#391 | ||
Postovi: 556
Code:
1 1049kB 256MB 255MB primary ext2 boot 2 257MB 21.0GB 20.7GB extended 5 257MB 21.0GB 20.7GB logical lvm Code:
udev 2.0G 4.0K 2.0G 1% /dev tmpfs 396M 628K 395M 1% /run /dev/dm-0 15G 3.0G 12G 21% / none 4.0K 0 4.0K 0% /sys/fs/cgroup none 5.0M 0 5.0M 0% /run/lock none 2.0G 0 2.0G 0% /run/shm none 100M 0 100M 0% /run/user /dev/sda1 236M 74M 150M 34% /boot Citiraj:
Code:
Information: You may need to update /etc/fstab. Code:
# /etc/fstab: static file system information. # # Use 'blkid' to print the universally unique identifier for a # device; this may be used with UUID= as a more robust way to name devices # that works even if disks are added and removed. See fstab(5). # # <file system> <mount point> <type> <options> <dump> <pass> /dev/mapper/graylog--vg-root / ext4 errors=remount-ro 0 1 # /boot was on /dev/sda1 during installation UUID=f3c82967-d226-4c5a-99bd-2ecb6a31adfc /boot ext2 defaults $ /dev/mapper/graylog--vg-swap_1 none swap sw 0 0 Code:
fd0 2:0 1 4K 0 disk sda 8:0 0 19.5G 0 disk ├─sda1 8:1 0 243M 0 part /boot ├─sda2 8:2 0 1K 0 part └─sda5 8:5 0 19.3G 0 part ├─graylog--vg-root (dm-0) 252:0 0 15.3G 0 lvm / └─graylog--vg-swap_1 (dm-1) 252:1 0 4G 0 lvm [SWAP] sdb 8:16 0 100G 0 disk loop0 7:0 0 0 loop loop1 7:1 0 0 loop loop2 7:2 0 0 loop loop3 7:3 0 0 loop loop4 7:4 0 0 loop loop5 7:5 0 0 loop loop6 7:6 0 0 loop loop7 7:7 0 0 loop Zadnje izmijenjeno od: Wuchko. 29.07.2017. u 11:44. |
#392 |
Datum registracije: Feb 2004
Postovi: 1,030
Bilo bi lakse citati da je u CODE tagovima. Po meni samo trebas nastaviti. Disk je tu, ali nema particije i filesystem. Code:
#kreiras particiju $ sudo parted -a optimal -- /dev/sdb unit compact mkpart primary ext3 "1" "-1" #kreiras fs $ sudo mkfs.ext4 /dev/sdb1 |
#393 |
Postovi: 556
Puno hvala na odgovoru! Ispravio sam prijašnji post. U međuvremenu sam uspio, no na nešto drugačiji način (logiran sam kao root user): Code:
$parted /dev/sdb (parted) -a optimal /dev/sdb mklabel gpt (parted) -a optimal -- /dev/sdb unit compact mkpart primary ext3 "1" "-1" (parted) quit $mkfs.ext4 /dev/sdb1 .... ![]() |
#395 |
Postovi: 556
Evo mene opet. Dakle, sada bih na radne stanice trebao instalirati Graylog Collector Sidecar da bi Graylog mogao prikupljati logove. I sve to uredno radi dok je GCS upaljen i vidljiv na radnoj površini, no ono što me muči je - kako ga dodati kao Windows service, znači da se vrti neprimjetno u pozadini? Na ovom linku postoje upute no uopće ne kužim na koji način ovo riješiti, posebno ove dijelove: Code:
$ C:\Program Files (x86)\nxlog\nxlog -u $ collector_sidecar_installer.exe Code:
$ C:\Program Files\graylog\collector-sidecar\graylog-collector-sidecar.exe -service install $ C:\Program Files\graylog\collector-sidecar\graylog-collector-sidecar.exe -service start Puno hvala! |
#396 | |
Postovi: 1,030
Skini NXLog i instaliraj. Ugasi servis koji se automatski pokrece Code:
$ C:\Program Files (x86)\nxlog\nxlog -u Code:
$ putanja/do/datoteke/collector_sidecar_installer.exe Code:
$ C:\Program Files\graylog\collector-sidecar\graylog-collector-sidecar.exe -service install $ C:\Program Files\graylog\collector-sidecar\graylog-collector-sidecar.exe -service start |
#397 |
Postovi: 556
Uspio sam pokrenuti, no sada dobivam poruku "Access denied". Ništa, prespavat' pa sutra isprobavat ponovno ![]() EDIT: šugavi AV je blokirao pokretanje, sad je sve ok (bar mislim). Zadnje izmijenjeno od: Wuchko. 31.07.2017. u 18:51. |
#398 |
..starija garda
Postovi: 3,278
Pitanje je možda više za neki drugi dio podforuma, VM i slično, ali da probam tu. Kupio sam 250hdd i stavio linux tek toliko da s vremena na vrijeme mogu ga malo probati. Stavio sam ZORIN OS u dual boot, i za sad sam zadovoljan. Pitanje je, s obzirom da mi se neda izlaziti iz windowsa, da li se može iskoristi ta instalacija linuxa da se pokrene virtualna mašina pa da iz windowsa vrtim linux?
#399 | |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,753
Vjerojatno ima neki export u OVF pa ga mozes vrtiti u bilo kojoj virtualki poslje.
#400 | |
Lokacija: München/Varaždin
Postovi: 4,800
https://www.google.hr/search?q=conve...hrome&ie=UTF-8 ![]() |
#401 |
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,765
Od kada sam prešao s Linux Mint 17.3 na 18.2 (čista instalacija, nije nadogradnja), ne radi mi VPN. Znači uredno, s istim openvpn datotekama napravim import openVPN veze kroz GUI. Sve prođe bez greške, uredno se spoji na VPN server, ali internet ne radi, tj. niti jedna stranica se ne može učitati. Ima li tko ideju kako riješiti? VPN server 100% radi, ako se spajam preko mobitela ili drugih računala radi bez greške. |
#402 |
Postovi: 642
"Niti jedna stranica se ne moze ucitati" nije bas neki podatak. Koji error dobijes? Jel ti resolva DNS ime u adresu? Jel imas spojivost kad pingas neku IP adresu npr. 8.8.8.8? Kad si spojen na VPN pogledaj si rute (netstat -r) i napravi ping pa traceroute na neku IP adresu za koju znas da bi trebala ici preko VPN-a. Moguce da je nesto s firewallom isto, mozda drugacija defaultna pravila na 18.2. |
#403 | |
Lokacija: Ramura
Postovi: 2,765
2. Kada radim ping, npr. na pcekspert.com, uredno mi se pojavi: Code:
ping pcekspert.com PING pcekspert.com (185.103.217.199) 56(84) bytes of data. 3. Ne mogu pingati 8.8.8.8, 100% packet loss. 4. netstat -r Code:
Kernel IP routing table Destination Gateway Genmask Flags MSS Window irtt Iface default 10.4.0.1 0.0.0.0 UG 0 0 0 tun0 default unknown 0.0.0.0 UG 0 0 0 enp3s0 10.4.0.0 * 255.255.0.0 U 0 0 0 tun0 link-local * 255.255.0.0 U 0 0 0 enp3s0 185.189.112.10 unknown 255.255.255.255 UGH 0 0 0 enp3s0 192.168.1.0 * 255.255.255.0 U 0 0 0 enp3s0 Inače, VPN je podešen automatski, samo sam napravio import .ovpn datoteke, i inače je to radilo bez problema, ali evo, sada ne. Pokušao mijenjati razne postavke u GUI, ali ništa nije urodilo plodom, pošto ukoliko idem ručno po .ovpn datoteci i provjeravam sve u GUI, izgleda mi da je sve uredno postavljeno. |
