Staro 22.11.2005., 18:10   #1
psf[i]-[Tomek]
-nVidiot-
psf[i]-[Tomek]'s Avatar
Lokacija: Varaždin/Zabreg
Postovi: 962
Lightbulb 7800 GS when 6800 GS is no longer needed!
For those of you who have followed our previous articles, NVIDIA has internally announced the GeForce 7800GS; a 16 pipe replacement for the GeForce 6800GT and 6800 Ultra. We recently got a chance to benchmark the card, and not surprisingly the performance is right between the GeForce 6800GS and GeForce 7800GT. However, what was perhaps most interesting about the card was that NVIDIA's current driver support; current drivers had no problem detecting the 7800GS in our test beds. The 7800GS uses the same 110nm G70 core as the GeForce 7800GT and 7800GTX.
The card we benchmarked came with a 375MHz core clock and a 1000MHz memory clock. Even with an entire quad disabled, our internal testing proved that the card was ample competition for ATI's X1800XL. Currently, we are working on enabling the disabled quad and/or overclocking the 7800GS up to 7800GT and GTX speeds. With a good price point, the GeForce 7800GS could easily become 2006's rendition of the Radeon X800GTO^2. A 16 pipe version of 7800GT would easily best a GeForce 6800GT or 6800 Ultra (at least on paper), but with current drivers we've already witnessed higher performance than that.
You may notice our first screenshot showed a total of 2 PCIe lanes. We are still working on this, and it looks like the screenshot only demonstrates an anomaly of the motherboard. Stay tuned for the full review within the next few days!
AnandTech
psf[i]-[Tomek] je offline   Reply With Quote
Staro 22.11.2005., 19:26   #2
Konan
Konan's Avatar
Datum registracije: Jun 2004
Lokacija: Xindi weapon
Postovi: 441
Nice. Evo članak o 7800 seriji na PCE:
http://www.pcekspert.com/articles/346-1.html
NVIDIA tvrdi da zbog nove arhitekture jedna vertex shader operacija traje 79 clockova dok je za istu operaciju na 6800 karticama potrebno 108 clockova. Dakle, ubrzanje bi trebalo biti bar 30% no vjerovatno više jer 7800GTX dolazi sa osam vertex jedinica dok ih 6800Ultra ima šest.
Pixel shaderi su također doživjeli face lifting na način da su im poboljšane floating-point operacije te da su dodatno optimizirani da što brže izvršavaju MADD (Multiply and accumulate) operacije. NVIDIA tvrdi da su MADD operacija najčešće opracije kod pixel shadera pa su se tako potrudili da njih što više ubrzaju - GeForce 7800 kartice bi trebale u istom vremenu obraditi duplo više ovih operacije nego što to rade 6800 kartice.
Jedinica za teksture je pak pojačana novim hardverskim algoritmima i boljim cacheingom što je dovelo do boljih performansi kod filteringa i blendinga. Vrijeme potrebno da se uzme neka tekstura je također smanjeno a i developerima je omogućeno da iskoriste različite veličine texel uzoraka. Glavnih razlozi zašto se NVIDIA dosta pozabavila teksturama su anisotropic filtering te high-dynamic rendering (HDR).
Uglavnom mislim da će biti kartica oko 6800Ultra ili malo brža.
OT: Mislim da nakon izlaska GTX512 oni koji su kupili Gainward GTX-icu s vodenim nisu baš presretni. Slabiji taktovi, manje RAM-a a isto koštaju.
Konan je offline   Reply With Quote
Staro 22.11.2005., 20:31   #3
Postovi: 7,568
Zato se ja držim one stare: ''Strpljenje je vrlina''.
Mislim da bu 7800GS znatno brža (i bolja) od 6800Ultre.
Staro 23.11.2005., 19:39   #4
Konan
Konan's Avatar
Postovi: 441
Staro 24.11.2005., 12:34   #5
sick_boy
sick_boy's Avatar
Postovi: 680
Mislim da nece. Bice malo, ako ce uopce biti brza od Ultre. Ali ce biti bolji izbor zbog novije arhitekture (uostalom, Ultru je vec danas gotovo nemoguce naci na trzistu).
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 24.11.2005., 13:08   #6
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
sve je moguće na našoj tržnici
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 24.11.2005., 14:20   #7
Postovi: 7,568
Pa kad tu zver od 7800GS otključaš (ako se bu dala, naravno) ili sclockaš na taktove GT ili GTX-a......e onda bu brža i bolja.
Staro 24.11.2005., 16:25   #8
sick_boy
sick_boy's Avatar
Postovi: 680
U tom slucaju mozda hoce. Ako ju otkljucas i podignes taktove, bice zvijer. Po defaultu sumnjam da ce biti nesto posebno brza od Ultre (na defaultu, naravno).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 24.11.2005., 16:50   #9
Postovi: 7,568
nVidia-ina referentna bu po pitanju preformansi ista ko i Ultra. Ali kad Leadtek i XFX izdaju (naprave) svoje bijesne (Extreme i XXX) modele, onda bu ipak malo bolja.
Staro 24.11.2005., 21:37   #10
Lihto
Lihto's Avatar
Postovi: 3,945
Pa po pravilu otključanja onda bi se i 7800GT trebala otključat zar ne?
iPhone XR 128gb
Staro 24.11.2005., 23:36   #11
Postovi: 7,568
Ne bi se trebala, tj. ne da se. Zakaj, nemam pojma. Uostalom kud bi došli kad bi se sve dalo otključati. nVidia bi propala, jer bi svi kupovali kartice za cca. 2.000 kn i onda ih doma otključavali u GT i GTX modele. To nVidia stavi jedan ili dva modela da se ljudi vesele i da oni naravno još više zarade.
Staro 25.11.2005., 10:34   #12
sick_boy
sick_boy's Avatar
Postovi: 680
I BFG, samo sto oni nisu toliko popularni kod nas.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 25.11.2005., 10:46   #13
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Možda će nVidia pljunuti 6800GS za AGP, a 7800GS za PCI-E
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 25.11.2005., 12:05   #14
sick_boy
sick_boy's Avatar
Postovi: 680
E, to bi vec bilo za ocekivati (posebno zato sto je 6800 nativno AGP, a 7800 PCI-E chip).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 25.11.2005., 15:31   #15
Postovi: 7,568
Meni se čini da bi moglo biti 6800GS i za AGP i za PCI-X, ali zato 7800GS ostaje na PCI-X.
Staro 25.11.2005., 18:46   #16
Konan
Konan's Avatar
Postovi: 441
Razlika u cijeni nije toliko u cijeni čipa nego i u bržoj memoriji. A normalno da ne mogu pogoditi taman tako cijene da bude potražnja takva da imaju taman toliko GTXica da im ne ostane ni jedna koja ide pod GT ili GS. A i lakše je prodat model od 16 pipea ako postoji šansa da se otključa nego ako ne. Ali možda ih i zaključaju. Uglavnom kak si rekao-samo da najviše zarade.
Staro 25.11.2005., 23:30   #17
b1tterman
Takozvani influenser
b1tterman's Avatar
Lokacija: Dublin
Postovi: 650
agp je mrtav. zivio agp
b1tterman je offline   Reply With Quote
