MiningMod
Postovi: 8,715
HashRate (h/s) - GPU Mining
Gigabyte R9 380x 4GB G1 Gaming, Hynix (By FRipper) All stock ETH: 20 MH/s (Claymore v8.0) ETH+Pasc: 18.5 MH/s + 275 MH/s (Claymore v8.0) ZEC: 190 H/s (Claymore's ZCash AMD GPU Miner v12.2 Beta) XMR: 545 H/s (Claymore's CryptoNight GPU Miner v9.7) ------------------------------------------- MSI Armor RX 470 4GB, Samsung (By maXonja) String (polaris editor): 1750MHz na 1900MHz i 2000MHz OC (Wattman): Memory 2150MHz ETH: 29 mh/s (Claymore V7.3) ETH+Pasc: 21 mh/s eth + 330 mh/s pasc (Claymore V8.0) ZEC: 285 h/s ------------------------------------------- MSI RX470 Gaming X 4G, Hynix (By Shamanix) String (polaris editor): 1500MHz na 1625MHz, 1750MHz i 2000MHz GPU: 1300MHz Mem: 1900MHz ETH: 27.2 MH/s (Claymore v8.0) ETH+Pasc: 25MH/s + 385MH/s (Claymore v8.0) ZEC: 295 H/s (Claymore's ZCash AMD GPU Miner v12.2 Beta) XMR: 719 H/s (Claymore's CryptoNight GPU Miner v9.7) ------------------------------------------- Gigabyte RX480 Gaming G1 4GB, Hynix (By maXonja) String (polaris editor): 1500MHz na 1625MHz, 1750MHz i 2000MHz OC (Wattman): Memory 2050MHz ETH: 29 Mh/s (Claymore V7.3) ETH+Pasc: 24.5 Mh/s eth + 360-380 Mh/s pasc (Claymore V8.0) ZEC: 315-320 H/s ------------------------------------------- Sapphire Fury Nano, Hynix (By FRipper) All stock ETH: 26.5 mh/s (Claymore V8.0) ETH+Pasc: 23.5 mh/s eth + 350 mh/s pasc (Claymore V8.0) ZEC: 420 mh/s (Claymore V12.2 Linux) XMR: 760 h/s (Claymore V9.7) ------------------------------------------- MSI GamingX GTX 1060 6GB, Samsung (By FRipper) All stock ETH: 20 mh/s (Claymore V8.0) ZEC: 290 mh/s (EWBF's CUDA Zcash miner 0.3.0b) ZEC: 275 h/s (NiceHash 1.7.5.0) ZCoin XZC: 840 kh/s (ccminer by Tourgasm) ------------------------------------------- MSI GTX 1050 2GB, Hynix (By FRipper) All stock ZEC: 150 mh/s (EWBF's CUDA Zcash miner 0.3.2b) ZCoin XZC: 390 kh/s (ccminer by Tourgasm) ------------------------------------------- Gigabyte GTX 1050Ti 4GB, Samsung (By FRipper) All stock ZEC: 170 mh/s (EWBF's CUDA Zcash miner 0.3.2b) ZCoin XZC: 460 kh/s (ccminer by Tourgasm) ------------------------------------------- Asus Strix GTX 970 4GB, Hynix (By maXonja) ZEC: 248 mh/s (NiceHash) XMR: 400 h/s (NiceHash) ------------------------------------------- Gigabyte GTX 1070 G1 Gaming, Samsung (By Shamanix) GPU: 2000MHz Mem: 4500MHz ETH: 29-30 MH/s (Claymore v8.0) ZEC: 460-470 H/s (EWBF's CUDA Zcash miner 0.3.1b) 470-480 H/s (EWBF's CUDA Zcash miner 0.3.2b) XMR: 680 H/s (ccminer-cryptonight by KlausT) Zadnje izmijenjeno od: FRipper. 11.03.2017. u 15:55. |
bu
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,605
