address 93.139.188.27
Aug 1 02:01:43 pppd[472]: remote IP address 172.29.252.89
Aug 1 02:01:43 rc_service: ip-up 818:notify_rc start_firewall
Aug 1 02:01:44 miniupnpd[740]: shutting down MiniUPnPd
Aug 1 02:01:44 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:01:44 rc_service: ip-up 818:notify_rc stop_upnp
Aug 1 02:01:44 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:01:45 miniupnpd[869]: version 1.9 started
Aug 1 02:01:45 miniupnpd[869]: HTTP listening on port 56143
Aug 1 02:01:45 miniupnpd[869]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:45 rc_service: ip-up 818:notify_rc start_upnp
Aug 1 02:01:45 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:01:45 miniupnpd[869]: shutting down MiniUPnPd
Aug 1 02:01:47 miniupnpd[873]: version 1.9 started
Aug 1 02:01:47 miniupnpd[873]: HTTP listening on port 41917
Aug 1 02:01:47 miniupnpd[873]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:47 WAN Connection: WAN was restored.
Aug 1 02:01:48 ntp: start NTP update
Aug 1 02:01:48 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 13 18:12:49 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 13 18:12:49 rc_service: ntp 871:notify_rc restart_upnp
Dec 13 18:12:49 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 13 18:12:49 miniupnpd[873]: shutting down MiniUPnPd
Dec 13 18:12:49 miniupnpd[893]: version 1.9 started
Dec 13 18:12:49 miniupnpd[893]: HTTP listening on port 37135
Dec 13 18:12:49 miniupnpd[893]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 13 18:12:49 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 13 18:12:50 rc_service: ntp 871:notify_rc restart_diskmon
Dec 13 18:12:50 disk_monitor: Finish
Dec 13 18:12:51 disk monitor: be idle
Dec 13 19:00:58 disk_monitor: Got SIGALRM...
Dec 13 23:01:29 disk_monitor: Got SIGALRM...
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae53004, fsr=0x1c06, pc=0x2ab40e08 lr=0x2ab40e5c ignored.
Aug 1 02:00:11 kernel: <4>Exception stack(0x851fdfb0 to 0x851fdff8)
Aug 1 02:00:11 kernel: <4>dfa0: 00001800 0009a21c 00001800 0009a21c
Aug 1 02:00:11 kernel: <4>dfc0: 0009a21c 000983cc 000000fa 00000067 0009a258 00001e38 00000500 00000000
Aug 1 02:00:11 kernel: <4>dfe0: 000984e4 7e8e0d68 0002c878 2ac8c370 80000010 ffffffff
Aug 1 02:00:18 miniupnpd[457]: HTTP listening on port 33819
Aug 1 02:00:39 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:00:44 miniupnpd[457]: shutting down MiniUPnPd
Aug 1 02:00:46 miniupnpd[740]: version 1.9 started
Aug 1 02:00:46 miniupnpd[740]: HTTP listening on port 50075
Aug 1 02:00:46 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:52 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:01:05 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:01:18 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:01:31 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:01:44 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:01:44 pppd[472]: peer from calling number 84:B5:9C:A4:4D:B7 authorized
Aug 1 02:01:45 pppd[472]: local IP address 78.1.186.208
Aug 1 02:01:45 pppd[472]: remote IP address 172.29.252.59
Aug 1 02:01:45 rc_service: ip-up 820:notify_rc start_firewall
Aug 1 02:01:46 rc_service: ip-up 820:notify_rc stop_upnp
Aug 1 02:01:47 miniupnpd[867]: version 1.9 started
Aug 1 02:01:47 miniupnpd[867]: HTTP listening on port 46435
Aug 1 02:01:47 miniupnpd[867]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:47 rc_service: ip-up 820:notify_rc start_upnp
Aug 1 02:01:47 miniupnpd[867]: shutting down MiniUPnPd
Aug 1 02:01:48 WAN Connection: WAN was restored.
Aug 1 02:01:49 miniupnpd[872]: version 1.9 started
Aug 1 02:01:49 miniupnpd[872]: HTTP listening on port 44026
Aug 1 02:01:49 miniupnpd[872]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:49 ntp: start NTP update
Dec 14 01:18:19 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 14 01:18:19 rc_service: ntp 870:notify_rc restart_upnp
Dec 14 01:18:19 miniupnpd[872]: shutting down MiniUPnPd
Dec 14 01:18:19 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 14 01:18:19 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 14 01:18:19 miniupnpd[890]: version 1.9 started
Dec 14 01:18:19 miniupnpd[890]: HTTP listening on port 42889
Dec 14 01:18:19 miniupnpd[890]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 14 01:18:20 rc_service: ntp 870:notify_rc restart_diskmon
Dec 14 01:18:20 disk_monitor: Finish
Dec 14 01:18:20 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 14 01:18:21 disk monitor: be idle
Dec 14 02:00:27 disk_monitor: Got SIGALRM...
Dec 14 05:00:12 kernel: Emergency Sync complete
Dec 14 05:00:14 iTunes: daemon is stoped
Dec 14 05:00:14 FTP Server: daemon is stoped
Dec 14 05:00:14 Samba Server: smb daemon is stoped
Dec 14 05:00:14 kernel: gro disabled
Dec 14 05:00:14 disk_monitor: Finish
Dec 14 05:00:14 miniupnpd[890]: shutting down MiniUPnPd
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ad9b004, fsr=0x1c06, pc=0x800ce10c lr=0x800c1154 ignored.
Aug 1 02:00:18 miniupnpd[461]: HTTP listening on port 60517
Aug 1 02:00:19 pppd[472]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[472]: PAP authentication succeeded
Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:00:20 pppd[472]: local IP address 93.138.127.180
Aug 1 02:00:20 pppd[472]: remote IP address 172.29.252.64
Aug 1 02:00:20 rc_service: ip-up 501:notify_rc start_firewall
Aug 1 02:00:20 syslog: module leds-usb not found in modules.dep
Aug 1 02:00:20 rc_service: ip-up 501:notify_rc stop_upnp
Aug 1 02:00:28 miniupnpd[461]: shutting down MiniUPnPd
Aug 1 02:00:32 miniupnpd[747]: version 1.9 started
Aug 1 02:00:32 miniupnpd[747]: HTTP listening on port 55279
Aug 1 02:00:32 miniupnpd[747]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:33 rc_service: ip-up 501:notify_rc start_upnp
Aug 1 02:00:33 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:00:33 miniupnpd[747]: shutting down MiniUPnPd
Aug 1 02:00:36 miniupnpd[751]: version 1.9 started
Aug 1 02:00:36 miniupnpd[751]: HTTP listening on port 33504
Aug 1 02:00:36 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 14 05:01:53 rc_service: ntp 749:notify_rc restart_upnp
Dec 14 05:01:53 miniupnpd[751]: shutting down MiniUPnPd
Dec 14 05:01:54 rc_service: ntp 749:notify_rc restart_diskmon
Dec 14 05:01:54 disk_monitor: Finish
Dec 14 05:01:56 miniupnpd[767]: version 1.9 started
Dec 14 05:01:56 miniupnpd[767]: HTTP listening on port 48911
Dec 14 05:01:56 miniupnpd[767]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 14 05:01:57 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 14 05:01:57 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 14 05:01:57 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 14 05:01:57 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 14 05:01:58 disk monitor: be idle
Dec 14 05:01:58 rc_service: zcip 779:notify_rc start_firewall
Dec 14 05:01:59 zcip client: configured 169.254.163.221
Dec 14 05:02:00 miniupnpd[767]: shutting down MiniUPnPd
Dec 14 05:02:00 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 14 05:02:04 miniupnpd[826]: version 1.9 started
Dec 14 05:02:04 miniupnpd[826]: HTTP listening on port 46443
Dec 14 05:02:04 miniupnpd[826]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 14 05:59:23 kernel: active_file:438 inactive_file:687 isolated_file:0
Dec 14 05:59:23 kernel: unevictable:0 dirty:0 writeback:0 unstable:0
Dec 14 05:59:23 kernel: free:383 slab_reclaimable:266 slab_unreclaimable:24677
Dec 14 05:59:23 kernel: mapped:824 shmem:188 pagetables:151 bounce:0
Dec 14 05:59:23 kernel: DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:6616kB inactive_anon:940kB active_file:1752kB inactive_file:2748kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:3296kB shmem:752kB slab_reclaimable:1064kB slab_unreclaimable:98708kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:195 all_unreclaimable? no
Dec 14 05:59:23 kernel: lowmem_reserve[]: 0 0 0
Dec 14 05:59:23 kernel: DMA: 1*4kB 1*8kB 1*16kB 1*32kB 1*64kB 1*128kB 1*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1532kB
Dec 14 05:59:23 kernel: 1313 total pagecache pages
Dec 14 05:59:23 kernel: 0 pages in swap cache
Dec 14 05:59:23 kernel: Swap cache stats: add 0, delete 0, find 0/0
Dec 14 05:59:23 kernel: Free swap = 0kB
Dec 14 05:59:23 kernel: Total swap = 0kB
Dec 14 05:59:23 kernel: 32768 pages of RAM
Dec 14 05:59:23 kernel: 552 free pages
Dec 14 05:59:23 kernel: 1352 reserved pages
Dec 14 05:59:23 kernel: 9328 slab pages
Dec 14 05:59:23 kernel: 4621 pages shared
Dec 14 05:59:23 kernel: 0 pages swap cached
Dec 14 05:59:24 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20)
Dec 14 05:59:24 kernel: cache: kmalloc-256, object size: 256, buffer size: 256, default order: 0, min order: 0
Dec 14 05:59:24 kernel: node 0: slabs: 3375, objs: 54000, free: 0
Dec 14 05:59:24 kernel: acsd: page allocation failure. order:0, mode:0x20
Dec 14 05:59:24 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694)
Dec 14 05:59:24 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0)
Dec 14 05:59:24 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0970>] (kmem_cache_alloc+0x90/0x9c)
Dec 14 05:59:24 kernel: [<803b0970>] (kmem_cache_alloc+0x90/0x9c) from [<803b28ac>] (__alloc_skb+0x30/0x104)
Dec 14 05:59:24 kernel: [<803b28ac>] (__alloc_skb+0x30/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac)
Dec 14 05:59:24 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<803c2cc0>] (osl_pktget+0x6c/0x170)
Dec 14 05:59:24 kernel: [<803c2cc0>] (osl_pktget+0x6c/0x170) from [<7f29458c>] (wlc_hdr_proc+0x54/0x254 [wl])
Dec 14 05:59:24 kernel: unwind: Index not found 7f29458c
Dec 14 05:59:24 kernel: Mem-info:
Dec 14 05:59:24 kernel: DMA per-cpu:
Dec 14 05:59:24 kernel: CPU 0: hi: 42, btch: 7 usd: 6
Dec 14 05:59:24 kernel: active_anon:1654 inactive_anon:235 isolated_anon:0
Dec 14 05:59:24 kernel: active_file:438 inactive_file:687 isolated_file:0
Dec 14 05:59:24 kernel: unevictable:0 dirty:0 writeback:0 unstable:0
Dec 14 05:59:24 kernel: free:383 slab_reclaimable:266 slab_unreclaimable:24677
Dec 14 05:59:24 kernel: mapped:824 shmem:188 pagetables:151 bounce:0
Dec 14 05:59:24 kernel: DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:6616kB inactive_anon:940kB active_file:1752kB inactive_file:2748kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:3296kB shmem:752kB slab_reclaimable:1064kB slab_unreclaimable:98708kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:195 all_unreclaimable? no
Dec 14 05:59:24 kernel: lowmem_reserve[]: 0 0 0
Dec 14 05:59:24 kernel: DMA: 1*4kB 1*8kB 1*16kB 1*32kB 1*64kB 1*128kB 1*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1532kB
Dec 14 05:59:24 kernel: 1313 total pagecache pages
Dec 14 05:59:24 kernel: 0 pages in swap cache
Dec 14 05:59:24 kernel: Swap cache stats: add 0, delete 0, find 0/0
Dec 14 05:59:24 kernel: Free swap = 0kB
Dec 14 05:59:24 kernel: Total swap = 0kB
Dec 14 05:59:24 kernel: 32768 pages of RAM
Dec 14 05:59:24 kernel: 552 free pages
Dec 14 05:59:24 kernel: 1352 reserved pages
Dec 14 05:59:24 kernel: 9328 slab pages
Dec 14 05:59:24 kernel: 4621 pages shared
Dec 14 05:59:24 kernel: 0 pages swap cached
Dec 14 05:59:24 kernel: [<803b0970>] (kmem_cache_alloc+0x90/0x9c) from [<80216050>] (skb_clone+0x130/0x14c)
Dec 14 05:59:24 kernel: [<80216050>] (skb_clone+0x130/0x14c) from [<802e8ba0>] (deliver_clone+0x20/0x4c)
Dec 14 05:59:24 kernel: [<802e8ba0>] (deliver_clone+0x20/0x4c) from [<802e9e24>] (br_handle_frame_finish+0x230/0x23c)
Dec 14 05:59:24 kernel: [<802e9e24>] (br_handle_frame_finish+0x230/0x23c) from [<802e9fdc>] (br_handle_frame+0x1ac/0x24c)
Dec 14 05:59:24 kernel: [<802e9fdc>] (f len 2016 failed
Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed
Dec 14 05:59:24 kernel: __alloc_pages_slowpath: 7870 callbacks suppressed
Dec 14 05:59:24 kernel: kworker/0:1: page allocation failure. order:0, mode:0x4020
Dec 14 05:59:24 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8)
Dec 14 05:59:24 kernel: [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104)
Dec 14 05:59:24 kernel: [<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac)
Dec 14 05:59:24 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<801fc918>] (osl_ctfpool_add+0x5c/0xf8)
Dec 14 05:59:24 kernel: [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) from [<7f018a14>] (et_tx_tasklet+0x304/0xbdc [et])
Dec 14 05:59:24 kernel: unwind: Index not found 7f018a14
Dec 14 05:59:24 kernel: CPU 0: hi: 42, btch: 7 usd: 7
Dec 14 05:59:24 kernel: active_anon:951 inactive_anon:938 isolated_anon:0
Dec 14 05:59:24 kernel: active_file:397 inactive_file:599 isolated_file:0
Dec 14 05:59:24 kernel: free:382 slab_reclaimable:150 slab_unreclaimable:24922
Dec 14 05:59:24 kernel: mapped:711 shmem:188 pagetables:151 bounce:0
Dec 14 05:59:24 kernel: DMA free:1528kB min:4096kB low:5120kB high:6144kB active_anon:3804kB inactive_anon:3752kB active_file:1588kB inactive_file:2396kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:2844kB shmem:752kB slab_reclaimable:600kB slab_unreclaimable:99688kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Dec 14 05:59:24 kernel: DMA: 14*4kB 6*8kB 5*16kB 6*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1528kB
Dec 14 05:59:24 kernel: 1184 total pagecache pages
Dec 14 05:59:24 kernel: 9646 slab pages
Dec 14 05:59:24 kernel: 3844 pages shared
Dec 14 05:59:24 kernel: cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0
Dec 14 05:59:24 kernel: node 0: slabs: 2213, objs: 17466, free: 0
Dec 14 05:59:25 kernel: [<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac)
Dec 14 05:59:25 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<801fc918>] (osl_ctfpool_add+0x5c/0xf8)
Dec 14 05:59:25 kernel: [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) from [<7f018a14>] (et_tx_tasklet+0x304/0xbdc [et])
Dec 14 05:59:25 kernel: unwind: Index not found 7f018a14
Dec 14 05:59:25 kernel: Mem-info:
Dec 14 05:59:25 kernel: DMA per-cpu:
Dec 14 05:59:25 kernel: CPU 0: hi: 42, btch: 7 usd: 7
Dec 14 05:59:25 kernel: active_anon:951 inactive_anon:938 isolated_anon:0
Dec 14 05:59:25 kernel: active_file:397 inactive_file:599 isolated_file:0
Dec 14 05:59:25 kernel: unevictable:0 dirty:0 writeback:0 unstable:0
Dec 14 05:59:25 kernel: free:382 slab_reclaimable:150 slab_unreclaimable:24922
Dec 14 05:59:25 kernel: mapped:711 shmem:188 pagetables:151 bounce:0
Dec 14 05:59:25 kernel: DMA free:1528kB min:4096kB low:5120kB high:6144kB active_anon:3804kB inactive_anon:3752kB active_file:1588kB inactive_file:2396kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:2844kB shmem:752kB slab_reclaimable:600kB slab_unreclaimable:99688kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Dec 14 05:59:25 kernel: lowmem_reserve[]: 0 0 0
Dec 14 05:59:25 kernel: DMA: 14*4kB 6*8kB 5*16kB 6*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1528kB
Dec 14 05:59:25 kernel: 1184 total pagecache pages
Dec 14 05:59:25 kernel: 0 pages in swap cache
Dec 14 05:59:25 kernel: Swap cache stats: add 0, delete 0, find 0/0
Dec 14 05:59:25 kernel: Free swap = 0kB
Dec 14 05:59:25 kernel: Total swap = 0kB
Dec 14 05:59:25 kernel: 32768 pages of RAM
Dec 14 05:59:25 kernel: 552 free pages
Dec 14 05:59:25 kernel: 1352 reserved pages
Dec 14 05:59:25 kernel: 9646 slab pages
Dec 14 05:59:25 kernel: 3844 pages shared
Dec 14 05:59:25 kernel: 0 pages swap cached
Dec 14 05:59:25 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20)
Dec 14 05:59:25 kernel: cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0
Dec 14 05:59:25 kernel: node 0: slabs: 2213, objs: 17466, free: 0
Dec 14 05:59:25 kernel: osl_ctfpool_add: skb alloc of len 2016 failed
Dec 14 05:59:25 kernel: kworker/0:1: page allocation failure. order:0, mode:0x4020
Dec 14 05:59:25 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694)
Dec 14 05:59:25 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0)
Dec 14 05:59:25 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8)
Dec 14 05:59:25 kernel: [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104)
Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed
Dec 19 23:04:32 disk_monitor: Got SIGALRM...
