Staro 15.04.2017., 17:49   #3721
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
1 x Gigabyte AB350M-Gaming 3 Socket AM4 (AMD RYZEN™ processor), 4*DDR4 3200, USB3.1/USB 2.0, DVI-D, VGA, HDMI, M.2, SATA III, RAID, GLAN, mATX
1 x AMD CPU Desktop Ryzen 5 1600 (6C/12T, 3.4/3.6GHz Boost,19MB,65W,AM4) box, with Wraith Spire 95W cooler
1 x Corsair 2x8GB DDR4 2666 C16 LP
1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance
1 x Toshiba SSD A100, R550/W480, 120GB,7mm,2.5"
1 x Zalman Z1, USB3.0 black, 2x120mm
1 x Fortron Hyper 500W, 80+ - 60mj.
1 x GIGABYTE GeForce GTX 1050 GDDR5 2GB/128bit
Ukupno: 6.222kn s forumskim popustom(2%)
Zadnje izmijenjeno od: coconut. 15.04.2017. u 20:48.
Staro 16.04.2017., 20:03   #3722
pljugi
Lokacija: /dev/random
Postovi: 42
Kolega mi predložio ovu konfu:
Code:
Procesor AMD Ryzen 5 1600 BOX, s. AM4, 3.4GHz, 19MB cache, Six Core, Wraith Spire Cooler
Matična ploča MSI B350 PC Mate, AMD B350, DDR4, zvuk, G-LAN, SATA, M.2, PCI-E 3.0, CrossFire, D-Sub, HDMI, USB 3.1-C, ATX, s. AM4
Memorija PC-21300, 8GB, KINGSTON HyperX Fury HX426C15FB/8 DDR4 2666Mhz
SSD 256.0 GB INTEL Series 600p SSDPEKKW256G7X1, M.2, 80mm, PCIe NVMe 3.0 x4, 1570/540 MB/s
Grafička kartica PCI-E GAINWARD GeForce GTX 1060, 3GB, DDR5, DVI, HDMI, DP
Napajanje 600W, CHIEFTEC Smart Series GPE-600S, ATX v2.3, 120mm vent, PFC
Kućište ANTEC NSK4100, MIDI, ATX, crno, USB 3.0, bez napajanja
Ukupno: 6.902,48 kn (links.hr)
Nisam neki gejmer ali bi volio tu i tamo odigrati neki hit, komp bi koristio prvenstveno za za CAD/CAM (SolidWorks / Solid Edge, AutoCAD). Može preporuka slične konfiguracije, ali da prođem jeftinije.
pljugi je offline   Reply With Quote
Staro 16.04.2017., 20:30   #3723
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Izbacio bi msi ploču i ubacio asus b350 prime plus, ili gaming 3 (bilo matx ili atx) od gigabytea
Možeš uštediti još na SATA SSD-u, rx 470 4gb (ne referentnu sa blower coolerom). Napajanje recimo hyper 500w ili 600w (5 god. garancije, a jeftino i pristojno), no nemaš ga u linksu. Case zalman z3, z1 neo (dosta gratis ventova)
Staro 17.04.2017., 23:25   #3724
listerstorm
listerstorm's Avatar
Datum registracije: Apr 2011
Postovi: 1,430
Pozdrav društvo,
Trebao bih komentare za kantu, frend mi uzima novo a namjena je office, multimedija i gaming (full HD rezolucija). S tim da za gaming nije siguran koliko će imati vremena ali volio bi da može vrtit nove naslove (kontam da bude 50-60 FPS-a).
Gigabyte Main Board Desktop AB350M-Gaming 3
Kingston 8GB 2666MHz DDR4 CL15 DIMM HyperX FURY Black
XFX AMD Radeon RX 480 RS GDDR5 4GB
Intel® SSD 600p Series (256GB, M.2 80mm PCIe 3.0 x4, 3D1, TLC)
Napajanje Seasonic SS-520GB, 520W
Fractal Define S, crno s prozorom, bez napajanja
To je nekih 7,7 tisuća.
Moglo bi jeftinije za cca 500 kn uz običan SSD i npr. Zalman z3+ kućište.
Može li se tu složiti nešto bolje za te pare ili jeftinije a da ne gubi na performansama?
