Staro 06.06.2017., 20:38   #1261
O9g1
Bee-do Bee-do Bee-do, TUP
O9g1's Avatar
Datum registracije: Aug 2009
Postovi: 323
ETH---> Deposit Address ----> red letters
kad izdrilaš 1.00 ETH onda ćeš ga vidjet
Autor arrow Pregled postova
sad sam pustio nek rudari, čitao sam ovdje što se sve može raditi s tim no iskreno zapeo sam, gdje sa eth-om koji je na dwarfpool, prebaciti na wallet? na walletu ima exchange, ručno upišem trenutno 0.037eth(9.65$) sto je 0.00041btc te ima vrijdenost samo 1.16$? te mi zabravo stoji 0.00$ not enought funds
da li ja to nešto krivo radim? totalno sam zbunjen
Poloniex---> ETH---> Deposit Address ----> red letters
CPU: Intel i5 2500k (BX80623I52500K) cooled by Scythe Ninja3 (SCNJ-3000)
MBO: Asus P8Z68-V PRO/GEN3
RAM: 2x4GB Kingston 1600MHz, DDR3, XMP (KHX1600C9D3K2/8G)
GPU: GIGABYTE Radeon R9 290 4GB Windforce 3x (GV-R929OC-4GD)
SSD: Samsung 840 EVO 120GB (MZ-7TE120BW) - System
HDD1: WD Caviar Black 500GB (WD5001AALS) - Storage
HDD2: WD 250GB (WD2500JS-22MHB0 ) - Backup
ODD: Samsung 22/8/8/48/32x (SH-S222AB)
PSU: XFX XXX Edition P1-650X-CAG9 650W
CASE: Fractal Design Arc midi
FAN CONTROL: Scythe KAZE MASTER 5.25″ Bay Fan Controller (KM01-BK)
FAN: 2x Fractal Design Dynamic GP-14, 140 mm intake+2X Scythe S-flex 120mm (SFF21E) exhaust
OS: W10 x64
LCD:MASTER: LG 29UM57-P Ultra širok đubar, jooooj što ga volem... , SLAVE: Dell 17"
KEYBOARD: Logitech UltraX keyboard (Y-BL49)
MOUSE: Logitech G400
SOUND: Creative Sound Blaster X-Fi XtremeMusic
HEADSET: Steelseries Siberia v2
RALLYING GEAR: Logitech G25+homemade cokpit+handbrake (modani Genius MaxFighter F-16U)
IF IN DOUBT, FLAT OUT!!!
Don't touch it! It is mine! It's all miiiiineeee!!!
Lenovo Essential B580
CPU: Intel Celeron Dual Core B820 1.70GHz (2MB cache)
LCD: 15.6" HD LED 1366 x 768
GPU: Intel HD Graphics 3000
RAM: 4GB DDR3 1600MHz
HDD: 320GB SATA
ODD: DVDRW DL
PSU: Up to 4hours (Li-Ion 6 cell)
ETHERNET: Yes (Gb LAN)
COMM: Yes (802.11b/g/n)
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
FINGERPRINT READER: Yes
CAMERA: Yes
OS: Windows 7 Profesional
Lenovo ThinkPad E560
CPU: Intel Core i7-6500U 2.5 GHz
LCD: 15.6 inch 16:9, 1920x1080, IPS-Panel, LED-Backlight, glossy: no
Extern LCD:Lenovo X24a, 24 inch 16:10, 1920x1200, IPS-Panel, LED-Backlight
GPU: AMD Radeon R7 M370 2 GB GDDR5
RAM: 16GB, 2 x 8 GB DDR3L-1600
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
ETHERNET: Gigabit Ethernet
COMM: 802.11ac, Bluetooth, Intel Dual Band Wireless-AC 8260 - M.2 Card
CONNECTIONS: 3 x USB 3.0, HDMI, VGA, OneLink connector, LAN, Headphone/microphone combo jack
CARD READER: 4 in 1 ( SD Card, MultiMediaCard, SDHC Card, SDXC Card )
CAMERA: Yes
OS: Windows 10 64x
Poštena, dobra i odgovorna trgovina +još jedna...
