Staro 19.12.2017., 23:28   #1
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
Asus RT-AC1200G+ random reboot
eth0 Aug 1 02:00:19 pppd[472]: PAP authentication succeeded Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A3:B7:70 authorized Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:20 pppd[472]: local IP address 93.142.236.121 Aug 1 02:00:20 pppd[472]: remote IP address 172.29.252.90 Aug 1 02:00:20 rc_service: ip-up 500:notify_rc start_firewall Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:21 rc_service: ip-up 500:notify_rc stop_upnp Aug 1 02:00:21 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:22 WAN Connection: WAN was restored. Aug 1 02:00:27 miniupnpd[465]: shutting down MiniUPnPd Aug 1 02:00:27 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:32 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:32 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:32 miniupnpd[748]: version 1.9 started Aug 1 02:00:32 miniupnpd[748]: HTTP listening on port 45952 Aug 1 02:00:32 miniupnpd[748]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:33 rc_service: ip-up 500:notify_rc start_upnp Aug 1 02:00:33 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:33 miniupnpd[748]: shutting down MiniUPnPd Aug 1 02:00:35 miniupnpd[754]: version 1.9 started Aug 1 02:00:35 miniupnpd[754]: HTTP listening on port 55762 Aug 1 02:00:35 miniupnpd[754]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:37 ntp: start NTP update Aug 1 02:00:37 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Nov 29 05:02:11 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Nov 29 05:02:12 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Nov 29 05:02:12 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Nov 29 05:02:12 rc_service: ntp 752:notify_rc restart_upnp Nov 29 05:02:12 miniupnpd[754]: shutting down MiniUPnPd Nov 29 05:02:13 rc_service: ntp 752:notify_rc restart_diskmon Nov 29 05:02:14 disk_monitor: Finish Nov 29 05:02:15 miniupnpd[784]: version 1.9 started Nov 29 05:02:15 miniupnpd[784]: HTTP listening on port 44342 Nov 29 05:02:15 miniupnpd[784]: Listening for NAT-PMP/PCP traffic on port 5351 Nov 29 05:02:17 disk monitor: be idle Nov 29 05:02:17 rc_service: zcip 785:notify_rc start_firewall Nov 29 05:02:17 zcip client: configured 169.254.163.221 Nov 29 05:02:18 miniupnpd[784]: shutting down MiniUPnPd Nov 29 05:02:18 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Nov 29 05:02:20 miniupnpd[825]: version 1.9 started Nov 29 05:02:20 miniupnpd[825]: HTTP listening on port 49515 Nov 29 05:02:20 miniupnpd[825]: Listening for NAT-PMP/PCP traffic on port 5351 Nov 29 09:36:17 miniupnpd[825]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out Nov 29 09:36:24 miniupnpd[825]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out Nov 29 09:36:38 miniupnpd[825]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out Nov 29 09:36:38 miniupnpd[825]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out Nov 29 17:18:01 rc_service: httpds 417:notify_rc start_webs_update Nov 29 23:04:49 disk_monitor: Got SIGALRM... Nov 30 05:00:15 kernel: Emergency Sync complete Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:09 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:09 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:10 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:10 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:10 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2adde000, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored. Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2abb13b0, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL Aug 1 02:00:16 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:17 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[464]: version 1.9 started Aug 1 02:00:18 miniupnpd[464]: HTTP listening on port 59631 Aug 1 02:00:18 miniupnpd[464]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:19 pppd[472]: PAP authentication succeeded Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized Aug 1 02:00:19 kernel: SCSI subsystem initialized Aug 1 02:00:20 pppd[472]: local IP address 93.139.156.15 Aug 1 02:00:20 pppd[472]: remote IP address 172.29.252.89 Aug 1 02:00:20 rc_service: ip-up 513:notify_rc start_firewall Aug 1 02:00:20 rc_service: ip-up 513:notify_rc stop_upnp Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:21 WAN Connection: WAN was restored. Aug 1 02:00:27 miniupnpd[464]: shutting down MiniUPnPd Aug 1 02:00:27 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:30 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:30 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:31 miniupnpd[746]: version 1.9 started Aug 1 02:00:31 miniupnpd[746]: HTTP listening on port 46370 Aug 1 02:00:31 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:32 rc_service: ip-up 513:notify_rc start_upnp Aug 1 02:00:32 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:32 miniupnpd[746]: shutting down MiniUPnPd Aug 1 02:00:34 miniupnpd[751]: version 1.9 started Aug 1 02:00:34 miniupnpd[751]: HTTP listening on port 54040 Aug 1 02:00:34 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:35 ntp: start NTP update Nov 30 05:01:45 rc_service: ntp 749:notify_rc restart_upnp Nov 30 05:01:45 miniupnpd[751]: shutting down MiniUPnPd Nov 30 05:01:46 rc_service: ntp 749:notify_rc restart_diskmon Nov 30 05:01:47 miniupnpd[766]: version 1.9 started Nov 30 05:01:47 miniupnpd[766]: HTTP listening on port 36896 Nov 30 05:01:47 miniupnpd[766]: Listening for NAT-PMP/PCP traffic on port 5351 Nov 30 05:01:47 disk_monitor: Finish Nov 30 05:01:47 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Nov 30 05:01:47 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Nov 30 05:01:47 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Nov 30 05:01:48 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Nov 30 05:01:50 disk monitor: be idle Nov 30 05:01:50 rc_service: zcip 778:notify_rc start_firewall Nov 30 05:01:50 zcip client: configured 169.254.163.221 Nov 30 05:01:52 miniupnpd[766]: shutting down MiniUPnPd Nov 30 05:01:52 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Nov 30 05:01:54 miniupnpd[821]: version 1.9 started Nov 30 05:01:54 miniupnpd[821]: HTTP listening on port 41162 Nov 30 05:01:54 miniupnpd[821]: Listening for NAT-PMP/PCP traffic on port 5351 Nov 30 23:04:17 disk_monitor: Got SIGALRM... Dec 1 00:26:07 rc_service: httpds 417:notify_rc start_webs_update Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:10 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:10 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:10 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae0e004, fsr=0x1c06, pc=0x80171f68 lr=0x800cc4c4 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL Aug 1 02:00:16 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[459]: version 1.9 started Aug 1 02:00:18 miniupnpd[459]: HTTP listening on port 59994 Aug 1 02:00:18 miniupnpd[459]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:19 pppd[473]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[473]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Aug 1 02:00:19 pppd[473]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 pppd[473]: PAP authentication succeeded Aug 1 02:00:19 pppd[473]: peer from calling number 00:90:1A:A3:B7:7C authorized Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:20 syslog: module leds-usb not found in modules.dep Aug 1 02:00:20 pppd[473]: local IP address 93.139.153.7 Aug 1 02:00:20 pppd[473]: remote IP address 172.29.252.89 Aug 1 02:00:20 rc_service: ip-up 503:notify_rc start_firewall Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:21 rc_service: ip-up 503:notify_rc stop_upnp Aug 1 02:00:21 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:21 WAN Connection: WAN was restored. Aug 1 02:00:28 miniupnpd[459]: shutting down MiniUPnPd Aug 1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:32 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:32 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:33 miniupnpd[750]: version 1.9 started Aug 1 02:00:33 miniupnpd[750]: HTTP listening on port 54542 Aug 1 02:00:33 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:33 rc_service: ip-up 503:notify_rc start_upnp Aug 1 02:00:33 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:33 miniupnpd[750]: shutting down MiniUPnPd Aug 1 02:00:35 miniupnpd[755]: version 1.9 started Aug 1 02:00:35 miniupnpd[755]: HTTP listening on port 38653 Aug 1 02:00:35 miniupnpd[755]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:36 ntp: start NTP update Aug 1 02:00:36 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Aug 1 02:00:36 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 1 05:01:41 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 1 05:01:42 rc_service: ntp 753:notify_rc restart_upnp Dec 1 05:01:42 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 1 05:01:42 miniupnpd[755]: shutting down MiniUPnPd Dec 1 05:01:42 miniupnpd[779]: version 1.9 started Dec 1 05:01:42 miniupnpd[779]: HTTP listening on port 43370 Dec 1 05:01:42 miniupnpd[779]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 1 05:01:43 rc_service: ntp 753:notify_rc restart_diskmon Dec 1 05:01:43 disk_monitor: Finish Dec 1 05:01:45 disk monitor: be idle Dec 1 05:01:47 rc_service: zcip 803:notify_rc start_firewall Dec 1 05:01:47 zcip client: configured 169.254.163.221 Dec 1 05:01:48 miniupnpd[779]: shutting down MiniUPnPd Dec 1 05:01:48 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 1 05:01:49 miniupnpd[830]: version 1.9 started Dec 1 05:01:49 miniupnpd[830]: HTTP listening on port 35003 Dec 1 05:01:49 miniupnpd[830]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 1 13:31:57 rc_service: httpds 417:notify_rc start_webs_update Dec 1 13:46:24 rc_service: httpds 417:notify_rc start_webs_update Dec 1 15:51:15 rc_service: httpds 417:notify_rc start_webs_update Dec 1 23:04:19 disk_monitor: Got SIGALRM... Dec 2 00:19:22 rc_service: httpds 417:notify_rc start_webs_update Aug 1 02:00:10 syslogd started: BusyBox v1.17.4 Aug 1 02:00:10 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:10 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:10 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:10 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:10 kernel: Machine: Northstar Prototype Aug 1 02:00:10 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:10 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:11 kernel: PCI: Fixing up bus 0 Aug 1 02:00:11 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:11 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:11 kernel: pflash: found no supported devices Aug 1 02:00:11 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:11 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:11 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:11 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:11 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2adf7004, fsr=0x1c06, pc=0x8016ff34 lr=0x616e6669 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:12 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:12 WAN Connection: Fail to connect with some issues. Aug 1 02:00:17 RT-AC1200G+: start httpd - SSL Aug 1 02:00:17 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:18 hour monitor: daemon is starting Aug 1 02:00:18 hour monitor: daemon terminates Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[463]: version 1.9 started Aug 1 02:00:18 miniupnpd[463]: HTTP listening on port 48188 Aug 1 02:00:18 miniupnpd[463]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:19 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 pppd[472]: PAP authentication succeeded Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:19 pppd[472]: local IP address 93.138.35.49 Aug 1 02:00:19 pppd[472]: remote IP address 172.29.252.64 Aug 1 02:00:20 rc_service: ip-up 502:notify_rc start_firewall Aug 1 02:00:20 rc_service: ip-up 502:notify_rc stop_upnp Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:22 WAN Connection: WAN was restored. Aug 1 02:00:28 miniupnpd[463]: shutting down MiniUPnPd Aug 1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:32 miniupnpd[746]: version 1.9 started Aug 1 02:00:32 miniupnpd[746]: HTTP listening on port 38934 Aug 1 02:00:32 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:32 rc_service: ip-up 502:notify_rc start_upnp Aug 1 02:00:32 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:32 miniupnpd[746]: shutting down MiniUPnPd Aug 1 02:00:35 miniupnpd[752]: version 1.9 started Aug 1 02:00:35 miniupnpd[752]: HTTP listening on port 34247 Aug 1 02:00:35 miniupnpd[752]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:36 ntp: start NTP update Dec 2 05:01:51 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 2 05:01:52 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 2 05:01:52 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 2 05:01:52 rc_service: ntp 749:notify_rc restart_upnp Dec 2 05:01:52 miniupnpd[752]: shutting down MiniUPnPd Dec 2 05:01:53 rc_service: ntp 749:notify_rc restart_diskmon Dec 2 05:01:53 disk_monitor: Finish Dec 2 05:01:54 miniupnpd[772]: version 1.9 started Dec 2 05:01:54 miniupnpd[772]: HTTP listening on port 39930 Dec 2 05:01:54 miniupnpd[772]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 2 05:01:55 disk monitor: be idle Dec 2 05:01:55 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 2 05:01:56 rc_service: zcip 783:notify_rc start_firewall Dec 2 05:01:56 zcip client: configured 169.254.163.221 Dec 2 05:01:57 miniupnpd[772]: shutting down MiniUPnPd Dec 2 05:01:57 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 2 05:01:59 miniupnpd[829]: version 1.9 started Dec 2 05:01:59 miniupnpd[829]: HTTP listening on port 60719 Dec 2 05:01:59 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 2 23:04:36 disk_monitor: Got SIGALRM... Dec 2 23:24:42 rc_service: httpds 417:notify_rc start_webs_update Dec 3 05:00:08 kernel: Emergency Sync complete Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:11 kernel: pflash: found no supported devices Aug 1 02:00:11 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:11 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:11 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:11 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:11 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2addf004, fsr=0x1c06, pc=0x2abe2c58 lr=0x17bd8 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:12 WAN Connection: Fail to connect with some issues. Aug 1 02:00:17 RT-AC1200G+: start httpd - SSL Aug 1 02:00:17 RT-AC1200G+: start httpd Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:18 syslog: Generating SSL certificate... Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 syslog: Generating SSL certificate... Aug 1 02:00:18 miniupnpd[456]: version 1.9 started Aug 1 02:00:18 miniupnpd[456]: HTTP listening on port 58051 Aug 1 02:00:18 miniupnpd[456]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[468]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[468]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0 Aug 1 02:00:19 pppd[468]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 pppd[468]: PAP authentication succeeded Aug 1 02:00:19 pppd[468]: peer from calling number 84:B5:9C:A4:4D:B7 authorized Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:19 pppd[468]: local IP address 78.1.145.97 Aug 1 02:00:19 pppd[468]: remote IP address 172.29.252.59 Aug 1 02:00:20 rc_service: ip-up 500:notify_rc start_firewall Aug 1 02:00:20 rc_service: ip-up 500:notify_rc stop_upnp Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:22 WAN Connection: WAN was restored. Aug 1 02:00:28 miniupnpd[456]: shutting down MiniUPnPd Aug 1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:31 miniupnpd[746]: version 1.9 started Aug 1 02:00:31 miniupnpd[746]: HTTP listening on port 34838 Aug 1 02:00:31 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:32 rc_service: ip-up 500:notify_rc start_upnp Aug 1 02:00:32 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:32 miniupnpd[746]: shutting down MiniUPnPd Aug 1 02:00:36 miniupnpd[751]: version 1.9 started Aug 1 02:00:36 miniupnpd[751]: HTTP listening on port 43021 Aug 1 02:00:36 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:37 ntp: start NTP update Aug 1 02:00:38 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 3 05:01:41 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 3 05:01:41 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 3 05:01:41 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 3 05:01:41 rc_service: ntp 749:notify_rc restart_upnp Dec 3 05:01:41 miniupnpd[751]: shutting down MiniUPnPd Dec 3 05:01:42 rc_service: ntp 749:notify_rc restart_diskmon Dec 3 05:01:43 disk_monitor: Finish Dec 3 05:01:43 miniupnpd[777]: version 1.9 started Dec 3 05:01:43 miniupnpd[777]: HTTP listening on port 58098 Dec 3 05:01:43 miniupnpd[777]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 3 05:01:46 disk monitor: be idle Dec 3 05:01:46 rc_service: zcip 779:notify_rc start_firewall Dec 3 05:01:46 zcip client: configured 169.254.163.221 Dec 3 05:01:48 miniupnpd[777]: shutting down MiniUPnPd Dec 3 05:01:48 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 3 05:01:51 miniupnpd[821]: version 1.9 started Dec 3 05:01:51 miniupnpd[821]: HTTP listening on port 38041 Dec 3 05:01:51 miniupnpd[821]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 3 14:38:57 rc_service: httpds 417:notify_rc start_webs_update Dec 3 16:27:13 rc_service: httpds 417:notify_rc start_webs_update Dec 3 23:04:15 disk_monitor: Got SIGALRM... Dec 4 05:00:31 kernel: Emergency Sync complete Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:10 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:10 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:10 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ace0004, fsr=0x1c06, pc=0x2aefa014 lr=0xed80 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL Aug 1 02:00:16 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[458]: version 1.9 started Aug 1 02:00:18 miniupnpd[458]: HTTP listening on port 57289 Aug 1 02:00:18 miniupnpd[458]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[473]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[473]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:19 pppd[473]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 pppd[473]: PAP authentication succeeded Aug 1 02:00:19 pppd[473]: peer from calling number 00:90:1A:A5:00:86 authorized Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 pppd[473]: local IP address 93.138.65.23 Aug 1 02:00:19 pppd[473]: remote IP address 172.29.252.64 Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:20 rc_service: ip-up 500:notify_rc start_firewall Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:20 rc_service: ip-up 500:notify_rc stop_upnp Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:21 WAN Connection: WAN was restored. Aug 1 02:00:28 miniupnpd[458]: shutting down MiniUPnPd Aug 1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:32 miniupnpd[749]: version 1.9 started Aug 1 02:00:32 miniupnpd[749]: HTTP listening on port 56477 Aug 1 02:00:32 miniupnpd[749]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:32 rc_service: ip-up 500:notify_rc start_upnp Aug 1 02:00:32 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:32 miniupnpd[749]: shutting down MiniUPnPd Aug 1 02:00:34 miniupnpd[753]: version 1.9 started Aug 1 02:00:34 miniupnpd[753]: HTTP listening on port 45468 Aug 1 02:00:34 miniupnpd[753]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:36 ntp: start NTP update Dec 4 05:02:10 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 4 05:02:10 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 4 05:02:10 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 4 05:02:10 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 4 05:02:10 rc_service: ntp 751:notify_rc restart_upnp Dec 4 05:02:10 miniupnpd[753]: shutting down MiniUPnPd Dec 4 05:02:11 miniupnpd[777]: version 1.9 started Dec 4 05:02:11 miniupnpd[777]: HTTP listening on port 34593 Dec 4 05:02:11 miniupnpd[777]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 4 05:02:11 rc_service: ntp 751:notify_rc restart_diskmon Dec 4 05:02:12 disk_monitor: Finish Dec 4 05:02:14 disk monitor: be idle Dec 4 05:02:15 rc_service: zcip 794:notify_rc start_firewall Dec 4 05:02:15 zcip client: configured 169.254.163.221 Dec 4 05:02:15 miniupnpd[777]: shutting down MiniUPnPd Dec 4 05:02:15 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 4 05:02:16 miniupnpd[830]: version 1.9 started Dec 4 05:02:16 miniupnpd[830]: HTTP listening on port 58999 Dec 4 05:02:16 miniupnpd[830]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 4 23:04:47 disk_monitor: Got SIGALRM... Dec 4 23:48:21 miniupnpd[830]: send(res_buf): Connection reset by peer Dec 4 23:56:56 rc_service: httpds 417:notify_rc start_webs_update Dec 4 23:57:13 rc_service: httpds 417:notify_rc start_webs_update Dec 5 00:24:08 miniupnpd[830]: upnp_event_recv: recv(): Connection reset by peer Dec 5 00:38:33 miniupnpd[830]: upnp_event_recv: recv(): Connection reset by peer Dec 5 00:51:09 miniupnpd[830]: upnp_event_recv: recv(): Connection reset by peer Dec 5 05:00:09 kernel: Emergency Sync complete Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:10 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:10 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:10 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2adef004, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored. Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac983b0, fsr=0x1c06, pc=0x7f190b38 lr=0x80208820 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL Aug 1 02:00:16 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:17 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[459]: version 1.9 started Aug 1 02:00:18 miniupnpd[459]: HTTP listening on port 34377 Aug 1 02:00:18 miniupnpd[459]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 pppd[472]: PAP authentication succeeded Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:19 pppd[472]: local IP address 93.138.33.193 Aug 1 02:00:19 pppd[472]: remote IP address 172.29.252.64 Aug 1 02:00:20 rc_service: ip-up 505:notify_rc start_firewall Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:20 rc_service: ip-up 505:notify_rc stop_upnp Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:21 WAN Connection: WAN was restored. Aug 1 02:00:27 miniupnpd[459]: shutting down MiniUPnPd Aug 1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:31 miniupnpd[747]: version 1.9 started Aug 1 02:00:31 miniupnpd[747]: HTTP listening on port 33348 Aug 1 02:00:31 miniupnpd[747]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:31 rc_service: ip-up 505:notify_rc start_upnp Aug 1 02:00:31 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:31 miniupnpd[747]: shutting down MiniUPnPd Aug 1 02:00:34 miniupnpd[753]: version 1.9 started Aug 1 02:00:34 miniupnpd[753]: HTTP listening on port 46842 Aug 1 02:00:34 miniupnpd[753]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:35 ntp: start NTP update Dec 5 05:01:47 rc_service: ntp 750:notify_rc restart_upnp Dec 5 05:01:47 miniupnpd[753]: shutting down MiniUPnPd Dec 5 05:01:47 rc_service: ntp 750:notify_rc restart_diskmon Dec 5 05:01:48 miniupnpd[767]: version 1.9 started Dec 5 05:01:48 miniupnpd[767]: HTTP listening on port 34835 Dec 5 05:01:48 miniupnpd[767]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 5 05:01:48 disk_monitor: Finish Dec 5 05:01:49 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 5 05:01:49 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 5 05:01:49 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 5 05:01:50 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 5 05:01:50 syslog: Generating SSL certificate... Dec 5 05:01:51 disk monitor: be idle Dec 5 05:01:51 syslog: Generating SSL certificate... Dec 5 05:01:54 rc_service: zcip 817:notify_rc start_firewall Dec 5 05:01:54 zcip client: configured 169.254.163.221 Dec 5 05:01:55 miniupnpd[767]: shutting down MiniUPnPd Dec 5 05:01:55 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 5 05:01:57 miniupnpd[845]: version 1.9 started Dec 5 05:01:57 miniupnpd[845]: HTTP listening on port 35000 Dec 5 05:01:57 miniupnpd[845]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 5 17:13:06 rc_service: httpds 417:notify_rc start_webs_update Dec 5 17:19:06 rc_service: httpds 417:notify_rc restart_firewall;restart_qos Dec 5 17:19:07 miniupnpd[845]: shutting down MiniUPnPd Dec 5 17:19:07 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 5 17:19:08 miniupnpd[11742]: version 1.9 started Dec 5 17:19:08 miniupnpd[11742]: HTTP listening on port 59119 Dec 5 17:19:08 miniupnpd[11742]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 5 17:19:09 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 5 17:19:09 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 5 17:19:09 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 5 17:19:09 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 5 17:19:09 kernel: HTB: quantum of class 10030 is big. Consider r2q change. Dec 5 17:19:13 rc_service: httpds 417:notify_rc restart_firewall;restart_qos Dec 5 17:19:14 miniupnpd[11742]: shutting down MiniUPnPd Dec 5 17:19:14 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 5 17:19:17 miniupnpd[11825]: version 1.9 started Dec 5 17:19:17 miniupnpd[11825]: HTTP listening on port 36609 Dec 5 17:19:17 miniupnpd[11825]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 5 17:19:17 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 5 17:19:17 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 5 17:19:17 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 5 17:19:17 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 5 17:19:18 kernel: HTB: quantum of class 10030 is big. Consider r2q change. Dec 5 17:27:34 rc_service: httpds 417:notify_rc restart_firewall;restart_qos Dec 5 17:27:35 miniupnpd[11825]: shutting down MiniUPnPd Dec 5 17:27:35 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 5 17:27:37 miniupnpd[12024]: version 1.9 started Dec 5 17:27:37 miniupnpd[12024]: HTTP listening on port 50107 Dec 5 17:27:37 miniupnpd[12024]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 5 17:27:38 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 5 17:27:38 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 5 17:27:38 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 5 17:27:38 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 5 17:27:38 kernel: HTB: quantum of class 10030 is big. Consider r2q change. Dec 5 17:38:51 rc_service: httpds 417:notify_rc start_webs_update Dec 5 23:04:12 disk_monitor: Got SIGALRM... Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:10 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:10 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:10 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae3c000, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored. Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ad133b0, fsr=0x1c06, pc=0x7f190b38 lr=0x80208820 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL Aug 1 02:00:16 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[464]: version 1.9 started Aug 1 02:00:18 miniupnpd[464]: HTTP listening on port 40151 Aug 1 02:00:18 miniupnpd[464]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:41 rc_service: zcip 659:notify_rc start_firewall Aug 1 02:00:41 zcip client: configured 169.254.163.221 Aug 1 02:00:42 miniupnpd[464]: shutting down MiniUPnPd Aug 1 02:00:42 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)! Aug 1 02:00:43 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:43 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:44 miniupnpd[715]: version 1.9 started Aug 1 02:00:44 miniupnpd[715]: HTTP listening on port 51086 Aug 1 02:00:44 miniupnpd[715]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:47 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:49 pppd[472]: No response to PAP authenticate-requests Aug 1 02:00:49 pppd[472]: Connection terminated. Aug 1 02:00:59 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:59 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:00 pppd[472]: PAP authentication succeeded Aug 1 02:01:00 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized Aug 1 02:01:00 pppd[472]: local IP address 93.138.14.31 Aug 1 02:01:00 pppd[472]: remote IP address 172.29.252.64 Aug 1 02:01:01 rc_service: ip-up 742:notify_rc start_firewall Aug 1 02:01:02 miniupnpd[715]: shutting down MiniUPnPd Aug 1 02:01:02 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:01:02 rc_service: ip-up 742:notify_rc stop_upnp Aug 1 02:01:02 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:01:03 WAN Connection: WAN was restored. Aug 1 02:01:03 miniupnpd[806]: version 1.9 started Aug 1 02:01:03 miniupnpd[806]: HTTP listening on port 56297 Aug 1 02:01:03 miniupnpd[806]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:01:03 rc_service: ip-up 742:notify_rc start_upnp Aug 1 02:01:03 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:01:03 miniupnpd[806]: shutting down MiniUPnPd Aug 1 02:01:05 miniupnpd[810]: version 1.9 started Aug 1 02:01:05 miniupnpd[810]: HTTP listening on port 48458 Aug 1 02:01:05 miniupnpd[810]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:01:06 ntp: start NTP update Dec 6 05:02:21 rc_service: ntp 808:notify_rc restart_upnp Dec 6 05:02:21 miniupnpd[810]: shutting down MiniUPnPd Dec 6 05:02:22 miniupnpd[818]: version 1.9 started Dec 6 05:02:22 miniupnpd[818]: HTTP listening on port 39117 Dec 6 05:02:22 miniupnpd[818]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 6 05:02:22 rc_service: ntp 808:notify_rc restart_diskmon Dec 6 05:02:22 disk_monitor: Finish Dec 6 05:02:23 disk monitor: be idle Dec 6 05:02:23 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 6 05:02:23 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 6 05:02:23 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 6 05:02:23 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 6 05:02:23 kernel: HTB: quantum of class 10030 is big. Consider r2q change. Dec 6 23:05:05 disk_monitor: Got SIGALRM... Dec 7 05:00:09 kernel: Emergency Sync complete Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:11 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae82000, fsr=0x1c06, pc=0x80171f68 lr=0x800cc4c4 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL Aug 1 02:00:16 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:17 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[464]: version 1.9 started Aug 1 02:00:18 miniupnpd[464]: HTTP listening on port 48188 Aug 1 02:00:18 miniupnpd[464]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 pppd[472]: PAP authentication succeeded Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:19 pppd[472]: local IP address 93.139.184.227 Aug 1 02:00:19 pppd[472]: remote IP address 172.29.252.89 Aug 1 02:00:19 rc_service: ip-up 502:notify_rc start_firewall Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:20 rc_service: ip-up 502:notify_rc stop_upnp Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:22 WAN Connection: WAN was restored. Aug 1 02:00:27 miniupnpd[464]: shutting down MiniUPnPd Aug 1 02:00:27 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:30 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:30 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:31 miniupnpd[746]: version 1.9 started Aug 1 02:00:31 miniupnpd[746]: HTTP listening on port 47285 Aug 1 02:00:31 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:31 rc_service: ip-up 502:notify_rc start_upnp Aug 1 02:00:31 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:31 miniupnpd[746]: shutting down MiniUPnPd Aug 1 02:00:33 miniupnpd[751]: version 1.9 started Aug 1 02:00:33 miniupnpd[751]: HTTP listening on port 41997 Aug 1 02:00:33 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:35 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Aug 1 02:00:36 ntp: start NTP update Aug 1 02:00:36 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Aug 1 02:00:36 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 7 05:01:38 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 7 05:01:38 kernel: HTB: quantum of class 10030 is big. Consider r2q change. Dec 7 05:01:38 rc_service: ntp 749:notify_rc restart_upnp Dec 7 05:01:38 miniupnpd[751]: shutting down MiniUPnPd Dec 7 05:01:39 rc_service: ntp 749:notify_rc restart_diskmon Dec 7 05:01:39 miniupnpd[781]: version 1.9 started Dec 7 05:01:39 miniupnpd[781]: HTTP listening on port 53280 Dec 7 05:01:39 miniupnpd[781]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 7 05:01:40 disk_monitor: Finish Dec 7 05:01:42 disk monitor: be idle Dec 7 05:01:43 rc_service: zcip 790:notify_rc start_firewall Dec 7 05:01:43 zcip client: configured 169.254.163.221 Dec 7 05:01:45 miniupnpd[781]: shutting down MiniUPnPd Dec 7 05:01:45 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 7 05:01:48 miniupnpd[831]: version 1.9 started Dec 7 05:01:48 miniupnpd[831]: HTTP listening on port 37489 Dec 7 05:01:48 miniupnpd[831]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 7 11:46:32 kernel: wl1: PHYTX error Dec 7 11:46:33 kernel: wl1: PHYTX error Dec 7 11:46:33 kernel: wl1: PHYTX error Dec 7 17:38:38 rc_service: httpds 417:notify_rc start_webs_update Dec 7 17:38:56 rc_service: httpds 417:notify_rc restart_firewall;restart_qos Dec 7 17:38:57 miniupnpd[831]: shutting down MiniUPnPd Dec 7 17:38:57 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 7 17:38:58 miniupnpd[11999]: version 1.9 started Dec 7 17:38:58 miniupnpd[11999]: HTTP listening on port 54246 Dec 7 17:38:58 miniupnpd[11999]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 7 17:38:59 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 7 17:38:59 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 7 17:38:59 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 7 17:38:59 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 7 23:04:25 disk_monitor: Got SIGALRM... Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:11 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae13000, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored. Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac803b0, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL Aug 1 02:00:16 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:17 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[458]: version 1.9 started Aug 1 02:00:18 miniupnpd[458]: HTTP listening on port 38078 Aug 1 02:00:18 miniupnpd[458]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:18 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Aug 1 02:00:18 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:19 pppd[472]: PAP authentication succeeded Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized Aug 1 02:00:19 pppd[472]: local IP address 93.139.145.162 Aug 1 02:00:19 pppd[472]: remote IP address 172.29.252.89 Aug 1 02:00:19 rc_service: ip-up 500:notify_rc start_firewall Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:20 rc_service: ip-up 500:notify_rc stop_upnp Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:22 WAN Connection: WAN was restored. Aug 1 02:00:27 miniupnpd[458]: shutting down MiniUPnPd Aug 1 02:00:27 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:32 miniupnpd[755]: version 1.9 started Aug 1 02:00:32 miniupnpd[755]: HTTP listening on port 41125 Aug 1 02:00:32 miniupnpd[755]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:32 rc_service: ip-up 500:notify_rc start_upnp Aug 1 02:00:32 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:32 miniupnpd[755]: shutting down MiniUPnPd Aug 1 02:00:34 miniupnpd[759]: version 1.9 started Aug 1 02:00:34 miniupnpd[759]: HTTP listening on port 34872 Aug 1 02:00:34 miniupnpd[759]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:35 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Aug 1 02:00:36 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Aug 1 02:00:36 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Aug 1 02:00:36 ntp: start NTP update Aug 1 02:00:36 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 8 05:01:57 rc_service: ntp 757:notify_rc restart_upnp Dec 8 05:01:57 miniupnpd[759]: shutting down MiniUPnPd Dec 8 05:01:57 miniupnpd[789]: version 1.9 started Dec 8 05:01:57 miniupnpd[789]: HTTP listening on port 39839 Dec 8 05:01:57 miniupnpd[789]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 8 05:01:58 rc_service: ntp 757:notify_rc restart_diskmon Dec 8 05:01:58 disk_monitor: Finish Dec 8 05:01:58 disk monitor: be idle Dec 8 05:02:02 rc_service: zcip 801:notify_rc start_firewall Dec 8 05:02:02 zcip client: configured 169.254.163.221 Dec 8 05:02:02 miniupnpd[789]: shutting down MiniUPnPd Dec 8 05:02:02 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 8 05:02:03 miniupnpd[829]: version 1.9 started Dec 8 05:02:03 miniupnpd[829]: HTTP listening on port 54681 Dec 8 05:02:03 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:11 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae70004, fsr=0x1c06, pc=0x2ac34c58 lr=0x17bd8 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1403) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <0>Kernel panic - not syncing: Out of memory: system-wide panic_on_oom is enabled Aug 1 02:00:11 kernel: <0> Aug 1 02:00:11 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<802fec2c>] (panic+0x7c/0x1a4) Aug 1 02:00:11 kernel: <4>[<802fec2c>] (panic+0x7c/0x1a4) from [<80091038>] (out_of_memory+0x2c8/0x328) Aug 1 02:00:11 kernel: <4>[<80091038>] (out_of_memory+0x2c8/0x328) from [<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) Aug 1 02:00:11 kernel: <4>[<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) from [<80096000>] (__do_page_cache_readahead+0x140/0x2d0) Aug 1 02:00:11 kernel: <4>[<80096000>] (__do_page_cache_readahead+0x140/0x2d0) from [<80096440>] (ra_submit+0x28/0x30) Aug 1 02:00:11 kernel: <4>[<80096440>] (ra_submit+0x28/0x30) from [<8008e5d0>] (filemap_fault+0x42c/0x454) Aug 1 02:00:11 kernel: <4>[<8008e5d0>] (filemap_fault+0x42c/0x454) from [<800a315c>] (__do_fault.clone.60+0x54/0x4c8) Aug 1 02:00:11 kernel: <4>[<800a315c>] (__do_fault.clone.60+0x54/0x4c8) from [<800a67c4>] (handle_mm_fault+0x114/0x934) Aug 1 02:00:11 kernel: <4>[<800a67c4>] (handle_mm_fault+0x114/0x934) from [<8003fd90>] (do_page_fault+0x178/0x1ec) Aug 1 02:00:11 kernel: <4>[<8003fd90>] (do_page_fault+0x178/0x1ec) from [<80038298>] (do_PrefetchAbort+0x30/0x9c) Aug 1 02:00:11 kernel: <4>[<80038298>] (do_PrefetchAbort+0x30/0x9c) from [<803bf2e0>] (ret_from_exception+0x0/0x10) Aug 1 02:00:11 kernel: <4>Exception stack(0x849fffb0 to 0x849ffff8) Aug 1 02:00:11 kernel: <4>ffa0: 00000001 7ea52ca0 7ea52c20 00000000 Aug 1 02:00:11 kernel: <4>ffc0: 7ea52da8 7ea52c20 0000000a 0000008e 00000007 7ea52c20 00027078 00000001 Aug 1 02:00:11 kernel: <4>ffe0: 000258c4 7ea52768 0000b318 2ab764cc 60000010 ffffffff Aug 1 02:00:11 kernel: <0>Rebooting in 3 seconds.. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL Aug 1 02:00:16 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:17 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[465]: version 1.9 started Aug 1 02:00:18 miniupnpd[465]: HTTP listening on port 35710 Aug 1 02:00:18 miniupnpd[465]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:21 pppd[472]: PAP authentication failed Aug 1 02:00:28 pppd[472]: Connection terminated. Aug 1 02:00:28 pppd[472]: Modem hangup Aug 1 02:00:38 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:38 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:41 rc_service: zcip 674:notify_rc start_firewall Aug 1 02:00:41 zcip client: configured 169.254.163.221 Aug 1 02:00:41 pppd[472]: PAP authentication failed Aug 1 02:00:42 miniupnpd[465]: shutting down MiniUPnPd Aug 1 02:00:42 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)! Aug 1 02:00:43 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:44 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:44 miniupnpd[731]: version 1.9 started Aug 1 02:00:44 miniupnpd[731]: HTTP listening on port 46554 Aug 1 02:00:44 miniupnpd[731]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:46 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:48 pppd[472]: Connection terminated. Aug 1 02:00:48 pppd[472]: Modem hangup Aug 1 02:00:59 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0 Aug 1 02:00:59 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:01 pppd[472]: PAP authentication failed Aug 1 02:01:01 pppd[472]: Connection terminated. Aug 1 02:01:12 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:01:12 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:14 pppd[472]: PAP authentication failed Aug 1 02:01:14 pppd[472]: Connection terminated. Aug 1 02:01:25 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:01:25 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:27 pppd[472]: PAP authentication failed Aug 1 02:01:27 pppd[472]: Connection terminated. Aug 1 02:01:38 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:01:38 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:38 pppd[472]: PAP authentication succeeded Aug 1 02:01:38 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized Aug 1 02:01:39 pppd[472]: local IP address 93.138.5.224 Aug 1 02:01:39 pppd[472]: remote IP address 172.29.252.64 Aug 1 02:01:39 rc_service: ip-up 805:notify_rc start_firewall Aug 1 02:01:40 miniupnpd[731]: shutting down MiniUPnPd Aug 1 02:01:40 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:01:40 rc_service: ip-up 805:notify_rc stop_upnp Aug 1 02:01:40 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:01:40 WAN Connection: WAN was restored. Aug 1 02:01:41 miniupnpd[865]: version 1.9 started Aug 1 02:01:41 miniupnpd[865]: HTTP listening on port 54744 Aug 1 02:01:41 miniupnpd[865]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:01:41 rc_service: ip-up 805:notify_rc start_upnp Aug 1 02:01:41 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:01:41 miniupnpd[865]: shutting down MiniUPnPd Aug 1 02:01:42 miniupnpd[868]: version 1.9 started Aug 1 02:01:42 miniupnpd[868]: HTTP listening on port 37727 Aug 1 02:01:42 miniupnpd[868]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:01:43 ntp: start NTP update Dec 8 22:53:22 rc_service: ntp 867:notify_rc restart_upnp Dec 8 22:53:22 miniupnpd[868]: shutting down MiniUPnPd Dec 8 22:53:23 miniupnpd[878]: version 1.9 started Dec 8 22:53:23 miniupnpd[878]: HTTP listening on port 48606 Dec 8 22:53:23 miniupnpd[878]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 8 22:53:23 rc_service: ntp 867:notify_rc restart_diskmon Dec 8 22:53:23 disk_monitor: Finish Dec 8 22:53:24 disk monitor: be idle Dec 8 22:53:24 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 8 22:53:24 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 8 22:53:24 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 8 22:53:24 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 8 22:54:06 rc_service: httpd 418:notify_rc start_webs_update Dec 8 23:00:25 disk_monitor: Got SIGALRM... Aug 1 02:00:10 syslogd started: BusyBox v1.17.4 Aug 1 02:00:10 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:10 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:10 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:10 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:10 kernel: Machine: Northstar Prototype Aug 1 02:00:10 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:10 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: * Invalid signature of oopsbuf: 37-F3-57-77-B5-75-56-55 (len 4283905917) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:10 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:10 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:11 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae31004, fsr=0x1c06, pc=0x2abffbe8 lr=0x2ac00c7c ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:12 WAN Connection: Fail to connect with some issues. Aug 1 02:00:17 RT-AC1200G+: start httpd - SSL Aug 1 02:00:17 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[461]: version 1.9 started Aug 1 02:00:18 miniupnpd[461]: HTTP listening on port 48173 Aug 1 02:00:18 miniupnpd[461]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:19 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:20 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:20 syslog: module leds-usb not found in modules.dep Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:42 rc_service: zcip 654:notify_rc start_firewall Aug 1 02:00:42 zcip client: configured 169.254.163.221 Aug 1 02:00:42 miniupnpd[461]: shutting down MiniUPnPd Aug 1 02:00:42 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)! Aug 1 02:00:44 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:44 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:44 miniupnpd[710]: version 1.9 started Aug 1 02:00:44 miniupnpd[710]: HTTP listening on port 52585 Aug 1 02:00:44 miniupnpd[710]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:47 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:54 pppd[472]: Timeout waiting for PADO packets Aug 1 02:02:09 pppd[472]: Timeout waiting for PADO packets Aug 1 02:02:09 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0 Aug 1 02:02:09 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:02:39 pppd[472]: PAP authentication succeeded Aug 1 02:02:39 pppd[472]: peer from calling number 00:90:1A:A3:B7:70 authorized Aug 1 02:02:40 pppd[472]: local IP address 93.142.212.104 Aug 1 02:02:40 pppd[472]: remote IP address 172.29.252.90 Aug 1 02:02:40 rc_service: ip-up 733:notify_rc start_firewall Aug 1 02:02:41 miniupnpd[710]: shutting down MiniUPnPd Aug 1 02:02:41 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:02:41 rc_service: ip-up 733:notify_rc stop_upnp Aug 1 02:02:41 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:02:42 miniupnpd[792]: version 1.9 started Aug 1 02:02:42 miniupnpd[792]: HTTP listening on port 44126 Aug 1 02:02:42 miniupnpd[792]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:02:42 rc_service: ip-up 733:notify_rc start_upnp Aug 1 02:02:42 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:02:42 miniupnpd[792]: shutting down MiniUPnPd Aug 1 02:02:43 miniupnpd[794]: version 1.9 started Aug 1 02:02:43 miniupnpd[794]: HTTP listening on port 40806 Aug 1 02:02:43 miniupnpd[794]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:02:44 WAN Connection: WAN was restored. Aug 1 02:02:44 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Aug 1 02:02:44 ntp: start NTP update Aug 1 02:02:44 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Aug 1 02:02:44 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Aug 1 02:02:44 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 9 09:37:03 rc_service: ntp 795:notify_rc restart_upnp Dec 9 09:37:03 miniupnpd[794]: shutting down MiniUPnPd Dec 9 09:37:04 miniupnpd[824]: version 1.9 started Dec 9 09:37:04 miniupnpd[824]: HTTP listening on port 48536 Dec 9 09:37:04 miniupnpd[824]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 9 09:37:04 rc_service: ntp 795:notify_rc restart_diskmon Dec 9 09:37:04 disk_monitor: Finish Dec 9 09:37:05 disk monitor: be idle Dec 9 09:47:53 pppd[472]: Serial link appears to be disconnected. Dec 9 09:47:54 WAN Connection: Fail to connect with some issues. Dec 9 09:47:54 stop_nat_rules: apply the redirect_rules! Dec 9 09:47:59 pppd[472]: Connection terminated. Dec 9 09:47:59 pppd[472]: Modem hangup Dec 9 09:48:09 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Dec 9 09:48:09 pppd[472]: Connect: ppp0 <--> eth0 Dec 9 09:48:13 pppd[472]: PAP authentication failed Dec 9 09:48:13 pppd[472]: Connection terminated. Dec 9 09:48:23 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0 Dec 9 09:48:23 pppd[472]: Connect: ppp0 <--> eth0 Dec 9 09:48:26 pppd[472]: PAP authentication failed Dec 9 09:48:26 pppd[472]: Connection terminated. Dec 9 09:48:36 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Dec 9 09:48:36 pppd[472]: Connect: ppp0 <--> eth0 Dec 9 09:48:39 pppd[472]: PAP authentication failed Dec 9 09:48:39 pppd[472]: Connection terminated. Dec 9 09:48:49 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Dec 9 09:48:49 pppd[472]: Connect: ppp0 <--> eth0 Dec 9 09:49:17 rc_service: httpds 417:notify_rc start_webs_update Dec 9 09:49:19 pppd[472]: No response to PAP authenticate-requests Dec 9 09:49:20 pppd[472]: Connection terminated. Dec 9 09:49:30 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Dec 9 09:49:30 pppd[472]: Connect: ppp0 <--> eth0 Dec 9 09:49:54 rc_service: httpds 417:notify_rc start_webs_update Dec 9 09:50:00 pppd[472]: PAP authentication succeeded Dec 9 09:50:00 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized Dec 9 09:50:01 pppd[472]: local IP address 93.139.178.251 Dec 9 09:50:01 pppd[472]: remote IP address 172.29.252.89 Dec 9 09:50:01 rc_service: ip-up 1308:notify_rc start_firewall Dec 9 09:50:02 miniupnpd[824]: shutting down MiniUPnPd Dec 9 09:50:02 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 9 09:50:02 rc_service: httpds 417:notify_rc reboot Dec 9 09:50:02 rc_service: waitting "start_firewall" via ip-up ... Dec 9 09:50:02 rc_service: ip-up 1308:notify_rc stop_upnp Dec 9 09:50:02 rc_service: waitting "start_firewall" via ip-up ... Dec 9 09:50:03 miniupnpd[1352]: version 1.9 started Dec 9 09:50:03 miniupnpd[1352]: HTTP listening on port 58937 Dec 9 09:50:03 miniupnpd[1352]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 9 09:50:04 pppd[472]: Connection terminated. Dec 9 09:50:05 kernel: Attempt to kill tasklet from interrupt Dec 9 09:50:05 stop_nat_rules: apply the redirect_rules! Dec 9 09:50:06 iTunes: daemon is stoped Dec 9 09:50:06 FTP Server: daemon is stoped Dec 9 09:50:06 Samba Server: smb daemon is stoped Dec 9 09:50:06 kernel: gro disabled Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:09 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:09 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:09 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:09 kernel: Virtual kernel memory layout: Aug 1 02:00:09 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:09 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:09 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:09 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:09 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:09 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:09 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:09 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:09 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:10 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:10 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:10 kernel: === PPTP init === Aug 1 02:00:10 kernel: Registering the dns_resolver key type Aug 1 02:00:10 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2adf4004, fsr=0x1c06, pc=0x800ce0e0 lr=0x800c1154 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL Aug 1 02:00:16 RT-AC1200G+: start httpd Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:17 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 syslog: Generating SSL certificate... Aug 1 02:00:18 syslog: Generating SSL certificate... Aug 1 02:00:18 miniupnpd[457]: version 1.9 started Aug 1 02:00:18 miniupnpd[457]: HTTP listening on port 36504 Aug 1 02:00:18 miniupnpd[457]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[466]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[466]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0 Aug 1 02:00:19 pppd[466]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:19 pppd[466]: PAP authentication succeeded Aug 1 02:00:19 pppd[466]: peer from calling number 84:B5:9C:A4:4D:B7 authorized Aug 1 02:00:19 kernel: SCSI subsystem initialized Aug 1 02:00:19 pppd[466]: local IP address 93.141.119.37 Aug 1 02:00:19 pppd[466]: remote IP address 172.29.252.59 Aug 1 02:00:20 rc_service: ip-up 509:notify_rc start_firewall Aug 1 02:00:20 rc_service: ip-up 509:notify_rc stop_upnp Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:21 WAN Connection: WAN was restored. Aug 1 02:00:26 miniupnpd[457]: shutting down MiniUPnPd Aug 1 02:00:26 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:28 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:29 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:29 miniupnpd[750]: version 1.9 started Aug 1 02:00:29 miniupnpd[750]: HTTP listening on port 56881 Aug 1 02:00:29 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:29 rc_service: ip-up 509:notify_rc start_upnp Aug 1 02:00:29 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:29 miniupnpd[750]: shutting down MiniUPnPd Aug 1 02:00:31 miniupnpd[753]: version 1.9 started Aug 1 02:00:31 miniupnpd[753]: HTTP listening on port 38145 Aug 1 02:00:31 miniupnpd[753]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:32 ntp: start NTP update Dec 9 09:51:26 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 9 09:51:26 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 9 09:51:26 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 9 09:51:26 rc_service: ntp 752:notify_rc restart_upnp Dec 9 09:51:26 miniupnpd[753]: shutting down MiniUPnPd Dec 9 09:51:27 miniupnpd[775]: version 1.9 started Dec 9 09:51:27 miniupnpd[775]: HTTP listening on port 55434 Dec 9 09:51:27 miniupnpd[775]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 9 09:51:27 rc_service: ntp 752:notify_rc restart_diskmon Dec 9 09:51:27 disk_monitor: Finish Dec 9 09:51:28 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 9 09:51:29 disk monitor: be idle Dec 9 09:51:34 rc_service: zcip 801:notify_rc start_firewall Dec 9 09:51:34 zcip client: configured 169.254.163.221 Dec 9 09:51:34 miniupnpd[775]: shutting down MiniUPnPd Dec 9 09:51:34 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 9 09:51:35 miniupnpd[829]: version 1.9 started Dec 9 09:51:35 miniupnpd[829]: HTTP listening on port 52933 Dec 9 09:51:35 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 9 10:00:30 disk_monitor: Got SIGALRM... Dec 9 23:02:13 disk_monitor: Got SIGALRM... Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:11 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae35004, fsr=0x1c06, pc=0x2abb0be8 lr=0x2abb1c7c ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL Aug 1 02:00:16 RT-AC1200G+: start httpd Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[465]: version 1.9 started Aug 1 02:00:18 miniupnpd[465]: HTTP listening on port 52007 Aug 1 02:00:18 miniupnpd[465]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:18 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:18 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 pppd[472]: PAP authentication succeeded Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:19 pppd[472]: local IP address 93.138.84.144 Aug 1 02:00:19 pppd[472]: remote IP address 172.29.252.64 Aug 1 02:00:20 rc_service: ip-up 500:notify_rc start_firewall Aug 1 02:00:20 rc_service: ip-up 500:notify_rc stop_upnp Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:22 WAN Connection: WAN was restored. Aug 1 02:00:29 miniupnpd[465]: shutting down MiniUPnPd Aug 1 02:00:29 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:32 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:32 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:32 miniupnpd[750]: version 1.9 started Aug 1 02:00:32 miniupnpd[750]: HTTP listening on port 42798 Aug 1 02:00:32 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:33 rc_service: ip-up 500:notify_rc start_upnp Aug 1 02:00:33 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:33 miniupnpd[750]: shutting down MiniUPnPd Aug 1 02:00:35 miniupnpd[755]: version 1.9 started Aug 1 02:00:35 miniupnpd[755]: HTTP listening on port 48602 Aug 1 02:00:35 miniupnpd[755]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:36 ntp: start NTP update Dec 10 05:01:57 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 10 05:01:57 rc_service: ntp 753:notify_rc restart_upnp Dec 10 05:01:57 miniupnpd[755]: shutting down MiniUPnPd Dec 10 05:01:57 miniupnpd[772]: version 1.9 started Dec 10 05:01:57 miniupnpd[772]: HTTP listening on port 55124 Dec 10 05:01:57 miniupnpd[772]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 10 05:01:57 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 10 05:01:58 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 10 05:01:58 rc_service: ntp 753:notify_rc restart_diskmon Dec 10 05:01:58 disk_monitor: Finish Dec 10 05:01:58 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 10 05:02:00 disk monitor: be idle Dec 10 05:02:01 rc_service: zcip 788:notify_rc start_firewall Dec 10 05:02:01 zcip client: configured 169.254.163.221 Dec 10 05:02:03 miniupnpd[772]: shutting down MiniUPnPd Dec 10 05:02:03 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 10 05:02:04 miniupnpd[825]: version 1.9 started Dec 10 05:02:04 miniupnpd[825]: HTTP listening on port 48968 Dec 10 05:02:04 miniupnpd[825]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:11 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:11 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:11 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:11 kernel: Virtual kernel memory layout: Aug 1 02:00:11 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:11 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:11 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:11 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:11 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:11 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:11 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:11 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:11 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:11 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:11 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:11 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:11 kernel: bio: create slab at 0 Aug 1 02:00:12 kernel: PCI: no core Aug 1 02:00:12 kernel: PCI: no core Aug 1 02:00:12 kernel: PCI: Fixing up bus 0 Aug 1 02:00:12 kernel: PCI: Fixing up bus 1 Aug 1 02:00:12 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:12 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:12 kernel: PCI: Fixing up bus 0 Aug 1 02:00:12 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:12 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:12 kernel: pflash: found no supported devices Aug 1 02:00:12 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:12 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:12 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:12 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:12 WAN Connection: Fail to connect with some issues. Aug 1 02:00:12 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:12 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:12 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:12 kernel: === PPTP init === Aug 1 02:00:12 kernel: Registering the dns_resolver key type Aug 1 02:00:12 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:12 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:12 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:12 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:12 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:12 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:12 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:12 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:12 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:12 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:12 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:12 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:12 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:12 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:12 kernel: External imprecise Data abort at addr=0x2ae99000, fsr=0x1c06, pc=0x800c2aec lr=0x800ce1c8 ignored. Aug 1 02:00:12 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:12 kernel: [dump prev ops] from 87000000, local len(8179) Aug 1 02:00:12 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:12 kernel: <0>Kernel panic - not syncing: Out of memory: system-wide panic_on_oom is enabled Aug 1 02:00:12 kernel: <0> Aug 1 02:00:12 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<802fec2c>] (panic+0x7c/0x1a4) Aug 1 02:00:12 kernel: <4>[<802fec2c>] (panic+0x7c/0x1a4) from [<80091038>] (out_of_memory+0x2c8/0x328) Aug 1 02:00:12 kernel: <4>[<80091038>] (out_of_memory+0x2c8/0x328) from [<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) Aug 1 02:00:12 kernel: <4>[<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) from [<80096000>] (__do_page_cache_readahead+0x140/0x2d0) Aug 1 02:00:12 kernel: <4>[<80096000>] (__do_page_cache_readahead+0x140/0x2d0) from [<80096440>] (ra_submit+0x28/0x30) Aug 1 02:00:12 kernel: <4>[<80096440>] (ra_submit+0x28/0x30) from [<8008e5d0>] (filemap_fault+0x42c/0x454) Aug 1 02:00:12 kernel: <4>[<8008e5d0>] (filemap_fault+0x42c/0x454) from [<800a315c>] (__do_fault.clone.60+0x54/0x4c8) Aug 1 02:00:12 kernel: <4>[<800a315c>] (__do_fault.clone.60+0x54/0x4c8) from [<800a67c4>] (handle_mm_fault+0x114/0x934) Aug 1 02:00:12 kernel: <4>[<800a67c4>] (handle_mm_fault+0x114/0x934) from [<8003fd90>] (do_page_fault+0x178/0x1ec) Aug 1 02:00:13 kernel: <4>[<8003fd90>] (do_page_fault+0x178/0x1ec) from [<80038298>] (do_PrefetchAbort+0x30/0x9c) Aug 1 02:00:13 kernel: <4>[<80038298>] (do_PrefetchAbort+0x30/0x9c) from [<803bf2e0>] (ret_from_exception+0x0/0x10) Aug 1 02:00:13 kernel: <4>Exception stack(0x8534ffb0 to 0x8534fff8) Aug 1 02:00:13 kernel: <4>ffa0: 0000000e 00000008 7eae7c48 00000000 Aug 1 02:00:13 kernel: <4>ffc0: 7eae7c48 00000001 7eae7e94 000000b3 0000d1f0 0000ec14 7eae7e08 00000000 Aug 1 02:00:13 kernel: <4>ffe0: 2aef35b4 7eae7948 2ae9b254 0003be5c 00000010 ffffffff Aug 1 02:00:13 kernel: <0>Rebooting in 3 seconds..osl_ctfpool_add: skb alloc of len 2272 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed Aug 1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:13 kernel: <4>__alloc_pages_slowpath: 54706 callbacks suppressed Aug 1 02:00:13 kernel: <4>watchdog: page allocation failure. order:0, mode:0x4020 Aug 1 02:00:13 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) Aug 1 02:00:13 kernel: <4>[<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0) Aug 1 02:00:13 kernel: <4>[<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) Aug 1 02:00:13 kernel: <4>[<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104) Aug 1 02:00:13 kernel: <4>[<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac) Aug 1 02:00:13 kernel: <4>[<801fc860>] (osl_alloc_skb+0x50/0xac) from [<803c2cc0>] (osl_pktget+0x6c/0x170) Aug 1 02:00:13 kernel: <4>[<803c2cc0>] (osl_pktget+0x6c/0x170) from [<803c1a34>] (_dma_rxfill+0x3c8/0x51c) Aug 1 02:00:13 kernel: <4>[<803c1a34>] (_dma_rxfill+0x3c8/0x51c) from [<7f289fc0>] (wlc_bmac_recv+0x368/0x380 [wl]) Aug 1 02:00:13 kernel: <4>unwind: Index not found 7f289fc0 Aug 1 02:00:13 kernel: <4>Mem-info: Aug 1 02:00:13 kernel: <4>DMA per-cpu: Aug 1 02:00:13 kernel: <4>CPU 0: hi: 42, btch: 7 usd: 6 Aug 1 02:00:13 kernel: <4>active_anon:941 inactive_anon:953 isolated_anon:0 Aug 1 02:00:13 kernel: <4> active_file:0 inactive_file:0 isolated_file:32 Aug 1 02:00:13 kernel: <4> unevictable:0 dirty:0 writeback:0 unstable:0 Aug 1 02:00:13 kernel: <4> free:383 slab_reclaimable:82 slab_unreclaimable:25949 Aug 1 02:00:13 kernel: <4> mapped:16 shmem:172 pagetables:151 bounce:0 Aug 1 02:00:13 kernel: <4>DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:3764kB inactive_anon:3812kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):128kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:64kB shmem:688kB slab_reclaimable:328kB slab_unreclaimable:103796kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no Aug 1 02:00:13 kernel: <4>lowmem_reserve[]: 0 0 0 Aug 1 02:00:13 kernel: <4>DMA: 111*4kB 52*8kB 28*16kB 1*32kB 1*64kB 1*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 1532kB Aug 1 02:00:13 kernel: <4>185 total pagecache pages Aug 1 02:00:13 kernel: <4>0 pages in swap cache Aug 1 02:00:13 kernel: <4>Swap cache stats: add 0, delete 0, find 0/0 Aug 1 02:00:13 kernel: <4>Free swap = 0kB Aug 1 02:00:13 kernel: <4>Total swap = 0kB Aug 1 02:00:13 kernel: <4>32768 pages of RAM Aug 1 02:00:13 kernel: <4>571 free pages Aug 1 02:00:13 kernel: <4>1352 reserved pages Aug 1 02:00:13 kernel: <4>8182 slab pages Aug 1 02:00:13 kernel: <4>266 pages shared Aug 1 02:00:13 kernel: <4>0 pages swap cached Aug 1 02:00:13 kernel: <4>SLUB: Unable to allocate memory on node -1 (gfp=0x20) Aug 1 02:00:13 kernel: <4> cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0 Aug 1 02:00:13 kernel: <4> node 0: slabs: 3297, objs: 20972, free: 0 Aug 1 02:00:13 kernel: <4>watchdog: page allocation failure. order:0, mode:0x4020 Aug 1 02:00:13 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) Aug 1 02:00:13 kernel: <4>[<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0) Aug 1 02:00:13 kernel: <4>[<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) Aug 1 02:00:13 kernel: <4>[<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104) Aug 1 02:00:13 kernel: <4>[<803b28d0>] (__alloc_skb+0x54/0x104) from [<802179c0>] (pskb_copy+0x20/0x184) Aug 1 02:00:13 kernel: <4>[<802179c0>] (pskb_copy+0x20/0x184) from [<801fcbc4>] (osl_pktdup+0x68/0x134) Aug 1 02:00:13 kernel: <4>[<801fcbc4>] (osl_pktdup+0x68/0x134) from [<7f28edf4>] (wlc_recvdata_sendup+0x714/0x768 [wl]) Aug 1 02:00:13 kernel: <4>unwind: Index not found 7f28edf4 Aug 1 02:00:13 kernel: <4>Mem-info: Aug 1 02:00:13 kernel: <4>DMA per-cpu: Aug 1 02:00:13 kernel: <4>CPU 0: hi: 42, btch: 7 usd: 6 Aug 1 02:00:13 kernel: <4>active_anon:941 inactive_anon:953 isolated_anon:0 Aug 1 02:00:13 kernel: <4> active_file:0 inactive_file:0 isolated_file:32 Aug 1 02:00:13 kernel: <4> unevictable:0 dirty:0 writeback:0 unstable:0 Aug 1 02:00:13 kernel: <4> free:383 slab_reclaimable:82 slab_unreclaimable:25949 Aug 1 02:00:13 kernel: <4> mapped:16 shmem:172 pagetables:151 bounce:0 Aug 1 02:00:13 kernel: <4>DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:3764kB