#451 |
Freelancer
Lokacija: Bilje (Osijek)
Postovi: 5,299
Imam "zanimljiv" problem. Kad mi radi uttorent dobar dio WEB stranica se uopce neotvara ili otvara super sporo ? Recimo neraid mi ni https://moj.vip.hr/ a PCekspert se otvori nakon jedno minutu (valjda ce ovo sad postati/proci). Ima neko ideju sto bi to moglo biti ?
#453 |
Freelancer
Postovi: 5,299
Ma jok nije do toga, upload je ogranicen (i donwload) i slanje mailova i primanje radi bez problema. Jednostanvo kao da nema stranica , server not responded i slicno. Isto to preko Tcom routera radi bez problema.
#455 |
Datum registracije: Jan 2017
Postovi: 273
Aplikacija "Network Cell Info Lite" može pronaći odašiljač s kojeg mobitel prima signal, naravno mora biti Vip ili Tomato kartica u njemu da bi znali onda približno s kojega i Homebox hvata signal. |
#456 |
Freelancer
Postovi: 5,299
#457 |
Lokacija: Čazma
Postovi: 1,728
Moj ruter je na putu a i u međuvremenu trenutno aktivan prijenos sa iskona na t com. Će da bude zanimljivo ![]() <mytubeelement id="myTubeRelayElementToPage" event="preferencesUpdated" data="{"bundle":{"label_delimitor":":","percentage":"%","smart_buffer":"Smart Buffer","start_playing_when_buffered":"Start playing when buffered","sound":"Sound","desktop_notification":"Desktop Notification","continuation_on_next_line":"-","loop":"Loop","only_notify":"Only Notify","estimated_time":"Estimated Time","global_preferences":"Global Preferences","no_notification_supported_on_your_browser":"No notification style supported on your browser version","video_buffered":"Video Buffered","buffered":"Buffered","hyphen":"-","buffered_message":"The video has been buffered as requested and is ready to play.","not_supported":"Not Supported","on":"On","off":"Off","click_to_enable_for_this_site":"Click to enable for this site","desktop_notification_denied":"You have denied permission for desktop notification for this site","notification_status_delimitor":";","error":"Error","adblock_interferance_message":"Adblock (or similar extension) is known to interfere with SmartVideo. Please add this url to adblock whitelist.","calculating":"Calculating","waiting":"Waiting","will_start_buffering_when_initialized":"Will start buffering when initialized","will_start_playing_when_initialized":"Will start playing when initialized","completed":"Completed","buffering_stalled":"Buffering is stalled. Will stop.","stopped":"Stopped","hr":"Hr","min":"Min","sec":"Sec","any_moment":"Any Moment","popup_donate_to":"Donate to","extension_id":null},"prefs":{"desktopNotification":true,"soundNotification":true,"logLevel":0,"enable":true,"loop":false,"hidePopup":false,"autoPlay":false,"autoBuffer":false,"autoPlayOnBuffer":false,"autoPlayOnBufferPercentage":42,"autoPlayOnSmartBuffer":true,"quality":"hd720","fshd":false,"onlyNotification":false,"enableFullScreen":true,"saveBandwidth":false,"hideAnnotations":false,"turnOffPagedBuffering":false}}"></mytubeelement><mytubeelement id="myTubeRelayElementToTab" event="relayPrefs" data="{"loadBundle":true}"></mytubeelement> |
#458 | ||
Postovi: 3,489
![]() Citiraj:
Nego jel ovaj cell id jedinstven ili samo u kombinaciji s nekim drugim parametrima? kod mene ovako na 3G, signal router pokazuje full signal, -38dBm: Code:
[DC-HSPA+ | HR VIP (21910) | 2100 MHz] [RSCP: -49, EC/IO: -2.0 (100.0%)] [CELL ID: 154945201, LAC: 6657] [1s] [DC-HSPA+ | HR VIP (21910) | 2100 MHz] [RSCP: -38, EC/IO: -3.0 (100.0%)] [CELL ID: 154945204, LAC: 6657] [0s] Na 4G osjetno lošije, -107 dBm: Code:
[LTE | HR VIP (21910) | 800 MHz (6225)] [RSRP: -109, RSRQ: -12, RSSI: -79, SINR: 3.0 (56.2%)] [CELL ID: 615505] [0s] Kako je ovdje cell ID drugačiji, izgleda da mi se router na 4G spaja na neku drugu, udaljeniju stanicu? |
#459 |
Lokacija: doma
Postovi: 2,895
![]() ![]() Koliko vidim iz raznih primjera jos nitko nema da mu SINR stoji na 100%. Kod mene varira izmedu 15 i 23 ali je uvjek 100%. RSRQ varira od -8 do -12 Ako iskopcam antene jedino sto se promjeni je RSRP koji ode na -70 ili -72, sve ostale vrijednosti ostanu identicno iste.... Brzina padne na nekih 50Mbps sa ovoga gore tako da sve ovo ostalo nema bas nikakve veze sa brzinom, bar u mojem primjeru. Znaci iskljucivo promjena RSRP-a utjece na promjenu brzine.