Razmišljam i o intel + nvidia opciji, tamo je sigurno "plug and play" i može se jeftinije uz i5 i matičnu (ne bih volio neka iznenađenja s kompatibilnošću, BIOS-om, driverima itd., ako je to moguće u AMD slučaju).
thx
Staro 17.04.2017., 23:36   #3725
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
1 x Gigabyte AB350-Gaming 3, Socket AM4 (AMD RYZEN™ ), 4*DDR4 3200, RAID, LAN, ATX
1 x Kingston 8GB 2666MHz DDR4 CL15 DIMM HyperX FURY Black, EAN: 740617244397
1 x XFX AMD Radeon RX 480 RS GDDR5 4GB/256bit, HDMI, DVI, 3xDP, DD 2X, Backplate, Retail
1 x SSD Patriot Hellfire R3000/W2200, 240GB, M.2 NVMe
1 x Kućište DeepCool Dukase V2, USB3.0, plexy, black
1 x Fortron Hyper 600W, 80+ - 60mj.
Ukupno: 7836,40 kn -2% = cca 7650kn
*Iako za takav gaming je dosta RX470/570
Staro 17.04.2017., 23:52   #3726
listerstorm
Postovi: 1,430
Uzeo bih 470 grafu ali zanemariva je razlika u cijeni jer ta 480 je 1,8 tisuća, a ne nađem značajno jeftiniju 470.
Izgleda dosta slično mojoj kanti a i cijena je skoro ista. Tih 2% jel to kod uzija?
Zadnje izmijenjeno od: coconut. 18.04.2017. u 07:49.
Staro 19.04.2017., 13:30   #3727
big_B
big_B's Avatar
Postovi: 560
Bok, tražim novu kantu (nije potrebno da lijepo izgleda) kojoj je primarni zadatak poslovna namjena (2D autocad, i kojekakvi programi za poračune). Proračun mi iznosi cca 6300 kn s PDV-om (trebam R1 račun).
U početku sam mislio da neću preživjeti bez i7 procesora, no nakon nešto istraživanja sam shvatio (moguće krivo?) da vjerojatno može koristiti i jača verzija i5 (7500?). OC i pojačano hlađenje me ne zanima. O AMD-ovim procesorima ne znam mnogo.
Ostali uvjeti bi bili min 8 Gb RAM-a (za sada, jasno je da će ovo uskoro postati premalo) i 120-240 Gb SSD + HDD (moguće 1 Tb).
Moguće da me uhvati kakvo igranje, pa bi bio sretan kada bi u konfiguraciju upala grafička kartica, tako da integrirana ne krade sistemski RAM. Kratica bi trebala izdignuti performanse kante iz područja integriranih kartica u područje „ide igranje, ali ne na nekim visokim rezolucijama/bijesnim detaljima/visokim FPS-ovima“. Svojedobno sam negdje pročitao da je i slabija kratica mnogo bolja od bilo koje integrirane (jesam li u krivu?).
Sve je na kraju potrebno zalijepiti na primjerenu ploču i napajanje.
Kopanje po trgovinama je došlo do približnih rezultata tipa (potrebne manje izmjene):
https://www.centro.hr/extro-havocpro...freedos-1.aspx
https://www.instar-informatika.hr/ra...99901/product/
https://www.futura-it.hr/katalog/got...la/futura-037/
Imate li kakvo mišljenje/prijedlog?
big_B je offline   Reply With Quote
Staro 19.04.2017., 13:43   #3728
Postovi: 34,005
Gotove kante u pravilu treba izbjegavati. Dečki će ti uvijek složiti nešto bolje za tu lovu.
btw, vidim da govoriš o R1. Da li to znači da ti trebaju i Winsi (firma mora imati legalno kupljene winse)?
Staro 19.04.2017., 14:42   #3729
big_B
big_B's Avatar
Postovi: 560
Nije mi potreban operacijski sustav.
Staro 19.04.2017., 14:58   #3730
Smartic
Smartic's Avatar
Postovi: 2,707
AMD Ryzen R5 1600
Asus Prime B350M-A
2x DDR4 8GB (1x8) PC4-19200 2400MHz CL15 G.Skill, F4-2400C15S-8GNT
Grafička kartica MSI RX460 2G OC, 2GB GDDR5, 1210/1750MHz
Napajanje 500W FSP Fortron/Source Hyper M
Toshiba P300 1TB HDD
SSD 128GB Samsung PM961, M.2 2280 PCIe
Kućište Zalman Z1
~6000kn
Staro 19.04.2017., 15:06   #3731
Doc
Postovi: 430
1 x Patriot Viper4, 2800Mhz, 16GB (2x8GB), CL16
1 x Asrock Fatal1ty AB350 Gaming K4, Ryzen, S.AM4
1 x GIGABYTE GeForce GTX 1050 OC GDDR5 2GB/128bit, WINDFORCE 2X
1 x GIGABYTE Pulse 450W, Modular, 80+ Bronze
Ukupno: 6552,00 kn -2% popusta = 6420kn. Slaganje i dostava u cijeni.