inactive_anon:3812kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):128kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:64kB shmem:688kB slab_reclaimable:328kB slab_unreclaimable:103796kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no Aug 1 02:00:13 kernel: <4>lowmem_reserve[]: 0 0 0 Aug 1 02:00:13 kernel: <4>DMA: 111*4kB 52*8kB 28*16kB 1*32kB 1*64kB 1*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 1532kB Aug 1 02:00:13 kernel: <4>185 total pagecache pages Aug 1 02:00:13 kernel: <4>0 pages in swap cache Aug 1 02:00:13 kernel: <4>Swap cache stats: add 0, delete 0, find 0/0 Aug 1 02:00:13 kernel: <4>Free swap = 0kB Aug 1 02:00:13 kernel: <4>Total swap = 0kB Aug 1 02:00:13 kernel: <4>32768 pages of RAM Aug 1 02:00:13 kernel: <4>571 free pages Aug 1 02:00:13 kernel: <4>1352 reserved pages Aug 1 02:00:13 kernel: <4>8182 slab pages Aug 1 02:00:13 kernel: <4>266 pages shared Aug 1 02:00:13 kernel: <4>0 pages swap cached Aug 1 02:00:13 kernel: <4>SLUB: Unable to allocate memory on node -1 (gfp=0x20) Aug 1 02:00:13 kernel: <4> cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0 Aug 1 02:00:13 kernel: <4> node 0: slabs: 3297, objs: 20972, free: 0 Aug 1 02:00:13 kernel: <4>watchdog: page allocation failure. order:0, mode:0x4020 Aug 1 02:00:13 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) Aug 1 02:00:13 kernel: <4>[<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0) Aug 1 02:00:13 kernel: <4>[<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) Aug 1 02:00:13 kernel: <4>[<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104) Aug 1 02:00:13 kernel: <4>[<803b28d0>] (__alloc_skb+0x54/0x104) from [<802179c0>] (pskb_copy+0x20/0x184) Aug 1 02:00:13 kernel: <4>[<802179c0>] (pskb_copy+0x20/0x184) from [<801fcbc4>] (osl_pktdup+0x68/0x134) Aug 1 02:00:13 kernel: <4>[<801fcbc4>] (osl_pktdup+0x68/0x134) from [<7f28edf4>] (wlc_recvdata_sendup+0x714/0x768 [wl]) Aug 1 02:00:13 kernel: <4>unwind: Index not found 7f28edf4 Aug 1 02:00:13 kernel: <4>Mem-info: Aug 1 02:00:13 kernel: <4>DMA per-cpu: Aug 1 02:00:13 kernel: <4>CPU 0: hi: 42, btch: 7 usd: 6 Aug 1 02:00:13 kernel: <4>active_anon:941 inactive_anon:953 isolated_anon:0 Aug 1 02:00:13 kernel: <4> active_file:0 inactive_file:0 isolated_file:32 Aug 1 02:00:13 kernel: <4> unevictable:0 dirty:0 writeback:0 unstable:0 Aug 1 02:00:13 kernel: <4> free:383 slab_reclaimable:82 slab_unreclaimable:25949 Aug 1 02:00:13 kernel: <4> mapped:16 shmem:172 pagetables:151 bounce:0 Aug 1 02:00:13 kernel: <4>DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:3764kB inactive_anon:3812kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):128kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:64kB Aug 1 02:00:13 kernel: ____________________________________________________________________________ Aug 1 02:00:17 RT-AC1200G+: start httpd - SSL Aug 1 02:00:17 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:18 syslog: Generating SSL certificate... Aug 1 02:00:18 disk monitor: be idle Aug 1 02:00:18 hour monitor: daemon is starting Aug 1 02:00:18 hour monitor: daemon terminates Aug 1 02:00:18 jffs2: valid logs(1) Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[463]: version 1.9 started Aug 1 02:00:18 miniupnpd[463]: HTTP listening on port 33441 Aug 1 02:00:18 miniupnpd[463]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:19 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:20 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:20 syslog: module leds-usb not found in modules.dep Aug 1 02:00:21 kernel: SCSI subsystem initialized Aug 1 02:00:22 pppd[472]: PAP authentication failed Aug 1 02:00:28 pppd[472]: Connection terminated. Aug 1 02:00:28 pppd[472]: Modem hangup Aug 1 02:00:39 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0 Aug 1 02:00:39 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:42 pppd[472]: PAP authentication failed Aug 1 02:00:42 pppd[472]: Connection terminated. Aug 1 02:00:43 rc_service: zcip 684:notify_rc start_firewall Aug 1 02:00:43 zcip client: configured 169.254.163.221 Aug 1 02:00:44 miniupnpd[463]: shutting down MiniUPnPd Aug 1 02:00:44 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)! Aug 1 02:00:45 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:45 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:45 miniupnpd[740]: version 1.9 started Aug 1 02:00:45 miniupnpd[740]: HTTP listening on port 47434 Aug 1 02:00:45 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:47 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:52 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Aug 1 02:00:52 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:55 pppd[472]: PAP authentication failed Aug 1 02:00:55 pppd[472]: Connection terminated. Aug 1 02:01:05 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0 Aug 1 02:01:05 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:08 pppd[472]: PAP authentication failed Aug 1 02:01:08 pppd[472]: Connection terminated. Aug 1 02:01:18 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0 Aug 1 02:01:18 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:21 pppd[472]: PAP authentication failed Aug 1 02:01:21 pppd[472]: Connection terminated. Aug 1 02:01:31 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0 Aug 1 02:01:31 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:34 pppd[472]: PAP authentication failed Aug 1 02:01:34 pppd[472]: Connection terminated. Aug 1 02:01:44 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Aug 1 02:01:44 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:44 pppd[472]: PAP authentication succeeded Aug 1 02:01:44 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized Aug 1 02:01:45 pppd[472]: local IP address 93.139.148.103 Aug 1 02:01:45 pppd[472]: remote IP address 172.29.252.89 Aug 1 02:01:45 rc_service: ip-up 819:notify_rc start_firewall Aug 1 02:01:46 miniupnpd[740]: shutting down MiniUPnPd Aug 1 02:01:46 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:01:46 rc_service: ip-up 819:notify_rc stop_upnp Aug 1 02:01:46 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:01:47 miniupnpd[878]: version 1.9 started Aug 1 02:01:47 miniupnpd[878]: HTTP listening on port 41732 Aug 1 02:01:47 miniupnpd[878]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:01:47 rc_service: ip-up 819:notify_rc start_upnp Aug 1 02:01:47 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:01:47 miniupnpd[878]: shutting down MiniUPnPd Aug 1 02:01:49 WAN Connection: WAN was restored. Aug 1 02:01:49 miniupnpd[883]: version 1.9 started Aug 1 02:01:49 miniupnpd[883]: HTTP listening on port 39510 Aug 1 02:01:49 miniupnpd[883]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:01:50 ntp: start NTP update Dec 10 10:09:54 rc_service: ntp 880:notify_rc restart_upnp Dec 10 10:09:54 miniupnpd[883]: shutting down MiniUPnPd Dec 10 10:09:54 miniupnpd[892]: version 1.9 started Dec 10 10:09:54 miniupnpd[892]: HTTP listening on port 34451 Dec 10 10:09:54 miniupnpd[892]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 10 10:09:55 rc_service: ntp 880:notify_rc restart_diskmon Dec 10 10:09:55 disk_monitor: Finish Dec 10 10:09:56 disk monitor: be idle Dec 10 10:09:56 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 10 10:09:56 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 10 10:09:56 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 10 10:09:56 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 10 23:11:45 disk_monitor: Got SIGALRM... Dec 11 00:00:45 disk_monitor: Got SIGALRM... Dec 11 00:24:48 miniupnpd[892]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out Dec 11 00:24:54 miniupnpd[892]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:11 kernel: pflash: found no supported devices Aug 1 02:00:11 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:11 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:11 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:11 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:11 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae48004, fsr=0x1c06, pc=0x2abeac58 lr=0x17bd8 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL Aug 1 02:00:16 RT-AC1200G+: start httpd Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:17 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 syslog: Generating SSL certificate... Aug 1 02:00:18 syslog: Generating SSL certificate... Aug 1 02:00:18 miniupnpd[457]: version 1.9 started Aug 1 02:00:18 miniupnpd[457]: HTTP listening on port 57753 Aug 1 02:00:18 miniupnpd[457]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[460]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:18 pppd[460]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:18 pppd[460]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 pppd[460]: PAP authentication succeeded Aug 1 02:00:19 pppd[460]: peer from calling number 00:90:1A:A5:00:86 authorized Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:19 pppd[460]: local IP address 93.138.42.188 Aug 1 02:00:19 pppd[460]: remote IP address 172.29.252.64 Aug 1 02:00:19 rc_service: ip-up 500:notify_rc start_firewall Aug 1 02:00:20 rc_service: ip-up 500:notify_rc stop_upnp Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:21 WAN Connection: WAN was restored. Aug 1 02:00:28 miniupnpd[457]: shutting down MiniUPnPd Aug 1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:31 miniupnpd[750]: version 1.9 started Aug 1 02:00:31 miniupnpd[750]: HTTP listening on port 46651 Aug 1 02:00:31 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:32 rc_service: ip-up 500:notify_rc start_upnp Aug 1 02:00:32 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:32 miniupnpd[750]: shutting down MiniUPnPd Aug 1 02:00:35 miniupnpd[759]: version 1.9 started Aug 1 02:00:35 miniupnpd[759]: HTTP listening on port 60062 Aug 1 02:00:35 miniupnpd[759]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:36 ntp: start NTP update Dec 11 05:02:06 rc_service: ntp 757:notify_rc restart_upnp Dec 11 05:02:06 miniupnpd[759]: shutting down MiniUPnPd Dec 11 05:02:07 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 11 05:02:07 miniupnpd[774]: version 1.9 started Dec 11 05:02:07 miniupnpd[774]: HTTP listening on port 35670 Dec 11 05:02:07 miniupnpd[774]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 11 05:02:07 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 11 05:02:07 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 11 05:02:07 rc_service: ntp 757:notify_rc restart_diskmon Dec 11 05:02:07 disk_monitor: Finish Dec 11 05:02:08 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 11 05:02:09 disk monitor: be idle Dec 11 05:02:13 rc_service: zcip 801:notify_rc start_firewall Dec 11 05:02:13 zcip client: configured 169.254.163.221 Dec 11 05:02:13 miniupnpd[774]: shutting down MiniUPnPd Dec 11 05:02:13 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 11 05:02:14 miniupnpd[829]: version 1.9 started Dec 11 05:02:14 miniupnpd[829]: HTTP listening on port 54166 Dec 11 05:02:14 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 11 14:31:10 rc_service: httpds 417:notify_rc start_webs_update Dec 11 23:04:34 disk_monitor: Got SIGALRM... Dec 12 05:00:03 kernel: Emergency Sync complete Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:11 kernel: pflash: found no supported devices Aug 1 02:00:11 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:11 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:11 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:11 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:11 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2acef004, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored. Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac963b0, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:12 WAN Connection: Fail to connect with some issues. Aug 1 02:00:17 RT-AC1200G+: start httpd - SSL Aug 1 02:00:17 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[465]: version 1.9 started Aug 1 02:00:18 miniupnpd[465]: HTTP listening on port 34836 Aug 1 02:00:18 miniupnpd[465]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[470]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[470]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:19 pppd[470]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 pppd[470]: PAP authentication succeeded Aug 1 02:00:19 pppd[470]: peer from calling number 00:90:1A:A5:00:86 authorized Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:19 pppd[470]: local IP address 93.138.92.101 Aug 1 02:00:19 pppd[470]: remote IP address 172.29.252.64 Aug 1 02:00:19 rc_service: ip-up 498:notify_rc start_firewall Aug 1 02:00:20 rc_service: ip-up 498:notify_rc stop_upnp Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:21 WAN Connection: WAN was restored. Aug 1 02:00:28 miniupnpd[465]: shutting down MiniUPnPd Aug 1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:31 miniupnpd[746]: version 1.9 started Aug 1 02:00:31 miniupnpd[746]: HTTP listening on port 41075 Aug 1 02:00:31 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:32 rc_service: ip-up 498:notify_rc start_upnp Aug 1 02:00:32 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:32 miniupnpd[746]: shutting down MiniUPnPd Aug 1 02:00:34 miniupnpd[750]: version 1.9 started Aug 1 02:00:34 miniupnpd[750]: HTTP listening on port 35645 Aug 1 02:00:34 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:36 ntp: start NTP update Dec 12 05:01:43 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 12 05:01:44 rc_service: ntp 749:notify_rc restart_upnp Dec 12 05:01:44 miniupnpd[750]: shutting down MiniUPnPd Dec 12 05:01:44 miniupnpd[770]: version 1.9 started Dec 12 05:01:44 miniupnpd[770]: HTTP listening on port 37305 Dec 12 05:01:44 miniupnpd[770]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 12 05:01:45 rc_service: ntp 749:notify_rc restart_diskmon Dec 12 05:01:45 disk_monitor: Finish Dec 12 05:01:47 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 12 05:01:47 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 12 05:01:47 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 12 05:01:47 disk monitor: be idle Dec 12 05:01:48 rc_service: zcip 793:notify_rc start_firewall Dec 12 05:01:48 zcip client: configured 169.254.163.221 Dec 12 05:01:49 miniupnpd[770]: shutting down MiniUPnPd Dec 12 05:01:49 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 12 05:01:50 miniupnpd[829]: version 1.9 started Dec 12 05:01:50 miniupnpd[829]: HTTP listening on port 36053 Dec 12 05:01:50 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 12 23:04:13 disk_monitor: Got SIGALRM... Dec 12 23:34:16 rc_service: httpds 417:notify_rc start_webs_update Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:11 kernel: pflash: found no supported devices Aug 1 02:00:11 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:11 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:11 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:11 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:11 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae3f004, fsr=0x1c06, pc=0x2ab76a00 lr=0x2ab76e5c ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:12 WAN Connection: Fail to connect with some issues. Aug 1 02:00:17 RT-AC1200G+: start httpd - SSL Aug 1 02:00:17 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[464]: version 1.9 started Aug 1 02:00:18 miniupnpd[464]: HTTP listening on port 34013 Aug 1 02:00:18 miniupnpd[464]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[470]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[470]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:19 pppd[470]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 pppd[470]: PAP authentication succeeded Aug 1 02:00:19 pppd[470]: peer from calling number 00:90:1A:A5:00:86 authorized Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:19 pppd[470]: local IP address 93.138.17.169 Aug 1 02:00:19 pppd[470]: remote IP address 172.29.252.64 Aug 1 02:00:20 rc_service: ip-up 502:notify_rc start_firewall Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:20 rc_service: ip-up 502:notify_rc stop_upnp Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:22 WAN Connection: WAN was restored. Aug 1 02:00:28 miniupnpd[464]: shutting down MiniUPnPd Aug 1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:32 miniupnpd[746]: version 1.9 started Aug 1 02:00:32 miniupnpd[746]: HTTP listening on port 49039 Aug 1 02:00:32 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:32 rc_service: ip-up 502:notify_rc start_upnp Aug 1 02:00:32 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:33 miniupnpd[746]: shutting down MiniUPnPd Aug 1 02:00:35 miniupnpd[751]: version 1.9 started Aug 1 02:00:35 miniupnpd[751]: HTTP listening on port 37247 Aug 1 02:00:35 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:36 ntp: start NTP update Dec 13 05:01:51 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 13 05:01:51 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 13 05:01:51 rc_service: ntp 749:notify_rc restart_upnp Dec 13 05:01:51 miniupnpd[751]: shutting down MiniUPnPd Dec 13 05:01:52 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 13 05:01:52 rc_service: ntp 749:notify_rc restart_diskmon Dec 13 05:01:53 disk_monitor: Finish Dec 13 05:01:53 miniupnpd[771]: version 1.9 started Dec 13 05:01:53 miniupnpd[771]: HTTP listening on port 41168 Dec 13 05:01:53 miniupnpd[771]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 13 05:01:53 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 13 05:01:55 disk monitor: be idle Dec 13 05:01:56 rc_service: zcip 778:notify_rc start_firewall Dec 13 05:01:56 zcip client: configured 169.254.163.221 Dec 13 05:01:57 miniupnpd[771]: shutting down MiniUPnPd Dec 13 05:01:57 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 13 05:02:00 miniupnpd[816]: version 1.9 started Dec 13 05:02:00 miniupnpd[816]: HTTP listening on port 60177 Dec 13 05:02:00 miniupnpd[816]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 13 17:41:12 rc_service: httpds 417:notify_rc start_webs_update Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:11 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ade2004, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored. Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2acc23b0, fsr=0x1c06, pc=0x7f190b38 lr=0x80208820 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1403) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <0>Kernel panic - not syncing: Out of memory: system-wide panic_on_oom is enabled Aug 1 02:00:11 kernel: <0> Aug 1 02:00:11 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<802fec2c>] (panic+0x7c/0x1a4) Aug 1 02:00:11 kernel: <4>[<802fec2c>] (panic+0x7c/0x1a4) from [<80091038>] (out_of_memory+0x2c8/0x328) Aug 1 02:00:11 kernel: <4>[<80091038>] (out_of_memory+0x2c8/0x328) from [<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) Aug 1 02:00:11 kernel: <4>[<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) from [<80096000>] (__do_page_cache_readahead+0x140/0x2d0) Aug 1 02:00:11 kernel: <4>[<80096000>] (__do_page_cache_readahead+0x140/0x2d0) from [<80096440>] (ra_submit+0x28/0x30) Aug 1 02:00:11 kernel: <4>[<80096440>] (ra_submit+0x28/0x30) from [<8008e5d0>] (filemap_fault+0x42c/0x454) Aug 1 02:00:11 kernel: <4>[<8008e5d0>] (filemap_fault+0x42c/0x454) from [<800a315c>] (__do_fault.clone.60+0x54/0x4c8) Aug 1 02:00:11 kernel: <4>[<800a315c>] (__do_fault.clone.60+0x54/0x4c8) from [<800a67c4>] (handle_mm_fault+0x114/0x934) Aug 1 02:00:11 kernel: <4>[<800a67c4>] (handle_mm_fault+0x114/0x934) from [<8003fd90>] (do_page_fault+0x178/0x1ec) Aug 1 02:00:11 kernel: <4>[<8003fd90>] (do_page_fault+0x178/0x1ec) from [<80038298>] (do_PrefetchAbort+0x30/0x9c) Aug 1 02:00:11 kernel: <4>[<80038298>] (do_PrefetchAbort+0x30/0x9c) from [<803bf2e0>] (ret_from_exception+0x0/0x10) Aug 1 02:00:11 kernel: <4>Exception stack(0x8534bfb0 to 0x8534bff8) Aug 1 02:00:11 kernel: <4>bfa0: 0000000e 00000008 7ec48c48 00000000 Aug 1 02:00:11 kernel: <4>bfc0: 7ec48c48 00000001 7ec48e94 000000b3 0000d1f0 0000ec14 7ec48e08 00000000 Aug 1 02:00:11 kernel: <4>bfe0: 2aea65b4 7ec48948 2ae4e254 0003be5c 00000010 ffffffff Aug 1 02:00:11 kernel: <0>Rebooting in 3 seconds.. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:17 RT-AC1200G+: start httpd - SSL Aug 1 02:00:17 RT-AC1200G+: start httpd Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:18 syslog: Generating SSL certificate... Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[465]: version 1.9 started Aug 1 02:00:18 miniupnpd[465]: HTTP listening on port 56032 Aug 1 02:00:18 miniupnpd[465]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:21 pppd[472]: PAP authentication failed Aug 1 02:00:27 pppd[472]: Connection terminated. Aug 1 02:00:27 pppd[472]: Modem hangup Aug 1 02:00:38 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:38 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:40 pppd[472]: PAP authentication failed Aug 1 02:00:40 pppd[472]: Connection terminated. Aug 1 02:00:41 rc_service: zcip 684:notify_rc start_firewall Aug 1 02:00:41 zcip client: configured 169.254.163.221 Aug 1 02:00:42 miniupnpd[465]: shutting down MiniUPnPd Aug 1 02:00:42 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)! Aug 1 02:00:43 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:43 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:43 miniupnpd[740]: version 1.9 started Aug 1 02:00:43 miniupnpd[740]: HTTP listening on port 48089 Aug 1 02:00:43 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:47 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:50 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:50 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:53 pppd[472]: PAP authentication failed Aug 1 02:00:53 pppd[472]: Connection terminated. Aug 1 02:01:03 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:01:03 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:06 pppd[472]: PAP authentication failed Aug 1 02:01:06 pppd[472]: Connection terminated. Aug 1 02:01:16 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0 Aug 1 02:01:16 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:19 pppd[472]: PAP authentication failed Aug 1 02:01:19 pppd[472]: Connection terminated. Aug 1 02:01:29 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Aug 1 02:01:29 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:32 pppd[472]: PAP authentication failed Aug 1 02:01:32 pppd[472]: Connection terminated. Aug 1 02:01:42 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Aug 1 02:01:42 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:43 pppd[472]: PAP authentication succeeded Aug 1 02:01:43 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized Aug 1 02:01:43 pppd[472]: local IP address 93.139.188.27 Aug 1 02:01:43 pppd[472]: remote IP address 172.29.252.89 Aug 1 02:01:43 rc_service: ip-up 818:notify_rc start_firewall Aug 1 02:01:44 miniupnpd[740]: shutting down MiniUPnPd Aug 1 02:01:44 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:01:44 rc_service: ip-up 818:notify_rc stop_upnp Aug 1 02:01:44 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:01:45 miniupnpd[869]: version 1.9 started Aug 1 02:01:45 miniupnpd[869]: HTTP listening on port 56143 Aug 1 02:01:45 miniupnpd[869]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:01:45 rc_service: ip-up 818:notify_rc start_upnp Aug 1 02:01:45 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:01:45 miniupnpd[869]: shutting down MiniUPnPd Aug 1 02:01:47 miniupnpd[873]: version 1.9 started Aug 1 02:01:47 miniupnpd[873]: HTTP listening on port 41917 Aug 1 02:01:47 miniupnpd[873]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:01:47 WAN Connection: WAN was restored. Aug 1 02:01:48 ntp: start NTP update Aug 1 02:01:48 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 13 18:12:49 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 13 18:12:49 rc_service: ntp 871:notify_rc restart_upnp Dec 13 18:12:49 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 13 18:12:49 miniupnpd[873]: shutting down MiniUPnPd Dec 13 18:12:49 miniupnpd[893]: version 1.9 started Dec 13 18:12:49 miniupnpd[893]: HTTP listening on port 37135 Dec 13 18:12:49 miniupnpd[893]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 13 18:12:49 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 13 18:12:50 rc_service: ntp 871:notify_rc restart_diskmon Dec 13 18:12:50 disk_monitor: Finish Dec 13 18:12:51 disk monitor: be idle Dec 13 19:00:58 disk_monitor: Got SIGALRM... Dec 13 23:01:29 disk_monitor: Got SIGALRM... Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:11 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae53004, fsr=0x1c06, pc=0x2ab40e08 lr=0x2ab40e5c ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1403) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <0>Kernel panic - not syncing: Out of memory: system-wide panic_on_oom is enabled Aug 1 02:00:11 kernel: <0> Aug 1 02:00:11 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<802fec2c>] (panic+0x7c/0x1a4) Aug 1 02:00:11 kernel: <4>[<802fec2c>] (panic+0x7c/0x1a4) from [<80091038>] (out_of_memory+0x2c8/0x328) Aug 1 02:00:11 kernel: <4>[<80091038>] (out_of_memory+0x2c8/0x328) from [<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) Aug 1 02:00:11 kernel: <4>[<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) from [<80096000>] (__do_page_cache_readahead+0x140/0x2d0) Aug 1 02:00:11 kernel: <4>[<80096000>] (__do_page_cache_readahead+0x140/0x2d0) from [<80096440>] (ra_submit+0x28/0x30) Aug 1 02:00:11 kernel: <4>[<80096440>] (ra_submit+0x28/0x30) from [<8008e5d0>] (filemap_fault+0x42c/0x454) Aug 1 02:00:11 kernel: <4>[<8008e5d0>] (filemap_fault+0x42c/0x454) from [<800a315c>] (__do_fault.clone.60+0x54/0x4c8) Aug 1 02:00:11 kernel: <4>[<800a315c>] (__do_fault.clone.60+0x54/0x4c8) from [<800a67c4>] (handle_mm_fault+0x114/0x934) Aug 1 02:00:11 kernel: <4>[<800a67c4>] (handle_mm_fault+0x114/0x934) from [<8003fd90>] (do_page_fault+0x178/0x1ec) Aug 1 02:00:11 kernel: <4>[<8003fd90>] (do_page_fault+0x178/0x1ec) from [<80038298>] (do_PrefetchAbort+0x30/0x9c) Aug 1 02:00:11 kernel: <4>[<80038298>] (do_PrefetchAbort+0x30/0x9c) from [<803bf2e0>] (ret_from_exception+0x0/0x10) Aug 1 02:00:11 kernel: <4>Exception stack(0x851fdfb0 to 0x851fdff8) Aug 1 02:00:11 kernel: <4>dfa0: 00001800 0009a21c 00001800 0009a21c Aug 1 02:00:11 kernel: <4>dfc0: 0009a21c 000983cc 000000fa 00000067 0009a258 00001e38 00000500 00000000 Aug 1 02:00:11 kernel: <4>dfe0: 000984e4 7e8e0d68 0002c878 2ac8c370 80000010 ffffffff Aug 1 02:00:11 kernel: <0>Rebooting in 3 seconds.. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL Aug 1 02:00:16 RT-AC1200G+: start httpd Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[457]: version 1.9 started Aug 1 02:00:18 miniupnpd[457]: HTTP listening on port 33819 Aug 1 02:00:18 miniupnpd[457]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:22 pppd[472]: PAP authentication failed Aug 1 02:00:28 pppd[472]: Connection terminated. Aug 1 02:00:28 pppd[472]: Modem hangup Aug 1 02:00:39 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0 Aug 1 02:00:39 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:42 pppd[472]: PAP authentication failed Aug 1 02:00:42 pppd[472]: Connection terminated. Aug 1 02:00:43 rc_service: zcip 684:notify_rc start_firewall Aug 1 02:00:43 zcip client: configured 169.254.163.221 Aug 1 02:00:44 miniupnpd[457]: shutting down MiniUPnPd Aug 1 02:00:44 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)! Aug 1 02:00:45 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:45 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:46 miniupnpd[740]: version 1.9 started Aug 1 02:00:46 miniupnpd[740]: HTTP listening on port 50075 Aug 1 02:00:46 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:46 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:52 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0 Aug 1 02:00:52 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:55 pppd[472]: PAP authentication failed Aug 1 02:00:55 pppd[472]: Connection terminated. Aug 1 02:01:05 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0 Aug 1 02:01:05 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:08 pppd[472]: PAP authentication failed Aug 1 02:01:08 pppd[472]: Connection terminated. Aug 1 02:01:18 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0 Aug 1 02:01:18 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:21 pppd[472]: PAP authentication failed Aug 1 02:01:21 pppd[472]: Connection terminated. Aug 1 02:01:31 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0 Aug 1 02:01:31 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:34 pppd[472]: PAP authentication failed Aug 1 02:01:34 pppd[472]: Connection terminated. Aug 1 02:01:44 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0 Aug 1 02:01:44 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:44 pppd[472]: PAP authentication succeeded Aug 1 02:01:44 pppd[472]: peer from calling number 84:B5:9C:A4:4D:B7 authorized Aug 1 02:01:45 pppd[472]: local IP address 78.1.186.208 Aug 1 02:01:45 pppd[472]: remote IP address 172.29.252.59 Aug 1 02:01:45 rc_service: ip-up 820:notify_rc start_firewall Aug 1 02:01:46 miniupnpd[740]: shutting down MiniUPnPd Aug 1 02:01:46 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:01:46 rc_service: ip-up 820:notify_rc stop_upnp Aug 1 02:01:46 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:01:47 miniupnpd[867]: version 1.9 started Aug 1 02:01:47 miniupnpd[867]: HTTP listening on port 46435 Aug 1 02:01:47 miniupnpd[867]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:01:47 rc_service: ip-up 820:notify_rc start_upnp Aug 1 02:01:47 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:01:47 miniupnpd[867]: shutting down MiniUPnPd Aug 1 02:01:48 WAN Connection: WAN was restored. Aug 1 02:01:49 miniupnpd[872]: version 1.9 started Aug 1 02:01:49 miniupnpd[872]: HTTP listening on port 44026 Aug 1 02:01:49 miniupnpd[872]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:01:49 ntp: start NTP update Dec 14 01:18:19 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 14 01:18:19 rc_service: ntp 870:notify_rc restart_upnp Dec 14 01:18:19 miniupnpd[872]: shutting down MiniUPnPd Dec 14 01:18:19 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 14 01:18:19 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 14 01:18:19 miniupnpd[890]: version 1.9 started Dec 14 01:18:19 miniupnpd[890]: HTTP listening on port 42889 Dec 14 01:18:19 miniupnpd[890]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 14 01:18:20 rc_service: ntp 870:notify_rc restart_diskmon Dec 14 01:18:20 disk_monitor: Finish Dec 14 01:18:20 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 14 01:18:21 disk monitor: be idle Dec 14 02:00:27 disk_monitor: Got SIGALRM... Dec 14 05:00:12 kernel: Emergency Sync complete Dec 14 05:00:14 iTunes: daemon is stoped Dec 14 05:00:14 FTP Server: daemon is stoped Dec 14 05:00:14 Samba Server: smb daemon is stoped Dec 14 05:00:14 kernel: gro disabled Dec 14 05:00:14 disk_monitor: Finish Dec 14 05:00:14 miniupnpd[890]: shutting down MiniUPnPd Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:11 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ad9b004, fsr=0x1c06, pc=0x800ce10c lr=0x800c1154 ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <4>Emergency Sync complete Aug 1 02:00:11 kernel: <4> Aug 1 02:00:11 kernel: <4>gro disabled Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>device eth0 entered promiscuous mode Aug 1 02:00:11 kernel: <6>br0: topology change detected, propagating Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state Aug 1 02:00:11 kernel: <6>device vlan1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth1 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state Aug 1 02:00:11 kernel: <6>device eth2 left promiscuous mode Aug 1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state Aug 1 02:00:11 kernel: <6>device eth0 left promiscuous mode Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix Aug 1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp Aug 1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt Aug 1 02:00:11 kernel: <0>Restarting system. Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:12 WAN Connection: Fail to connect with some issues. Aug 1 02:00:17 RT-AC1200G+: start httpd - SSL Aug 1 02:00:17 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[461]: version 1.9 started Aug 1 02:00:18 miniupnpd[461]: HTTP listening on port 60517 Aug 1 02:00:18 miniupnpd[461]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:19 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 pppd[472]: PAP authentication succeeded Aug 1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized Aug 1 02:00:20 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:20 pppd[472]: local IP address 93.138.127.180 Aug 1 02:00:20 pppd[472]: remote IP address 172.29.252.64 Aug 1 02:00:20 rc_service: ip-up 501:notify_rc start_firewall Aug 1 02:00:20 syslog: module leds-usb not found in modules.dep Aug 1 02:00:20 rc_service: ip-up 501:notify_rc stop_upnp Aug 1 02:00:20 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:00:21 kernel: SCSI subsystem initialized Aug 1 02:00:22 WAN Connection: WAN was restored. Aug 1 02:00:28 miniupnpd[461]: shutting down MiniUPnPd Aug 1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:32 miniupnpd[747]: version 1.9 started Aug 1 02:00:32 miniupnpd[747]: HTTP listening on port 55279 Aug 1 02:00:32 miniupnpd[747]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:33 rc_service: ip-up 501:notify_rc start_upnp Aug 1 02:00:33 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:00:33 miniupnpd[747]: shutting down MiniUPnPd Aug 1 02:00:36 miniupnpd[751]: version 1.9 started Aug 1 02:00:36 miniupnpd[751]: HTTP listening on port 33504 Aug 1 02:00:36 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:36 ntp: start NTP update Dec 14 05:01:53 rc_service: ntp 749:notify_rc restart_upnp Dec 14 05:01:53 miniupnpd[751]: shutting down MiniUPnPd Dec 14 05:01:54 rc_service: ntp 749:notify_rc restart_diskmon Dec 14 05:01:54 disk_monitor: Finish Dec 14 05:01:56 miniupnpd[767]: version 1.9 started Dec 14 05:01:56 miniupnpd[767]: HTTP listening on port 48911 Dec 14 05:01:56 miniupnpd[767]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 14 05:01:57 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 14 05:01:57 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 14 05:01:57 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 14 05:01:57 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 14 05:01:58 disk monitor: be idle Dec 14 05:01:58 rc_service: zcip 779:notify_rc start_firewall Dec 14 05:01:59 zcip client: configured 169.254.163.221 Dec 14 05:02:00 miniupnpd[767]: shutting down MiniUPnPd Dec 14 05:02:00 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Dec 14 05:02:04 miniupnpd[826]: version 1.9 started Dec 14 05:02:04 miniupnpd[826]: HTTP listening on port 46443 Dec 14 05:02:04 miniupnpd[826]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 14 05:59:23 kernel: active_file:438 inactive_file:687 isolated_file:0 Dec 14 05:59:23 kernel: unevictable:0 dirty:0 writeback:0 unstable:0 Dec 14 05:59:23 kernel: free:383 slab_reclaimable:266 slab_unreclaimable:24677 Dec 14 05:59:23 kernel: mapped:824 shmem:188 pagetables:151 bounce:0 Dec 14 05:59:23 kernel: DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:6616kB inactive_anon:940kB active_file:1752kB inactive_file:2748kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:3296kB shmem:752kB slab_reclaimable:1064kB slab_unreclaimable:98708kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:195 all_unreclaimable? no Dec 14 05:59:23 kernel: lowmem_reserve[]: 0 0 0 Dec 14 05:59:23 kernel: DMA: 1*4kB 1*8kB 1*16kB 1*32kB 1*64kB 1*128kB 1*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1532kB Dec 14 05:59:23 kernel: 1313 total pagecache pages Dec 14 05:59:23 kernel: 0 pages in swap cache Dec 14 05:59:23 kernel: Swap cache stats: add 0, delete 0, find 0/0 Dec 14 05:59:23 kernel: Free swap = 0kB Dec 14 05:59:23 kernel: Total swap = 0kB Dec 14 05:59:23 kernel: 32768 pages of RAM Dec 14 05:59:23 kernel: 552 free pages Dec 14 05:59:23 kernel: 1352 reserved pages Dec 14 05:59:23 kernel: 9328 slab pages Dec 14 05:59:23 kernel: 4621 pages shared Dec 14 05:59:23 kernel: 0 pages swap cached Dec 14 05:59:24 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20) Dec 14 05:59:24 kernel: cache: kmalloc-256, object size: 256, buffer size: 256, default order: 0, min order: 0 Dec 14 05:59:24 kernel: node 0: slabs: 3375, objs: 54000, free: 0 Dec 14 05:59:24 kernel: acsd: page allocation failure. order:0, mode:0x20 Dec 14 05:59:24 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) Dec 14 05:59:24 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0) Dec 14 05:59:24 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0970>] (kmem_cache_alloc+0x90/0x9c) Dec 14 05:59:24 kernel: [<803b0970>] (kmem_cache_alloc+0x90/0x9c) from [<803b28ac>] (__alloc_skb+0x30/0x104) Dec 14 05:59:24 kernel: [<803b28ac>] (__alloc_skb+0x30/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac) Dec 14 05:59:24 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<803c2cc0>] (osl_pktget+0x6c/0x170) Dec 14 05:59:24 kernel: [<803c2cc0>] (osl_pktget+0x6c/0x170) from [<7f29458c>] (wlc_hdr_proc+0x54/0x254 [wl]) Dec 14 05:59:24 kernel: unwind: Index not found 7f29458c Dec 14 05:59:24 kernel: Mem-info: Dec 14 05:59:24 kernel: DMA per-cpu: Dec 14 05:59:24 kernel: CPU 0: hi: 42, btch: 7 usd: 6 Dec 14 05:59:24 kernel: active_anon:1654 inactive_anon:235 isolated_anon:0 Dec 14 05:59:24 kernel: active_file:438 inactive_file:687 isolated_file:0 Dec 14 05:59:24 kernel: unevictable:0 dirty:0 writeback:0 unstable:0 Dec 14 05:59:24 kernel: free:383 slab_reclaimable:266 slab_unreclaimable:24677 Dec 14 05:59:24 kernel: mapped:824 shmem:188 pagetables:151 bounce:0 Dec 14 05:59:24 kernel: DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:6616kB inactive_anon:940kB active_file:1752kB inactive_file:2748kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:3296kB shmem:752kB slab_reclaimable:1064kB slab_unreclaimable:98708kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:195 all_unreclaimable? no Dec 14 05:59:24 kernel: lowmem_reserve[]: 0 0 0 Dec 14 05:59:24 kernel: DMA: 1*4kB 1*8kB 1*16kB 1*32kB 1*64kB 1*128kB 1*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1532kB Dec 14 05:59:24 kernel: 1313 total pagecache pages Dec 14 05:59:24 kernel: 0 pages in swap cache Dec 14 05:59:24 kernel: Swap cache stats: add 0, delete 0, find 0/0 Dec 14 05:59:24 kernel: Free swap = 0kB Dec 14 05:59:24 kernel: Total swap = 0kB Dec 14 05:59:24 kernel: 32768 pages of RAM Dec 14 05:59:24 kernel: 552 free pages Dec 14 05:59:24 kernel: 1352 reserved pages Dec 14 05:59:24 kernel: 9328 slab pages Dec 14 05:59:24 kernel: 4621 pages shared Dec 14 05:59:24 kernel: 0 pages swap cached Dec 14 05:59:24 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20) Dec 14 05:59:24 kernel: cache: kmalloc-256, object size: 256, buffer size: 256, default order: 0, min order: 0 Dec 14 05:59:24 kernel: node 0: slabs: 3375, objs: 54000, free: 0 Dec 14 05:59:24 kernel: acsd: page allocation failure. order:0, mode:0x20 Dec 14 05:59:24 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) Dec 14 05:59:24 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0) Dec 14 05:59:24 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0970>] (kmem_cache_alloc+0x90/0x9c) Dec 14 05:59:24 kernel: [<803b0970>] (kmem_cache_alloc+0x90/0x9c) from [<803b28ac>] (__alloc_skb+0x30/0x104) Dec 14 05:59:24 kernel: [<803b28ac>] (__alloc_skb+0x30/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac) Dec 14 05:59:24 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<803c2cc0>] (osl_pktget+0x6c/0x170) Dec 14 05:59:24 kernel: [<803c2cc0>] (osl_pktget+0x6c/0x170) from [<7f29458c>] (wlc_hdr_proc+0x54/0x254 [wl]) Dec 14 05:59:24 kernel: unwind: Index not found 7f29458c Dec 14 05:59:24 kernel: Mem-info: Dec 14 05:59:24 kernel: DMA per-cpu: Dec 14 05:59:24 kernel: CPU 0: hi: 42, btch: 7 usd: 6 Dec 14 05:59:24 kernel: active_anon:1654 inactive_anon:235 isolated_anon:0 Dec 14 05:59:24 kernel: active_file:438 inactive_file:687 isolated_file:0 Dec 14 05:59:24 kernel: unevictable:0 dirty:0 writeback:0 unstable:0 Dec 14 05:59:24 kernel: free:383 slab_reclaimable:266 slab_unreclaimable:24677 Dec 14 05:59:24 kernel: mapped:824 shmem:188 pagetables:151 bounce:0 Dec 14 05:59:24 kernel: DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:6616kB inactive_anon:940kB active_file:1752kB inactive_file:2748kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:3296kB shmem:752kB slab_reclaimable:1064kB slab_unreclaimable:98708kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:195 all_unreclaimable? no Dec 14 05:59:24 kernel: lowmem_reserve[]: 0 0 0 Dec 14 05:59:24 kernel: DMA: 1*4kB 1*8kB 1*16kB 1*32kB 1*64kB 1*128kB 1*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1532kB Dec 14 05:59:24 kernel: 1313 total pagecache pages Dec 14 05:59:24 kernel: 0 pages in swap cache Dec 14 05:59:24 kernel: Swap cache stats: add 0, delete 0, find 0/0 Dec 14 05:59:24 kernel: Free swap = 0kB Dec 14 05:59:24 kernel: Total swap = 0kB Dec 14 05:59:24 kernel: 32768 pages of RAM Dec 14 05:59:24 kernel: 552 free pages Dec 14 05:59:24 kernel: 1352 reserved pages Dec 14 05:59:24 kernel: 9328 slab pages Dec 14 05:59:24 kernel: 4621 pages shared Dec 14 05:59:24 kernel: 0 pages swap cached Dec 14 05:59:24 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20) Dec 14 05:59:24 kernel: cache: kmalloc-256, object size: 256, buffer size: 256, default order: 0, min order: 0 Dec 14 05:59:24 kernel: node 0: slabs: 3375, objs: 54000, free: 0 Dec 14 05:59:24 kernel: acsd: page allocation failure. order:0, mode:0x20 Dec 14 05:59:24 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) Dec 14 05:59:24 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0) Dec 14 05:59:24 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0970>] (kmem_cache_alloc+0x90/0x9c) Dec 14 05:59:24 kernel: [<803b0970>] (kmem_cache_alloc+0x90/0x9c) from [<80216050>] (skb_clone+0x130/0x14c) Dec 14 05:59:24 kernel: [<80216050>] (skb_clone+0x130/0x14c) from [<802e8ba0>] (deliver_clone+0x20/0x4c) Dec 14 05:59:24 kernel: [<802e8ba0>] (deliver_clone+0x20/0x4c) from [<802e9e24>] (br_handle_frame_finish+0x230/0x23c) Dec 14 05:59:24 kernel: [<802e9e24>] (br_handle_frame_finish+0x230/0x23c) from [<802e9fdc>] (br_handle_frame+0x1ac/0x24c) Dec 14 05:59:24 kernel: [<802e9fdc>] (f len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: __alloc_pages_slowpath: 7870 callbacks suppressed Dec 14 05:59:24 kernel: kworker/0:1: page allocation failure. order:0, mode:0x4020 Dec 14 05:59:24 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) Dec 14 05:59:24 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0) Dec 14 05:59:24 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) Dec 14 05:59:24 kernel: [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104) Dec 14 05:59:24 kernel: [<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac) Dec 14 05:59:24 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) Dec 14 05:59:24 kernel: [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) from [<7f018a14>] (et_tx_tasklet+0x304/0xbdc [et]) Dec 14 05:59:24 kernel: unwind: Index not found 7f018a14 Dec 14 05:59:24 kernel: Mem-info: Dec 14 05:59:24 kernel: DMA per-cpu: Dec 14 05:59:24 kernel: CPU 0: hi: 42, btch: 7 usd: 7 Dec 14 05:59:24 kernel: active_anon:951 inactive_anon:938 isolated_anon:0 Dec 14 05:59:24 kernel: active_file:397 inactive_file:599 isolated_file:0 Dec 14 05:59:24 kernel: unevictable:0 dirty:0 writeback:0 unstable:0 Dec 14 05:59:24 kernel: free:382 slab_reclaimable:150 slab_unreclaimable:24922 Dec 14 05:59:24 kernel: mapped:711 shmem:188 pagetables:151 bounce:0 Dec 14 05:59:24 kernel: DMA free:1528kB min:4096kB low:5120kB high:6144kB active_anon:3804kB inactive_anon:3752kB active_file:1588kB inactive_file:2396kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:2844kB shmem:752kB slab_reclaimable:600kB slab_unreclaimable:99688kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no Dec 14 05:59:24 kernel: lowmem_reserve[]: 0 0 0 Dec 14 05:59:24 kernel: DMA: 14*4kB 6*8kB 5*16kB 6*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1528kB Dec 14 05:59:24 kernel: 1184 total pagecache pages Dec 14 05:59:24 kernel: 0 pages in swap cache Dec 14 05:59:24 kernel: Swap cache stats: add 0, delete 0, find 0/0 Dec 14 05:59:24 kernel: Free swap = 0kB Dec 14 05:59:24 kernel: Total swap = 0kB Dec 14 05:59:24 kernel: 32768 pages of RAM Dec 14 05:59:24 kernel: 552 free pages Dec 14 05:59:24 kernel: 1352 reserved pages Dec 14 05:59:24 kernel: 9646 slab pages Dec 14 05:59:24 kernel: 3844 pages shared Dec 14 05:59:24 kernel: 0 pages swap cached Dec 14 05:59:24 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20) Dec 14 05:59:24 kernel: cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0 Dec 14 05:59:24 kernel: node 0: slabs: 2213, objs: 17466, free: 0 Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:24 kernel: kworker/0:1: page allocation failure. order:0, mode:0x4020 Dec 14 05:59:24 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) Dec 14 05:59:24 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0) Dec 14 05:59:24 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) Dec 14 05:59:24 kernel: [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104) Dec 14 05:59:25 kernel: [<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac) Dec 14 05:59:25 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) Dec 14 05:59:25 kernel: [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) from [<7f018a14>] (et_tx_tasklet+0x304/0xbdc [et]) Dec 14 05:59:25 kernel: unwind: Index not found 7f018a14 Dec 14 05:59:25 kernel: Mem-info: Dec 14 05:59:25 kernel: DMA per-cpu: Dec 14 05:59:25 kernel: CPU 0: hi: 42, btch: 7 usd: 7 Dec 14 05:59:25 kernel: active_anon:951 inactive_anon:938 isolated_anon:0 Dec 14 05:59:25 kernel: active_file:397 inactive_file:599 isolated_file:0 Dec 14 05:59:25 kernel: unevictable:0 dirty:0 writeback:0 unstable:0 Dec 14 05:59:25 kernel: free:382 slab_reclaimable:150 slab_unreclaimable:24922 Dec 14 05:59:25 kernel: mapped:711 shmem:188 pagetables:151 bounce:0 Dec 14 05:59:25 kernel: DMA free:1528kB min:4096kB low:5120kB high:6144kB active_anon:3804kB inactive_anon:3752kB active_file:1588kB inactive_file:2396kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:2844kB shmem:752kB slab_reclaimable:600kB slab_unreclaimable:99688kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no Dec 14 05:59:25 kernel: lowmem_reserve[]: 0 0 0 Dec 14 05:59:25 kernel: DMA: 14*4kB 6*8kB 5*16kB 6*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1528kB Dec 14 05:59:25 kernel: 1184 total pagecache pages Dec 14 05:59:25 kernel: 0 pages in swap cache Dec 14 05:59:25 kernel: Swap cache stats: add 0, delete 0, find 0/0 Dec 14 05:59:25 kernel: Free swap = 0kB Dec 14 05:59:25 kernel: Total swap = 0kB Dec 14 05:59:25 kernel: 32768 pages of RAM Dec 14 05:59:25 kernel: 552 free pages Dec 14 05:59:25 kernel: 1352 reserved pages Dec 14 05:59:25 kernel: 9646 slab pages Dec 14 05:59:25 kernel: 3844 pages shared Dec 14 05:59:25 kernel: 0 pages swap cached Dec 14 05:59:25 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20) Dec 14 05:59:25 kernel: cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0 Dec 14 05:59:25 kernel: node 0: slabs: 2213, objs: 17466, free: 0 Dec 14 05:59:25 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:25 kernel: kworker/0:1: page allocation failure. order:0, mode:0x4020 Dec 14 05:59:25 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) Dec 14 05:59:25 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0) Dec 14 05:59:25 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) Dec 14 05:59:25 kernel: [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104) Dec 14 05:59:25 kernel: [<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac) Dec 14 05:59:25 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) Dec 14 05:59:25 kernel: [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) from [<7f018a14>] (et_tx_tasklet+0x304/0xbdc [et]) Dec 14 05:59:25 kernel: unwind: Index not found 7f018a14 Dec 14 05:59:25 kernel: Mem-info: Dec 14 05:59:25 kernel: DMA per-cpu: Dec 14 05:59:25 kernel: CPU 0: hi: 42, btch: 7 usd: 7 Dec 14 05:59:25 kernel: active_anon:951 inactive_anon:938 isolated_anon:0 Dec 14 05:59:25 kernel: active_file:397 inactive_file:599 isolated_file:0 Dec 14 05:59:25 kernel: unevictable:0 dirty:0 writeback:0 unstable:0 Dec 14 05:59:25 kernel: free:382 slab_reclaimable:150 slab_unreclaimable:24922 Dec 14 05:59:25 kernel: mapped:711 shmem:188 pagetables:151 bounce:0 Dec 14 05:59:25 kernel: DMA free:1528kB min:4096kB low:5120kB high:6144kB active_anon:3804kB inactive_anon:3752kB active_file:1588kB inactive_file:2396kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:2844kB shmem:752kB slab_reclaimable:600kB slab_unreclaimable:99688kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no Dec 14 05:59:25 kernel: lowmem_reserve[]: 0 0 0 Dec 14 05:59:25 kernel: DMA: 14*4kB 6*8kB 5*16kB 6*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1528kB Dec 14 05:59:25 kernel: 1184 total pagecache pages Dec 14 05:59:25 kernel: 0 pages in swap cache Dec 14 05:59:25 kernel: Swap cache stats: add 0, delete 0, find 0/0 Dec 14 05:59:25 kernel: Free swap = 0kB Dec 14 05:59:25 kernel: Total swap = 0kB Dec 14 05:59:25 kernel: 32768 pages of RAM Dec 14 05:59:25 kernel: 552 free pages Dec 14 05:59:25 kernel: 1352 reserved pages Dec 14 05:59:25 kernel: 9646 slab pages Dec 14 05:59:25 kernel: 3844 pages shared Dec 14 05:59:25 kernel: 0 pages swap cached Dec 14 05:59:25 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20) Dec 14 05:59:25 kernel: cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0 Dec 14 05:59:25 kernel: node 0: slabs: 2213, objs: 17466, free: 0 Dec 14 05:59:25 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:25 kernel: kworker/0:1: page allocation failure. order:0, mode:0x4020 Dec 14 05:59:25 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) Dec 14 05:59:25 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0) Dec 14 05:59:25 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) Dec 14 05:59:25 kernel: [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104) Dec 14 05:59:25 kernel: [<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac) Dec 14 05:59:25 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) Dec 14 05:59:25 kernel: [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) from [<7f018a14>] (et_tx_tasklet+0x304/0xbdc [et]) Dec 14 05:59:25 kernel: unwind: Index not found 7f018a14 Dec 14 05:59:25 kernel: Mem-info: Dec 14 05:59:25 kernel: DMA per-cpu: Dec 14 05:59:25 kernel: CPU 0: hi: 42, btch: 7 usd: 7 Dec 14 05:59:25 kernel: active_anon:951 inactive_anon:938 isolated_anon:0 Dec 14 05:59:25 kernel: active_file:397 inactive_file:599 isolated_file:0 Dec 14 05:59:25 kernel: unevictable:0 dirty:0 writeback:0 unstable:0 Dec 14 05:59:25 kernel: free:382 slab_reclaimable:150 slab_unreclaimable:24922 Dec 14 05:59:25 kernel: mapped:711 shmem:188 pagetables:151 bounce:0 Dec 14 05:59:25 kernel: DMA free:1528kB min:4096kB low:5120kB high:6144kB active_anon:3804kB inactive_anon:3752kB active_file:1588kB inactive_file:2396kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:2844kB shmem:752kB slab_reclaimable:600kB slab_unreclaimable:99688kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no Dec 14 05:59:25 kernel: lowmem_reserve[]: 0 0 0 Dec 14 05:59:25 kernel: DMA: 14*4kB 6*8kB 5*16kB 6*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1528kB Dec 14 05:59:25 kernel: 1184 total pagecache pages Dec 14 05:59:25 kernel: 0 pages in swap cache Dec 14 05:59:25 kernel: Swap cache stats: add 0, delete 0, find 0/0 Dec 14 05:59:25 kernel: Free swap = 0kB Dec 14 05:59:25 kernel: Total swap = 0kB Dec 14 05:59:25 kernel: 32768 pages of RAM Dec 14 05:59:25 kernel: 552 free pages Dec 14 05:59:25 kernel: 1352 reserved pages Dec 14 05:59:25 kernel: 9646 slab pages Dec 14 05:59:25 kernel: 3844 pages shared Dec 14 05:59:25 kernel: 0 pages swap cached Dec 14 05:59:25 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20) Dec 14 05:59:25 kernel: cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0 Dec 14 05:59:25 kernel: node 0: slabs: 2213, objs: 17466, free: 0 Dec 14 05:59:25 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:25 kernel: kworker/0:1: page allocation failure. order:0, mode:0x4020 Dec 14 05:59:25 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) Dec 14 05:59:25 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0) Dec 14 05:59:25 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) Dec 14 05:59:25 kernel: [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104) Dec 14 05:59:25 kernel: [<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac) Dec 14 05:59:25 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) Dec 14 05:59:25 kernel: [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) from [<7f018a14>] (et_tx_tasklet+0x304/0xbdc [et]) Dec 14 05:59:25 kernel: unwind: Index not found 7f018a14 Dec 14 05:59:25 kernel: Mem-info: Dec 14 05:59:25 kernel: DMA per-cpu: Dec 14 05:59:25 kernel: CPU 0: hi: 42, btch: 7 usd: 7 Dec 14 05:59:25 kernel: active_anon:951 inactive_anon:938 isolated_anon:0 Dec 14 05:59:25 kernel: active_file:397 inactive_file:599 isolated_file:0 Dec 14 05:59:25 kernel: unevictable:0 dirty:0 writeback:0 unstable:0 Dec 14 05:59:25 kernel: free:382 slab_reclaimable:150 slab_unreclaimable:24922 Dec 14 05:59:25 kernel: mapped:711 shmem:188 pagetables:151 bounce:0 Dec 14 05:59:25 kernel: DMA free:1528kB min:4096kB low:5120kB high:6144kB active_anon:3804kB inactive_anon:3752kB active_file:1588kB inactive_file:2396kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:2844kB shmem:752kB slab_reclaimable:600kB slab_unreclaimable:99688kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no Dec 14 05:59:25 kernel: lowmem_reserve[]: 0 0 0 Dec 14 05:59:25 kernel: DMA: 14*4kB 6*8kB 5*16kB 6*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1528kB Dec 14 05:59:25 kernel: 1184 total pagecache pages Dec 14 05:59:25 kernel: 0 pages in swap cache Dec 14 05:59:25 kernel: Swap cache stats: add 0, delete 0, find 0/0 Dec 14 05:59:25 kernel: Free swap = 0kB Dec 14 05:59:25 kernel: Total swap = 0kB Dec 14 05:59:25 kernel: 32768 pages of RAM Dec 14 05:59:25 kernel: 552 free pages Dec 14 05:59:25 kernel: 1352 reserved pages Dec 14 05:59:25 kernel: 9646 slab pages Dec 14 05:59:25 kernel: 3844 pages shared Dec 14 05:59:25 kernel: 0 pages swap cached Dec 14 05:59:25 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20) Dec 14 05:59:25 kernel: cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0 Dec 14 05:59:25 kernel: node 0: slabs: 2213, objs: 17466, free: 0 Dec 14 05:59:25 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:25 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed Dec 19 23:04:32 disk_monitor: Got SIGALRM... Aug 1 02:00:09 syslogd started: BusyBox v1.17.4 Aug 1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST) Aug 1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017 Aug 1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f Aug 1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Aug 1 02:00:09 kernel: Machine: Northstar Prototype Aug 1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000 Aug 1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc Aug 1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Aug 1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug Aug 1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem Aug 1 02:00:10 kernel: Virtual kernel memory layout: Aug 1 02:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Aug 1 02:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Aug 1 02:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB) Aug 1 02:00:10 kernel: vmalloc : 0x88800000 - 0xf0000000 (1656 MB) Aug 1 02:00:10 kernel: lowmem : 0x80000000 - 0x88000000 ( 128 MB) Aug 1 02:00:10 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB) Aug 1 02:00:10 kernel: .init : 0x80008000 - 0x80038000 ( 192 kB) Aug 1 02:00:10 kernel: .text : 0x80038000 - 0x803e4000 (3760 kB) Aug 1 02:00:10 kernel: .data : 0x803fc000 - 0x8041ef80 ( 140 kB) Aug 1 02:00:10 kernel: Mount-cache hash table entries: 512 Aug 1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB Aug 1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled Aug 1 02:00:10 kernel: bio: create slab at 0 Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: no core Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: PCI: Fixing up bus 1 Aug 1 02:00:10 kernel: PCI: scanning bus 0 !!! Aug 1 02:00:10 kernel: PCI: Fixing up bus 0 Aug 1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2 Aug 1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Aug 1 02:00:10 kernel: pflash: found no supported devices Aug 1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30 Aug 1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash": Aug 1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot" Aug 1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux" Aug 1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs" Aug 1 02:00:10 kernel: 0x000000d30000-0x000000ff0000 : "jffs2" Aug 1 02:00:10 kernel: 0x000000ff0000-0x000001000000 : "nvram" Aug 1 02:00:10 kernel: === PPTP init === Aug 1 02:00:11 kernel: Registering the dns_resolver key type Aug 1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2. Aug 1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel. Aug 1 02:00:11 kernel: Disabling lock debugging due to kernel taint Aug 1 02:00:11 kernel: et_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: et_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8 Aug 1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20 Aug 1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled Aug 1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: wl_module_init: passivemode set to 0x0 Aug 1 02:00:11 kernel: wl_module_init: txworkq set to 0x1 Aug 1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142) Aug 1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac81004, fsr=0x1c06, pc=0x2aacda40 lr=0x2aacde5c ignored. Aug 1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393) Aug 1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1547) Aug 1 02:00:11 kernel: _ Reboot message ... _______________________________________________________ Aug 1 02:00:11 kernel: <0>Kernel panic - not syncing: Out of memory: system-wide panic_on_oom is enabled Aug 1 02:00:11 kernel: <0> Aug 1 02:00:11 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<802fec2c>] (panic+0x7c/0x1a4) Aug 1 02:00:11 kernel: <4>[<802fec2c>] (panic+0x7c/0x1a4) from [<80091038>] (out_of_memory+0x2c8/0x328) Aug 1 02:00:11 kernel: <4>[<80091038>] (out_of_memory+0x2c8/0x328) from [<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) Aug 1 02:00:11 kernel: <4>[<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) from [<80096000>] (__do_page_cache_readahead+0x140/0x2d0) Aug 1 02:00:11 kernel: <4>[<80096000>] (__do_page_cache_readahead+0x140/0x2d0) from [<80096440>] (ra_submit+0x28/0x30) Aug 1 02:00:11 kernel: <4>[<80096440>] (ra_submit+0x28/0x30) from [<8008e5d0>] (filemap_fault+0x42c/0x454) Aug 1 02:00:11 kernel: <4>[<8008e5d0>] (filemap_fault+0x42c/0x454) from [<800a315c>] (__do_fault.clone.60+0x54/0x4c8) Aug 1 02:00:11 kernel: <4>[<800a315c>] (__do_fault.clone.60+0x54/0x4c8) from [<800a67c4>] (handle_mm_fault+0x114/0x934) Aug 1 02:00:11 kernel: <4>[<800a67c4>] (handle_mm_fault+0x114/0x934) from [<8003fd90>] (do_page_fault+0x178/0x1ec) Aug 1 02:00:11 kernel: <4>[<8003fd90>] (do_page_fault+0x178/0x1ec) from [<80038298>] (do_PrefetchAbort+0x30/0x9c) Aug 1 02:00:11 kernel: <4>[<80038298>] (do_PrefetchAbort+0x30/0x9c) from [<803bf2e0>] (ret_from_exception+0x0/0x10) Aug 1 02:00:11 kernel: <4>Exception stack(0x8523ffb0 to 0x8523fff8) Aug 1 02:00:11 kernel: <4>ffa0: 00000004 0008d206 0009a21f 00000073 Aug 1 02:00:11 kernel: <4>ffc0: 0009a21f 000983cc 0000010e 00000000 0009a256 00001e38 00000500 0000000a Aug 1 02:00:11 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:11 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:11 kernel: <4>ffe0: 00098720 7eb6ed78 0002c958 2ac956e0 20000010 ffffffff Aug 1 02:00:11 kernel: <0>Rebooting in 3 seconds..osl_ctfpool_add: skb alloc of len 2016 failed Aug 1 02:00:11 kernel: ____________________________________________________________________________ Aug 1 02:00:11 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:11 WAN Connection: Fail to connect with some issues. Aug 1 02:00:16 RT-AC1200G+: start httpd - SSL Aug 1 02:00:16 RT-AC1200G+: start httpd Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 syslog: Generating SSL certificate... Aug 1 02:00:17 disk monitor: be idle Aug 1 02:00:17 jffs2: valid logs(1) Aug 1 02:00:17 hour monitor: daemon is starting Aug 1 02:00:17 hour monitor: daemon terminates Aug 1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1] Aug 1 02:00:18 kernel: Attempt to kill tasklet from interrupt Aug 1 02:00:18 miniupnpd[459]: version 1.9 started Aug 1 02:00:18 miniupnpd[459]: HTTP listening on port 36767 Aug 1 02:00:18 miniupnpd[459]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:19 pppd[472]: pppd 2.4.7 started by admin, uid 0 Aug 1 02:00:19 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep Aug 1 02:00:19 syslog: module leds-usb not found in modules.dep Aug 1 02:00:20 kernel: SCSI subsystem initialized Aug 1 02:00:22 pppd[472]: PAP authentication failed Aug 1 02:00:28 pppd[472]: Connection terminated. Aug 1 02:00:28 pppd[472]: Modem hangup Aug 1 02:00:38 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:38 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:42 pppd[472]: PAP authentication failed Aug 1 02:00:42 pppd[472]: Connection terminated. Aug 1 02:00:42 rc_service: zcip 684:notify_rc start_firewall Aug 1 02:00:42 zcip client: configured 169.254.163.221 Aug 1 02:00:42 miniupnpd[459]: shutting down MiniUPnPd Aug 1 02:00:42 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)! Aug 1 02:00:44 kernel: nf_conntrack_rtsp v0.6.21 loading Aug 1 02:00:44 kernel: nf_nat_rtsp v0.6.21 loading Aug 1 02:00:44 miniupnpd[740]: version 1.9 started Aug 1 02:00:44 miniupnpd[740]: HTTP listening on port 52453 Aug 1 02:00:44 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:00:47 stop_nat_rules: apply the redirect_rules! Aug 1 02:00:52 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:00:52 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:00:55 pppd[472]: PAP authentication failed Aug 1 02:00:55 pppd[472]: Connection terminated. Aug 1 02:01:05 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0 Aug 1 02:01:05 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:07 pppd[472]: PAP authentication failed Aug 1 02:01:08 pppd[472]: Connection terminated. Aug 1 02:01:18 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:01:18 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:21 pppd[472]: PAP authentication failed Aug 1 02:01:21 pppd[472]: Connection terminated. Aug 1 02:01:31 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0 Aug 1 02:01:31 pppd[472]: Connect: ppp0 <--> eth0 Aug 1 02:01:31 pppd[472]: PAP authentication succeeded Aug 1 02:01:31 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized Aug 1 02:01:32 pppd[472]: local IP address 93.138.54.92 Aug 1 02:01:32 pppd[472]: remote IP address 172.29.252.64 Aug 1 02:01:32 rc_service: ip-up 804:notify_rc start_firewall Aug 1 02:01:33 miniupnpd[740]: shutting down MiniUPnPd Aug 1 02:01:33 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)! Aug 1 02:01:33 rc_service: ip-up 804:notify_rc stop_upnp Aug 1 02:01:33 rc_service: waitting "start_firewall" via ip-up ... Aug 1 02:01:35 miniupnpd[851]: version 1.9 started Aug 1 02:01:35 miniupnpd[851]: HTTP listening on port 34250 Aug 1 02:01:35 miniupnpd[851]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:01:35 miniupnpd[851]: shutting down MiniUPnPd Aug 1 02:01:35 rc_service: ip-up 804:notify_rc start_upnp Aug 1 02:01:36 rc_service: waitting "stop_upnp" via ip-up ... Aug 1 02:01:36 WAN Connection: WAN was restored. Aug 1 02:01:38 miniupnpd[856]: version 1.9 started Aug 1 02:01:38 miniupnpd[856]: HTTP listening on port 36430 Aug 1 02:01:38 miniupnpd[856]: Listening for NAT-PMP/PCP traffic on port 5351 Aug 1 02:01:38 ntp: start NTP update Dec 19 23:16:17 rc_service: ntp 854:notify_rc restart_upnp Dec 19 23:16:17 miniupnpd[856]: shutting down MiniUPnPd Dec 19 23:16:17 miniupnpd[869]: version 1.9 started Dec 19 23:16:17 miniupnpd[869]: HTTP listening on port 46870 Dec 19 23:16:17 miniupnpd[869]: Listening for NAT-PMP/PCP traffic on port 5351 Dec 19 23:16:18 rc_service: ntp 854:notify_rc restart_diskmon Dec 19 23:16:18 disk_monitor: Finish Dec 19 23:16:18 kernel: HTB: quantum of class 10001 is big. Consider r2q change. Dec 19 23:16:19 kernel: HTB: quantum of class 20001 is big. Consider r2q change. Dec 19 23:16:19 kernel: HTB: quantum of class 10009 is big. Consider r2q change. Dec 19 23:16:19 kernel: HTB: quantum of class 20009 is big. Consider r2q change. Dec 19 23:16:19 disk monitor: be idle
pozdrav,
imam navedeni ruter u kombinaciji sa ht-ovim speedportom (ona ac wifi verzija), asus je na zadnjem sluzbenom fw i zadnjih 3 mjeseca je normalno radio no sad se smrzne sam od sebe i nakon par minuta reboota
ovo pise u logu pa ako ga netko moze desifrirati, asus support mi rekao da nosim na servis ako sumnjam da je neispravan i ne znam sto je sa ovim august 1 datumom, clearao sam jutros log tako da je ovo od zadnjeg crasha
Code:
Aug  1 02:00:11 kernel: pflash: found no supported devices
Aug  1 02:00:11 kernel: bcmsflash: squash filesystem found at block 30
Aug  1 02:00:11 kernel: Creating 5 MTD partitions on "bcmsflash":
Aug  1 02:00:11 kernel: 0x000000000000-0x000000040000 : "boot"
Aug  1 02:00:11 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae50004, fsr=0x1c06, pc=0x800cda10 lr=0x800cdd30 ignored.
