Staro 20.05.2017., 22:49   #29191
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
Do sad narucio / proslijedio tri ovakva VCDS klona:
https://tinyurl.com/kl5x6oj
Podrska za Win 10 je problematicna, ali Win 7 / XP rade bez greske.
Staro 20.05.2017., 23:55   #29192
Dottore
Dottore's Avatar
Postovi: 7,664
Castrol SRF je bez premca, tu nema priče, ali za cijenu jednoga dva puta zamijenim sa novim Motulom i bok.
Ti si super prošao sa tu cijenu Otkud si nabavio dosta povoljno? Zadnji SRF sam dobio za 480kn.
Još nisam zamijenio svoje pločice za novi ATE. Morao sam još nadodatii tekućine zbog lufta odnosno praznog hoda na papučici kočnice.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 21.05.2017., 07:44   #29193
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,073
Autor CatKiller Pregled postova
Ne otvara mi link, možeš li poslati direktni link?
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 21.05.2017., 09:40   #29194
Postovi: 8,217
Code:
https://pt.aliexpress.com/item/VAG-COM-16-8-3-VAGCOM-16-8-VCDS-HEX-CAN-USB-Interface-VAG-16-8/32806841723.html?spm=2114.01010208.3.16.p0WSKs&ws_ab_test=searchweb0_0%252Csearchweb201602_1_10152_10065_10151_10068_5010017_10136_10157_10137_10060_10138_10155_10062_10156_437_10154_10056_10055_10054_10059_303_100031_10099_10103_10102_10101_10096_10147_10052_10053_10050_10107_10142_10051_5190017_10084_10083_10080_10082_10081_10177_10110_519_10111_10112_10113_10114_10037_10181_10180_10183_10182_10185_10184_10032_10078_10079_10077_10073_10186_10123_142%252Csearchweb201603_4%252CppcSwitch_7&btsid=e8dcb36a-3bab-42e9-bf24-ffb49ea0f355&algo_expid=0d5e9e6c-c3b5-4ddd-a2e4-2fe3a7eefe06-2&algo_pvid=0d5e9e6c-c3b5-4ddd-a2e4-2fe3a7eefe06&aff_platform=aaf&cpt=1495352576438&sk=VnYZvQVf&aff_trace_key=6f700a7f6829465d901400c7f1c48586-1495352576438-09955-VnYZvQVf
Staro 21.05.2017., 10:00   #29195
HONDA type R
HONDA type R's Avatar
Lokacija: Požega
Postovi: 335
dali se programski dio treba skinuti ili dolazi sa kablom?
Autor Dottore Pregled postova
iz ciaka, inace je 304 kune litra ali mi kolega da rabat koliko može.
recimo ate sl6 je litra 113 kuna a sa rabatom 70.
HONDA type R je offline   Reply With Quote
Staro 21.05.2017., 10:23   #29196
CatKiller
CatKiller's Avatar
Postovi: 3,312
Autor HONDA type R Pregled postova
Dodje uz kabel na malome CD-u.
Staro 21.05.2017., 12:16   #29197
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Jel znas neki pouzdani za Toyotu (Auris 2007)?
žmnpp
Staro 21.05.2017., 13:25   #29198
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,860
https://youtu.be/UEJbKLZ7RmM?t=1m27s
Jel ko zna gdje u nas kupiti nešto slično
Dakle radi se o bezbojnom laku za farove(plastiku) sa UV zaštitom
Staro 21.05.2017., 13:56   #29199
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
I ja sam ovo vidio, ranije nekad, i bas se isto pitao.
Staro 21.05.2017., 14:06   #29200
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,421
ak treba netko u zg ovo nek se javi http://www.njuskalo.hr/image-w920x69...a-75336311.jpg
Staro 21.05.2017., 14:26   #29201
Igneos Eructid
običan user
Igneos Eructid's Avatar
Lokacija: Phuket, Thailand
Postovi: 844
kad ides u sumicu, idi terencem i iz vrece izvadi gumicu...
Igneos Eructid je offline   Reply With Quote
Staro 22.05.2017., 13:41   #29202
pero_dinamit
pero_dinamit's Avatar
Datum registracije: Mar 2011
Postovi: 39
Autor Old Iggy Pregled postova
Negdje sam neki dan čitao da bi se i moglo po toj snimci nešto napraviti.
Pa frend s posla to tako prijavi preko one anonimne MUP-ove aplikacije.
Već je tako 2, 3 tipa prijavio i svaki puta je pisalo da je prijava uvažena, tako nešto. Imaš kratki tekst opisa, stavio registraciju iako se vidi na snimci i to je to.
pero_dinamit je offline   Reply With Quote
Staro 22.05.2017., 20:07   #29203
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Borovje. Meni super
Staro 22.05.2017., 20:27   #29204
N!NO
N!NO's Avatar
Datum registracije: Sep 2002
Postovi: 278
To je baka naheklala tabletic?
N!NO je offline   Reply With Quote
Staro 22.05.2017., 22:04   #29205
Tvrdi
Sremium
Datum registracije: Oct 2013
Postovi: 2,854
ne bi o ukusima ali felga je malkice prevelika
Nego pitanje vezano za poliranje farova. Farovi su mi ko novi sam kaj je kod desnog blago "zamućenje" na jednom manjem djelu površine fara. Jel za skinut to je dosta krpa i polir pasta il ću morat ipak sa finim vodobrusnim prvo?
