Staro 10.09.2017., 15:51   #2581
renaTq
renaTq's Avatar
Datum registracije: May 2017
Postovi: 387
Autor maXonja Pregled postova
Jel to sa elpidom 31 MH/s? :O
Hou d fak?
Tako je
#propo
renaTq je offline   Reply With Quote
Staro 10.09.2017., 16:04   #2582
croclocker
croclocker's Avatar
Datum registracije: Apr 2008
Lokacija: GER
Postovi: 724
jel ko korisiti
WINDOWS 10 REGISTRY TWEAKS FOR MINING
Once windows is full installed and booted for the first time i always run the Windows 10 Registry tweaks for mining.bat file https://mega.nz/#!8gZzjQaa!Dt4wE0WEo...6CJgFZTXKq9pnQ (i am not disabling everything, just things that i think wont be needed, windows update, cortana, crash reports etc..)
Back Up Your Registry or create a restore point
Run in administrator mode
Once everything is applied, restart the rig
List of Tweaks
Replace Utilman with CMD
Disable Cortana, Bing Search and Searchbar
Disable automatic Windows Updates
Disable Hibernation
Disable tracking services
Disable WAP Push Message Routing Service
Disable Windows Search
Disable Superfetch
Disable Windows Defender
Disable OneDrive
Disable Quick Access as default view in Explorer
show computer shortcut on desktop
Show file extensions
Disable lockscreen
Enable classic control panel view
Hide indication for compressed NTFS files
Disable Windows Update sharing
Remove Pin to start
Classic vertical icon spacing
Remove versioning tab from properties
Disable jump lists
Remove telemetry and data collection
Change Logon screen background with accent color
Disable Windows Error Reporting
Removing Windows default apps
Blocking Telemetry Servers
croclocker je offline   Reply With Quote
Staro 10.09.2017., 16:59   #2583
maja333
Datum registracije: Sep 2017
Lokacija: mostar
Postovi: 4
[QUOTE=FRipper;3100384]Tamo upišeš transakciju i vidiš di je otišlo,i to onda priloži poloniexu pa neka vide
ukucavala ne moze da pronadje transakciju,prije toga je uspjesno 1 ltc prosao tu odmah nadju,kada udjem u svoj novcanik pise mi za tu transakciju da je nepotvrdjena,da li je moguce da je hakovano jer nema ih ni u novcaniju ni na poloniexu
maja333 je offline   Reply With Quote
Staro 10.09.2017., 17:54   #2584
rudi1
Postovi: 95
Autor croclocker Pregled postova
jel ko korisiti
Samo full power, veća vm, i dis. update da ne restarta sam.
rudi1 je offline   Reply With Quote
Staro 10.09.2017., 17:57   #2585
RimtuTiTuki
RimtuTiTuki's Avatar
Postovi: 1,629
jel ko korisiti
List of Tweaks
Disable Hibernation
Disable Superfetch
Disable OneDrive
Disable lockscreen
Remove Pin to start
Disable jump lists
ovo izgleda super...
dio toga napravim sam... dio toga mi nije pao na pamet... ali mislim da ću napraviti.
ako ću imati malo vremena bacim oko... Mene je uvjek frka bilo šta instalirati na rig, s obzirom da postoji opastnost od toga da instaliraš trojanca..
Staro 10.09.2017., 19:02   #2586
croclocker
croclocker's Avatar
Lokacija: GER
Postovi: 724
Pa mozes si sve pogledati sto je postavljeno
Na testnom rigu sam stavio... pa cu vidit ocu to i na ostale
Elpida Bios RX 570
http://www.mediafire.com/file/u71etk...570+elpida.rom
Zadnje izmijenjeno od: croclocker. 10.09.2017. u 19:15.
Staro 10.09.2017., 19:24   #2587
zupanjac29
Lokacija: Zupanja
Postovi: 12
[QUOTE=FRipper;3100982]Na YT je sigurno Samsung ili Micron memorija, a ti imaš Hynix kojoj je max s ocom tako oko 19.
