#1891 | |
Datum registracije: Mar 2017
Postovi: 12
Evo SNR per tone... ![]() Novi prekid danas oko 18:10... ![]() I novi Connection speed očito nakon prekida... ![]() Prekid očito popraćen hrpom errora... Snimanje je nastavljeno cijelo vrijeme, sad već skoro 30 sati. Ove oscilacije u brzini oko 17:30 su najveće što su se desile u tih tridesetak sati) izuzev dva prekida. EDIT: Grmilo je oko pola šest i tada se nakupila hrpa tih grešaka, kod prekida se vec smirilo, ali moguce da je to (nevrijeme + errori) uzrok ovog prekida? Code:
VDSL Training Status: Showtime
Mode: VDSL2 Annex B
VDSL Profile: Profile 8b
Traffic Type: PTM Mode
Link Uptime: 0 day: 2 hours: 4 minutes
VDSL Port Details Upstream Downstream
Line Rate: 7.166 Mbps 37.887 Mbps
Actual Net Data Rate: 7.167 Mbps 37.888 Mbps
Trellis Coding: ON ON
SNR Margin: 8.6 dB 6.9 dB
Actual Delay: 0 ms 0 ms
Transmit Power: 6.7 dBm 18.6 dBm
Receive Power: 0.2 dBm 3.1 dBm
Actual INP: 13.0 symbols 28.0 symbols
Total Attenuation: 7.2 dB 15.5 dB
Attainable Net Data Rate: 8.637 Mbps 40.552 Mbps
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 11.3 38.9 N/A N/A 20.8 48.0 N/A
Signal Attenuation(dB): 11.3 38.3 N/A N/A 18.0 47.6 N/A
SNR Margin(dB): 8.6 8.6 N/A N/A 7.0 6.9 N/A
Transmit Power(dBm):- 1.1 5.8 N/A N/A 18.2 7.7 N/A
VDSL Counters
Downstream Upstream
Since Link time = 4 min 33 sec
FEC: 1848 1
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 3 min 29 sec
FEC: 23 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 780 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 17 hours 18 min 29 sec
FEC: 6586717 59
CRC: 1474 0
ES: 87 0
SES: 25 0
UAS: 45 24
LOS: 1 0
LOF: 5 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 21806 2
CRC: 3504 0
ES: 60 0
SES: 60 0
UAS: 219 159
LOS: 1 0
LOF: 8 0
LOM: 0 0
Total time = 1 days 17 hours 18 min 29 sec
FEC: 6822701 68
CRC: 4979 0
ES: 148 0
SES: 85 0
UAS: 646 565
LOS: 2 0
LOF: 13 0
LOM: 0 0
Zadnje izmijenjeno od: Vitzco. 21.06.2017. u 22:16. |
#1892 |
Lokacija: doma
Postovi: 2,899
Nije nego se ipak pokazalo da sam opravdano sumnjao na oscilacije iako informacije koje si davao i trenutno stanje nije ukazivalo na iste. No kako se sada linija snima duze izaslo je na vidjelo. E sad, po ovome kod resinkanja router je povukao vecu brzinu ( 37Mbps ) i margina je sukladno tome odmah manja i ide prema 6dB sto bi znacilo da oni nista nisu tebi smanjili nego eventualno resetirali port na DSLAM-u i to je to... Parica je takva kakva je, SNR per tone je los u dijelu visljih frekvencija, ako prebacis prikaz u bitloading tablu onda ces vidjeti da u tom drugom djelu doslovce imas "rupu" tj. neki tonovi ne nose ni jedan bit. Prije nego ih ides zivkati i zaliti se na prekide testiraj sam. Skini si putty. Putem telneta logiraj se u router sa supervisorom, sve isto kao logiranje sa dslstat. Kada si se logirao sa putty u router kucaj: Code:
xdslctl configure --bitswap on --sra on --trellis on --i24k on --maxDataRate 31666 7166 50000 Ako ugasis router ili nestane struje ta sinhronizacija ce se izgubiti pa prosvrljaj po opcijama samog routera i ima jedna stavka: Save to ROM i to potvrdi tako da ti kod gasenje routera ili nestanka struje router putem cfg konfiguracije uvjek sinka tu tvoju postavljenu brzinu. Ako je sve OK pomiri se sa 30Mbps i uzivaj... ako i dalje puca mozes forsirati da tehnicar izadje na teren i da se trazi gdje parica eventualno ima smetnje no budi spreman na njihovo rjesavanje problema tako da ce te vrniti na 20Mbps razred...
trebaš seedbox? |
#1893 |
Postovi: 704
Code:
ADSL Training Status: Showtime
Mode: ADSL2+ Annex B
Traffic Type: ATM Mode
Link Uptime: 16 days: 19 hours: 24 minutes
ADSL Port Details Upstream Downstream
Line Rate: 1.043 Mbps 11.686 Mbps
Actual Net Data Rate: 1.035 Mbps 11.654 Mbps
SNR Margin: 7.0 dB 11.6 dB
Actual Delay: 2 ms 4 ms
Transmit Power: 12.3 dBm 19.3 dBm
Receive Power: 4.7 dBm 4.7 dBm
Actual INP: 0.5 symbols 1.0 symbols
Total Attenuation: 0.0 dB 0.0 dB
Attainable Net Data Rate: 1.120 Mbps 16.828 Mbps
Sig-5 redova normalne veličine max
#1896 |
RESPECT MY AUTHORITAH
Postovi: 7,488
Koliko CRC-a u 5min ili općenito može uzrokovati smetnje u maxtv-u tj da slika prekida. Kada god počne padati kiša, do tih 150m do FTTC-a meni se FEC-ovi broje u stotinama tisuća i počnu CRC-ovi. U sat vremena 160 CRC-ova. ![]() Kabel cijelim putem do zgrade podzeman a takav utjecaj ima kiša.
#1898 |
Postovi: 7,488
Pa imam manje? Imam 2-10 CRC-a u 5min, pa i to je loše? Kako misliš "a kamoli ne ovoliko"? Ovi FEC-ovi dolje su kao ispravljeni i ima ih mnogo po kiši ali oni ne utječu na ništa niti su znak nečeg loše. Bolje bi ih bilo da ih nema, pogotovo ne da ih se stvori 100 000 u sat vremena ali nisu ozbiljni.
#1899 |
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,523
brzopotezno - vjetar (??) je razvalio ptt ormarić di mi je parica (u mom dvorištu je stup). od starta sam planirao zamjenu tel kabela od stupa do kuće, sad to tehnički i mogu izvest (mislio sam kopneno ić, ukopat kabel do kuće jer nismo betonirali). znam koja mi je parica jer sam bio prisutan kod spajanja, zračni kabel je star oko 40 godina, a i cijeli stup je od onda. za vikend ću spojit router direkt na dolazni kabel pa vidit koliki je signal, sad sam na 30-31mbit sa 6-7dB snr. pitanje je samo - hoće li me itko išta pitat? dvorište je moje, kabel je moj, samo je stup njihov. imam rolu cat5 kabela, uzimat bolje? kad sam zadnji put to radio kod staraca, iskoristio sam sve parice u lan kabelu, sve obojane na 1 zilu, sve bijele na drugu. ima da traje koliko i ja. |
#1900 |
Lokacija: doma
Postovi: 2,899
U pravilu nece te niko nista pitati dok dok ne dodje lokalac da netkom drugom spaja nesto. Mogo si sliku okaciti da se vidi gdje, sta i kako pa mozda se moze i zamaskirati dobro, samo taj tvoj kabl koji bi isao iz ormarica. Ako ce pod zemlju mora ici u jos nesto dodatno, alkaten cijev za vodu recimo, najmanji promjer... nije ni skupa nesto. U kranjem slucaju i da te tehnicar pita nesto a cisto sumnjam... kazes da je kabl do tvoje kuce u qlincu i da si provukao svoj, stetu nisi nikakvu napravio a niti krades nesto... Ja imam regletu u tavanu sa 10-tak korisnika pa sigurno 5 tehnicara se izredalo i svaki je vidio da sam instalciju provukao direktno u regletu i zalemio na paricu pa mi nis nisu rekli, tudje zice ne diras i sve ok. Nemoj ko ja slucajno odspojiti komsiju no moj komso doso prvo kod mene pitati jel imam interneta, reko nemam ni ja.. sigurno su nesto shebali na tavanu, sad su maloprije bili ![]() Zalemio i njemu kad je vec parica kraj moje pa da ne pojebem opet kada prckam ![]()
trebaš seedbox? |
#1901 |
Lokacija: istra
Postovi: 3,523
ideja s lemljenjem se i meni promuvala kroz glavu, jer je sad stanje ovakvo: dolazni kabel iz zemlje - pa spoj, pa 20cm kabela, pa spoj, pa 3 metra kabela do vrha stupa, pa jos 1 spoj u rđavom malom ormariću, pa 20tak metara tel kabela do kuće. mogu slikat, ali tek popodne kad se vratim s posla. inače stup je jedno 20 metara od kuće... usred vrta skoro. neznam koliko je na njemu linija, ali ne puno, 16-20 možda. |
#1902 |
Postovi: 7,488
Možeš si osigurati napajanje kraj ormara i da probaš s 1m kabela se spojiti direktno na izvod s routerom? Ako tada imaš iste parametre kao i sada onda nema smisla sve ovo raditi.
#1903 |
Lokacija: istra
Postovi: 3,523
da, mogu, garaža mi je pored, ma sam mislio dovuć struju i spojit router. ako je neka veća razlika u signalu bi se odlučio za zamjenu, ako je to do 1dB, onda ne. kad sam kod staraca testirao na izvodu, razlika između izvoda i u stanu sa 40tak metara prastarog kabela je bila oko 0.1dB. |
#1904 |
Postovi: 23,566
Nisu samo spojevi u pitanju (recimo bilo koja kutija bez poklopca pa kad počne oksidirat i ruzinavit eto veselja), igra i "stanje" izolacije žiica (pa da vidiš veselja sa pucanjem xDSL linka sa većim prometom ili prilikom tel. razgovora za one koji još imaju klasični POTS). |
#1905 |
Lokacija: istra
Postovi: 3,523
ma bio sam odustao od toga zbog procedure. i kad je prošli tjedan bila nevera mi je puknuo link par puta i spustio se na 20mbit, i onda je držao tih 20mbit dok ga nisam restartao. i onda sam prekjučer kad sam išao u garažu skužio da su vrata ormarića full otvorena i da kiša pada unutra. i ko za qurac upravo pljušti. |
#1906 |
Postovi: 7,488
Stavi baš parametre parice, tj konrektno CRC da vidim i uspredim kod sebe. Evo, otkako pada kiša prije dva sata, imam čak 28CRC-a kroz to vrijeme (tj zadnjih sat vremena nemam ali nema veze)
#1907 | |
Lokacija: doma
Postovi: 2,899
Ti moras svoju liniju nakacit na bilo koji spoj prije ormarica ili moze u ormaric no moras zastititi cjelokupni ulaz glavnog kabla u ormaric te spoj tvoje parice na tom kablu do vanjskog crijeva u kojem ce ici parica prema zemlji. Zato sam i rekao da slikas boga mu ljenoga da se vidi stup, ormaric i spojevi tj. opcenito situacija pa shodno tome naci najprihvatljivije rjesenje.