#404 |
Postovi: 642
Meni se cini da je ovo visak: Code:
Kernel IP routing table Destination Gateway Genmask Flags MSS Window irtt Iface default 10.4.0.1 0.0.0.0 UG 0 0 0 tun0 default unknown 0.0.0.0 UG 0 0 0 enp3s0 10.4.0.0 * 255.255.0.0 U 0 0 0 tun0 link-local * 255.255.0.0 U 0 0 0 enp3s0 185.189.112.10 unknown 255.255.255.255 UGH 0 0 0 enp3s0 192.168.1.0 * 255.255.255.0 U 0 0 0 enp3s0 Code:
netstat -nr |
#405 |
Lokacija: Ramura
Postovi: 2,765
Code:
Kernel IP routing table Destination Gateway Genmask Flags MSS Window irtt Iface 0.0.0.0 10.4.0.1 0.0.0.0 UG 0 0 0 tun0 0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 enp3s0 10.4.0.0 0.0.0.0 255.255.0.0 U 0 0 0 tun0 169.254.0.0 0.0.0.0 255.255.0.0 U 0 0 0 enp3s0 185.189.112.10 192.168.1.1 255.255.255.255 UGH 0 0 0 enp3s0 192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 enp3s0 |
#407 |
Lokacija: Histria
Postovi: 1,242
Imam dva pitanja. 1) dali postoji koji program bolji/brži od firefoxa, a opet jednako funkcionalan, troši mi dosta rama? 2) di mogu u linux mintu pogledati hardware specs koji se nalaze u mojoj konfiguraciji?
ševa! ![]() |
#410 | |
Lokacija: Home
Postovi: 2,186
Net mora ići kroz 192.168.1.1. Kad si tu rutu obrisao, naravno da nije pomoglo dakle 0.0.0.0 - sav ostali promet guraj kroz lokalnu mrežu koja ima gateway 192.168.1.1 koristeći interface enp3s0 10.4.0.0 mrežu idi kroz gateway 0.0.0.0 koristeći interface tun0 koji je tvoj vpn |
#412 | ||
Datum registracije: Mar 2010
Postovi: 2,057
- Palemoon - nisam ga nikad probao ali znam par ljudi koji su bili jako zadovoljni njime Jedan tekst na Hr gdje autor razmišlja što koristiti ako FF ode u bananu. Citiraj:
Code:
lshw Zadnje izmijenjeno od: bertone. 22.09.2017. u 00:04. |
#413 | |
Postovi: 4,800
2 - lshw ![]() |
#414 |
Ape
Datum registracije: Jan 2012
Postovi: 157
Bok, danas sam se odlučio prebaciti s "prozora" na Linux u potpunosti tako da ću malo visiti ovdje od sada ![]() U svakom slučaju, imam sharkoon tipkovnicu i miša, i TP-link wi-fi adapter za PC, ništa od toga ne radi u Mintu. Jel se to može kak složit jer ovak mi je totalno propao plan prebacivanja, mogu upalit komp i gledat desktop ![]() P.S. imam i laptop lenovo thinkpad t420, na njemu sve normalno radi ![]()
#415 | |
Postovi: 2,057
#416 |
Ape
Postovi: 157
#417 | |
Postovi: 2,057
2. ništa jednostavno nisam našao 3. https://forums.linuxmint.com/viewtopic.php?t=233212 |
#419 |
Postovi: 2,057
Nije jedini koliko sam vidio sa tom tipkovnicom i mišem koji ima problema na Linuxu. Imao sam i ja problem sa nekom backlight Genius tipkovnicom koja je malo radila malo ne na Linuxu pa sam se vratio na IBM mod.M i sa njom nikakvih problema ![]() |
#420 |
Ape
Postovi: 157
Ma vidim, trazim cijelo popodne neko rjesenje ali neuspjesno. Najbolje mi otic po drugu tipkovnicu i mis ako mislim vec koristit linux skroz. Malo me to odbija moram priznat. A kad prikljucim mis i tipkovnicu na laptop rade normalno ![]() ![]()