Aug 1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs"
Aug 1 02:00:10 kernel: 0x000000d30000-0x000000ff0000 : "jffs2"
Aug 1 02:00:10 kernel: 0x000000ff0000-0x000001000000 : "nvram"
Aug 1 02:00:10 kernel: === PPTP init ===
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac81004, fsr=0x1c06, pc=0x2aacda40 lr=0x2aacde5c ignored.
Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1547)
Aug 1 02:00:11 kernel: <0>Kernel panic - not syncing: Out of memory: system-wide panic_on_oom is enabled
Aug 1 02:00:11 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<802fec2c>] (panic+0x7c/0x1a4)
Aug 1 02:00:11 kernel: <4>[<802fec2c>] (panic+0x7c/0x1a4) from [<80091038>] (out_of_memory+0x2c8/0x328)
Aug 1 02:00:11 kernel: <4>[<80091038>] (out_of_memory+0x2c8/0x328) from [<800942c0>] (__alloc_pages_nodemask+0x66c/0x694)
Aug 1 02:00:11 kernel: <4>[<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) from [<80096000>] (__do_page_cache_readahead+0x140/0x2d0)
Aug 1 02:00:11 kernel: <4>[<80096000>] (__do_page_cache_readahead+0x140/0x2d0) from [<80096440>] (ra_submit+0x28/0x30)
Aug 1 02:00:11 kernel: <4>[<80096440>] (ra_submit+0x28/0x30) from [<8008e5d0>] (filemap_fault+0x42c/0x454)
Aug 1 02:00:11 kernel: <4>[<8008e5d0>] (filemap_fault+0x42c/0x454) from [<800a315c>] (__do_fault.clone.60+0x54/0x4c8)
Aug 1 02:00:11 kernel: <4>[<800a315c>] (__do_fault.clone.60+0x54/0x4c8) from [<800a67c4>] (handle_mm_fault+0x114/0x934)
Aug 1 02:00:11 kernel: <4>[<800a67c4>] (handle_mm_fault+0x114/0x934) from [<8003fd90>] (do_page_fault+0x178/0x1ec)
Aug 1 02:00:11 kernel: <4>[<8003fd90>] (do_page_fault+0x178/0x1ec) from [<80038298>] (do_PrefetchAbort+0x30/0x9c)
Aug 1 02:00:11 kernel: <4>[<80038298>] (do_PrefetchAbort+0x30/0x9c) from [<803bf2e0>] (ret_from_exception+0x0/0x10)
Aug 1 02:00:11 kernel: <4>Exception stack(0x8523ffb0 to 0x8523fff8)
Aug 1 02:00:11 kernel: <4>ffa0: 00000004 0008d206 0009a21f 00000073
Aug 1 02:00:11 kernel: <4>ffc0: 0009a21f 000983cc 0000010e 00000000 0009a256 00001e38 00000500 0000000a
Aug 1 02:00:11 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed
Aug 1 02:00:11 kernel: <4>ffe0: 00098720 7eb6ed78 0002c958 2ac956e0 20000010 ffffffff
Aug 1 02:00:11 kernel: <0>Rebooting in 3 seconds..osl_ctfpool_add: skb alloc of len 2016 failed
Aug 1 02:00:18 miniupnpd[459]: version 1.9 started
Aug 1 02:00:18 miniupnpd[459]: HTTP listening on port 36767
Aug 1 02:00:18 miniupnpd[459]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:28 pppd[472]: Connection terminated.
Aug 1 02:00:28 pppd[472]: Modem hangup
Aug 1 02:00:38 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:38 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:42 rc_service: zcip 684:notify_rc start_firewall
Aug 1 02:00:42 zcip client: configured 169.254.163.221
Aug 1 02:00:42 miniupnpd[459]: shutting down MiniUPnPd
Aug 1 02:00:42 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)!
Aug 1 02:00:44 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:44 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:44 miniupnpd[740]: version 1.9 started
Aug 1 02:00:44 miniupnpd[740]: HTTP listening on port 52453
Aug 1 02:00:44 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:47 stop_nat_rules: apply the redirect_rules!
Aug 1 02:00:52 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:05 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:01:07 pppd[472]: PAP authentication failed
Aug 1 02:01:18 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:31 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:31 pppd[472]: PAP authentication succeeded
Aug 1 02:01:31 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:01:32 pppd[472]: local IP address 93.138.54.92
Aug 1 02:01:32 pppd[472]: remote IP address 172.29.252.64
Aug 1 02:01:32 rc_service: ip-up 804:notify_rc start_firewall
Aug 1 02:01:33 miniupnpd[740]: shutting down MiniUPnPd
Aug 1 02:01:33 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:01:33 rc_service: ip-up 804:notify_rc stop_upnp
Aug 1 02:01:33 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:01:35 miniupnpd[851]: version 1.9 started
Aug 1 02:01:35 miniupnpd[851]: HTTP listening on port 34250
Aug 1 02:01:35 miniupnpd[851]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:35 miniupnpd[851]: shutting down MiniUPnPd
Aug 1 02:01:35 rc_service: ip-up 804:notify_rc start_upnp
Aug 1 02:01:36 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:01:36 WAN Connection: WAN was restored.
Aug 1 02:01:38 miniupnpd[856]: version 1.9 started
Aug 1 02:01:38 miniupnpd[856]: HTTP listening on port 36430
Aug 1 02:01:38 miniupnpd[856]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:38 ntp: start NTP update
Dec 19 23:16:17 rc_service: ntp 854:notify_rc restart_upnp
Dec 19 23:16:17 miniupnpd[856]: shutting down MiniUPnPd
Dec 19 23:16:17 miniupnpd[869]: version 1.9 started
Dec 19 23:16:17 miniupnpd[869]: HTTP listening on port 46870
Dec 19 23:16:17 miniupnpd[869]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 19 23:16:18 rc_service: ntp 854:notify_rc restart_diskmon
Dec 19 23:16:18 disk_monitor: Finish
Dec 19 23:16:18 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 19 23:16:19 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 19 23:16:19 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 19 23:16:19 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 19 23:16:19 disk monitor: be idle
pozdrav,
imam navedeni ruter u kombinaciji sa ht-ovim speedportom (ona ac wifi verzija), asus je na zadnjem sluzbenom fw i zadnjih 3 mjeseca je normalno radio no sad se smrzne sam od sebe i nakon par minuta reboota
ovo pise u logu pa ako ga netko moze desifrirati, asus support mi rekao da nosim na servis ako sumnjam da je neispravan i ne znam sto je sa ovim august 1 datumom, clearao sam jutros log tako da je ovo od zadnjeg crasha
Code:
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae50004, fsr=0x1c06, pc=0x800cda10 lr=0x800cdd30 ignored.
Aug 1 02:00:18 miniupnpd[465]: version 1.9 started
Aug 1 02:00:18 miniupnpd[465]: HTTP listening on port 44321
Aug 1 02:00:18 miniupnpd[465]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A3:B7:70 authorized
Aug 1 02:00:20 pppd[472]: local IP address 93.142.236.121
Aug 1 02:00:20 pppd[472]: remote IP address 172.29.252.90
Aug 1 02:00:20 rc_service: ip-up 500:notify_rc start_firewall
Aug 1 02:00:21 rc_service: ip-up 500:notify_rc stop_upnp
Aug 1 02:00:21 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:00:27 miniupnpd[465]: shutting down MiniUPnPd
Aug 1 02:00:27 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:00:32 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:32 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:32 miniupnpd[748]: version 1.9 started
Aug 1 02:00:32 miniupnpd[748]: HTTP listening on port 45952
Aug 1 02:00:32 miniupnpd[748]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:33 rc_service: ip-up 500:notify_rc start_upnp
Aug 1 02:00:33 miniupnpd[748]: shutting down MiniUPnPd
Aug 1 02:00:35 miniupnpd[754]: version 1.9 started
Aug 1 02:00:35 miniupnpd[754]: HTTP listening on port 55762
Aug 1 02:00:35 miniupnpd[754]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:37 ntp: start NTP update
Aug 1 02:00:37 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Nov 29 05:02:11 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Nov 29 05:02:12 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Nov 29 05:02:12 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Nov 29 05:02:12 rc_service: ntp 752:notify_rc restart_upnp
Nov 29 05:02:12 miniupnpd[754]: shutting down MiniUPnPd
Nov 29 05:02:13 rc_service: ntp 752:notify_rc restart_diskmon
Nov 29 05:02:14 disk_monitor: Finish
Nov 29 05:02:15 miniupnpd[784]: version 1.9 started
Nov 29 05:02:15 miniupnpd[784]: HTTP listening on port 44342
Nov 29 05:02:15 miniupnpd[784]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 29 05:02:17 disk monitor: be idle
Nov 29 05:02:17 rc_service: zcip 785:notify_rc start_firewall
Nov 29 05:02:17 zcip client: configured 169.254.163.221
Nov 29 05:02:18 miniupnpd[784]: shutting down MiniUPnPd
Nov 29 05:02:18 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Nov 29 05:02:20 miniupnpd[825]: version 1.9 started
Nov 29 05:02:20 miniupnpd[825]: HTTP listening on port 49515
Nov 29 05:02:20 miniupnpd[825]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 29 09:36:17 miniupnpd[825]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Nov 29 09:36:24 miniupnpd[825]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Nov 29 09:36:38 miniupnpd[825]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Nov 29 17:18:01 rc_service: httpds 417:notify_rc start_webs_update
Nov 29 23:04:49 disk_monitor: Got SIGALRM...
Nov 30 05:00:15 kernel: Emergency Sync complete
Aug 1 02:00:09 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Aug 1 02:00:09 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2adde000, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2abb13b0, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored.
Aug 1 02:00:18 miniupnpd[464]: HTTP listening on port 59631
Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized
Aug 1 02:00:19 kernel: SCSI subsystem initialized
Aug 1 02:00:20 pppd[472]: local IP address 93.139.156.15
Aug 1 02:00:20 pppd[472]: remote IP address 172.29.252.89
Aug 1 02:00:20 rc_service: ip-up 513:notify_rc start_firewall
Aug 1 02:00:20 rc_service: ip-up 513:notify_rc stop_upnp
Aug 1 02:00:27 miniupnpd[464]: shutting down MiniUPnPd
Aug 1 02:00:30 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:30 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:31 miniupnpd[746]: HTTP listening on port 46370
Aug 1 02:00:32 rc_service: ip-up 513:notify_rc start_upnp
Aug 1 02:00:34 miniupnpd[751]: version 1.9 started
Aug 1 02:00:34 miniupnpd[751]: HTTP listening on port 54040
Aug 1 02:00:34 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:35 ntp: start NTP update
Nov 30 05:01:45 rc_service: ntp 749:notify_rc restart_upnp
Nov 30 05:01:45 miniupnpd[751]: shutting down MiniUPnPd
Nov 30 05:01:46 rc_service: ntp 749:notify_rc restart_diskmon
Nov 30 05:01:47 miniupnpd[766]: version 1.9 started
Nov 30 05:01:47 miniupnpd[766]: HTTP listening on port 36896
Nov 30 05:01:47 miniupnpd[766]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 30 05:01:47 disk_monitor: Finish
Nov 30 05:01:47 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Nov 30 05:01:47 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Nov 30 05:01:47 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Nov 30 05:01:48 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Nov 30 05:01:50 disk monitor: be idle
Nov 30 05:01:50 rc_service: zcip 778:notify_rc start_firewall
Nov 30 05:01:50 zcip client: configured 169.254.163.221
Nov 30 05:01:52 miniupnpd[766]: shutting down MiniUPnPd
Nov 30 05:01:52 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Nov 30 05:01:54 miniupnpd[821]: version 1.9 started
Nov 30 05:01:54 miniupnpd[821]: HTTP listening on port 41162
Nov 30 05:01:54 miniupnpd[821]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 30 23:04:17 disk_monitor: Got SIGALRM...
Dec 1 00:26:07 rc_service: httpds 417:notify_rc start_webs_update
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae0e004, fsr=0x1c06, pc=0x80171f68 lr=0x800cc4c4 ignored.
