Staro 18.04.2017., 09:38   #61
b1tterman
Takozvani influenser
b1tterman's Avatar
Lokacija: Dublin
Postovi: 649
kupio jučer da se malo igram i igra je toliko neoptimizirana i clunky da ću tražiti refund i pričekati da vidim razvoj situacije.
b1tterman je offline   Reply With Quote
Staro 18.04.2017., 20:55   #62
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,809
Autor b1tterman Pregled postova
Kviteru
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
Staro 18.04.2017., 22:52   #63
b1tterman
b1tterman's Avatar
Lokacija: Dublin
Postovi: 649
vratim se čim još malo ispeglaju igru. koncept je super ali izvedba horrendous
Staro 19.04.2017., 09:19   #64
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,777
Early access igra
xGAME je offline   Reply With Quote
Staro 19.04.2017., 12:05   #65
Necto
Necto's Avatar
Postovi: 747
Known issues
  • The motorbike leans slightly to the right when being driven straight.
  • The tires of the motorbike cannot be shot out at the moment
  • [Non-English Players] There are some mistranslated in-game texts and they will be shown in English
Client Performance Improvements
  • Made some improvements to address the issue of FPS drops when opening the inventory UI
  • Reduced the load on the CPU through instance rendering so that the GPUs can function to their full capabilities
  • Made improvements to address the issue of FPS severely dropping when in the vicinity of Yasnaya, Polyana & Georgopol
  • Rendering performance on PCs with minimum system requirements has been improved
  • Graphic performance and quality on PCs with minimum system requirements has been improved
Server Performance Improvements
  • Performance improvements have been made with relation to the items spawned in the world
Content Updates
  • Added Vector SMG. A very powerful SMG most appropriate for short to mid-range combat that is spawned in the world
  • Added Motorbike w/ sidecar. A sidecar-less version will be added in a future update
  • Added a 2X Aimpoint scope
  • Added a Ballistic Mask
  • Added 3 new color variations for the Dacia
  • Added the crossbow back into the game
World
  • Adjusted the density of environmental elements to be identical across all graphic options
  • Adjusted object placement to address issues of characters getting stuck
  • Adjusted placement of trees that were spawning inside houses or above the terrain
  • Adjusted the frequency of thunder sound effects
UI
  • Revised certain system messages and item descriptions.
  • Added descriptions for attachments
  • The dead team-mate icon will now disappear after a certain time and distance when in team modes
  • Map markers are now visible to all teammates
  • Names of teammates now appear on the world map
Gameplay
  • You are now able to move sideways and backwards in the REVIVE state
  • The REVIVE timer will no longer decrease when a team mate is attempting to revive you
  • When attempting to revive a team mate, the reviving timer icon will now also be visible to the player being revived
  • Adjusted the character position slightly when in the REVIVE state
  • Made improvements to address the issue of characters shaking while being spectated
  • You are now able to open the world map when spectating
  • You can now view the casting bar when the teammate you are spectating uses heal and/or boost items
  • You can no longer use heal and/or boost items when in water
Action/Gunplay
  • Adjusted the overall balance on all attachments
  • Adjusted the overall balance on Assault Rifles
  • We will continue to balance all weapons and attachments throughout Early Access
  • Fixed the issue that caused cars to temporarily stop when their tires get shot out
  • You can now sprint when in the crouch stance
  • Fixed the issue of “Armed/Unarmed” state not being applied when there are delays in the server network
  • The blood hit effect size now varies according to the weapon caliber
  • You can now move when in aiming and/or scoping in the prone state
  • Fixed an issue with the sitting position of the character in the back-right seat of the UAZ
  • Fixed an issue with the position of the left hand when reloading the AWM
  • Fixed an issue where aiming from vehicles was not accurate
  • The positions of bullet hits are now the same for both yourself and the others
  • Fixed an issue that caused the hit box for the head to be slightly larger than the actual head
  • Adjusted the ragdoll physics for dead characters to be more natural