Aug  1 02:00:18 miniupnpd[465]: version 1.9 started
Aug  1 02:00:18 miniupnpd[465]: HTTP listening on port 44321
Aug  1 02:00:18 miniupnpd[465]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:19 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug  1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A3:B7:70 authorized
Aug  1 02:00:20 pppd[472]: local  IP address 93.142.236.121
Aug  1 02:00:20 pppd[472]: remote IP address 172.29.252.90
Aug  1 02:00:20 rc_service: ip-up 500:notify_rc start_firewall
Aug  1 02:00:21 rc_service: ip-up 500:notify_rc stop_upnp
Aug  1 02:00:21 rc_service: waitting "start_firewall" via ip-up ...
Aug  1 02:00:27 miniupnpd[465]: shutting down MiniUPnPd
Aug  1 02:00:27 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug  1 02:00:32 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug  1 02:00:32 kernel: nf_nat_rtsp v0.6.21 loading
Aug  1 02:00:32 miniupnpd[748]: version 1.9 started
Aug  1 02:00:32 miniupnpd[748]: HTTP listening on port 45952
Aug  1 02:00:32 miniupnpd[748]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:33 rc_service: ip-up 500:notify_rc start_upnp
Aug  1 02:00:33 miniupnpd[748]: shutting down MiniUPnPd
Aug  1 02:00:35 miniupnpd[754]: version 1.9 started
Aug  1 02:00:35 miniupnpd[754]: HTTP listening on port 55762
Aug  1 02:00:35 miniupnpd[754]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:37 ntp: start NTP update
Aug  1 02:00:37 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Nov 29 05:02:11 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Nov 29 05:02:12 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Nov 29 05:02:12 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Nov 29 05:02:12 rc_service: ntp 752:notify_rc restart_upnp
Nov 29 05:02:12 miniupnpd[754]: shutting down MiniUPnPd
Nov 29 05:02:13 rc_service: ntp 752:notify_rc restart_diskmon
Nov 29 05:02:14 disk_monitor: Finish
Nov 29 05:02:15 miniupnpd[784]: version 1.9 started
Nov 29 05:02:15 miniupnpd[784]: HTTP listening on port 44342
Nov 29 05:02:15 miniupnpd[784]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 29 05:02:17 disk monitor: be idle
Nov 29 05:02:17 rc_service: zcip 785:notify_rc start_firewall
Nov 29 05:02:17 zcip client: configured 169.254.163.221
Nov 29 05:02:18 miniupnpd[784]: shutting down MiniUPnPd
Nov 29 05:02:18 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Nov 29 05:02:20 miniupnpd[825]: version 1.9 started
Nov 29 05:02:20 miniupnpd[825]: HTTP listening on port 49515
Nov 29 05:02:20 miniupnpd[825]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 29 09:36:17 miniupnpd[825]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Nov 29 09:36:24 miniupnpd[825]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Nov 29 09:36:38 miniupnpd[825]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Nov 29 17:18:01 rc_service: httpds 417:notify_rc start_webs_update
Nov 29 23:04:49 disk_monitor: Got SIGALRM...
Nov 30 05:00:15 kernel: Emergency Sync complete
Aug  1 02:00:09 kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Aug  1 02:00:09 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2adde000, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored.
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2abb13b0, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored.
Aug  1 02:00:17 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1]
Aug  1 02:00:17 kernel: Attempt to kill tasklet from interrupt
Aug  1 02:00:18 miniupnpd[464]: version 1.9 started
Aug  1 02:00:18 miniupnpd[464]: HTTP listening on port 59631
Aug  1 02:00:18 miniupnpd[464]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:19 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug  1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized
Aug  1 02:00:19 kernel: SCSI subsystem initialized
Aug  1 02:00:20 pppd[472]: local  IP address 93.139.156.15
Aug  1 02:00:20 pppd[472]: remote IP address 172.29.252.89
Aug  1 02:00:20 rc_service: ip-up 513:notify_rc start_firewall
Aug  1 02:00:20 rc_service: ip-up 513:notify_rc stop_upnp
Aug  1 02:00:21 WAN Connection: WAN was restored.
Aug  1 02:00:27 miniupnpd[464]: shutting down MiniUPnPd
Aug  1 02:00:30 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug  1 02:00:30 kernel: nf_nat_rtsp v0.6.21 loading
Aug  1 02:00:31 miniupnpd[746]: version 1.9 started
Aug  1 02:00:31 miniupnpd[746]: HTTP listening on port 46370
Aug  1 02:00:31 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:32 rc_service: ip-up 513:notify_rc start_upnp
Aug  1 02:00:32 rc_service: waitting "stop_upnp" via ip-up ...
Aug  1 02:00:32 miniupnpd[746]: shutting down MiniUPnPd
Aug  1 02:00:34 miniupnpd[751]: version 1.9 started
Aug  1 02:00:34 miniupnpd[751]: HTTP listening on port 54040
Aug  1 02:00:34 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:35 ntp: start NTP update
Nov 30 05:01:45 rc_service: ntp 749:notify_rc restart_upnp
Nov 30 05:01:45 miniupnpd[751]: shutting down MiniUPnPd
Nov 30 05:01:46 rc_service: ntp 749:notify_rc restart_diskmon
Nov 30 05:01:47 miniupnpd[766]: version 1.9 started
Nov 30 05:01:47 miniupnpd[766]: HTTP listening on port 36896
Nov 30 05:01:47 miniupnpd[766]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 30 05:01:47 disk_monitor: Finish
Nov 30 05:01:47 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Nov 30 05:01:47 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Nov 30 05:01:47 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Nov 30 05:01:48 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Nov 30 05:01:50 disk monitor: be idle
Nov 30 05:01:50 rc_service: zcip 778:notify_rc start_firewall
Nov 30 05:01:50 zcip client: configured 169.254.163.221
Nov 30 05:01:52 miniupnpd[766]: shutting down MiniUPnPd
Nov 30 05:01:52 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Nov 30 05:01:54 miniupnpd[821]: version 1.9 started
Nov 30 05:01:54 miniupnpd[821]: HTTP listening on port 41162
Nov 30 05:01:54 miniupnpd[821]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 30 23:04:17 disk_monitor: Got SIGALRM...
Dec  1 00:26:07 rc_service: httpds 417:notify_rc start_webs_update
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae0e004, fsr=0x1c06, pc=0x80171f68 lr=0x800cc4c4 ignored.
Aug  1 02:00:18 miniupnpd[459]: HTTP listening on port 59994
Aug  1 02:00:19 pppd[473]: pppd 2.4.7 started by admin, uid 0
Aug  1 02:00:19 pppd[473]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug  1 02:00:19 pppd[473]: Connect: ppp0 <--> eth0
Aug  1 02:00:19 pppd[473]: PAP authentication succeeded
Aug  1 02:00:19 pppd[473]: peer from calling number 00:90:1A:A3:B7:7C authorized
Aug  1 02:00:20 pppd[473]: local  IP address 93.139.153.7
Aug  1 02:00:20 pppd[473]: remote IP address 172.29.252.89
Aug  1 02:00:20 rc_service: ip-up 503:notify_rc start_firewall
Aug  1 02:00:21 rc_service: ip-up 503:notify_rc stop_upnp
Aug  1 02:00:28 miniupnpd[459]: shutting down MiniUPnPd
Aug  1 02:00:33 miniupnpd[750]: version 1.9 started
Aug  1 02:00:33 miniupnpd[750]: HTTP listening on port 54542
Aug  1 02:00:33 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:33 rc_service: ip-up 503:notify_rc start_upnp
Aug  1 02:00:33 miniupnpd[750]: shutting down MiniUPnPd
Aug  1 02:00:35 miniupnpd[755]: version 1.9 started
Aug  1 02:00:35 miniupnpd[755]: HTTP listening on port 38653
Aug  1 02:00:35 miniupnpd[755]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:36 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Aug  1 02:00:36 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec  1 05:01:41 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec  1 05:01:42 rc_service: ntp 753:notify_rc restart_upnp
Dec  1 05:01:42 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  1 05:01:42 miniupnpd[755]: shutting down MiniUPnPd
Dec  1 05:01:42 miniupnpd[779]: version 1.9 started
Dec  1 05:01:42 miniupnpd[779]: HTTP listening on port 43370
Dec  1 05:01:42 miniupnpd[779]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  1 05:01:43 rc_service: ntp 753:notify_rc restart_diskmon
Dec  1 05:01:43 disk_monitor: Finish
Dec  1 05:01:45 disk monitor: be idle
Dec  1 05:01:47 rc_service: zcip 803:notify_rc start_firewall
Dec  1 05:01:47 zcip client: configured 169.254.163.221
Dec  1 05:01:48 miniupnpd[779]: shutting down MiniUPnPd
Dec  1 05:01:48 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec  1 05:01:49 miniupnpd[830]: version 1.9 started
Dec  1 05:01:49 miniupnpd[830]: HTTP listening on port 35003
Dec  1 05:01:49 miniupnpd[830]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  1 13:31:57 rc_service: httpds 417:notify_rc start_webs_update
Dec  1 13:46:24 rc_service: httpds 417:notify_rc start_webs_update
Dec  1 15:51:15 rc_service: httpds 417:notify_rc start_webs_update
Dec  1 23:04:19 disk_monitor: Got SIGALRM...
Dec  2 00:19:22 rc_service: httpds 417:notify_rc start_webs_update
Aug  1 02:00:10 syslogd started: BusyBox v1.17.4
Aug  1 02:00:10 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST)
Aug  1 02:00:10 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017
Aug  1 02:00:10 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f
Aug  1 02:00:10 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug  1 02:00:10 kernel: Machine: Northstar Prototype
Aug  1 02:00:10 kernel: Ignoring unrecognised tag 0x00000000
Aug  1 02:00:10 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug  1 02:00:11 kernel: PCI: Fixing up bus 0
Aug  1 02:00:11 kernel: VFS: Disk quotas dquot_6.5.2
Aug  1 02:00:11 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2adf7004, fsr=0x1c06, pc=0x8016ff34 lr=0x616e6669 ignored.
Aug  1 02:00:12 stop_nat_rules: apply the redirect_rules!
Aug  1 02:00:18 hour monitor: daemon is starting
Aug  1 02:00:18 hour monitor: daemon terminates
Aug  1 02:00:18 miniupnpd[463]: version 1.9 started
Aug  1 02:00:18 miniupnpd[463]: HTTP listening on port 48188
Aug  1 02:00:18 miniupnpd[463]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:19 pppd[472]: local  IP address 93.138.35.49
Aug  1 02:00:19 pppd[472]: remote IP address 172.29.252.64
Aug  1 02:00:20 rc_service: ip-up 502:notify_rc start_firewall
Aug  1 02:00:20 rc_service: ip-up 502:notify_rc stop_upnp
Aug  1 02:00:28 miniupnpd[463]: shutting down MiniUPnPd
Aug  1 02:00:32 miniupnpd[746]: version 1.9 started
Aug  1 02:00:32 miniupnpd[746]: HTTP listening on port 38934
Aug  1 02:00:32 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:32 rc_service: ip-up 502:notify_rc start_upnp
Aug  1 02:00:35 miniupnpd[752]: version 1.9 started
Aug  1 02:00:35 miniupnpd[752]: HTTP listening on port 34247
Aug  1 02:00:35 miniupnpd[752]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  2 05:01:51 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec  2 05:01:52 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec  2 05:01:52 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec  2 05:01:52 rc_service: ntp 749:notify_rc restart_upnp
Dec  2 05:01:52 miniupnpd[752]: shutting down MiniUPnPd
Dec  2 05:01:53 rc_service: ntp 749:notify_rc restart_diskmon
Dec  2 05:01:53 disk_monitor: Finish
Dec  2 05:01:54 miniupnpd[772]: version 1.9 started
Dec  2 05:01:54 miniupnpd[772]: HTTP listening on port 39930
Dec  2 05:01:54 miniupnpd[772]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  2 05:01:55 disk monitor: be idle
Dec  2 05:01:55 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  2 05:01:56 rc_service: zcip 783:notify_rc start_firewall
Dec  2 05:01:56 zcip client: configured 169.254.163.221
Dec  2 05:01:57 miniupnpd[772]: shutting down MiniUPnPd
Dec  2 05:01:57 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec  2 05:01:59 miniupnpd[829]: version 1.9 started
Dec  2 05:01:59 miniupnpd[829]: HTTP listening on port 60719
Dec  2 05:01:59 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  2 23:04:36 disk_monitor: Got SIGALRM...
Dec  2 23:24:42 rc_service: httpds 417:notify_rc start_webs_update
Dec  3 05:00:08 kernel: Emergency Sync complete
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2addf004, fsr=0x1c06, pc=0x2abe2c58 lr=0x17bd8 ignored.
Aug  1 02:00:18 syslog: Generating SSL certificate...
Aug  1 02:00:18 miniupnpd[456]: version 1.9 started
Aug  1 02:00:18 miniupnpd[456]: HTTP listening on port 58051
Aug  1 02:00:18 miniupnpd[456]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:18 pppd[468]: pppd 2.4.7 started by admin, uid 0
Aug  1 02:00:19 pppd[468]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug  1 02:00:19 pppd[468]: Connect: ppp0 <--> eth0
Aug  1 02:00:19 pppd[468]: PAP authentication succeeded
Aug  1 02:00:19 pppd[468]: peer from calling number 84:B5:9C:A4:4D:B7 authorized
Aug  1 02:00:19 pppd[468]: local  IP address 78.1.145.97
Aug  1 02:00:19 pppd[468]: remote IP address 172.29.252.59
Aug  1 02:00:20 rc_service: ip-up 500:notify_rc stop_upnp
Aug  1 02:00:28 miniupnpd[456]: shutting down MiniUPnPd
Aug  1 02:00:31 miniupnpd[746]: HTTP listening on port 34838
Aug  1 02:00:32 rc_service: ip-up 500:notify_rc start_upnp
Aug  1 02:00:36 miniupnpd[751]: HTTP listening on port 43021
Aug  1 02:00:38 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec  3 05:01:41 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec  3 05:01:41 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec  3 05:01:41 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  3 05:01:41 rc_service: ntp 749:notify_rc restart_upnp
Dec  3 05:01:41 miniupnpd[751]: shutting down MiniUPnPd
Dec  3 05:01:42 rc_service: ntp 749:notify_rc restart_diskmon
Dec  3 05:01:43 disk_monitor: Finish
Dec  3 05:01:43 miniupnpd[777]: version 1.9 started
Dec  3 05:01:43 miniupnpd[777]: HTTP listening on port 58098
Dec  3 05:01:43 miniupnpd[777]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  3 05:01:46 disk monitor: be idle
Dec  3 05:01:46 rc_service: zcip 779:notify_rc start_firewall
Dec  3 05:01:46 zcip client: configured 169.254.163.221
Dec  3 05:01:48 miniupnpd[777]: shutting down MiniUPnPd
Dec  3 05:01:48 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec  3 05:01:51 miniupnpd[821]: version 1.9 started
Dec  3 05:01:51 miniupnpd[821]: HTTP listening on port 38041
Dec  3 05:01:51 miniupnpd[821]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  3 14:38:57 rc_service: httpds 417:notify_rc start_webs_update
Dec  3 16:27:13 rc_service: httpds 417:notify_rc start_webs_update
Dec  3 23:04:15 disk_monitor: Got SIGALRM...
Dec  4 05:00:31 kernel: Emergency Sync complete
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ace0004, fsr=0x1c06, pc=0x2aefa014 lr=0xed80 ignored.
Aug  1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257)
Aug  1 02:00:18 miniupnpd[458]: version 1.9 started
Aug  1 02:00:18 miniupnpd[458]: HTTP listening on port 57289
Aug  1 02:00:18 miniupnpd[458]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:18 pppd[473]: pppd 2.4.7 started by admin, uid 0
Aug  1 02:00:19 pppd[473]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:00:19 pppd[473]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug  1 02:00:19 pppd[473]: local  IP address 93.138.65.23
Aug  1 02:00:19 pppd[473]: remote IP address 172.29.252.64
Aug  1 02:00:28 miniupnpd[458]: shutting down MiniUPnPd
Aug  1 02:00:32 miniupnpd[749]: version 1.9 started
Aug  1 02:00:32 miniupnpd[749]: HTTP listening on port 56477
Aug  1 02:00:32 miniupnpd[749]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:32 miniupnpd[749]: shutting down MiniUPnPd
Aug  1 02:00:34 miniupnpd[753]: version 1.9 started
Aug  1 02:00:34 miniupnpd[753]: HTTP listening on port 45468
Aug  1 02:00:34 miniupnpd[753]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  4 05:02:10 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec  4 05:02:10 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec  4 05:02:10 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec  4 05:02:10 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  4 05:02:10 rc_service: ntp 751:notify_rc restart_upnp
Dec  4 05:02:10 miniupnpd[753]: shutting down MiniUPnPd
Dec  4 05:02:11 miniupnpd[777]: version 1.9 started
Dec  4 05:02:11 miniupnpd[777]: HTTP listening on port 34593
Dec  4 05:02:11 miniupnpd[777]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  4 05:02:11 rc_service: ntp 751:notify_rc restart_diskmon
Dec  4 05:02:12 disk_monitor: Finish
Dec  4 05:02:14 disk monitor: be idle
Dec  4 05:02:15 rc_service: zcip 794:notify_rc start_firewall
Dec  4 05:02:15 zcip client: configured 169.254.163.221
Dec  4 05:02:15 miniupnpd[777]: shutting down MiniUPnPd
Dec  4 05:02:15 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec  4 05:02:16 miniupnpd[830]: version 1.9 started
Dec  4 05:02:16 miniupnpd[830]: HTTP listening on port 58999
Dec  4 05:02:16 miniupnpd[830]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  4 23:04:47 disk_monitor: Got SIGALRM...
Dec  4 23:48:21 miniupnpd[830]: send(res_buf): Connection reset by peer
Dec  4 23:56:56 rc_service: httpds 417:notify_rc start_webs_update
Dec  4 23:57:13 rc_service: httpds 417:notify_rc start_webs_update
Dec  5 00:24:08 miniupnpd[830]: upnp_event_recv: recv(): Connection reset by peer
Dec  5 00:38:33 miniupnpd[830]: upnp_event_recv: recv(): Connection reset by peer
Dec  5 00:51:09 miniupnpd[830]: upnp_event_recv: recv(): Connection reset by peer
Dec  5 05:00:09 kernel: Emergency Sync complete
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2adef004, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac983b0, fsr=0x1c06, pc=0x7f190b38 lr=0x80208820 ignored.
Aug  1 02:00:11 kernel: <4>Emergency Sync complete
Aug  1 02:00:11 kernel: <4>gro disabled
Aug  1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt
Aug  1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state
Aug  1 02:00:11 kernel: <6>device eth0 left promiscuous mode
Aug  1 02:00:11 kernel: <6>device eth0 entered promiscuous mode
Aug  1 02:00:11 kernel: <6>br0: topology change detected, propagating
Aug  1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state
Aug  1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state
Aug  1 02:00:11 kernel: <6>device vlan1 left promiscuous mode
Aug  1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state
Aug  1 02:00:11 kernel: <6>device eth1 left promiscuous mode
Aug  1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state
Aug  1 02:00:11 kernel: <6>device eth2 left promiscuous mode
Aug  1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp
Aug  1 02:00:11 kernel: <0>Restarting system.
Aug  1 02:00:18 miniupnpd[459]: HTTP listening on port 34377
Aug  1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0
Aug  1 02:00:19 pppd[472]: PAP authentication succeeded
Aug  1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug  1 02:00:19 pppd[472]: local  IP address 93.138.33.193
Aug  1 02:00:20 rc_service: ip-up 505:notify_rc start_firewall
Aug  1 02:00:20 rc_service: ip-up 505:notify_rc stop_upnp
Aug  1 02:00:20 rc_service: waitting "start_firewall" via ip-up ...
Aug  1 02:00:27 miniupnpd[459]: shutting down MiniUPnPd
Aug  1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug  1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug  1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading
Aug  1 02:00:31 miniupnpd[747]: version 1.9 started
Aug  1 02:00:31 miniupnpd[747]: HTTP listening on port 33348
Aug  1 02:00:31 miniupnpd[747]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:31 rc_service: ip-up 505:notify_rc start_upnp
Aug  1 02:00:31 rc_service: waitting "stop_upnp" via ip-up ...
Aug  1 02:00:31 miniupnpd[747]: shutting down MiniUPnPd
Aug  1 02:00:34 miniupnpd[753]: HTTP listening on port 46842
Dec  5 05:01:47 rc_service: ntp 750:notify_rc restart_upnp
Dec  5 05:01:47 miniupnpd[753]: shutting down MiniUPnPd
Dec  5 05:01:47 rc_service: ntp 750:notify_rc restart_diskmon
Dec  5 05:01:48 miniupnpd[767]: version 1.9 started
Dec  5 05:01:48 miniupnpd[767]: HTTP listening on port 34835
Dec  5 05:01:48 miniupnpd[767]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  5 05:01:48 disk_monitor: Finish
Dec  5 05:01:49 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec  5 05:01:49 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec  5 05:01:49 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec  5 05:01:50 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  5 05:01:50 syslog: Generating SSL certificate...
Dec  5 05:01:51 disk monitor: be idle
Dec  5 05:01:51 syslog: Generating SSL certificate...
Dec  5 05:01:54 rc_service: zcip 817:notify_rc start_firewall
Dec  5 05:01:54 zcip client: configured 169.254.163.221
Dec  5 05:01:55 miniupnpd[767]: shutting down MiniUPnPd
Dec  5 05:01:55 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec  5 05:01:57 miniupnpd[845]: version 1.9 started
Dec  5 05:01:57 miniupnpd[845]: HTTP listening on port 35000
Dec  5 05:01:57 miniupnpd[845]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  5 17:13:06 rc_service: httpds 417:notify_rc start_webs_update
Dec  5 17:19:06 rc_service: httpds 417:notify_rc restart_firewall;restart_qos
Dec  5 17:19:07 miniupnpd[845]: shutting down MiniUPnPd
Dec  5 17:19:07 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec  5 17:19:08 miniupnpd[11742]: version 1.9 started
Dec  5 17:19:08 miniupnpd[11742]: HTTP listening on port 59119
Dec  5 17:19:08 miniupnpd[11742]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  5 17:19:09 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec  5 17:19:09 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec  5 17:19:09 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec  5 17:19:09 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  5 17:19:09 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec  5 17:19:13 rc_service: httpds 417:notify_rc restart_firewall;restart_qos
Dec  5 17:19:14 miniupnpd[11742]: shutting down MiniUPnPd
Dec  5 17:19:14 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec  5 17:19:17 miniupnpd[11825]: version 1.9 started
Dec  5 17:19:17 miniupnpd[11825]: HTTP listening on port 36609
Dec  5 17:19:17 miniupnpd[11825]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  5 17:19:17 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec  5 17:19:17 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec  5 17:19:17 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec  5 17:19:17 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  5 17:19:18 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec  5 17:27:34 rc_service: httpds 417:notify_rc restart_firewall;restart_qos
Dec  5 17:27:35 miniupnpd[11825]: shutting down MiniUPnPd
Dec  5 17:27:35 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec  5 17:27:37 miniupnpd[12024]: version 1.9 started
Dec  5 17:27:37 miniupnpd[12024]: HTTP listening on port 50107
Dec  5 17:27:37 miniupnpd[12024]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  5 17:27:38 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec  5 17:27:38 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec  5 17:27:38 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec  5 17:27:38 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  5 17:27:38 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec  5 17:38:51 rc_service: httpds 417:notify_rc start_webs_update
Dec  5 23:04:12 disk_monitor: Got SIGALRM...
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae3c000, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ad133b0, fsr=0x1c06, pc=0x7f190b38 lr=0x80208820 ignored.
Aug  1 02:00:18 miniupnpd[464]: HTTP listening on port 40151
Aug  1 02:00:41 rc_service: zcip 659:notify_rc start_firewall
Aug  1 02:00:41 zcip client: configured 169.254.163.221
Aug  1 02:00:42 miniupnpd[464]: shutting down MiniUPnPd
Aug  1 02:00:43 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug  1 02:00:43 kernel: nf_nat_rtsp v0.6.21 loading
Aug  1 02:00:44 miniupnpd[715]: version 1.9 started
Aug  1 02:00:44 miniupnpd[715]: HTTP listening on port 51086
Aug  1 02:00:44 miniupnpd[715]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:49 pppd[472]: No response to PAP authenticate-requests
Aug  1 02:00:49 pppd[472]: Connection terminated.
Aug  1 02:00:59 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:00:59 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:01:00 pppd[472]: PAP authentication succeeded
Aug  1 02:01:00 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug  1 02:01:00 pppd[472]: local  IP address 93.138.14.31
Aug  1 02:01:00 pppd[472]: remote IP address 172.29.252.64
Aug  1 02:01:01 rc_service: ip-up 742:notify_rc start_firewall
Aug  1 02:01:02 miniupnpd[715]: shutting down MiniUPnPd
Aug  1 02:01:02 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug  1 02:01:02 rc_service: ip-up 742:notify_rc stop_upnp
Aug  1 02:01:02 rc_service: waitting "start_firewall" via ip-up ...
Aug  1 02:01:03 WAN Connection: WAN was restored.
Aug  1 02:01:03 miniupnpd[806]: version 1.9 started
Aug  1 02:01:03 miniupnpd[806]: HTTP listening on port 56297
Aug  1 02:01:03 miniupnpd[806]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:01:03 rc_service: ip-up 742:notify_rc start_upnp
Aug  1 02:01:03 rc_service: waitting "stop_upnp" via ip-up ...
Aug  1 02:01:03 miniupnpd[806]: shutting down MiniUPnPd
Aug  1 02:01:05 miniupnpd[810]: version 1.9 started
Aug  1 02:01:05 miniupnpd[810]: HTTP listening on port 48458
Aug  1 02:01:05 miniupnpd[810]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:01:06 ntp: start NTP update
Dec  6 05:02:21 rc_service: ntp 808:notify_rc restart_upnp
Dec  6 05:02:21 miniupnpd[810]: shutting down MiniUPnPd
Dec  6 05:02:22 miniupnpd[818]: version 1.9 started
Dec  6 05:02:22 miniupnpd[818]: HTTP listening on port 39117
Dec  6 05:02:22 miniupnpd[818]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  6 05:02:22 rc_service: ntp 808:notify_rc restart_diskmon
Dec  6 05:02:22 disk_monitor: Finish
Dec  6 05:02:23 disk monitor: be idle
Dec  6 05:02:23 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec  6 05:02:23 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec  6 05:02:23 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec  6 05:02:23 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  6 05:02:23 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec  6 23:05:05 disk_monitor: Got SIGALRM...
Dec  7 05:00:09 kernel: Emergency Sync complete
Aug  1 02:00:11 kernel: 0x0000001ef614-0x000000d30000 : "rootfs"
Aug  1 02:00:11 kernel: 0x000000d30000-0x000000ff0000 : "jffs2"
Aug  1 02:00:11 kernel: 0x000000ff0000-0x000001000000 : "nvram"
Aug  1 02:00:11 kernel: === PPTP init ===
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae82000, fsr=0x1c06, pc=0x80171f68 lr=0x800cc4c4 ignored.
Aug  1 02:00:18 miniupnpd[464]: HTTP listening on port 48188
Aug  1 02:00:19 pppd[472]: local  IP address 93.139.184.227
Aug  1 02:00:19 pppd[472]: remote IP address 172.29.252.89
Aug  1 02:00:19 rc_service: ip-up 502:notify_rc start_firewall
Aug  1 02:00:22 WAN Connection: WAN was restored.
Aug  1 02:00:31 miniupnpd[746]: HTTP listening on port 47285
Aug  1 02:00:31 rc_service: ip-up 502:notify_rc start_upnp
Aug  1 02:00:31 miniupnpd[746]: shutting down MiniUPnPd
Aug  1 02:00:33 miniupnpd[751]: version 1.9 started
Aug  1 02:00:33 miniupnpd[751]: HTTP listening on port 41997
Aug  1 02:00:33 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:35 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Aug  1 02:00:36 ntp: start NTP update
Aug  1 02:00:36 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec  7 05:01:38 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  7 05:01:38 kernel: HTB: quantum of class 10030 is big. Consider r2q change.
