Staro 30.04.2017., 22:32   #241
gin.tonic
gin.tonic's Avatar
Postovi: 2,421
Autor Dottore Pregled postova
Rade li vam torrenti?
Rade
gin.tonic je offline   Reply With Quote
Staro 01.05.2017., 08:38   #242
santos
santos's Avatar
Lokacija: Čakovec / AT
Postovi: 1,782
rade ali treba smanjiti broj konekcija ako ti puca dok skidas...
slow is smooth, smooth is fast...
santos je offline   Reply With Quote
Staro 02.05.2017., 00:15   #243
Dottore
Dottore's Avatar
Postovi: 7,591
Autor gin.tonic Pregled postova
Rade
Fala!
Autor santos Pregled postova
Do koliko?
Sent from my Nexus 6P using Tapatalk
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Dottore je online   Reply With Quote
Staro 02.05.2017., 05:41   #244
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
evo ti dokaz da snaga signala, sum i ostalo nemaju toliko direktne veze sa downloadom i uploadom:
Može molim te neki tutorial kak se spojiti s tom aplikacijom? Probao s 2 mobitela i stalno piše contacting router API...
d4rk_ch1ld je offline   Reply With Quote
Staro 02.05.2017., 09:35   #245
Cr00k
Postovi: 28
Cr00k je offline   Reply With Quote
Staro 02.05.2017., 10:30   #246
santos
santos's Avatar
Postovi: 1,782
ja sam stavio na 100 konekcija (global connections) I ogranicenje download jer mi opet baca ako ostavim na full... limitirao sam do na 2.5 megabajta u sekundi I radio je dobro.
samo klikni ovu refresh ikonu gore desno i trebalo bi ti se sve ucitat
Staro 02.05.2017., 10:58   #247
jacobbb
jacobbb's Avatar
Lokacija: somewhere
Postovi: 565
ja sam jučer skinuo neki fajl od 2,5 gb preko torrenta, brzina je stalno skakala od 1 do 7.5 mbps no skinuo je opet dosta brzo. nikakva ograničenja nisam stavio.
nego jel tko gledao na moj.tele2 portal, meni od jučer stoji trenutna potrošnja 169kn iako tek 3 dana koristim uslugu. jel tako i kod drugih?
jacobbb je offline   Reply With Quote
Staro 02.05.2017., 22:08   #248
arrow
arrow's Avatar
Datum registracije: Nov 2014
Lokacija: Zd
Postovi: 609
uzeo i ja
cekam aktivaciju SIM kartice pa da napravim testove, ne ocekujem previse samo nek je malo bolje od 7.2/2
arrow je offline   Reply With Quote
Staro 02.05.2017., 22:32   #249
dhalan
Datum registracije: Apr 2008
Lokacija: Gračac
Postovi: 177
Šum (SINR) ima velik utjecaj na download, to sam se uvjerio dok sam ganjao signal od VIPa.
Kod mene se preklapaju dva odašiljača od VIPa i imam velik šum i zbog toga loš download, a upload je uvijek dobar.
Stavio sam router u auto i vozio se dok nisam iza brda umakao jednom odašiljaču. SINR je otišao na maximum (30) i brzina downloada se uduplala.
Mislim da silver_tip ima sličan slučaj. Sve dok mu SINR i RSRQ ne budu bolji, mislim da neće imat veći download, a čini mi se da je oko 45 Mbps uploada maximum.
Pa čak ni s ove dvije antene ne mogu imat dobar signal od Vipa.
Zato Tele2 leti
dhalan je offline   Reply With Quote
Staro 02.05.2017., 23:03   #250
arrow
arrow's Avatar
Lokacija: Zd
Postovi: 609
opaaaa, ide mali
Staro 03.05.2017., 09:04   #251
santos
santos's Avatar
Postovi: 1,782
moj probni period je danas gotov, vracam opremu...
btw nedo Bog da vam prebaci na 3g mrezu... brzina mi pala na 2.7 mbita... znat cete da vam se prebacilo na 3g mrezu tako sto lampica vise nije cijan boje nego klasicna plava na ruteru... samo disconnect i connect i onda je nazad na 4g
Staro 03.05.2017., 09:13   #252
johnsmith
Lokacija: vž
Postovi: 1,330
Sta se neda "lockat" na 4G only?
Staro 03.05.2017., 09:15   #253
Dubach
Datum registracije: Mar 2017
Lokacija: Zabok
Postovi: 56
Iz kojeg razloga vračaš? Nisi zadovoljan ili?
Dubach je offline   Reply With Quote
Staro 03.05.2017., 09:23   #254
santos
santos's Avatar
Postovi: 1,782
ma ostavio sam na automatski, da se u opcijama stavit na 4g only...
uzimao sam s namjerom da samo testiram.... cekam da se pokace svi koji se misle pokacit pa da vidim dal ce mreza patit ili ne.... nije da nisam zadovoljan, jedino me smeta ovo pucanje na p2p ako ne smanjis brzine i broj konekcija... inace je radilo oke u ovih 5 dana
Staro 03.05.2017., 12:30   #255
Nevidljivi
Nevidljivi's Avatar
Datum registracije: Oct 2015
Postovi: 51
ajde javi i koliko je trajalo da sve to sa njima na salteru rijesis kada si vratio opremu.
dali je gnjavaza ili je stvar uhodana ?
