#3781 | |
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,593
1 x AMD Ryzen 5 1600, 3,4GHz, 19MB, AM4 1 x CPU Hladnjak LC POWER LC-CC-120, Intel/AMD, 120mm, PWM 1 x Gigabyte Main Board Desktop AB350M-Gaming 3 Socket AM4 (AMD RYZEN™ processor), 4*DDR4 3200, USB3.1/USB 2.0, DVI-D, VGA, HDMI, M.2, SATA III, RAID, GLAN, mATX 1 x MEM DDR4 8GB 3000MHz XPG DAZZLE AD LED 1 x WESTERN DIGITAL Caviar Blue (3.5", 1TB, 64MB, SATA III-600) 1 x Corsair 550W, CX-M Series, 80+ Bronze - 60mj. 1 x MS BLACK WIDOW ultra tiho PRO gaming kućište Ukupno: 5149,49 kn (-2%=5.046kn) Besplatno slaganje i dostava |
#3782 |
Datum registracije: Mar 2011
Postovi: 2,707
Toshiba P300 1TB, 64MB, 7200rpm HDWD110UZSVA Procesor AMD Ryzen 5 1600 Fractal Focus G, crno s prozorom, bez napajanja Matična ploča ASRock AB350 Pro4 Corsair Enthusiast Series TX550 Watt Modular Power Supply 80 Plus Gold Certified, EU Version 2x Patriot Signature DDR4, 2400Mhz, 8GB, CL15 5.008,51kn |
#3784 |
Postovi: 1,593
i ne napišeš najbitnije stvari, koliko max para možeš dati i kako plaćaš? |
#3785 |
Lokacija: Bjelovar
Postovi: 85
#3786 |
Postovi: 2,707
Toshiba P300 1TB, 64MB, 7200rpm HDWD110UZSVA Patriot Signature DDR4, 2400Mhz, 8GB, CL15 ASRock AB350M, AM4 Corsair PSU Builder Series CX450, 450 Watt Power Supply, EU Version Procesor AMD Ryzen 5 1600 Kingston SSD A400, R500/W450,120GB, 7mm, 2.5" MS BLACK WIDOW silent fans PRO gaming kućište uz zvučnu izolaciju MSI GF GTX 1060 6GT OC V1, 6GB GDDR5, DX12 7.410kn na kartice |
#3787 |
Datum registracije: May 2017
Postovi: 8
Pozdrav, trebao bi pomoć oko konfiguracije, kupujem novi pc, nesto od 6500 do 7500. Zasad sam si slozio nesto pa me zanima vase misljenje. Kućište Zalman R1 mid tower black SSD Kingston UV400, R550/W350,120GB, 7mm, 2.5" Procesor Intel Core i5 7600 3,5GHz,6MB,LGA 1151 Grafička Gigabyte GF GTX1060 G1 GAMING, 6GB GDDR5 Memorija Kingston DDR4 8GB 2400MHz HyperX Fury KIN Napajanje Seasonic SS-520GM2 EVO, 520W i maticna asus prime z270-p hard imam od 2tb wd caviar green ovo cisto za pocetak uzeo bi poslije jos 8gb rama zanima me vise ssd i napajanje dal bi mogao nesto drugo |
#3788 |
Postovi: 1,593
XiPi87 1 x AMD Ryzen 5 1600, 3,4GHz, 19MB, AM4 1 x CPU Hladnjak LC POWER LC-CC-120, Intel/AMD, 120mm, PWM 1 x Gigabyte Main Board Desktop AB350M-Gaming 3 Socket AM4 (AMD RYZEN™ processor), 4*DDR4 3200, USB3.1/USB 2.0, DVI-D, VGA, HDMI, M.2, SATA III, RAID, GLAN, mATX 1 x Patriot Signature DDR4, 2400Mhz, 8GB, CL15 1 x Gigabyte GF GTX1060 G1 GAMING, 6GB GDDR5 1 x Crucial SSD 275GB Crucial MX300 SATA 2.5” 7mm (with 9.5mm adapter) SSD 1 x CORSAIR Builder Series CX550M, Modular Power Supply, EU Version 1 x MS BLACK WIDOW ultra tiho PRO gaming kućište Ukupno: 7694,87 kn (-2%=7.540kn) Besplatno slaganje i dostava |