Doc je offline   Reply With Quote
Staro 19.04.2017., 16:40   #3732
big_B
big_B's Avatar
Postovi: 560
U redu, vidim Intel nije u konkurenciji.
Bi li mogli ugurati SSD od 240 Gb umjesto 120 Gb, te kolika bi bila razlika u cijeni (možda neku komponentu pojeftiniti)?
Samsung PM961 je neki divlji SSD s čitanjem od 3 Gb/s?
Koliko mi u životu znači razlika u fekvenciji RAM-a 2400 i 2800 Mhz?
Autor Smartic Pregled postova
~6000kn
O kojoj trgovini je riječ?
Probao sam složiti ovu konfiguraciju u ADM-u, i ispalo je 7000 kn
Autor Doc Pregled postova
Također isto pitanje, o kojoj trgovini se radi.
Staro 19.04.2017., 16:47   #3733
Autor coconut Pregled postova
Gotove kante kod nekih pouzdanih šopova tipa Uzi i Futura su sasvim OK jer dečki koji rade tamo (kao i owneri) itekako prate situaciju, kako potreba tako i ovog foruma
Gotove kante se ne kupuju od trgovačkih centara tipa Konzum, Elipso, ex Tehnomarket i slično.
Sent from my SM-G930F using Tapatalk
Staro 19.04.2017., 17:35   #3734
Smartic
Smartic's Avatar
Postovi: 2,707
Autor big_B Pregled postova
Da, u ADM-u je složeno, i ovo je cijena na 12+ rata iz tvojeg screenshota. -700kn ide za gotovinu. 200kn sam premalo napisao jer sam neku drugu konfu slagao
Staro 19.04.2017., 19:34   #3735
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
big_B
Ovako mislim da je najbolje ako hoćeš veći SSD, jer realno, da malo je 120GB.
1 x Gigabyte AB350-Gaming, Socket AM4 (AMD RYZEN™)
1 x XFX AMD Radeon RX 460 GDDR5 2GB/128bit
1 x Kingston UV400 240GB SSD, 2.5” 7mm, SATA 6 Gbit/s
Ukupno: 6567,00 kn -2% = cca 6440 kn Trgovina je ona treča... a i u ostalom treba baciti malo oko na iskustva
Ryzen bolje radi sa bržom memorijom, te svakako gledaj minimalno 2800MHz.
Staro 19.04.2017., 20:01   #3736
Doc
Postovi: 430
Kod kolege, pošalji mu nick s foruma da dobiješ 2% popusta.
Staro 19.04.2017., 20:08   #3737
big_B
big_B's Avatar
Postovi: 560
Može li netko iz prve ruke reći koliko SSD-ovi koji su uštekani u MBO s deklariranim brzinama od 3 Gb/s rade bolje/brže od ovih koji su na žici. Isplati li se u to ulagati. Kad imaš takav disk na sistemskoj particiji, jel' te onda počne sekirati čekanje dok se ne otvori nešto što se nalazi na rotirajućoj šajbi?
Staro 19.04.2017., 20:16   #3738
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Pa zavisi što radiš... imaš na netu razne usporedbe pa odluči...
Ako gledaš M.2 gledaj gen2 ili gen3
Staro 19.04.2017., 22:52   #3739
big_B
big_B's Avatar
Postovi: 560
...zaključio sam da mi ipak ne treba 3 Gb/s, ukoliko imam dosta RAM-a, u koji će sve biti učitano.
Nadalje bih radije kupio EVO 850 250 Gb od Samsunga (s njim imam iskustva).
Kako ste rekli da procesor može iskoristiti brži takt RAM-a, malo sam modificirao ponudu od ADM-a (Corsair RAM na kojem piše 2400-3000 Mhz, što je valjda usporedivo s 2800 Mhz):
Čini mi se da je ADM ovdje ispao za dlaku bolji.