MSI Armor RX 470 4GB, Samsung String (polaris editor): 1750MHz na 1900MHz i 2000MHz OC (Wattman): Memory 2150MHz ETH: 29.5 Mh/s (Claymore V7.3) ETH+Pasc: 21 Mh/s eth + 330 Mh/s pasc (Claymore V8.0) ZEC: 285 H/s XMR: ? ------------------------------------------- Gigabyte RX480 Gaming G1 4GB, Hynix String (polaris editor): 1500MHz na 1625MHz, 1750MHz i 2000MHz OC (Wattman): Memory 2050MHz ETH: 29 Mh/s (Claymore V7.3) ETH+Pasc: 24.5 Mh/s eth + 360-380 Mh/s pasc (Claymore V8.0) ZEC: 315-320 H/s XMR: ? Evo FRipper da možeš napraviti update ![]() Ako mi se bude dalo možda danas izvrtim sa GTX970 pa da imamo i taj rez, ona mi je van pogona i u petak bi trebala ići novome vlasniku ![]()
Nvidia u očima Intel u duši Alfa Romeo u srcu Zadnje izmijenjeno od: maXonja. 02.03.2017. u 13:51. |
Postovi: 870
Gigabyte GTX 1070 G1 Gaming, Samsung GPU: 2000MHz Mem: 4500MHz ETH: 29-30 MH/s (Claymore v8.0) ETH+Pasc: ? ZEC: 460-470 H/s (EWBF's CUDA Zcash miner 0.3.1b) XMR: 680 H/s (ccminer-cryptonight by KlausT) MSI RX470 Gaming X 4G, Hynix String (polaris editor): 1500MHz na 1625MHz, 1750MHz i 2000MHz GPU: 1300MHz Mem: 1900MHz ETH: 27.2 MH/s (Claymore v8.0) ETH+Pasc: 25MH/s + 385MH/s (Claymore v8.0) ZEC: 295 H/s (Claymore's ZCash AMD GPU Miner v12.2 Beta) XMR: 719 H/s (Claymore's CryptoNight GPU Miner v9.7) Zadnje izmijenjeno od: Shamanix. 03.03.2017. u 06:09. |
koliko mogu na zcashu ocekivat od 1050TI? |
Lokacija: zadar
Postovi: 192
jel prati netko ovaj thread? https://bitcointalk.org/index.php?topic=1758267.0 poprilično zanimljivi rezultati, radi se o custom memory timinzima, iliti ga strapovima, za GPU. RAS, CAS itd, za AMD seriju kartica. MAlo je kompleksno jer ljudi koji znaju ne žele direktno podijeliti to znanje, ali može se naći strapova za određeni tip memorije koji daju 5-10% bolje rezltate. npr, moja rx 470 4GB hynix sada radi 28.5 ETH, 840 XMR... |
bu
Lokacija: VŽ
Postovi: 2,605
A misliš da moje RX470 po defaultu daju oko 29.5MH/s eth-a? ![]()
Postovi: 870
Kod mene je samo jedna samsung, sve ostale hynix..Morao sam jos malo popustit taktove inace pucaju grafe ili javljaju incorrect share.. Testiram jos al kontam ovo bi trebalo radit sad.. Samsung (GPU3) 1850, hynix 1950-2050 ![]() |
Datum registracije: Oct 2012
Postovi: 292
Da i ja dam svoj obol: MSI R9 390 8GB, Hynix stack bios OC (afterburner): clock 1300, power +50, core volt +38 ETH: ~32 Mh/s (Claymore Dual V8.1) ETH+Pasc: ? ZEC: ~304 H/s (Claymore V12.3) XMR: ? ------------------------------------------- SAPPHIRE R9 390 8GB, Hynix stack bios OC (afterburner): clock 1100, power +50, core volt +56 ETH: ~31 Mh/s (Claymore Dual V8.1) ETH+Pasc: ? ZEC: ~300 H/s (Claymore V12.3) XMR: ? ------------------------------------------- MSI R9 390X 8GB, Hynix stack bios OC (afterburner): clock 1130, power +50, core volt +0 ETH: ~32 Mh/s (Claymore Dual V8.1) ETH+Pasc: ? ZEC: ~315 H/s (Claymore V12.3) XMR: ? Zadnje izmijenjeno od: orbital_station. 18.03.2017. u 09:57. |
#16 |
bu
Lokacija: VŽ
Postovi: 2,605
XFX RX 470 RS 4GB (single fan), Samsung String (polaris editor): 1750MHz na 1900MHz i 2000MHz OC (Afterburner): Memory 2100MHz ETH: 29.5 Mh/s (Claymore V8.0) ETH+Pasc: 21 Mh/s eth + 330 Mh/s pasc (Claymore V8.0) ZEC: 290 H/s XMR: ?