#3789 |
Postovi: 8
volio bi od intela i5 7600 box bez cpu coolera za pocetak radije nego ryzen, treba mi pc strogo za igrice, nikakav stream i pozadinske aplikacije, programi itd ssd bi mi bio dosta od 120 gb i atx maticnu a kuciste ne treba bit tiho, neko jeftino nek se kuca trese =D |
#3790 |
Postovi: 2,707
#3792 |
Postovi: 8
sta nije intel bolji kad je u pitanju samo igranje jedne igrice i niceg drugog, manje jezgri koje rade brze i bolje nego ryzen koji je za multitasking |
#3793 |
Postovi: 14,584
Šema je što i nisu baš nešto brže. Od intela dobiješ čisti quad, umjerenog clocka i lockan. Nije to i7 7700K na 5ghz i5 ima nešto sitno bolji ipc, no ovaj je otključan (pa ga anulira), 8 threadova tj. bolji multithread (1400 i 1500X), 1600 sa 12 threadaova da ne spominjem, perspektivnija platforma (do 2020 i zen3) dok bi se 1151 mogao škartirati već ove ili sljedeće godine, a mbo nestati totalno za 2 god., zatim upgrade path na hexe i octe na AM4 itd. Moje mišljenje glede R5 vs i5 se doslovce podudara sa ovim što je fino objasnio ovaj tip https://www.youtube.com/watch?v=OE7s...tu.be&t=28m11s https://www.youtube.com/watch?v=eH6R...tu.be&t=17m20s Zadnje izmijenjeno od: Manuel Calavera. 29.05.2017. u 16:00. |
#3794 |
Postovi: 8
bi bilo ovo onda u redu? 1 x AMD Ryzen 5 1600, 3,4GHz, 19MB, AM4 1 x CPU Hladnjak LC POWER LC-CC-120, Intel/AMD, 120mm, PWM 1 x Gigabyte AB350M-Gaming 3 Socket AM4 (AMD RYZEN™ processor), 4*DDR4 3200, USB3.1/USB 2.0, DVI-D, VGA, HDMI, M.2, SATA III, RAID, GLAN, mATX 1 x Kingston Technology HyperX FURY Memory Black 8GB Module DDR4 2666MHz CL15 DIMM 1 x Gigabyte GF GTX1060 G1 GAMING, 6GB GDDR5 1 x Kingston Technology HyperX FURY SSD 120GB, 120 GB, Serial ATA III, 500 MB/s, 6,35 cm (2.5") ..jos napajanje i kuciste, znaci nije mi vazno dal ce bit glasno samo da sve stane unutra, a napajanje neko drugo isto modularno jer u uzi shopu trenutno nema CORSAIR koji je ibme stavio a nema trenutno ni graficke Zadnje izmijenjeno od: coconut. 31.05.2017. u 06:13. |
#3795 |
Postovi: 14,584
eJel sam sastavljaš konfiguraciju ili ti treba slaganje? Cooler je dobar samo ne znam dali dolazi sa AM4 bracketom, Fortron Windale 4 ti je safe bet ako ne želiš čekati da ti pošalju bracket. Također R5 1600 ima solidan stock cooler tako da njegovu kupovinu možeš i odgoditi ako ti radi toga prelazi budžet. SSD je stari model, rađe bi dao 16kn više za noviji SU800 i dobiješ par gb više Od modularnih napajanja imaš tamo cx450m za 430kn. Case ti je Z1 neo dobar value za ispod 300kn |
#3796 |
Postovi: 8
