#3721 |
Datum registracije: Mar 2011
Postovi: 2,707
1 x Gigabyte AB350M-Gaming 3 Socket AM4 (AMD RYZEN™ processor), 4*DDR4 3200, USB3.1/USB 2.0, DVI-D, VGA, HDMI, M.2, SATA III, RAID, GLAN, mATX 1 x AMD CPU Desktop Ryzen 5 1600 (6C/12T, 3.4/3.6GHz Boost,19MB,65W,AM4) box, with Wraith Spire 95W cooler 1 x Corsair 2x8GB DDR4 2666 C16 LP 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance 1 x Toshiba SSD A100, R550/W480, 120GB,7mm,2.5" 1 x Zalman Z1, USB3.0 black, 2x120mm 1 x Fortron Hyper 500W, 80+ - 60mj. 1 x GIGABYTE GeForce GTX 1050 GDDR5 2GB/128bit Ukupno: 6.222kn s forumskim popustom(2%) Zadnje izmijenjeno od: coconut. 15.04.2017. u 19:48. |
#3722 |
Lokacija: /dev/random
Postovi: 42
Kolega mi predložio ovu konfu: Code:
Procesor AMD Ryzen 5 1600 BOX, s. AM4, 3.4GHz, 19MB cache, Six Core, Wraith Spire Cooler Matična ploča MSI B350 PC Mate, AMD B350, DDR4, zvuk, G-LAN, SATA, M.2, PCI-E 3.0, CrossFire, D-Sub, HDMI, USB 3.1-C, ATX, s. AM4 Memorija PC-21300, 8GB, KINGSTON HyperX Fury HX426C15FB/8 DDR4 2666Mhz SSD 256.0 GB INTEL Series 600p SSDPEKKW256G7X1, M.2, 80mm, PCIe NVMe 3.0 x4, 1570/540 MB/s Grafička kartica PCI-E GAINWARD GeForce GTX 1060, 3GB, DDR5, DVI, HDMI, DP Napajanje 600W, CHIEFTEC Smart Series GPE-600S, ATX v2.3, 120mm vent, PFC Kućište ANTEC NSK4100, MIDI, ATX, crno, USB 3.0, bez napajanja Ukupno: 6.902,48 kn (links.hr) |
#3723 |
Postovi: 14,584
Izbacio bi msi ploču i ubacio asus b350 prime plus, ili gaming 3 (bilo matx ili atx) od gigabytea Možeš uštediti još na SATA SSD-u, rx 470 4gb (ne referentnu sa blower coolerom). Napajanje recimo hyper 500w ili 600w (5 god. garancije, a jeftino i pristojno), no nemaš ga u linksu. Case zalman z3, z1 neo (dosta gratis ventova) |
#3724 |
Datum registracije: Apr 2011
Postovi: 1,429
Pozdrav društvo, Trebao bih komentare za kantu, frend mi uzima novo a namjena je office, multimedija i gaming (full HD rezolucija). S tim da za gaming nije siguran koliko će imati vremena ali volio bi da može vrtit nove naslove (kontam da bude 50-60 FPS-a). AMD CPU Desktop Ryzen 5 1600 (6C/12T, 3.4/3.6GHz Boost,19MB,65W,AM4) box, with Wraith Spire 95W cooler Gigabyte Main Board Desktop AB350M-Gaming 3 Kingston 8GB 2666MHz DDR4 CL15 DIMM HyperX FURY Black XFX AMD Radeon RX 480 RS GDDR5 4GB Intel® SSD 600p Series (256GB, M.2 80mm PCIe 3.0 x4, 3D1, TLC) HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance Napajanje Seasonic SS-520GB, 520W Fractal Define S, crno s prozorom, bez napajanja To je nekih 7,7 tisuća. Moglo bi jeftinije za cca 500 kn uz običan SSD i npr. Zalman z3+ kućište. Može li se tu složiti nešto bolje za te pare ili jeftinije a da ne gubi na performansama? Razmišljam i o intel + nvidia opciji, tamo je sigurno "plug and play" i može se jeftinije uz i5 i matičnu (ne bih volio neka iznenađenja s kompatibilnošću, BIOS-om, driverima itd., ako je to moguće u AMD slučaju). thx |