Staro 22.05.2017., 22:05   #29206
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,061
Ova felga je sigurno atestirana i upisana u prometnu
Staro 22.05.2017., 22:08   #29207
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,103
Jedan od onih čije prelaženje jednog ležećeg policajca mjeriš u minutama
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 22.05.2017., 22:17   #29208
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,061
Autor 1v@n Pregled postova
Sumnjam da se usudi voziti po nasim prometnicama ovak onisko,vjerojatno zracni ovjes
Staro 22.05.2017., 22:54   #29209
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Autor Tvrdi Pregled postova
To je takav dir.. Ovo je jos mild varijanta..
https://www.google.hr/search?q=stanc...=1920&bih=1061
Staro 22.05.2017., 23:47   #29210
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Bemti kako retardirano, to treba necim tupim zatuc.
Sent from my SM-G920F using Tapatalk
Staro 23.05.2017., 07:05   #29211
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,167
Ak nije prejako, možeš polir pastom proći. Probaj prvo s njom pa ćeš vidjeti. Obrusiti bi trebao cijelu površinu, da nebi bila "fleka" samo na jednom dijelu
Staro 23.05.2017., 07:53   #29212
Green_FanBoy
Green_FanBoy's Avatar
Datum registracije: Mar 2015
Postovi: 255
U petak sma igrom slučaja (gps utvrdio najmanju gužvu) prolazi Av. Većeslava Holjevca i bome mi nije bilo svejedno, obavezno kotač prko ležećeg, nisam se usudil ovak sa sredinom
A bome nije mi ni bilo udobno prek tračnica iz (s)Vodnikove u Savsku.. Opće sam zaboravil koja je tortura to s ljetnim prelaziti
I moram se za potrošnju pohvaliti, uspio sam u ZG doći s 4.8 l/100km, a doma s 6.0 (prema BCu)
Green_FanBoy je offline   Reply With Quote
Staro 23.05.2017., 13:36   #29213
prileee
laser
prileee's Avatar
Postovi: 2,348
Sta kazete na novog i30? Ne kupujem nego me cisto zanima drugo misljenje, meni se cini super, a nije mi ni ruzan.
https://www.facebook.com/automarket....42503972819545
Staro 23.05.2017., 19:38   #29214
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Zagreb / Maksimir
Postovi: 4,007
Izvana onak, običan, golfovski, no iznutra je doživio napredak u odnosu na prijašnji model.
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
Staro 23.05.2017., 20:42   #29215
Tvrdi
Sremium
Postovi: 2,854
Autor prileee Pregled postova
Meni je ružnjikav i običan. Prošli model mi je čak bio više atraktivan. Inače ostalo je poznato da je ok, to je vrlo solidan auto i ni po čemu lošiji od golfa. Ali to danas i nije neko postignuće. Nažalost.
Staro 23.05.2017., 20:52   #29216
Gigi1
Postovi: 2,138
isplati li se i dalje ici u sloveniju(furlan i ta ekipa) kupit auto gume ili je to sad tu negdje kao kod nas(neznam koji su ok ducani)?
vjerojatno bi samo predjnje mijenjao za prvu ruku, dimenzije 225/45 r17, koje bi preporucili(nebih neke preskupe, ono najbolji omjer ulozeno/dobiveno, all season gume)
Staro 23.05.2017., 20:57   #29217
Tvrdi
Sremium
Postovi: 2,854
Autor Gigi1 Pregled postova
vjerojatno bi samo predjnje mijenjao za prvu ruku, dimenzije 225/45 r17, koje bi preporucili(nebih neke preskupe, ono najbolji omjer ulozeno/dobiveno)
Po meni se ne isplati. Pogotovo jel se kod nas sad može dobit guma na popustu ili webshop niža cijena itd. Dosta su pale cijene guma kod nas. Ti još uzimaš samo 2 za prvu ruku. Jel više nema povrata PDVa.....Nedavno sam na vulkalovom webshopu uzimao gume starom i dosta su povoljnije neg tamo u dućanu. Za sebe sam uzeo kod autokreše, bio neki popust....Taman s popustom cijena skoro ko u SLO....poneki modeli čak i jeftinije.
Staro 23.05.2017., 21:14   #29218
Postovi: 16,937
130k kuna za najjeftiniju verziju dizela je po meni daleko previše za Hyundai-a.
Ovaj od 136ks je već oko 180k kuna što je smiješno za to, iskreno.
Usporedi. Npr. vulkal i furlan pa vidi.
Ne isplati se baš više nešto previše. Ušaprati 100kn, možda.
Staro 23.05.2017., 21:25   #29219
zgmmax
zgmmax's Avatar
Postovi: 1,673
Previse para dodje i30 (najjeftiniji), a ima nikakvu opremu.
I onda kad jos pod opremu nabroje
Aero metlice brisača
Poklopci kotača pune veličine 15″
ako oces automatsku klimu moras ici na style plus paket, a najjeftiniji je 127kkn (benzinac), dizelas je vec na 142kkn.
EDIT:
Plus jos nekih 3500kn za metalik ili mineralnu boju na ove gore cijene
Staro 23.05.2017., 21:41   #29220
Gigi1
Postovi: 2,138
bas gledam, nije furlan jeftinij da bi se isplatilo ici.
kako sad imam 4 ljetne na autu, hoce li biti problema na tehnickom ako se napred stave all season gume a odostraga ostave stare ljetne, odnosno dali ce utjecati nes osjetno kod voznje, ili je bolje da naprijed stavim ljetne?