Hvala na odgovoru... Dal ja kako mogu iz nje izvući nešta više od 19 hashrate...?
zupanjac29 je offline   Reply With Quote
Staro 10.09.2017., 19:25   #2588
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,593
Nažalost ne, barem koliko je meni poznato
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 10.09.2017., 19:29   #2589
zupanjac29
Lokacija: Zupanja
Postovi: 12
hvala na odgovoru... Dal bi ja kako mogo izući iz te kartice šta više o 19 hash
Autor FRipper Pregled postova
EWBF's CUDA Zcash miner
Code:
miner --server zcl.suprnova.cc --port 4042 --user TvojUser.TvojWorker --pass x
Staro 10.09.2017., 19:32   #2590
zupanjac29
Lokacija: Zupanja
Postovi: 12
imam u planu ovaj mjesec kupit još jednu karticu jer slažem si miner polako koliko omam novaca pa ako može koji prijedlog koju karticu da nebi opet pogriješio u odabiru... pošto sam krenio sa nvidiom ako može preporuka za iste.. hvala
Staro 10.09.2017., 19:45   #2591
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Autor zupanjac29 Pregled postova
Odabir svake će bit pogreška jer grafičkih kartica sa samsungom više nema.
Staro 10.09.2017., 19:50   #2592
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,593
Neće jedino fulati sa 1070, na njima dosad nisam vidio hynixa
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 10.09.2017., 19:55   #2593
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
hmm s obzirom da samsunga na 1060 više nema onda je možda 1070 i logičan izbor. Samo dali cijena i perf u zec-u jednako skaliraju?
Staro 10.09.2017., 20:02   #2594
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,542
Pa zar nisu 1060 6GB grafe još uvijek blagoslovljene Samsungovim čipovima?
Prije par tjedana je Fripper nešto na tu temu natuknuo ak se ne varam.
Gadna je situacija, sve iznad 1060 je masno precijenjeno, bilo prije, sad još više.
A Radeoni nikako opet na 1500kn pasti
Moguće je BESPLATNO produžiti W10 sigurnosne nadogradnje do 2028!
Staro 10.09.2017., 20:14   #2595
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Autor kopija Pregled postova
Da radeoni padnu na 2000 bilo bi već razumno.
Staro 10.09.2017., 21:50   #2596
zupanjac29
Lokacija: Zupanja
Postovi: 12
Pošto je takva situacija šta kažete o ovome...?
https://www.protis.hr/products/detai...m_medium=click
ili za 1500 kn da uzmem još jednu MSI GTX 1050 TI GAMING X 4G 15 hashrate na eth...?
Poslano sa mog F5321 koristeći Tapatalk
Staro 10.09.2017., 22:39   #2597
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
gtx 1050 po toj cijeni je debelo neisplativa.
Uzmi 1060 i rokaj zec ili zen.
Staro 10.09.2017., 23:46   #2598
dfranc
Datum registracije: Nov 2011
Lokacija: Daruvar
Postovi: 308
Ja sam kupio antiminer s7,za 600 ojera,sad planiram ili kupiti gotov rig ili sam složiti,6x 1060,ili slićne.Brine me isto hinix,a 1070 su bezobrazno skupe.Ako mi naleti, neki gotov rig, sa 1060,što moram paziti,osim da ima garanciju.Lp
dfranc je offline   Reply With Quote
Staro 11.09.2017., 07:10   #2599
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,542
Autor dfranc Pregled postova
Po mogućnosti da hladnjak ima barem trunku bakra na sebi.
Gigabyte Windforce, Zotac AMP, MSI 1060 3GT OC su dobri primjeri dobrih hladnjaka.
Uzi/Alza imaju Windforce po 1750kn. Hynix, ofkors
Staro 11.09.2017., 08:49   #2600
Kamby
Kamby's Avatar
Datum registracije: Oct 2013
Postovi: 132
Zanima me koje su razlike za određene modele gtx1060?