Aug 1 02:00:18 miniupnpd[459]: HTTP listening on port 59994
Aug 1 02:00:19 pppd[473]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[473]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:00:19 pppd[473]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 pppd[473]: PAP authentication succeeded
Aug 1 02:00:19 pppd[473]: peer from calling number 00:90:1A:A3:B7:7C authorized
Aug 1 02:00:20 pppd[473]: local IP address 93.139.153.7
Aug 1 02:00:20 pppd[473]: remote IP address 172.29.252.89
Aug 1 02:00:20 rc_service: ip-up 503:notify_rc start_firewall
Aug 1 02:00:21 rc_service: ip-up 503:notify_rc stop_upnp
Aug 1 02:00:28 miniupnpd[459]: shutting down MiniUPnPd
Aug 1 02:00:33 miniupnpd[750]: version 1.9 started
Aug 1 02:00:33 miniupnpd[750]: HTTP listening on port 54542
Aug 1 02:00:33 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:33 rc_service: ip-up 503:notify_rc start_upnp
Aug 1 02:00:33 miniupnpd[750]: shutting down MiniUPnPd
Aug 1 02:00:35 miniupnpd[755]: version 1.9 started
Aug 1 02:00:35 miniupnpd[755]: HTTP listening on port 38653
Aug 1 02:00:35 miniupnpd[755]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:36 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Aug 1 02:00:36 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 1 05:01:41 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 1 05:01:42 rc_service: ntp 753:notify_rc restart_upnp
Dec 1 05:01:42 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 1 05:01:42 miniupnpd[755]: shutting down MiniUPnPd
Dec 1 05:01:42 miniupnpd[779]: version 1.9 started
Dec 1 05:01:42 miniupnpd[779]: HTTP listening on port 43370
Dec 1 05:01:42 miniupnpd[779]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 1 05:01:43 rc_service: ntp 753:notify_rc restart_diskmon
Dec 1 05:01:43 disk_monitor: Finish
Dec 1 05:01:45 disk monitor: be idle
Dec 1 05:01:47 rc_service: zcip 803:notify_rc start_firewall
Dec 1 05:01:47 zcip client: configured 169.254.163.221
Dec 1 05:01:48 miniupnpd[779]: shutting down MiniUPnPd
Dec 1 05:01:48 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 1 05:01:49 miniupnpd[830]: version 1.9 started
Dec 1 05:01:49 miniupnpd[830]: HTTP listening on port 35003
Dec 1 05:01:49 miniupnpd[830]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 1 13:31:57 rc_service: httpds 417:notify_rc start_webs_update
Dec 1 13:46:24 rc_service: httpds 417:notify_rc start_webs_update
Dec 1 15:51:15 rc_service: httpds 417:notify_rc start_webs_update
Dec 1 23:04:19 disk_monitor: Got SIGALRM...
Dec 2 00:19:22 rc_service: httpds 417:notify_rc start_webs_update
Aug 1 02:00:10 syslogd started: BusyBox v1.17.4
Aug 1 02:00:10 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST)
Aug 1 02:00:10 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017
Aug 1 02:00:10 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f
Aug 1 02:00:10 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug 1 02:00:10 kernel: Machine: Northstar Prototype
Aug 1 02:00:10 kernel: Ignoring unrecognised tag 0x00000000
Aug 1 02:00:10 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug 1 02:00:11 kernel: PCI: Fixing up bus 0
Aug 1 02:00:11 kernel: VFS: Disk quotas dquot_6.5.2
Aug 1 02:00:11 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2adf7004, fsr=0x1c06, pc=0x8016ff34 lr=0x616e6669 ignored.
Aug 1 02:00:12 stop_nat_rules: apply the redirect_rules!
Aug 1 02:00:18 hour monitor: daemon is starting
Aug 1 02:00:18 hour monitor: daemon terminates
Aug 1 02:00:18 miniupnpd[463]: version 1.9 started
Aug 1 02:00:18 miniupnpd[463]: HTTP listening on port 48188
Aug 1 02:00:18 miniupnpd[463]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:19 pppd[472]: local IP address 93.138.35.49
Aug 1 02:00:19 pppd[472]: remote IP address 172.29.252.64
Aug 1 02:00:28 miniupnpd[463]: shutting down MiniUPnPd
Aug 1 02:00:32 miniupnpd[746]: HTTP listening on port 38934
Aug 1 02:00:35 miniupnpd[752]: version 1.9 started
Aug 1 02:00:35 miniupnpd[752]: HTTP listening on port 34247
Aug 1 02:00:35 miniupnpd[752]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 2 05:01:51 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 2 05:01:52 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 2 05:01:52 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 2 05:01:52 rc_service: ntp 749:notify_rc restart_upnp
Dec 2 05:01:52 miniupnpd[752]: shutting down MiniUPnPd
Dec 2 05:01:53 rc_service: ntp 749:notify_rc restart_diskmon
Dec 2 05:01:53 disk_monitor: Finish
Dec 2 05:01:54 miniupnpd[772]: version 1.9 started
Dec 2 05:01:54 miniupnpd[772]: HTTP listening on port 39930
Dec 2 05:01:54 miniupnpd[772]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 2 05:01:55 disk monitor: be idle
Dec 2 05:01:55 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 2 05:01:56 rc_service: zcip 783:notify_rc start_firewall
Dec 2 05:01:56 zcip client: configured 169.254.163.221
Dec 2 05:01:57 miniupnpd[772]: shutting down MiniUPnPd
Dec 2 05:01:57 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 2 05:01:59 miniupnpd[829]: version 1.9 started
Dec 2 05:01:59 miniupnpd[829]: HTTP listening on port 60719
Dec 2 05:01:59 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 2 23:04:36 disk_monitor: Got SIGALRM...
Dec 2 23:24:42 rc_service: httpds 417:notify_rc start_webs_update
Dec 3 05:00:08 kernel: Emergency Sync complete
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2addf004, fsr=0x1c06, pc=0x2abe2c58 lr=0x17bd8 ignored.
Aug 1 02:00:18 miniupnpd[456]: version 1.9 started
Aug 1 02:00:18 miniupnpd[456]: HTTP listening on port 58051
Aug 1 02:00:18 miniupnpd[456]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:18 pppd[468]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[468]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:00:19 pppd[468]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 pppd[468]: PAP authentication succeeded
Aug 1 02:00:19 pppd[468]: peer from calling number 84:B5:9C:A4:4D:B7 authorized
Aug 1 02:00:19 pppd[468]: local IP address 78.1.145.97
Aug 1 02:00:19 pppd[468]: remote IP address 172.29.252.59
Aug 1 02:00:20 rc_service: ip-up 500:notify_rc stop_upnp
Aug 1 02:00:28 miniupnpd[456]: shutting down MiniUPnPd
Aug 1 02:00:31 miniupnpd[746]: HTTP listening on port 34838
Aug 1 02:00:32 rc_service: ip-up 500:notify_rc start_upnp
Aug 1 02:00:36 miniupnpd[751]: HTTP listening on port 43021
Aug 1 02:00:38 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 3 05:01:41 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 3 05:01:41 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 3 05:01:41 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 3 05:01:41 rc_service: ntp 749:notify_rc restart_upnp
Dec 3 05:01:41 miniupnpd[751]: shutting down MiniUPnPd
Dec 3 05:01:42 rc_service: ntp 749:notify_rc restart_diskmon
Dec 3 05:01:43 disk_monitor: Finish
Dec 3 05:01:43 miniupnpd[777]: version 1.9 started
Dec 3 05:01:43 miniupnpd[777]: HTTP listening on port 58098
Dec 3 05:01:43 miniupnpd[777]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 3 05:01:46 disk monitor: be idle
Dec 3 05:01:46 rc_service: zcip 779:notify_rc start_firewall
Dec 3 05:01:46 zcip client: configured 169.254.163.221
Dec 3 05:01:48 miniupnpd[777]: shutting down MiniUPnPd
Dec 3 05:01:48 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 3 05:01:51 miniupnpd[821]: version 1.9 started
Dec 3 05:01:51 miniupnpd[821]: HTTP listening on port 38041
Dec 3 05:01:51 miniupnpd[821]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 3 14:38:57 rc_service: httpds 417:notify_rc start_webs_update
Dec 3 16:27:13 rc_service: httpds 417:notify_rc start_webs_update
Dec 3 23:04:15 disk_monitor: Got SIGALRM...
Dec 4 05:00:31 kernel: Emergency Sync complete
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ace0004, fsr=0x1c06, pc=0x2aefa014 lr=0xed80 ignored.
Aug 1 02:00:18 miniupnpd[458]: version 1.9 started
Aug 1 02:00:18 miniupnpd[458]: HTTP listening on port 57289
Aug 1 02:00:18 miniupnpd[458]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:18 pppd[473]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[473]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:19 pppd[473]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:00:19 pppd[473]: local IP address 93.138.65.23
Aug 1 02:00:19 pppd[473]: remote IP address 172.29.252.64
Aug 1 02:00:28 miniupnpd[458]: shutting down MiniUPnPd
Aug 1 02:00:32 miniupnpd[749]: version 1.9 started
Aug 1 02:00:32 miniupnpd[749]: HTTP listening on port 56477
Aug 1 02:00:32 miniupnpd[749]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:32 miniupnpd[749]: shutting down MiniUPnPd
Aug 1 02:00:34 miniupnpd[753]: version 1.9 started
Aug 1 02:00:34 miniupnpd[753]: HTTP listening on port 45468
Aug 1 02:00:34 miniupnpd[753]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 4 05:02:10 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 4 05:02:10 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 4 05:02:10 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 4 05:02:10 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 4 05:02:10 rc_service: ntp 751:notify_rc restart_upnp
Dec 4 05:02:10 miniupnpd[753]: shutting down MiniUPnPd
Dec 4 05:02:11 miniupnpd[777]: version 1.9 started
Dec 4 05:02:11 miniupnpd[777]: HTTP listening on port 34593
Dec 4 05:02:11 miniupnpd[777]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 4 05:02:11 rc_service: ntp 751:notify_rc restart_diskmon
Dec 4 05:02:12 disk_monitor: Finish
Dec 4 05:02:14 disk monitor: be idle
Dec 4 05:02:15 rc_service: zcip 794:notify_rc start_firewall
Dec 4 05:02:15 zcip client: configured 169.254.163.221
Dec 4 05:02:15 miniupnpd[777]: shutting down MiniUPnPd
Dec 4 05:02:15 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 4 05:02:16 miniupnpd[830]: version 1.9 started
Dec 4 05:02:16 miniupnpd[830]: HTTP listening on port 58999
Dec 4 05:02:16 miniupnpd[830]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 4 23:04:47 disk_monitor: Got SIGALRM...
Dec 4 23:48:21 miniupnpd[830]: send(res_buf): Connection reset by peer
Dec 4 23:56:56 rc_service: httpds 417:notify_rc start_webs_update
Dec 4 23:57:13 rc_service: httpds 417:notify_rc start_webs_update
Dec 5 00:24:08 miniupnpd[830]: upnp_event_recv: recv(): Connection reset by peer
Dec 5 00:38:33 miniupnpd[830]: upnp_event_recv: recv(): Connection reset by peer
Dec 5 00:51:09 miniupnpd[830]: upnp_event_recv: recv(): Connection reset by peer
Dec 5 05:00:09 kernel: Emergency Sync complete
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2adef004, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac983b0, fsr=0x1c06, pc=0x7f190b38 lr=0x80208820 ignored.
Aug 1 02:00:18 miniupnpd[459]: HTTP listening on port 34377
Aug 1 02:00:19 pppd[472]: local IP address 93.138.33.193
Aug 1 02:00:20 rc_service: ip-up 505:notify_rc start_firewall
Aug 1 02:00:20 rc_service: ip-up 505:notify_rc stop_upnp
Aug 1 02:00:27 miniupnpd[459]: shutting down MiniUPnPd
Aug 1 02:00:31 miniupnpd[747]: version 1.9 started
Aug 1 02:00:31 miniupnpd[747]: HTTP listening on port 33348
Aug 1 02:00:31 miniupnpd[747]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:31 rc_service: ip-up 505:notify_rc start_upnp
Aug 1 02:00:31 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:00:31 miniupnpd[747]: shutting down MiniUPnPd
Aug 1 02:00:34 miniupnpd[753]: HTTP listening on port 46842
Dec 5 05:01:47 rc_service: ntp 750:notify_rc restart_upnp
Dec 5 05:01:47 miniupnpd[753]: shutting down MiniUPnPd
Dec 5 05:01:47 rc_service: ntp 750:notify_rc restart_diskmon
Dec 5 05:01:48 miniupnpd[767]: version 1.9 started
Dec 5 05:01:48 miniupnpd[767]: HTTP listening on port 34835
Dec 5 05:01:48 miniupnpd[767]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 5 05:01:48 disk_monitor: Finish
Dec 5 05:01:49 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 5 05:01:49 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 5 05:01:49 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 5 05:01:50 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 5 05:01:50 syslog: Generating SSL certificate...
Dec 5 05:01:51 disk monitor: be idle
Dec 5 05:01:51 syslog: Generating SSL certificate...
Dec 5 05:01:54 rc_service: zcip 817:notify_rc start_firewall
Dec 5 05:01:54 zcip client: configured 169.254.163.221
Dec 5 05:01:55 miniupnpd[767]: shutting down MiniUPnPd
Dec 5 05:01:55 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 5 05:01:57 miniupnpd[845]: version 1.9 started
Dec 5 05:01:57 miniupnpd[845]: HTTP listening on port 35000
Dec 5 05:01:57 miniupnpd[845]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 5 17:13:06 rc_service: httpds 417:notify_rc start_webs_update
Dec 5 17:19:06 rc_service: httpds 417:notify_rc restart_firewall;restart_qos
Dec 5 17:19:07 miniupnpd[845]: shutting down MiniUPnPd
Dec 5 17:19:07 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 5 17:19:08 miniupnpd[11742]: version 1.9 started
Dec 5 17:19:08 miniupnpd[11742]: HTTP listening on port 59119
Dec 5 17:19:08 miniupnpd[11742]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 5 17:19:09 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 5 17:19:09 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 5 17:19:09 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 5 17:19:09 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 5 17:19:09 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec 5 17:19:13 rc_service: httpds 417:notify_rc restart_firewall;restart_qos
Dec 5 17:19:14 miniupnpd[11742]: shutting down MiniUPnPd
Dec 5 17:19:14 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 5 17:19:17 miniupnpd[11825]: version 1.9 started
Dec 5 17:19:17 miniupnpd[11825]: HTTP listening on port 36609
Dec 5 17:19:17 miniupnpd[11825]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 5 17:19:17 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 5 17:19:17 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 5 17:19:17 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 5 17:19:17 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 5 17:19:18 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec 5 17:27:34 rc_service: httpds 417:notify_rc restart_firewall;restart_qos
Dec 5 17:27:35 miniupnpd[11825]: shutting down MiniUPnPd
Dec 5 17:27:35 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 5 17:27:37 miniupnpd[12024]: version 1.9 started
Dec 5 17:27:37 miniupnpd[12024]: HTTP listening on port 50107
Dec 5 17:27:37 miniupnpd[12024]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 5 17:27:38 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 5 17:27:38 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 5 17:27:38 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 5 17:27:38 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 5 17:27:38 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec 5 17:38:51 rc_service: httpds 417:notify_rc start_webs_update
Dec 5 23:04:12 disk_monitor: Got SIGALRM...