Dec  7 05:01:38 rc_service: ntp 749:notify_rc restart_upnp
Dec  7 05:01:38 miniupnpd[751]: shutting down MiniUPnPd
Dec  7 05:01:39 rc_service: ntp 749:notify_rc restart_diskmon
Dec  7 05:01:39 miniupnpd[781]: version 1.9 started
Dec  7 05:01:39 miniupnpd[781]: HTTP listening on port 53280
Dec  7 05:01:39 miniupnpd[781]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  7 05:01:40 disk_monitor: Finish
Dec  7 05:01:42 disk monitor: be idle
Dec  7 05:01:43 rc_service: zcip 790:notify_rc start_firewall
Dec  7 05:01:43 zcip client: configured 169.254.163.221
Dec  7 05:01:45 miniupnpd[781]: shutting down MiniUPnPd
Dec  7 05:01:45 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec  7 05:01:48 miniupnpd[831]: version 1.9 started
Dec  7 05:01:48 miniupnpd[831]: HTTP listening on port 37489
Dec  7 05:01:48 miniupnpd[831]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  7 11:46:32 kernel: wl1: PHYTX error
Dec  7 11:46:33 kernel: wl1: PHYTX error
Dec  7 17:38:38 rc_service: httpds 417:notify_rc start_webs_update
Dec  7 17:38:56 rc_service: httpds 417:notify_rc restart_firewall;restart_qos
Dec  7 17:38:57 miniupnpd[831]: shutting down MiniUPnPd
Dec  7 17:38:57 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec  7 17:38:58 miniupnpd[11999]: version 1.9 started
Dec  7 17:38:58 miniupnpd[11999]: HTTP listening on port 54246
Dec  7 17:38:58 miniupnpd[11999]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  7 17:38:59 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec  7 17:38:59 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec  7 17:38:59 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec  7 17:38:59 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  7 23:04:25 disk_monitor: Got SIGALRM...
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae13000, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac803b0, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored.
Aug  1 02:00:18 miniupnpd[458]: HTTP listening on port 38078
Aug  1 02:00:18 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug  1 02:00:18 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:00:19 pppd[472]: local  IP address 93.139.145.162
Aug  1 02:00:19 rc_service: ip-up 500:notify_rc start_firewall
Aug  1 02:00:27 miniupnpd[458]: shutting down MiniUPnPd
Aug  1 02:00:32 miniupnpd[755]: version 1.9 started
Aug  1 02:00:32 miniupnpd[755]: HTTP listening on port 41125
Aug  1 02:00:32 miniupnpd[755]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:32 miniupnpd[755]: shutting down MiniUPnPd
Aug  1 02:00:34 miniupnpd[759]: version 1.9 started
Aug  1 02:00:34 miniupnpd[759]: HTTP listening on port 34872
Aug  1 02:00:34 miniupnpd[759]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:36 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  8 05:01:57 rc_service: ntp 757:notify_rc restart_upnp
Dec  8 05:01:57 miniupnpd[759]: shutting down MiniUPnPd
Dec  8 05:01:57 miniupnpd[789]: version 1.9 started
Dec  8 05:01:57 miniupnpd[789]: HTTP listening on port 39839
Dec  8 05:01:57 miniupnpd[789]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  8 05:01:58 rc_service: ntp 757:notify_rc restart_diskmon
Dec  8 05:01:58 disk_monitor: Finish
Dec  8 05:01:58 disk monitor: be idle
Dec  8 05:02:02 rc_service: zcip 801:notify_rc start_firewall
Dec  8 05:02:02 zcip client: configured 169.254.163.221
Dec  8 05:02:02 miniupnpd[789]: shutting down MiniUPnPd
Dec  8 05:02:02 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec  8 05:02:03 miniupnpd[829]: version 1.9 started
Dec  8 05:02:03 miniupnpd[829]: HTTP listening on port 54681
Dec  8 05:02:03 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae70004, fsr=0x1c06, pc=0x2ac34c58 lr=0x17bd8 ignored.
Aug  1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1403)
Aug  1 02:00:11 kernel: <4>Exception stack(0x849fffb0 to 0x849ffff8)
Aug  1 02:00:11 kernel: <4>ffa0:                                     00000001 7ea52ca0 7ea52c20 00000000
Aug  1 02:00:11 kernel: <4>ffc0: 7ea52da8 7ea52c20 0000000a 0000008e 00000007 7ea52c20 00027078 00000001
Aug  1 02:00:11 kernel: <4>ffe0: 000258c4 7ea52768 0000b318 2ab764cc 60000010 ffffffff
Aug  1 02:00:18 miniupnpd[465]: HTTP listening on port 35710
Aug  1 02:00:21 pppd[472]: PAP authentication failed
Aug  1 02:00:41 rc_service: zcip 674:notify_rc start_firewall
Aug  1 02:00:41 pppd[472]: PAP authentication failed
Aug  1 02:00:42 miniupnpd[465]: shutting down MiniUPnPd
Aug  1 02:00:44 miniupnpd[731]: version 1.9 started
Aug  1 02:00:44 miniupnpd[731]: HTTP listening on port 46554
Aug  1 02:00:44 miniupnpd[731]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:46 stop_nat_rules: apply the redirect_rules!
Aug  1 02:00:48 pppd[472]: Connection terminated.
Aug  1 02:00:48 pppd[472]: Modem hangup
Aug  1 02:00:59 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug  1 02:01:01 pppd[472]: PAP authentication failed
Aug  1 02:01:01 pppd[472]: Connection terminated.
Aug  1 02:01:12 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:01:12 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:01:14 pppd[472]: PAP authentication failed
Aug  1 02:01:14 pppd[472]: Connection terminated.
Aug  1 02:01:25 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:01:25 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:01:27 pppd[472]: PAP authentication failed
Aug  1 02:01:27 pppd[472]: Connection terminated.
Aug  1 02:01:38 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:01:38 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:01:38 pppd[472]: PAP authentication succeeded
Aug  1 02:01:38 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug  1 02:01:39 pppd[472]: local  IP address 93.138.5.224
Aug  1 02:01:39 pppd[472]: remote IP address 172.29.252.64
Aug  1 02:01:39 rc_service: ip-up 805:notify_rc start_firewall
Aug  1 02:01:40 miniupnpd[731]: shutting down MiniUPnPd
Aug  1 02:01:40 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug  1 02:01:40 rc_service: ip-up 805:notify_rc stop_upnp
Aug  1 02:01:40 rc_service: waitting "start_firewall" via ip-up ...
Aug  1 02:01:40 WAN Connection: WAN was restored.
Aug  1 02:01:41 miniupnpd[865]: version 1.9 started
Aug  1 02:01:41 miniupnpd[865]: HTTP listening on port 54744
Aug  1 02:01:41 miniupnpd[865]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:01:41 rc_service: ip-up 805:notify_rc start_upnp
Aug  1 02:01:41 rc_service: waitting "stop_upnp" via ip-up ...
Aug  1 02:01:41 miniupnpd[865]: shutting down MiniUPnPd
Aug  1 02:01:42 miniupnpd[868]: version 1.9 started
Aug  1 02:01:42 miniupnpd[868]: HTTP listening on port 37727
Aug  1 02:01:42 miniupnpd[868]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:01:43 ntp: start NTP update
Dec  8 22:53:22 rc_service: ntp 867:notify_rc restart_upnp
Dec  8 22:53:22 miniupnpd[868]: shutting down MiniUPnPd
Dec  8 22:53:23 miniupnpd[878]: version 1.9 started
Dec  8 22:53:23 miniupnpd[878]: HTTP listening on port 48606
Dec  8 22:53:23 miniupnpd[878]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  8 22:53:23 rc_service: ntp 867:notify_rc restart_diskmon
Dec  8 22:53:23 disk_monitor: Finish
Dec  8 22:53:24 disk monitor: be idle
Dec  8 22:53:24 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec  8 22:53:24 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec  8 22:53:24 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec  8 22:53:24 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  8 22:54:06 rc_service: httpd 418:notify_rc start_webs_update
Dec  8 23:00:25 disk_monitor: Got SIGALRM...
Aug  1 02:00:10 kernel: * Invalid signature of oopsbuf: 37-F3-57-77-B5-75-56-55 (len 4283905917)
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae31004, fsr=0x1c06, pc=0x2abffbe8 lr=0x2ac00c7c ignored.
Aug  1 02:00:12 WAN Connection: Fail to connect with some issues.
Aug  1 02:00:17 RT-AC1200G+: start httpd - SSL
Aug  1 02:00:18 miniupnpd[461]: version 1.9 started
Aug  1 02:00:18 miniupnpd[461]: HTTP listening on port 48173
Aug  1 02:00:18 miniupnpd[461]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:20 syslog: module ledtrig-usbdev not found in modules.dep
Aug  1 02:00:20 syslog: module leds-usb not found in modules.dep
Aug  1 02:00:42 rc_service: zcip 654:notify_rc start_firewall
Aug  1 02:00:42 miniupnpd[461]: shutting down MiniUPnPd
Aug  1 02:00:44 miniupnpd[710]: version 1.9 started
Aug  1 02:00:44 miniupnpd[710]: HTTP listening on port 52585
Aug  1 02:00:44 miniupnpd[710]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:54 pppd[472]: Timeout waiting for PADO packets
Aug  1 02:02:09 pppd[472]: Timeout waiting for PADO packets
Aug  1 02:02:09 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug  1 02:02:09 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:02:39 pppd[472]: PAP authentication succeeded
Aug  1 02:02:39 pppd[472]: peer from calling number 00:90:1A:A3:B7:70 authorized
Aug  1 02:02:40 pppd[472]: local  IP address 93.142.212.104
Aug  1 02:02:40 pppd[472]: remote IP address 172.29.252.90
Aug  1 02:02:40 rc_service: ip-up 733:notify_rc start_firewall
Aug  1 02:02:41 miniupnpd[710]: shutting down MiniUPnPd
Aug  1 02:02:41 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug  1 02:02:41 rc_service: ip-up 733:notify_rc stop_upnp
Aug  1 02:02:41 rc_service: waitting "start_firewall" via ip-up ...
Aug  1 02:02:42 miniupnpd[792]: version 1.9 started
Aug  1 02:02:42 miniupnpd[792]: HTTP listening on port 44126
Aug  1 02:02:42 miniupnpd[792]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:02:42 rc_service: ip-up 733:notify_rc start_upnp
Aug  1 02:02:42 rc_service: waitting "stop_upnp" via ip-up ...
Aug  1 02:02:42 miniupnpd[792]: shutting down MiniUPnPd
Aug  1 02:02:43 miniupnpd[794]: version 1.9 started
Aug  1 02:02:43 miniupnpd[794]: HTTP listening on port 40806
Aug  1 02:02:43 miniupnpd[794]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:02:44 WAN Connection: WAN was restored.
Aug  1 02:02:44 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Aug  1 02:02:44 ntp: start NTP update
Aug  1 02:02:44 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Aug  1 02:02:44 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Aug  1 02:02:44 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  9 09:37:03 rc_service: ntp 795:notify_rc restart_upnp
Dec  9 09:37:03 miniupnpd[794]: shutting down MiniUPnPd
Dec  9 09:37:04 miniupnpd[824]: version 1.9 started
Dec  9 09:37:04 miniupnpd[824]: HTTP listening on port 48536
Dec  9 09:37:04 miniupnpd[824]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  9 09:37:04 rc_service: ntp 795:notify_rc restart_diskmon
Dec  9 09:37:04 disk_monitor: Finish
Dec  9 09:37:05 disk monitor: be idle
Dec  9 09:47:53 pppd[472]: Serial link appears to be disconnected.
Dec  9 09:47:54 WAN Connection: Fail to connect with some issues.
Dec  9 09:47:54 stop_nat_rules: apply the redirect_rules!
Dec  9 09:47:59 pppd[472]: Connection terminated.
Dec  9 09:47:59 pppd[472]: Modem hangup
Dec  9 09:48:09 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Dec  9 09:48:09 pppd[472]: Connect: ppp0 <--> eth0
Dec  9 09:48:13 pppd[472]: PAP authentication failed
Dec  9 09:48:13 pppd[472]: Connection terminated.
Dec  9 09:48:23 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Dec  9 09:48:23 pppd[472]: Connect: ppp0 <--> eth0
Dec  9 09:48:26 pppd[472]: PAP authentication failed
Dec  9 09:48:26 pppd[472]: Connection terminated.
Dec  9 09:48:36 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Dec  9 09:48:36 pppd[472]: Connect: ppp0 <--> eth0
Dec  9 09:48:39 pppd[472]: PAP authentication failed
Dec  9 09:48:39 pppd[472]: Connection terminated.
Dec  9 09:48:49 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Dec  9 09:48:49 pppd[472]: Connect: ppp0 <--> eth0
Dec  9 09:49:17 rc_service: httpds 417:notify_rc start_webs_update
Dec  9 09:49:19 pppd[472]: No response to PAP authenticate-requests
Dec  9 09:49:20 pppd[472]: Connection terminated.
Dec  9 09:49:30 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Dec  9 09:49:30 pppd[472]: Connect: ppp0 <--> eth0
Dec  9 09:49:54 rc_service: httpds 417:notify_rc start_webs_update
Dec  9 09:50:00 pppd[472]: PAP authentication succeeded
Dec  9 09:50:00 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized
Dec  9 09:50:01 pppd[472]: local  IP address 93.139.178.251
Dec  9 09:50:01 pppd[472]: remote IP address 172.29.252.89
Dec  9 09:50:01 rc_service: ip-up 1308:notify_rc start_firewall
Dec  9 09:50:02 miniupnpd[824]: shutting down MiniUPnPd
Dec  9 09:50:02 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec  9 09:50:02 rc_service: httpds 417:notify_rc reboot
Dec  9 09:50:02 rc_service: waitting "start_firewall" via ip-up ...
Dec  9 09:50:02 rc_service: ip-up 1308:notify_rc stop_upnp
Dec  9 09:50:03 miniupnpd[1352]: version 1.9 started
Dec  9 09:50:03 miniupnpd[1352]: HTTP listening on port 58937
Dec  9 09:50:03 miniupnpd[1352]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  9 09:50:04 pppd[472]: Connection terminated.
Dec  9 09:50:05 kernel: Attempt to kill tasklet from interrupt
Dec  9 09:50:05 stop_nat_rules: apply the redirect_rules!
Dec  9 09:50:06 iTunes: daemon is stoped
Dec  9 09:50:06 FTP Server: daemon is stoped
Dec  9 09:50:06 Samba Server: smb daemon is stoped
Dec  9 09:50:06 kernel: gro disabled
Aug  1 02:00:09 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem
Aug  1 02:00:09 kernel: Virtual kernel memory layout:
Aug  1 02:00:09 kernel:     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Aug  1 02:00:09 kernel:     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
Aug  1 02:00:09 kernel:     DMA     : 0xf7e00000 - 0xffe00000   ( 128 MB)
Aug  1 02:00:09 kernel:     vmalloc : 0x88800000 - 0xf0000000   (1656 MB)
Aug  1 02:00:09 kernel:     lowmem  : 0x80000000 - 0x88000000   ( 128 MB)
Aug  1 02:00:09 kernel:     modules : 0x7f000000 - 0x80000000   (  16 MB)
Aug  1 02:00:09 kernel:       .init : 0x80008000 - 0x80038000   ( 192 kB)
Aug  1 02:00:09 kernel:       .text : 0x80038000 - 0x803e4000   (3760 kB)
Aug  1 02:00:09 kernel:       .data : 0x803fc000 - 0x8041ef80   ( 140 kB)
Aug  1 02:00:10 kernel: Registering the dns_resolver key type
Aug  1 02:00:10 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2adf4004, fsr=0x1c06, pc=0x800ce0e0 lr=0x800c1154 ignored.
Aug  1 02:00:18 miniupnpd[457]: version 1.9 started
Aug  1 02:00:18 miniupnpd[457]: HTTP listening on port 36504
Aug  1 02:00:18 miniupnpd[457]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:18 pppd[466]: pppd 2.4.7 started by admin, uid 0
Aug  1 02:00:19 pppd[466]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug  1 02:00:19 pppd[466]: Connect: ppp0 <--> eth0
Aug  1 02:00:19 pppd[466]: PAP authentication succeeded
Aug  1 02:00:19 pppd[466]: peer from calling number 84:B5:9C:A4:4D:B7 authorized
Aug  1 02:00:19 pppd[466]: local  IP address 93.141.119.37
Aug  1 02:00:19 pppd[466]: remote IP address 172.29.252.59
Aug  1 02:00:20 rc_service: ip-up 509:notify_rc start_firewall
Aug  1 02:00:20 rc_service: ip-up 509:notify_rc stop_upnp
Aug  1 02:00:26 miniupnpd[457]: shutting down MiniUPnPd
Aug  1 02:00:26 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug  1 02:00:28 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug  1 02:00:29 kernel: nf_nat_rtsp v0.6.21 loading
Aug  1 02:00:29 miniupnpd[750]: version 1.9 started
Aug  1 02:00:29 miniupnpd[750]: HTTP listening on port 56881
Aug  1 02:00:29 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:29 rc_service: ip-up 509:notify_rc start_upnp
Aug  1 02:00:29 rc_service: waitting "stop_upnp" via ip-up ...
Aug  1 02:00:29 miniupnpd[750]: shutting down MiniUPnPd
Aug  1 02:00:31 miniupnpd[753]: version 1.9 started
Aug  1 02:00:31 miniupnpd[753]: HTTP listening on port 38145
Aug  1 02:00:31 miniupnpd[753]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:32 ntp: start NTP update
Dec  9 09:51:26 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec  9 09:51:26 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec  9 09:51:26 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec  9 09:51:26 rc_service: ntp 752:notify_rc restart_upnp
Dec  9 09:51:26 miniupnpd[753]: shutting down MiniUPnPd
Dec  9 09:51:27 miniupnpd[775]: version 1.9 started
Dec  9 09:51:27 miniupnpd[775]: HTTP listening on port 55434
Dec  9 09:51:27 miniupnpd[775]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  9 09:51:27 rc_service: ntp 752:notify_rc restart_diskmon
Dec  9 09:51:27 disk_monitor: Finish
Dec  9 09:51:28 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec  9 09:51:29 disk monitor: be idle
Dec  9 09:51:34 rc_service: zcip 801:notify_rc start_firewall
Dec  9 09:51:34 zcip client: configured 169.254.163.221
Dec  9 09:51:34 miniupnpd[775]: shutting down MiniUPnPd
Dec  9 09:51:34 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec  9 09:51:35 miniupnpd[829]: version 1.9 started
Dec  9 09:51:35 miniupnpd[829]: HTTP listening on port 52933
Dec  9 09:51:35 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Dec  9 10:00:30 disk_monitor: Got SIGALRM...
Dec  9 23:02:13 disk_monitor: Got SIGALRM...
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae35004, fsr=0x1c06, pc=0x2abb0be8 lr=0x2abb1c7c ignored.
Aug  1 02:00:18 miniupnpd[465]: HTTP listening on port 52007
Aug  1 02:00:18 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:00:19 pppd[472]: local  IP address 93.138.84.144
Aug  1 02:00:29 miniupnpd[465]: shutting down MiniUPnPd
Aug  1 02:00:29 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug  1 02:00:32 miniupnpd[750]: version 1.9 started
Aug  1 02:00:32 miniupnpd[750]: HTTP listening on port 42798
Aug  1 02:00:32 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:33 rc_service: waitting "stop_upnp" via ip-up ...
Aug  1 02:00:35 miniupnpd[755]: HTTP listening on port 48602
Dec 10 05:01:57 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 10 05:01:57 rc_service: ntp 753:notify_rc restart_upnp
Dec 10 05:01:57 miniupnpd[755]: shutting down MiniUPnPd
Dec 10 05:01:57 miniupnpd[772]: version 1.9 started
Dec 10 05:01:57 miniupnpd[772]: HTTP listening on port 55124
Dec 10 05:01:57 miniupnpd[772]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 10 05:01:57 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 10 05:01:58 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 10 05:01:58 rc_service: ntp 753:notify_rc restart_diskmon
Dec 10 05:01:58 disk_monitor: Finish
Dec 10 05:01:58 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 10 05:02:00 disk monitor: be idle
Dec 10 05:02:01 rc_service: zcip 788:notify_rc start_firewall
Dec 10 05:02:01 zcip client: configured 169.254.163.221
Dec 10 05:02:03 miniupnpd[772]: shutting down MiniUPnPd
Dec 10 05:02:03 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 10 05:02:04 miniupnpd[825]: version 1.9 started
Dec 10 05:02:04 miniupnpd[825]: HTTP listening on port 48968
Dec 10 05:02:04 miniupnpd[825]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:09 syslogd started: BusyBox v1.17.4
Aug  1 02:00:09 kernel: klogd started: BusyBox v1.17.4 (2017-06-20 10:31:01 CST)
Aug  1 02:00:09 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 PREEMPT Tue Jun 20 10:41:08 CST 2017
Aug  1 02:00:09 kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7f
Aug  1 02:00:09 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug  1 02:00:09 kernel: Machine: Northstar Prototype
Aug  1 02:00:09 kernel: Ignoring unrecognised tag 0x00000000
Aug  1 02:00:09 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug  1 02:00:11 kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Aug  1 02:00:11 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug  1 02:00:11 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem
Aug  1 02:00:11 kernel: Virtual kernel memory layout:
Aug  1 02:00:11 kernel:     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Aug  1 02:00:11 kernel:     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
Aug  1 02:00:11 kernel:     DMA     : 0xf7e00000 - 0xffe00000   ( 128 MB)
Aug  1 02:00:11 kernel:     vmalloc : 0x88800000 - 0xf0000000   (1656 MB)
Aug  1 02:00:11 kernel:     lowmem  : 0x80000000 - 0x88000000   ( 128 MB)
Aug  1 02:00:11 kernel:     modules : 0x7f000000 - 0x80000000   (  16 MB)
Aug  1 02:00:11 kernel:       .init : 0x80008000 - 0x80038000   ( 192 kB)
Aug  1 02:00:11 kernel:       .text : 0x80038000 - 0x803e4000   (3760 kB)
Aug  1 02:00:11 kernel:       .data : 0x803fc000 - 0x8041ef80   ( 140 kB)
Aug  1 02:00:11 kernel: Mount-cache hash table entries: 512
Aug  1 02:00:11 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB
Aug  1 02:00:11 kernel: ACP (Accelerator Coherence Port) enabled
Aug  1 02:00:11 kernel: bio: create slab  at 0
Aug  1 02:00:12 kernel: PCI: no core
Aug  1 02:00:12 kernel: PCI: Fixing up bus 0
Aug  1 02:00:12 kernel: PCI: Fixing up bus 1
Aug  1 02:00:12 kernel: PCI: scanning bus 0 !!!
Aug  1 02:00:12 kernel: VFS: Disk quotas dquot_6.5.2
Aug  1 02:00:12 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug  1 02:00:12 kernel: pflash: found no supported devices
Aug  1 02:00:12 kernel: bcmsflash: squash filesystem found at block 30
Aug  1 02:00:12 kernel: Creating 5 MTD partitions on "bcmsflash":
Aug  1 02:00:12 kernel: 0x000000000000-0x000000040000 : "boot"
Aug  1 02:00:12 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug  1 02:00:12 kernel: 0x0000001ef614-0x000000d30000 : "rootfs"
Aug  1 02:00:12 kernel: 0x000000d30000-0x000000ff0000 : "jffs2"
Aug  1 02:00:12 kernel: 0x000000ff0000-0x000001000000 : "nvram"
Aug  1 02:00:12 kernel: === PPTP init ===
Aug  1 02:00:12 kernel: Registering the dns_resolver key type
Aug  1 02:00:12 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Aug  1 02:00:12 kernel: ctf: module license 'Proprietary' taints kernel.
Aug  1 02:00:12 kernel: Disabling lock debugging due to kernel taint
Aug  1 02:00:12 kernel: et_module_init: passivemode set to 0x0
Aug  1 02:00:12 kernel: et_module_init: txworkq set to 0x1
Aug  1 02:00:12 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug  1 02:00:12 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8
Aug  1 02:00:12 kernel: et_module_init: et_rxlazy_framecnt set to 0x20
Aug  1 02:00:12 kernel: bcm_robo_enable_switch: EEE is disabled
Aug  1 02:00:12 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393)
Aug  1 02:00:12 kernel: wl_module_init: passivemode set to 0x0
Aug  1 02:00:12 kernel: wl_module_init: txworkq set to 0x1
Aug  1 02:00:12 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
Aug  1 02:00:12 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug  1 02:00:12 kernel: External imprecise Data abort at addr=0x2ae99000, fsr=0x1c06, pc=0x800c2aec lr=0x800ce1c8 ignored.
Aug  1 02:00:12 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug  1 02:00:12 kernel: [dump prev ops] from 87000000, local len(8179)
Aug  1 02:00:12 kernel: _ Reboot message ... _______________________________________________________
Aug  1 02:00:12 kernel: <0>Kernel panic - not syncing: Out of memory: system-wide panic_on_oom is enabled
Aug  1 02:00:12 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<802fec2c>] (panic+0x7c/0x1a4)
Aug  1 02:00:12 kernel: <4>[<802fec2c>] (panic+0x7c/0x1a4) from [<80091038>] (out_of_memory+0x2c8/0x328)
Aug  1 02:00:12 kernel: <4>[<80091038>] (out_of_memory+0x2c8/0x328) from [<800942c0>] (__alloc_pages_nodemask+0x66c/0x694)
Aug  1 02:00:12 kernel: <4>[<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) from [<80096000>] (__do_page_cache_readahead+0x140/0x2d0)
Aug  1 02:00:12 kernel: <4>[<80096000>] (__do_page_cache_readahead+0x140/0x2d0) from [<80096440>] (ra_submit+0x28/0x30)
Aug  1 02:00:12 kernel: <4>[<80096440>] (ra_submit+0x28/0x30) from [<8008e5d0>] (filemap_fault+0x42c/0x454)
Aug  1 02:00:12 kernel: <4>[<8008e5d0>] (filemap_fault+0x42c/0x454) from [<800a315c>] (__do_fault.clone.60+0x54/0x4c8)
Aug  1 02:00:12 kernel: <4>[<800a315c>] (__do_fault.clone.60+0x54/0x4c8) from [<800a67c4>] (handle_mm_fault+0x114/0x934)
Aug  1 02:00:12 kernel: <4>[<800a67c4>] (handle_mm_fault+0x114/0x934) from [<8003fd90>] (do_page_fault+0x178/0x1ec)
Aug  1 02:00:13 kernel: <4>[<8003fd90>] (do_page_fault+0x178/0x1ec) from [<80038298>] (do_PrefetchAbort+0x30/0x9c)
Aug  1 02:00:13 kernel: <4>[<80038298>] (do_PrefetchAbort+0x30/0x9c) from [<803bf2e0>] (ret_from_exception+0x0/0x10)
Aug  1 02:00:13 kernel: <4>Exception stack(0x8534ffb0 to 0x8534fff8)
Aug  1 02:00:13 kernel: <4>ffa0:                                     0000000e 00000008 7eae7c48 00000000
Aug  1 02:00:13 kernel: <4>ffc0: 7eae7c48 00000001 7eae7e94 000000b3 0000d1f0 0000ec14 7eae7e08 00000000
Aug  1 02:00:13 kernel: <4>ffe0: 2aef35b4 7eae7948 2ae9b254 0003be5c 00000010 ffffffff
Aug  1 02:00:13 kernel: <0>Rebooting in 3 seconds..osl_ctfpool_add: skb alloc of len 2272 failed
Aug  1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2272 failed
Aug  1 02:00:13 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed
Aug  1 02:00:13 kernel: <4>__alloc_pages_slowpath: 54706 callbacks suppressed
Aug  1 02:00:13 kernel: <4>watchdog: page allocation failure. order:0, mode:0x4020
Aug  1 02:00:13 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694)
Aug  1 02:00:13 kernel: <4>[<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0)
Aug  1 02:00:13 kernel: <4>[<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8)
Aug  1 02:00:13 kernel: <4>[<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104)
Aug  1 02:00:13 kernel: <4>[<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac)
Aug  1 02:00:13 kernel: <4>[<801fc860>] (osl_alloc_skb+0x50/0xac) from [<803c2cc0>] (osl_pktget+0x6c/0x170)
Aug  1 02:00:13 kernel: <4>[<803c2cc0>] (osl_pktget+0x6c/0x170) from [<803c1a34>] (_dma_rxfill+0x3c8/0x51c)
Aug  1 02:00:13 kernel: <4>[<803c1a34>] (_dma_rxfill+0x3c8/0x51c) from [<7f289fc0>] (wlc_bmac_recv+0x368/0x380 [wl])
Aug  1 02:00:13 kernel: <4>unwind: Index not found 7f289fc0
Aug  1 02:00:13 kernel: <4>Mem-info:
Aug  1 02:00:13 kernel: <4>DMA per-cpu:
Aug  1 02:00:13 kernel: <4>CPU    0: hi:   42, btch:   7 usd:   6
Aug  1 02:00:13 kernel: <4>active_anon:941 inactive_anon:953 isolated_anon:0
Aug  1 02:00:13 kernel: <4> active_file:0 inactive_file:0 isolated_file:32
Aug  1 02:00:13 kernel: <4> unevictable:0 dirty:0 writeback:0 unstable:0
Aug  1 02:00:13 kernel: <4> free:383 slab_reclaimable:82 slab_unreclaimable:25949
Aug  1 02:00:13 kernel: <4> mapped:16 shmem:172 pagetables:151 bounce:0
Aug  1 02:00:13 kernel: <4>DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:3764kB inactive_anon:3812kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):128kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:64kB shmem:688kB slab_reclaimable:328kB slab_unreclaimable:103796kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Aug  1 02:00:13 kernel: <4>lowmem_reserve[]: 0 0 0
Aug  1 02:00:13 kernel: <4>DMA: 111*4kB 52*8kB 28*16kB 1*32kB 1*64kB 1*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 1532kB
Aug  1 02:00:13 kernel: <4>185 total pagecache pages
Aug  1 02:00:13 kernel: <4>0 pages in swap cache
Aug  1 02:00:13 kernel: <4>Swap cache stats: add 0, delete 0, find 0/0
Aug  1 02:00:13 kernel: <4>Free swap  = 0kB
Aug  1 02:00:13 kernel: <4>Total swap = 0kB
Aug  1 02:00:13 kernel: <4>32768 pages of RAM
Aug  1 02:00:13 kernel: <4>571 free pages
Aug  1 02:00:13 kernel: <4>1352 reserved pages
Aug  1 02:00:13 kernel: <4>8182 slab pages
Aug  1 02:00:13 kernel: <4>266 pages shared
Aug  1 02:00:13 kernel: <4>0 pages swap cached
Aug  1 02:00:13 kernel: <4>SLUB: Unable to allocate memory on node -1 (gfp=0x20)
Aug  1 02:00:13 kernel: <4>  cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0
Aug  1 02:00:13 kernel: <4>  node 0: slabs: 3297, objs: 20972, free: 0
Aug  1 02:00:13 kernel: <4>[<803b28d0>] (__alloc_skb+0x54/0x104) from [<802179c0>] (pskb_copy+0x20/0x184)
Aug  1 02:00:13 kernel: <4>[<802179c0>] (pskb_copy+0x20/0x184) from [<801fcbc4>] (osl_pktdup+0x68/0x134)
Aug  1 02:00:13 kernel: <4>[<801fcbc4>] (osl_pktdup+0x68/0x134) from [<7f28edf4>] (wlc_recvdata_sendup+0x714/0x768 [wl])
Aug  1 02:00:13 kernel: <4>unwind: Index not found 7f28edf4
Aug  1 02:00:13 kernel: ____________________________________________________________________________
Aug  1 02:00:17 syslog: Generating SSL certificate...
