Staro 05.05.2017., 12:57   #1
Antesan13
Datum registracije: May 2017
Lokacija: Brac
Postovi: 6
Open-Air Mining Frame
Bok svima.
Mozete li napisat gdje ste nabavili djelove za kuciste i kako ste ga sastavili dimenzije?
Zadnje izmijenjeno od: FRipper. 05.05.2017. u 19:46.
Antesan13 je offline   Reply With Quote
Staro 05.05.2017., 19:23   #2
dakky
Uptime freak
dakky's Avatar
Lokacija: Ri, Cro
Postovi: 2,958
Generalno se ne slaze kuciste nego ajmo to nazvati postolje.
Duza strana od 50 cm moze biti i dosta kraca, ali u principu to ti je skica.
Hvala overclock_freaku za skicu
Staro 05.05.2017., 19:43   #3
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
overclock nezna crtati :P
Evo moje slikice... srednja je po potrebi..
Dimenzije:
4x 46cm
2x 26cm
4x 15cm
2x 19cm
1x 40cm
Ako idete s dva napajanja onda poloča u sredinu a napajanja vani sa nekim držačima...
ID:	18038   Click image for larger version
ID:	18039   Click image for larger version
ID:	18040   Click image for larger version
ID:	18041   Click image for larger version
ID:	18043   Click image for larger version
ID:	18044   Click image for larger version
Staro 05.05.2017., 19:54   #4
Shamanix
Shamanix's Avatar
Postovi: 870
Imam i ja od svojih al je na papiru sve.. trebao bi skenirat ili uposlit starog da to odradi u AutoCAD-u
Shamanix je offline   Reply With Quote
Staro 06.05.2017., 01:04   #5
O9g1
Bee-do Bee-do Bee-do, TUP
O9g1's Avatar
Datum registracije: Aug 2009
Postovi: 323
Autor FRipper Pregled postova
LOLzzzzz, š'a jes', jes'!
SketchUp majka!
CPU: Intel i5 2500k (BX80623I52500K) cooled by Scythe Ninja3 (SCNJ-3000)
MBO: Asus P8Z68-V PRO/GEN3
RAM: 2x4GB Kingston 1600MHz, DDR3, XMP (KHX1600C9D3K2/8G)
GPU: GIGABYTE Radeon R9 290 4GB Windforce 3x (GV-R929OC-4GD)
SSD: Samsung 840 EVO 120GB (MZ-7TE120BW) - System
HDD1: WD Caviar Black 500GB (WD5001AALS) - Storage
HDD2: WD 250GB (WD2500JS-22MHB0 ) - Backup
ODD: Samsung 22/8/8/48/32x (SH-S222AB)
PSU: XFX XXX Edition P1-650X-CAG9 650W
CASE: Fractal Design Arc midi
FAN CONTROL: Scythe KAZE MASTER 5.25″ Bay Fan Controller (KM01-BK)
FAN: 2x Fractal Design Dynamic GP-14, 140 mm intake+2X Scythe S-flex 120mm (SFF21E) exhaust
OS: W10 x64
LCD:MASTER: LG 29UM57-P Ultra širok đubar, jooooj što ga volem... , SLAVE: Dell 17"
KEYBOARD: Logitech UltraX keyboard (Y-BL49)
MOUSE: Logitech G400
SOUND: Creative Sound Blaster X-Fi XtremeMusic
HEADSET: Steelseries Siberia v2
RALLYING GEAR: Logitech G25+homemade cokpit+handbrake (modani Genius MaxFighter F-16U)
IF IN DOUBT, FLAT OUT!!!
Don't touch it! It is mine! It's all miiiiineeee!!!