Straight roads are for fast cars, turns are for fast drivers!
O9g1 je offline   Reply With Quote
Staro 06.06.2017., 20:38   #1262
dadoremix
dadoremix's Avatar
Postovi: 4,717
Autor Neo-ST Pregled postova
I koliko plaćaš to? Mislim, na kraju kad povučeš crtu, koliko te izađe Nicehash i koliko ti donese zarade?
Ne znam ni ja
Pa klasicno rudarenje picim
Sve ti pise
Mozes majnat i na moj walet
135$/mjesec
Minus 20$ struja cca
Po sadasnjem tecaju naravno
Eto danas mi prebaceno u roku 1h 61$ na walet
Radilo kakvih 2tj
Nicehas ima isplatu svaki utorak ako dostignes 0.01 btc
1x mjesecno ako si dosao do 0.001
Drugi rudariju sa claymore i direkt pokaju eth na walet
I cekaju ako poleti kao btc
Nicehash radi konverziju u btc i ide btc na walet
Ima nesto proviziju kao i svi
Klik and forget
Staro 06.06.2017., 21:11   #1263
arrow
arrow's Avatar
Datum registracije: Nov 2014
Lokacija: Zd
Postovi: 609
Autor O9g1 Pregled postova
auuuu potrajat će
hvala
EDIT:
znači da ne diram ništa dok ne dođe do 1 eth, do tad žu valjda skužit kako prebaciti novac
Zadnje izmijenjeno od: arrow. 06.06.2017. u 21:17.
arrow je offline   Reply With Quote
Staro 06.06.2017., 21:49   #1264
luka1002
Craken
luka1002's Avatar
Postovi: 23
Smile POzdrav
Planiram se uključiti tj uložiti u rudarenje. Pročitao sam manje više sve teme, ali trebam pomoć. Molim Vas da me se ispravi ukoliko griješim negdje.
- ATI -a je gotovo nemoguće naručiti stoga bi išao na NVIDI-u (1070 x 6)
- Planiram ganjati ZEC-a koliko sam skužio je sada kada su CUDA mineri došli isplativo.
- Sam proces konverzije u nešto drugo mi još nije jasan ali moram ponovo pročitati i probati naravno.
- Koliko sam čitao NVIDIA može biti ok i za ETH pogotovo pod Linuxom kojeg planiram koristiit i iz razloga jer ne plačam struju ( )
Kalkulacija mi je sljedeća pa Vas molim za korekcije:
1x 1070 cca 450H/s x 6 = 2700 H/s
Po kalkulatoru to ispada dnevno :
CALC
(malo mi je to napuhano, gdje griješim?)
luka1002 je offline   Reply With Quote
Staro 06.06.2017., 21:52   #1265
seki250
Datum registracije: May 2017
Lokacija: U šumi
Postovi: 7
Pa šta se nemože narihtati na dwarfpoolu Autopayout from 1.01* na neki drugi iznos??
seki250 je offline   Reply With Quote
Staro 06.06.2017., 22:07   #1266
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Autor luka1002 Pregled postova
er
CALC
Pa ne griješiš, to ti je cca 1000$/mj po trenutnoj težini i tečaju.
Staro 06.06.2017., 22:07   #1267
ravkan
ravkan's Avatar
Postovi: 753
Autor seki250 Pregled postova
Možeš, ja imam na 0.1 to je minimum.
Red Vishera Blue Devil
Zadnje izmijenjeno od: ravkan. 06.06.2017. u 22:16.
ravkan je offline   Reply With Quote
Staro 06.06.2017., 22:14   #1268
Neo-ST
Neo-ST's Avatar
Postovi: 8,371
CALC
Ako vrijednost ZEC-a ne padne, onda ti je to to.