#3725 |
MiningMod
Postovi: 8,715
1 x AMD CPU Desktop Ryzen 5 1600 (6C/12T, 3.4/3.6GHz Boost,19MB,65W,AM4) box, with Wraith Spire 95W cooler 1 x Gigabyte AB350-Gaming 3, Socket AM4 (AMD RYZEN™ ), 4*DDR4 3200, RAID, LAN, ATX 1 x Kingston 8GB 2666MHz DDR4 CL15 DIMM HyperX FURY Black, EAN: 740617244397 1 x XFX AMD Radeon RX 480 RS GDDR5 4GB/256bit, HDMI, DVI, 3xDP, DD 2X, Backplate, Retail 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance 1 x SSD Patriot Hellfire R3000/W2200, 240GB, M.2 NVMe 1 x Kućište DeepCool Dukase V2, USB3.0, plexy, black 1 x Fortron Hyper 600W, 80+ - 60mj. Ukupno: 7836,40 kn -2% = cca 7650kn *Iako za takav gaming je dosta RX470/570 |
#3726 |
Postovi: 1,429
Uzeo bih 470 grafu ali zanemariva je razlika u cijeni jer ta 480 je 1,8 tisuća, a ne nađem značajno jeftiniju 470. Izgleda dosta slično mojoj kanti a i cijena je skoro ista. Tih 2% jel to kod uzija? Zadnje izmijenjeno od: coconut. 18.04.2017. u 06:49. |
#3727 |
Postovi: 560
Bok, tražim novu kantu (nije potrebno da lijepo izgleda) kojoj je primarni zadatak poslovna namjena (2D autocad, i kojekakvi programi za poračune). Proračun mi iznosi cca 6300 kn s PDV-om (trebam R1 račun). U početku sam mislio da neću preživjeti bez i7 procesora, no nakon nešto istraživanja sam shvatio (moguće krivo?) da vjerojatno može koristiti i jača verzija i5 (7500?). OC i pojačano hlađenje me ne zanima. O AMD-ovim procesorima ne znam mnogo. Ostali uvjeti bi bili min 8 Gb RAM-a (za sada, jasno je da će ovo uskoro postati premalo) i 120-240 Gb SSD + HDD (moguće 1 Tb). Moguće da me uhvati kakvo igranje, pa bi bio sretan kada bi u konfiguraciju upala grafička kartica, tako da integrirana ne krade sistemski RAM. Kratica bi trebala izdignuti performanse kante iz područja integriranih kartica u područje „ide igranje, ali ne na nekim visokim rezolucijama/bijesnim detaljima/visokim FPS-ovima“. Svojedobno sam negdje pročitao da je i slabija kratica mnogo bolja od bilo koje integrirane (jesam li u krivu?). Sve je na kraju potrebno zalijepiti na primjerenu ploču i napajanje. Kopanje po trgovinama je došlo do približnih rezultata tipa (potrebne manje izmjene): https://www.centro.hr/extro-havocpro...freedos-1.aspx https://www.instar-informatika.hr/ra...99901/product/ https://www.futura-it.hr/katalog/got...la/futura-037/ Imate li kakvo mišljenje/prijedlog?
#3728 |
Postovi: 33,982
Gotove kante u pravilu treba izbjegavati. Dečki će ti uvijek složiti nešto bolje za tu lovu. btw, vidim da govoriš o R1. Da li to znači da ti trebaju i Winsi (firma mora imati legalno kupljene winse)?
#3729 |
Postovi: 560
Nije mi potreban operacijski sustav.
