|  18.02.2005., 20:56 | #1 |
| Heros Arise Datum registracije: Dec 2003 Lokacija: Croatia
					Postovi: 41
				Warcraft 3 TFT
			 Ovako. Samo odjednom kad pokrenem bnet(battlenet) na Warcraft-u pojavi mi se error: This application has encountered a critical error: FATAL ERROR! Program: f:\games\warcraft iii\war3.exe Exception: 0xC0000005 (ACCESS_VIOLATION) at 001B:009D806B The instruction at '0x009D806B' referenced memory at '0x10003024'. The memory could not be 'written'. reinstaliro sam je dva puta i isto na kraju. Neznam sta mu je prije sve super islo i sad odjednom ovo. PLZ HELP
				__________________ Hope Is The First Step On the Road Of Disappointmen!! |
|  19.02.2005., 01:11 | #2 |
| bycod Datum registracije: May 2004 Lokacija: Zagreb / Dubrava
					Postovi: 6,699
				 | probaj defrag harda, ja sma imao slican error ali se sve rijesilo reinstalacijom promjeni ramima utore....  pa javi jeli ista pomoglo
				__________________ |
|  19.02.2005., 10:38 | #3 |
| Premium Datum registracije: Dec 2002 Lokacija: Zagreb
					Postovi: 1,610
				 | Provijeri PM!
				__________________ Kirk: "Spock, you want to know something? Everybody's Human." Spock: "I find that remark... insulting." |
|  20.02.2005., 15:48 | #4 |
					Postovi: 41
				 | oprosti ali sto znaci PM:confused:
|  20.02.2005., 18:31 | #5 | |
| Kompjuterov frend Datum registracije: Jan 2005 Lokacija: Karlovac
					Postovi: 326
				 | Citiraj:
				__________________ Bolje je šutjeti i pustiti da te smatraju budalom, nego progovoriti i otkloniti svaku sumnju. A. Lincoln | |
|  22.02.2005., 00:50 | #6 |
| Premium Datum registracije: Jan 2004 Lokacija: ZaGReB
					Postovi: 406
				 | format c: pomaže zihre
				__________________ Intel P4 1.8 Mhz ASUS P4S533-E SiS 645DX 2 x 256MB DDR333 Samsung HERCULES ATI Radeon 9800SE AIW 128 MB HDD Seagate Barracuda 60 & 80 GB NEC DVD RW+/-ND-2500 PSU Aopen 300W Monitor EIZO 19" Flexscan Microsoft IntelliMouse Optical CoolerMaster Aerogate II CoolerMaster Cool Drive 3 CoolerMaster 2 x 80mm vent LED Blue Papst 120mm vent SkyStar 2 Case InWin X710 Black |
|  22.02.2005., 11:03 | #7 |
					Postovi: 1,610
				 | Ne pomaže!   Maknite sve thirdy part programe, ili ako imate neke codec packove, to isto sve maknite.Za daljnje upute i riješenje koje stvarno radi, recite mi pa ću vam poslati na PM.
