Staro 21.11.2017., 14:41   #1891
Dottore
Dottore's Avatar
Postovi: 7,661
Autor syss Pregled postova
ma da ga ne bi sad sa docka skidao i gasio sve
prek firme je to išlo, nikakvi bakrači.
Pa reci da si spotakao na kabel.
Ne pratiš, to mi je za pridošlicu
Znači T440/p?
Sent from my SM-950U
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 21.11.2017., 18:46   #1892
calypso
calypso's Avatar
Datum registracije: Oct 2002
Lokacija: Zagreb/Rijeka
Postovi: 1,983
Ahaaaa, zo... Nisam imo pojma, al dobro, realno, nisam jos ni radio puno sa x40 serijom iako mi stize jedan T440p sutra...
GMKTec K8Plus
2x EIZO EV2336WFS3-BK
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4-2666
intel UHD 620
13.3" FullHD IPS Touchscreen
Staro 22.11.2017., 10:24   #1893
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Autor Dottore Pregled postova
Znači T440/p?
Yep, P
Autor calypso Pregled postova
Najs, ostaje kod tebe ili?
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Zadnje izmijenjeno od: ThePornstar. 22.11.2017. u 10:36.
Staro 22.11.2017., 10:28   #1894
calypso
calypso's Avatar
Postovi: 1,983
Ma jok, ide u prodaju... Sta ce mi jos T440p pored W530 i X220...
GMKTec K8Plus
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4-2666
intel UHD 620
Staro 22.11.2017., 11:11   #1895
cdanijel
Kakva je to 57++ oznaka? Za takvu jos nisam cuo. 55++ je oznaka za 9cell za T410/420.
To ti je ona velika 9cell za T, L i W seriju do x40 na dalje...
Staro 22.11.2017., 22:38   #1896
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,059
Iako se ovo tiče svih računala sa Intelovim procesorima, ipak ću postati ovdje pa da si možete provjeriti firmware vaših ThinkPada.
Dakle, 20.11.2017. je Intel napokon priznao sigurnosni propust u svojim procesorima vezan za Intel ME tehnologiju izdavanjem zakrpe i alata za provjeru sistema.
Prvo, ovdje imate popis Lenovo računala i laptopa (pa i ThinkPada) koji su pogođeni problemom, a o Intel ME budalaštini (ako još niste upoznati) možete pročitati ovdje ili ovdje ili ... ma znate naći i sami
Staro 22.11.2017., 22:47   #1897
calypso
calypso's Avatar
Postovi: 1,983
Autor bertone Pregled postova
Odlican update, hvala bertone!!
Provjerio sam i moji W530 i X220 su unaffected...
GMKTec K8Plus
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4-2666
intel UHD 620
Staro 22.11.2017., 23:03   #1898
bertone
bertone's Avatar
Postovi: 2,059
Mislim da su Intel ME stavili od SkyLake procesora.
Inače, ta priča (MINiX3) se vuče već neko vrijeme, ali je Intel šutio do sada (izdavanja zakrpe).
Staro 23.11.2017., 22:39   #1899
Dottore
Dottore's Avatar
Postovi: 7,661
Odlično
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 27.11.2017., 14:26   #1900
rodriguez
rodriguez's Avatar
Postovi: 2,062
http://www.narucime.hr/naviatec-mini...m_medium=click
Jel bi mogao s ovime riješit problem ekrana, tj igrat CS 1.6 bez lagga, ako spojim mini DP sa HDMIijem u TV?
imam T430
Staro 27.11.2017., 15:16   #1901
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Ovisno o modelu TV-a, imat ćeš znatno veći ili malo veći input lag od bilo kojeg TN monitora.
Imaš li postojećih problema s input lagom ili te zanima samo informativno?
Naslućujem nešto u smjeru internog ekrana i input laga, ali nisi jasno iznio problem, tako da odgovor na pitanje može biti i da i ne
Spoiler alert!
Staro 27.11.2017., 17:26   #1902
rodriguez
rodriguez's Avatar
Postovi: 2,062
Ma pitanje je samo ako bi si mogao povećati ekran dok igram CS, znači čisto gledanje u veći ekran... Ako bi mi se lag povećao onda mi to i nema smisla nikakvog.