Aug 1 02:00:09 syslogd started: BusyBox v1.17.4
Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST)
Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017
Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f
Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug 1 02:00:09 kernel: Machine: Northstar Prototype
Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000
Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem
Aug 1 02:00:10 kernel: Virtual kernel memory layout:
Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB)
Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB)
Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB)
Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB)
Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB)
Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB)
Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512
Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB
Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled
Aug 1 02:00:10 kernel: bio: create slab at 0
Aug 1 02:00:10 kernel: PCI: no core
Aug 1 02:00:10 kernel: PCI: Fixing up bus 0
Aug 1 02:00:10 kernel: PCI: Fixing up bus 1
Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!!
Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2
Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 1 02:00:11 kernel: Registering the dns_resolver key type
Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel.
Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint
Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0
Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1
Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8
Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20
Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled
Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393)
Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0
Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1
Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae3c000, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ad133b0, fsr=0x1c06, pc=0x7f190b38 lr=0x80208820 ignored.
Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257)
Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________
Aug 1 02:00:11 kernel: <4>Emergency Sync complete
Aug 1 02:00:11 kernel: <4>gro disabled
Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt
Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state
Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode
Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating
Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state
Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state
Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state
Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state
Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp
Aug 1 02:00:11 kernel: <0>Restarting system.
Aug 1 02:00:11 kernel: ____________________________________________________________________________
Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules!
Aug 1 02:00:11 WAN Connection: Fail to connect with some issues.
Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL
Aug 1 02:00:17 disk monitor: be idle
Aug 1 02:00:17 hour monitor: daemon is starting
Aug 1 02:00:17 hour monitor: daemon terminates
Aug 1 02:00:17 jffs2: valid logs(1)
Aug 1 02:00:18 miniupnpd[464]: HTTP listening on port 40151
Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep
Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep
Aug 1 02:00:20 kernel: SCSI subsystem initialized
Aug 1 02:00:41 rc_service: zcip 659:notify_rc start_firewall
Aug 1 02:00:41 zcip client: configured 169.254.163.221
Aug 1 02:00:42 miniupnpd[464]: shutting down MiniUPnPd
Aug 1 02:00:43 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:43 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:44 miniupnpd[715]: version 1.9 started
Aug 1 02:00:44 miniupnpd[715]: HTTP listening on port 51086
Aug 1 02:00:44 miniupnpd[715]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:49 pppd[472]: No response to PAP authenticate-requests
Aug 1 02:00:49 pppd[472]: Connection terminated.
Aug 1 02:00:59 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:59 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:00 pppd[472]: PAP authentication succeeded
Aug 1 02:01:00 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:01:00 pppd[472]: local IP address 93.138.14.31
Aug 1 02:01:00 pppd[472]: remote IP address 172.29.252.64
Aug 1 02:01:01 rc_service: ip-up 742:notify_rc start_firewall
Aug 1 02:01:02 miniupnpd[715]: shutting down MiniUPnPd
Aug 1 02:01:02 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:01:02 rc_service: ip-up 742:notify_rc stop_upnp
Aug 1 02:01:02 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:01:03 WAN Connection: WAN was restored.
Aug 1 02:01:03 miniupnpd[806]: version 1.9 started
Aug 1 02:01:03 miniupnpd[806]: HTTP listening on port 56297
Aug 1 02:01:03 miniupnpd[806]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:03 rc_service: ip-up 742:notify_rc start_upnp
Aug 1 02:01:03 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:01:03 miniupnpd[806]: shutting down MiniUPnPd
Aug 1 02:01:05 miniupnpd[810]: version 1.9 started
Aug 1 02:01:05 miniupnpd[810]: HTTP listening on port 48458
Aug 1 02:01:05 miniupnpd[810]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:06 ntp: start NTP update
Dec 6 05:02:21 rc_service: ntp 808:notify_rc restart_upnp
Dec 6 05:02:21 miniupnpd[810]: shutting down MiniUPnPd
Dec 6 05:02:22 miniupnpd[818]: version 1.9 started
Dec 6 05:02:22 miniupnpd[818]: HTTP listening on port 39117
Dec 6 05:02:22 miniupnpd[818]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 6 05:02:22 rc_service: ntp 808:notify_rc restart_diskmon
Dec 6 05:02:22 disk_monitor: Finish
Dec 6 05:02:23 disk monitor: be idle
Dec 6 05:02:23 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 6 05:02:23 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 6 05:02:23 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 6 05:02:23 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 6 05:02:23 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec 6 23:05:05 disk_monitor: Got SIGALRM...
Dec 7 05:00:09 kernel: Emergency Sync complete
Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug 1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs"
Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2"
Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram"
Aug 1 02:00:11 kernel: === PPTP init ===
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae82000, fsr=0x1c06, pc=0x80171f68 lr=0x800cc4c4 ignored.
Aug 1 02:00:17 syslog: Generating SSL certificate...
Aug 1 02:00:17 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1]
Aug 1 02:00:17 kernel: Attempt to kill tasklet from interrupt
Aug 1 02:00:18 miniupnpd[464]: HTTP listening on port 48188
Aug 1 02:00:19 pppd[472]: local IP address 93.139.184.227
Aug 1 02:00:19 pppd[472]: remote IP address 172.29.252.89
Aug 1 02:00:19 rc_service: ip-up 502:notify_rc start_firewall
Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:00:31 miniupnpd[746]: version 1.9 started
Aug 1 02:00:31 miniupnpd[746]: HTTP listening on port 47285
Aug 1 02:00:31 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:31 rc_service: ip-up 502:notify_rc start_upnp
Aug 1 02:00:31 miniupnpd[746]: shutting down MiniUPnPd
Aug 1 02:00:33 miniupnpd[751]: version 1.9 started
Aug 1 02:00:33 miniupnpd[751]: HTTP listening on port 41997
Aug 1 02:00:33 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:35 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Aug 1 02:00:36 ntp: start NTP update
Aug 1 02:00:36 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 7 05:01:38 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 7 05:01:38 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec 7 05:01:38 rc_service: ntp 749:notify_rc restart_upnp
Dec 7 05:01:38 miniupnpd[751]: shutting down MiniUPnPd
Dec 7 05:01:39 rc_service: ntp 749:notify_rc restart_diskmon
Dec 7 05:01:39 miniupnpd[781]: version 1.9 started
Dec 7 05:01:39 miniupnpd[781]: HTTP listening on port 53280
Dec 7 05:01:39 miniupnpd[781]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 7 05:01:40 disk_monitor: Finish
Dec 7 05:01:42 disk monitor: be idle
Dec 7 05:01:43 rc_service: zcip 790:notify_rc start_firewall
Dec 7 05:01:43 zcip client: configured 169.254.163.221
Dec 7 05:01:45 miniupnpd[781]: shutting down MiniUPnPd
Dec 7 05:01:45 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 7 05:01:48 miniupnpd[831]: version 1.9 started
Dec 7 05:01:48 miniupnpd[831]: HTTP listening on port 37489
Dec 7 05:01:48 miniupnpd[831]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 7 11:46:32 kernel: wl1: PHYTX error
Dec 7 11:46:33 kernel: wl1: PHYTX error
Dec 7 17:38:38 rc_service: httpds 417:notify_rc start_webs_update
Dec 7 17:38:56 rc_service: httpds 417:notify_rc restart_firewall;restart_qos
Dec 7 17:38:57 miniupnpd[831]: shutting down MiniUPnPd
Dec 7 17:38:57 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 7 17:38:58 miniupnpd[11999]: version 1.9 started
Dec 7 17:38:58 miniupnpd[11999]: HTTP listening on port 54246
Dec 7 17:38:58 miniupnpd[11999]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 7 17:38:59 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 7 17:38:59 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 7 17:38:59 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 7 17:38:59 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 7 23:04:25 disk_monitor: Got SIGALRM...
Aug 1 02:00:10 kernel: pflash: found no supported devices
Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30
Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash":
Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot"
Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae13000, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac803b0, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored.
Aug 1 02:00:18 miniupnpd[458]: HTTP listening on port 38078
Aug 1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:18 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:00:18 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 pppd[472]: local IP address 93.139.145.162
Aug 1 02:00:19 rc_service: ip-up 500:notify_rc start_firewall
Aug 1 02:00:22 WAN Connection: WAN was restored.
Aug 1 02:00:27 miniupnpd[458]: shutting down MiniUPnPd
Aug 1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:32 miniupnpd[755]: version 1.9 started
Aug 1 02:00:32 miniupnpd[755]: HTTP listening on port 41125
Aug 1 02:00:32 miniupnpd[755]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:32 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:00:32 miniupnpd[755]: shutting down MiniUPnPd
Aug 1 02:00:34 miniupnpd[759]: version 1.9 started
Aug 1 02:00:34 miniupnpd[759]: HTTP listening on port 34872
Aug 1 02:00:34 miniupnpd[759]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:36 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 8 05:01:57 rc_service: ntp 757:notify_rc restart_upnp
Dec 8 05:01:57 miniupnpd[759]: shutting down MiniUPnPd
Dec 8 05:01:57 miniupnpd[789]: version 1.9 started
Dec 8 05:01:57 miniupnpd[789]: HTTP listening on port 39839
Dec 8 05:01:57 miniupnpd[789]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 8 05:01:58 rc_service: ntp 757:notify_rc restart_diskmon
Dec 8 05:01:58 disk_monitor: Finish
Dec 8 05:01:58 disk monitor: be idle
Dec 8 05:02:02 rc_service: zcip 801:notify_rc start_firewall
Dec 8 05:02:02 zcip client: configured 169.254.163.221
Dec 8 05:02:02 miniupnpd[789]: shutting down MiniUPnPd
Dec 8 05:02:02 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 8 05:02:03 miniupnpd[829]: version 1.9 started
Dec 8 05:02:03 miniupnpd[829]: HTTP listening on port 54681
Dec 8 05:02:03 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae70004, fsr=0x1c06, pc=0x2ac34c58 lr=0x17bd8 ignored.
Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1403)
Aug 1 02:00:11 kernel: <4>Exception stack(0x849fffb0 to 0x849ffff8)
Aug 1 02:00:11 kernel: <4>ffa0: 00000001 7ea52ca0 7ea52c20 00000000
Aug 1 02:00:11 kernel: <4>ffc0: 7ea52da8 7ea52c20 0000000a 0000008e 00000007 7ea52c20 00027078 00000001
Aug 1 02:00:11 kernel: <4>ffe0: 000258c4 7ea52768 0000b318 2ab764cc 60000010 ffffffff
Aug 1 02:00:18 miniupnpd[465]: HTTP listening on port 35710
Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:21 pppd[472]: PAP authentication failed
Aug 1 02:00:41 rc_service: zcip 674:notify_rc start_firewall
Aug 1 02:00:41 pppd[472]: PAP authentication failed
Aug 1 02:00:42 miniupnpd[465]: shutting down MiniUPnPd
Aug 1 02:00:44 miniupnpd[731]: version 1.9 started
Aug 1 02:00:44 miniupnpd[731]: HTTP listening on port 46554
Aug 1 02:00:44 miniupnpd[731]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:46 stop_nat_rules: apply the redirect_rules!
Aug 1 02:00:48 pppd[472]: Connection terminated.
Aug 1 02:00:48 pppd[472]: Modem hangup
Aug 1 02:00:59 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:01:01 pppd[472]: PAP authentication failed
Aug 1 02:01:01 pppd[472]: Connection terminated.
Aug 1 02:01:12 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:12 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:14 pppd[472]: PAP authentication failed
Aug 1 02:01:14 pppd[472]: Connection terminated.
Aug 1 02:01:25 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:25 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:27 pppd[472]: PAP authentication failed
Aug 1 02:01:27 pppd[472]: Connection terminated.
Aug 1 02:01:38 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:38 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:38 pppd[472]: PAP authentication succeeded
Aug 1 02:01:38 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:01:39 pppd[472]: local IP address 93.138.5.224
Aug 1 02:01:39 pppd[472]: remote IP address 172.29.252.64
Aug 1 02:01:39 rc_service: ip-up 805:notify_rc start_firewall
Aug 1 02:01:40 miniupnpd[731]: shutting down MiniUPnPd
Aug 1 02:01:40 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:01:40 rc_service: ip-up 805:notify_rc stop_upnp
Aug 1 02:01:40 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:01:40 WAN Connection: WAN was restored.
Aug 1 02:01:41 miniupnpd[865]: version 1.9 started
Aug 1 02:01:41 miniupnpd[865]: HTTP listening on port 54744
Aug 1 02:01:41 miniupnpd[865]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:41 rc_service: ip-up 805:notify_rc start_upnp
Aug 1 02:01:41 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:01:41 miniupnpd[865]: shutting down MiniUPnPd
Aug 1 02:01:42 miniupnpd[868]: version 1.9 started
Aug 1 02:01:42 miniupnpd[868]: HTTP listening on port 37727
Aug 1 02:01:42 miniupnpd[868]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:43 ntp: start NTP update
Dec 8 22:53:22 rc_service: ntp 867:notify_rc restart_upnp
Dec 8 22:53:22 miniupnpd[868]: shutting down MiniUPnPd
Dec 8 22:53:23 miniupnpd[878]: version 1.9 started
Dec 8 22:53:23 miniupnpd[878]: HTTP listening on port 48606
Dec 8 22:53:23 miniupnpd[878]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 8 22:53:23 rc_service: ntp 867:notify_rc restart_diskmon
Dec 8 22:53:23 disk_monitor: Finish
Dec 8 22:53:24 disk monitor: be idle
Dec 8 22:53:24 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 8 22:53:24 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 8 22:53:24 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 8 22:53:24 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 8 22:54:06 rc_service: httpd 418:notify_rc start_webs_update
Dec 8 23:00:25 disk_monitor: Got SIGALRM...
Aug 1 02:00:10 kernel: * Invalid signature of oopsbuf: 37-F3-57-77-B5-75-56-55 (len 4283905917)
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae31004, fsr=0x1c06, pc=0x2abffbe8 lr=0x2ac00c7c ignored.
Aug 1 02:00:12 WAN Connection: Fail to connect with some issues.