Aug  1 02:00:18 disk monitor: be idle
Aug  1 02:00:18 jffs2: valid logs(1)
Aug  1 02:00:18 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1]
Aug  1 02:00:18 kernel: Attempt to kill tasklet from interrupt
Aug  1 02:00:18 miniupnpd[463]: HTTP listening on port 33441
Aug  1 02:00:19 pppd[472]: pppd 2.4.7 started by admin, uid 0
Aug  1 02:00:19 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:00:21 kernel: SCSI subsystem initialized
Aug  1 02:00:22 pppd[472]: PAP authentication failed
Aug  1 02:00:28 pppd[472]: Connection terminated.
Aug  1 02:00:28 pppd[472]: Modem hangup
Aug  1 02:00:39 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug  1 02:00:39 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:00:42 pppd[472]: PAP authentication failed
Aug  1 02:00:42 pppd[472]: Connection terminated.
Aug  1 02:00:43 rc_service: zcip 684:notify_rc start_firewall
Aug  1 02:00:43 zcip client: configured 169.254.163.221
Aug  1 02:00:44 miniupnpd[463]: shutting down MiniUPnPd
Aug  1 02:00:44 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)!
Aug  1 02:00:45 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug  1 02:00:45 kernel: nf_nat_rtsp v0.6.21 loading
Aug  1 02:00:45 miniupnpd[740]: version 1.9 started
Aug  1 02:00:45 miniupnpd[740]: HTTP listening on port 47434
Aug  1 02:00:45 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:47 stop_nat_rules: apply the redirect_rules!
Aug  1 02:00:52 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug  1 02:00:52 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:00:55 pppd[472]: PAP authentication failed
Aug  1 02:00:55 pppd[472]: Connection terminated.
Aug  1 02:01:05 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug  1 02:01:05 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:01:08 pppd[472]: PAP authentication failed
Aug  1 02:01:08 pppd[472]: Connection terminated.
Aug  1 02:01:18 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug  1 02:01:18 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:01:21 pppd[472]: PAP authentication failed
Aug  1 02:01:21 pppd[472]: Connection terminated.
Aug  1 02:01:31 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug  1 02:01:31 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:01:34 pppd[472]: PAP authentication failed
Aug  1 02:01:34 pppd[472]: Connection terminated.
Aug  1 02:01:44 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug  1 02:01:44 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:01:44 pppd[472]: PAP authentication succeeded
Aug  1 02:01:44 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized
Aug  1 02:01:45 pppd[472]: local  IP address 93.139.148.103
Aug  1 02:01:45 pppd[472]: remote IP address 172.29.252.89
Aug  1 02:01:45 rc_service: ip-up 819:notify_rc start_firewall
Aug  1 02:01:46 miniupnpd[740]: shutting down MiniUPnPd
Aug  1 02:01:46 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug  1 02:01:46 rc_service: ip-up 819:notify_rc stop_upnp
Aug  1 02:01:46 rc_service: waitting "start_firewall" via ip-up ...
Aug  1 02:01:47 miniupnpd[878]: version 1.9 started
Aug  1 02:01:47 miniupnpd[878]: HTTP listening on port 41732
Aug  1 02:01:47 miniupnpd[878]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:01:47 rc_service: ip-up 819:notify_rc start_upnp
Aug  1 02:01:47 rc_service: waitting "stop_upnp" via ip-up ...
Aug  1 02:01:47 miniupnpd[878]: shutting down MiniUPnPd
Aug  1 02:01:49 WAN Connection: WAN was restored.
Aug  1 02:01:49 miniupnpd[883]: version 1.9 started
Aug  1 02:01:49 miniupnpd[883]: HTTP listening on port 39510
Aug  1 02:01:49 miniupnpd[883]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:01:50 ntp: start NTP update
Dec 10 10:09:54 rc_service: ntp 880:notify_rc restart_upnp
Dec 10 10:09:54 miniupnpd[883]: shutting down MiniUPnPd
Dec 10 10:09:54 miniupnpd[892]: version 1.9 started
Dec 10 10:09:54 miniupnpd[892]: HTTP listening on port 34451
Dec 10 10:09:54 miniupnpd[892]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 10 10:09:55 rc_service: ntp 880:notify_rc restart_diskmon
Dec 10 10:09:55 disk_monitor: Finish
Dec 10 10:09:56 disk monitor: be idle
Dec 10 10:09:56 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 10 10:09:56 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 10 10:09:56 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 10 10:09:56 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 10 23:11:45 disk_monitor: Got SIGALRM...
Dec 11 00:00:45 disk_monitor: Got SIGALRM...
Dec 11 00:24:48 miniupnpd[892]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Dec 11 00:24:54 miniupnpd[892]: upnp_event_process_notify: connect(192.168.0.131:2869): Connection timed out
Aug  1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Aug  1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug  1 02:00:10 kernel: Memory: 125472k/125472k available, 5600k reserved, 0K highmem
Aug  1 02:00:10 kernel: Virtual kernel memory layout:
Aug  1 02:00:10 kernel:     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Aug  1 02:00:10 kernel:     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
Aug  1 02:00:10 kernel:     DMA     : 0xf7e00000 - 0xffe00000   ( 128 MB)
Aug  1 02:00:10 kernel:     vmalloc : 0x88800000 - 0xf0000000   (1656 MB)
Aug  1 02:00:10 kernel:     lowmem  : 0x80000000 - 0x88000000   ( 128 MB)
Aug  1 02:00:10 kernel:     modules : 0x7f000000 - 0x80000000   (  16 MB)
Aug  1 02:00:10 kernel:       .init : 0x80008000 - 0x80038000   ( 192 kB)
Aug  1 02:00:10 kernel:       .text : 0x80038000 - 0x803e4000   (3760 kB)
Aug  1 02:00:10 kernel:       .data : 0x803fc000 - 0x8041ef80   ( 140 kB)
Aug  1 02:00:10 kernel: Mount-cache hash table entries: 512
Aug  1 02:00:10 kernel: Found ST compatible serial flash with 256 64KB blocks; total size 16MB
Aug  1 02:00:10 kernel: ACP (Accelerator Coherence Port) enabled
Aug  1 02:00:10 kernel: bio: create slab  at 0
Aug  1 02:00:10 kernel: PCI: no core
Aug  1 02:00:10 kernel: PCI: Fixing up bus 0
Aug  1 02:00:10 kernel: PCI: Fixing up bus 1
Aug  1 02:00:10 kernel: PCI: scanning bus 0 !!!
Aug  1 02:00:10 kernel: VFS: Disk quotas dquot_6.5.2
Aug  1 02:00:10 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug  1 02:00:11 kernel: pflash: found no supported devices
Aug  1 02:00:11 kernel: bcmsflash: squash filesystem found at block 30
Aug  1 02:00:11 kernel: Creating 5 MTD partitions on "bcmsflash":
Aug  1 02:00:11 kernel: 0x000000000000-0x000000040000 : "boot"
Aug  1 02:00:11 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug  1 02:00:11 kernel: Registering the dns_resolver key type
Aug  1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Aug  1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel.
Aug  1 02:00:11 kernel: Disabling lock debugging due to kernel taint
Aug  1 02:00:11 kernel: et_module_init: passivemode set to 0x0
Aug  1 02:00:11 kernel: et_module_init: txworkq set to 0x1
Aug  1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug  1 02:00:11 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8
Aug  1 02:00:11 kernel: et_module_init: et_rxlazy_framecnt set to 0x20
Aug  1 02:00:11 kernel: bcm_robo_enable_switch: EEE is disabled
Aug  1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 9.10.178.27 (r584393)
Aug  1 02:00:11 kernel: wl_module_init: passivemode set to 0x0
Aug  1 02:00:11 kernel: wl_module_init: txworkq set to 0x1
Aug  1 02:00:11 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
Aug  1 02:00:11 kernel: eth1: Broadcom BCM43227 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae48004, fsr=0x1c06, pc=0x2abeac58 lr=0x17bd8 ignored.
Aug  1 02:00:11 kernel: eth2: Broadcom BCM43c8 802.11 Wireless Controller 9.10.178.27 (r584393)
Aug  1 02:00:11 kernel: _ Reboot message ... _______________________________________________________
Aug  1 02:00:11 stop_nat_rules: apply the redirect_rules!
Aug  1 02:00:11 kernel: ____________________________________________________________________________
Aug  1 02:00:11 WAN Connection: Fail to connect with some issues.
Aug  1 02:00:16 RT-AC1200G+: start httpd - SSL
Aug  1 02:00:17 disk monitor: be idle
Aug  1 02:00:17 jffs2: valid logs(1)
Aug  1 02:00:17 hour monitor: daemon is starting
Aug  1 02:00:17 hour monitor: daemon terminates
Aug  1 02:00:17 wan: mac clone: [wan0_hwaddr] == [d0:17:c2:1c:8a:a1]
Aug  1 02:00:17 kernel: Attempt to kill tasklet from interrupt
Aug  1 02:00:18 miniupnpd[457]: HTTP listening on port 57753
Aug  1 02:00:18 pppd[460]: pppd 2.4.7 started by admin, uid 0
Aug  1 02:00:18 pppd[460]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:00:18 pppd[460]: Connect: ppp0 <--> eth0
Aug  1 02:00:19 pppd[460]: PAP authentication succeeded
Aug  1 02:00:19 pppd[460]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug  1 02:00:19 syslog: module ledtrig-usbdev not found in modules.dep
Aug  1 02:00:19 syslog: module leds-usb not found in modules.dep
Aug  1 02:00:19 pppd[460]: local  IP address 93.138.42.188
Aug  1 02:00:19 pppd[460]: remote IP address 172.29.252.64
Aug  1 02:00:20 kernel: SCSI subsystem initialized
Aug  1 02:00:21 WAN Connection: WAN was restored.
Aug  1 02:00:28 miniupnpd[457]: shutting down MiniUPnPd
Aug  1 02:00:31 miniupnpd[750]: version 1.9 started
Aug  1 02:00:31 miniupnpd[750]: HTTP listening on port 46651
Aug  1 02:00:31 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:32 rc_service: waitting "stop_upnp" via ip-up ...
Aug  1 02:00:32 miniupnpd[750]: shutting down MiniUPnPd
Aug  1 02:00:35 miniupnpd[759]: version 1.9 started
Aug  1 02:00:35 miniupnpd[759]: HTTP listening on port 60062
Aug  1 02:00:35 miniupnpd[759]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 11 05:02:06 rc_service: ntp 757:notify_rc restart_upnp
Dec 11 05:02:06 miniupnpd[759]: shutting down MiniUPnPd
Dec 11 05:02:07 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 11 05:02:07 miniupnpd[774]: version 1.9 started
Dec 11 05:02:07 miniupnpd[774]: HTTP listening on port 35670
Dec 11 05:02:07 miniupnpd[774]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 11 05:02:07 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 11 05:02:07 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 11 05:02:07 rc_service: ntp 757:notify_rc restart_diskmon
Dec 11 05:02:07 disk_monitor: Finish
Dec 11 05:02:08 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 11 05:02:09 disk monitor: be idle
Dec 11 05:02:13 rc_service: zcip 801:notify_rc start_firewall
Dec 11 05:02:13 zcip client: configured 169.254.163.221
Dec 11 05:02:13 miniupnpd[774]: shutting down MiniUPnPd
Dec 11 05:02:13 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 11 05:02:14 miniupnpd[829]: version 1.9 started
Dec 11 05:02:14 miniupnpd[829]: HTTP listening on port 54166
Dec 11 05:02:14 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 11 14:31:10 rc_service: httpds 417:notify_rc start_webs_update
Dec 11 23:04:34 disk_monitor: Got SIGALRM...
Dec 12 05:00:03 kernel: Emergency Sync complete
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2acef004, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac963b0, fsr=0x1c06, pc=0x801d6758 lr=0x80208820 ignored.
Aug  1 02:00:18 miniupnpd[465]: version 1.9 started
Aug  1 02:00:18 miniupnpd[465]: HTTP listening on port 34836
Aug  1 02:00:18 miniupnpd[465]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:18 pppd[470]: pppd 2.4.7 started by admin, uid 0
Aug  1 02:00:19 pppd[470]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:00:19 pppd[470]: Connect: ppp0 <--> eth0
Aug  1 02:00:19 pppd[470]: PAP authentication succeeded
Aug  1 02:00:19 pppd[470]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug  1 02:00:19 pppd[470]: local  IP address 93.138.92.101
Aug  1 02:00:19 pppd[470]: remote IP address 172.29.252.64
Aug  1 02:00:19 rc_service: ip-up 498:notify_rc start_firewall
Aug  1 02:00:20 rc_service: ip-up 498:notify_rc stop_upnp
Aug  1 02:00:28 miniupnpd[465]: shutting down MiniUPnPd
Aug  1 02:00:31 miniupnpd[746]: version 1.9 started
Aug  1 02:00:31 miniupnpd[746]: HTTP listening on port 41075
Aug  1 02:00:31 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:32 rc_service: ip-up 498:notify_rc start_upnp
Aug  1 02:00:32 miniupnpd[746]: shutting down MiniUPnPd
Aug  1 02:00:34 miniupnpd[750]: version 1.9 started
Aug  1 02:00:34 miniupnpd[750]: HTTP listening on port 35645
Aug  1 02:00:34 miniupnpd[750]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 12 05:01:43 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 12 05:01:44 rc_service: ntp 749:notify_rc restart_upnp
Dec 12 05:01:44 miniupnpd[750]: shutting down MiniUPnPd
Dec 12 05:01:44 miniupnpd[770]: version 1.9 started
Dec 12 05:01:44 miniupnpd[770]: HTTP listening on port 37305
Dec 12 05:01:44 miniupnpd[770]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 12 05:01:45 rc_service: ntp 749:notify_rc restart_diskmon
Dec 12 05:01:45 disk_monitor: Finish
Dec 12 05:01:47 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 12 05:01:47 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 12 05:01:47 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 12 05:01:47 disk monitor: be idle
Dec 12 05:01:48 rc_service: zcip 793:notify_rc start_firewall
Dec 12 05:01:48 zcip client: configured 169.254.163.221
Dec 12 05:01:49 miniupnpd[770]: shutting down MiniUPnPd
Dec 12 05:01:49 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 12 05:01:50 miniupnpd[829]: version 1.9 started
Dec 12 05:01:50 miniupnpd[829]: HTTP listening on port 36053
Dec 12 05:01:50 miniupnpd[829]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 12 23:04:13 disk_monitor: Got SIGALRM...
Dec 12 23:34:16 rc_service: httpds 417:notify_rc start_webs_update
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae3f004, fsr=0x1c06, pc=0x2ab76a00 lr=0x2ab76e5c ignored.
Aug  1 02:00:18 miniupnpd[464]: version 1.9 started
Aug  1 02:00:18 miniupnpd[464]: HTTP listening on port 34013
Aug  1 02:00:18 miniupnpd[464]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:19 pppd[470]: local  IP address 93.138.17.169
Aug  1 02:00:20 rc_service: ip-up 502:notify_rc start_firewall
Aug  1 02:00:20 rc_service: ip-up 502:notify_rc stop_upnp
Aug  1 02:00:28 miniupnpd[464]: shutting down MiniUPnPd
Aug  1 02:00:32 miniupnpd[746]: version 1.9 started
Aug  1 02:00:32 miniupnpd[746]: HTTP listening on port 49039
Aug  1 02:00:32 miniupnpd[746]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:32 rc_service: ip-up 502:notify_rc start_upnp
Aug  1 02:00:33 miniupnpd[746]: shutting down MiniUPnPd
Aug  1 02:00:35 miniupnpd[751]: version 1.9 started
Aug  1 02:00:35 miniupnpd[751]: HTTP listening on port 37247
Aug  1 02:00:35 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 13 05:01:51 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 13 05:01:51 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 13 05:01:51 rc_service: ntp 749:notify_rc restart_upnp
Dec 13 05:01:51 miniupnpd[751]: shutting down MiniUPnPd
Dec 13 05:01:52 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 13 05:01:52 rc_service: ntp 749:notify_rc restart_diskmon
Dec 13 05:01:53 disk_monitor: Finish
Dec 13 05:01:53 miniupnpd[771]: version 1.9 started
Dec 13 05:01:53 miniupnpd[771]: HTTP listening on port 41168
Dec 13 05:01:53 miniupnpd[771]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 13 05:01:53 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 13 05:01:55 disk monitor: be idle
Dec 13 05:01:56 rc_service: zcip 778:notify_rc start_firewall
Dec 13 05:01:56 zcip client: configured 169.254.163.221
Dec 13 05:01:57 miniupnpd[771]: shutting down MiniUPnPd
Dec 13 05:01:57 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 13 05:02:00 miniupnpd[816]: version 1.9 started
Dec 13 05:02:00 miniupnpd[816]: HTTP listening on port 60177
Dec 13 05:02:00 miniupnpd[816]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 13 17:41:12 rc_service: httpds 417:notify_rc start_webs_update
Aug  1 02:00:10 kernel: pflash: found no supported devices
Aug  1 02:00:10 kernel: bcmsflash: squash filesystem found at block 30
Aug  1 02:00:10 kernel: Creating 5 MTD partitions on "bcmsflash":
Aug  1 02:00:10 kernel: 0x000000000000-0x000000040000 : "boot"
Aug  1 02:00:10 kernel: 0x000000040000-0x000000ff0000 : "linux"
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ade2004, fsr=0x1c06, pc=0x801d9b1c lr=0x7f190b78 ignored.
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2acc23b0, fsr=0x1c06, pc=0x7f190b38 lr=0x80208820 ignored.
Aug  1 02:00:11 kernel: <0>Kernel panic - not syncing: Out of memory: system-wide panic_on_oom is enabled
Aug  1 02:00:11 kernel: <4>[<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<802fec2c>] (panic+0x7c/0x1a4)
Aug  1 02:00:11 kernel: <4>[<802fec2c>] (panic+0x7c/0x1a4) from [<80091038>] (out_of_memory+0x2c8/0x328)
Aug  1 02:00:11 kernel: <4>[<80091038>] (out_of_memory+0x2c8/0x328) from [<800942c0>] (__alloc_pages_nodemask+0x66c/0x694)
Aug  1 02:00:11 kernel: <4>[<800942c0>] (__alloc_pages_nodemask+0x66c/0x694) from [<80096000>] (__do_page_cache_readahead+0x140/0x2d0)
Aug  1 02:00:11 kernel: <4>[<80096000>] (__do_page_cache_readahead+0x140/0x2d0) from [<80096440>] (ra_submit+0x28/0x30)
Aug  1 02:00:11 kernel: <4>[<80096440>] (ra_submit+0x28/0x30) from [<8008e5d0>] (filemap_fault+0x42c/0x454)
Aug  1 02:00:11 kernel: <4>[<8008e5d0>] (filemap_fault+0x42c/0x454) from [<800a315c>] (__do_fault.clone.60+0x54/0x4c8)
Aug  1 02:00:11 kernel: <4>[<800a315c>] (__do_fault.clone.60+0x54/0x4c8) from [<800a67c4>] (handle_mm_fault+0x114/0x934)
Aug  1 02:00:11 kernel: <4>[<800a67c4>] (handle_mm_fault+0x114/0x934) from [<8003fd90>] (do_page_fault+0x178/0x1ec)
Aug  1 02:00:11 kernel: <4>[<8003fd90>] (do_page_fault+0x178/0x1ec) from [<80038298>] (do_PrefetchAbort+0x30/0x9c)
Aug  1 02:00:11 kernel: <4>[<80038298>] (do_PrefetchAbort+0x30/0x9c) from [<803bf2e0>] (ret_from_exception+0x0/0x10)
Aug  1 02:00:11 kernel: <4>Exception stack(0x8534bfb0 to 0x8534bff8)
Aug  1 02:00:11 kernel: <4>bfa0:                                     0000000e 00000008 7ec48c48 00000000
Aug  1 02:00:11 kernel: <4>bfc0: 7ec48c48 00000001 7ec48e94 000000b3 0000d1f0 0000ec14 7ec48e08 00000000
Aug  1 02:00:11 kernel: <4>bfe0: 2aea65b4 7ec48948 2ae4e254 0003be5c 00000010 ffffffff
Aug  1 02:00:11 kernel: <0>Rebooting in 3 seconds..
Aug  1 02:00:18 syslog: Generating SSL certificate...
Aug  1 02:00:18 miniupnpd[465]: HTTP listening on port 56032
Aug  1 02:00:19 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:00:27 pppd[472]: Connection terminated.
Aug  1 02:00:27 pppd[472]: Modem hangup
Aug  1 02:00:38 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:00:38 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:00:40 pppd[472]: PAP authentication failed
Aug  1 02:00:40 pppd[472]: Connection terminated.
Aug  1 02:00:41 rc_service: zcip 684:notify_rc start_firewall
Aug  1 02:00:42 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)!
Aug  1 02:00:43 miniupnpd[740]: version 1.9 started
Aug  1 02:00:43 miniupnpd[740]: HTTP listening on port 48089
Aug  1 02:00:43 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:50 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:00:50 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:00:53 pppd[472]: PAP authentication failed
Aug  1 02:00:53 pppd[472]: Connection terminated.
Aug  1 02:01:03 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:01:03 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:01:06 pppd[472]: PAP authentication failed
Aug  1 02:01:06 pppd[472]: Connection terminated.
Aug  1 02:01:16 pppd[472]: Connected to 00:90:1a:a3:b7:70 via interface eth0
Aug  1 02:01:16 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:01:19 pppd[472]: PAP authentication failed
Aug  1 02:01:19 pppd[472]: Connection terminated.
Aug  1 02:01:29 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug  1 02:01:29 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:01:32 pppd[472]: PAP authentication failed
Aug  1 02:01:32 pppd[472]: Connection terminated.
Aug  1 02:01:42 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug  1 02:01:42 pppd[472]: Connect: ppp0 <--> eth0
Aug  1 02:01:43 pppd[472]: PAP authentication succeeded
Aug  1 02:01:43 pppd[472]: peer from calling number 00:90:1A:A3:B7:7C authorized
Aug  1 02:01:43 pppd[472]: local  IP address 93.139.188.27
Aug  1 02:01:43 pppd[472]: remote IP address 172.29.252.89
Aug  1 02:01:43 rc_service: ip-up 818:notify_rc start_firewall
Aug  1 02:01:44 miniupnpd[740]: shutting down MiniUPnPd
Aug  1 02:01:44 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug  1 02:01:44 rc_service: ip-up 818:notify_rc stop_upnp
Aug  1 02:01:44 rc_service: waitting "start_firewall" via ip-up ...
Aug  1 02:01:45 miniupnpd[869]: version 1.9 started
Aug  1 02:01:45 miniupnpd[869]: HTTP listening on port 56143
Aug  1 02:01:45 miniupnpd[869]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:01:45 rc_service: ip-up 818:notify_rc start_upnp
Aug  1 02:01:45 rc_service: waitting "stop_upnp" via ip-up ...
Aug  1 02:01:45 miniupnpd[869]: shutting down MiniUPnPd
Aug  1 02:01:47 miniupnpd[873]: version 1.9 started
Aug  1 02:01:47 miniupnpd[873]: HTTP listening on port 41917
Aug  1 02:01:47 miniupnpd[873]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:01:47 WAN Connection: WAN was restored.
Aug  1 02:01:48 ntp: start NTP update
Aug  1 02:01:48 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 13 18:12:49 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 13 18:12:49 rc_service: ntp 871:notify_rc restart_upnp
Dec 13 18:12:49 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 13 18:12:49 miniupnpd[873]: shutting down MiniUPnPd
Dec 13 18:12:49 miniupnpd[893]: version 1.9 started
Dec 13 18:12:49 miniupnpd[893]: HTTP listening on port 37135
Dec 13 18:12:49 miniupnpd[893]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 13 18:12:49 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 13 18:12:50 rc_service: ntp 871:notify_rc restart_diskmon
Dec 13 18:12:50 disk_monitor: Finish
Dec 13 18:12:51 disk monitor: be idle
Dec 13 19:00:58 disk_monitor: Got SIGALRM...
Dec 13 23:01:29 disk_monitor: Got SIGALRM...
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ae53004, fsr=0x1c06, pc=0x2ab40e08 lr=0x2ab40e5c ignored.
Aug  1 02:00:11 kernel: <4>Exception stack(0x851fdfb0 to 0x851fdff8)
Aug  1 02:00:11 kernel: <4>dfa0:                                     00001800 0009a21c 00001800 0009a21c
Aug  1 02:00:11 kernel: <4>dfc0: 0009a21c 000983cc 000000fa 00000067 0009a258 00001e38 00000500 00000000
Aug  1 02:00:11 kernel: <4>dfe0: 000984e4 7e8e0d68 0002c878 2ac8c370 80000010 ffffffff
Aug  1 02:00:18 miniupnpd[457]: HTTP listening on port 33819
Aug  1 02:00:18 pppd[472]: pppd 2.4.7 started by admin, uid 0
Aug  1 02:00:39 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug  1 02:00:44 miniupnpd[457]: shutting down MiniUPnPd
Aug  1 02:00:46 miniupnpd[740]: version 1.9 started
Aug  1 02:00:46 miniupnpd[740]: HTTP listening on port 50075
Aug  1 02:00:46 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:52 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug  1 02:01:05 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug  1 02:01:18 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug  1 02:01:31 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug  1 02:01:44 pppd[472]: Connected to 84:b5:9c:a4:4d:b7 via interface eth0
Aug  1 02:01:44 pppd[472]: peer from calling number 84:B5:9C:A4:4D:B7 authorized
Aug  1 02:01:45 pppd[472]: local  IP address 78.1.186.208
Aug  1 02:01:45 pppd[472]: remote IP address 172.29.252.59
Aug  1 02:01:45 rc_service: ip-up 820:notify_rc start_firewall
Aug  1 02:01:46 rc_service: ip-up 820:notify_rc stop_upnp
Aug  1 02:01:47 miniupnpd[867]: version 1.9 started
Aug  1 02:01:47 miniupnpd[867]: HTTP listening on port 46435
Aug  1 02:01:47 miniupnpd[867]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:01:47 rc_service: ip-up 820:notify_rc start_upnp
Aug  1 02:01:47 miniupnpd[867]: shutting down MiniUPnPd
Aug  1 02:01:48 WAN Connection: WAN was restored.
Aug  1 02:01:49 miniupnpd[872]: version 1.9 started
Aug  1 02:01:49 miniupnpd[872]: HTTP listening on port 44026
Aug  1 02:01:49 miniupnpd[872]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:01:49 ntp: start NTP update
Dec 14 01:18:19 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 14 01:18:19 rc_service: ntp 870:notify_rc restart_upnp
Dec 14 01:18:19 miniupnpd[872]: shutting down MiniUPnPd
Dec 14 01:18:19 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 14 01:18:19 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 14 01:18:19 miniupnpd[890]: version 1.9 started
Dec 14 01:18:19 miniupnpd[890]: HTTP listening on port 42889
Dec 14 01:18:19 miniupnpd[890]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 14 01:18:20 rc_service: ntp 870:notify_rc restart_diskmon
Dec 14 01:18:20 disk_monitor: Finish
Dec 14 01:18:20 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 14 01:18:21 disk monitor: be idle
Dec 14 02:00:27 disk_monitor: Got SIGALRM...
Dec 14 05:00:12 kernel: Emergency Sync complete
Dec 14 05:00:14 iTunes: daemon is stoped
Dec 14 05:00:14 FTP Server: daemon is stoped
Dec 14 05:00:14 Samba Server: smb daemon is stoped
Dec 14 05:00:14 kernel: gro disabled
Dec 14 05:00:14 disk_monitor: Finish
Dec 14 05:00:14 miniupnpd[890]: shutting down MiniUPnPd
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ad9b004, fsr=0x1c06, pc=0x800ce10c lr=0x800c1154 ignored.
Aug  1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1257)
Aug  1 02:00:11 kernel: <4>Emergency Sync complete
Aug  1 02:00:11 kernel: <4>gro disabled
Aug  1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt
Aug  1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state
Aug  1 02:00:11 kernel: <6>device eth0 left promiscuous mode
Aug  1 02:00:11 kernel: <6>device eth0 entered promiscuous mode
Aug  1 02:00:11 kernel: <6>br0: topology change detected, propagating
Aug  1 02:00:11 kernel: <6>br0: port 3(eth2) entering forwarding state
Aug  1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state
Aug  1 02:00:11 kernel: <6>device vlan1 left promiscuous mode
Aug  1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state
Aug  1 02:00:11 kernel: <6>device eth1 left promiscuous mode
Aug  1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state
Aug  1 02:00:11 kernel: <6>device eth2 left promiscuous mode
Aug  1 02:00:11 kernel: <6>br0: port 3(eth2) entering disabled state
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp
Aug  1 02:00:11 kernel: <0>Restarting system.
Aug  1 02:00:18 miniupnpd[461]: HTTP listening on port 60517
Aug  1 02:00:19 pppd[472]: PAP authentication succeeded
Aug  1 02:00:19 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug  1 02:00:20 pppd[472]: local  IP address 93.138.127.180
Aug  1 02:00:20 pppd[472]: remote IP address 172.29.252.64
Aug  1 02:00:20 rc_service: ip-up 501:notify_rc start_firewall
Aug  1 02:00:20 rc_service: ip-up 501:notify_rc stop_upnp
Aug  1 02:00:20 rc_service: waitting "start_firewall" via ip-up ...
