Staro 19.06.2017., 15:18   #1411
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Autor Sonim Pregled postova
Trebalo bi ici bez problema, ali ipak da provjerim :-D
Na x230 preko dp se može bez problema spojiti 2k monitor?
Piše da može:
Maximum external resolution: 2560x1600@60Hz (DisplayPort via optional Mini DP cable);
1920x1200@60Hz (single-link DVI-I via optional Mini DP cable); 2048x1536@75Hz (VGA)
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 21.06.2017., 16:10   #1412
ThePornstar
Postovi: 4,403
Ono o čemu se šuškalo je potvrdio David Hill - za 25. godišnjicu ThinkPada dolazi Retro ThinkPad!
Link
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 21.06.2017., 18:36   #1413
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,057
Link
Iako znam da neće to napraviti, ali tako bih volio 14" 4:3 LCD sa AHVA matricom (mat naravno) + da neće cijenom otići debelo preko 2k€ ... ahhh želje
... u svakom slučaju, tnx za info
Staro 21.06.2017., 19:40   #1414
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
prerano sam kupio thinkpad
Spoiler alert!
Staro 21.06.2017., 19:47   #1415
Dottore
Dottore's Avatar
Postovi: 7,644
Sent from my Htc U11
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Zadnje izmijenjeno od: Dottore. 21.06.2017. u 19:54.
Staro 22.06.2017., 10:46   #1416
GoGzS
GoGzS's Avatar
Lokacija: Novi Zagreb
Postovi: 979
Jao, da bude ono sto su ankete zahtjevale... jos kad bi sjeo neki Zen u njega, pa do 2k EUR bi se isplatilo rastegnuti
Staro 22.06.2017., 13:58   #1417
ThePornstar
Postovi: 4,403
Autor GoGzS Pregled postova
Prije će bit 4:3 ekran kakvog bi htio Bertone, nego AMD u premium ThinkPadu
Vidjet ćemo. Mislim da bi možda čak mogla biti neka limitirana serija s 4:3 omjerom za entuzijaste, ali u tom slučaju će netko samo za njih raditi seriju takvih ekrana. Izglednije je da će bit 16:10, što također uopće nije loše, dapače (puno bolje od 16:9).
Cijena, ak se uopće pojavi kod nas, bez beda 20k kuna
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 22.06.2017., 14:45   #1418
bertone
bertone's Avatar
Postovi: 2,057
Kako je 25 godišnjica krajem godine, tako bi taman u njega mogao sjesti kakav i7 HQ Cannonlake
Pa ja isto zapravo očekujem 16:10 (3840x2400 pix) iako bi 4:3 (3200x2400 pix) u današnje vrijeme bio potez do jaja
Tako i ja razmišljam... minimum je 15k kn, očekivani iznos oko 20k kn, a sve preko toga je rizik da će ga kupiti ipak samo entuzijasti i fanovi
Staro 22.06.2017., 14:58   #1419
akoj
lijevo smetalo
akoj's Avatar
Datum registracije: Jan 2014
Postovi: 1,120
16:10 ili 3:2 bi bili ok. I neka bude neka lowend opcija s normalnim ekranom eventualo ts.
Nvisen Y-GX01 // BMAX Y11
akoj je offline   Reply With Quote
Staro 22.06.2017., 15:25   #1420
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,054
Kupiti dva komada - jedan za korištenje, drugi za nekoliko godina za višu cijenu
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 22.06.2017., 23:46   #1421
Dottore
Dottore's Avatar
Postovi: 7,644
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 28.06.2017., 23:04   #1422
cdanijel
Ehem.
Work hard, play hard...
Sent from my Redmi Note 4 using Tapatalk
Staro 29.06.2017., 00:22   #1423
bertone
bertone's Avatar
Postovi: 2,057
Strašno, izgurali te s trosjeda
Staro 29.06.2017., 08:13   #1424
Frung
Frung's Avatar
Lokacija: zg westside
Postovi: 621
Koja crna banda razbojnika
Frung je online   Reply With Quote
Staro 29.06.2017., 10:06   #1425
robik666
Datum registracije: Feb 2012
Lokacija: into the void
Postovi: 345
Poštovanje
Javlja se budući član thinkpad obitelji, na ebayu sam uzea jednog t 430 za 1100 kn, klasična konfiguracija s 4 gb rama i hard diskom.
Pa me zanima ima li ikakvih caka, tajni za dobar rad? Mislim stavit win 7, a u skorasnjoj budućnosti jos uzet 4 gige rama i ssd. Imaju li kakvi programi koje bi bilo dobro instalirat?
Zahvaljujem
robik666 je offline   Reply With Quote
Staro 29.06.2017., 10:51   #1426
cdanijel
Autor robik666 Pregled postova
Poštovanje
Zahvaljujem
Nisam siguran zašto w7. Ti strojevi vrte štogod te volja.
Personal flavour je Mint ako je za po doma i za dokoličarsko surfanje i w10 ako trebaš na njemu actually raditi...
Staro 29.06.2017., 10:54   #1427
cdanijel
Autor bertone Pregled postova
Anin N20 ili kako se zove Chromebook.
Yoga 11e / Mint
X1 Carbon / Mint
X270 / W10
11e / Chromebook
Još je jedan T550 u radnoj sobi i thinkcentre radna stanica.