Aug 1 02:00:17 RT-AC1200G+: start httpd - SSL
Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1]
Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt
Aug 1 02:00:18 miniupnpd[461]: version 1.9 started
Aug 1 02:00:18 miniupnpd[461]: HTTP listening on port 48173
Aug 1 02:00:18 miniupnpd[461]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:20 syslog: module ledtrig-usbdev not found in modules.dep
Aug 1 02:00:42 rc_service: zcip 654:notify_rc start_firewall
Aug 1 02:00:42 miniupnpd[461]: shutting down MiniUPnPd
Aug 1 02:00:44 miniupnpd[710]: version 1.9 started
Aug 1 02:00:44 miniupnpd[710]: HTTP listening on port 52585
Aug 1 02:00:44 miniupnpd[710]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:54 pppd[472]: Timeout waiting for PADO packets
Aug 1 02:02:09 pppd[472]: Timeout waiting for PADO packets
Aug 1 02:02:09 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:02:09 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:02:39 pppd[472]: PAP authentication succeeded
Aug 1 02:02:39 pppd[472]: peer from calling number 00:90:1A:A3:B7:70 authorized
Aug 1 02:02:40 pppd[472]: local IP address 93.142.212.104
Aug 1 02:02:40 pppd[472]: remote IP address 172.29.252.90
Aug 1 02:02:40 rc_service: ip-up 733:notify_rc start_firewall
Aug 1 02:02:41 miniupnpd[710]: shutting down MiniUPnPd
Aug 1 02:02:41 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:02:41 rc_service: ip-up 733:notify_rc stop_upnp
Aug 1 02:02:41 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:02:42 miniupnpd[792]: version 1.9 started
Aug 1 02:02:42 miniupnpd[792]: HTTP listening on port 44126
Aug 1 02:02:42 miniupnpd[792]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:02:42 rc_service: ip-up 733:notify_rc start_upnp
Aug 1 02:02:42 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:02:42 miniupnpd[792]: shutting down MiniUPnPd
Aug 1 02:02:43 miniupnpd[794]: version 1.9 started
Aug 1 02:02:43 miniupnpd[794]: HTTP listening on port 40806
Aug 1 02:02:43 miniupnpd[794]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:02:44 WAN Connection: WAN was restored.
Aug 1 02:02:44 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Aug 1 02:02:44 ntp: start NTP update
Aug 1 02:02:44 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Aug 1 02:02:44 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Aug 1 02:02:44 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 9 09:37:03 rc_service: ntp 795:notify_rc restart_upnp
Dec 9 09:37:03 miniupnpd[794]: shutting down MiniUPnPd
Dec 9 09:37:04 miniupnpd[824]: version 1.9 started
Dec 9 09:37:04 miniupnpd[824]: HTTP listening on port 48536
Dec 9 09:37:04 miniupnpd[824]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 9 09:37:04 rc_service: ntp 795:notify_rc restart_diskmon
Dec 9 09:37:04 disk_monitor: Finish
Dec 9 09:37:05 disk monitor: be idle
Dec 9 09:47:53 pppd[472]: Serial link appears to be disconnected.
Dec 9 09:47:54 WAN Connection: Fail to connect with some issues.
Dec 9 09:47:54 stop_nat_rules: apply the redirect_rules!
Dec 9 09:47:59 pppd[472]: Connection terminated.
Dec 9 09:47:59 pppd[472]: Modem hangup
Dec 9 09:48:09 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Dec 9 09:48:09 pppd[472]: Connect: ppp0 <--> eth0
Dec 9 09:48:13 pppd[472]: PAP authentication failed
Dec 9 09:48:13 pppd[472]: Connection terminated.
Dec 9 09:48:23 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Dec 9 09:48:23 pppd[472]: Connect: ppp0 <--> eth0
Dec 9 09:48:26 pppd[472]: PAP authentication failed
Dec 9 09:48:26 pppd[472]: Connection terminated.
Dec 9 09:48:36 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Dec 9 09:48:36 pppd[472]: Connect: ppp0 <--> eth0
Dec 9 09:48:39 pppd[472]: PAP authentication failed
Dec 9 09:48:39 pppd[472]: Connection terminated.
Dec 9 09:48:49 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Dec 9 09:48:49 pppd[472]: Connect: ppp0 <--> eth0
Dec 9 09:49:17 rc_service: httpds 417:notify_rc start_webs_update
Dec 9 09:49:19 pppd[472]: No response to PAP authenticate-requests
Dec 9 09:49:20 pppd[472]: Connection terminated.
Dec 9 09:49:30 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Dec 9 09:49:30 pppd[472]: Connect: ppp0 <--> eth0
Dec 9 09:49:54 rc_service: httpds 417:notify_rc start_webs_update
Dec 9 09:50:00 pppd[472]: PAP authentication succeeded
Dec 9 09:50:00 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized
Dec 9 09:50:01 pppd[472]: local IP address 93.139.178.251
Dec 9 09:50:01 pppd[472]: remote IP address 172.29.252.89
Dec 9 09:50:01 rc_service: ip-up 1308:notify_rc start_firewall
Dec 9 09:50:02 miniupnpd[824]: shutting down MiniUPnPd
Dec 9 09:50:02 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 9 09:50:02 rc_service: httpds 417:notify_rc reboot
Dec 9 09:50:02 rc_service: waitting "start_firewall" via ip-up ...
Dec 9 09:50:02 rc_service: ip-up 1308:notify_rc stop_upnp
Dec 9 09:50:03 miniupnpd[1352]: version 1.9 started
Dec 9 09:50:03 miniupnpd[1352]: HTTP listening on port 58937
Dec 9 09:50:03 miniupnpd[1352]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 9 09:50:04 pppd[472]: Connection terminated.
Dec 9 09:50:05 kernel: Attempt to kill tasklet from interrupt
Dec 9 09:50:05 stop_nat_rules: apply the redirect_rules!
Dec 9 09:50:06 iTunes: daemon is stoped
Dec 9 09:50:06 FTP Server: daemon is stoped
Dec 9 09:50:06 Samba Server: smb daemon is stoped
Dec 9 09:50:06 kernel: gro disabled
Aug 1 02:00:09 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem
Aug 1 02:00:09 kernel: Virtual kernel memory layout:
Aug 1 02:00:09 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Aug 1 02:00:09 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Aug 1 02:00:09 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Aug 1 02:00:09 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB)
Aug 1 02:00:09 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB)
Aug 1 02:00:09 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB)
Aug 1 02:00:09 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB)
Aug 1 02:00:09 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB)
Aug 1 02:00:09 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB)
Aug 1 02:00:10 kernel: Registering the dns_resolver key type
Aug 1 02:00:10 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2adf4004, fsr=0x1c06, pc=0x800ce0e0 lr=0x800c1154 ignored.
Aug 1 02:00:18 syslog: Generating SSL certificate...
Aug 1 02:00:18 miniupnpd[457]: version 1.9 started
Aug 1 02:00:18 miniupnpd[457]: HTTP listening on port 36504
Aug 1 02:00:18 miniupnpd[457]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:18 pppd[466]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[466]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:00:19 pppd[466]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 pppd[466]: PAP authentication succeeded
Aug 1 02:00:19 pppd[466]: peer from calling number 84:B5:9C:A4:4D:B7 authorized
Aug 1 02:00:19 pppd[466]: local IP address 93.141.119.37
Aug 1 02:00:19 pppd[466]: remote IP address 172.29.252.59
Aug 1 02:00:20 rc_service: ip-up 509:notify_rc start_firewall
Aug 1 02:00:20 rc_service: ip-up 509:notify_rc stop_upnp
Aug 1 02:00:21 WAN Connection: WAN was restored.
Aug 1 02:00:26 miniupnpd[457]: shutting down MiniUPnPd
Aug 1 02:00:26 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:00:28 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:29 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:29 miniupnpd[750]: version 1.9 started
Aug 1 02:00:29 miniupnpd[750]: HTTP listening on port 56881
Aug 1 02:00:29 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:29 rc_service: ip-up 509:notify_rc start_upnp
Aug 1 02:00:29 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:00:29 miniupnpd[750]: shutting down MiniUPnPd
Aug 1 02:00:31 miniupnpd[753]: version 1.9 started
Aug 1 02:00:31 miniupnpd[753]: HTTP listening on port 38145
Aug 1 02:00:31 miniupnpd[753]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:32 ntp: start NTP update
Dec 9 09:51:26 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 9 09:51:26 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 9 09:51:26 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 9 09:51:26 rc_service: ntp 752:notify_rc restart_upnp
Dec 9 09:51:26 miniupnpd[753]: shutting down MiniUPnPd
Dec 9 09:51:27 miniupnpd[775]: version 1.9 started
Dec 9 09:51:27 miniupnpd[775]: HTTP listening on port 55434
Dec 9 09:51:27 miniupnpd[775]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 9 09:51:27 rc_service: ntp 752:notify_rc restart_diskmon
Dec 9 09:51:27 disk_monitor: Finish
Dec 9 09:51:28 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 9 09:51:29 disk monitor: be idle
Dec 9 09:51:34 rc_service: zcip 801:notify_rc start_firewall
Dec 9 09:51:34 zcip client: configured 169.254.163.221
Dec 9 09:51:34 miniupnpd[775]: shutting down MiniUPnPd
Dec 9 09:51:34 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 9 09:51:35 miniupnpd[829]: version 1.9 started
Dec 9 09:51:35 miniupnpd[829]: HTTP listening on port 52933
Dec 9 09:51:35 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 9 10:00:30 disk_monitor: Got SIGALRM...
Dec 9 23:02:13 disk_monitor: Got SIGALRM...
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae35004, fsr=0x1c06, pc=0x2abb0be8 lr=0x2abb1c7c ignored.
Aug 1 02:00:18 miniupnpd[465]: HTTP listening on port 52007
Aug 1 02:00:18 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:19 pppd[472]: PAP authentication succeeded
Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:00:19 pppd[472]: local IP address 93.138.84.144
Aug 1 02:00:29 miniupnpd[465]: shutting down MiniUPnPd
Aug 1 02:00:29 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:00:32 miniupnpd[750]: version 1.9 started
Aug 1 02:00:32 miniupnpd[750]: HTTP listening on port 42798
Aug 1 02:00:32 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:33 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:00:35 miniupnpd[755]: HTTP listening on port 48602
Dec 10 05:01:57 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 10 05:01:57 rc_service: ntp 753:notify_rc restart_upnp
Dec 10 05:01:57 miniupnpd[755]: shutting down MiniUPnPd
Dec 10 05:01:57 miniupnpd[772]: version 1.9 started
Dec 10 05:01:57 miniupnpd[772]: HTTP listening on port 55124
Dec 10 05:01:57 miniupnpd[772]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 10 05:01:57 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 10 05:01:58 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 10 05:01:58 rc_service: ntp 753:notify_rc restart_diskmon
Dec 10 05:01:58 disk_monitor: Finish
Dec 10 05:01:58 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 10 05:02:00 disk monitor: be idle
Dec 10 05:02:01 rc_service: zcip 788:notify_rc start_firewall
Dec 10 05:02:01 zcip client: configured 169.254.163.221
Dec 10 05:02:03 miniupnpd[772]: shutting down MiniUPnPd
Dec 10 05:02:03 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 10 05:02:04 miniupnpd[825]: version 1.9 started
Dec 10 05:02:04 miniupnpd[825]: HTTP listening on port 48968
Dec 10 05:02:04 miniupnpd[825]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:11 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Aug 1 02:00:11 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug 1 02:00:11 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem
Aug 1 02:00:11 kernel: Virtual kernel memory layout:
Aug 1 02:00:11 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Aug 1 02:00:11 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Aug 1 02:00:11 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Aug 1 02:00:11 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB)
Aug 1 02:00:11 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB)
Aug 1 02:00:11 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB)
Aug 1 02:00:11 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB)
Aug 1 02:00:11 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB)
Aug 1 02:00:11 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB)
Aug 1 02:00:11 kernel: Mount-cache hash table entries: 512
Aug 1 02:00:11 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB
Aug 1 02:00:11 kernel: ACP (Accelerator Coherence Port) enabled
Aug 1 02:00:11 kernel: bio: create slab at 0
Aug 1 02:00:12 kernel: PCI: no core
Aug 1 02:00:12 kernel: PCI: Fixing up bus 0
Aug 1 02:00:12 kernel: PCI: Fixing up bus 1
Aug 1 02:00:12 kernel: PCI: scanning bus 0 !!!
Aug 1 02:00:12 kernel: VFS: Disk quotas dquot_6.5.2
Aug 1 02:00:12 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 1 02:00:12 kernel: pflash: found no supported devices
Aug 1 02:00:12 kernel: bcmsflash: squash filesystem found at block 30
Aug 1 02:00:12 kernel: Creating 5 MTD partitions on "bcmsflash":
Aug 1 02:00:12 kernel: 0x000000000000-0x000000040000 : "boot"
Aug 1 02:00:12 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug 1 02:00:12 kernel: 0x0000001ef614-0x000000d30000 : "rootfs"
Aug 1 02:00:12 kernel: 0x000000d30000-0x000000ff0000 : "jffs2"
Aug 1 02:00:12 kernel: 0x000000ff0000-0x000001000000 : "nvram"
Aug 1 02:00:12 kernel: === PPTP init ===
Aug 1 02:00:12 kernel: Registering the dns_resolver key type
Aug 1 02:00:12 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Aug 1 02:00:12 kernel: ctf: module license 'Proprietary' taints kernel.
Aug 1 02:00:12 kernel: Disabling lock debugging due to kernel taint
Aug 1 02:00:12 kernel: et_module_init: passivemode set to 0x0
Aug 1 02:00:12 kernel: et_module_init: txworkq set to 0x1
Aug 1 02:00:12 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug 1 02:00:12 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8
Aug 1 02:00:12 kernel: et_module_init: et_rxlazy_framecnt set to 0x20
Aug 1 02:00:12 kernel: bcm_robo_enable_switch: EEE is disabled
Aug 1 02:00:12 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393)
Aug 1 02:00:12 kernel: wl_module_init: passivemode set to 0x0
Aug 1 02:00:12 kernel: wl_module_init: txworkq set to 0x1
Aug 1 02:00:12 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
Aug 1 02:00:12 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 02:00:12 kernel: External imprecise Data abort at addr=0x2ae99000, fsr=0x1c06, pc=0x800c2aec lr=0x800ce1c8 ignored.
