#33 |
Datum registracije: Aug 2011
Postovi: 533
#35 |
Datum registracije: Feb 2015
Postovi: 218
Novi 376.09 - WHQL http://www.nvidia.com/download/drive...x/111830/en-us Game Ready Drivers provide the best possible gaming experience for all major new releases, including Virtual Reality games. Prior to a new title launching, our driver team is working up until the last minute to ensure every performance tweak and bug fix is included for the best gameplay on day-1. Game Ready Provides the optimal experience for Watch Dogs 2 |
#36 |
Postovi: 218
GeForce 376.19 WHQL driver download http://www.guru3d.com/files-details/...-download.html Game Ready Provides the optimal VR experience for Oculus Touch launch titles We have a discussion thread open on this driver right here. Application SLI Profiles No SLI profiles were added with this version. Windows 10 Fixed Issues [SLI] No Man's Sky with Foundation Update 1.10 shows severe texture corruption if SLI enabled. Notebook G-SYNC flickering. Notebook G-SYNC pendulum demo issue. 3D Vision Profiles: Added or updated the following 3DV profiles: DeadRising 4 - added 3DV profile Mars 2030 - added 3DV profile Serious Sam - added 3DV profile SuperHot - added 3DV profile 3D Compatibility Mode Profiles: No compatibility mode profiles were added with this version |
#37 |
Postovi: 1,441
samo da javim da mi zadnji 378.49 WHQL baca error 43; https://www.drivereasy.com/knowledge...rted-problems/ stari driveri rade... |
#38 |
Postovi: 1,193
Koga zanima 376.80 Vulkan developer beta driveri - ljubitelji Dooma..... http://www.guru3d.com/files-details/...-download.html |
#40 |
Postovi: 1,441
sa 378.66 opet dobivam error 43 “Windows has stopped this device because it has reported problems. (Code 43)” sad se vec mislim da je prob kod mene jer drugi ocito nemaju ovaj problem. Zanimljivo kako grafa radi najnormalnije sa svim prijasnjim driverima osim ova 2 najnovija... |
#41 |
#42 |
Aiden Fierce
Datum registracije: Jan 2016
Postovi: 1,171
![]() the Bariarnil
#44 |
Datum registracije: Aug 2010
Postovi: 239
Isto tako, s predzadnjih 378.49. Nisam siguran da CPU ima veze s ovim, jedino što sam od prethodnog testa mijenjao su GPU driveri. Evo screen od friškog testa - nešto je niši rez od onog prvog što sam vrtio. Svakako poboljšanja s novim driverima ima. BTW ne šljaka mi baš postanje slika pa moram ovako u linku. https://postimg.org/image/v2vrpbtb9 - 378.66 https://postimg.org/image/7gq1mknsn/ - 378.49 Zadnje izmijenjeno od: realmadrid. 16.02.2017. u 20:14. Razlog: Screen novog testa |
#45 |
Postovi: 239
Skužio sam u čem je fora bila - inače uvijek u Nvidia control panelu imam postavljen V-Sync na Fast jer tako nemam coil whine kad FPS ode u neke lude cifre (npr. u meniju). Nakon što sam napravio clean install drivera opcija vratila na default odnosno Use the 3D application setting i odatle tih 5-7 FPS-ova viška u benchmarku. |
#46 |
Postovi: 218
#47 |
Postovi: 218
#48 |
Lokacija: Grobnik - Rijeka
Postovi: 3,254
Ajde veceras cu probat. Mozda vise nece biti rušenja u cutscena iz Mafie 3. Sent from my iPhone using Tapatalk |
#49 |
Postovi: 218
#51 |
Lokacija: Sv.Nedelja
Postovi: 5,824
Pozdrav, jučer (vlc, mpc) pokrenem film u FHD na 55" telki u extended modu, naravno primary je monitor, slika (video stutter) zatrzava, prebacim samo da mi prikazuje sliku na telki, radi sve bez greške.. Ak stavim da je primary na tv onda je čak ok.. Jel primjetio taj problem ko od vas, a da imate komp povezan s telkom putem hdmia? Ovaj problem je raširen diljem neta i očito pogađa redovno korisnike nvidia kartice.. Onaj ko ima izvježbano oko primjetit će taj iritantni problem, dok postoji mogućnost da pojedinci neće ni primjetit to.. |
#52 |
Lokacija: Rijeka / Grobnik
Postovi: 4,247
jesi probo namjestit monitor na osvjezenje videa? daklem ak je video 23.9xx fps, namjestis ga u playeru na toliko. ja to uvjek radim u MPHC, akli i onda znam imat trzaje. jednostavno mi se neda po tome drkeljat vise. ima puno rjesenja, drugih codeca itd. samo neki mi iskljuce OSD pa me to nervira... i ukljuci da ti vrti preko grafe, ako nisi... edit: il sam ja nest kriv shvatio pa ti je ovaj problem tek na ovom novom driveru? |
#53 | |
Sent from Mobara |
#54 |
Postovi: 5,824
Moguće.. 1709 16299.64 tu verziju imam.. Probao tri prethodna drivera od nvidije i ništa.. Kollko se sjećam, taj problem nisam imao prije reinstalacije winsa, doduše bila je starija verzija OSa.. A ček, jel to konkretno neki update zafrkava ili isključivo ta verzija winsa? Kak je kod vas ostalih? Izgleda da ovaj put nvidia nije kriva ![]() @geronimo, ak je do winsa, onda nema drugog rješenja osim na ić na nižu verziju ili čekat da se ekipa pobuni i prijavi ovaj issue, mada sumnjam da će bit kaj od toga.. |
#55 |
Moš se karat. Ili 1703 ili MPC HC + madVR + Smooth motion za filmove. VLCu otpjevaj pjesmu od neprežaljene Đurđice Barlović "Zaboravi me Gorane". Ja to napravio pred koji dan, nađi moje postove u Windows 10 info temi i Koji media player kupiti. Imaš linkove i tutorial. I kao što rečem, radi. Sent from Mobara |
#56 |
Postovi: 8,360
I da stvar bude bolja, Microsoft je iz Fall Creators Update odlučil maknuti HEVC dekoder, samo da bi ga nudili kao zasebnu aplikaciju. ![]() |
#58 |
Evo mali heads-up kako ne instalirati sav crapware/bloatware/spyware iz nVidia drivera: 1. Skinuti najnoviji driver za karticu/OS sa nVidia stranice 2. Skinutom fajlu promjeniti ekstenziju iz .exe u .7z 3. Raspakirati drivere u folder 4. Izbrisati sve iz tog foldera sve osim prikazanog na slici ispod 5. Instalirati klikom na setup.exe ![]() Sebi sam ostavio Fiziks i HD audio jer to koristim, ali ako vam ne treba, možete i to maknuti. |