Nvidia u očima Intel u duši Alfa Romeo u srcu Zadnje izmijenjeno od: maXonja. 20.03.2017. u 09:37. |
#18 |
bu
Lokacija: VŽ
Postovi: 2,605
Pa wattman ti dolazi sa driverima, nemas sto posebno skidati... Imas ga u AMD settingsima Ali prebacio se i ja na afrerburner, jednostavniji i brzi je, zaboravio sam promijeniti + mogu se lijepo sloziti temperature svih grafa u taskbar
#19 |
evo jedna asusica 280x i msi rx470. asus undervoltan, to solidno pici ![]() 280x: 1125/1800, 1100mv (mozda moze i nize) rx470: modan bios, mem ide samo do 2100 ![]() Sent from my MI MAX using Tapatalk |
#22 | |
bu
Lokacija: VŽ
Postovi: 2,605
RX470 je MSI i vjerojatno je Samsung gore Ja svoje MSI RX470 bez problema držim na 2125MHz dok u jednom rigu imam Asusice RX470 sa Hynixom i neidu iznad 1925MHz
#23 |
Axl Rose
Postovi: 395
Aha.. j sam mislio da je 470 asus.. meni su asusice tri hynix memorija i max na 1900 rade.. i jednu nsaphire nitro koja sama ide na 2100 i 29.5 i sa ove tri na oko 2000 i 28.3.. Sent from my iPhone using Tapatalk |
#24 |
#25 |
bu
Lokacija: VŽ
Postovi: 2,605
#26 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,712
Evo ja se razulario s svojom Gigabyte 970 G1. EWBF izgruntao 300 sol/s na 1500/7000 pri 160W prema Nevidija Inspektoru. 1060 3G na Linux mašini nikako iznad 290 Sol/s pri 100W 1950/4500. |
#27 |
Lokacija: zadar
Postovi: 192
![]() Evo i mojih noob iskustva/rezultata. GPU0 je MSI armor sa 4GB samsung K4G4, GPU1 je XFX RS xxx 4GB hynix h5gc4h24ajr GPU0 samsung - 1200 core, 2100 memorija GPU1 hynix - 1200 core, 2025 memorija Sa samsungom je bilo jednostavno, samo kopirati strap i eto 29 MHs, ali hynix me izmučio, a i ja karticu, eksperimentirao sam sa raznim strapovima i timinzima i flashao sam je sigurno 50 puta da bi dobio 28.8, i tek sa claymorom 9 preko 29. Zasad radi stabilno već duže od 24h. Ukratko, tko ima hynix h5gc4h24ajr, neka kopira donji strap na 1750 i 2000, i stavi -dcri 5 opciju u claymore-u 9, i javi rezultate. 999000000000000022559D0010DE5B4480551312B74C450A00400600750414206A8900A00200312010112D34A42A3816 Tek sa ovim strapom sam uspio natjerati hynix preko 1975Mhz. |
#30 |
Lokacija: zadar
Postovi: 192
U ovom threadu 10-ak poruka iznad sam stavio link na raspravu o custom strapovima na bitcointalku https://bitcointalk.org/index.php?topic=1758267.0 napravio sam i svoju primitivnu skriptu za dekodiranje strapova, u međuvremenu su drugi objavili public verzije svojih dekodera/encodera, sve je na linku iznad. ovaj strap iznad, više se ne sjećam jesam li ga iskopao tamo na forumu ili sam ga sam skemijao, uglavnom to je malo modificiran 1500 strap |