#3730 |
Postovi: 2,707
AMD Ryzen R5 1600 Asus Prime B350M-A 2x DDR4 8GB (1x8) PC4-19200 2400MHz CL15 G.Skill, F4-2400C15S-8GNT Grafička kartica MSI RX460 2G OC, 2GB GDDR5, 1210/1750MHz Napajanje 500W FSP Fortron/Source Hyper M Toshiba P300 1TB HDD SSD 128GB Samsung PM961, M.2 2280 PCIe Kućište Zalman Z1 ~6000kn |
#3731 |
Postovi: 430
1 x AMD CPU Desktop Ryzen 5 1600 (6C/12T, 3.4/3.6GHz Boost,19MB,65W,AM4) box, with Wraith Spire 95W cooler 1 x Patriot Viper4, 2800Mhz, 16GB (2x8GB), CL16 1 x Asrock Fatal1ty AB350 Gaming K4, Ryzen, S.AM4 1 x GIGABYTE GeForce GTX 1050 OC GDDR5 2GB/128bit, WINDFORCE 2X 1 x Toshiba SSD A100, R550/W480, 120GB,7mm,2.5" 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance 1 x Zalman Z1, USB3.0 black, 2x120mm 1 x GIGABYTE Pulse 450W, Modular, 80+ Bronze Ukupno: 6552,00 kn -2% popusta = 6420kn. Slaganje i dostava u cijeni. |
#3732 |
Postovi: 560
U redu, vidim Intel nije u konkurenciji. Bi li mogli ugurati SSD od 240 Gb umjesto 120 Gb, te kolika bi bila razlika u cijeni (možda neku komponentu pojeftiniti)? Samsung PM961 je neki divlji SSD s čitanjem od 3 Gb/s? Koliko mi u životu znači razlika u fekvenciji RAM-a 2400 i 2800 Mhz? O kojoj trgovini je riječ? Probao sam složiti ovu konfiguraciju u ADM-u, i ispalo je 7000 kn ![]() Također isto pitanje, o kojoj trgovini se radi.
#3733 | |
![]() Gotove kante se ne kupuju od trgovačkih centara tipa Konzum, Elipso, ex Tehnomarket i slično. Sent from my SM-G930F using Tapatalk |
#3734 |
Postovi: 2,707
#3735 |
MiningMod
Postovi: 8,715
big_B Ovako mislim da je najbolje ako hoćeš veći SSD, jer realno, da malo je 120GB. 1 x AMD CPU Desktop Ryzen 5 1600 (6C/12T, 3.4/3.6GHz Boost,19MB,65W,AM4) box 1 x Gigabyte AB350-Gaming, Socket AM4 (AMD RYZEN™) 1 x Patriot Viper4, 2800Mhz, 16GB (2x8GB), CL16 1 x XFX AMD Radeon RX 460 GDDR5 2GB/128bit 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance 1 x Kingston UV400 240GB SSD, 2.5” 7mm, SATA 6 Gbit/s 1 x Zalman Z1, USB3.0 black, 2x120mm 1 x Fortron Hyper 500W, 80+ - 60mj. Ukupno: 6567,00 kn -2% = cca 6440 kn Trgovina je ona treča... a i u ostalom treba baciti malo oko na iskustva Ryzen bolje radi sa bržom memorijom, te svakako gledaj minimalno 2800MHz. |
#3737 |
Postovi: 560
Može li netko iz prve ruke reći koliko SSD-ovi koji su uštekani u MBO s deklariranim brzinama od 3 Gb/s rade bolje/brže od ovih koji su na žici. Isplati li se u to ulagati. Kad imaš takav disk na sistemskoj particiji, jel' te onda počne sekirati čekanje dok se ne otvori nešto što se nalazi na rotirajućoj šajbi?