Treba mi samo još potvrda da odabrani Corsair-ov RAM može raditi s ovom pločom.
Proračun je probijen za 500 kn. Mogu eventualno kupiti jeftinije napajanje kod ADM-a (-100 kn) i to bi bilo to.
ASUSov Prime B350M-A nije baš najbolje prošao kod publike (čitajući komentare, te sam ploču ostavio od Asrock-a)
Što kažete?
Staro 20.04.2017., 09:45   #3740
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ok adm je jeftiniji 100kn doslovce (kada u futuri dodaš bolje hyper 500), a jesi čitao iskustva?
Eto to kažem
Moj savjet je da gledaš Futuru i UZI, ipak su kolege tu sa foruma i sve će ti riješiti ako bude problema... Jer realno ako ti to nije važno, možeš kupiti i u njemačkoj
Edit sada vidim, u futuri si stavio skuplji 1600 a imaš jeftiniji za 100kn... tako da opet nije baš adm jeftiniji
Zadnje izmijenjeno od: FRipper. 20.04.2017. u 09:50.
Staro 20.04.2017., 09:46   #3741
Doc
Postovi: 430
Kolega, matematika vam nije jača strana? ADM je skuplji 12kn, ali ima bržu memoriju i hyper 500.
Makar Big_b je odabrao krivi procesor, imaju ih više na webu, kad uzmeš ovaj onda je futura jeftinija 130kn.
Staro 20.04.2017., 10:34   #3742
Postovi: 16,971
Od ove dvije meni se ADM čini bolja solucija, napajanje ne daleko bolje.
Ali kako kaže kolega, javiti se Uzi-u i riješiti će se sve.
Staro 20.04.2017., 10:41   #3743
Doc
Postovi: 430
Potpisujem, dodaj još 16kn pa uzmi hyper 500w.
Staro 20.04.2017., 10:46   #3744
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Pa bolja je solucija samo zato jer je uzeo krivi procesor...ak uzme jeftiniji a isti dobiti će isti komp u Futuri za manje love + da ne pričam duplo bolju uslugu. Čak može i bolju Gigabyte ploču ubaciti.
1 x Samsung 850 EVO 250GB SATA 2.5"
Ukupno: 6807,00 kn -2% = cca 6675kn
*S Asrock pločom ispada oko 40kn manje
Zadnje izmijenjeno od: FRipper. 20.04.2017. u 10:54.
Staro 20.04.2017., 15:01   #3745
big_B
big_B's Avatar
Postovi: 560
Nakon još malo istraživanja sam shvatio sljedeće:
1) RAM na ploči Gigabyte AB350-Gaming 3 ne radi na 2800 Mhz, već ide do 2667 Mhz, dakle uzalud mi RAM frekvencije 2800 Mhz.
2) Predloženi Patriot Viper4, 2800Mhz moduli se ne nalaze na listi blagoslovljenih od strane Gigabyta.
3) Dodatno kopanje po netu me dovelo do ovih članaka:
https://knowledge.autodesk.com/suppo...h-AutoCAD.html
…..AutoCAD only supports multi-core technology in specific areas of the product, including:
2D regeneration
MentalRay rendering
To fully benefit from multi-core processors, you need to use multi-threaded software; AutoCAD is predominantly a single-threaded application.
Nadalje, aplikacije kojima se najviše koristim u svojoj specifikaciji imaju sljedeću rečenicu:
Hardware requirements
Workstation
The computer platform is a PC with an Intel Core i5 or i7 or compatible processor. Rather select a high-speed computer with less CPU cores than a slower computer with more CPU cores.
Nadalje sam pronašao čalanak o tome kako radi Solidworks:
https://www.pugetsystems.com/labs/ar...rformance-741/
Ispada da postoji mogućnost upotrebe više jezgara kod renderinja, ali kod proračuna se razlika između 4 I 6 jezgri slabo izražava.
Zbog svega prethodnog sam odlučio ipak razmotriti i Intel.
Također me pomalo sekiraju matične ploče s LED rasvjetom, kao i sve one koje u sebi sadrže riječ gejming. Na stanici proizvođača je obično pola stranice podređeno uputstvima u kojim svim bojama mogu svijetliti LED-ice, što je meni totalno beskorisno. Imam sentiment prema ASUS-u, a ove njegove fore o zaštiti od prenapona mi izgledaju korisno (u svakom slučaju bolje od LED-ica). Vidim Futura baš i nije frend s ASUSom, možda Uzi...