Nevidljivi je offline   Reply With Quote
Staro 03.05.2017., 13:32   #256
santos
santos's Avatar
Postovi: 1,782
will do.
evo testiranja iz koprivnice, centar. ubi me ako ja kuzim kako ovaj signal funkcionira... 2 mjerenja koja su iznad 40/45 mbita u downloadu su u uredu, prostorija sa prozorcicem 40x40 cm, sve ostalo u zidu, i kroz prozor 10 m dalje zid druge zgrade...
a ova mjerenja ispod su u vecoj prostoriji , gdje je cijela vanjska strana zida u staklu...
Staro 03.05.2017., 13:46   #257
VandaL.pr!
VandaL.pr!'s Avatar
Lokacija: zaDAR
Postovi: 821
Autor arrow Pregled postova
opaaaa, ide mali
To u Zadru? Koji kvart?
Staro 03.05.2017., 14:13   #258
arrow
arrow's Avatar
Lokacija: Zd
Postovi: 609
Autor -^sato. Pregled postova
u jednom naselju blizu Benkovca, odasiljac cca 500m od mene
to je bilo sinoc u 23h, evo sada test u 14h
EDIT:
malo sam ga setao po sobi, najbolje hvata na sred sobe okrenut prema odasiljacu(to je onaj prvi speedtest rezultat) no nema smisla da ga tu drzim, sad je na pc-u i jedino upload malo opao
EDIT2:
Zadnje izmijenjeno od: arrow. 03.05.2017. u 14:33.
Staro 03.05.2017., 14:19   #259
santos
santos's Avatar
Postovi: 1,782
raskid ugovora je trajao koliko i sklapanje, nikakvih problema, jedino sto se proporcionalni iznos ne moze platiti na licu mjesta, nego ti dodje uplatnica doma. a kak sam ja imao probni rok na prijelazu iz mjeseca u mjesec, dobit cu dvije
Staro 03.05.2017., 16:00   #260
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,691
Raskinuo i ja, jebiga, brzina nevalja na lokaciji gdje mi treba.
Imam 2km do odasiljaca, ali nemam LOS, malo brdo izmedju. Jedva hvata 3g ,jako nestabilnih 10/3, nekad padne na 3/1.
A Tcom odasiljac je na 5.7km udaljenosti, ali ima LOS, brzina 60/30 fix.
Tako da sam se vratio natrag na Tcom visitors tarifu, 7 dana flat 4g za 80kn.
Nije preskupo za 3 miseca apartmana.
Staro 04.05.2017., 19:48   #261
bachvamix
bachvamix's Avatar
Datum registracije: Apr 2017
Postovi: 52
Autor jacobbb Pregled postova
Odmah zi na početku stave cijenu za taj mjesec. Tako je i kod mene bilo, ali sam na kraju vratio zbog slabijeg signala na području gdje mi je bio potreban.
bachvamix je offline   Reply With Quote
Staro 05.05.2017., 07:55   #262
domis
Lokacija: Hrvatistan
Postovi: 4,164
will do.
Prouči sastav tih staklenih ploča na zgradama i jasno bude ti
Relativno čest problem u Zagrebu na takvim zgradama
Staro 05.05.2017., 10:17   #263
Tihomir111
ZeNgE_Tiho_Cro
Tihomir111's Avatar
Lokacija: Virovitica
Postovi: 466
Kako vam rade FPS igre preko 4g/lte? Usporedivo sa žicom? Umiranje iza zaklona i sl peezdarije?
Tihomir111 je offline   Reply With Quote
Staro 05.05.2017., 11:30   #264
buljaka
Datum registracije: Aug 2014
Postovi: 2,927
Vip homebox 4g ping cs go od 30 do 55.
Sent from my SM-G930F using Tapatalk
Staro 05.05.2017., 12:01   #265
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
Kakva veličina kartice se dobije za pokućni? Dobio neki razbijeni galaxy s6 koji radi pa da ga upogonim kao modem za probu.
Staro 05.05.2017., 12:22   #266
santos
santos's Avatar
Postovi: 1,782
full size sim card
Staro 05.05.2017., 12:24   #267
Enna
Datum registracije: Jan 2017
Postovi: 15
Imam pokrivenost 3g signalom planiram uzeti taj pokucni od tele 2 ali vidim da bas i nije dobar na 3g mrezi ..sad imam fiksni vipov i nikad ne ide do 4mbit..padne na 2.6 do 3.20mbit.
Sto kazete dal se iplati ili ne
Poslano sa mog HUAWEI NXT-L29 koristeći Tapatalk
Enna je offline   Reply With Quote
Staro 05.05.2017., 12:24   #268
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
Uf, not good. Mislio sam da se barem dobije micro sim. Imam note 3 sa micro i s6 sa nano sim. Možda ima mogućnosti uzimanja manje sim kartice. Budem probao zvati.
edit: eto upravo zvao službu i kažu da sam mogu birati koja god mi veličina sim kartice odgovara na licu mjesta.
Staro 05.05.2017., 18:41   #269
dhalan
Lokacija: Gračac
Postovi: 177
Ja sam dobio 3u1 SIM
A što se tiče 3G... ako ne misliš igrat online, možda ti bude ok
Staro 05.05.2017., 19:14   #270
gin.tonic
gin.tonic's Avatar
Postovi: 2,421
Autor dhalan Pregled postova
To se dobi