trebaš seedbox? |
#460 |
Datum registracije: Aug 2013
Postovi: 4,336
Imas vrlo jak signal, za razliku od @c-shadow. Sve ispod -88dBm se smatra jakim signalom, pa iz toga slijedi sve ostalo. Reference Signal Recieved Power: Better than -88dBm RSRP is a strong signal Between -89dBm and -96dBm is a very good signal Between -97dBm and -105dBm is good Between -106dBm and -112dBm is fair Worse than -113dBm RSRP is poor |
#461 |
Datum registracije: Apr 2008
Lokacija: Gračac
Postovi: 177
Tih 100% je RSSI kad dođe ispod (nemoj me uzet čvrsto za riječ) -60 EDIT SINR ide do 30, što veći to bolji, znači da nema smetnji, ako nema smetnji downlink je bolji RSRQ ja max -3, ali -6 je isto odličan CELL ID je točno ćelija na koju si spojen, jedan odašiljač ima naravno više ćelija Danas sam se vozio oko odašiljača i vidio tri različita IDa pa vjerojatno imaju tri ćelije na njemu. Svi brojevi od jednog odašiljača počinju isto, samo zadnji brojevi su različiti (u mom slučaju 1149009, 1149010, 1149011) Miješa se 1036881 i kažu tehničari da zbog toga imam nizak SINR i s time i loš download. EDIT: postotak koji je u programu je CSQ koji ovisi o RSSI i SINR vrijednostima. CSQ ide do 31 max i to je onda 100% general relationship between CSQ value and dBm in a noise free environment. CSQ RSSI (dBm) 7 -104 9 -100 14 -95 16 -90 21 -85 24 -80 27 -75 31 -70 Zadnje izmijenjeno od: dhalan. 08.03.2017. u 17:55. |
#462 | |
Lokacija: doma
Postovi: 2,895
Ok, tamo gdje je neko granicno podrucje pa neka antena mozda moze izvuci nesto vise ali u globalu sve preko 50Mbps najvise ovisi o tome koliko je odasiljac bukiran. Evo primjera, malo sam isao detaljnije ustimati poziciju routera. ![]() ![]() RSRP - bolji RSRQ - isti s time da nekad prebaci na -7 RSSI - bolji SINR - bolji Dakle sve bolje ali brzina ista kao prije. Ako ga iskljucim i ukljucim spaja se na istu celiju. Da sad opalim 15 testova, 2 do 3 bi prebacila 80Mbps, 2 do 3 bi podbacili sa oko 60Mbps a ostatak bi se vrtio oko 70/75Mbps kako vec nocu i ide... Nekad nocu vuce 85mbps po 2-3 sata ako se skida a nekada pola sata pa padne na 75Mbps Max. U globalu radnim danom su brzine bolje a problem je izgleda veci broj korisnika po pojedinom odasiljacu i to je najveci problem cini se...