  • Fixed an issue that caused the character to use the wrong aim offset when using the freelook function while holding a grenade
  • Fixed an issue that caused the landing-from-a-high-altitude motion to seem awkward when holding a pistol
  • Improved the quality of zoomed-in scope views
  • Bolt actions are now triggered even after the final shot has been fired, so that you can starti re-firing as soon as reload is complete
  • Added swimming animations to go upwards and downwards
  • Fixed an issue that caused the reticle to appear even when in situations where you are not able to shoot
  • Your character now uses a different animation when in crouch stance while holding a melee weapon
  • Made improvements to the reload animations for the M249
  • Made improvements to the reload animations for the P1911
  • The muzzle flash is now brighter than before and is now visible from a longer distance
Sound
  • There are now sound effect differences for supersonic and non-supersonic bullet speeds
  • Made adjustments so that the sound of the bullet flying through air doesn’t play when shots are fired from a short distance from your character
  • You can now figure out what floor the opponents are at just by listening to their footsteps
  • Adjusted the firing sound of the SKS in mid to long range combat
  • Adjusted the volume of the footsteps
Miscellaneous
  • We have opened a test server to better manage our content and secure stability for our live environment updates
  • Additional in-game texts have been localized
Bug fixes
  • Fixed a bug that caused some buildings to not be visible at long distance
  • Fixed a bug that caused a knocked out player to be ejected in front of a vehicle. If knocked out in a vehicle, you will now be ejected to the side
  • Fixed a bug that caused weapons to clip through walls
  • Fixed a bug that caused the icons for certain “pants” items to not appear correctly
  • Fixed a bug that caused the PLAYERUNKNOWN shoes to not render properly
  • Fixed a bug that caused the hit effects to play at random
  • Fixed a bug that caused bald characters to have hair
  • Fixed a bug that caused disconnects after 5 minutes into a match
Early Access Month 1 Update
http://steamcommunity.com/games/5780...73219748632258
This patch will be deployed for both clients and servers Thursday, April 20, 5PM KST/1AM PDT/8AM UTC and is expected to take approx. 1 hour to complete.
Early Access - Month 1 - Patch Notes
Known issues
Content Updates
World
UI
Gameplay
Action/Gunplay
Sound
Miscellaneous
Bug fixes
Necto je offline   Reply With Quote
Staro 26.04.2017., 01:20   #66
Mogy
Hala Madrid!
Mogy's Avatar
Postovi: 1,320
Ima neki kvalitetni igrač da mu treba duo? Da ima mozga naravno i makar sitno skilla i da voli igrati timski, a ne ić rambo mode svaki game i igrat kao da solo igra. Ova ekipa sa kojima sam igrao duo, svaka im čast, ali mi ne paše njihov stil igre i način razmišljanja tokom igre tako da tražim novog suigrača/e za duo ili squad. Za sebe mogu reć da sam ok igrač, niti pretjerano dobar, a bogami niti loš. Rekao bih zlatna sredina Javite se na pm ako ste zainteresirani
Mogy je offline   Reply With Quote
Staro 28.04.2017., 08:20   #67
nub
PREMIUM
nub's Avatar
Datum registracije: Dec 2014
Postovi: 2,137
Probao i ja. Uzeo sa steama, odigrao nešto više od sat vremena i vratio natrag
Igra je ono, ok, definitivno zanimljiv koncept. Naravno, jasno vidi da je još u ranoj fazi. To se najviše osjeti na kretnjama koje su još dosta nedorađene.
Inače, igra mi je radila ok (istina, igram s dosta low postavkama sve te multiplayer pucaljke ).
Al eto, sve skupa mi jednostavno nije leglo. Nemam puno vremena za gejmanje, pa onda kad uhvatim nešto vremena nekak nemam živaca čučat u nekom grmu ili tavanu po 10+ minuta, već hoću akciju odmah, a ovdje se to skupo plaća
Staro 29.04.2017., 10:48   #68
extasy
Lokacija: st
Postovi: 370
Evo sinoc pala prva duo pobjeda i moram rec da mi se igra stvarno sviđa! Za razliku od ostalih early access money sinkova ovo je skroz pristojno.
Jedino malo da srede performance igre ali ni to nije toliko strasno.
extasy je offline   Reply With Quote
Staro 14.05.2017., 21:27   #69
Mogy
Hala Madrid!
Mogy's Avatar
Postovi: 1,320
Zadnje izmijenjeno od: Mogy. 29.05.2017. u 07:48.
Staro 10.06.2017., 15:31   #70
donbon
Datum registracije: Jun 2011
Lokacija: Katolibanovina Apsurdistan
Postovi: 175
Kupio sam igru i mogu reći da je koncept igre vrlo dobar.Igra je u vrlo ranoj fazi razvoja ali koliko čitam PUBG forum developeri slušaju community.To je pohvalno za vidjeti.