Aug 1 02:00:12 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 02:00:12 kernel: [dump prev ops] from 87000000, local len(8179)
Aug 1 02:00:12 kernel: _ Reboot message ... _______________________________________________________
Aug 1 02:00:12 kernel: <0>Kernel panic - not syncing: Out of memory: system-wide panic_on_oom is enabled
Aug 1 02:00:12 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<802fec2c>] (panic+0x7c/0x1a4)
Aug 1 02:00:12 kernel: <4>[<802fec2c>] (panic+0x7c/0x1a4) from [<80091038>] (out_of_memory+0x2c8/0x328)
Aug 1 02:00:12 kernel: <4>[<80091038>] (out_of_memory+0x2c8/0x328) from [<800942c0>] (__alloc_pages_nodemask+0x66c/0x694)
Aug 1 02:00:12 kernel: <4>[<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) from [<80096000>] (__do_page_cache_readahead+0x140/0x2d0)
Aug 1 02:00:12 kernel: <4>[<80096000>] (__do_page_cache_readahead+0x140/0x2d0) from [<80096440>] (ra_submit+0x28/0x30)
Aug 1 02:00:12 kernel: <4>[<80096440>] (ra_submit+0x28/0x30) from [<8008e5d0>] (filemap_fault+0x42c/0x454)
Aug 1 02:00:12 kernel: <4>[<8008e5d0>] (filemap_fault+0x42c/0x454) from [<800a315c>] (__do_fault.clone.60+0x54/0x4c8)
Aug 1 02:00:12 kernel: <4>[<800a315c>] (__do_fault.clone.60+0x54/0x4c8) from [<800a67c4>] (handle_mm_fault+0x114/0x934)
Aug 1 02:00:12 kernel: <4>[<800a67c4>] (handle_mm_fault+0x114/0x934) from [<8003fd90>] (do_page_fault+0x178/0x1ec)
Aug 1 02:00:13 kernel: <4>[<8003fd90>] (do_page_fault+0x178/0x1ec) from [<80038298>] (do_PrefetchAbort+0x30/0x9c)
Aug 1 02:00:13 kernel: <4>[<80038298>] (do_PrefetchAbort+0x30/0x9c) from [<803bf2e0>] (ret_from_exception+0x0/0x10)
Aug 1 02:00:13 kernel: <4>Exception stack(0x8534ffb0 to 0x8534fff8)
Aug 1 02:00:13 kernel: <4>ffa0: 0000000e 00000008 7eae7c48 00000000
Aug 1 02:00:13 kernel: <4>ffc0: 7eae7c48 00000001 7eae7e94 000000b3 0000d1f0 0000ec14 7eae7e08 00000000
Aug 1 02:00:13 kernel: <4>ffe0: 2aef35b4 7eae7948 2ae9b254 0003be5c 00000010 ffffffff
Aug 1 02:00:13 kernel: <0>Rebooting in 3 seconds..osl_ctfpool_add: skb alloc of len 2272 failed
Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed
Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed
Aug 1 02:00:13 kernel: <4>__alloc_pages_slowpath: 54706 callbacks suppressed
Aug 1 02:00:13 kernel: <4>watchdog: page allocation failure. order:0, mode:0x4020
Aug 1 02:00:13 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694)
Aug 1 02:00:13 kernel: <4>[<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0)
Aug 1 02:00:13 kernel: <4>[<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8)
Aug 1 02:00:13 kernel: <4>[<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104)
Aug 1 02:00:13 kernel: <4>[<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac)
Aug 1 02:00:13 kernel: <4>[<801fc860>] (osl_alloc_skb+0x50/0xac) from [<803c2cc0>] (osl_pktget+0x6c/0x170)
Aug 1 02:00:13 kernel: <4>[<803c2cc0>] (osl_pktget+0x6c/0x170) from [<803c1a34>] (_dma_rxfill+0x3c8/0x51c)
Aug 1 02:00:13 kernel: <4>[<803c1a34>] (_dma_rxfill+0x3c8/0x51c) from [<7f289fc0>] (wlc_bmac_recv+0x368/0x380 [wl])
Aug 1 02:00:13 kernel: <4>unwind: Index not found 7f289fc0
Aug 1 02:00:13 kernel: <4>Mem-info:
Aug 1 02:00:13 kernel: <4>DMA per-cpu:
Aug 1 02:00:13 kernel: <4>CPU 0: hi: 42, btch: 7 usd: 6
Aug 1 02:00:13 kernel: <4>active_anon:941 inactive_anon:953 isolated_anon:0
Aug 1 02:00:13 kernel: <4> active_file:0 inactive_file:0 isolated_file:32
Aug 1 02:00:13 kernel: <4> unevictable:0 dirty:0 writeback:0 unstable:0
Aug 1 02:00:13 kernel: <4> free:383 slab_reclaimable:82 slab_unreclaimable:25949
Aug 1 02:00:13 kernel: <4> mapped:16 shmem:172 pagetables:151 bounce:0
Aug 1 02:00:13 kernel: <4>DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:3764kB inactive_anon:3812kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):128kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:64kB shmem:688kB slab_reclaimable:328kB slab_unreclaimable:103796kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Aug 1 02:00:13 kernel: <4>lowmem_reserve[]: 0 0 0
Aug 1 02:00:13 kernel: <4>DMA: 111*4kB 52*8kB 28*16kB 1*32kB 1*64kB 1*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 1532kB
Aug 1 02:00:13 kernel: <4>185 total pagecache pages
Aug 1 02:00:13 kernel: <4>0 pages in swap cache
Aug 1 02:00:13 kernel: <4>Swap cache stats: add 0, delete 0, find 0/0
Aug 1 02:00:13 kernel: <4>Free swap = 0kB
Aug 1 02:00:13 kernel: <4>Total swap = 0kB
Aug 1 02:00:13 kernel: <4>32768 pages of RAM
Aug 1 02:00:13 kernel: <4>571 free pages
Aug 1 02:00:13 kernel: <4>1352 reserved pages
Aug 1 02:00:13 kernel: <4>8182 slab pages
Aug 1 02:00:13 kernel: <4>266 pages shared
Aug 1 02:00:13 kernel: <4>0 pages swap cached
Aug 1 02:00:13 kernel: <4>SLUB: Unable to allocate memory on node -1 (gfp=0x20)
Aug 1 02:00:13 kernel: <4> cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0
Aug 1 02:00:13 kernel: <4> node 0: slabs: 3297, objs: 20972, free: 0
Aug 1 02:00:13 kernel: <4>[<803b28d0>] (__alloc_skb+0x54/0x104) from [<802179c0>] (pskb_copy+0x20/0x184)
Aug 1 02:00:13 kernel: <4>[<802179c0>] (pskb_copy+0x20/0x184) from [<801fcbc4>] (osl_pktdup+0x68/0x134)
Aug 1 02:00:13 kernel: <4>[<801fcbc4>] (osl_pktdup+0x68/0x134) from [<7f28edf4>] (wlc_recvdata_sendup+0x714/0x768 [wl])
Aug 1 02:00:13 kernel: <4>unwind: Index not found 7f28edf4
Aug 1 02:00:13 kernel: ____________________________________________________________________________
Aug 1 02:00:18 disk monitor: be idle
Aug 1 02:00:18 jffs2: valid logs(1)
Aug 1 02:00:18 miniupnpd[463]: HTTP listening on port 33441
Aug 1 02:00:19 pppd[472]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:20 syslog: module leds-usb not found in modules.dep
Aug 1 02:00:21 kernel: SCSI subsystem initialized
Aug 1 02:00:22 pppd[472]: PAP authentication failed
Aug 1 02:00:28 pppd[472]: Connection terminated.
Aug 1 02:00:28 pppd[472]: Modem hangup
Aug 1 02:00:39 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:00:39 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:42 pppd[472]: PAP authentication failed
Aug 1 02:00:42 pppd[472]: Connection terminated.
Aug 1 02:00:43 rc_service: zcip 684:notify_rc start_firewall
Aug 1 02:00:43 zcip client: configured 169.254.163.221
Aug 1 02:00:44 miniupnpd[463]: shutting down MiniUPnPd
Aug 1 02:00:44 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)!
Aug 1 02:00:45 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:45 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:45 miniupnpd[740]: version 1.9 started
Aug 1 02:00:45 miniupnpd[740]: HTTP listening on port 47434
Aug 1 02:00:45 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:47 stop_nat_rules: apply the redirect_rules!
Aug 1 02:00:52 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:00:52 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:55 pppd[472]: PAP authentication failed
Aug 1 02:00:55 pppd[472]: Connection terminated.
Aug 1 02:01:05 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:01:05 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:08 pppd[472]: PAP authentication failed
Aug 1 02:01:08 pppd[472]: Connection terminated.
Aug 1 02:01:18 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:01:18 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:21 pppd[472]: PAP authentication failed
Aug 1 02:01:21 pppd[472]: Connection terminated.
Aug 1 02:01:31 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:01:31 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:34 pppd[472]: PAP authentication failed
Aug 1 02:01:34 pppd[472]: Connection terminated.
Aug 1 02:01:44 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:01:44 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:44 pppd[472]: PAP authentication succeeded
Aug 1 02:01:44 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized
Aug 1 02:01:45 pppd[472]: local IP address 93.139.148.103
Aug 1 02:01:45 pppd[472]: remote IP address 172.29.252.89
Aug 1 02:01:45 rc_service: ip-up 819:notify_rc start_firewall
Aug 1 02:01:46 miniupnpd[740]: shutting down MiniUPnPd
Aug 1 02:01:46 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:01:46 rc_service: ip-up 819:notify_rc stop_upnp
Aug 1 02:01:46 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:01:47 miniupnpd[878]: version 1.9 started
Aug 1 02:01:47 miniupnpd[878]: HTTP listening on port 41732
Aug 1 02:01:47 miniupnpd[878]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:47 rc_service: ip-up 819:notify_rc start_upnp
Aug 1 02:01:47 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:01:47 miniupnpd[878]: shutting down MiniUPnPd
Aug 1 02:01:49 WAN Connection: WAN was restored.
Aug 1 02:01:49 miniupnpd[883]: version 1.9 started
Aug 1 02:01:49 miniupnpd[883]: HTTP listening on port 39510
Aug 1 02:01:49 miniupnpd[883]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:50 ntp: start NTP update
Dec 10 10:09:54 rc_service: ntp 880:notify_rc restart_upnp
Dec 10 10:09:54 miniupnpd[883]: shutting down MiniUPnPd
Dec 10 10:09:54 miniupnpd[892]: version 1.9 started
Dec 10 10:09:54 miniupnpd[892]: HTTP listening on port 34451
Dec 10 10:09:54 miniupnpd[892]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 10 10:09:55 rc_service: ntp 880:notify_rc restart_diskmon
Dec 10 10:09:55 disk_monitor: Finish
Dec 10 10:09:56 disk monitor: be idle
Dec 10 10:09:56 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 10 10:09:56 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 10 10:09:56 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 10 10:09:56 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 10 23:11:45 disk_monitor: Got SIGALRM...
Dec 11 00:00:45 disk_monitor: Got SIGALRM...
Dec 11 00:24:48 miniupnpd[892]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Dec 11 00:24:54 miniupnpd[892]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Aug 1 02:00:11 kernel: pflash: found no supported devices
Aug 1 02:00:11 kernel: bcmsflash: squash filesystem found at block 30
Aug 1 02:00:11 kernel: Creating 5 MTD partitions on "bcmsflash":
Aug 1 02:00:11 kernel: 0x000000000000-0x000000040000 : "boot"
Aug 1 02:00:11 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae48004, fsr=0x1c06, pc=0x2abeac58 lr=0x17bd8 ignored.
Aug 1 02:00:18 miniupnpd[457]: HTTP listening on port 57753
Aug 1 02:00:18 pppd[460]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:18 pppd[460]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:18 pppd[460]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 pppd[460]: PAP authentication succeeded
Aug 1 02:00:19 pppd[460]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:00:19 pppd[460]: local IP address 93.138.42.188
Aug 1 02:00:19 pppd[460]: remote IP address 172.29.252.64
Aug 1 02:00:28 miniupnpd[457]: shutting down MiniUPnPd
Aug 1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:00:31 miniupnpd[750]: version 1.9 started
Aug 1 02:00:31 miniupnpd[750]: HTTP listening on port 46651
Aug 1 02:00:31 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:32 miniupnpd[750]: shutting down MiniUPnPd
Aug 1 02:00:35 miniupnpd[759]: version 1.9 started
Aug 1 02:00:35 miniupnpd[759]: HTTP listening on port 60062
Aug 1 02:00:35 miniupnpd[759]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 11 05:02:06 rc_service: ntp 757:notify_rc restart_upnp
Dec 11 05:02:06 miniupnpd[759]: shutting down MiniUPnPd
Dec 11 05:02:07 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 11 05:02:07 miniupnpd[774]: version 1.9 started
Dec 11 05:02:07 miniupnpd[774]: HTTP listening on port 35670
Dec 11 05:02:07 miniupnpd[774]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 11 05:02:07 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 11 05:02:07 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 11 05:02:07 rc_service: ntp 757:notify_rc restart_diskmon
Dec 11 05:02:07 disk_monitor: Finish
Dec 11 05:02:08 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 11 05:02:09 disk monitor: be idle
Dec 11 05:02:13 rc_service: zcip 801:notify_rc start_firewall
Dec 11 05:02:13 zcip client: configured 169.254.163.221
Dec 11 05:02:13 miniupnpd[774]: shutting down MiniUPnPd
Dec 11 05:02:13 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 11 05:02:14 miniupnpd[829]: version 1.9 started
Dec 11 05:02:14 miniupnpd[829]: HTTP listening on port 54166
Dec 11 05:02:14 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 11 14:31:10 rc_service: httpds 417:notify_rc start_webs_update
Dec 11 23:04:34 disk_monitor: Got SIGALRM...
Dec 12 05:00:03 kernel: Emergency Sync complete
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2acef004, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac963b0, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored.
Aug 1 02:00:18 miniupnpd[465]: version 1.9 started
Aug 1 02:00:18 miniupnpd[465]: HTTP listening on port 34836
Aug 1 02:00:18 miniupnpd[465]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:18 pppd[470]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:19 pppd[470]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:19 pppd[470]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 pppd[470]: PAP authentication succeeded
Aug 1 02:00:19 pppd[470]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:00:19 pppd[470]: local IP address 93.138.92.101
Aug 1 02:00:19 pppd[470]: remote IP address 172.29.252.64
Aug 1 02:00:19 rc_service: ip-up 498:notify_rc start_firewall
Aug 1 02:00:20 rc_service: ip-up 498:notify_rc stop_upnp
Aug 1 02:00:28 miniupnpd[465]: shutting down MiniUPnPd
Aug 1 02:00:31 miniupnpd[746]: HTTP listening on port 41075
Aug 1 02:00:32 rc_service: ip-up 498:notify_rc start_upnp
Aug 1 02:00:32 miniupnpd[746]: shutting down MiniUPnPd
Aug 1 02:00:34 miniupnpd[750]: version 1.9 started
Aug 1 02:00:34 miniupnpd[750]: HTTP listening on port 35645
Aug 1 02:00:34 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 12 05:01:43 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 12 05:01:44 rc_service: ntp 749:notify_rc restart_upnp
Dec 12 05:01:44 miniupnpd[750]: shutting down MiniUPnPd
Dec 12 05:01:44 miniupnpd[770]: version 1.9 started
Dec 12 05:01:44 miniupnpd[770]: HTTP listening on port 37305
Dec 12 05:01:44 miniupnpd[770]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 12 05:01:45 rc_service: ntp 749:notify_rc restart_diskmon
Dec 12 05:01:45 disk_monitor: Finish
Dec 12 05:01:47 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 12 05:01:47 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 12 05:01:47 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 12 05:01:47 disk monitor: be idle
Dec 12 05:01:48 rc_service: zcip 793:notify_rc start_firewall
Dec 12 05:01:48 zcip client: configured 169.254.163.221
Dec 12 05:01:49 miniupnpd[770]: shutting down MiniUPnPd
Dec 12 05:01:49 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 12 05:01:50 miniupnpd[829]: version 1.9 started
Dec 12 05:01:50 miniupnpd[829]: HTTP listening on port 36053
Dec 12 05:01:50 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 12 23:04:13 disk_monitor: Got SIGALRM...
Dec 12 23:34:16 rc_service: httpds 417:notify_rc start_webs_update
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae3f004, fsr=0x1c06, pc=0x2ab76a00 lr=0x2ab76e5c ignored.