1 x AMD Ryzen 5 1600, 3,4GHz, 19MB, AM4 1 x Fortron Windale 4, hlad. za procesor, s1151/AM4 1 x Gigabyte AB350M-Gaming 3 Socket AM4 (AMD RYZEN™ processor), 4*DDR4 3200, USB3.1/USB 2.0, DVI-D, VGA, HDMI, M.2, SATA III, RAID, GLAN, mATX 1 x Kingston Technology HyperX FURY Memory Black 8GB Module DDR4 2666MHz CL15 DIMM 1 x Gigabyte GF GTX1060 G1 GAMING, 6GB GDDR5 1 x ADATA Ultimate SU800 128GB, Serial ATA III, TLC, SMI, Crno, 2.5", CE, FCC, BSMI, VCCI, KCC 1 x Zalman Z1 NEO mid tower case 1 x Corsair CX550M 550 Watt Modular (2015 Edition) trebam slaganje naravno, jos me samo zanima zasto ova maticna (mATX), oce stat graficka i hladnjak i sve na to!? |
#3798 |
Postovi: 8
Hvala puno, pozdrav |
#3800 |
Datum registracije: Sep 2014
Lokacija: osijek
Postovi: 15
Pozdrav, nadam se brzom odgovoru jer bi što prije krenuo s potražnjom novog računala. Ukratko, potrebna mi je konfiguracija za gaming development (Unity) i za gaming općenito. Nisam opsjednut grafikom igara, ne treba sve raditi na ultra settings, ali bitno mi da je dovoljno jak da žvače dosadašnje zahtjevnije igre + sljedećih par godina pa makar po minimum requirementsima. Može i da bude nadogradiv pa da ga pojačam kad/ako bude potrebno. Za hard disk dovoljno mi je 1 TB, ne treba mi periferija. Iz malo istraživanja došao sam do pretpostavke da je AMD isplativiji od Intela, ali to vi bolje znate. Budžet do 7000, može i više ako će malo više novaca bitno utjecati na perfomans. Edit: volio bi čuti vaše mišljenje o ova dva već sklopljena računala: https://www.links.hr/hr/racunalo-lin...tita-034900036 i https://www.links.hr/hr/racunalo-lin...tita-034900032 . |
#3801 |
Postovi: 1,593
Ako mozes jos 400kn gore: 1x Procesor AMD Ryzen 5 1600 1x MSI Main Board Desktop B350 (SAM4, 4xDDR4, PCI-Ex16, 2xPCI-Ex1, USB3.1, USB2.0, 4xSATA III, M.2 1x Memorija Adata XPG Z1 DDR4 16GB (2x8GB) 3000MHz P/N: AX4U300038G16-DBZ 1x Gigabyte GF GTX1060 WF2 OC, 6GB GDDR5 1x Kingston UV400 120GB SSD, 2.5” 7mm, SATA 6 Gbit/s, Read/Write: 550 MB/s / 350 MB/s, Random Read/Writ 1x Toshiba P300 1TB, 64MB, 7200rpm HDWD110UZSVA 1x Fortron napajanje Hyper 500W 1x MS CYCLOPS II gaming kućište 2x MS PC COOL 12cm hladnjak za kućište (jedno naprijed za upuh jedno iza za ispuh) Ukupno: 7.400kn Besplatno slaganje |
#3802 |
Datum registracije: Mar 2013
Postovi: 1,391
Pozdrav ekipa, Planiram uzet neki novi pc samo kutija. Do 6000kn amex na rate, lokacija zg. Ducani koje bih volio izbjeci instar, hg spot. Namjena konfe bi bila ovak hmm.. Jos sam na faksu i svasta radim, Java, java script, baze mysql, html, css i sl. Podizao bi virtualku itd. U principu programiranje raznovrsno. I to bi bila sustinska namjena konfiguracije. Sto se tice gaminga ja odigram sa ekipom s faxa cod4, buraz igra taj league of legends. Eto to je vise manje to i isao bih do 6000kn max. Ssd i hard imam znaci trebao bi mi ostatak kutije, pa neke sugestije, preporuke su dobro dosle. I eventualno neka zvucna zvucna da izvucem malo vise iz svojih slusalica. Intel, amd moze preporuka za oboje pa cu donjeti odluku. hvala unaprijed. Powered by LG G6 |
