Magister Mundi sum!
Datum registracije: Jun 2003
Lokacija: Zagorje
Postovi: 2,335
pitanje u vezi neceg ........
samo me zanima .... kod digitalaca .. kad pishe da podrzava SD i MMC .. ovaj SD oznacava secure digital card a MMC multimedia card kaj ne ? imam canon powershot A410 ... kaj je opce bolje SD ili MMC ?
Strichek Moderator
Postovi: 9,344
MMC su malo bolje jer su malo brže. ![]() |
Strichek Moderator
Postovi: 9,344
@kian evo napokon sam pročitao sve i vidim da nema XD kartica koje su uz CF typeII i MMC po meni najbolje kartice (ajmo reć najbolje) za digitalne fotiće.. usporedni test spremanja .raw fotografije (znači oko 40MB) CF TypeII i XD: XD je brža za oko sekundu, štoperica je bila u ruci.. eh da to se izvodilo na fotiču FUJI S7000 koji ima mogućnost primanja obje kartice. |
Datum registracije: Oct 2001
Lokacija: Velika Gorica
Postovi: 600
Sve zavisi od fotoaparata do fotoaparata. Fujifilm FinePix S3 Pro "Note: This camera accepts both CompactFlash and xD format media. The latter format is not widely used, tops out at 512MB currently (though 1GB cards are on the near horizon) and is relatively slow in card-to-computer transfers, relative to top-tier CompactFlash like the SanDisk Extreme III. But, because of a CompactFlash interface in this camera that's seriously underpowered, it's likely that any number of xD cards on the market will be quicker at writing photos in the S3 Pro. For example, we tested a Fujifilm-branded SanDisk 256MB xD card and found that at 3.731MB/second and 3.811MB/second for JPEG and RAW respectively, it's almost twice as fast as the fastest CompactFlash card in Fuji's latest digital SLR. So, if maximum card speed is a requirement, one that overshadows the drawbacks of going with a relatively obscure card format in the pro digital photography world, you might consider xD." Ljink testa |
