Staro 01.03.2017., 11:29   #1
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Windows i Linux majneri
ZEC (ZCash)
Claymore's ZCash AMD GPU Miner v12.3 (Windows/Linux)
Download:
GOOGLE: https://drive.google.com/drive/folde...EE?usp=sharing
MEGA: https://mega.nz/#F!P0ZjFDjC!Cmb-ZRqlbAnNrajRtp4zvA
ETH (Ethereum)
Claymore's Dual Ethereum+Decred AMD+NVIDIA GPU Miner.
Download:
GOOGLE: https://drive.google.com/open?id=0B6...FZUV2toUG5HdlU
MEGA: https://mega.nz/#F!O4YA2JgD!n2b4iSHQDruEsYUvTQP5_w
Zadnje izmijenjeno od: FRipper. 08.03.2017. u 21:56.
Staro 01.03.2017., 11:29   #2
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
REZERVIRANO
Staro 01.03.2017., 11:33   #3
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
REZERVIRANO
Staro 04.03.2017., 22:37   #4
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Izašao novi EWBF's CUDA Zcash miner 0.3.1b
https://mega.nz/#F!usQh2bTa!3qp_PaiO-dw3F0mpvLXynA
Na GTX1060 daje samo oko 10-15 više.
Staro 08.03.2017., 21:56   #5
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Claymore's ZCash AMD GPU Miner.
Latest version v12.3:
- slightly improved speed, about 410H/s on stock 390X, 465H/s on stock Nano, 300H/s on stock 280X, 305H/s on stock RX480.
- improved stability for high "-i" option values, added "-i 9" option value.
- fixed a few bugs.
Staro 10.03.2017., 12:31   #6
Shamanix
Shamanix's Avatar
Postovi: 870
Eto izasao i novi EWBF 0.3.2b
sad 1070 radi 470-482 H/s
Shamanix je offline   Reply With Quote
Staro 15.03.2017., 00:26   #7
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,309
Latest version v8.1:
- added Ethereum+Pascal mode for NVidia cards.
- improved "-di detect" option: now after GPU order detection miner starts mining with the detected order.
- now remote management is working in read-only mode by default.
- improved "-mport" option, now you can specify network adapter IP for incoming connections for remote management.
- added "-benchmark" option.
- fixed issue with "-retrydelay" option.
- added "-v" option.
- a few minor bug fixes and improvements.
- EthMan: added option for font color selection.
LINKS:
C/P
Chuby je offline   Reply With Quote
Staro 22.03.2017., 14:14   #8
Shamanix
Shamanix's Avatar
Postovi: 870
Izasao novi EWBF_ 0.3.3b
Od sad mozete namjestit fee koji hocete, pa tako i iskljucit ga, znaci miner je od sad bez fee-a
Staro 22.03.2017., 14:27   #9
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,712
Autor Shamanix Pregled postova
Fenomenalno.
Jel to EWBF zaradio milion pa reko dosta je ili je neki drugi razlog?
EDIT:
reko bi da je ovo razlog
https://bitcointalk.org/index.php?topic=1777827.0
We are presenting excavator - multi-algorithm advanced CUDA miner. Miner is close-sourced, but open to ANY pool and does NOT contain any fees. excavator is brought to you by NiceHash.
Zadnje izmijenjeno od: kopija. 22.03.2017. u 20:16.
Staro 08.04.2017., 13:24   #10
Chuby
Chuby's Avatar
Postovi: 1,309
Claymore's Dual Ethereum + Decred/Siacoin/Lbry/Pascal AMD+NVIDIA GPU Miner.
Latest version is v9.0:
- added "-asm" option (AMD cards only) which enables assembler GPU kernels. In this mode some tuning is required even in ETH-only mode, use "-dcri" option or or "+/-" keys in runtime to set best speed.
Currently only ETH-only and ETH-DCR modes are supported in assembler. Use "-asm 0" if you don't want to use new assembler kernels.
If ASM mode is enabled, miner must show "GPU #x: algorithm ASM" at startup.
- improved ETH mining speed in ASM mode for some cards, also a bit reduced power usage for some cards (fine-tuning is required via "-dcri" or "+/-" keys in runtime).
NOTE 1: if GPU throttles, best "-dcri" value is different.
NOTE 2: speed peak can be rather short, so change "-dcri" value slowly.
- dramatically increased DCR mining speed in assembler mode (up to 70%). Be careful, power usage is higher too.
- added "-gmap" option.
- fixed DCR Nicehash support.
- added "FINE-TUNING" section to Readme file.
- A lot of minor improvements and bug fixes.
LINKS:
GOOGLE: https://drive.google.com/open?id=0B6...FZUV2toUG5HdlU NOTE: It seems Google blocks some files, use MEGA if you cannot find latest version.
Staro 15.04.2017., 23:27   #11
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Latest version is v9.1:
- added assembler kernels for ETH+SIA and ETH+PASCAL modes (major speedup for SIA and PASCAL).
- added alternative assembler kernels for Tonga and Polaris cards for ETH-only mode. Use them if you get best speed at "-dcri 1" (i.e. you cannot find speed peak), use "-asm 2" option to enable this mode.
LINKS:
