Staro 31.03.2005., 00:35   #1
del
del's Avatar
Postovi: 66
malo AMDova
Manufactured in 0.13µ, The first desktop CPU to support 64bit instructions and memory addressing. Available with 512KB & 1mb of L2 cache. With a 400mhz (200 FSB) bus, and with 3 different socket types:
Core Names:
Mobile Athlon64 CPUs:
Also manufactured in 0.13µ, and with 64bit instructions and memory addressing, but designed for Laptops, with less power consumption. With 512KB & 1mb of L2 cache. With a 400mhz (200 FSB) bus and available only in socket 754, with two consumption flavors, 62 and 35 Watts.
Sempron & Mobile Sempron CPUs:
Semprons use the Thorton or T-bred b core. These have 128kb L1 (64 data + 64 instruction), and 256kb of L2 cache. They operate with a stock FSB of 166(333 effective)mhz. Their Multipliers are also locked. They are fabbed using 130nm process.
Sempron:
Bus is 333mhz (166 FSB). Core is made in a 0.13µ. process and 84 sq. mm. in area. Only the 3000+ has 512kb L2 Cache
Mobile Sempron:
Only difference is the variation of L2 Cache and the lower Wattage
Mobile Athlon XP CPUs:
Mobile Athlon XP (Barton):
Manufactured in 0.13µ, available with 512KB of L2 cache. With a 266mhz bus (133 FSB) and with lower vCore than their non-mobile brothers (for the exception of the 3000+)
Mobile Athlon XP (Thoroughbred):
Manufactured in 0.13µ, with 1.45 vCore and 256KB L2 Cache.
There are actually a lot of mobile T-Breds: 2200+ was the highest 45w, 2000+ was the highest 35w. Thanks WiCKeD!
del je offline   Reply With Quote
Staro 31.03.2005., 00:36   #2
del
del's Avatar
Postovi: 66
Athlon XP (Barton):
Flagship chip was XP 2500+ (1.83GHz). As the TBred B (manufactured in 0.13µ), but now available with 512KB of L2 cache. With a 333mhz (166 FSB) bus available at 2500+ (1.833GHz), 2800+, 3000+ (2.17GHz) and finally the 3200+ and 3400+ with 400mhz bus (200 FSB).
Athlon XP (Thorton):
Visually the same as the Barton, with 333mhz bus but 256KB of L2 cache.
Athlon XP (Thoroughbred A):
Launched with the XP 2200+ (1.8GHz). As the Palomino, but with the difference that it was originally made with a 0.18µ. core, and then changed to 0.13µ. process, which makes it possible to work with less core voltage (1.5 to 1.65v, against 1.7 to 1.75v from Palominos), therefore, they do not heat as much. They can operate at higher frequencies. Core is 80 sq. mm. in area.
Available from 1700+ (1.466GHz) to 2200+ (1.8GHz)
Athlon XP (Thoroughbred B):
Launched with the XP 2400+ (2GHz). Bus is 266mhz (133 FSB) and 333mhz (166 FSB). It's practically the same as the TBred A, but the manufacturing process is refined, has more layers, and it's fabricated at FAB30 in Dresden, Germany. Core was then made in a 0.13µ. process. Core is 84 sq. mm. in area.
Available from 1700+ (1.466GHz) to 2800+ (2.250GHz)
Athlon XP (Palomino):
Were launched after the Tbirds. Also 0.18µ, with 256KB of L2 Cache and all operate at 266mhz bus (133 FSB). Core is also 128 sq. mm.
SSE instruction set was implemented (from Pentium 3s)
Available from 1500+ (1.333GHz) to 2100+ (1.7GHz).
Table for AthlonXP recognition:
Athlon MP CPUs:
Opteron CPUs:
High-end CPUs to directly compete against Intel Xeons. All currently available with 1mb L2 cache and socket 940.
Duron (Applebred) CPUs:
Low end CPUs, to directly compete against Intel Celerons, beating them by a good margin.
Staro 01.04.2005., 00:08   #3
nodavilp
pUtNiK
nodavilp's Avatar
Datum registracije: Feb 2004
Lokacija: na forumu
Postovi: 342
mogo si bar prevest
li jednostavno stavit ljinK
nodavilp je offline   Reply With Quote
Staro 01.04.2005., 00:21   #4
RAK
Feldwebel
RAK's Avatar
Datum registracije: Feb 2002
Lokacija: bolnica
Postovi: 3,739
Originally posted by nodavilp
mogo si bar prevest
Ovako je savršeno. Nikakav link.
Jako lijepo. Baš ono što mi treba.
Tih kao mačka
Brz kao gepard
Jak kao lav
Elegantan kao leopard
Nisam to ja, to je moj komp.
Staro 01.04.2005., 00:56   #5
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Ma kakv link ovako je izvrsno! StickY!!!
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 01.04.2005., 01:53   #6
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
Nice : cheers2
STI-KI STI-KI STI-KI
Staro 01.04.2005., 09:59   #7
del
del's Avatar
Postovi: 66
apdejt
AMD Athlon (Thunderbird Core, 0.18 Micron's)
AMD Duron (Spitfire Core, 0.18 Micron's)
AMD Duron (Morgan Core, 0.18 Micron's)
AMD Athlon MP (0.18 Micron's)
AMD Athlon MP (0.13 Micron's)
AMD Turion 64 2800+ - 1.6 GHz - 1M L2 - Core 90nm Rev 'E' - TDP 25W Socket754
http://www.fragtek.com/pix/turion_ss1.jpg
http://www.fragtek.com/pix/turion_ss2.jpg
Staro 01.04.2005., 12:06   #8
Darth Revan
Darth Revan's Avatar
Lokacija: Ireland
Postovi: 1,565
jedan info sto se tice Turiona, naime AMD ne zeli da ti procevi idu na desktop s754 platforme, zato niti jedna firma nece izdati bios da place podrzavaju ovaj divni proc, ali, dobio sam top secret informaciju, da se skupljaju donacije za turion, koji ce biti dan Oskar Wu koji ce napraviti bios za nase DFI lanparty nf3 kako bi podrzavale Turione, a onda pocinje bijesni OC!
