MiningMod
Postovi: 8,715
Windows i Linux majneri
ZEC (ZCash) Claymore's ZCash AMD GPU Miner v12.3 (Windows/Linux) Download: GOOGLE: https://drive.google.com/drive/folde...EE?usp=sharing MEGA: https://mega.nz/#F!P0ZjFDjC!Cmb-ZRqlbAnNrajRtp4zvA ETH (Ethereum) Claymore's Dual Ethereum+Decred AMD+NVIDIA GPU Miner. Download: GOOGLE: https://drive.google.com/open?id=0B6...FZUV2toUG5HdlU MEGA: https://mega.nz/#F!O4YA2JgD!n2b4iSHQDruEsYUvTQP5_w Zadnje izmijenjeno od: FRipper. 08.03.2017. u 20:56. |
MiningMod
Postovi: 8,715
REZERVIRANO |
MiningMod
Postovi: 8,715
Izašao novi EWBF's CUDA Zcash miner 0.3.1b https://mega.nz/#F!usQh2bTa!3qp_PaiO-dw3F0mpvLXynA Na GTX1060 daje samo oko 10-15 više. |
MiningMod
Postovi: 8,715
Claymore's ZCash AMD GPU Miner. ========================= Latest version v12.3: - slightly improved speed, about 410H/s on stock 390X, 465H/s on stock Nano, 300H/s on stock 280X, 305H/s on stock RX480. - improved stability for high "-i" option values, added "-i 9" option value. - fixed a few bugs. MEGA: https://mega.nz/#F!P0ZjFDjC!Cmb-ZRqlbAnNrajRtp4zvA |
Datum registracije: Feb 2004
Postovi: 1,303
Claymore's Dual Ethereum+Decred AMD+NVIDIA GPU Miner. ========================= Latest version v8.1: - added Ethereum+Pascal mode for NVidia cards. - improved "-di detect" option: now after GPU order detection miner starts mining with the detected order. - now remote management is working in read-only mode by default. - improved "-mport" option, now you can specify network adapter IP for incoming connections for remote management. - added "-benchmark" option. - fixed issue with "-retrydelay" option. - added "-v" option. - a few minor bug fixes and improvements. - EthMan: added option for font color selection. LINKS: GOOGLE: https://drive.google.com/open?id=0B6...FZUV2toUG5HdlU MEGA: https://mega.nz/#F!O4YA2JgD!n2b4iSHQDruEsYUvTQP5_w C/P |
#9 | ||
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,543
Jel to EWBF zaradio milion pa reko dosta je ili je neki drugi razlog? EDIT: reko bi da je ovo razlog https://bitcointalk.org/index.php?topic=1777827.0 Citiraj:
Zadnje izmijenjeno od: kopija. 22.03.2017. u 19:16. |
Postovi: 1,303
Claymore's Dual Ethereum + Decred/Siacoin/Lbry/Pascal AMD+NVIDIA GPU Miner. ========================= Latest version is v9.0: - added "-asm" option (AMD cards only) which enables assembler GPU kernels. In this mode some tuning is required even in ETH-only mode, use "-dcri" option or or "+/-" keys in runtime to set best speed. Currently only ETH-only and ETH-DCR modes are supported in assembler. Use "-asm 0" if you don't want to use new assembler kernels. If ASM mode is enabled, miner must show "GPU #x: algorithm ASM" at startup. - improved ETH mining speed in ASM mode for some cards, also a bit reduced power usage for some cards (fine-tuning is required via "-dcri" or "+/-" keys in runtime). NOTE 1: if GPU throttles, best "-dcri" value is different. NOTE 2: speed peak can be rather short, so change "-dcri" value slowly. - dramatically increased DCR mining speed in assembler mode (up to 70%). Be careful, power usage is higher too. - added "-gmap" option. - fixed DCR Nicehash support. - added "FINE-TUNING" section to Readme file. - A lot of minor improvements and bug fixes. LINKS: GOOGLE: https://drive.google.com/open?id=0B6...FZUV2toUG5HdlU NOTE: It seems Google blocks some files, use MEGA if you cannot find latest version. MEGA: https://mega.nz/#F!O4YA2JgD!n2b4iSHQDruEsYUvTQP5_w |
MiningMod
Postovi: 8,715
Claymore's Dual Ethereum + Decred/Siacoin/Lbry/Pascal AMD+NVIDIA GPU Miner. ========================= Latest version is v9.1: - added assembler kernels for ETH+SIA and ETH+PASCAL modes (major speedup for SIA and PASCAL). - added alternative assembler kernels for Tonga and Polaris cards for ETH-only mode. Use them if you get best speed at "-dcri 1" (i.e. you cannot find speed peak), use "-asm 2" option to enable this mode. - a few minor bug fixes and improvements. LINKS: GOOGLE: https://drive.google.com/open?id=0B6...FZUV2toUG5HdlU NOTE: It seems Google blocks some files, use MEGA if you cannot find latest version. MEGA: https://mega.nz/#F!O4YA2JgD!n2b4iSHQDruEsYUvTQP5_w |
