Staro 13.11.2005., 18:51   #1
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,531
Posebno digital audio out, a posebno analog
Pade mi nesto na pamet, da li bi se moglo nekako iskemijati da mi recimo foobar svira preko digitalno izlaza o ostalo preko analognog? Spojio sam receiver preko SPDF-a i bilo bi dobro da na nemu foobar svira a da mi win sounds ide na kompjuterske zvucnike.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 15.11.2005., 13:36   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Re: Posebno digital audio out, a posebno analog
Uf, ne mogu se trenutno sjetiti ali mislim da kaj se tiče DFI NE SMIJEŠ imati ništa drugo uštekano kad je priključen SPDF...
Pazi, nisam ziher-budem pogledao pa ti javim.
Staro 15.11.2005., 15:24   #3
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,531
Re: Re: Posebno digital audio out, a posebno analog
Pa vec imam. Jelc idu u q, sasro sam se Evo iz manuala koji se skidao tako sporooooo:
The system board is equipped with an onboard S/PDIF-in RCA jack
(red) and a S/PDIF-out RCA jack (yellow) at locations CN5 and
CN7 respectively.
The S/PDIF connector at location J3 is used to connect to
optical S/PDIF ports. The S/PDIF ports may be mounted on a card-
edge bracket. Install the card-edge bracket to the system chassis
then connect the audio cable connector to J3. Make sure pin 1 of
the audio cable connector is aligned with pin 1 of J3.
DO NOT use RCA S/PDIF and optical S/PDIF at the same time.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Zadnje izmijenjeno od: LAcy. 15.11.2005. u 15:55.
Staro 15.11.2005., 22:55   #4
Jelc
Super Moderators
Postovi: 17,485
Re: Re: Re: Posebno digital audio out, a posebno analog
Ma znao sam da je bilo neko upozorenje ali se napamet nisam mogao sjetiti.
Jesi kaj riješio??
Možda da probaš na nekoj našoj news grupi koja se tim bavi?
Staro 15.11.2005., 23:14   #5
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,531
Re: Re: Re: Re: Posebno digital audio out, a posebno analog
Jesi kaj riješio??
Ma nisam, danas sam imao pametnijeg posla
MacBook M1 Pro
MacBook Air M2
Moto Edge