Gledam postoje Gigabyte, Gainward GeForce, MSI, Zotac, Asus GeForce...
Hvala unaprijed.
Kamby je offline   Reply With Quote
Staro 11.09.2017., 08:59   #2601
zupanjac29
Lokacija: Zupanja
Postovi: 12
Zašto mi se ovo dešava...? Do danas je radilo sve kako treba...
Staro 11.09.2017., 12:23   #2602
zupanjac29
Lokacija: Zupanja
Postovi: 12
I ovo ni je na eth... Majner vrti al se ništa ne vidi i worker mi je crven..? Dal tko zna o čemu se radi u ova dva slučaja..? Sve radilo u redu do danas...
Staro 11.09.2017., 13:43   #2603
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ja uopce ne kuzim sta ti majnas? Prva slika je zcash a druga eth...ili sta vec
Staro 11.09.2017., 13:47   #2604
zupanjac29
Lokacija: Zupanja
Postovi: 12
Da prva je eth, a druga zcash... Majno sam eth i vidio sam da jučer cijeli dan mi se nije ništa nakupili a majner pokazuje da se vrti i vidio sam da mi je worker crven... Onda sam stavio zec jer sam njega Majno dok sam imo jednu grafičku i radilo je prije i radilo je i sad sve do et jutros...
Staro 11.09.2017., 13:53   #2605
zupanjac29
Lokacija: Zupanja
Postovi: 12
Ugl jel imo itko ovakav slučaj i jel itko zna riješenje...?
Staro 11.09.2017., 14:25   #2606
mraka
Datum registracije: Apr 2017
Postovi: 23
Pozdrav, jedno pitanje
Kakva je gainward gtx 1080 (cijena oko 4500kn?)
kao sto sam rekao, sluzila bi za gejming i majning.
(inace igram na 1080 50" tvu) tako da mi nereba ta jacina graficke, vec bi se zadovoljio i sad nekom drugom.
Ugl pruza mi se prilika uzed i msi gtx 1060 6gb (cijena 2600kn)
e sad, preporuka za neki eventualni buduci majning. (recimo da me vise zanima majning, al eto moram od nekud pocet sudeci da se nemogu isprsit za par komada grafickih. osim do 5000kn max.
nadam se da ste razumili pitanje.
(da mozda ciljam 2x 1060? 1080? 1070 ne spominjem jel ih nemaaaaaaaa)
mraka je offline   Reply With Quote
Staro 11.09.2017., 17:30   #2607
rudi1
Postovi: 95
Izmjeri ako mozes / imas s cime napon na DC konektoru graficke (pazljivo da ne šlusaš) prema šasiji. Svih 6 ili 8 pinova. Najbolje mjeriti sa strane gdje su zalemljeni pinovi.
Bar ces znati da nije napajanje/žice/konektori problem.
Staro 11.09.2017., 18:24   #2608
zupanjac29
Lokacija: Zupanja
Postovi: 12
Nemam s čime izmjeriti al ću probat stavit u pcie od ove grafičke koja radi.... Al ovo se meni dešava na zec majneru, a na eth ona radi...
Staro 11.09.2017., 20:25   #2609
vulkan1
Datum registracije: Aug 2017
Postovi: 111
Imam RIG 5 X 570 4 GB Elpida,
Pošto mi je napajanje 1000 w i ima još jedno mjesto
kupio bih proširenje raisera za ploču i stavio
SAPPHIRE NITRO+ RX 570 8GB GDDR5 GPU
dali je to dobro riješenje? Mislim u smislu
dalui bi mi to bilo dostatno napajanje
i dali imate neku "pametniju" karticu koja više rudai MH/s
za kupiti.
Cijena nije važna
Hvala (početnik).)))
vulkan1 je offline   Reply With Quote
Staro 11.09.2017., 20:27   #2610
croclocker
croclocker's Avatar
Lokacija: GER
Postovi: 724
Dali je ko imo iskustva sa power color rx 570/580 ?
lp