Zasada je stabilan i 1ZEC vrijedi oko $250: https://poloniex.com/exchange#usdt_zec
Staro 06.06.2017., 22:18   #1269
bloodthorn
Crypto currency
bloodthorn's Avatar
Datum registracije: Aug 2008
Lokacija: Dubrovnik
Postovi: 525
Da li je netko probao ovo? PCIe 1 to 3 PCI Express 1x slot Adapter Port multiplier
Zanima me da li radi...
bloodthorn je offline   Reply With Quote
Staro 06.06.2017., 22:27   #1270
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Autor goran047 Pregled postova
tier level ti je 0 a mora ti bit minimum 1 da bi mogao polozit ista, sretno sa verifikacijom, ja sam ju cekao 3 tjedna na krakenu i naravno sad mi vise niti ne treba ko bi njih docekao
meni rijeseno do tier 3 u manje od 24h.
Staro 06.06.2017., 22:28   #1271
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,736
Autor bloodthorn Pregled postova
sudeci po dobrim ljudima interneta radi, vjerojatno nece na svakoj ploci ali recimo vidio sam da na mojoj h270 plus radi
Staro 06.06.2017., 22:38   #1272
seki250
Lokacija: U šumi
Postovi: 7
Autor ravkan Pregled postova
sam si to naštimo ili si moro slat email adminu
Staro 06.06.2017., 22:48   #1273
Neo-ST
Neo-ST's Avatar
Postovi: 8,371
Sad bio na Poloniex chatu i tamo je gužva neviđena, svi imaju problema sa depositima i withdrawalima. Moderatori mole za strpljenje, da su ovi zatrpani requestovima kojih ima više nego inače. Neki likovi su napisali da čekaju već više od 14 dana na withdrawal...
Kad mi ovo razriješe selim na Kraken ili neku drugu burzu (preporuke?).
Staro 06.06.2017., 22:50   #1274
goran047
goran047's Avatar
Datum registracije: Nov 2016
Postovi: 142
na dwarfpoolu ti stoji lijevo box za promjene, ali morat ces verificirat ip adresu ako se ne varam
OVDJE saznas svoju trenutnu ip adresu
goran047 je offline   Reply With Quote
Staro 06.06.2017., 23:13   #1275
Neo-ST
Neo-ST's Avatar
Postovi: 8,371
Jel meni netko nešto nije rekao za Poloniex?
Nakon šta sam ugnjavio moderatora na chatu da pogleda moj slučaj, izgleda da je support bacio oko (i odobrio mi withdrawale), ali ovo je odgovor:
Ja sam mislio da tako svi rade, majnaju na Poloniex i onda withdrawaju na Jaxx.
Šta sad da radim? Da majnam direktno na Jaxx ?
Staro 06.06.2017., 23:43   #1276
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,736
ja majnam direkt na coinomi i tamo drzim eth, dok siacoin majnam na poloniex i tamo trejdam
jaxx inace navodi na svojoj stranici da se ne majna direkt na njega, ali mislim da se to odnosi na one koji imaju desetke uplata dnevno a ne mi koji imamo 1 svakih 7 ili vise dana
Staro 06.06.2017., 23:56   #1277
Neo-ST
Neo-ST's Avatar
Postovi: 8,371
Autor vacs Pregled postova
https://decentral.zendesk.com/hc/en-...youts-to-Jaxx-
Staro 07.06.2017., 00:03   #1278
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,736
Staro 07.06.2017., 00:34   #1279
dadoremix
dadoremix's Avatar
Postovi: 4,717
a da mi tu banda.. otvorimo kakavu skype grupo.. ili irc ?
pa da tamo chatamo..
jer tu se vrtimo u krug
ili bilo koji drugi chat program..
