#1921 | |
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,612
1x Gigabyte Main Board Desktop AB350M-Gaming 3 Socket AM4 4*DDR4 3200, DVI-D, VGA, HDMI, M.2, mATX 1x Memorija Corsair 1X8GB DDR4 2666 C16 1x Grafička MSI GeForce GTX 1070 Gaming, 8GB GDDR5, DX12 1x SSD Kingston A400, R500/W350,240GB, 7mm, 2.5" 1x Hard disk Toshiba P300 (3.5" 1TB, 7200RPM, 64MB, NCQ, AF, SATAIII), bulk - MAXI PONUDA 1x Napajanje Corsair Builder Series CX550, 550 Watt, EU Version 1x Kućište Zalman Z3 PLUS mid tower case black - AKCIJA UKUPNO: 9.960kn Zadnje izmijenjeno od: coconut. 09.06.2017. u 13:41. |
#1924 |
Postovi: 34,019
U toj cjenovnoj klasi konfe, CX nema šta tražiti. Ili RM serija ili nešto slično njoj (SuperFlower, Seasonic, EVGA,...).
#1925 |
Datum registracije: May 2017
Postovi: 8
Help?
Jel ovo valja? iskljucivo pc za igrice, do 7800kn AMD Ryzen 5 1600 ASUS PRIME B350-PLUS ATX EVGA GTX 1060 6GB SC Gaming ACX 2.0 Zalman Z1 Neo mid tower case black Corsair CX550M 550 Watt Modular (2015 Edition) Cooler Master Hyper 212 Evo Procesor Hladnjak Corsair SSD 120GB Force LE200 7,550.34kn bilo kakav savjet ce mi dobro doc, hvala, pozdrav |
#1927 | |
Postovi: 1,612
1x MSI Main Board Desktop B350 (SAM4, 4xDDR4, PCI-Ex16, 2xPCI-Ex1, USB3.1, USB2.0, 4xSATA III, M.2 1x Procesor AMD Ryzen 5 1600 1x Memorija Adata XPG Z1 DDR4 16GB (2x8GB) 3000MHz 1x MSI GF GTX 1060 6GT OC V1, 6GB GDDR5, DX12 1x Kingston UV400 240GB SSD, 2.5” 7mm, SATA 6 Gbit/s, Read/Write: 550 MB/s / 490 MB/s 1x Toshiba P300 1TB, 64MB, 7200rpm 1x CORSAIR Builder Series CX550M, Modular Power Supply, EU Version 1x Fractal Focus G, crno s prozorom UKUPNO: 7.762kn |
#1929 |
Postovi: 1,612
kako će se staviti kad zbog ove mining ludnice GTX1070 košta skoro koliko je koštala GTX1080 prije početka ludnice ![]() |
#1930 |
Datum registracije: Jul 2017
Postovi: 2
Pozdrav, nez je li ko već pisao o tome, ali treba mi konfa za "ozbiljniji" posao, tipa cfd simulacije i fem analiza, cjenovni rang 9-10k max. Fala svima |
#1931 |
Datum registracije: Mar 2011
Postovi: 2,707
ASRock AB350 Pro4 AMD Ryzen 7 1700 BOX Kingston HyperX FURY Black 32GB DDR4 2400MHz Kit Toshiba 2TB 3.5" 7.2k SATA 6Gb/s Enermax MaxPro 500w Asus Turbo GTX 1060 3GB White Fractal Focus G, crno s prozorom, bez napajanja Samsung 960 EVO 250GB, PCIe, M.2, SSD ~9660kn s forumskim popustom |
#1932 |
Postovi: 2
Smartic, zahvaljujem |
#1933 |
Datum registracije: Feb 2011
Lokacija: Dubrovnik
Postovi: 55
Pozdrav, trebao bi kuciste do 8k kuna, iskljucivo za Premier i video editing i po mogucnosti jedan wen shop. Ne znam kakva je situacija s AMD CPU/GPU sad? Pa bi htio da mi preporucite sluzbeno ovdje. Hvala evo jedna konfiguracija za 8k ASUS ROG STRIX B350-F GAMING AMD B350 Socket AM4 ATX matična ploča AMD RYZEN 3 1300X Gigabyte GeForce GTX 1060 G1 Gaming 6GB Corsair RM550x GOLD Enthusiast Samsung 250GB 850 EVO G.SKILL Ripjaws V Series 16GB (2 x 8GB) DDR4 3200MHz Fractal Define S, crno, bez napajanja uzishop s forum popustom naravno, pa bi molio komentare hvala Zadnje izmijenjeno od: CABaaL. 03.08.2017. u 14:33. |