|  22.02.2005., 11:16 | #8 |
					Postovi: 41
				 | THx na PM
|  15.11.2005., 14:50 | #9 |
| Registered User Datum registracije: Nov 2005 Lokacija: dubrovnik
					Postovi: 12
				 | poz svima imam problem, kada god na bnetu hocu kreirat drugi igraci mi se uopce ne mogu joinat (imam siemens gigaset SE515 dsl, na blizzovom supportu kazu ovo: Others are not able to join the Warcraft III custom Battle.net games you create We are aware of a couple issues customers are experiencing in regards to people not being able to join custom Battle.net games you create. Routers Normal reason: The router is not forwarding the data to the correct computer. The solution: Set your router to forward data on 6112 to one of the computers on your network and 6113 to the next computer and so on. Then start Warcraft III on each computer, click the Options button, and click the Gameplay button. Towards the bottom of this screen you will see a text box titled Game port. Make sure the number in this box is the same as the port your router is trying to send the data to (the first computer being 6112, the second being 6113, and so on). al meni nije jasno sto da radim...help |
|  15.11.2005., 22:22 | #10 |
| Premium Datum registracije: Jan 2005 Lokacija: okolica Varaždina
					Postovi: 166
				 | Isključi firewall!!!    btw. kolko mapa imaš? Ili kak da se izrazim?? Karti?  Ja imam 192 na 77,5 MB i rijetko kaj dobroga. Koje mape igraš? |
|  16.11.2005., 00:11 | #11 |
					Postovi: 12
				 | ma nije do firewalla nego do routera, pokusavo sma za iskljucenim fw i ista stvar uglavom prcko sma danas ok port-forwardinga i stuff i naiso sam na http://www.portforward.com de je cijela stvar ako lijepo objasnjena, kazu da prvo treba namjestit static ip (ja mislim da sam to uradio kako treba) i onda prkat po routeru, al problem je kretenske prirode, (pogledaj sliku) kad klinem na apply NE DOGODI SE NISTA, vrati me ko sto je bilo kad je kvacica bila na "Select predefined services from the list"....ubit cu se  sto se tice mapa igram dotu i jedino dotu slika |
|  16.11.2005., 11:08 | #12 |
					Postovi: 166
				 | waaaaaaaaaaa... Zakaj svi igraju tu j..... dotu??? Nije da je loša nego mi je glupo kaj stalno izlaze nove verzije i nikak da imaš neku verziju i igraš kak treba!!! Imam 56k i neda mi se stalno skidati novu verziju jer mi uzima previše vremena. |
|  16.11.2005., 14:41 | #13 |
					Postovi: 12
				 | ma igra rula koliko vas ode igra na "onim serverima", ja sam na eurobattle.net-u, nick cro_pms |
|  16.11.2005., 16:52 | #14 |
					Postovi: 166
				 | Misliš na PvPGN??? Ja igram. "[CRO]_Destroyer" bez navodnika  igra ko x hero siege ili runn kitty ili kakve dobre td-ove? |
|  17.11.2005., 19:44 | #16 |
					Postovi: 166
				 | Zakaj piše da treba imati adsl??? Ja igram na 56k i radi ko ludo. Čak mogu i kreirati igre i nitko se još nije žalil.   |
|  17.11.2005., 23:25 | #17 |
					Postovi: 12
				 | zato sto kad ides kreirat dotu sa modemom tako te ispickaraju da ti to vise nikad ne padne na pamet:PP lag lag.... |
|  18.11.2005., 13:50 | #18 |
					Postovi: 166
				 | Zato ja ne igram dotu   |
|  02.12.2005., 21:38 | #19 |
| Registered User Datum registracije: Dec 2005 Lokacija: Osijek,Croatia
					Postovi: 9
				War 3 error + SE515
			 Igram vec duze vrijeme na battlenetu, Sherife, sto se tice errora to ti je tzv. ban, vjerovatno si ga dobio prilikom izlaska iz neke igre.... P.M.S. sto se tice SE515 Siemensa,imam ga doma i jedino sto moras otici tamo mislim u Advanced Options mislim NAT i moras ukljuciti virtualne servere,tj. moras tamo izabrati Blizzard BAttle.Net i spoj IP,Apply i Logout... i mora raditi... mozda nece odmah igraci dolaziti ali budi strpljiv...  |
|  30.10.2017., 11:57 | #24 |
| Premium Datum registracije: Nov 2008 Lokacija: Shire
					Postovi: 16,970
				 | https://www.kinguin.net/category/213...ign=allkeyshop https://www.g2play.net/category/2133...ign=allkeyshop Iskoristi: -3%: allkeyshop3 |
|  30.10.2017., 13:16 | #30 |
| Nikad sit, uvijek žedan Datum registracije: Jun 2005 Lokacija: Vallis Aurea / ZG
					Postovi: 8,218
				 | Samo dodaš u bnet račun te kijeve, i oni ti poslje praktički više ni ne trebaju. Sve ostane gore. |