Zadnje izmijenjeno od: donbon. 10.06.2017. u 19:22.
donbon je offline   Reply With Quote
Staro 07.07.2017., 16:44   #71
marijo84
marijo84's Avatar
Lokacija: Opuzen
Postovi: 39
Dosta se radi na igrici i zanimljiv koncept. Nadam se da će nastavit ovako
Svi Hrvatine a svaki skače ka klokan čim čuje Cecu il neki hit turbo folka...
marijo84 je offline   Reply With Quote
Staro 13.07.2017., 22:02   #72
Lun
Lun's Avatar
Datum registracije: Jan 2010
Postovi: 406
Lun je offline   Reply With Quote
Staro 13.07.2017., 22:10   #73
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,277
Ueeeeeeeeeeeeeeeee
Saš vidit kad nitko ne bude igrao na njima
Staro 14.07.2017., 00:49   #74
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor Neo-ST Pregled postova
Ueeeeeeeeeeeeeeeee
Normalno da nece, jer koliko god svi kukali za 3rd PV da je built-in wallhack, svi ga koriste.
Ja bih mogao prati solo na first person view serverima.
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 14.07.2017., 08:23   #75
nub
PREMIUM
nub's Avatar
Postovi: 2,137
Ma valjda bu igralo nešto ekipe.
Razlog da ponovno skinem igru
Staro 15.07.2017., 13:10   #76
prileee
laser
prileee's Avatar
Postovi: 2,338
Eto ga fps igračine, dočekali ste i taj dan. Sad perite taj hardcore mode!
Staro 28.07.2017., 11:52   #77
prileee
laser
prileee's Avatar
Postovi: 2,338
Toliko se igra ovaj first person da ne stigne ekipa komentirat kakav je, GG!
Staro 28.07.2017., 14:34   #78
xGAME
xGAME's Avatar
Postovi: 4,777
Zašto si ti tako buthurt ako netko želi realističniji, više fer i imerzivniji gameplay?
PUBG je bio zamišljen kao FPS, a ne TPS, ali kad je došla ekipa s dubokim džepovima su htjeli prvo TPS izbaciti i fokusirati se na to.
Pa sam kreator igre je rekao da je zamišljeno kao FPS što mu je i cilj ispolirati na kraju, jer je i sam igrao samo na FPS battle royale serverima u Armi.
Sad će biti izbor, tko želi third person imat će to na izbor, a tko želi fps only imat će i taj mod. Nema ničeg lošeg tu.
A jedan i drugi su daleko od ispoliranog modela jer je sve clunky još.
Staro 28.07.2017., 15:18   #79
sharyn
sharyn's Avatar
Datum registracije: Jun 2010
Lokacija: grubišno polje
Postovi: 564
Autor prileee Pregled postova
first person dolazi tek 3.8
sharyn je offline   Reply With Quote
Staro 28.07.2017., 21:11   #80
donbon
Postovi: 175
PUBG je premašio 4.000.000 prodanih jedinica i takve velike brojke puno govore o kakvoj se kvaliteti igre radi.
Igra je u early alpha fazi, slobodno se može napisati ¨prototip¨.
Velika većina igraća ne razumije ili ne žele razumijeti što taj termin znači? (detaljnije u drugom dijelu teksta)
PUBG je igra gdje se mora igrati timski, gdje je poželjno igrati u grupi jer imate veće šanse za preživjeti.
Možete igrati sami ¨lone wolf¨ ali to je već jedna druga dimenzija u igri.
u PUBG je važno preživjeti, dok pobjeda dolazi druga na red.Ako ćete od samog početka ići na pobjedu, iz iskustva ostati ćete razočarani i naravno mrtvi.
Tko je zaslužan za ovakvu veliku popularnost PUBG i takve velike prodajne brojke u tako ranoj fazi?
community koji je znao šta hoće i Developeri koji su od samog početka pomno pratili i slušali svaki glas, dobili smo... PUBG.
Moram napisati par riječi od PUBG developerima jer oni to apsolutno zaslužuju.Ovo je rijetkost u gaming industriju da developeri tako surađuju sa community-em i slušaju želje.
Veliki Update-i su redoviti na mjesčnoj bazi + manji update-i po potrebi tjedni.
Kako ukratko opisati PUBG gameplay?
- vrlo napeto
- ponekad vrlo stresno ( do PTSP mjere)
- zamrziti ćete prozore i vrata
- zbog random loota ponekad frustrirajuće.Kada očekujete da ćete na tom mjestu nešto naći, ono nije tamo.
- pravi battle royale
PUBG Balkanska scena
Za sve nas sa ovih prostora ovo je najtužnijij dio priče u ovoj odličnoj igri.
Igra je u vrlo early access fazi, dok balkanski dio populacije ne zna i neće razumjeti što to u stvari znači.
način razmišljanja:
¨ja sam kupio PUBG i to je to, to je full igra a ovo su samo update-ovi¨
Osobno imam za sada 350 sati u ovoj igri i već sada iz iskustva mogu napisati da sam svašta doživio.