Žena koristi Lenovo P2 Vibe, a moj Lenovo Phab 2 Pro je na servisu (kamera ja prestala raditi)...
Dodat ću si prezime...
Staro 29.06.2017., 12:30   #1428
bertone
bertone's Avatar
Postovi: 2,057
Poštovanje
Zahvaljujem
Čestitke na dolasku u klub
Ako baš moraš (želiš) koristiti Win, skineš Lenovo System Update i on će sam pronaći i ponuditi sve potrebno... uostalom, dok čekaš da stigne taman imaš vremena polako pročitati cijelu temu o ThinkPad laptopima
Autor cdanijel Pregled postova
Slažem se da je grijeh na TP koristiti WIndowse jer Linux tako lijepo radi na ThinkPadima (obrati potrošnju rama kod Archa na T420 - 2. slika), čak je i autonomija rada na bateriji bolja što mi je bilo teško za povjerovati dok sam nisam isprobao na nekoliko modela TP i različitih distribucija.
Također, danas sutra za siću ubodeš dock na koji spojiš periferiju i koristiš laptop kao desktop kad si doma/na poslu.
Staro 29.06.2017., 13:14   #1429
robik666
Postovi: 345
Ok, sugestije uzete u obzir..pa se cujemo ako bude kakvih problema
Staro 29.06.2017., 19:15   #1430
Dottore
Dottore's Avatar
Postovi: 7,644
Pošto sam već dugo pikirao na X230 kao mogućnost nadogradnje jednako kao brat T430 (isti i5 3320M i 16Gb) , na kraju sam uzeo X240. Isprva sam bojao zbog limita 8Gb i jedan USB manje. Ali, prevario sam se i teško ću preći preko 3Gb u radu sa browserom sa 10 tabova.
Moram priznati da sam prilično jako oduševljen sa x240, funkcionalan ,mobilan i prelagan s obzirom da ima samo jednu vanjsku 6 cell bateriju (može nadodati još u unutarnju)
Jedini minus je clickpad koju ne prepoznaje učinke lijeve i desne tipke. Ponekad malo živcira pa ću naručiti od modela x250.
A sad ukratko o bateriji (već sam napomenuo o vanjskom 6 cell i nema dodatni unutarnji), jučer sam istestirao. Browsanje i prebacivanje sa USB3.0 2 puta po 50Gb na prijenosni disk (mehanički) i nešto sam sitno dogurao namjanje 4 sat. Bateriji je ostalo još 67%. Najsmiješnjiji je mali punjač 45w i manji je od 65w. Mali buco od punjača Na struji odnosno ne puni bateriju i glumi mrtav hladan. U radu (stuja i punjenje) i zna jače zagrijati kao stari 90w punjač.
U planu mi je, dodatna interna baterija, m.2 2242 SSD 256Gb. Za sad prioritet touchpad od X250.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 01.07.2017., 12:49   #1431
chillout23
Your God is in your mind.
chillout23's Avatar
Datum registracije: Jun 2017
Lokacija: Planet Earth
Postovi: 642
Bok društvo
Koja Linux distribucija bi najbolje legla na T60 (3GB RAM)?
Mjesto rođenja: Zemlja, Rasa: čovjek, Politika: sloboda, Religija: ljubav
chillout23 je offline   Reply With Quote
Staro 01.07.2017., 13:45   #1432
Dottore
Dottore's Avatar
Postovi: 7,644
Mislim Mint bi legao.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 01.07.2017., 14:27   #1433
bertone
bertone's Avatar
Postovi: 2,057
Radit će svaki, a najmanje resursa će trošiti Arch u kombinaciji sa Xfce DE.
Staro 01.07.2017., 19:15   #1434
schetz
schetz's Avatar
Postovi: 1,570
Debian s XFCE ne bi trebao trošiti puno više, čisto ako je nekome ta instalacija više friendly ..
https://www.reddit.com/r/linux/comme...rison_updated/
U principu koliko čitam, Thinkpad i Linux su divna kombinacija, tako da ne bi trebalo biti problema ni sa čim.
schetz je offline   Reply With Quote
Staro 01.07.2017., 21:53   #1435
chillout23
chillout23's Avatar
Postovi: 642
Ok. Hvala na odgovorima
Staro 01.07.2017., 21:58   #1436
cdanijel
Autor chillout23 Pregled postova
Bok društvo
A sve su ista sreća. Koristi što je najjednostavnije za održavanje. Trenutačno ti je Mint prilično raširen, popularan, ima jak community, radi na čemu god...
Staro 02.07.2017., 09:23   #1437
chillout23
chillout23's Avatar
Postovi: 642
Shvatio
Hvala
Staro 05.07.2017., 09:01   #1438
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,237
Ubuntu server minimal install s xfce
Staro 06.07.2017., 22:53   #1439
Dottore
Dottore's Avatar
Postovi: 7,644
eGPU using an x1 Carbon 5th gen
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 12.07.2017., 14:46   #1440
cdanijel
FYI, u pawn shopu u Importanneu imaju T540P s i7, 250GB SSD, IPS 2880x1620, 8/12 GB memorije za cca 2700-3000 Kn.
Stanje 9/10.