trebaš seedbox? |
#463 |
Lokacija: Gračac
Postovi: 177
Moguće da je kod drugih zagušenje u pitanju, ali kod mene u Gračacu? Zagušenje? Nema šanse. Na ćeliji 1149010 na puno većoj udaljenosti vrlo lako dobijem 50Mbps. Na ćeliji 1149009 jedva dobijem 20Mbps, osim kad odem na 200m ispred ćelije, gdje imam 65Mbps. Ćelija 1449010 se kod moje kuće preklapa s 1036881 i dovoljno je da okrenem router na stranu da me prebaci s jedne na drugu. 1449010 kod mene kući ima SINR oko 10dB, na udaljenosti od 1,8km i direktnoj vidljivosti, 20Mpbs, a kada odem preko 5km daleko i bez vidljivosti, SINR ode na 24dB i brzina na 50Mbps, jer tamo nema 1036881 signala. Jedino je VIP pokrio ovaj dio prema Kninu s 1449010 ćelijom, HT i TELE2 tamo ne rade s 4g, ali zato TELE2 kod mene kući radi na 125Mbps downloada, a i to radi zato što im je odašijač na 1800Mhz, SINR se zakuca na 30dB, kao i SINR od HTa, ali oni rade na samo jednom odašiljaču. Jedino je moguće da je ovaj 1036881 prebukiran, ako pokriva čitavo područje prema Gospiću, a i to ću saznat ovih dana, samo da kolega dobije Homebox. Zadnje izmijenjeno od: dhalan. 01.03.2017. u 03:36. |
#464 | |
Lokacija: doma
Postovi: 2,895
![]() dio korisnika i eventualno pravi smetnju onima sto se spajaju na ovaj moj tako da iako sam nekih 500m od svojega brzina je pristojna. Evo ti friski primjer, sada mjereno. ![]() A vidi vrijednosti signala u odnosu na jucer sto sam okacio. ![]() Dakle sve isto vise manje. Jucer SINR bio 21.4 i 25.2 a vuklo 70Mbps. Sada SINR 24.8 a jedva prebacilo 60Mbps. I tak ce biti do jedno 21h, onda ce na +70Mbps... tableti razni, telefoni, 4G stickovi... sve to ljudi koriste kada dodju sa posla dok ne odu spat... Tu nikakva antena ne pomaze niti ima utjecaja na brzinu, sve ovo ja dobijem i bez ikakvih antena, sam ga moram malo bolje pozicionirati tj. ne moze stajati tamo gdje mi pase da stoji. @buljaka Jel se spajas na isti Cell ID kao ja ?
trebaš seedbox? |
#465 |
Datum registracije: Aug 2014
Postovi: 2,931
[LTE | HR VIP (21910) | 800 MHz (6225)] [RSRP: -87, RSRQ: -12, RSSI: -53, SINR: 3.0 (96.9%)] [CELL ID: 777041] [1s] nije isti cell id... hm.. |
#466 |
Lokacija: doma
Postovi: 2,895
trebaš seedbox? |
#467 |
Postovi: 2,931
Pa nemam pojma lol. Sad mi je još manje jasno... možda beliscanski ? Poslano iz mikrovalne |
#468 |
Lokacija: doma
Postovi: 2,895
Pa nebih rekao... jako je mala razlika i isti brojevi maltene. 777041 777043 To bi po nekoj logici trebao biti isti odasiljac ali hmmm... mozda je svaka antena 1 celija tamo gore no nisu ni iste velicine... Mozda jedna pokriva prvih neznam 1km a druga sve iza toga ili tako nesto. Cudno mi je, ama da mi se bas nikad nece spojiti ni na jednu drugu celiju.
trebaš seedbox? |
#469 |
Postovi: 2,931
Da. Čudno je . Meni je uvijek na ovoj ćeliji... vjerojatno je to valpovacki odašiljač a druga antena Poslano iz mikrovalne |
#470 | |
Lokacija: Gračac
Postovi: 477
Sljedece vece nasljeno mjesto je 15 km zracne linije negjde i ima oko 500-1000 stanovika. Vi nemate koncpet uopce koliko je Lika slabo naseljena. Kod njega je problem do mjesanja signala od dva repetitora 99%. |
#471 |
Glazba, auti, itd :D
Datum registracije: Dec 2011
Lokacija: Zg- Kvatrić
Postovi: 62
Nema veze ako ste blizu repetitora. Bas tada nema dovoljno signala. Najgore je ako su repetitori na brdu a vi ste u kotlini, Treba pregledati pokrivenost signala.