Aug 1 02:00:18 miniupnpd[464]: version 1.9 started
Aug 1 02:00:18 miniupnpd[464]: HTTP listening on port 34013
Aug 1 02:00:18 miniupnpd[464]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:19 pppd[470]: local IP address 93.138.17.169
Aug 1 02:00:20 rc_service: ip-up 502:notify_rc start_firewall
Aug 1 02:00:20 rc_service: ip-up 502:notify_rc stop_upnp
Aug 1 02:00:28 miniupnpd[464]: shutting down MiniUPnPd
Aug 1 02:00:32 miniupnpd[746]: version 1.9 started
Aug 1 02:00:32 miniupnpd[746]: HTTP listening on port 49039
Aug 1 02:00:32 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:32 rc_service: ip-up 502:notify_rc start_upnp
Aug 1 02:00:33 miniupnpd[746]: shutting down MiniUPnPd
Aug 1 02:00:35 miniupnpd[751]: version 1.9 started
Aug 1 02:00:35 miniupnpd[751]: HTTP listening on port 37247
Aug 1 02:00:35 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 13 05:01:51 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 13 05:01:51 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 13 05:01:51 rc_service: ntp 749:notify_rc restart_upnp
Dec 13 05:01:51 miniupnpd[751]: shutting down MiniUPnPd
Dec 13 05:01:52 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 13 05:01:52 rc_service: ntp 749:notify_rc restart_diskmon
Dec 13 05:01:53 disk_monitor: Finish
Dec 13 05:01:53 miniupnpd[771]: version 1.9 started
Dec 13 05:01:53 miniupnpd[771]: HTTP listening on port 41168
Dec 13 05:01:53 miniupnpd[771]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 13 05:01:53 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 13 05:01:55 disk monitor: be idle
Dec 13 05:01:56 rc_service: zcip 778:notify_rc start_firewall
Dec 13 05:01:56 zcip client: configured 169.254.163.221
Dec 13 05:01:57 miniupnpd[771]: shutting down MiniUPnPd
Dec 13 05:01:57 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 13 05:02:00 miniupnpd[816]: version 1.9 started
Dec 13 05:02:00 miniupnpd[816]: HTTP listening on port 60177
Dec 13 05:02:00 miniupnpd[816]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 13 17:41:12 rc_service: httpds 417:notify_rc start_webs_update
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ade2004, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2acc23b0, fsr=0x1c06, pc=0x7f190b38 lr=0x80208820 ignored.
Aug 1 02:00:11 kernel: <0>Kernel panic - not syncing: Out of memory: system-wide panic_on_oom is enabled
Aug 1 02:00:11 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<802fec2c>] (panic+0x7c/0x1a4)
Aug 1 02:00:11 kernel: <4>[<802fec2c>] (panic+0x7c/0x1a4) from [<80091038>] (out_of_memory+0x2c8/0x328)
Aug 1 02:00:11 kernel: <4>[<80091038>] (out_of_memory+0x2c8/0x328) from [<800942c0>] (__alloc_pages_nodemask+0x66c/0x694)
Aug 1 02:00:11 kernel: <4>[<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) from [<80096000>] (__do_page_cache_readahead+0x140/0x2d0)
Aug 1 02:00:11 kernel: <4>[<80096000>] (__do_page_cache_readahead+0x140/0x2d0) from [<80096440>] (ra_submit+0x28/0x30)
Aug 1 02:00:11 kernel: <4>[<80096440>] (ra_submit+0x28/0x30) from [<8008e5d0>] (filemap_fault+0x42c/0x454)
Aug 1 02:00:11 kernel: <4>[<8008e5d0>] (filemap_fault+0x42c/0x454) from [<800a315c>] (__do_fault.clone.60+0x54/0x4c8)
Aug 1 02:00:11 kernel: <4>[<800a315c>] (__do_fault.clone.60+0x54/0x4c8) from [<800a67c4>] (handle_mm_fault+0x114/0x934)
Aug 1 02:00:11 kernel: <4>[<800a67c4>] (handle_mm_fault+0x114/0x934) from [<8003fd90>] (do_page_fault+0x178/0x1ec)
Aug 1 02:00:11 kernel: <4>[<8003fd90>] (do_page_fault+0x178/0x1ec) from [<80038298>] (do_PrefetchAbort+0x30/0x9c)
Aug 1 02:00:11 kernel: <4>[<80038298>] (do_PrefetchAbort+0x30/0x9c) from [<803bf2e0>] (ret_from_exception+0x0/0x10)
Aug 1 02:00:11 kernel: <4>Exception stack(0x8534bfb0 to 0x8534bff8)
Aug 1 02:00:11 kernel: <4>bfa0: 0000000e 00000008 7ec48c48 00000000
Aug 1 02:00:11 kernel: <4>bfc0: 7ec48c48 00000001 7ec48e94 000000b3 0000d1f0 0000ec14 7ec48e08 00000000
Aug 1 02:00:11 kernel: <4>bfe0: 2aea65b4 7ec48948 2ae4e254 0003be5c 00000010 ffffffff
Aug 1 02:00:11 kernel: <0>Rebooting in 3 seconds..
Aug 1 02:00:18 miniupnpd[465]: HTTP listening on port 56032
Aug 1 02:00:27 pppd[472]: Connection terminated.
Aug 1 02:00:27 pppd[472]: Modem hangup
Aug 1 02:00:38 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:38 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:40 pppd[472]: PAP authentication failed
Aug 1 02:00:40 pppd[472]: Connection terminated.
Aug 1 02:00:41 rc_service: zcip 684:notify_rc start_firewall
Aug 1 02:00:42 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)!
Aug 1 02:00:43 miniupnpd[740]: version 1.9 started
Aug 1 02:00:43 miniupnpd[740]: HTTP listening on port 48089
Aug 1 02:00:43 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:50 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:50 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:53 pppd[472]: PAP authentication failed
Aug 1 02:00:53 pppd[472]: Connection terminated.
Aug 1 02:01:03 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:03 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:06 pppd[472]: PAP authentication failed
Aug 1 02:01:06 pppd[472]: Connection terminated.
Aug 1 02:01:16 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug 1 02:01:16 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:19 pppd[472]: PAP authentication failed
Aug 1 02:01:19 pppd[472]: Connection terminated.
Aug 1 02:01:29 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:01:29 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:32 pppd[472]: PAP authentication failed
Aug 1 02:01:32 pppd[472]: Connection terminated.
Aug 1 02:01:42 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:01:42 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:01:43 pppd[472]: PAP authentication succeeded
Aug 1 02:01:43 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized
Aug 1 02:01:43 pppd[472]: local IP address 93.139.188.27
Aug 1 02:01:43 pppd[472]: remote IP address 172.29.252.89
Aug 1 02:01:43 rc_service: ip-up 818:notify_rc start_firewall
Aug 1 02:01:44 miniupnpd[740]: shutting down MiniUPnPd
Aug 1 02:01:44 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:01:44 rc_service: ip-up 818:notify_rc stop_upnp
Aug 1 02:01:44 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:01:45 miniupnpd[869]: version 1.9 started
Aug 1 02:01:45 miniupnpd[869]: HTTP listening on port 56143
Aug 1 02:01:45 miniupnpd[869]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:45 rc_service: ip-up 818:notify_rc start_upnp
Aug 1 02:01:45 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:01:45 miniupnpd[869]: shutting down MiniUPnPd
Aug 1 02:01:47 miniupnpd[873]: version 1.9 started
Aug 1 02:01:47 miniupnpd[873]: HTTP listening on port 41917
Aug 1 02:01:47 miniupnpd[873]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:47 WAN Connection: WAN was restored.
Aug 1 02:01:48 ntp: start NTP update
Aug 1 02:01:48 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 13 18:12:49 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 13 18:12:49 rc_service: ntp 871:notify_rc restart_upnp
Dec 13 18:12:49 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 13 18:12:49 miniupnpd[873]: shutting down MiniUPnPd
Dec 13 18:12:49 miniupnpd[893]: version 1.9 started
Dec 13 18:12:49 miniupnpd[893]: HTTP listening on port 37135
Dec 13 18:12:49 miniupnpd[893]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 13 18:12:49 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 13 18:12:50 rc_service: ntp 871:notify_rc restart_diskmon
Dec 13 18:12:50 disk_monitor: Finish
Dec 13 18:12:51 disk monitor: be idle
Dec 13 19:00:58 disk_monitor: Got SIGALRM...
Dec 13 23:01:29 disk_monitor: Got SIGALRM...
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae53004, fsr=0x1c06, pc=0x2ab40e08 lr=0x2ab40e5c ignored.
Aug 1 02:00:11 kernel: <4>Exception stack(0x851fdfb0 to 0x851fdff8)
Aug 1 02:00:11 kernel: <4>dfa0: 00001800 0009a21c 00001800 0009a21c
Aug 1 02:00:11 kernel: <4>dfc0: 0009a21c 000983cc 000000fa 00000067 0009a258 00001e38 00000500 00000000
Aug 1 02:00:11 kernel: <4>dfe0: 000984e4 7e8e0d68 0002c878 2ac8c370 80000010 ffffffff
Aug 1 02:00:18 miniupnpd[457]: HTTP listening on port 33819
Aug 1 02:00:39 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:00:44 miniupnpd[457]: shutting down MiniUPnPd
Aug 1 02:00:46 miniupnpd[740]: version 1.9 started
Aug 1 02:00:46 miniupnpd[740]: HTTP listening on port 50075
Aug 1 02:00:46 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:52 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:01:05 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:01:18 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:01:31 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:01:44 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug 1 02:01:44 pppd[472]: peer from calling number 84:B5:9C:A4:4D:B7 authorized
Aug 1 02:01:45 pppd[472]: local IP address 78.1.186.208
Aug 1 02:01:45 pppd[472]: remote IP address 172.29.252.59
Aug 1 02:01:45 rc_service: ip-up 820:notify_rc start_firewall
Aug 1 02:01:46 rc_service: ip-up 820:notify_rc stop_upnp
Aug 1 02:01:47 miniupnpd[867]: version 1.9 started
Aug 1 02:01:47 miniupnpd[867]: HTTP listening on port 46435
Aug 1 02:01:47 miniupnpd[867]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:47 rc_service: ip-up 820:notify_rc start_upnp
Aug 1 02:01:47 miniupnpd[867]: shutting down MiniUPnPd
Aug 1 02:01:48 WAN Connection: WAN was restored.
Aug 1 02:01:49 miniupnpd[872]: version 1.9 started
Aug 1 02:01:49 miniupnpd[872]: HTTP listening on port 44026
Aug 1 02:01:49 miniupnpd[872]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:49 ntp: start NTP update
Dec 14 01:18:19 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 14 01:18:19 rc_service: ntp 870:notify_rc restart_upnp
Dec 14 01:18:19 miniupnpd[872]: shutting down MiniUPnPd
Dec 14 01:18:19 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 14 01:18:19 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 14 01:18:19 miniupnpd[890]: version 1.9 started
Dec 14 01:18:19 miniupnpd[890]: HTTP listening on port 42889
Dec 14 01:18:19 miniupnpd[890]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 14 01:18:20 rc_service: ntp 870:notify_rc restart_diskmon
Dec 14 01:18:20 disk_monitor: Finish
Dec 14 01:18:20 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 14 01:18:21 disk monitor: be idle
Dec 14 02:00:27 disk_monitor: Got SIGALRM...
Dec 14 05:00:12 kernel: Emergency Sync complete
Dec 14 05:00:14 iTunes: daemon is stoped
Dec 14 05:00:14 FTP Server: daemon is stoped
Dec 14 05:00:14 Samba Server: smb daemon is stoped
Dec 14 05:00:14 kernel: gro disabled
Dec 14 05:00:14 disk_monitor: Finish
Dec 14 05:00:14 miniupnpd[890]: shutting down MiniUPnPd
Aug 1 02:00:09 syslogd started: BusyBox v1.17.4
Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST)
Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017
Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f
Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug 1 02:00:09 kernel: Machine: Northstar Prototype
Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000
Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem
Aug 1 02:00:10 kernel: Virtual kernel memory layout:
Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB)
Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB)
Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB)
Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB)
Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB)
Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB)
Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512
Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB
Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled
Aug 1 02:00:10 kernel: bio: create slab at 0
Aug 1 02:00:10 kernel: PCI: no core
Aug 1 02:00:10 kernel: PCI: Fixing up bus 0
Aug 1 02:00:10 kernel: PCI: Fixing up bus 1
Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!!
Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2
Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 1 02:00:11 kernel: Registering the dns_resolver key type
Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel.
Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint
Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0
Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1
Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8
Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20
Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled
Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393)
Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0
Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1
Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ad9b004, fsr=0x1c06, pc=0x800ce10c lr=0x800c1154 ignored.
Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257)
Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________
Aug 1 02:00:11 kernel: <4>Emergency Sync complete
Aug 1 02:00:11 kernel: <4>gro disabled
Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt
Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state
Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode
Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating
Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state
Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state
Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state
Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state
Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode
Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix
Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp
Aug 1 02:00:11 kernel: <0>Restarting system.
Aug 1 02:00:11 kernel: ____________________________________________________________________________
Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules!