Lenovo Essential B580
CPU: Intel Celeron Dual Core B820 1.70GHz (2MB cache)
LCD: 15.6" HD LED 1366 x 768
GPU: Intel HD Graphics 3000
RAM: 4GB DDR3 1600MHz
HDD: 320GB SATA
ODD: DVDRW DL
PSU: Up to 4hours (Li-Ion 6 cell)
ETHERNET: Yes (Gb LAN)
COMM: Yes (802.11b/g/n)
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
FINGERPRINT READER: Yes
CAMERA: Yes
OS: Windows 7 Profesional
Lenovo ThinkPad E560
CPU: Intel Core i7-6500U 2.5 GHz
LCD: 15.6 inch 16:9, 1920x1080, IPS-Panel, LED-Backlight, glossy: no
Extern LCD:Lenovo X24a, 24 inch 16:10, 1920x1200, IPS-Panel, LED-Backlight
GPU: AMD Radeon R7 M370 2 GB GDDR5
RAM: 16GB, 2 x 8 GB DDR3L-1600
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
ETHERNET: Gigabit Ethernet
COMM: 802.11ac, Bluetooth, Intel Dual Band Wireless-AC 8260 - M.2 Card
CONNECTIONS: 3 x USB 3.0, HDMI, VGA, OneLink connector, LAN, Headphone/microphone combo jack
CARD READER: 4 in 1 ( SD Card, MultiMediaCard, SDHC Card, SDXC Card )
CAMERA: Yes
OS: Windows 10 64x
Poštena, dobra i odgovorna trgovina +još jedna...
Straight roads are for fast cars, turns are for fast drivers!
O9g1 je offline   Reply With Quote
Staro 12.05.2017., 10:59   #6
CheCola
Postovi: 371
kako palite te delanec rigove, ima negdje za kupit prekidača ili šarafciger metoda po matičnoj? Nekako mi se ne rastura kejs da izvadim prekidač a volio bi neko gotovo rješenje ako ga ima kod nas za kupiti.
CheCola je offline   Reply With Quote
Staro 12.05.2017., 11:00   #7
Shamanix
Shamanix's Avatar
Postovi: 870
Staro 12.05.2017., 13:11   #8
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
izvadio ovo iz starog kučišta.
Staro 13.05.2017., 20:15   #9
draksa
Postovi: 333
Dimenzije:
4x 46cm
2x 26cm
4x 15cm
2x 19cm
1x 40cm
Složio rig danas po po ovome samo malo širi ,thx
Zanima me kaj se može staviti ispod matične? Nemam obične standoffe, mogu li gumice nekakve?
draksa je offline   Reply With Quote
Staro 14.05.2017., 11:47   #10
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,327
također imam jedno više pa ako kome treba neka javi i pokupi to, free naravno, zg
otišlo
Zadnje izmijenjeno od: SetH. 14.05.2017. u 12:14.
SetH je offline   Reply With Quote
Staro 16.05.2017., 09:00   #11
johnsmith
Lokacija: vž
Postovi: 1,336
Sad ću ispast slon, al koje dimenzije letvica koristite odnosno koji je minimum za izradu framea? 20-25mm? Našo u podrumu 40x40 i čini mi se ogromno
Staro 16.05.2017., 09:12   #12
CheCola
Postovi: 371
ono što sam gledao na friperovom nacrtu rekao bi 3x3
Staro 26.05.2017., 21:15   #13
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Danas sam za 35 kuna u pevecu kupio letve 30x30 mm smreku, 2 komada po 2 metra. Sutra krecem sa izradom.
Staro 27.05.2017., 13:11   #14
johnsmith
Lokacija: vž
Postovi: 1,336
Autor Gilbert5 Pregled postova
Glavno da su letve ravne, a ne ovo trešće koje sam ja uspio naći
Staro 12.06.2017., 13:01   #15
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Hvala kolegi kopija na preporuci susjeda. Za 120kn nema boljeg
Koliko sam čuo, ima ih još na lageru.
Bez potpisa.
Staro 20.06.2017., 12:15   #16
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,684
Autor RaneZ Pregled postova
Možda si i ja kupim jednog Frippera kad se obogatim rudarenjem.