Mislim da također neću propasti ako se RAM vrti na 2400 Mhz, I isto tako netreba mi napajanje od 500 kn.
Na kraju se izrodilo ovo:
Mišljenje?
Staro 20.04.2017., 15:19   #3746
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Misljenje je da nisi dosao uopce slusati savjet od nas vec i dalje tepes po svojem...ma sve je odlicno! Kupi to pa da vise zavrsimo...
Staro 20.04.2017., 15:25   #3747
Smartic
Smartic's Avatar
Postovi: 2,707
Imam loše mišljenje o tvojim izborima
Biranje zaključanog, skupog i5 i skupe H270 ploče je zločin prema tvojim novcima, iskreno. Čak i ako je 10ak% brži u single-threadu(i to prije overclockanja Ryzena) u nekim scenarijima, R5 1600 jednostavno ima toliko više resursa na raspolaganju, npr. u renderingu će biti duplo brži.
2800MHz RAM ti može raditi i na 2933MHz s par klikova btw. Za napajanje, nikako šparati 40kn za 3 godine manje garancije i lošiju kvalitetu. Ono je modularna verzija koja dođe 475kn, stavljena tek tolko da nemaš gužvu u kućištu(ostavljaš samo kablove koji ti trebaju).
Staro 20.04.2017., 15:43   #3748
Postovi: 34,005
To što neka memorija nije navedena na proizvođačevom supportu, ne znači da neće raditi na nekoj ploči. Zamisli koliko bi vremena proizvođač izgubio da testira ama baš svaku memoriju koja postoji na svijetu. Kupiš memoriju koju ti hoćeš pa ako ne radi, lako se zamijeni za neku drugu.
Staro 20.04.2017., 16:11   #3749
big_B
big_B's Avatar
Postovi: 560
Autor FRipper Pregled postova
Hej, nemoj se ljutiti. Razmišljam i postavljam pitanja, jer o ovome svemu neznam mnogo.
Hoće li taj klik mišem dovesti do toga da se komp počne dodatno grijati?
Postoji li mogučnost da se uslijed tog klika pojavi BSOD?
Ukoliko je odgovor na bilo koje pitanje "da", tada to predstavlja problem za mene.
Prvi da znači da je potrebno ulagati dodatno u ventove i slične điđe miđe, te da će se uslijed povišene temperature sve uokolo početi kuhati.
Drug da znači problem. Nisam siguran kako se iz te situacije izvući. Komp na kojem radiš posao, koji se skrši u pola posla je iznimno opasan.
"Lako" ovisi o trgovcu i njegovom raspoloženju. Ukoliko je čovjek dobar, no frks, no postoji i ono drugo rješenje, natezanje u beskraj. Kad nekome daš 6500 kn i onda ovisiš o njegovom raspoloženju, to je baš jaaaaako loše. (čitajući iskustva iz ADM-a).
Dečki, sve je još na stolu. Razgovaramo. Sad mi je jasno da se ne slažete s odabirom.
Za sada imam konstruktivan komentar od Smartica. Neda se OC-ati. Ok drži vodu. Postavio sam dodatno pitanje, valjda ću dobiti odgovor.
Ryzen radi bolje kada ima mnogo paralelnog posla. I to je točno. Kopao sam po netu i pronašao informacije da današnji sw baš i nije multi-core friendly. Možda bi mogao razmišljati o budućnosti, kada će valjda biti.
Na kraju, tko onda kupuje Intelove procesore i ploče? Čemu to služi ako je samo skupo i ništa ne dobiješ?
Staro 20.04.2017., 16:45   #3750
Smartic
Smartic's Avatar
Postovi: 2,707
Kod Ryzena RAM radi u inkrementima od 266MHz, ploča će si prilagoditi takt, a onda ga još i ti možeš u BIOSu. RAM se baš i ne grije, zanemarivo. BSOD... ne vjerujem. Ovako bi otprilike to izgledalo:
https://youtu.be/RYMRYAFnnKk?t=11m32s
Po trenutnim cijenama od Intela ima smisla kupiti tek Pentium G4560 za budget konfu i i7 7700K za high-end gaming konfu gdje novci nisu problem. Ostali njihovi modeli imaju manje/više lošiji value od Ryzena.