Staro 28.11.2017., 02:26   #1903
vedranzeman
Lokacija: Kloštar Podravski
Postovi: 1,019
Na ovom Lenovo popisu većina x3x modela nije ni spomenuta, ali izgleda da je ipak izašao nekakav patch za Intel ME, ovo mi je danas izbacio System Update:
Software name Intel Management Engine 8.1 Firmware
Support models ThinkPad Helix
ThinkPad T430, T430i, T430s, T430si, T431s
ThinkPad T530, T530i
ThinkPad W530
ThinkPad X1 Carbon (Machine types: 34xx), X1 Helix,
X1 Helix 3G
ThinkPad X230, X230i, X230 Tablet, X230i Tablet, X230s
CHANGES IN THIS RELEASE
Version 8.1.72.3002
[Problem fixes]
- Fixed the following security vulnerabilities:
CVE-2017-5711, CVE-2017-5712, CVE-2017-13077, CVE-2017-13078, CVE-2017-13080.
Po CVE brojevima to je izgleda slično sranje samo u manjem opsegu u odnosu na novije ThinkPadove.
P.S. Nisam još instalirao.
Tko nije skršio Socket A procesor na bilo koji način, neka prvi baci kamen!
vedranzeman je offline   Reply With Quote
Staro 28.11.2017., 08:16   #1904
bertone
bertone's Avatar
Postovi: 2,059
Ako se dobro sjećam samo su se tri CPU-a (2xi3 i 1xi5) 2. serije (Sandy Bridge) ugrađivali u T430, svi drugi modeli u T i X serijama su imali 3. generaciju, odnosno Ivy Bridge a sa njima je Intel već počeo kemijati sa BIOS-om koji se nije mogao lako modificirati.
Staro 28.11.2017., 09:41   #1905
orson
Postovi: 129
Jučer mi se pojavio taj patch na X230 i X1 Carbon (1st gen).
orson je offline   Reply With Quote
Staro 28.11.2017., 20:38   #1906
rodriguez
rodriguez's Avatar
Postovi: 2,062
Meni isto, ja sam ga instalirao.
Staro 28.11.2017., 20:43   #1907
calypso
calypso's Avatar
Postovi: 1,983
Autor orson Pregled postova
Meni danas izletio na W530 i to usred sastanka. Pa cu sutra to stavit.
Sent from my EVA-L09 using Tapatalk
GMKTec K8Plus
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4-2666
intel UHD 620
Staro 28.11.2017., 21:09   #1908
Dottore
Dottore's Avatar
Postovi: 7,661
Nisam ni još instalirao na T430 jer ne stignem.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 28.11.2017., 22:57   #1909
bertone
bertone's Avatar
Postovi: 2,059
Meni ni neće doći
Staro 01.12.2017., 20:39   #1910
arrow
arrow's Avatar
Datum registracije: Nov 2014
Lokacija: Zd
Postovi: 609
@bertone
hvala ti na pomoći oko linuxa ali mi nikako ne leži, nisam se mogao naviknuti
drmnio gore win10 i laptop se preporodio, doslovno leti
na kraju je lenovo 3000 n500 završio kod žene, meni naletio neispravni hp compaq cq58-d51sm i popravio ga, na njega stavio win7 preko HDD-a i super radi za slabašni 1.5ghz proc, u planu je stavit neki SSD, baterija drži cca 3 sata
e sad jedno pitanje, na njemu je rezolucija 1366x768, ima li ikakve šanse da preko HDMI-a dobijem 1080p kad spojim na TV?
arrow je offline   Reply With Quote
Staro 01.12.2017., 21:02   #1911
bertone
bertone's Avatar
Postovi: 2,059
Ne vidim razlog zašto ne bi mogao imati 1080p na TV-u ako je HDMI izlaz ispravan.
Spoji Laptop i TV HDMI kablom digni Windowse i kombinacijom tipki WinKey+P biraš izlaz slike.