Do tada i ovo služi svrsi.
kopija je online   Reply With Quote
Staro 15.10.2017., 18:03   #17
baTman
Lokacija: asfsafsa
Postovi: 327
http://forum.pcekspert.com/showthread.php?t=285672
Ima li neki tutorial kako napraviti drveno kuciste? Imam sve od alata, cak i vise, samo neznam kako zapoceti, brine me kako npr spojiti 2 "tanka" komada drva. Prvo sam mislio ljepilom, pa cavlom pa vise nista neznam kako to odraditi pravilno pa mi treba neki savjet ili makar link na neki tutorial jer cim upisem mining wood case ne baca nikakav tutorial.
baTman je offline   Reply With Quote
Staro 15.10.2017., 18:11   #18
renaTq
renaTq's Avatar
Postovi: 387
#propo
renaTq je offline   Reply With Quote
Staro 15.10.2017., 18:16   #19
baTman
Lokacija: asfsafsa
Postovi: 327
Hvala, mislim da su ovo mali dugi sarafi koji se samo rucnom "busilicom" na baterije zavida i to je to?
Staro 15.10.2017., 20:01   #20
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
http://www.ikea.com/hr/hr/catalog/pr.../?query=albert
Ako možeš bolje i jeftinije od ovoga svaka ti čast.
Staro 15.10.2017., 20:39   #21
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Autor Blue_Fatal1ty Pregled postova
Ali kako namontiraš rig u to? Imaš kakve slike?
Staro 15.10.2017., 23:07   #22
baTman
Lokacija: asfsafsa
Postovi: 327
Nije lose, ali koliko vidim i tu bi trebalo nekoliko modifikacija napraviti ili se varam?
Staro 15.10.2017., 23:42   #23
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Uz male modifikacije.
https://imgur.com/a/DZIXv
Staro 21.10.2017., 19:01   #24
baTman
Lokacija: asfsafsa
Postovi: 327
Nabavio drvo, sada... jelii ma neki build da nema veze jeli to 570,580 kartica? Mislim na visinu-sirinu?
Staro 21.10.2017., 19:50   #25
Sniper
Community Manager
Sniper's Avatar
Postovi: 313
Napravio prije koji tjedan?
Ovako nešto:
https://imgur.com/JDVTAIF
Sniper je offline   Reply With Quote
Staro 21.10.2017., 20:46   #26
baTman
Lokacija: asfsafsa
Postovi: 327
Da, to mi se svida, ali jeli to ima neku univerzalnu visinu/sirinu? Pitam jer ako kupim rx 570 ili 580, a drugacije su visine i sirine. Jos nesto mozes napisati koje si dimenzije napravio?
Staro 21.10.2017., 22:43   #27
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Daj mi objasni što točno fali ovom threadu da je bilo potrebno otvarati novi bez da se pitalo da li se smije otvoriti?
Prebačeno sve tu..
Staro 27.10.2017., 14:22   #28
ICT Avatar
ICT Avatar's Avatar
Datum registracije: Dec 2014
Lokacija: Area 51
Postovi: 234
Moja verzija za paljenje mbo
ICT Avatar je online   Reply With Quote
Staro 13.11.2017., 10:39   #29
tabana
Postovi: 60
Volio bih čuti savjet oko hlađenja od iskusnih majnera.
Izrađujem novi frame za 10-13 GPU-a i zatvaram ga u ormar. Hladni zrak bi dovodio kroz rupu s donje strane, a topli odvodio ventilatorom s gornje strane. Zbog toga sam grafičke zarotirao za 30°.
Zanima me jesam li dobro okrenuo grafičke? Na internetu uglavnom vidim ventilator na prednjoj strani GPU-a. Meni se čini da sve kartice najviše toplog zraka izbacuju baš na prednju stranu, pa sam zato predvidio usis zraka sa stražnje strane (gdje su konektori) kartica.
Zadnje izmijenjeno od: FRipper. 13.11.2017. u 11:20.
tabana je offline   Reply With Quote
Staro 13.11.2017., 11:14   #30
Alister
Alister's Avatar
Postovi: 1,491
ja bi grafičke okrenuo za da gledaju gore, jer one ispuhuju topli zrak na prednju rešetku ovako će ti se dodatno grijati cijeli rig ako bi ga još zatvorio
Alister je online   Reply With Quote