Aug  1 02:00:28 miniupnpd[461]: shutting down MiniUPnPd
Aug  1 02:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug  1 02:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug  1 02:00:31 kernel: nf_nat_rtsp v0.6.21 loading
Aug  1 02:00:32 miniupnpd[747]: version 1.9 started
Aug  1 02:00:32 miniupnpd[747]: HTTP listening on port 55279
Aug  1 02:00:32 miniupnpd[747]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:33 rc_service: ip-up 501:notify_rc start_upnp
Aug  1 02:00:33 miniupnpd[747]: shutting down MiniUPnPd
Aug  1 02:00:36 miniupnpd[751]: version 1.9 started
Aug  1 02:00:36 miniupnpd[751]: HTTP listening on port 33504
Aug  1 02:00:36 miniupnpd[751]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 14 05:01:53 rc_service: ntp 749:notify_rc restart_upnp
Dec 14 05:01:53 miniupnpd[751]: shutting down MiniUPnPd
Dec 14 05:01:54 rc_service: ntp 749:notify_rc restart_diskmon
Dec 14 05:01:54 disk_monitor: Finish
Dec 14 05:01:56 miniupnpd[767]: version 1.9 started
Dec 14 05:01:56 miniupnpd[767]: HTTP listening on port 48911
Dec 14 05:01:56 miniupnpd[767]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 14 05:01:57 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 14 05:01:57 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 14 05:01:57 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 14 05:01:57 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 14 05:01:58 disk monitor: be idle
Dec 14 05:01:58 rc_service: zcip 779:notify_rc start_firewall
Dec 14 05:01:59 zcip client: configured 169.254.163.221
Dec 14 05:02:00 miniupnpd[767]: shutting down MiniUPnPd
Dec 14 05:02:00 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 14 05:02:04 miniupnpd[826]: version 1.9 started
Dec 14 05:02:04 miniupnpd[826]: HTTP listening on port 46443
Dec 14 05:02:04 miniupnpd[826]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 14 05:59:23 kernel:  active_file:438 inactive_file:687 isolated_file:0
Dec 14 05:59:23 kernel:  unevictable:0 dirty:0 writeback:0 unstable:0
Dec 14 05:59:23 kernel:  free:383 slab_reclaimable:266 slab_unreclaimable:24677
Dec 14 05:59:23 kernel:  mapped:824 shmem:188 pagetables:151 bounce:0
Dec 14 05:59:23 kernel: DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:6616kB inactive_anon:940kB active_file:1752kB inactive_file:2748kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:3296kB shmem:752kB slab_reclaimable:1064kB slab_unreclaimable:98708kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:195 all_unreclaimable? no
Dec 14 05:59:23 kernel: lowmem_reserve[]: 0 0 0
Dec 14 05:59:23 kernel: DMA: 1*4kB 1*8kB 1*16kB 1*32kB 1*64kB 1*128kB 1*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1532kB
Dec 14 05:59:23 kernel: 1313 total pagecache pages
Dec 14 05:59:23 kernel: 0 pages in swap cache
Dec 14 05:59:23 kernel: Swap cache stats: add 0, delete 0, find 0/0
Dec 14 05:59:23 kernel: Free swap  = 0kB
Dec 14 05:59:23 kernel: Total swap = 0kB
Dec 14 05:59:23 kernel: 32768 pages of RAM
Dec 14 05:59:23 kernel: 552 free pages
Dec 14 05:59:23 kernel: 1352 reserved pages
Dec 14 05:59:23 kernel: 9328 slab pages
Dec 14 05:59:23 kernel: 4621 pages shared
Dec 14 05:59:23 kernel: 0 pages swap cached
Dec 14 05:59:24 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20)
Dec 14 05:59:24 kernel:   cache: kmalloc-256, object size: 256, buffer size: 256, default order: 0, min order: 0
Dec 14 05:59:24 kernel:   node 0: slabs: 3375, objs: 54000, free: 0
Dec 14 05:59:24 kernel: acsd: page allocation failure. order:0, mode:0x20
Dec 14 05:59:24 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694)
Dec 14 05:59:24 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0)
Dec 14 05:59:24 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0970>] (kmem_cache_alloc+0x90/0x9c)
Dec 14 05:59:24 kernel: [<803b0970>] (kmem_cache_alloc+0x90/0x9c) from [<803b28ac>] (__alloc_skb+0x30/0x104)
Dec 14 05:59:24 kernel: [<803b28ac>] (__alloc_skb+0x30/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac)
Dec 14 05:59:24 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<803c2cc0>] (osl_pktget+0x6c/0x170)
Dec 14 05:59:24 kernel: [<803c2cc0>] (osl_pktget+0x6c/0x170) from [<7f29458c>] (wlc_hdr_proc+0x54/0x254 [wl])
Dec 14 05:59:24 kernel: unwind: Index not found 7f29458c
Dec 14 05:59:24 kernel: Mem-info:
Dec 14 05:59:24 kernel: DMA per-cpu:
Dec 14 05:59:24 kernel: CPU    0: hi:   42, btch:   7 usd:   6
Dec 14 05:59:24 kernel: active_anon:1654 inactive_anon:235 isolated_anon:0
Dec 14 05:59:24 kernel:  active_file:438 inactive_file:687 isolated_file:0
Dec 14 05:59:24 kernel:  unevictable:0 dirty:0 writeback:0 unstable:0
Dec 14 05:59:24 kernel:  free:383 slab_reclaimable:266 slab_unreclaimable:24677
Dec 14 05:59:24 kernel:  mapped:824 shmem:188 pagetables:151 bounce:0
Dec 14 05:59:24 kernel: DMA free:1532kB min:4096kB low:5120kB high:6144kB active_anon:6616kB inactive_anon:940kB active_file:1752kB inactive_file:2748kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:3296kB shmem:752kB slab_reclaimable:1064kB slab_unreclaimable:98708kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:195 all_unreclaimable? no
Dec 14 05:59:24 kernel: lowmem_reserve[]: 0 0 0
Dec 14 05:59:24 kernel: DMA: 1*4kB 1*8kB 1*16kB 1*32kB 1*64kB 1*128kB 1*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1532kB
Dec 14 05:59:24 kernel: 1313 total pagecache pages
Dec 14 05:59:24 kernel: 0 pages in swap cache
Dec 14 05:59:24 kernel: Swap cache stats: add 0, delete 0, find 0/0
Dec 14 05:59:24 kernel: Free swap  = 0kB
Dec 14 05:59:24 kernel: Total swap = 0kB
Dec 14 05:59:24 kernel: 32768 pages of RAM
Dec 14 05:59:24 kernel: 552 free pages
Dec 14 05:59:24 kernel: 1352 reserved pages
Dec 14 05:59:24 kernel: 9328 slab pages
Dec 14 05:59:24 kernel: 4621 pages shared
Dec 14 05:59:24 kernel: 0 pages swap cached
Dec 14 05:59:24 kernel: [<803b0970>] (kmem_cache_alloc+0x90/0x9c) from [<80216050>] (skb_clone+0x130/0x14c)
Dec 14 05:59:24 kernel: [<80216050>] (skb_clone+0x130/0x14c) from [<802e8ba0>] (deliver_clone+0x20/0x4c)
Dec 14 05:59:24 kernel: [<802e8ba0>] (deliver_clone+0x20/0x4c) from [<802e9e24>] (br_handle_frame_finish+0x230/0x23c)
Dec 14 05:59:24 kernel: [<802e9e24>] (br_handle_frame_finish+0x230/0x23c) from [<802e9fdc>] (br_handle_frame+0x1ac/0x24c)
Dec 14 05:59:24 kernel: [<802e9fdc>] (f len 2016 failed
Dec 14 05:59:24 kernel: osl_ctfpool_add: skb alloc of len 2016 failed
Dec 14 05:59:24 kernel: __alloc_pages_slowpath: 7870 callbacks suppressed
Dec 14 05:59:24 kernel: kworker/0:1: page allocation failure. order:0, mode:0x4020
Dec 14 05:59:24 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8)
Dec 14 05:59:24 kernel: [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104)
Dec 14 05:59:24 kernel: [<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac)
Dec 14 05:59:24 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<801fc918>] (osl_ctfpool_add+0x5c/0xf8)
Dec 14 05:59:24 kernel: [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) from [<7f018a14>] (et_tx_tasklet+0x304/0xbdc [et])
Dec 14 05:59:24 kernel: unwind: Index not found 7f018a14
Dec 14 05:59:24 kernel: CPU    0: hi:   42, btch:   7 usd:   7
Dec 14 05:59:24 kernel: active_anon:951 inactive_anon:938 isolated_anon:0
Dec 14 05:59:24 kernel:  active_file:397 inactive_file:599 isolated_file:0
Dec 14 05:59:24 kernel:  free:382 slab_reclaimable:150 slab_unreclaimable:24922
Dec 14 05:59:24 kernel:  mapped:711 shmem:188 pagetables:151 bounce:0
Dec 14 05:59:24 kernel: DMA free:1528kB min:4096kB low:5120kB high:6144kB active_anon:3804kB inactive_anon:3752kB active_file:1588kB inactive_file:2396kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:2844kB shmem:752kB slab_reclaimable:600kB slab_unreclaimable:99688kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Dec 14 05:59:24 kernel: DMA: 14*4kB 6*8kB 5*16kB 6*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1528kB
Dec 14 05:59:24 kernel: 1184 total pagecache pages
Dec 14 05:59:24 kernel: 9646 slab pages
Dec 14 05:59:24 kernel: 3844 pages shared
Dec 14 05:59:24 kernel:   cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0
Dec 14 05:59:24 kernel:   node 0: slabs: 2213, objs: 17466, free: 0
Dec 14 05:59:25 kernel: [<803b28d0>] (__alloc_skb+0x54/0x104) from [<801fc860>] (osl_alloc_skb+0x50/0xac)
Dec 14 05:59:25 kernel: [<801fc860>] (osl_alloc_skb+0x50/0xac) from [<801fc918>] (osl_ctfpool_add+0x5c/0xf8)
Dec 14 05:59:25 kernel: [<801fc918>] (osl_ctfpool_add+0x5c/0xf8) from [<7f018a14>] (et_tx_tasklet+0x304/0xbdc [et])
Dec 14 05:59:25 kernel: unwind: Index not found 7f018a14
Dec 14 05:59:25 kernel: Mem-info:
Dec 14 05:59:25 kernel: DMA per-cpu:
Dec 14 05:59:25 kernel: CPU    0: hi:   42, btch:   7 usd:   7
Dec 14 05:59:25 kernel: active_anon:951 inactive_anon:938 isolated_anon:0
Dec 14 05:59:25 kernel:  active_file:397 inactive_file:599 isolated_file:0
Dec 14 05:59:25 kernel:  unevictable:0 dirty:0 writeback:0 unstable:0
Dec 14 05:59:25 kernel:  free:382 slab_reclaimable:150 slab_unreclaimable:24922
Dec 14 05:59:25 kernel:  mapped:711 shmem:188 pagetables:151 bounce:0
Dec 14 05:59:25 kernel: DMA free:1528kB min:4096kB low:5120kB high:6144kB active_anon:3804kB inactive_anon:3752kB active_file:1588kB inactive_file:2396kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:130048kB mlocked:0kB dirty:0kB writeback:0kB mapped:2844kB shmem:752kB slab_reclaimable:600kB slab_unreclaimable:99688kB kernel_stack:464kB pagetables:604kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Dec 14 05:59:25 kernel: lowmem_reserve[]: 0 0 0
Dec 14 05:59:25 kernel: DMA: 14*4kB 6*8kB 5*16kB 6*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB = 1528kB
Dec 14 05:59:25 kernel: 1184 total pagecache pages
Dec 14 05:59:25 kernel: 0 pages in swap cache
Dec 14 05:59:25 kernel: Swap cache stats: add 0, delete 0, find 0/0
Dec 14 05:59:25 kernel: Free swap  = 0kB
Dec 14 05:59:25 kernel: Total swap = 0kB
Dec 14 05:59:25 kernel: 32768 pages of RAM
Dec 14 05:59:25 kernel: 552 free pages
Dec 14 05:59:25 kernel: 1352 reserved pages
Dec 14 05:59:25 kernel: 9646 slab pages
Dec 14 05:59:25 kernel: 3844 pages shared
Dec 14 05:59:25 kernel: 0 pages swap cached
Dec 14 05:59:25 kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x20)
Dec 14 05:59:25 kernel:   cache: kmalloc-4096, object size: 4096, buffer size: 4096, default order: 3, min order: 0
Dec 14 05:59:25 kernel:   node 0: slabs: 2213, objs: 17466, free: 0
Dec 14 05:59:25 kernel: osl_ctfpool_add: skb alloc of len 2016 failed
Dec 14 05:59:25 kernel: kworker/0:1: page allocation failure. order:0, mode:0x4020
Dec 14 05:59:25 kernel: [<8003e72c>] (unwind_backtrace+0x0/0xf8) from [<8009426c>] (__alloc_pages_nodemask+0x618/0x694)
Dec 14 05:59:25 kernel: [<8009426c>] (__alloc_pages_nodemask+0x618/0x694) from [<803b0854>] (__slab_alloc+0x724/0x7b0)
Dec 14 05:59:25 kernel: [<803b0854>] (__slab_alloc+0x724/0x7b0) from [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8)
Dec 14 05:59:25 kernel: [<803b0a58>] (__kmalloc_track_caller+0xdc/0xe8) from [<803b28d0>] (__alloc_skb+0x54/0x104)
Dec 14 05:59:26 kernel: osl_ctfpool_add: skb alloc of len 2016 failed
Dec 19 23:04:32 disk_monitor: Got SIGALRM...
Aug  1 02:00:10 kernel: 0x0000001ef614-0x000000d30000 : "rootfs"
Aug  1 02:00:10 kernel: 0x000000d30000-0x000000ff0000 : "jffs2"
Aug  1 02:00:10 kernel: 0x000000ff0000-0x000001000000 : "nvram"
Aug  1 02:00:10 kernel: === PPTP init ===
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x2ac81004, fsr=0x1c06, pc=0x2aacda40 lr=0x2aacde5c ignored.
Aug  1 02:00:11 kernel: [dump prev ops] from 87000000, local len(1547)
Aug  1 02:00:11 kernel: <4>Exception stack(0x8523ffb0 to 0x8523fff8)
Aug  1 02:00:11 kernel: <4>ffa0:                                     00000004 0008d206 0009a21f 00000073
Aug  1 02:00:11 kernel: <4>ffc0: 0009a21f 000983cc 0000010e 00000000 0009a256 00001e38 00000500 0000000a
Aug  1 02:00:11 kernel: <4>osl_ctfpool_add: skb alloc of len 2016 failed
Aug  1 02:00:11 kernel: <4>ffe0: 00098720 7eb6ed78 0002c958 2ac956e0 20000010 ffffffff
Aug  1 02:00:11 kernel: <0>Rebooting in 3 seconds..osl_ctfpool_add: skb alloc of len 2016 failed
Aug  1 02:00:18 miniupnpd[459]: version 1.9 started
Aug  1 02:00:18 miniupnpd[459]: HTTP listening on port 36767
Aug  1 02:00:18 miniupnpd[459]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:42 rc_service: zcip 684:notify_rc start_firewall
Aug  1 02:00:42 zcip client: configured 169.254.163.221
Aug  1 02:00:42 miniupnpd[459]: shutting down MiniUPnPd
Aug  1 02:00:44 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug  1 02:00:44 kernel: nf_nat_rtsp v0.6.21 loading
Aug  1 02:00:44 miniupnpd[740]: version 1.9 started
Aug  1 02:00:44 miniupnpd[740]: HTTP listening on port 52453
Aug  1 02:00:44 miniupnpd[740]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:52 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:01:05 pppd[472]: Connected to 00:90:1a:a3:b7:7c via interface eth0
Aug  1 02:01:07 pppd[472]: PAP authentication failed
Aug  1 02:01:18 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:01:31 pppd[472]: Connected to 00:90:1a:a5:00:86 via interface eth0
Aug  1 02:01:31 pppd[472]: PAP authentication succeeded
Aug  1 02:01:31 pppd[472]: peer from calling number 00:90:1A:A5:00:86 authorized
Aug  1 02:01:32 pppd[472]: local  IP address 93.138.54.92
Aug  1 02:01:32 pppd[472]: remote IP address 172.29.252.64
Aug  1 02:01:32 rc_service: ip-up 804:notify_rc start_firewall
Aug  1 02:01:33 miniupnpd[740]: shutting down MiniUPnPd
Aug  1 02:01:33 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Aug  1 02:01:33 rc_service: ip-up 804:notify_rc stop_upnp
Aug  1 02:01:33 rc_service: waitting "start_firewall" via ip-up ...
Aug  1 02:01:35 miniupnpd[851]: version 1.9 started
Aug  1 02:01:35 miniupnpd[851]: HTTP listening on port 34250
Aug  1 02:01:35 miniupnpd[851]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:01:35 miniupnpd[851]: shutting down MiniUPnPd
Aug  1 02:01:35 rc_service: ip-up 804:notify_rc start_upnp
Aug  1 02:01:36 rc_service: waitting "stop_upnp" via ip-up ...
Aug  1 02:01:36 WAN Connection: WAN was restored.
Aug  1 02:01:38 miniupnpd[856]: version 1.9 started
Aug  1 02:01:38 miniupnpd[856]: HTTP listening on port 36430
Aug  1 02:01:38 miniupnpd[856]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:01:38 ntp: start NTP update
Dec 19 23:16:17 rc_service: ntp 854:notify_rc restart_upnp
Dec 19 23:16:17 miniupnpd[856]: shutting down MiniUPnPd
Dec 19 23:16:17 miniupnpd[869]: version 1.9 started
Dec 19 23:16:17 miniupnpd[869]: HTTP listening on port 46870
Dec 19 23:16:17 miniupnpd[869]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 19 23:16:18 rc_service: ntp 854:notify_rc restart_diskmon
Dec 19 23:16:18 disk_monitor: Finish
Dec 19 23:16:18 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Dec 19 23:16:19 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Dec 19 23:16:19 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Dec 19 23:16:19 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Dec 19 23:16:19 disk monitor: be idle
vacs je online   Reply With Quote
Staro 19.12.2017., 23:35   #2
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
Asus RT-AC1200G+ random reboot
pozdrav,
imam navedeni ruter u kombinaciji sa ht-ovim speedportom (ona ac wifi verzija), asus je na zadnjem sluzbenom fw i zadnjih 3 mjeseca je normalno radio no sad se smrzne sam od sebe i nakon par minuta reboota
ovo pise u logu pa ako ga netko moze desifrirati, asus support mi rekao da nosim na servis ako sumnjam da je neispravan i ne znam sto je sa ovim august 1 datumom, clearao sam jutros log tako da je ovo od zadnjeg crasha
https://drive.google.com/open?id=1eY...Ybdw1MV4R-XOwW
btw cim krenem tipkati reply pise mi u address baru "not secure" i ako pejstam log direkt ovdje nece mi poslati temu
Staro 20.12.2017., 00:22   #3
skalar
skalar's Avatar
Datum registracije: Apr 2015
Postovi: 1,699
Probaj :
vratiti na tvorničke postavke -- rebotat otraga na gumbu -- ponovno konfigurirat,
ako to ne pomogne probaj sa "ASUS Firmware Restoration toolom" učitati stariji firmware,
čini mi se da zbog ne baš sjajnih hadrwerskih komponenti tog rotera dolazi do raspada firmwarea
nakon nekog vremena pa bi ovo moglo pomoći samo moraš očistiti memoriju poslje nadogradnje
da slučajno nešto ne ostane od starog firmwarea.
Staro 20.12.2017., 00:57   #4
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
Ok, tnx...ici cu odmah restoration napraviti...za ocistiti memoriju treba nesto posebno ili ce isti tool sve odraditi?
Staro 20.12.2017., 04:04   #5
skalar
skalar's Avatar
Postovi: 1,699
trebao bi isti tool sve odraditi,ali nije na odmet hard reset otraga iza toga.
samo ga pusti prije da odradi svoje i da se digne ne u pola posla reset
Staro 20.12.2017., 07:22   #6
jurbAs
jurbAs's Avatar
Postovi: 2,583
isti problem imam od nedavno nisam se stigao pozabavit problemom ali zadnji put kad sam imao taj problem samo sam vratio FW jednu verziju u nazad.
Staro 20.12.2017., 13:29   #7
Postovi: 23,510
@jurbAs
Ako ti nije teško napiši precizno HW i SW (FW) verziju na kojoj ti radi stabilno.
Staro 20.12.2017., 18:14   #8
jurbAs
jurbAs's Avatar
Postovi: 2,583
Pozdrav,
Danas sam uhvatio vremena da malo istrazim svoj problem i nasao sam ovo
LINK
Sve je detaljno objasnjeno ne mogu naći tu verziju FW koji oni spominju da ju probam staviti gore.... 3.0.0.4.382_15525 ako neko nađe download neka okači neki link kako skinuti pa da probam.
trenutno je gore na ruteru Firmware Version:3.0.0.4.380_7743 koju imam zadnjih par mj i radilo je super do prije mozda 2 tjedna žena mi je prijavila da net stalno puca i da nesto nestima. Onda se i meni par puta dogodilo. Tako da ne znam u čemu je stvar sa problemom.
Prije toga sam isto imao taj problem ali sa ovim FW mi se problem rijesio koji je gore i sad sa njime imam ponovo isti problem... Nije mi jasno u čemu je problem....
Staro 20.12.2017., 20:26   #9
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
Autor jurbAs Pregled postova
http://drivers.softpedia.com/get/Rou...82-15525.shtml
idem probati
edit: ne stavljaj ovaj, UI je sav pobrkan, s razlogom je povucena ta verzija
Zadnje izmijenjeno od: vacs. 20.12.2017. u 20:41.
Staro 21.12.2017., 08:54   #10
skalar
skalar's Avatar
Postovi: 1,699
Pozdrav,
LINK
Asus RT-AC1200G+ ima određene probleme,zbog toga bi bilo pametno ako se pronađe firmware s kojim radi zadovoljavajuće i ostati na tom firmwareu
ne se igrati ,jer očito jedan te isti firmware "ne sjeda" uvijek isto.
ono što bi ja napravio ako si siguran da nije nešto otišlo harwerski ili da se ne pregrijava(što nije rijedak slučaj), vratiti na tvorničke postavke -
sa "ASUS Firmware Restoration toolom" učitati firmware za koji sam siguran da zadovoljavajuće radi - kad se router digne hard reset na gumb -
i onda opet vratiti na tvorničke postavke, sve to zbog toga da budeš 100% siguran da se firmware instalirao na čisto,odnosno da je nvram čist.
Staro 21.12.2017., 09:33   #11
djdado16
Datum registracije: Feb 2015
Lokacija: Slavonija
Postovi: 51
Stari moj imas iste probleme ko i ja(Drugaciji su nam logovi)...isti mi datum pokazuje, al meni to radi i na speedportu....i pokusavam otklonit vec danima, jel si ti isto na optici i koji grad?...ja brijem da nije problem do nas
Probaj sam ostavit speedport ukljucen i preko njega ici, i ak ti se i tamo freeza javi, onda imamo identicne probleme
Zadnje izmijenjeno od: djdado16. 21.12.2017. u 09:54.
djdado16 je offline   Reply With Quote
Staro 21.12.2017., 10:32   #12
jurbAs
jurbAs's Avatar
Postovi: 2,583
Ja sam na iskon optici u Osijeku moguće da je do njih. Ne bi me čudilo.
Poslano sa mog LG-H815 koristeći Tapatalk
Zadnje izmijenjeno od: Nikky. 21.12.2017. u 13:02.
Staro 21.12.2017., 11:18   #13
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
ja sam na vdslu u slunju...idem jos jednom factory i restoration pa ako opet bude smrzavalo cu makuti njega i probati samo sa speedportom
Staro 21.12.2017., 11:40   #14
djdado16
Lokacija: Slavonija
Postovi: 51
Moze ae probajte...ja sam takoder bio disable-o upnp, rucno dodijelio ip adrese itd, nista ne pomaze, ponekad potraje veza do 20h al opet se zablesira i restartira... Kad primjetite da nema veze brzo idite na 192.168.1.1(ako vam je tak namjesteno) i vidite jel imate istu gresku ko i ja, evo slika:
Staro 21.12.2017., 11:49   #15
skalar
skalar's Avatar
Postovi: 1,699
to se kod mene pojavljuje nakon nadogradnje firmwarea prilikom restarta routera i to samo onda,sve mi se čini da ti je problem taj router,ako ćeš ići na servis s njime i ponude ti zamjenu,mislim da imaš u istom cijenovnom razredu tp-linkov ac1200 gigabitni router mislim da bi s njim imao više sreće.
Staro 21.12.2017., 12:08   #16
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
meni kad se zablokira samo pise da nema interneta, ne mogu otvoriti 192.168.0.1, nakon 5 min radi normalno
sad sam napravio factory, restoration, factory...ako opet bude smrzavalo probat cu speedport da budem siguran da je do asusa, ako ispada da asus stvaro problem idem na reklamaciju
ima li tko preporuku za neki drugi? uzeo bi isto asusa jer su mi ostali AP-ovi rt-n12d1, stoga da mora biti iz linksa da mogu ostaviti ovaj i nadoplatiti za drugi
https://www.links.hr/hr/mrezna-oprem...0&pageNumber=1
Staro 21.12.2017., 14:17   #17
Postovi: 23,510
Hm, ako baš mora iz Links - a možda prvi slijedeći Asus RT-AC58U > https://www.links.hr/hr/wireless-rou...icni-053524170
Jedini pristojni review > https://www.digitalcitizen.life/revi...-ac1300-router
WikiDevi > https://wikidevi.com/wiki/ASUS_RT-AC58U
Našao sam da ga Merlin ne podržava (niti će) jer je Qualcom Atheros platforma.
Po sličnoj cijeni je ASUS RT-N66U > https://www.links.hr/hr/wireless-rou...icni-053524075
ako se ne varam njega podržava Merlin (treba provjeriti).
Slijedeći korak bi bio (šta je spomenio kolega skalar) je TP-LINK Archer C5 AC1200 > http://www.tp-link.fi/products/detai...Archer-C5.html
trebalo bi naći noviju V2 verziju baziranu na Broadcom platformi, info i review:
https://wikidevi.com/wiki/TP-LINK_Archer_C5_v2.x
https://www.smallnetbuilder.com/wire...c5-v2-reviewed
That's my 5 cents
Staro 21.12.2017., 15:25   #18
skalar
skalar's Avatar
Postovi: 1,699
popis routera koje merlin podržava :
Asuswrt-Merlin
Asus:
RT-AC86U
RT-N66U
RT-AC66U_B1
RT-AC1900
RT-AC87U
RT-AC5300
RT-AC3200
RT-AC3100
RT-AC88U - provjereno osim par dodatnih đinđi tipa prikaz temperature,on/off lampica-uglavnom prati orginal fw
RT-AC68U
RT-AC66U - provjereno poboljšava router u odnosu na orginal fw
RT-AC56U
XWRT-VORTEX(clon merlina)
Netgear r7000 provjereno omogučuje jednostavnost asusovog konfiguriranja na netgearu,negativno treba se igrati sa wifi postavkama(5-10 min posla)
Linksys EA6900
HUAWEI WS880
Zadnje izmijenjeno od: skalar. 21.12.2017. u 15:49.
Staro 21.12.2017., 15:31   #19
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
znaci preporuka je za ruter koji podrzava merlin pa njega staviti umjesto ofw?
inace prije ovoga sam imao ac55u, isto smece, 5ghz wifi cesce ne radio nego radio
Staro 21.12.2017., 16:18   #20
skalar
skalar's Avatar
Postovi: 1,699
popis svati kao popis dovoljno jakih routera na kojima se u pravilu neće desiti problemi kao na RT-AC1200G+ zbog hardwerskih slabosti,
sad dali treba koristiti merlin ili ne to je već individualna stvar, ono kaj ti ja mogu reći što je skuplji router to mu manje merlin treba,
osim toga osigurava ti i u budučnosti podršku sa novim firmwareovima.
Staro 21.12.2017., 16:55   #21
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
Samo pripazi odnosno prosurfaj prije kupnje routera po forumima, koji se routeri griju i koji su zbog toga nestabilni. Naime imao sam AC87U koje je bio fantastičan i brz router ali se je jako grijao i dok je došao na visoku temperaturu, resetirao se odnosno pucala je veza. To je bilo posebno izraženo na 5GHz. Kad sam mu stavio ispod hladnjak za notebook, radio je fantastično. Jednostavno greška Asusa u izradi uređaja.
To sam napomenuo zato jer vidim da je gore naveden kao uređaj koji se preporuča, pa da ne naletiš na minu
Staro 21.12.2017., 17:23   #22
skalar
skalar's Avatar
Postovi: 1,699
da se krivo ne svatimo lista nije lista preporuka ,kao ono moram kupiti jedan od njih od navedenih routera 3 sam imao u rukama i o njima mogu pričati,nijedan me nije iznevjerio s jedne strane s druge strane sa svakim je bilo određenih hrvanja ovisno od firmwarea do firmwarea,ono što je pozitiva pogotovo za početnika kod asusa -je jednostavnost konfiguracije,merlinov firmware treba svatiti kao dobru dodatnu mogučnost kontabilan je sa orginal firmwarovima.znaći možeš ga staviti i ako ti nevalja nakon 5 min vratiti na orginal bez potrebe za ponovnim konfiguriranjem,naravno da kad se kupuje da bi bilo dobro provjeriti iskustva prije same kupnje jer na kraju krajeva
nekošta to malo novaca,a i kupuje se na duži rok u pravilu.
Staro 21.12.2017., 20:21   #23
djdado16
Lokacija: Slavonija
Postovi: 51
Kolege javite da li radi to isto i na speedportu....Meni bi bilo lakse da nisam jedini haha..
Staro 22.12.2017., 10:02   #24
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
danas cu vratiti speedport pa javim, asusu nije pomoglo nista od navedenog prije, izdrzao je 11h i nakon toga svaka 2 do 3 sata crash
hvala Nikky i Skalar na savjetima, ako mi odobre reklamaciju ici cu na AC68U i gotovo
Staro 22.12.2017., 14:16   #25
djdado16
Lokacija: Slavonija
Postovi: 51
dd
Okej, kod mene radi za sad stabilno...iskljucio upnp, dodijelio sam ip adrese, preko onog dhcp servera, iskljucio ipv6 na računalu, te network discovery....(ak vam išta pomaže kod mene je zadnji firmware od asusa)
trenutna slika
Zadnje izmijenjeno od: djdado16. 22.12.2017. u 14:22.
Staro 23.12.2017., 11:11   #26
jurbAs
jurbAs's Avatar
Postovi: 2,583
dosao update 3.0.0.4.382_18991 ja sam ga stavio pa cemo viditi.
Staro 23.12.2017., 11:44   #27
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
ajde javi, ja svoj spremio u kutiju za reklmaciju pa da sam ne riktam sve ispocetka
@djdado16
na speedportu sam sad vec 25h, nije nijednom pukla veza osim normalan reconnect na 24. satu
Staro 23.12.2017., 12:24   #28
Postovi: 23,510
Na kraju će ispast da je ovaj 1200G+ samo za AP funkciju, a za sve drugo slab / faličan.
Zadnje izmijenjeno od: Nikky. 23.12.2017. u 13:04.
Staro 23.12.2017., 12:44   #29
djdado16
Lokacija: Slavonija
Postovi: 51
kod mene riješen problem, sve radi......s7 edge je crashao router
Staro 23.12.2017., 12:54   #30
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
Autor djdado16 Pregled postova
ja sam bio sumnjao na ps4 jer mi lan port malo defektan ali i preko wifi mi isto crashalo...da li imas ideju kako ustanoviti koji je uredaj problematican bez da svaki dan drzim jedan po jedan iskljucen? onda s druge strane tri mjeseca mi je radio normalno a u ova tri mjeseca nisam nijedan novi uredaj kupio
edit: sad se sjetio da mi je prekjucer ujutro crashalo dok su bili samo mobiteli na mrezi