Staro 07.06.2017., 00:40   #1280
topro86
Datum registracije: Feb 2011
Lokacija: Sarajevo
Postovi: 9
Autor RimtuTiTuki Pregled postova
Ja sam naručio Gigabyte GA-Z270P-D3. Nije još stigla, tako da ti ne mogu puno reći o njoj...
Hvala u svakom slučaju ))
topro86 je offline   Reply With Quote
Staro 07.06.2017., 00:46   #1281
topro86
Lokacija: Sarajevo
Postovi: 9
[QUOTE=FRipper;3068117]topro86
Uzmi Z270A Pro, odlična ploča i radi super s 6 grafi...
Napajanje zavisi koliko te košta od 1200W i koje je....
E hvala ti. U međuvremenu sam nasao jednu Asrockovu ploču... i ako ne bude druge onda cu uzet i ovu za drugi rig.
U međuvremenu lik kod kojeg sam bio rezervisao 570ke me izradio i prodao iste )
Sad sam negdje iščačkao 580ki za rig... i uzet cu jedan sa 1060kama od 3gb.
Sto se tiče napajanja slabo ima ovih od 1200-1300 na stanju.. :/.. a otprilike košta kao dva od 750 (koje si naveo u prvom postu), mozda za 100 kn jeftinije (40KM).
Hvala još jednom.
Riseri i dalje problem... lik u veleprodaji računarske opreme se hvata za glavu i ne zna o cemu pričam
Staro 07.06.2017., 00:50   #1282
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,736
riseri na ebayu, uzmi v006c, po 35kn (9 maraka) su
Staro 07.06.2017., 07:31   #1283
drz_nedaj
Axl Rose
drz_nedaj's Avatar
Postovi: 395
Dali netko ima informaciju kada bi trebale stici rx5xx?
Premisljam se dal da uzmem odmah 1060 ili cekam rxice..
Poslano sa mog EVA-L09 koristeći Tapatalk
drz_nedaj je offline   Reply With Quote
Staro 07.06.2017., 07:35   #1284
xoverload
Lokacija: osijek
Postovi: 119
Ma kakav ebay, cekat ces mjesec ipo dana da ti dodje. Uzmi s fasttech-a, 5.3$ komad i dodaj 1.5$ za DHL dostavu, dodje ti paket u roku od 2 tjedna.
xoverload je offline   Reply With Quote
Staro 07.06.2017., 07:36   #1285
xoverload
Lokacija: osijek
Postovi: 119
Autor drz_nedaj Pregled postova
Ma te koje i trebaju doci su sve vec rezervirane...
Staro 07.06.2017., 09:17   #1286
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,588
Futura kaže ništa narednih 2mj.
Staro 07.06.2017., 09:31   #1287
topro86
Lokacija: Sarajevo
Postovi: 9
I mene to zanima ://
Autor xoverload Pregled postova
Hvala, pokušat cu.
Sto se tiče napajanja, nude mi ovo:
http://www.thermaltake.com/products-...?id=C_00001780
Jel' ok?
Staro 07.06.2017., 09:34   #1288
DigitalVHS
Lokacija: BL
Postovi: 227
Autor kopija Pregled postova
Ja mislim da ce i 1060 uskoro nestati.
DigitalVHS je offline   Reply With Quote
Staro 07.06.2017., 09:56   #1289
luzer80
Datum registracije: Jun 2017
Postovi: 54
Autor luzer80 Pregled postova
kako kod nas nema za kupiti kartica pogledao sam malo van HR i vidim da postoje razni proizvođači za npr. GTX 1060. KFA2, PALIT, ZOTAC, MANLI, INNO3D...
Ima kakve veze koji je proizvođač kartice? Preporučujete neku od ovih ili da čekam ostale?
Samo ponavljam pitanje jer se možda izgubilo
luzer80 je offline   Reply With Quote
Staro 07.06.2017., 10:04   #1290
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,736
nema veze koji je proizvodac, samo uzmi verziju sa dva ventilatora