Kako bi se opisala trenutna balkanska scena?
Tokisčan mix CSGO i WOT-a.
Igrao sam s balkanskim igračima koji:
- igraju PUBG samo radi statistike (žele pobjediti pod svaku cijenu ,ali uporno ignoriraju timski igru i nemaju osnovno znanje o direktnoj komunikaciji kada su u grupi)
- igraju PUBG kao da igraju Call of duty i GTA ( imao sam priliku svijedočiti sceni gdje je igrač pokušava autom pregaziti neprijateljskog igrača, ali nije računao na drvo ispred tog igrača)
- 14 godišnjaci koji mislie da igraju pokemone online ali ovi pokemoni imaju M16 i kacige
- igrao sam PUBG sa vrlo labilnim igračima ( jedan mi je zaspao tokom igre, ostavio prst na push to talk i hrče)
- igrao sam sa igračem koji igra ovu igru samo da bi loot-ao, i to je to.Njega ubijanje ne zanima.
Posebna priča ide za PUBG balkanske igrače koji ganjaju samo statistiku, ali nemaju osnovno znanje za timsku igru i komunikaciju.
Koji su si umislili u svojim glavama da nakon 70 sati igri su budući pro ESL igrači.
Uz sve to velika toksičnost optužujući i uvjeravajući druge u grupi da su krivi za njihovu neučinkovitost tokom meča u igri.
Imao sam priliku igrati sa igračem koji se ponašao kao drill sergeant.Taj nije mogao komunicirati normalnim tonom glasa jer se uvjek derao na nas kuda moramo ići, kuda ne smijemo ići, u koju kuću smijemo ući, u koju ne. Uvjek optuživajući nas kada pogine za svoju rush call of duty taktiku za koju je on uvjeren da funkcionira u PUBG svijetu.
Svjedoćio sam na jednom hrvatskom discordu gdje je vlasnik tog discorda zaprijetio čovjeku koji ima malo djete.Ako ti to djete još jednom zaplače izbaciti ću te sa discorda.
Također sam bio svijedok na tom istom hrvatskom discordu gdje je isti izbacio čovjeka sa discorda jer se ovaj odvojio od grupe jer je razgovarao sa ženom.
U ovoj igri kratka i direktna komunikacija je esencijalna.To kod nas balkanaca jer vrlo teško probavljivo + karakter sa kratkim fitiljem.
Optuzivati drugog u svom squadu tokom igre za vlastite greške pridonosi vrlo brzo rasapadu sistema bez ikakve šanse za pobjedu.
Zadnje izmijenjeno od: donbon. 28.07.2017. u 21:32.
Staro 29.07.2017., 14:35   #81
xGAME
xGAME's Avatar
Postovi: 4,777
S kakvim ti to ljudima igras?
I zasto bi uopce igrao s random ljudima?
Osobno nema sanse da se team-upam s random osobom i ocekujem neku kvalitetnu igru. To je u svakoj igri tako, a ne samo ovdje.
Staro 29.07.2017., 15:02   #82
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
+1, ako od ekipe na TSu nikog nema, ne igram pubg, jednostavan recept. Cuva zivce i periferiju Dakle 3.8 se ocekuje pravi fps?
Staro 29.07.2017., 15:40   #83
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,277
Ako bude naših s TS-a koji će igrat fps verziju, uzmem i ja.
Sent from my mobile using Tapatalk
Staro 30.07.2017., 10:21   #84
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Ajde, napokon jedna igra da se okupi barem dio PCe ekipe...
Staro 31.07.2017., 09:44   #85
prileee
laser
prileee's Avatar
Postovi: 2,338
Autor xGAME Pregled postova
Nisam nimalo butthurt, samo podizem malo topic. I ne kazem da ima ista lose u igri, dapace drago mi je da ce bit na izbor tps/fps serveri.
Staro 31.07.2017., 09:58   #86
brodjo
Playmaker
brodjo's Avatar
Lokacija: Osijek/Wien
Postovi: 1,660
Gdje se okuplja PCE ekipa? Igram i ja svaki dan skoro pa mi treba ljudi za duo/squad. Evo Steam pa me dodajte tko hoce
brodjo je offline   Reply With Quote
Staro 31.07.2017., 11:22   #87
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,221
Staro 31.07.2017., 12:51   #88
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Ako ce te igrati na TS javite se na PM, tko zeli jel. Osim manskog on nemoze
Staro 31.07.2017., 12:57   #89
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,277
Još da se vrati triumph
Staro 31.07.2017., 13:54   #90
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,226
Bas on treba