trebaš seedbox? |
#1908 |
Lokacija: istra
Postovi: 3,523
a ja sam reko "tek popodne kad završim radit", i onda "upravo pljušti" :P slikat cu. kad se vratim doma. i da - nemam di prije ormarića, jer kabel iz zemlje ulazi u ormarić do reglete, s time da je moja parica "viseća" tj nije na regleti. ag - ma gledam sad, nemam crc-ova. zavezao sam ormarić pa vjerojatno sad nije padalo unutra, vrijednosti su normalne, 31mbit down, 7 up uz cca 6dB snr. imam 1.5ES u odnosu na 0.3-0.4 inače. to je jedina razlika. |
#1909 | |
Datum registracije: Dec 2012
Lokacija: Usa
Postovi: 253
Mozes prijavit kvar i reci tehnicaru da ti izmjeri, kada izmjeri te greske jedino sto moze je dat za mjernu ekipu ericssona koja ce mjeriti da je istosmjerno dobro i odjebat ce te, haha. Na kraju ces doci do toga da se tcomu ne isplati otvarati spojnice i slicno radi jednog korisnika i lagane degradacije. Ako nista bar mozes reci da ti izmjeri na ormaru u zgradi pa da vidis dal ti je kucna instalacija prema stanu cista. |
#1910 |
Lokacija: istra
Postovi: 3,523
nastavno na moju temu oko stupa, evo slike: stup u svom svom sjaju: ![]() i ormarić: ![]() moja parica je ova sa crvenom izolirkom. |
#1912 |
Lokacija: doma
Postovi: 2,899
E ormaric je super tj. nisko je a ima i mjesta za alkaten cijev u toj zastiti ispod njega ako odlucis ukopati si liniju. Ako dobro vidim tvoja parica ima 3 spoja, jedan je crvena izolirka, drugi je klema prema dolje a treci je na regleti prije izolirke tj. sama regleta. Ono sto bi trebao to je izbaciti sve spojeve i naci gdje na regletu dolazi tvoja parica i onda pratiti je do kabla ili ako ti se to neda onda bar direktno na tu okomitu regletu spojiti svoj kabl koji ce se nastaviti prema dolje i u zemlju. Ma ja bih pratio paricu direktno do kabla, nebih je kratio tj. zice ali bi samo tu svoju paricu raspetljao do glavnog kabla i onda spajao.
trebaš seedbox? |
#1913 |
Lokacija: istra
Postovi: 3,523
warlock - da, vidi se po onom zamotanom "paketu" parica, ono bi sve trebala bit rezerva. ja sam ih ovako nabrzinu izbrojao 13 zauzetih, tj spojenih. na našoj kući su 4 s time da su 2 moje a samo 1 ima liniju. ono šta me smeta je da kad sam tražio liniju, su rekli da "nema mjesta na izvodu" šta je sad očito da ima. morao sam povuć kontakte do lokalnih tehničara da me spoje. -silver - parica mi nije na regleti, one okrugle spojnice (kako se to skida btw? samo se odvida ona plastika ili ima neki drugi način?) su direkt na dolaznom kabelu. |
#1914 |
Lokacija: Vukovar-Osijek
Postovi: 491
to su scotch lockovi i nemogu se rastavljati, morao bi prerezati zicu. sta bi tu uopce radio? nema dovoljno zice da spojis primarnu paricu sa sekundarnom i mora ici ovaj komad od 10ak centi druge zice. |
#1915 |
Lokacija: doma
Postovi: 2,899
Sad vidim.. moro sam uvecat sliku. Iz crvenog idu u malu rupu tvoje 2-ve zice. Ma cvikaj taj spoj kod spojnice, cvicange i deri ![]() Tu gdje si cvikao spajas drugi svoj kabl. Za isprobavanje mos isto taj spoj cvikati pa ako je sve isto kao i sada umjesto spojnica ljepo zafrkas zice u duzini 1-2cm i onda tako zafrkani spoj zalemis tako sto ces staviti na njega malo paste za lemljenje i samo zericu lema cisto da se razlije po samom spoju. Preklopis zalemljeni spoj, "visak" u jednu ili drugu stranu zice i izoliras izolirkom.