Aug 1 02:00:17 disk monitor: be idle
Aug 1 02:00:17 hour monitor: daemon is starting
Aug 1 02:00:17 hour monitor: daemon terminates
Aug 1 02:00:17 jffs2: valid logs(1)
Aug 1 02:00:18 miniupnpd[461]: HTTP listening on port 60517
Aug 1 02:00:20 pppd[472]: local IP address 93.138.127.180
Aug 1 02:00:20 pppd[472]: remote IP address 172.29.252.64
Aug 1 02:00:20 rc_service: ip-up 501:notify_rc start_firewall
Aug 1 02:00:20 rc_service: ip-up 501:notify_rc stop_upnp
Aug 1 02:00:28 miniupnpd[461]: shutting down MiniUPnPd
Aug 1 02:00:32 miniupnpd[747]: version 1.9 started
Aug 1 02:00:32 miniupnpd[747]: HTTP listening on port 55279
Aug 1 02:00:32 miniupnpd[747]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:33 rc_service: ip-up 501:notify_rc start_upnp
Aug 1 02:00:33 miniupnpd[747]: shutting down MiniUPnPd
Aug 1 02:00:36 miniupnpd[751]: version 1.9 started
Aug 1 02:00:36 miniupnpd[751]: HTTP listening on port 33504
Aug 1 02:00:36 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 14 05:01:53 rc_service: ntp 749:notify_rc restart_upnp
Dec 14 05:01:53 miniupnpd[751]: shutting down MiniUPnPd
Dec 14 05:01:54 rc_service: ntp 749:notify_rc restart_diskmon
Dec 14 05:01:54 disk_monitor: Finish
Dec 14 05:01:56 miniupnpd[767]: version 1.9 started
Dec 14 05:01:56 miniupnpd[767]: HTTP listening on port 48911
Dec 14 05:01:56 miniupnpd[767]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 14 05:01:57 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 14 05:01:57 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 14 05:01:57 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 14 05:01:57 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 14 05:01:58 disk monitor: be idle
Dec 14 05:01:58 rc_service: zcip 779:notify_rc start_firewall
Dec 14 05:01:59 zcip client: configured 169.254.163.221
Dec 14 05:02:00 miniupnpd[767]: shutting down MiniUPnPd
Dec 14 05:02:00 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 14 05:02:04 miniupnpd[826]: version 1.9 started
Dec 14 05:02:04 miniupnpd[826]: HTTP listening on port 46443
Dec 14 05:02:04 miniupnpd[826]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 14 05:59:23 kernel: active_file:438 inactive_file:687 isolated_file:0
Dec 14 05:59:23 kernel: unevictable:0 dirty:0 writeback:0 unstable:0
Dec 14 05:59:23 kernel: free:383 slab_reclaimable:266 slab_unreclaimable:24677
Dec 14 05:59:23 kernel: mapped:824 shmem:188 pagetables:151 bounce:0
Dec 14 05:59:23 kernel: DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:6616kB inactive_anon:940kB active_file:1752kB inactive_file:2748kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:3296kB shmem:752kB slab_reclaimable:1064kB slab_unreclaimable:98708kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:195 all_unreclaimable? no
Dec 14 05:59:23 kernel: lowmem_reserve[]: 0 0 0
Dec 14 05:59:23 kernel: DMA: 1*4kB 1*8kB 1*16kB 1*32kB 1*64kB 1*128kB 1*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1532kB
Dec 14 05:59:23 kernel: 1313 total pagecache pages
Dec 14 05:59:23 kernel: 0 pages in swap cache
Dec 14 05:59:23 kernel: Swap cache stats: add 0, delete 0, find 0/0
Dec 14 05:59:23 kernel: Free swap = 0kB
Dec 14 05:59:23 kernel: Total swap = 0kB
Dec 14 05:59:23 kernel: 32768 pages of RAM
Dec 14 05:59:23 kernel: 552 free pages
Dec 14 05:59:23 kernel: 1352 reserved pages
Dec 14 05:59:23 kernel: 9328 slab pages
Dec 14 05:59:23 kernel: 4621 pages shared
Dec 14 05:59:23 kernel: 0 pages swap cached
Dec 14 05:59:24 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20)
Dec 14 05:59:24 kernel: cache: kmalloc-256, object size: 256, buffer size: 256, default order: 0, min order: 0
Dec 14 05:59:24 kernel: node 0: slabs: 3375, objs: 54000, free: 0
Dec 14 05:59:24 kernel: acsd: page allocation failure. order:0, mode:0x20
Dec 14 05:59:24 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694)
Dec 14 05:59:24 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0)
Dec 14 05:59:24 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0970>] (kmem_cache_alloc+0x90/0x9c)
Dec 14 05:59:24 kernel: [<803b0970>] (kmem_cache_alloc+0x90/0x9c) from [<803b28ac>] (__alloc_skb+0x30/0x104)
Dec 14 05:59:24 kernel: [<803b28ac>] (__alloc_skb+0x30/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac)
Dec 14 05:59:24 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<803c2cc0>] (osl_pktget+0x6c/0x170)
Dec 14 05:59:24 kernel: [<803c2cc0>] (osl_pktget+0x6c/0x170) from [<7f29458c>] (wlc_hdr_proc+0x54/0x254 [wl])
Dec 14 05:59:24 kernel: unwind: Index not found 7f29458c
Dec 14 05:59:24 kernel: Mem-info:
Dec 14 05:59:24 kernel: DMA per-cpu:
Dec 14 05:59:24 kernel: CPU 0: hi: 42, btch: 7 usd: 6
Dec 14 05:59:24 kernel: active_anon:1654 inactive_anon:235 isolated_anon:0
Dec 14 05:59:24 kernel: active_file:438 inactive_file:687 isolated_file:0
Dec 14 05:59:24 kernel: unevictable:0 dirty:0 writeback:0 unstable:0
Dec 14 05:59:24 kernel: free:383 slab_reclaimable:266 slab_unreclaimable:24677
Dec 14 05:59:24 kernel: mapped:824 shmem:188 pagetables:151 bounce:0
Dec 14 05:59:24 kernel: DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:6616kB inactive_anon:940kB active_file:1752kB inactive_file:2748kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:3296kB shmem:752kB slab_reclaimable:1064kB slab_unreclaimable:98708kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:195 all_unreclaimable? no
Dec 14 05:59:24 kernel: lowmem_reserve[]: 0 0 0
Dec 14 05:59:24 kernel: DMA: 1*4kB 1*8kB 1*16kB 1*32kB 1*64kB 1*128kB 1*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1532kB
Dec 14 05:59:24 kernel: 1313 total pagecache pages
Dec 14 05:59:24 kernel: 0 pages in swap cache
Dec 14 05:59:24 kernel: Swap cache stats: add 0, delete 0, find 0/0
Dec 14 05:59:24 kernel: Free swap = 0kB
Dec 14 05:59:24 kernel: Total swap = 0kB
Dec 14 05:59:24 kernel: 32768 pages of RAM
Dec 14 05:59:24 kernel: 552 free pages
Dec 14 05:59:24 kernel: 1352 reserved pages
Dec 14 05:59:24 kernel: 9328 slab pages
Dec 14 05:59:24 kernel: 4621 pages shared
Dec 14 05:59:24 kernel: 0 pages swap cached
Dec 14 05:59:24 kernel: [<803b0970>] (kmem_cache_alloc+0x90/0x9c) from [<80216050>] (skb_clone+0x130/0x14c)
Dec 14 05:59:24 kernel: [<80216050>] (skb_clone+0x130/0x14c) from [<802e8ba0>] (deliver_clone+0x20/0x4c)
Dec 14 05:59:24 kernel: [<802e8ba0>] (deliver_clone+0x20/0x4c) from [<802e9e24>] (br_handle_frame_finish+0x230/0x23c)
Dec 14 05:59:24 kernel: [<802e9e24>] (br_handle_frame_finish+0x230/0x23c) from [<802e9fdc>] (br_handle_frame+0x1ac/0x24c)
Dec 14 05:59:24 kernel: [<802e9fdc>] (f len 2016 failed
Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed
Dec 14 05:59:24 kernel: __alloc_pages_slowpath: 7870 callbacks suppressed
Dec 14 05:59:24 kernel: kworker/0:1: page allocation failure. order:0, mode:0x4020
Dec 14 05:59:24 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8)
Dec 14 05:59:24 kernel: [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104)
Dec 14 05:59:24 kernel: [<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac)
Dec 14 05:59:24 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<801fc918>] (osl_ctfpool_add+0x5c/0xf8)
Dec 14 05:59:24 kernel: [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) from [<7f018a14>] (et_tx_tasklet+0x304/0xbdc [et])
Dec 14 05:59:24 kernel: unwind: Index not found 7f018a14
Dec 14 05:59:24 kernel: CPU 0: hi: 42, btch: 7 usd: 7
Dec 14 05:59:24 kernel: active_anon:951 inactive_anon:938 isolated_anon:0
Dec 14 05:59:24 kernel: active_file:397 inactive_file:599 isolated_file:0
Dec 14 05:59:24 kernel: free:382 slab_reclaimable:150 slab_unreclaimable:24922
Dec 14 05:59:24 kernel: mapped:711 shmem:188 pagetables:151 bounce:0
Dec 14 05:59:24 kernel: DMA free:1528kB min:4096kB low:5120kB high:6144kB active_anon:3804kB inactive_anon:3752kB active_file:1588kB inactive_file:2396kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:2844kB shmem:752kB slab_reclaimable:600kB slab_unreclaimable:99688kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Dec 14 05:59:24 kernel: DMA: 14*4kB 6*8kB 5*16kB 6*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1528kB
Dec 14 05:59:24 kernel: 1184 total pagecache pages
Dec 14 05:59:24 kernel: 9646 slab pages
Dec 14 05:59:24 kernel: 3844 pages shared
Dec 14 05:59:24 kernel: cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0
Dec 14 05:59:24 kernel: node 0: slabs: 2213, objs: 17466, free: 0
Dec 14 05:59:25 kernel: [<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac)
Dec 14 05:59:25 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<801fc918>] (osl_ctfpool_add+0x5c/0xf8)
Dec 14 05:59:25 kernel: [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) from [<7f018a14>] (et_tx_tasklet+0x304/0xbdc [et])
Dec 14 05:59:25 kernel: unwind: Index not found 7f018a14
Dec 14 05:59:25 kernel: Mem-info:
Dec 14 05:59:25 kernel: DMA per-cpu:
Dec 14 05:59:25 kernel: CPU 0: hi: 42, btch: 7 usd: 7
Dec 14 05:59:25 kernel: active_anon:951 inactive_anon:938 isolated_anon:0
Dec 14 05:59:25 kernel: active_file:397 inactive_file:599 isolated_file:0
Dec 14 05:59:25 kernel: unevictable:0 dirty:0 writeback:0 unstable:0
Dec 14 05:59:25 kernel: free:382 slab_reclaimable:150 slab_unreclaimable:24922
Dec 14 05:59:25 kernel: mapped:711 shmem:188 pagetables:151 bounce:0
Dec 14 05:59:25 kernel: DMA free:1528kB min:4096kB low:5120kB high:6144kB active_anon:3804kB inactive_anon:3752kB active_file:1588kB inactive_file:2396kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:2844kB shmem:752kB slab_reclaimable:600kB slab_unreclaimable:99688kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Dec 14 05:59:25 kernel: lowmem_reserve[]: 0 0 0
Dec 14 05:59:25 kernel: DMA: 14*4kB 6*8kB 5*16kB 6*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1528kB
Dec 14 05:59:25 kernel: 1184 total pagecache pages
Dec 14 05:59:25 kernel: 0 pages in swap cache
Dec 14 05:59:25 kernel: Swap cache stats: add 0, delete 0, find 0/0
Dec 14 05:59:25 kernel: Free swap = 0kB
Dec 14 05:59:25 kernel: Total swap = 0kB
Dec 14 05:59:25 kernel: 32768 pages of RAM
Dec 14 05:59:25 kernel: 552 free pages
Dec 14 05:59:25 kernel: 1352 reserved pages
Dec 14 05:59:25 kernel: 9646 slab pages
Dec 14 05:59:25 kernel: 3844 pages shared
Dec 14 05:59:25 kernel: 0 pages swap cached
Dec 14 05:59:25 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20)
Dec 14 05:59:25 kernel: cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0
Dec 14 05:59:25 kernel: node 0: slabs: 2213, objs: 17466, free: 0
Dec 14 05:59:25 kernel: osl_ctfpool_add: skb alloc of len 2016 failed
Dec 14 05:59:25 kernel: kworker/0:1: page allocation failure. order:0, mode:0x4020
Dec 14 05:59:25 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694)
Dec 14 05:59:25 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0)
Dec 14 05:59:25 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8)
Dec 14 05:59:25 kernel: [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104)
Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed
Dec 19 23:04:32 disk_monitor: Got SIGALRM...
Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug 1 02:00:10 kernel: pflash: found no supported devices
Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30
Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash":
Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot"
Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug 1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs"
Aug 1 02:00:10 kernel: 0x000000d30000-0x000000ff0000 : "jffs2"
Aug 1 02:00:10 kernel: 0x000000ff0000-0x000001000000 : "nvram"
Aug 1 02:00:10 kernel: === PPTP init ===
Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac81004, fsr=0x1c06, pc=0x2aacda40 lr=0x2aacde5c ignored.
Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1547)
Aug 1 02:00:11 kernel: <4>Exception stack(0x8523ffb0 to 0x8523fff8)
Aug 1 02:00:11 kernel: <4>ffa0: 00000004 0008d206 0009a21f 00000073
Aug 1 02:00:11 kernel: <4>ffc0: 0009a21f 000983cc 0000010e 00000000 0009a256 00001e38 00000500 0000000a
Aug 1 02:00:11 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed
Aug 1 02:00:11 kernel: <4>ffe0: 00098720 7eb6ed78 0002c958 2ac956e0 20000010 ffffffff
Aug 1 02:00:11 kernel: <0>Rebooting in 3 seconds..osl_ctfpool_add: skb alloc of len 2016 failed
Aug 1 02:00:11 WAN Connection: Fail to connect with some issues.
Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL
Aug 1 02:00:17 syslog: Generating SSL certificate...
Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1]
Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt
Aug 1 02:00:18 miniupnpd[459]: version 1.9 started
Aug 1 02:00:18 miniupnpd[459]: HTTP listening on port 36767
Aug 1 02:00:18 miniupnpd[459]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0
Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep
Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep
Aug 1 02:00:20 kernel: SCSI subsystem initialized
Aug 1 02:00:42 rc_service: zcip 684:notify_rc start_firewall
Aug 1 02:00:42 zcip client: configured 169.254.163.221
Aug 1 02:00:42 miniupnpd[459]: shutting down MiniUPnPd
Aug 1 02:00:44 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 02:00:44 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 02:00:44 miniupnpd[740]: version 1.9 started
Aug 1 02:00:44 miniupnpd[740]: HTTP listening on port 52453
Aug 1 02:00:44 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:00:52 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:05 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug 1 02:01:07 pppd[472]: PAP authentication failed
Aug 1 02:01:18 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:31 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug 1 02:01:31 pppd[472]: PAP authentication succeeded
Aug 1 02:01:31 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug 1 02:01:32 pppd[472]: local IP address 93.138.54.92
Aug 1 02:01:32 pppd[472]: remote IP address 172.29.252.64
Aug 1 02:01:32 rc_service: ip-up 804:notify_rc start_firewall
Aug 1 02:01:33 miniupnpd[740]: shutting down MiniUPnPd
Aug 1 02:01:33 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug 1 02:01:33 rc_service: ip-up 804:notify_rc stop_upnp
Aug 1 02:01:33 rc_service: waitting "start_firewall" via ip-up ...
Aug 1 02:01:35 miniupnpd[851]: version 1.9 started
Aug 1 02:01:35 miniupnpd[851]: HTTP listening on port 34250
Aug 1 02:01:35 miniupnpd[851]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:35 miniupnpd[851]: shutting down MiniUPnPd
Aug 1 02:01:35 rc_service: ip-up 804:notify_rc start_upnp
Aug 1 02:01:36 rc_service: waitting "stop_upnp" via ip-up ...
Aug 1 02:01:36 WAN Connection: WAN was restored.
Aug 1 02:01:38 miniupnpd[856]: version 1.9 started
Aug 1 02:01:38 miniupnpd[856]: HTTP listening on port 36430
Aug 1 02:01:38 miniupnpd[856]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 02:01:38 ntp: start NTP update
Dec 19 23:16:17 rc_service: ntp 854:notify_rc restart_upnp
Dec 19 23:16:17 miniupnpd[856]: shutting down MiniUPnPd
Dec 19 23:16:17 miniupnpd[869]: version 1.9 started
Dec 19 23:16:17 miniupnpd[869]: HTTP listening on port 46870
Dec 19 23:16:17 miniupnpd[869]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 19 23:16:18 rc_service: ntp 854:notify_rc restart_diskmon
Dec 19 23:16:18 disk_monitor: Finish
Dec 19 23:16:18 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 19 23:16:19 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 19 23:16:19 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 19 23:16:19 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 19 23:16:19 disk monitor: be idle