#3803 |
Datum registracije: Jul 2017
Postovi: 1
Pozdrav ljudi , Trebala bi mi neka konfa + monitor 24". Namjena gaming i multimedija. Buđet 7000kn , može eventualno 200 kn gore/dolje. Miš i tipkovnica nisu potrebni. Kupnja bi iša na karticu - American na rate. Hvala lijepa unaprijed. |
#3804 |
Postovi: 1,593
1x AOC LED 24" I2476Vwm, VGA, HDMI,FHD 1x Procesor AMD Ryzen 5 1400 1x MSI Main Board Desktop B350 (SAM4, 4xDDR4, PCI-Ex16, 2xPCI-Ex1, USB3.1, USB2.0, 4xSATA III, M.2 1x Patriot Viper4, 3000Mhz, 8GB (2x4GB), CL16 1x Gigabyte nVidia GeForce GTX1060 3GB DDR5 OC WF2 1x Toshiba P300 1TB, 64MB, 7200rpm 1x MS CYCLOPS V gaming kućište window Mid Tower 2x MS PC COOL 12cm hladnjak za kućište UKUPNO: 7.200kn (na rate) Besplatno slaganje |
#3805 |
Postovi: 16,833
Je li stvarno tih 3gb na 1060 dosta za gaming u 2017.? |
#3806 | |
MiningMod
Postovi: 8,715
1 x Gigabyte Main Board Desktop AB350M-Gaming 3 Socket AM4 (AMD RYZEN™ processor) 1 x Patriot Viper4, 2800Mhz, 16GB (2x8GB), CL16 1 x GIGABYTE Radeon RX 560 GAMING OC GDDR5 4GB/128bit, PCI-E 3.0, DP, HDMI, DVI-D, WINDFORCE 2X 1 x Zalman Z1, USB3.0 black, 2x120mm 1 x Fortron Hyper 500W, 80+ - 60mj. cca 6000kn na rate, do 12 rata Da...a i ovako i onako ne stane nešto jače, sa 6GB je 600kn preko budžeta... Jedino da ide ovako s lošijim komponentama: 1 x Philips 23,6" 243V5QHSBA MVA, VGA, DVI, HDMI 1 x GIGABYTE GeForce GTX 1060 GDDR5 6GB/192bit, WINDFORCE 2X 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance 1 x Procesor Intel Core i5 7400 3GHz, S.1151, KabyLake 1 x GIGABYTE GA-H110M-S2, INTEL H110, VGA, mATX 1 x Crucial DRAM 8GB DDR4 2133 MT/s (PC4-17000) CL15 SR 1 x Fortron Hexa+ 400W, 80+ 1 x Kućište MS Helios 3, crno 1x12cm+1x8cm vent cca 7250kn na 12 rata Zadnje izmijenjeno od: coconut. 24.07.2017. u 15:23. |
#3807 |
Postovi: 16,833
Ne pitam vezano za budžet. Pitam informativno, da znam za ubuduće. |
#3808 |
MiningMod
Postovi: 8,715
Pa ono, neki koriste danas i 512MB grafe pa im je dobro... Sve ovisi o tome što ti planiraš. Ako ćeš ganjati 4K onda naravno da nije ok 3GB. A logično je da je bolje uzeti GTX1060 3GB nego GTX1050Ti 4GB jer je ipak GTX1060 jači čip. |
#3809 |
Postovi: 1,593
Kako u kojoj igri. u nekima to neće biti neka velika razlika, u nekima hoće klik Ako se ima love za 6GB onda definitivno nju uzeti, ako se nema onda će biti dosta i 3Gb (pogotovo ako se igra na 1080p), u svakom slučaju puno bolja kupovina nego GTX1050Ti ili RX560 bez obzira na 1GB VRAM-a manje |
#3810 |
Postovi: 16,833
Ok, hvala puno. LP |
