Staro 13.11.2005., 01:46   #1
Postovi: 7,568
Xfx 7800gtx 512mb Gddr3
Scores of upcoming cards, or at least some of them, have already leaked on the internet.
Perhaps someone went to a shop and bought one, possibly for the insane amount of $799 that Theo mentioned here but we learned that price hasn't stopped enthusiasts as those cards sold out imnediately. As Nvidia said, it's not expensive if people want to buy it.
The XFX card is by default clocked to 580MHz core and 1730MHz memory and at that speed with not the fastest around Athlon X2 3800+ it can score 9871 3dmark. If you overclock the card to just 600MHz core and 1800MHz memory you can score 10110 3dmarks.
You actually do a CPU like the Athlon FX 57 to unleash the pure power of this card and that's what reviews on Monday will show. For all of you impationt one, bear in mind that cards will be in retail at launch.
Izvor: www.theinquirer.net
Staro 13.11.2005., 03:12   #2
psf[i]-[Tomek]
-nVidiot-
psf[i]-[Tomek]'s Avatar
Lokacija: Varaždin/Zabreg
Postovi: 962
Lijepo je za vidjeti da cijena ipak nije 799$ nego je ipak nešto niža 649$!
Dam se kladiti da bu ta kartica prije dobavljiva u hrvata nego X1800XT!
psf[i]-[Tomek] je offline   Reply With Quote
Staro 13.11.2005., 13:05   #3
Postovi: 7,568
Mislim da bu, bez obzira na cijenu, kartica (kad napokon stigne u naše IT dućane), jednostavno ''planula''.
Staro 14.11.2005., 08:36   #4
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Bez ikakove sumnje
Staro 14.11.2005., 09:25   #5
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,847
čito čito,je to ultra ili ne??ili gtx sa 1.2 ili 1.1 ns memorijom.
Staro 14.11.2005., 09:27   #6
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,847
piše li di koje će napajanje trebati od 1 KW ??
Staro 14.11.2005., 14:16   #7
Beren
PC Ekspert šerif
Beren's Avatar
Datum registracije: Feb 2002
Lokacija: Vječno u labu...
Postovi: 1,496
To je Ultra koju su premienovali u GTX 512.
Ne treba ti nekakvo posebno napajanje - dosta je 350 kvalitetnih watta.
Beren je offline   Reply With Quote
Staro 14.11.2005., 15:58   #8
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
http://www.anandtech.com/video/showdoc.aspx?i=2607
evo i testa dotične.
Hm coller je mrcina još malo pa ćemo imat neku mrcinu tipa zalman 7700 na grafama, neke kutije su im već veće od standardne kutije za matičnu.
Utrka postaje jako zanimljiva jer kako anandtech veli :"Before we get into the thick of it, it is important to note that ATI released drivers last week that greatly improve OpenGL performance with 4xAA. One of the suprises we will see from this new ATI creation is that the X1800 XT actually bests the current 7800 GTX in Doom 3 when 4xAA is enabled. This driver is a welcome development from ATI (whose OpenGL drivers have been somewhat lacking for quite some time), but with the new 7800 GTX 512 coming up to bat, it may be too little too late."
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 14.11.2005., 16:13   #9
Mad_Duke
Ma drekec. Pogledaj Quake4. Skoro pa nitko ne igra doom3 koliko sam skuzio, dok se quake 4 koji je bolje postelan vec vrti svugdje!
Staro 15.11.2005., 09:33   #10
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,847
ne vidim test overklokinga,što nisu rekli da će ultra imati 32 topa.
Staro 15.11.2005., 09:59   #11
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,847
na guru sajtu su isto tetirali ali u sli modu.
Staro 15.11.2005., 14:11   #12
Postovi: 7,568
Tak je.
32 pixel cjavovoda, te min. 2.0 GHz memorija, a možda stave i 2.5 GHz i to GDDR4. GPU bude sigurno između 600 i 700 MHz, a možda i malo viši. Uglavnom vidli bumo kad to čudo stigne nekom u ruke. Cijena bu takva da nam padne mrak na oči.
Staro 15.11.2005., 14:45   #13
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Tak je.
ipak se ne može očekivat da će ta kartica biti jeftina
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 15.11.2005., 14:52   #14
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,847
negdje sam čito i 800mhz za ultru,šot se cijene tiče dignut ćemo nenamjenski kredit:clap: .
Staro 15.11.2005., 14:53   #15
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,847
sad vidim da su i tu recenzirali 7800 gtx 512,ali je nisu klokali a zašto.:confused:
Staro 15.11.2005., 15:45   #16
Postovi: 7,568
Imaš na netu masu recenzija di su ju clockali.
Staro 15.11.2005., 15:56   #17
FERRYS
AutoCad & Allplan expert
FERRYS's Avatar
Postovi: 2,159
evo i recenzije na pce-u
ajverojatnije nvidia jos uvijek drzi asa u rukavu, jer ova ima "samo" 24 pipelina a ultra ce bit valjda jos zesca s zescom memom...
neko je dobro reko - nenamjenski kredit ce trebat....
none
Staro 15.11.2005., 16:33   #18
Postovi: 7,568
Mislim da bu cijena Ultre negdje između 5.500 i 6.500 kuna.
Staro 15.11.2005., 18:33   #19
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,847
5.500-6500 taman,odmah par komada naručujem,samo mi treba ženska čarapa malo deblja,bicikl i .
