Postovi: 18
kupujem laptop
Treba mi za posao, znači, pisanje, prezentacije, surfanje. Jedino što mi je bitno da je što lakši, da mu baterija što dulje traje i da voli putovanja ![]() Prijedlozi?
AMD Athlon 64 X2 5000+ Black Edition MBO DFI, s. AM2, LAN PARTY DK 790FX-M2RS RAM, 4 GB (2GB + 2GB), DDR 2, PC-6400 VGA PCI-E POINT OF VIEW, 9600 GT Extreme 580 W ATX 2 |
Postovi: 32
moj frend ima končarov laptop i nije los ali ja ti preporucujem ibm-ov jeftin i dobar za stvari koje ti treba notebook ibm thinkpad r50e Intel Celeron M Processor 360 1.40GHz,400MHz Front Side Bus, BIOS type: Flash ROM15" TFT Active Matrix display with backlight illuminationMax resolution on built-in screen: XGA 1024 x 768256MB 266MHz PC2700 DDR SDRAM proširivo do 2GBHard disk 40GB ATA-100, EIDE, 5400 rpmIntel Extreme Graphics2, XGA, DVMT, Direct AGP,Maximum resolution 2048 x 1536 at 65536 colorsCD-RW/DVD-ROM Combo:24X/24X/24X/8X Max, EIDEAudio chipset make & model: SoundMAXIntegriran 1 zvučnik, snage 1 WattaFax/modem: 56K V.92 designedFax/modem speeds: 56Kbps data/14.4Kbps faxIntegrated Network Card 10/100 EthernetAC Adapter 72 watt,Pointing device: TrackPoint with Press to SelectFull size Standard Keyboard - HR, Keyboard lightPC Card support: 1 Type I/II or 1 Type IIILithium-Ion Batterijski sklop, do 3.4 sata autonomije radaPortovi: AC adapter, External Display, Headphone/Line out,Microphone/line in, RJ-11, RJ-45, 2 USB 2.0Težina: 2.453KgDimenzije: Visina 38mm, Širina: 332mm, Dubina: 269mmOperativni sistem: Microsoft Windows XP Pro Cijena za gotovinu: 5.882,54 KN Cijena za karticu: 6.283,62 KN imas ga za kupiti u Linksu(www.links.hr) |
#3 | |
Postovi: 519
Re: kupujem laptop
Postovi: 18
do 10k kuna. ||Spawn||, hvala na prijedlogu ![]()