Darth Revan je offline   Reply With Quote
Staro 01.04.2005., 15:30   #9
Vedran
Vedran's Avatar
Lokacija: Kutina
Postovi: 1,208
to je stara vijest, podrške će zasigurno biti, samo ona neće biti službena jer amd to ne dopušta. štoviše, čini mi se da neki proizvođači već imaju adekvatne biose...
Vedran je offline   Reply With Quote
Staro 02.04.2005., 09:28   #10
Srakar
Lokacija: Vžd / Banfica
Postovi: 32
Unhappy
sad ili sam ja ćorav, a n00b znam da jesam, ali ja tu nemogu naći svoj proc tj. athlon 64 3400+ soc. 754 koji radi na 12x200 default
2400Mhz
Srakar je offline   Reply With Quote
Staro 02.04.2005., 23:26   #11
Emissary
ČLAN FKTa
Emissary's Avatar
Postovi: 2,264
Ćorav si, ima ga u drugoj tablici, i to newcastle i clawhammer
Staro 03.04.2005., 12:15   #12
Vedran
Vedran's Avatar
Lokacija: Kutina
Postovi: 1,208
emissary, čovjerk dobro pita, ja ne znam di ti vidiš newcastle 3400 (2400mhz, 512kb cache) u tablici?
Staro 04.06.2005., 22:05   #13
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
WOOOOW Athlon enciklopedija :clap:
Pošteni Trgovci: 1,2
Staro 17.11.2005., 10:35   #14
sick_boy
sick_boy's Avatar
Postovi: 680
Ovo bi trebalo malo osvjeziti - upravo sam kupio laptopic (u pravom smislu rijeci) sa Mobile Sempron 2800+ (25W) procesorom (codename: Sonora). Vrlo zadovoljan, ali pretpostavljam da cemo ga upgrade-ati sa Turionom64 (posto je laptop upgrade-able, MSI S270W) i to MT serijom.
Edit:
Ups, upravo sam spazio da je i moj proc naveden u jednoj od tablica. Sorry.
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 25.11.2005., 00:05   #15
sNNooPY
sNNooPY's Avatar
Postovi: 1,908
sNNooPY je offline   Reply With Quote
Staro 25.11.2005., 07:13   #16
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,165
Nice
Tekst popračen sličicama
Dobar sticky
Staro 25.11.2005., 22:23   #17
b1tterman
Takozvani influenser
b1tterman's Avatar
Lokacija: Dublin
Postovi: 649
sta reci a da nije dosad receno...
b1tterman je offline   Reply With Quote
Staro 11.01.2006., 22:35   #18
blondie
blondie's Avatar
Lokacija: split
Postovi: 198
odlicno:clap: :clap:
CPU AMD Athlon64 BOX 3200+sck939 // MB Gigabyte K8N-SLI s939 nForce4 SLI // Powercolor Radeon x800gt // 2x256 MB RAM // HDD Seagate 120 GB s-ata150 // DVD+RW/-RW NEC ND-3550ABL // Codegen midi tower 6205L-CA, 400W // Mon. Samsung SM793DF 17" DynaFlat // ASUS TV TUNER My Cinema P7131H Dual
blondie je offline   Reply With Quote
Staro 30.01.2006., 10:33   #19
zox1000
zox1000's Avatar
Postovi: 27
Question AMD Athlon64 3000+, Socket754, venice, E6, 512Kb
zox1000 je offline   Reply With Quote
Staro 17.02.2006., 13:08   #20
zox1000
zox1000's Avatar
Postovi: 27
Još malo popisa AMD-ova....
Skinuto sa http://www.amdboard.com/amd64_opn.html
Staro 26.05.2006., 07:18   #21
atha
atha's Avatar
Postovi: 9,067
Link vise nije ziv, ali eto, bio sam lukav pa saveao slike na disk.
___________
Just atha
x
Staro 03.07.2006., 22:54   #22
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
jao decki pa zaboravili ste stvari iz prahistorije nesto tipa 486 nije valjda da nitko nije imao amd-ovu 486
kod mene doma stoji jedna u regalu
ADVANCED
MICRO
DEVICES
Am486 DX2-66
A80486DX2-66N
E6 9514DPI
jos uvijek ispravna ;-)
VoodooRain je offline   Reply With Quote
Staro 09.07.2006., 11:51   #23
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
evo decki ako nekoga zanima jos malo
http://www.cpu-museum.de/?m=AMD
ali ima tu jos svacega...
Staro 10.12.2006., 09:45   #24
Eustace
AMD Team
Eustace's Avatar
Lokacija: Tuzla
Postovi: 142
ABIT AN8-Ultra
AMD Athlon64 X2 4200+ (oc. @ 4600+)
2x1GB DDR400 RAM dualchannel
2x120GB WD SATA300 HDD in RAID 0
Gf7600GS 256MB
ASUS DVD-RW
ASUS DVD-R
ASUS TV-FM Tuner
Chieftec BA-02-B-B-B SuperTower
Chieftec 400w psu
19" LCD TFT 8ms
Eustace je offline   Reply With Quote
Staro 27.02.2007., 08:39   #25
zox1000
zox1000's Avatar
Postovi: 27
Evo još malo detaljnijeg popisa.....
http://www.techpowerup.com/cpudb/
Staro 04.04.2007., 10:15   #26
maX
maX's Avatar
Postovi: 7,326