#472 | |
Postovi: 4,336
Za jos realniju sliku zauzeca bi trebao pobrojat kolko je klinaca na VIP-u, jer ti stano vise na netu i zauzimaju ti bandwidth ![]() |
#473 |
Lokacija: Gračac
Postovi: 177
Ma tu su ti svi većinom na MaxAdslu i na wifiju. I ne može biti zauzeće mreže 24/7. Što također ne objašnjava da kod odašiljača imam 65Mbps u bilo koje doba dana. To što na simpi na full signalu ne mogu dobit više od 30Mbps, e to bi već moglo bit što je odašiljač pretrpan. To ću provjeriti još ujutro u 5. Tad valjda svi spavaju. Osim noćne smjene. I mene. |
#474 | |
Lokacija: doma
Postovi: 2,895
![]() Naseljeni ste ko i mi u Slavoniji, kako bjeze tamo kod vas tak i odavde bjeze ali nemos ocekivati da na 3t koliko grad ima da imate 10 homeboxa ![]()
trebaš seedbox? |
#475 |
Postovi: 273
Pogledajte ove podatke kada mi prebaci na 3G UMTS prilikom telefonskog poziva, ili ako ručno prebacim na samo 3G (2 crtice signala). Tu brzinu dobijem oko 2 Mb/s, ovo je loše. Zadnje izmijenjeno od: selk. 02.03.2017. u 21:25. |
#476 |
Datum registracije: Mar 2017
Postovi: 12
Pozdrav svima na temi.., ovo mi je i prvi post i već tražim pomoć.... Imam jedno pitanje za znalce..., tj. više problem nego pitanje.., nije moj Box i moja veza već od kolege koji ima Vip HomeBox... Ovako.., radi se o Vip HomeBoxu - uređaj je HUAWEI E5172, flat internet, brzina otkida, wifi ide oko 50mbps i još malo jače preko mrežnog kabela i sve je to u redu.., laptop preko wifi mreže radi OK, preko mobitela se može surfati do mile volje.., ma milina.. Onda je došao na red Android TVBox.., nebitno koji jer kod svih je isti problem... - bilo koji addon, Specto, Exodus.., ma bilo što iz Kodija ne radi već samo vrti, vrti.., vrti.., i još malo vrti.. i ništa...., a test brzine iz Kodija (LibreElec) ili iz Androida direkt svi pokazuju brutano dobru vezu i brzinu... Isproban je reset modema.., reset Boxa.., novi FW na TVBoxu.. ma sve - dakle nebitno je koji TVBox, - internet brzina kida..., a ne može se gledati ama baš ništa... Čak je kod mrežnog spajanja nakon restartanja vratio TVBox na kineski jezik.., WTF...!??? (Beelink Mini MXIII)... Da li je itko imao sličan problem, da li je tu Vip stavio neku "rampu" za stream u Kodiju.., a iz samog Kodija (Wooki build) kad mjerim brzinu - dere ko mutavo.., sve 5, ali ne može se ništa gledati... Vjerujem da treba nešto podesiti u konfiguraciji na HomeBoxu.., ali što...!?? |
#477 | |
Lokacija: Gračac
Postovi: 477
S tim da je kod nas u juznoj lici to prije 5 st/km2 tako da ne nije ni priblizno blizu i kao sto dhalan kaze vecina ljudi ima fiksni internet i nema 4g ni na mobitelima. |
#478 | |
Lokacija: doma
Postovi: 2,895
Nema mladih ? Niko ne ide u skolu ? Ko ide u skolu ima Nokiu 3310 ? Znaci kod vas curke 15/16 godina vuku motalicu sa zicom kad fejsbuce ? ![]() Nemoj zahebavat... 3t ljudi nije malo, vecina novijih danasnjih telefona ima 4G i to jeftinjare... Dovoljno da pod velikim odmorom iz Srednje skole Gracac njih 50 se nakaci + sedmasi i osmasi iz osnovne i eto zagusenja mreze... Naravno, kod kolege @dhalan je vrlo moguce da mu drugi repetitor pravi smetnje u vidu da SINR nije cist ali evo jednog primjera zagusenja... U Slunju ima t-com repetitor i oko 50-tak ljudi boravi i koristi ga sa Poligona. Sve ok, svi surfaju na 3G sa stickovima itd... dodje samo 50 ljudi na vjezbu i raspad sustava... Dakle 100 ljudi sto telefonima sto laptopima ubili repetitor a sad me uvjeravas da na 3t ljudi ima 10 homeboxa u Gracacu i da mladi su zaostali pa ne trebaju 4G telefone...
trebaš seedbox? |
#479 |
Lokacija: Gračac
Postovi: 177
Ajd recimo 3 operatera na 3000 ljudi, svakom po 1000. Jel tih 1000 moraju nešto skidat ili je dovoljno da su na odašiljaču da bi se dijelio downlink. Sent from my E5823 using Tapatalk |
#480 | |
Datum registracije: Feb 2012
Lokacija: into the void
Postovi: 345