trebaš seedbox? |
#1916 |
Postovi: 4,707
Koliko spojevi utječu na kvalitetu signala? Povukli su mi novi kabel s paricama (iznimno su tanke žičice, na moje čuđenje). Samo smo za prvu ostavili kabel i direktno spojili na njega. Sad bi možda cvaknuo kabel u krovu kuće gdje dolazi i prespojio na kućnu mrežu. Po kući su provučene neke deblje plavo-bijele žice, jesu li one okej ili da provučem nove? Ako ću provlačit nove, koje da povučem? Ili da ostavim ovako kako je sad? Inače, petlja se skratila za 100-ak metara, ali attenuation i SnR su ostali isti (sad direktno sa stupa ide na mene, više nije na susjeda pa od njega prema meni). ![]() Da provučem jedan CAT6 SFTP kabel pa da na njega spojim? Jel to najbolja opcija? Ili ima nekih posebnih žica? Radi se o dva priključka, dvije parice, tj. četiri žice. Također, smeta li ako u isti bužir provučem još dva aktivna CAT6 kabela? Na moje inzistiranje uopće nisu htjeli ići pogledat zahrđalu i oronulu kutiju sa izvodima... Vidim da ću morat sam ići otkriti koja je moja parica. ![]() Zadnje izmijenjeno od: IcyTexx. 08.07.2017. u 19:09. |
#1917 |
Datum registracije: Nov 2010
Postovi: 31
Pozdrav! Danas mi je uključena usluga Iskon.NET 20-50. Isporučen mi je ZyXel VMG5313-B30B router. Tijekom dana je mjerenje na speedtest.net izbacilo 11/1 Mbit/s, a sada u večernjim satima 7/1 Mbit/s. Tehničar kaže da su parametri linije jako loši pa je izvršio prijavu smetnje. Sad bi HT trebao odraditi svoju provjeru. U nastavku su statsi iz routera. Rekao mi je na koju centralu sam spojen, rekao bih da sam udaljen negdje oko 1.3 km. Može li se iz donjeg ispisa zaključiti zašto imam tako nisku brzinu? ============================================================================ VDSL Training Status: Showtime Mode: VDSL2 Annex B VDSL Profile: Profile 8b Traffic Type: PTM Mode Link Uptime: 0 day: 5 hours: 43 minutes ============================================================================ VDSL Port Details Upstream Downstream Line Rate: 1.120 Mbps 11.847 Mbps Actual Net Data Rate: 1.121 Mbps 11.848 Mbps Trellis Coding: ON ON SNR Margin: 8.6 dB 7.8 dB Actual Delay: 0 ms 0 ms Transmit Power: 11.4 dBm 18.6 dBm Receive Power: 1.4 dBm 0.5 dBm Actual INP: 12.0 symbols 26.0 symbols Total Attenuation: 10.2 dB 18.1 dB Attainable Net Data Rate: 1.185 Mbps 11.914 Mbps ============================================================================ VDSL Band Status U0 U1 U2 U3 D1 D2 D3 Line Attenuation(dB): 15.5 N/A N/A N/A 30.0 102.3 N/A Signal Attenuation(dB): 15.5 N/A N/A N/A 27.4 N/A N/A SNR Margin(dB): 8.6 N/A N/A N/A 7.8 N/A N/A Transmit Power(dBm): 11.4 N/A N/A N/A 18.6 N/A N/A ============================================================================ VDSL Counters Downstream Upstream Since Link time = 43 min 55 sec FEC: 1007 1 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Retr: 0 Latest 15 minutes time = 14 min 19 sec FEC: 39 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Retr: 0 Previous 15 minutes time = 15 min 0 sec FEC: 47 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Retr: N/A Latest 1 day time = 5 hours 44 min 19 sec FEC: 1007 1 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 24 24 LOS: 0 0 LOF: 0 0 LOM: 0 0 Retr: 0 Previous 1 day time = 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Retr: 0 Total time = 5 hours 44 min 19 sec FEC: 1007 1 CRC: 0 0 ES: 0 0 SES: 0 0 |
#1919 | |
Postovi: 31
Alternativno nude prelazak na ADSL gdje mogu ostvariti 5 - 10 Mbps (tj. 3,5 - 10 Mbit/s) za 20 kn manji mjesečni račun. Očito nisu niti pokušali detaljnije istražiti problem s paricom. Na moje inzistiranje da pričam s tehničarom, dobio sam sugestiju da zovem HT. Ali ja nemam ugovorni odnos s HT-om i ne pada mi napamet zivkati njih. Potom me zvao drugi agent (valjda s tehničke podrške) i ponudio iste opcije, ali ovaj je na moj upit odgovorio da se radi o prelasku na optičku infrastrukturu. Budući da sam inzistirao da se potrude riješiti problem s VDSL-om na bakru, dobio sam odgovor da će me netko (valjda stručniji) opet kontaktirati. Mišljenja, prijedlozi? |
#1920 | ||
Lokacija: istra
Postovi: 3,523