#3739 |
Postovi: 560
...zaključio sam da mi ipak ne treba 3 Gb/s, ukoliko imam dosta RAM-a, u koji će sve biti učitano. Nadalje bih radije kupio EVO 850 250 Gb od Samsunga (s njim imam iskustva). Kako ste rekli da procesor može iskoristiti brži takt RAM-a, malo sam modificirao ponudu od ADM-a (Corsair RAM na kojem piše 2400-3000 Mhz, što je valjda usporedivo s 2800 Mhz): ![]() Čini mi se da je ADM ovdje ispao za dlaku bolji. Treba mi samo još potvrda da odabrani Corsair-ov RAM može raditi s ovom pločom. Proračun je probijen za 500 kn. Mogu eventualno kupiti jeftinije napajanje kod ADM-a (-100 kn) i to bi bilo to. ASUSov Prime B350M-A nije baš najbolje prošao kod publike (čitajući komentare, te sam ploču ostavio od Asrock-a) Što kažete?
#3740 |
MiningMod
Postovi: 8,715
Ok adm je jeftiniji 100kn doslovce (kada u futuri dodaš bolje hyper 500), a jesi čitao iskustva? Eto to kažem ![]() Moj savjet je da gledaš Futuru i UZI, ipak su kolege tu sa foruma i sve će ti riješiti ako bude problema... Jer realno ako ti to nije važno, možeš kupiti i u njemačkoj ![]() Edit sada vidim, u futuri si stavio skuplji 1600 a imaš jeftiniji za 100kn... tako da opet nije baš adm jeftiniji ![]() Zadnje izmijenjeno od: FRipper. 20.04.2017. u 08:50. |
#3741 |
Postovi: 430
Kolega, matematika vam nije jača strana? ADM je skuplji 12kn, ali ima bržu memoriju i hyper 500. Makar Big_b je odabrao krivi procesor, imaju ih više na webu, kad uzmeš ovaj onda je futura jeftinija 130kn. |
#3742 |
Postovi: 16,838
Od ove dvije meni se ADM čini bolja solucija, napajanje ne daleko bolje. Ali kako kaže kolega, javiti se Uzi-u i riješiti će se sve. |
#3744 |
MiningMod
Postovi: 8,715
Pa bolja je solucija samo zato jer je uzeo krivi procesor...ak uzme jeftiniji a isti dobiti će isti komp u Futuri za manje love + da ne pričam duplo bolju uslugu. Čak može i bolju Gigabyte ploču ubaciti. 1 x AMD CPU Desktop Ryzen 5 1600 (6C/12T, 3.4/3.6GHz Boost,19MB,65W,AM4) box, with Wraith Spire 95W cooler 1 x Gigabyte AB350-Gaming 3, Socket AM4 (AMD RYZEN™ ), 4*DDR4 3200, RAID, LAN, ATX 1 x Patriot Viper4, 2800Mhz, 16GB (2x8GB), CL16 1 x XFX AMD Radeon RX 460 GDDR5 2GB/128bit 1 x Samsung 850 EVO 250GB SATA 2.5" 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance 1 x Zalman Z1, USB3.0 black, 2x120mm 1 x Fortron Hyper 500W, 80+ - 60mj. Ukupno: 6807,00 kn -2% = cca 6675kn *S Asrock pločom ispada oko 40kn manje Zadnje izmijenjeno od: FRipper. 20.04.2017. u 09:54. |
#3745 | ||
Postovi: 560
Nakon još malo istraživanja sam shvatio sljedeće: 1) RAM na ploči Gigabyte AB350-Gaming 3 ne radi na 2800 Mhz, već ide do 2667 Mhz, dakle uzalud mi RAM frekvencije 2800 Mhz. 2) Predloženi Patriot Viper4, 2800Mhz moduli se ne nalaze na listi blagoslovljenih od strane Gigabyta. 3) Dodatno kopanje po netu me dovelo do ovih članaka: https://knowledge.autodesk.com/suppo...h-AutoCAD.html Citiraj:
https://www.pugetsystems.com/labs/ar...rformance-741/ Ispada da postoji mogućnost upotrebe više jezgara kod renderinja, ali kod proračuna se razlika između 4 I 6 jezgri slabo izražava. Zbog svega prethodnog sam odlučio ipak razmotriti i Intel. Također me pomalo sekiraju matične ploče s LED rasvjetom, kao i sve one koje u sebi sadrže riječ gejming. Na stanici proizvođača je obično pola stranice podređeno uputstvima u kojim svim bojama mogu svijetliti LED-ice, što je meni totalno beskorisno. Imam sentiment prema ASUS-u, a ove njegove fore o zaštiti od prenapona mi izgledaju korisno (u svakom slučaju bolje od LED-ica). Vidim Futura baš i nije frend s ASUSom, možda Uzi... Mislim da također neću propasti ako se RAM vrti na 2400 Mhz, I isto tako netreba mi napajanje od 500 kn. Na kraju se izrodilo ovo: ![]() Mišljenje?