#1934 |
Lokacija: Ivanec, Zagreb
Postovi: 36
Pozdrav ekipa, pretpostavljam da sam pogodio (cjenovnu) temu. ![]() S obzirom da je nedavno nabavljen 34" monitor potrebna mi je konfiguracija koja će glatko pogoniti rezoluciju 3440x1440. Trenutna konfiguracija je postala preslaba. Više ne postoji potreba da se igre guraju s najvišim detaljima, ali opet da se mogu pokrenuti i da ne 'štekaju' na nekim normalnim postavkama. Veći naglasak mi je na programima koji su orijentirani na obradu fotografija i video uradaka (4k). Bit će tu zasigurno multitaskinga... Nek mi se ponudi samo SSD (veći od 200GB). HDD-a imam dovoljno, i njih ću ubaciti iz stare kutije. Nemam favorita između AMD-a i Intela tako da ponudite ono što je bolje (i jeftinije) za gorenavedeno. Kućište ne treba vrištati bojama, svemirskim dizajnom i sl. Fractal design kućišta mi se sviđaju, al ako ima nešto slično ubaciti, a jeftinije je, uzimam. ![]() Poželjno bi bilo sve to uzeti u jednoj trgovini... Mogu platiti i gotovinom bez rata ako bi to dodatno spustilo cijenu. Fala! ![]()
Usto, smatram da bi Kartagu trebalo razoriti... |
#1936 |
Postovi: 36
#1937 |
Postovi: 2,707
1 x MSI GF GTX 1080 Gaming X, 8GB GDDR5X, DX12 1 x MSI Main Board Desktop B350 (SAM4, 4xDDR4, 2xPCI-Ex16, 2xPCI-Ex1, 2xPCI, USB3.1, USB2.0 ,4xSATA III, M.2, Raid, VGA, DVI-D, HDMI, GLAN) ATX Retail 1 x Seagate HDD, 1TB, 7200rpm, SATA 6, 64M 1 x Fractal Focus G, crno s prozorom, bez napajanja 1 x GIGABYTE B700H Power Supply 700W, Modular, 80+ Bronze 1 x Procesor AMD Ryzen 5 1600 1 x Crucial DRAM 8GB DDR4 2666 MT/s (PC4-21300) CL19 SR x8 Unbuffered DIMM 288pin 1 x SSD AD 128GB SU800 SATA 3D Nand Ukupno: 9597,33(-2% = 9.405kn) Malo žrtvovanja RAMa i kapaciteta SSDa, ali ovako se jedino isplati za tu rezoluciju ![]() |
#1938 |
Postovi: 14,584
Može se složiti i sa gtx 1080 (najbolji value u višem segmentu) i igrat ćeš ko car, zatim najbolji value od procesora trenutno, ostalo je sve OK da može ispratit. Stavljen samo ssd, ako ti 240gb nije dosta ubaci 1tb hdd ili pređi budžet za cijenu diska 1 x GIGABYTE GeForce GTX 1080 GDDR5X 8GB/256bit, PCI-E 3.0 x16, HDMI, DVI-D, 3xDP, WINDFORCE 3X 1 x Procesor AMD Ryzen 5 1600 1 x MSI Main Board Desktop B350 (tomahawk) (SAM4, 4xDDR4, 2xPCI-Ex16, 2xPCI-Ex1, 2xPCI, USB3.1, USB2.0 ,4xSATA III, M.2, Raid, VGA, DVI-D, HDMI, GLAN) ATX Retail 1 x MEMORIJA DDR4 8GB 2400MHz ADATA - Bulk 1 x Kingston SSD A400, R500/W350,240GB, 7mm, 2.5" 1 x ENERMAX Ostrog Lite, 1x USB 3.0, 2x USB 2.0, HD Audio, 2x 120mm Apollish LED fan, Black 1 x Fortron Hyper 600W, 80+ - 60mj. Ukupno: 9184,24 kn |