Što se pak tiče Linuxa, nekome odgovara, nekome ne, netko ima prejake navike spram jednog OS-a ili prevelika očekivanja da oba OS-a trebaju raditi jednako, ali nitko nikoga ne sili na ništa
Staro 02.12.2017., 10:38   #1912
arrow
arrow's Avatar
Lokacija: Zd
Postovi: 609
preko HDMI-a sam na 60Hz dobio 1400x1050 rezu, kad stavim na 50Hz reza je 1080p ali slika bježi preko bezela tj. slika je veća od ekrana
laptop ima radeon grafu(pretpostavljam da je isto na nvidiji) pa sam preko radeon settings-a na gpu scaling smanjio sliku od ruba do ruba
sad je 1080p 60Hz
eto, možda nekome pomogne
Staro 02.12.2017., 11:12   #1913
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,249
Taj problem s bjezanjem slike ti je overscan i idealno je da ga zgasis na tv-u. Kod mene na grundigu ga iskljucim u opcijama pod "picture > aspect ratio > disable overscan".
Kod drugih televizora bi trebao biti takodjer u "pictures"uz podmeniju.
Tako da ti je bolje da to zgasis na samom tv-u i vozis fhd rezoluciju kako i treba
Staro 05.12.2017., 13:18   #1914
..::Matej::..
..::Matej::..'s Avatar
Postovi: 391
Posjeduje netko p51? Razmišljam ozbiljno o kupovini, a kako je to relativno novi model pokušavam naći da li ima kakvih bugova i slično
..::Matej::.. je offline   Reply With Quote
Staro 06.12.2017., 08:54   #1915
cdanijel
Autor ..::Matej::.. Pregled postova
Nema. Uz Acerov Spin 5 jedan od strojeva koji se najbrže diže uopće; od strojeva na kojima sam nešto radio; sve se izvršava trenutačno. Mrvicu je problem bio podesiti ekran da Windowsi izgledaju normalno, ali izvedivo je... (Spin 5 koristim unazad par dana za nosanje okolo).
U svakom pogledu je to vrh ThinkPada. Mrvicu težak i za današnje pojmove kabast, ali kaj sad...
d.
Staro 06.12.2017., 09:29   #1916
..::Matej::..
Postovi: 391
Autor cdanijel Pregled postova
d.
Dobro da je robustan, to mi i treba Jedino šteta što kod nas nema baš neki izbor modela (i7 7700hq i 8gb rama), planiram na rate pa ne mogu vani
Kad vidim cijene u USA i usporedim s našim cijenama, padne mi mrak na oči.
Staro 06.12.2017., 09:34   #1917
Roby86
Postovi: 73
Evo, da se pohvalim kod mene je udomljena zvjerka zvana Carbon X1 (2016, 4.generacija).
Konfa je full oprema.. core i7, 16 GB RAM, QHD reza i 1 TB Samsung NVMe SSD. Od svega najviše me oduševljava SSD, ekran i ergonomija laptopa. Kupljen je preko eBay aukcije iz amerike za smiješnu cijenu, star 3 mjeseca, garancija do kraja 2019.g. E sad me interesira informacija što se tiče 4G LTE modema, jel on ima neki softver za handleanje sim kartice, kako to generalno funkcionira? Hvala unaprijed..
Zadnje izmijenjeno od: Roby86. 06.12.2017. u 09:51.
Roby86 je offline   Reply With Quote
Staro 07.12.2017., 19:37   #1918
ThePornstar
Postovi: 4,403
Četvrta generacija se i meni najviše sviđa, zbog panti
Jednog sam skoro prelomio jer sam mislio da su dodali Yoga feature
BTW, o kojoj smiješnoj cijeni se radi?
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 07.12.2017., 22:29   #1919
Roby86
Postovi: 73
Hehe, pa da. 1026 dolara, cca 6500 kn. Novi iz dućana je tamo bio 2100 dolara, ovdje je ta konfa preko 20k, divna marža jelte.
Staro 07.12.2017., 22:49   #1920
ThePornstar
Postovi: 4,403
Uh, fino. To je cifra s plaćenim porezom carini ili si imao sreću i prošao im je ispod radara?
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