#3747 |
Postovi: 2,707
Imam loše mišljenje o tvojim izborima ![]() Biranje zaključanog, skupog i5 i skupe H270 ploče je zločin prema tvojim novcima, iskreno. Čak i ako je 10ak% brži u single-threadu(i to prije overclockanja Ryzena) u nekim scenarijima, R5 1600 jednostavno ima toliko više resursa na raspolaganju, npr. u renderingu će biti duplo brži. 2800MHz RAM ti može raditi i na 2933MHz s par klikova btw. Za napajanje, nikako šparati 40kn za 3 godine manje garancije i lošiju kvalitetu. Ono je modularna verzija koja dođe 475kn, stavljena tek tolko da nemaš gužvu u kućištu(ostavljaš samo kablove koji ti trebaju). |
#3748 |
Postovi: 33,982
To što neka memorija nije navedena na proizvođačevom supportu, ne znači da neće raditi na nekoj ploči. Zamisli koliko bi vremena proizvođač izgubio da testira ama baš svaku memoriju koja postoji na svijetu. Kupiš memoriju koju ti hoćeš pa ako ne radi, lako se zamijeni za neku drugu.
#3749 | |||
Postovi: 560
Postoji li mogučnost da se uslijed tog klika pojavi BSOD? Ukoliko je odgovor na bilo koje pitanje "da", tada to predstavlja problem za mene. Prvi da znači da je potrebno ulagati dodatno u ventove i slične điđe miđe, te da će se uslijed povišene temperature sve uokolo početi kuhati. Drug da znači problem. Nisam siguran kako se iz te situacije izvući. Komp na kojem radiš posao, koji se skrši u pola posla je iznimno opasan. Citiraj:
Dečki, sve je još na stolu. Razgovaramo. Sad mi je jasno da se ne slažete s odabirom. Za sada imam konstruktivan komentar od Smartica. Neda se OC-ati. Ok drži vodu. Postavio sam dodatno pitanje, valjda ću dobiti odgovor. Ryzen radi bolje kada ima mnogo paralelnog posla. I to je točno. Kopao sam po netu i pronašao informacije da današnji sw baš i nije multi-core friendly. Možda bi mogao razmišljati o budućnosti, kada će valjda biti. Na kraju, tko onda kupuje Intelove procesore i ploče? Čemu to služi ako je samo skupo i ništa ne dobiješ?
#3750 |
Postovi: 2,707
Kod Ryzena RAM radi u inkrementima od 266MHz, ploča će si prilagoditi takt, a onda ga još i ti možeš u BIOSu. RAM se baš i ne grije, zanemarivo. BSOD... ne vjerujem. Ovako bi otprilike to izgledalo: https://youtu.be/RYMRYAFnnKk?t=11m32s Po trenutnim cijenama od Intela ima smisla kupiti tek Pentium G4560 za budget konfu i i7 7700K za high-end gaming konfu gdje novci nisu problem. Ostali njihovi modeli imaju manje/više lošiji value od Ryzena. |