#1939 |
Datum registracije: Dec 2014
Postovi: 36
Moze jedna gaming konfa koja bi ukomponirala "best buy" 1080-ku? Igram pretezito cs lol i takva ne pc heavy sr*** al gledam si uzet sad nesto lijepo. Vidim manuel calavera je nabacio nesto slicno doslovno post iznad mene, medutim meni vjerovatno ne bi trebao ryzen. Hvala ljudi unaprijed |
#1942 |
Postovi: 36
Normalno da bi bio overkill , malo sam zastao na misli. Mislio sam u smislu, igram cs i lol pretezito, uzeo bi ga da igram zahtjevnije stvari. Prvobitno pubG koji ima tragicnu optimizaciju, a i kao investicija za buduce stvari. Sto se tice ryzena, mislio sam da je on pretezito dobar za multitasking, stvari kao editing itd, a ne tolko za gaming? Ne u smislu da je prejak procesor, tim vise. Treba bit bomba za 1080ku. Ako ista znaci, duo monitoram trenutno sa LG 24gm77 i dellom U2312HM koji bi koristio na tom rigu. Imam dosta jadni SSD (mx300) koji bi se dalo prebacit eventualno u novi rig al mozda se nema smisla diberiti i uzet bolju/novu za novi rig. Placam kešZadnje izmijenjeno od: iWaxxy. 27.08.2017. u 03:38. |
#1943 |
Datum registracije: Aug 2017
Lokacija: Virovitica
Postovi: 1
Kupujem preko UziShopa. 1x Gigabyte GeForce GTX 1060 G1 Gaming 6GB 1x AMD Ryzen 5 1600 1x MSI B350 Tomahawk 1x Toshiba 1TB P300 3.5" 7.2k 1x G. Skill Aegis 8GB DDR4 3000Mhz 1x Fortron napajanje Raider S PSU 550W,80+ SILVER 1x Fractal Focus G, crno s prozorom, bez napajanja - Ukupno: 7 168,39 kn Imam samo par pitanja, da li da uzmem Tomahawk ili Mortar b350, ne vidim bas veliku razliku izmedu njih dvoje, jedino sto Tomahawk ima 2 pciex16 slota. Jesu li ramovi i napajanje dobri? |
#1944 |
Postovi: 14,584
iWaxxy R5 1600 ti je bolji od bilo čega intelovog u tom i sličnom cjenovnom rangu. Naravno uz gtx 1080 na 1080p bi uz nekakav i7 7700K (trenutno neisplativa kupovina) nasviran na tipa 4.5-4.9ghz možda imao pokoji fps više u pokojoj igri, ali to je i skroz druga cjenovna kategorija Monitori i ssd naravno mogu ostati bo0dix Napajanje i ram su OK. Tomahawk je bolja ploča Zadnje izmijenjeno od: Manuel Calavera. 28.08.2017. u 01:20. |
#1945 |
Postovi: 36
Hmmm. Sto mislis pod pokoji fps ? 5-10 ili 30-40?1600 zvuci kao best value, i investicija za ubuduce ako te razumijem. Kako bi onda izgledao best value gaming rig od 8-9k? Moze i prekoraciti koju stotku ako treba, po mogucnosti iz jednog shopa Je li uopce isplativo sada kupovati? Zadnje izmijenjeno od: coconut. 28.08.2017. u 08:36. |
#1947 |
Postovi: 1,612
Prije bi rekao 10-20 FPS-a (a za igre koje jos uvijek koriste jednu-dvije jezgre jos puno vise) klik Ali slazem se da je neisplativo sada kupovati sky/kaby lake konfe. Ili idi na ryzen ili cekaj intel coffee lake. |
#1949 | |
Postovi: 36
Jedino sto znam je da je 2018. |
#1950 | |
Postovi: 17,032
